[U-Boot] MX51 Support V2
This is the second version of patchset to support the Freescale i.MX51 processor and the MX51EVK board, after fixing comments from first review. Thanks everybody for comments !
Stefano Babic
This patch adds support for "imximage" (MX Boot Image) to the mkimage utility. The imximage is used on the Freescales's MX.51 processors.
Further details under doc/README.imximage.
This patch was tested on a Freescale mx51evk board.
Signed-off-by: Stefano Babic sbabic@denx.de --- common/image.c | 1 + doc/README.imximage | 73 +++++++++++++ include/image.h | 1 + tools/Makefile | 2 + tools/imximage.c | 293 +++++++++++++++++++++++++++++++++++++++++++++++++++ tools/imximage.h | 105 ++++++++++++++++++ tools/mkimage.c | 2 + tools/mkimage.h | 1 + 8 files changed, 478 insertions(+), 0 deletions(-) create mode 100644 doc/README.imximage create mode 100644 tools/imximage.c create mode 100644 tools/imximage.h
diff --git a/common/image.c b/common/image.c index 82e7aa4..9e49713 100644 --- a/common/image.c +++ b/common/image.c @@ -140,6 +140,7 @@ static table_entry_t uimage_type[] = { { IH_TYPE_STANDALONE, "standalone", "Standalone Program", }, { IH_TYPE_FLATDT, "flat_dt", "Flat Device Tree", }, { IH_TYPE_KWBIMAGE, "kwbimage", "Kirkwood Boot Image",}, + { IH_TYPE_IMXIMAGE, "imximage", "Freescale i.MX Boot Image",}, { -1, "", "", }, };
diff --git a/doc/README.imximage b/doc/README.imximage new file mode 100644 index 0000000..db765d2 --- /dev/null +++ b/doc/README.imximage @@ -0,0 +1,73 @@ +--------------------------------------------- +Imximage Boot Image generation using mkimage +--------------------------------------------- + +This document describes how to set up a U-Boot image +that can be booted by the Freescale i.MX51 processor. + +The i.MX51 can boot directly from NAND, SPI flash and SD card flash +using its internal boot ROM support. It can boot from an internal +UART, if booting from device media fails. +Booting from NOR flash does not require to use this image type. + +For more details refer Chapter 2 - System Boot and section 2.14 +(flash header description) of the processor's manual. + +This implementation does not use at the moment the secure boot feature +of the processor. The image is generated disabling all security fields. + +Command syntax: +-------------- +./tools/mkimage -l <mx u-boot_file> + to list the imx image file details + +./tools/mkimage -T imximage \ + -n <board specific configuration file> \ + -e <execution address> -d <u-boot binary> <output image file> + +for example, for the mx51evk board: +./tools/mkimage -n ./board/freescale/mx51evk/imximage.cfg \ + -T imximage -e 0x97800000 \ + -d u-boot.bin u-boot.imx + +The output image can be flashed on the board SPI flash or on a SD card. +In both cases, you have to copy the image at the offset required for the +chosen media devices (0x400 for both SPI flash or SD card). + +Please check Freescale documentation for further details. + +Board specific configuration file specifications: +------------------------------------------------ +1. This file must present in the $(BOARDDIR) and the name should be + imximage.cfg (since this is used in Makefile). +2. This file can have empty lines and lines starting with "#" as first + character to put comments. +3. This file can have configuration command lines as mentioned below, + any other information in this file is treated as invalid. + +Configuration command line syntax: +--------------------------------- +1. Each command line is must have two strings, first one command or address + and second one data string +2. Following are the valid command strings and associated data strings:- + Command string data string + -------------- ----------- + BOOT_FROM nand/spi/sd/onenand + Example: + BOOT_FROM spi + DATA type address value + + type: word=4, halfword=2, byte=1 + address: physycal register address + value: value to be set in register + All values are in in hexadecimal. + Example (write to IOMUXC): + DATA 4 0x73FA88a0 0x200 + +The processor support up to 60 register programming commands. An error +is generated if more commands are found in the configuration file. + +3. All commands are optional to program. + +------------------------------------------------ +Author: Stefano babic sbabic@denx.de diff --git a/include/image.h b/include/image.h index d2e78fe..3e959de 100644 --- a/include/image.h +++ b/include/image.h @@ -156,6 +156,7 @@ #define IH_TYPE_FILESYSTEM 7 /* Filesystem Image (any type) */ #define IH_TYPE_FLATDT 8 /* Binary Flat Device Tree Blob */ #define IH_TYPE_KWBIMAGE 9 /* Kirkwood Boot Image */ +#define IH_TYPE_IMXIMAGE 10 /* Freescale IMXBoot Image */
/* * Compression Types diff --git a/tools/Makefile b/tools/Makefile index 5b8c3c3..afc1d44 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -73,6 +73,7 @@ OBJ_FILES-$(CONFIG_CMD_NET) += gen_eth_addr.o OBJ_FILES-$(CONFIG_CMD_LOADS) += img2srec.o OBJ_FILES-$(CONFIG_INCA_IP) += inca-swap-bytes.o NOPED_OBJ_FILES-y += kwbimage.o +NOPED_OBJ_FILES-y += imximage.o NOPED_OBJ_FILES-y += mkimage.o OBJ_FILES-$(CONFIG_NETCONSOLE) += ncb.o NOPED_OBJ_FILES-y += os_support.o @@ -159,6 +160,7 @@ $(obj)mkimage$(SFX): $(obj)crc32.o \ $(obj)fit_image.o \ $(obj)image.o \ $(obj)kwbimage.o \ + $(obj)imximage.o \ $(obj)md5.o \ $(obj)mkimage.o \ $(obj)os_support.o \ diff --git a/tools/imximage.c b/tools/imximage.c new file mode 100644 index 0000000..76afb3b --- /dev/null +++ b/tools/imximage.c @@ -0,0 +1,293 @@ +/* + * (C) Copyright 2009 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de. + * + * (C) Copyright 2008 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include "mkimage.h" +#include <image.h> +#include "imximage.h" + +/* + * Supported commands for configuration file + */ +static table_entry_t imximage_cmds[] = { + {CMD_BOOT_FROM, "BOOT_FROM", "boot comand", }, + {CMD_DATA, "DATA", "Reg Write Data", }, + {-1, "", "", }, +}; + +/* + * Supported Boot options for configuration file + * this is needed to set the correct flash offset + */ +static table_entry_t imximage_bootops[] = { + {FLASH_OFFSET_SPI, "spi", "SPI Flash", }, + {FLASH_OFFSET_NAND, "nand", "NAND Flash", }, + {FLASH_OFFSET_SD, "sd", "SD Card", }, + {FLASH_OFFSET_ONENAND, "onenand", "OneNAND Flash",}, + {-1, "", "Invalid", }, +}; + + +static struct imx_header imximage_header; + +static uint32_t get_cfg_value(char *token, char *name, int linenr) +{ + char *endptr; + uint32_t value; + + errno = 0; + value = strtoul(token, &endptr, 16); + if (errno || (token == endptr)) { + fprintf(stderr, "Error: %s[%d] - Invalid hex data(%s)\n", + name, linenr, token); + exit(EXIT_FAILURE); + } + return value; +} + +static int imximage_check_image_types(uint8_t type) +{ + if (type == IH_TYPE_IMXIMAGE) + return EXIT_SUCCESS; + else + return EXIT_FAILURE; +} + +static int imximage_verify_header(unsigned char *ptr, int image_size, + struct mkimage_params *params) +{ + + struct imx_header *imx_hdr = (struct imx_header *) ptr; + flash_header_t *hdr = &imx_hdr->fhdr; + + /* Only a few checks can be done: search for magic numbers */ + if (hdr->app_code_barker != APP_CODE_BARKER) + return -FDT_ERR_BADSTRUCTURE; + + if (imx_hdr->dcd_table.preamble.barker != DCD_BARKER) + return -FDT_ERR_BADSTRUCTURE; + + return 0; +} + +static void imximage_print_header(const void *ptr) +{ + struct imx_header *imx_hdr = (struct imx_header *) ptr; + flash_header_t *hdr = &imx_hdr->fhdr; + uint32_t size; + flash_cfg_parms_t *ext_header; + + size = imx_hdr->dcd_table.preamble.length; + if (size > (MAX_HW_CFG_SIZE * sizeof(dcd_type_addr_data_t))) { + fprintf(stderr, "Image corrupt: DCD size %d exceed maximum %d\n", + size / sizeof(dcd_type_addr_data_t), MAX_HW_CFG_SIZE); + exit(EXIT_FAILURE); + } + + ext_header = (flash_cfg_parms_t *) ((uint32_t)&imx_hdr->dcd_table + + sizeof(dcd_preamble_t) + size); + + printf("Image Type: Freescale IMX Boot Image\n"); + printf("Data Size: "); + genimg_print_size(ext_header->length); + printf("Load Address: %08x\n", (unsigned int)hdr->app_dest_ptr); + printf("Entry Point: %08x\n", (unsigned int)hdr->app_code_jump_vector); +} + +static uint32_t imximage_parse_cfg_file(struct imx_header *imxhdr, char *name) +{ + FILE *fd = NULL; + char *line = NULL; + char *token, *saveptr1, *saveptr2; + int lineno = 0; + int fld, value; + uint32_t len; + int dcd_len = 0; + dcd_t *dcd = &imxhdr->dcd_table; + int32_t cmd; + + fd = fopen(name, "r"); + if (fd == 0) { + fprintf(stderr, "Error: %s - Can't open DCD file\n", name); + exit(EXIT_FAILURE); + } + + /* Very simple parsing, line starting with # are comments + * and are dropped + */ + while ((getline(&line, &len, fd)) > 0) { + lineno++; + + token = strtok_r(line, "\r\n", &saveptr1); + if (token == NULL) + continue; + + /* Check inside the single line */ + for (fld = CFG_COMMAND, cmd = CMD_INVALID, + line = token; ; line = NULL, fld++) { + token = strtok_r(line, " \t", &saveptr2); + if (token == NULL) + break; + + /* Drop all text starting with '#' as comments */ + if (token[0] == '#') + break; + + /* parse all fields in a single line */ + switch (fld) { + case CFG_COMMAND: + cmd = get_table_entry_id(imximage_cmds, + "imximage commands", token); + if (cmd < 0) { + fprintf(stderr, "Error: %s[%d] - Invalid command (%s)\n", + name, lineno, token); + exit(EXIT_FAILURE); + } + break; + case CFG_REG_SIZE: + switch (cmd) { + case CMD_BOOT_FROM: + /* Get flash header offset */ + imxhdr->flash_offset = get_table_entry_id(imximage_bootops, + "imximage boot option", token); + if (imxhdr->flash_offset == -1) { + fprintf(stderr, "Error: %s[%d] - Invalid boot device (%s)\n", + name, lineno, token); + exit(EXIT_FAILURE); + } + break; + case CMD_DATA: + value = get_cfg_value(token, name, lineno); + + /* Byte, halfword, word */ + if ((value != 1) && (value != 2) && (value != 4)) { + fprintf(stderr, "Error:%s[%d] - Invalid register size %d\n", + name, lineno, value); + exit(EXIT_FAILURE); + } + dcd->addr_data[dcd_len].type = value; + break; + } + + case CFG_REG_ADDRESS: + if (cmd == CMD_DATA) + dcd->addr_data[dcd_len].addr = get_cfg_value(token, name, lineno); + break; + case CFG_REG_VALUE: + if (cmd == CMD_DATA) { + dcd->addr_data[dcd_len].value = get_cfg_value(token, name, lineno); + dcd_len++; + } + break; + } + } + + if (dcd_len > MAX_HW_CFG_SIZE) { + fprintf(stderr, "Error:%s[%d] - DCD table exceeds maximum size(%d)\n", + name, lineno, MAX_HW_CFG_SIZE); + } + } + dcd->preamble.barker = DCD_BARKER; + dcd->preamble.length = dcd_len * sizeof(dcd_type_addr_data_t); + fclose(fd); + + return dcd->preamble.length; +} + +static void imximage_set_header(void *ptr, struct stat *sbuf, int ifd, + struct mkimage_params *params) +{ + struct imx_header *hdr = (struct imx_header *)ptr; + flash_header_t *fhdr = &hdr->fhdr; + int dcd_len; + flash_cfg_parms_t *ext_header; + uint32_t base_offset; + + /* Set default offset */ + hdr->flash_offset = FLASH_OFFSET_STANDARD; + + /* Set magic number */ + fhdr->app_code_barker = APP_CODE_BARKER; + + /* Parse dcd configuration file */ + dcd_len = imximage_parse_cfg_file(hdr, params->imagename); + + fhdr->app_dest_ptr = params->addr; + fhdr->app_dest_ptr = params->ep - hdr->flash_offset - + sizeof(struct imx_header); + fhdr->app_code_jump_vector = params->ep; + + base_offset = fhdr->app_dest_ptr + hdr->flash_offset ; + fhdr->dcd_ptr_ptr = (uint32_t) ((uint32_t)&fhdr->dcd_ptr - + (uint32_t)&fhdr->app_code_jump_vector) + base_offset ; + + fhdr->dcd_ptr = base_offset + ((uint32_t)&hdr->dcd_table - (uint32_t)&hdr->fhdr); + + /* The external flash header must be at the end of the DCD table */ + ext_header = (flash_cfg_parms_t *) ((uint32_t)&hdr->dcd_table + dcd_len + + sizeof(dcd_preamble_t)); + ext_header->length = sbuf->st_size + hdr->flash_offset + sizeof(struct imx_header); + + /* Security feature are not supported */ + fhdr->app_code_csf = 0; + fhdr->super_root_key = NULL; + +} + +int imximage_check_params(struct mkimage_params *params) +{ + if (!params) + return CFG_INVALID; + if (!strlen(params->imagename)) { + fprintf(stderr, "Error:%s - Configuration file not specified, " + "it is needed for imximage generation\n", + params->cmdname); + return CFG_INVALID; + } + return (params->dflag && (params->fflag || params->lflag)) || + (params->fflag && (params->dflag || params->lflag)) || + (params->lflag && (params->dflag || params->fflag)) || + (params->xflag) || !(strlen(params->imagename)); +} + +/* + * imximage parameters + */ +static struct image_type_params imximage_params = { + .name = "Freescale i.MX 51 Boot Image support", + .header_size = sizeof(struct imx_header), + .hdr = (void *)&imximage_header, + .check_image_type = imximage_check_image_types, + .verify_header = imximage_verify_header, + .print_header = imximage_print_header, + .set_header = imximage_set_header, + .check_params = imximage_check_params, +}; + +void init_imx_image_type(void) +{ + mkimage_register(&imximage_params); +} diff --git a/tools/imximage.h b/tools/imximage.h new file mode 100644 index 0000000..75955e3 --- /dev/null +++ b/tools/imximage.h @@ -0,0 +1,105 @@ +/* + * (C) Copyright 2009 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _IMXIMAGE_H_ +#define _IMXIMAGE_H_ + +#define MAX_HW_CFG_SIZE 60 /* Max number of registers imx.51 can set */ +#define MAX_EXP_SIZE 4 +#define APP_CODE_BARKER 0xB1 +#define DCD_BARKER 0xB17219E9 +#define HEADER_OFFSET 0x400 + + +#define CMD_DATA_STR "DATA" +#define FLASH_OFFSET_STANDARD 0x400 +#define FLASH_OFFSET_NAND FLASH_OFFSET_STANDARD +#define FLASH_OFFSET_SD FLASH_OFFSET_STANDARD +#define FLASH_OFFSET_SPI FLASH_OFFSET_STANDARD +#define FLASH_OFFSET_ONENAND 0x100 + +enum imximage_cmd { + CMD_INVALID, + CMD_BOOT_FROM, + CMD_DATA +}; + +enum imximage_fld_types { + CFG_INVALID = -1, + CFG_COMMAND, + CFG_REG_SIZE, + CFG_REG_ADDRESS, + CFG_REG_VALUE +}; + +typedef struct { + uint8_t rsa_exponent[MAX_EXP_SIZE]; /* RSA public exponent */ + uint8_t *rsa_modulus; /* RSA modulus pointer */ + uint16_t exponent_size; /* Exponent size (bytes) */ + uint16_t modulus_size; /* Modulus size (bytes) */ + uint8_t init_flag; /* Indicates if key initialized */ +} hab_rsa_public_key; + +typedef struct { + uint32_t type; /* Type of pointer (byte, halfword, word, wait/read) */ + uint32_t addr; /* Address to write to */ + uint32_t value; /* Data to write */ +} dcd_type_addr_data_t; + +typedef struct { + uint32_t barker; /* Barker for sanity check */ + uint32_t length; /* Device configuration length (without preamble) */ +} dcd_preamble_t; + +typedef struct { + dcd_preamble_t preamble; + dcd_type_addr_data_t addr_data[MAX_HW_CFG_SIZE]; +} dcd_t; + +typedef struct { + uint32_t app_code_jump_vector; + uint32_t app_code_barker; + uint32_t app_code_csf; + uint32_t dcd_ptr_ptr; + hab_rsa_public_key *super_root_key; + uint32_t dcd_ptr; + uint32_t app_dest_ptr; +} flash_header_t; + +typedef struct { + uint32_t length; /* Length of data to be read from flash */ +} flash_cfg_parms_t; + +struct imx_header { + flash_header_t fhdr; + dcd_t dcd_table; + flash_cfg_parms_t ext_header; + uint32_t flash_offset; +}; + +struct reg_config { + uint32_t raddr; + uint32_t rdata; +}; + +#endif /* _IMXIMAGE_H_ */ diff --git a/tools/mkimage.c b/tools/mkimage.c index 1bed933..8b5d7f5 100644 --- a/tools/mkimage.c +++ b/tools/mkimage.c @@ -150,6 +150,8 @@ main (int argc, char **argv)
/* Init Kirkwood Boot image generation/list support */ init_kwb_image_type (); + /* Init Freescale imx.51 Boot image generation/list support */ + init_imx_image_type (); /* Init FIT image generation/list support */ init_fit_image_type (); /* Init Default image generation/list support */ diff --git a/tools/mkimage.h b/tools/mkimage.h index ec67336..9033a7d 100644 --- a/tools/mkimage.h +++ b/tools/mkimage.h @@ -140,6 +140,7 @@ void mkimage_register (struct image_type_params *tparams); * Supported image types init functions */ void init_kwb_image_type (void); +void init_imx_image_type (void); void init_default_image_type (void); void init_fit_image_type (void);
The patch add initial support for the Freescale i.MX51 processor (family arm cortex_a8).
Signed-off-by: Fred Fan fanyefeng@gmail.com Signed-off-by: Stefano Babic sbabic@denx.de --- cpu/arm_cortexa8/mx51/Makefile | 48 +++++ cpu/arm_cortexa8/mx51/clock.c | 287 +++++++++++++++++++++++++++++ cpu/arm_cortexa8/mx51/iomux.c | 201 +++++++++++++++++++++ cpu/arm_cortexa8/mx51/lowlevel_init.S | 320 +++++++++++++++++++++++++++++++++ cpu/arm_cortexa8/mx51/soc.c | 78 ++++++++ cpu/arm_cortexa8/mx51/timer.c | 122 +++++++++++++ cpu/arm_cortexa8/mx51/u-boot.lds | 61 +++++++ 7 files changed, 1117 insertions(+), 0 deletions(-) create mode 100644 cpu/arm_cortexa8/mx51/Makefile create mode 100644 cpu/arm_cortexa8/mx51/clock.c create mode 100644 cpu/arm_cortexa8/mx51/iomux.c create mode 100644 cpu/arm_cortexa8/mx51/lowlevel_init.S create mode 100644 cpu/arm_cortexa8/mx51/soc.c create mode 100644 cpu/arm_cortexa8/mx51/timer.c create mode 100644 cpu/arm_cortexa8/mx51/u-boot.lds
diff --git a/cpu/arm_cortexa8/mx51/Makefile b/cpu/arm_cortexa8/mx51/Makefile new file mode 100644 index 0000000..4d82293 --- /dev/null +++ b/cpu/arm_cortexa8/mx51/Makefile @@ -0,0 +1,48 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2009 Freescale Semiconductor, Inc. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).a + +COBJS = soc.o clock.o iomux.o timer.o +SOBJS = lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/cpu/arm_cortexa8/mx51/clock.c b/cpu/arm_cortexa8/mx51/clock.c new file mode 100644 index 0000000..bb66ec2 --- /dev/null +++ b/cpu/arm_cortexa8/mx51/clock.c @@ -0,0 +1,287 @@ +/* + * (C) Copyright 2007 + * Sascha Hauer, Pengutronix + * + * (C) Copyright 2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/crm_regs.h> + +enum pll_clocks { + PLL1_CLOCK = 0, + PLL2_CLOCK, + PLL3_CLOCK, + PLL_CLOCKS, +}; + +struct mxc_pll_reg *mxc_plls[PLL_CLOCKS] = { + [PLL1_CLOCK] = (struct mxc_pll_reg *)PLL1_BASE_ADDR, + [PLL2_CLOCK] = (struct mxc_pll_reg *)PLL2_BASE_ADDR, + [PLL3_CLOCK] = (struct mxc_pll_reg *)PLL3_BASE_ADDR, +}; + +struct mxc_ccm_reg *mxc_ccm = MXC_CCM_BASE; + +/* + * Calculate the frequence of this pll. + */ +static u32 decode_pll(struct mxc_pll_reg *pll, u32 infreq) +{ + u32 mfi, mfn, mfd, pd; + + mfn = __raw_readl(&pll->mfn); + mfd = __raw_readl(&pll->mfd) + 1; + mfi = __raw_readl(&pll->op); + pd = (mfi & 0xF) + 1; + mfi = (mfi >> 4) & 0xF; + mfi = (mfi >= 5) ? mfi : 5; + + return ((4 * (infreq / 1000) * (mfi * mfd + mfn)) / (mfd * pd)) * 1000; +} + +/* + * Get mcu main rate + */ +u32 get_mcu_main_clk(void) +{ + u32 reg, freq; + + reg = (__raw_readl(&mxc_ccm->cacrr) & MXC_CCM_CACRR_ARM_PODF_MASK) >> + MXC_CCM_CACRR_ARM_PODF_OFFSET; + freq = decode_pll(mxc_plls[PLL1_CLOCK], CONFIG_MX51_HCLK_FREQ); + return freq / (reg + 1); +} + +/* + * Get the rate of peripheral's root clock. + */ +static u32 get_periph_clk(void) +{ + u32 reg; + + reg = __raw_readl(&mxc_ccm->cbcdr); + if (!(reg & MXC_CCM_CBCDR_PERIPH_CLK_SEL)) + return decode_pll(mxc_plls[PLL2_CLOCK], CONFIG_MX51_HCLK_FREQ); + reg = __raw_readl(&mxc_ccm->cbcmr); + switch ((reg & MXC_CCM_CBCMR_PERIPH_CLK_SEL_MASK) >> + MXC_CCM_CBCMR_PERIPH_CLK_SEL_OFFSET) { + case 0: + return decode_pll(mxc_plls[PLL1_CLOCK], CONFIG_MX51_HCLK_FREQ); + case 1: + return decode_pll(mxc_plls[PLL3_CLOCK], CONFIG_MX51_HCLK_FREQ); + default: + return 0; + } + /* NOTREACHED */ +} + +/* + * Get the rate of ipg clock. + */ +static u32 get_ipg_clk(void) +{ + u32 ahb_podf, ipg_podf; + + ahb_podf = __raw_readl(&mxc_ccm->cbcdr); + ipg_podf = (ahb_podf & MXC_CCM_CBCDR_IPG_PODF_MASK) >> + MXC_CCM_CBCDR_IPG_PODF_OFFSET; + ahb_podf = (ahb_podf & MXC_CCM_CBCDR_AHB_PODF_MASK) >> + MXC_CCM_CBCDR_AHB_PODF_OFFSET; + return get_periph_clk() / ((ahb_podf + 1) * (ipg_podf + 1)); +} + +/* + * Get the rate of ipg_per clock. + */ +static u32 get_ipg_per_clk(void) +{ + u32 pred1, pred2, podf; + + if (__raw_readl(&mxc_ccm->cbcmr) & MXC_CCM_CBCMR_PERCLK_IPG_CLK_SEL) + return get_ipg_clk(); + /* Fixme: not handle what about lpm*/ + podf = __raw_readl(&mxc_ccm->cbcdr); + pred1 = (podf & MXC_CCM_CBCDR_PERCLK_PRED1_MASK) >> + MXC_CCM_CBCDR_PERCLK_PRED1_OFFSET; + pred2 = (podf & MXC_CCM_CBCDR_PERCLK_PRED2_MASK) >> + MXC_CCM_CBCDR_PERCLK_PRED2_OFFSET; + podf = (podf & MXC_CCM_CBCDR_PERCLK_PODF_MASK) >> + MXC_CCM_CBCDR_PERCLK_PODF_OFFSET; + + return get_periph_clk() / ((pred1 + 1) * (pred2 + 1) * (podf + 1)); +} + +/* + * Get the rate of uart clk. + */ +static u32 get_uart_clk(void) +{ + unsigned int freq, reg, pred, podf; + + reg = __raw_readl(&mxc_ccm->cscmr1); + switch ((reg & MXC_CCM_CSCMR1_UART_CLK_SEL_MASK) >> + MXC_CCM_CSCMR1_UART_CLK_SEL_OFFSET) { + case 0x0: + freq = decode_pll(mxc_plls[PLL1_CLOCK], + CONFIG_MX51_HCLK_FREQ); + break; + case 0x1: + freq = decode_pll(mxc_plls[PLL2_CLOCK], + CONFIG_MX51_HCLK_FREQ); + break; + case 0x2: + freq = decode_pll(mxc_plls[PLL3_CLOCK], + CONFIG_MX51_HCLK_FREQ); + break; + default: + return 66500000; + } + + reg = __raw_readl(&mxc_ccm->cscdr1); + + pred = (reg & MXC_CCM_CSCDR1_UART_CLK_PRED_MASK) >> + MXC_CCM_CSCDR1_UART_CLK_PRED_OFFSET; + + podf = (reg & MXC_CCM_CSCDR1_UART_CLK_PODF_MASK) >> + MXC_CCM_CSCDR1_UART_CLK_PODF_OFFSET; + freq /= (pred + 1) * (podf + 1); + + return freq; +} + +/* + * This function returns the low power audio clock. + */ +u32 get_lp_apm(void) +{ + u32 ret_val = 0; + u32 ccsr = __raw_readl(&mxc_ccm->ccsr); + + if (((ccsr >> 9) & 1) == 0) + ret_val = CONFIG_MX51_HCLK_FREQ; + else + ret_val = ((32768 * 1024)); + + return ret_val; +} + +/* + * get cspi clock rate. + */ +static u32 get_cspi_clk(void) +{ + u32 ret_val = 0, pdf, pre_pdf, clk_sel; + u32 cscmr1 = __raw_readl(&mxc_ccm->cscmr1); + u32 cscdr2 = __raw_readl(&mxc_ccm->cscdr2); + + pre_pdf = (cscdr2 & MXC_CCM_CSCDR2_CSPI_CLK_PRED_MASK) \ + >> MXC_CCM_CSCDR2_CSPI_CLK_PRED_OFFSET; + pdf = (cscdr2 & MXC_CCM_CSCDR2_CSPI_CLK_PODF_MASK) \ + >> MXC_CCM_CSCDR2_CSPI_CLK_PODF_OFFSET; + clk_sel = (cscmr1 & MXC_CCM_CSCMR1_CSPI_CLK_SEL_MASK) \ + >> MXC_CCM_CSCMR1_CSPI_CLK_SEL_OFFSET; + + switch (clk_sel) { + case 0: + ret_val = decode_pll(mxc_plls[PLL1_CLOCK], + CONFIG_MX51_HCLK_FREQ) / + ((pre_pdf + 1) * (pdf + 1)); + break; + case 1: + ret_val = decode_pll(mxc_plls[PLL2_CLOCK], + CONFIG_MX51_HCLK_FREQ) / + ((pre_pdf + 1) * (pdf + 1)); + break; + case 2: + ret_val = decode_pll(mxc_plls[PLL3_CLOCK], + CONFIG_MX51_HCLK_FREQ) / + ((pre_pdf + 1) * (pdf + 1)); + break; + default: + ret_val = get_lp_apm() / ((pre_pdf + 1) * (pdf + 1)); + break; + } + + return ret_val; +} + +/* + * The API of get mxc clockes. + */ +unsigned int mxc_get_clock(enum mxc_clock clk) +{ + switch (clk) { + case MXC_ARM_CLK: + return get_mcu_main_clk(); + case MXC_AHB_CLK: + break; + case MXC_IPG_CLK: + return get_ipg_clk(); + case MXC_IPG_PERCLK: + return get_ipg_per_clk(); + case MXC_UART_CLK: + return get_uart_clk(); + case MXC_CSPI_CLK: + return get_cspi_clk(); + case MXC_FEC_CLK: + return decode_pll(mxc_plls[PLL1_CLOCK], + CONFIG_MX51_HCLK_FREQ); + default: + break; + } + return -1; +} + +u32 imx_get_uartclk(void) +{ + return get_uart_clk(); +} + +/* + * Dump some core clockes. + */ +int do_mx51_showclocks(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + u32 freq; + + freq = decode_pll(mxc_plls[PLL1_CLOCK], CONFIG_MX51_HCLK_FREQ); + printf("mx51 pll1: %dMHz\n", freq / 1000000); + freq = decode_pll(mxc_plls[PLL2_CLOCK], CONFIG_MX51_HCLK_FREQ); + printf("mx51 pll2: %dMHz\n", freq / 1000000); + freq = decode_pll(mxc_plls[PLL3_CLOCK], CONFIG_MX51_HCLK_FREQ); + printf("mx51 pll3: %dMHz\n", freq / 1000000); + printf("ipg clock : %dHz\n", mxc_get_clock(MXC_IPG_CLK)); + printf("ipg per clock : %dHz\n", mxc_get_clock(MXC_IPG_PERCLK)); + + return 0; +} + +/***************************************************/ + +U_BOOT_CMD( + mx51clocks, CONFIG_SYS_MAXARGS, 1, do_mx51_showclocks, + "display mx51 clocks\n", + "" +); diff --git a/cpu/arm_cortexa8/mx51/iomux.c b/cpu/arm_cortexa8/mx51/iomux.c new file mode 100644 index 0000000..b607fa7 --- /dev/null +++ b/cpu/arm_cortexa8/mx51/iomux.c @@ -0,0 +1,201 @@ +/* + * (C) Copyright 2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/mx51_pins.h> +#include <asm/arch/iomux.h> + +/* IOMUX register (base) addresses */ +enum iomux_reg_addr { + IOMUXGPR0 = IOMUXC_BASE_ADDR, + IOMUXGPR1 = IOMUXC_BASE_ADDR + 0x004, + IOMUXSW_MUX_CTL = IOMUXC_BASE_ADDR, + IOMUXSW_MUX_END = IOMUXC_BASE_ADDR + MUX_I_END, + IOMUXSW_PAD_CTL = IOMUXC_BASE_ADDR + PAD_I_START, + IOMUXSW_INPUT_CTL = IOMUXC_BASE_ADDR, +}; + +#define MUX_PIN_NUM_MAX (((MUX_I_END - MUX_I_START) >> 2) + 1) + +/* Get the iomux register address of this pin */ +static inline u32 get_mux_reg(iomux_pin_name_t pin) +{ + u32 mux_reg = PIN_TO_IOMUX_MUX(pin); + + if (is_soc_rev(CHIP_REV_2_0) < 0) { + /* + * Fixup register address: + * i.MX51 TO1 has offset with the register + * which is define as TO2. + */ + if ((pin == MX51_PIN_NANDF_RB5) || + (pin == MX51_PIN_NANDF_RB6) || + (pin == MX51_PIN_NANDF_RB7)) + ; /* Do nothing */ + else if (mux_reg >= 0x2FC) + mux_reg += 8; + else if (mux_reg >= 0x130) + mux_reg += 0xC; + } + mux_reg += IOMUXSW_MUX_CTL; + return mux_reg; +} + +/* Get the pad register address of this pin */ +static inline u32 get_pad_reg(iomux_pin_name_t pin) +{ + u32 pad_reg = PIN_TO_IOMUX_PAD(pin); + + if (is_soc_rev(CHIP_REV_2_0) < 0) { + /* + * Fixup register address: + * i.MX51 TO1 has offset with the register + * which is define as TO2. + */ + if ((pin == MX51_PIN_NANDF_RB5) || + (pin == MX51_PIN_NANDF_RB6) || + (pin == MX51_PIN_NANDF_RB7)) + ; /* Do nothing */ + else if (pad_reg == 0x4D0 - PAD_I_START) + pad_reg += 0x4C; + else if (pad_reg == 0x860 - PAD_I_START) + pad_reg += 0x9C; + else if (pad_reg >= 0x804 - PAD_I_START) + pad_reg += 0xB0; + else if (pad_reg >= 0x7FC - PAD_I_START) + pad_reg += 0xB4; + else if (pad_reg >= 0x4E4 - PAD_I_START) + pad_reg += 0xCC; + else + pad_reg += 8; + } + pad_reg += IOMUXSW_PAD_CTL; + return pad_reg; +} + +/* Get the last iomux register address */ +static inline u32 get_mux_end(void) +{ + if (is_soc_rev(CHIP_REV_2_0) < 0) + return IOMUXC_BASE_ADDR + (0x3F8 - 4); + else + return IOMUXC_BASE_ADDR + (0x3F0 - 4); +} + +/*! + * This function is used to configure a pin through the IOMUX module. + * @param pin a pin number as defined in \b #iomux_pin_name_t + * @param cfg an output function as defined in \b #iomux_pin_cfg_t + * + * @return 0 if successful; Non-zero otherwise + */ +static void iomux_config_mux(iomux_pin_name_t pin, iomux_pin_cfg_t cfg) +{ + u32 mux_reg = get_mux_reg(pin); + + if ((mux_reg > get_mux_end()) || (mux_reg < IOMUXSW_MUX_CTL)) + return ; + if (cfg == IOMUX_CONFIG_GPIO) + writel(PIN_TO_ALT_GPIO(pin), mux_reg); + else + writel(cfg, mux_reg); +} + +/*! + * Request ownership for an IO pin. This function has to be the first one + * being called before that pin is used. The caller has to check the + * return value to make sure it returns 0. + * + * @param pin a name defined by \b iomux_pin_name_t + * @param cfg an input function as defined in \b #iomux_pin_cfg_t + * + */ +void mxc_request_iomux(iomux_pin_name_t pin, iomux_pin_cfg_t cfg) +{ + iomux_config_mux(pin, cfg); +} + +/*! + * Release ownership for an IO pin + * + * @param pin a name defined by \b iomux_pin_name_t + * @param cfg an input function as defined in \b #iomux_pin_cfg_t + */ +void mxc_free_iomux(iomux_pin_name_t pin, iomux_pin_cfg_t cfg) +{ +} + +/*! + * This function configures the pad value for a IOMUX pin. + * + * @param pin a pin number as defined in \b #iomux_pin_name_t + * @param config the ORed value of elements defined in \b #iomux_pad_config_t + */ +void mxc_iomux_set_pad(iomux_pin_name_t pin, u32 config) +{ + u32 pad_reg = get_pad_reg(pin); + writel(config, pad_reg); +} + +unsigned int mxc_iomux_get_pad(iomux_pin_name_t pin) +{ + u32 pad_reg = get_pad_reg(pin); + return readl(pad_reg); +} +/*! + * This function configures input path. + * + * @param input index of input select register as defined in \b + * #iomux_input_select_t + * @param config the binary value of elements defined in \b + * #iomux_input_config_t + */ +void mxc_iomux_set_input(iomux_input_select_t input, u32 config) +{ + u32 reg; + + if (is_soc_rev(CHIP_REV_2_0) < 0) { + if (input == MUX_IN_IPU_IPP_DI_0_IND_DISPB_SD_D_SELECT_INPUT) + input -= 4; + else if (input == + MUX_IN_IPU_IPP_DI_1_IND_DISPB_SD_D_SELECT_INPUT) + input -= 3; + else if (input >= MUX_IN_KPP_IPP_IND_COL_6_SELECT_INPUT) + input -= 2; + else if (input >= + MUX_IN_HSC_MIPI_MIX_PAR_SISG_TRIG_SELECT_INPUT) + input -= 5; + else if (input >= + MUX_IN_HSC_MIPI_MIX_IPP_IND_SENS1_DATA_EN_SELECT_INPUT) + input -= 3; + else if (input >= MUX_IN_ECSPI2_IPP_IND_SS_B_3_SELECT_INPUT) + input -= 2; + else if (input >= MUX_IN_CCM_PLL1_BYPASS_CLK_SELECT_INPUT) + input -= 1; + reg = IOMUXSW_INPUT_CTL + (input << 2) + INPUT_CTL_START_TO1; + } else + reg = IOMUXSW_INPUT_CTL + (input << 2) + INPUT_CTL_START; + + writel(config, reg); +} diff --git a/cpu/arm_cortexa8/mx51/lowlevel_init.S b/cpu/arm_cortexa8/mx51/lowlevel_init.S new file mode 100644 index 0000000..843a7b8 --- /dev/null +++ b/cpu/arm_cortexa8/mx51/lowlevel_init.S @@ -0,0 +1,320 @@ +/* + * Copyright (C) 2007, Guennadi Liakhovetski lg@denx.de + * + * (C) Copyright 2009 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <asm/arch/imx-regs.h> + +/* + * return soc version + * 0x10: TO1 + * 0x20: TO2 + * 0x30: TO3 + */ +.macro check_soc_version ret, tmp +.endm + +/* + * L2CC Cache setup/invalidation/disable + */ +.macro init_l2cc + /* explicitly disable L2 cache */ + mrc 15, 0, r0, c1, c0, 1 + bic r0, r0, #0x2 + mcr 15, 0, r0, c1, c0, 1 + + /* reconfigure L2 cache aux control reg */ + mov r0, #0xC0 /* tag RAM */ + add r0, r0, #0x4 /* data RAM */ + orr r0, r0, #(1 << 24) /* disable write allocate delay */ + orr r0, r0, #(1 << 23) /* disable write allocate combine */ + orr r0, r0, #(1 << 22) /* disable write allocate */ + + cmp r3, #0x10 /* r3 contains the silicon rev */ + orrls r0, r0, #(1 << 25) /* disable write combine for TO 2 and lower revs */ + + mcr 15, 1, r0, c9, c0, 2 +.endm /* init_l2cc */ + +/* AIPS setup - Only setup MPROTx registers. + * The PACR default values are good.*/ +.macro init_aips + /* + * Set all MPROTx to be non-bufferable, trusted for R/W, + * not forced to user-mode. + */ + ldr r0, =AIPS1_BASE_ADDR + ldr r1, =0x77777777 + str r1, [r0, #0x0] + str r1, [r0, #0x4] + ldr r0, =AIPS2_BASE_ADDR + str r1, [r0, #0x0] + str r1, [r0, #0x4] + /* + * Clear the on and off peripheral modules Supervisor Protect bit + * for SDMA to access them. Did not change the AIPS control registers + * (offset 0x20) access type + */ +.endm /* init_aips */ + +/* MAX (Multi-Layer AHB Crossbar Switch) setup */ +.macro init_max +.endm /* init_max */ + +/* M4IF setup */ +.macro init_m4if + /* VPU and IPU given higher priority (0x4) + * IPU accesses with ID=0x1 given highest priority (=0xA) + */ + ldr r0, =M4IF_BASE_ADDR + + ldr r1, =0x00000203 + str r1, [r0, #0x40] + + ldr r1, =0x0 + str r1, [r0, #0x44] + + ldr r1, =0x00120125 + str r1, [r0, #0x9C] + + ldr r1, =0x001901A3 + str r1, [r0, #0x48] + +/* + ldr r1, =0x00000a01 + str r1, [r0, #0x48] + ldr r1, =0x00000404 + str r1, [r0, #0x40] +*/ +.endm /* init_m4if */ + +/* To support 133MHz DDR */ +.macro init_drive_strength +.endm /* init_drive_strength */ + +/* CPLD on CS5 setup */ +.macro init_debug_board +.endm /* init_debug_board */ + +.macro setup_pll pll, freq + ldr r2, =\pll + ldr r1, =0x00001232 + str r1, [r2, #PLL_DP_CTL] /* Set DPLL ON (set UPEN bit): BRMO=1 */ + mov r1, #0x2 + str r1, [r2, #PLL_DP_CONFIG] /* Enable auto-restart AREN bit */ + + str r3, [r2, #PLL_DP_OP] + str r3, [r2, #PLL_DP_HFS_OP] + + str r4, [r2, #PLL_DP_MFD] + str r4, [r2, #PLL_DP_HFS_MFD] + + str r5, [r2, #PLL_DP_MFN] + str r5, [r2, #PLL_DP_HFS_MFN] + + ldr r1, =0x00001232 + str r1, [r2, #PLL_DP_CTL] +1: ldr r1, [r2, #PLL_DP_CTL] + ands r1, r1, #0x1 + beq 1b +.endm + +.macro init_clock + ldr r0, =CCM_BASE_ADDR + + /* Gate of clocks to the peripherals first */ + ldr r1, =0x3FFFFFFF + str r1, [r0, #CLKCTL_CCGR0] + ldr r1, =0x0 + str r1, [r0, #CLKCTL_CCGR1] + str r1, [r0, #CLKCTL_CCGR2] + str r1, [r0, #CLKCTL_CCGR3] + + ldr r1, =0x00030000 + str r1, [r0, #CLKCTL_CCGR4] + ldr r1, =0x00FFF030 + str r1, [r0, #CLKCTL_CCGR5] + ldr r1, =0x00000300 + str r1, [r0, #CLKCTL_CCGR6] + + /* Disable IPU and HSC dividers */ + mov r1, #0x60000 + str r1, [r0, #CLKCTL_CCDR] + + /* Make sure to switch the DDR away from PLL 1 */ + ldr r1, =0x19239145 + str r1, [r0, #CLKCTL_CBCDR] + /* make sure divider effective */ +1: ldr r1, [r0, #CLKCTL_CDHIPR] + cmp r1, #0x0 + bne 1b + + /* Switch ARM to step clock */ + mov r1, #0x4 + str r1, [r0, #CLKCTL_CCSR] + mov r3, #DP_OP_800 + mov r4, #DP_MFD_800 + mov r5, #DP_MFN_800 + setup_pll PLL1_BASE_ADDR + + mov r3, #DP_OP_665 + mov r4, #DP_MFD_665 + mov r5, #DP_MFN_665 + setup_pll PLL3_BASE_ADDR + + /* Switch peripheral to PLL 3 */ + ldr r0, =CCM_BASE_ADDR + ldr r1, =0x000010C0 + str r1, [r0, #CLKCTL_CBCMR] + ldr r1, =0x13239145 + str r1, [r0, #CLKCTL_CBCDR] + mov r3, #DP_OP_665 + mov r4, #DP_MFD_665 + mov r5, #DP_MFN_665 + setup_pll PLL2_BASE_ADDR + + /* Switch peripheral to PLL2 */ + ldr r0, =CCM_BASE_ADDR + ldr r1, =0x19239145 + str r1, [r0, #CLKCTL_CBCDR] + ldr r1, =0x000020C0 + str r1, [r0, #CLKCTL_CBCMR] + + mov r3, #DP_OP_216 + mov r4, #DP_MFD_216 + mov r5, #DP_MFN_216 + setup_pll PLL3_BASE_ADDR + + + /* Set the platform clock dividers */ + ldr r0, =ARM_BASE_ADDR + ldr r1, =0x00000725 + str r1, [r0, #0x14] + + ldr r0, =CCM_BASE_ADDR + /* Run TO 3.0 at Full speed, for other TO's wait till we increase VDDGP */ + ldr r1, =0x0 + ldr r3, [r1, #ROM_SI_REV] + cmp r3, #0x10 + movls r1, #0x1 + movhi r1, #0 + str r1, [r0, #CLKCTL_CACRR] + + /* Switch ARM back to PLL 1 */ + mov r1, #0 + str r1, [r0, #CLKCTL_CCSR] + + /* setup the rest */ + /* Use lp_apm (24MHz) source for perclk */ + ldr r1, =0x000020C2 + str r1, [r0, #CLKCTL_CBCMR] + /* ddr clock from PLL 1, all perclk dividers are 1 since using 24MHz */ + ldr r1, =0x59E35100 + str r1, [r0, #CLKCTL_CBCDR] + + /* Restore the default values in the Gate registers */ + ldr r1, =0xFFFFFFFF + str r1, [r0, #CLKCTL_CCGR0] + str r1, [r0, #CLKCTL_CCGR1] + str r1, [r0, #CLKCTL_CCGR2] + str r1, [r0, #CLKCTL_CCGR3] + str r1, [r0, #CLKCTL_CCGR4] + str r1, [r0, #CLKCTL_CCGR5] + str r1, [r0, #CLKCTL_CCGR6] + + /* Use PLL 2 for UART's, get 66.5MHz from it */ + ldr r1, =0xA5A2A020 + str r1, [r0, #CLKCTL_CSCMR1] + ldr r1, =0x00C30321 + str r1, [r0, #CLKCTL_CSCDR1] + + /* make sure divider effective */ +1: ldr r1, [r0, #CLKCTL_CDHIPR] + cmp r1, #0x0 + bne 1b + + mov r1, #0x0 + str r1, [r0, #CLKCTL_CCDR] + + /* for cko - for ARM div by 8 */ + mov r1, #0x000A0000 + add r1, r1, #0x00000F0 + str r1, [r0, #CLKCTL_CCOSR] +.endm + +.macro setup_wdog + ldr r0, =WDOG1_BASE_ADDR + mov r1, #0x30 + strh r1, [r0] +.endm + +.section ".text.init", "x" + +.globl lowlevel_init +lowlevel_init: + ldr r0, =GPIO1_BASE_ADDR + ldr r1, [r0, #0x0] + orr r1, r1, #(1 << 23) + str r1, [r0, #0x0] + ldr r1, [r0, #0x4] + orr r1, r1, #(1 << 23) + str r1, [r0, #0x4] + +#ifdef ENABLE_IMPRECISE_ABORT + mrs r1, spsr /* save old spsr */ + mrs r0, cpsr /* read out the cpsr */ + bic r0, r0, #0x100 /* clear the A bit */ + msr spsr, r0 /* update spsr */ + add lr, pc, #0x8 /* update lr */ + movs pc, lr /* update cpsr */ + nop + nop + nop + nop + msr spsr, r1 /* restore old spsr */ +#endif + + init_l2cc + + init_aips + + init_max + + init_m4if + + init_drive_strength + + init_clock + + init_debug_board + + /* return from mxc_nand_load */ + /* r12 saved upper lr*/ + mov pc,lr + +/* b mxc_nand_load */ + +/* Board level setting value */ +DDR_PERCHARGE_CMD: .word 0x04008008 +DDR_REFRESH_CMD: .word 0x00008010 +DDR_LMR1_W: .word 0x00338018 +DDR_LMR_CMD: .word 0xB2220000 +DDR_TIMING_W: .word 0xB02567A9 +DDR_MISC_W: .word 0x000A0104 diff --git a/cpu/arm_cortexa8/mx51/soc.c b/cpu/arm_cortexa8/mx51/soc.c new file mode 100644 index 0000000..e91e72a --- /dev/null +++ b/cpu/arm_cortexa8/mx51/soc.c @@ -0,0 +1,78 @@ +/* + * (C) Copyright 2007 + * Sascha Hauer, Pengutronix + * + * (C) Copyright 2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/imx-regs.h> +#include <asm/errno.h> +#include <asm/io.h> + +#if defined(CONFIG_DISPLAY_CPUINFO) +int print_cpuinfo(void) +{ + printf("CPU: Freescale i.MX51 family %d.%dV at %d MHz\n", + (get_board_rev() & 0xFF) >> 4, + (get_board_rev() & 0xF), + get_mcu_main_clk() / 1000000); + return 0; +} +#endif + +/* + * Initializes on-chip ethernet controllers. + * to override, implement board_eth_init() + */ +#if defined(CONFIG_MXC_FEC) +extern int mxc_fec_initialize(bd_t *bis); +#endif + +int cpu_eth_init(bd_t *bis) +{ + int rc = -ENODEV; + +#if defined(CONFIG_MXC_FEC) + rc = mxc_fec_initialize(bis); +#endif + + return rc; +} + +/* + * Initializes on-chip MMC controllers. + * to override, implement board_mmc_init() + */ +int cpu_mmc_init(bd_t *bis) +{ +#ifdef CONFIG_FSL_ESDHC + return fsl_esdhc_mmc_init(bis); +#else + return 0; +#endif +} + + +void reset_cpu(ulong addr) +{ + __raw_writew(4, WDOG1_BASE_ADDR); +} diff --git a/cpu/arm_cortexa8/mx51/timer.c b/cpu/arm_cortexa8/mx51/timer.c new file mode 100644 index 0000000..0937998 --- /dev/null +++ b/cpu/arm_cortexa8/mx51/timer.c @@ -0,0 +1,122 @@ +/* + * (C) Copyright 2007 + * Sascha Hauer, Pengutronix + * + * (C) Copyright 2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/imx-regs.h> + +/* General purpose timers registers */ +struct mxc_gpt { + unsigned int control; + unsigned int prescaler; + unsigned int status; + unsigned int nouse[6]; + unsigned int counter; +}; + +static struct mxc_gpt *cur_gpt = (struct mxc_gpt *)GPT1_BASE_ADDR; + +/* General purpose timers bitfields */ +#define GPTCR_SWR (1<<15) /* Software reset */ +#define GPTCR_FRR (1<<9) /* Freerun / restart */ +#define GPTCR_CLKSOURCE_32 (4<<6) /* Clock source */ +#define GPTCR_TEN (1) /* Timer enable */ + +static ulong timestamp; +static ulong lastinc; + +int timer_init(void) +{ + int i; + + /* setup GP Timer 1 */ + __raw_writel(GPTCR_SWR, &cur_gpt->control); + + /* We have no udelay by now */ + for (i = 0; i < 100; i++) + __raw_writel(0, &cur_gpt->control); + + __raw_writel(0, &cur_gpt->prescaler); /* 32Khz */ + + /* Freerun Mode, PERCLK1 input */ + i = __raw_readl(&cur_gpt->control); + __raw_writel(i | GPTCR_CLKSOURCE_32 | GPTCR_TEN, &cur_gpt->control); + reset_timer_masked(); + return 0; +} + +void reset_timer(void) +{ + reset_timer_masked(); +} + +void reset_timer_masked(void) +{ + ulong val = __raw_readl(&cur_gpt->counter); + lastinc = val / (CONFIG_MX51_CLK32 / CONFIG_SYS_HZ); + timestamp = 0; +} + +ulong get_timer_masked(void) +{ + ulong val = __raw_readl(&cur_gpt->counter); + val /= (CONFIG_MX51_CLK32 / CONFIG_SYS_HZ); + if (val >= lastinc) + timestamp += (val - lastinc); + else + timestamp += ((0xFFFFFFFF / (CONFIG_MX51_CLK32 / CONFIG_SYS_HZ)) + - lastinc) + val; + lastinc = val; + return val; +} + +ulong get_timer(ulong base) +{ + return get_timer_masked() - base; +} + +void set_timer(ulong t) +{ + timestamp = t; +} + +/* delay x useconds AND perserve advance timstamp value */ +void __udelay(unsigned long usec) +{ + unsigned long now, last = readl(&cur_gpt->counter); + long tmo = usec * (CONFIG_MX51_CLK32 / 1000) / 1000; + + if (!tmo) + tmo = 1; + + while (tmo > 0) { + now = readl(&cur_gpt->counter); + if (last > now) + tmo -= 0xFFFFFFFF - last + now; + else + tmo -= now - last; + last = now; + } +} diff --git a/cpu/arm_cortexa8/mx51/u-boot.lds b/cpu/arm_cortexa8/mx51/u-boot.lds new file mode 100644 index 0000000..84c173a --- /dev/null +++ b/cpu/arm_cortexa8/mx51/u-boot.lds @@ -0,0 +1,61 @@ +/* + * January 2004 - Changed to support H4 device + * Copyright (c) 2004 Texas Instruments + * + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, gj@denx.de + * + * (C) Copyright 2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/arm_cortexa8/start.o + *(.text) + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) } + _end = .; +}
The patch add header files to support the Freescale i.MX51 processor, setting definitions for internal registers.
Signed-off-by: Stefano Babic sbabic@denx.de Signed-off-by: Fred Fan fanyefeng@gmail.com --- include/asm-arm/arch-mx51/crm_regs.h | 192 +++++++++++++++++++++ include/asm-arm/arch-mx51/imx-regs.h | 308 ++++++++++++++++++++++++++++++++++ 2 files changed, 500 insertions(+), 0 deletions(-) create mode 100644 include/asm-arm/arch-mx51/crm_regs.h create mode 100644 include/asm-arm/arch-mx51/imx-regs.h
diff --git a/include/asm-arm/arch-mx51/crm_regs.h b/include/asm-arm/arch-mx51/crm_regs.h new file mode 100644 index 0000000..38dcbc4 --- /dev/null +++ b/include/asm-arm/arch-mx51/crm_regs.h @@ -0,0 +1,192 @@ +/* + * (C) Copyright 2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ARCH_ARM_MACH_MX51_CRM_REGS_H__ +#define __ARCH_ARM_MACH_MX51_CRM_REGS_H__ + +#define MXC_CCM_BASE CCM_BASE_ADDR + +/* DPLL register mapping structure */ +struct mxc_pll_reg { + u32 ctrl; + u32 config; + u32 op; + u32 mfd; + u32 mfn; + u32 mfn_minus; + u32 mfn_plus; + u32 hfs_op; + u32 hfs_mfd; + u32 hfs_mfn; + u32 mfn_togc; + u32 destat; +}; + +/* Register maping of CCM*/ +struct mxc_ccm_reg { + u32 ccr; /* 0x0000 */ + u32 ccdr; + u32 csr; + u32 ccsr; + u32 cacrr; /* 0x0010*/ + u32 cbcdr; + u32 cbcmr; + u32 cscmr1; + u32 cscmr2; /* 0x0020 */ + u32 cscdr1; + u32 cs1cdr; + u32 cs2cdr; + u32 cdcdr; /* 0x0030 */ + u32 chscdr; + u32 cscdr2; + u32 cscdr3; + u32 cscdr4; /* 0x0040 */ + u32 cwdr; + u32 cdhipr; + u32 cdcr; + u32 ctor; /* 0x0050 */ + u32 clpcr; + u32 cisr; + u32 cimr; + u32 ccosr; /* 0x0060 */ + u32 cgpr; + u32 CCGR0; + u32 CCGR1; + u32 CCGR2; /* 0x0070 */ + u32 CCGR3; + u32 CCGR4; + u32 CCGR5; + u32 CCGR6; /* 0x0080 */ + u32 cmeor; +}; + +/* Define the bits in register CACRR */ +#define MXC_CCM_CACRR_ARM_PODF_OFFSET (0) +#define MXC_CCM_CACRR_ARM_PODF_MASK (0x7) + +/* Define the bits in register CBCDR */ +#define MXC_CCM_CBCDR_EMI_CLK_SEL (0x1 << 26) +#define MXC_CCM_CBCDR_PERIPH_CLK_SEL (0x1 << 25) +#define MXC_CCM_CBCDR_EMI_PODF_OFFSET (22) +#define MXC_CCM_CBCDR_EMI_PODF_MASK (0x7 << 22) +#define MXC_CCM_CBCDR_AXI_B_PODF_OFFSET (19) +#define MXC_CCM_CBCDR_AXI_B_PODF_MASK (0x7 << 19) +#define MXC_CCM_CBCDR_AXI_A_PODF_OFFSET (16) +#define MXC_CCM_CBCDR_AXI_A_PODF_MASK (0x7 << 16) +#define MXC_CCM_CBCDR_NFC_PODF_OFFSET (13) +#define MXC_CCM_CBCDR_NFC_PODF_MASK (0x7 << 13) +#define MXC_CCM_CBCDR_AHB_PODF_OFFSET (10) +#define MXC_CCM_CBCDR_AHB_PODF_MASK (0x7 << 10) +#define MXC_CCM_CBCDR_IPG_PODF_OFFSET (8) +#define MXC_CCM_CBCDR_IPG_PODF_MASK (0x3 << 8) +#define MXC_CCM_CBCDR_PERCLK_PRED1_OFFSET (6) +#define MXC_CCM_CBCDR_PERCLK_PRED1_MASK (0x3 << 6) +#define MXC_CCM_CBCDR_PERCLK_PRED2_OFFSET (3) +#define MXC_CCM_CBCDR_PERCLK_PRED2_MASK (0x7 << 3) +#define MXC_CCM_CBCDR_PERCLK_PODF_OFFSET (0) +#define MXC_CCM_CBCDR_PERCLK_PODF_MASK (0x7) + +/* Define the bits in register CSCMR1 */ +#define MXC_CCM_CSCMR1_SSI_EXT2_CLK_SEL_OFFSET (30) +#define MXC_CCM_CSCMR1_SSI_EXT2_CLK_SEL_MASK (0x3 << 30) +#define MXC_CCM_CSCMR1_SSI_EXT1_CLK_SEL_OFFSET (28) +#define MXC_CCM_CSCMR1_SSI_EXT1_CLK_SEL_MASK (0x3 << 28) +#define MXC_CCM_CSCMR1_USB_PHY_CLK_SEL_OFFSET (26) +#define MXC_CCM_CSCMR1_USB_PHY_CLK_SEL (0x1 << 26) +#define MXC_CCM_CSCMR1_UART_CLK_SEL_OFFSET (24) +#define MXC_CCM_CSCMR1_UART_CLK_SEL_MASK (0x3 << 24) +#define MXC_CCM_CSCMR1_USBOH3_CLK_SEL_OFFSET (22) +#define MXC_CCM_CSCMR1_USBOH3_CLK_SEL_MASK (0x3 << 22) +#define MXC_CCM_CSCMR1_ESDHC1_MSHC1_CLK_SEL_OFFSET (20) +#define MXC_CCM_CSCMR1_ESDHC1_MSHC1_CLK_SEL_MASK (0x3 << 20) +#define MXC_CCM_CSCMR1_ESDHC3_CLK_SEL (0x1 << 19) +#define MXC_CCM_CSCMR1_ESDHC4_CLK_SEL (0x1 << 18) +#define MXC_CCM_CSCMR1_ESDHC2_MSHC2_CLK_SEL_OFFSET (16) +#define MXC_CCM_CSCMR1_ESDHC2_MSHC2_CLK_SEL_MASK (0x3 << 16) +#define MXC_CCM_CSCMR1_SSI1_CLK_SEL_OFFSET (14) +#define MXC_CCM_CSCMR1_SSI1_CLK_SEL_MASK (0x3 << 14) +#define MXC_CCM_CSCMR1_SSI2_CLK_SEL_OFFSET (12) +#define MXC_CCM_CSCMR1_SSI2_CLK_SEL_MASK (0x3 << 12) +#define MXC_CCM_CSCMR1_SSI3_CLK_SEL (0x1 << 11) +#define MXC_CCM_CSCMR1_VPU_RCLK_SEL (0x1 << 10) +#define MXC_CCM_CSCMR1_SSI_APM_CLK_SEL_OFFSET (8) +#define MXC_CCM_CSCMR1_SSI_APM_CLK_SEL_MASK (0x3 << 8) +#define MXC_CCM_CSCMR1_TVE_CLK_SEL (0x1 << 7) +#define MXC_CCM_CSCMR1_TVE_EXT_CLK_SEL (0x1 << 6) +#define MXC_CCM_CSCMR1_CSPI_CLK_SEL_OFFSET (4) +#define MXC_CCM_CSCMR1_CSPI_CLK_SEL_MASK (0x3 << 4) +#define MXC_CCM_CSCMR1_SPDIF_CLK_SEL_OFFSET (2) +#define MXC_CCM_CSCMR1_SPDIF_CLK_SEL_MASK (0x3 << 2) +#define MXC_CCM_CSCMR1_SSI_EXT2_COM_CLK_SEL (0x1 << 1) +#define MXC_CCM_CSCMR1_SSI_EXT1_COM_CLK_SEL (0x1) + +/* Define the bits in register CSCDR2 */ +#define MXC_CCM_CSCDR2_CSPI_CLK_PRED_OFFSET (25) +#define MXC_CCM_CSCDR2_CSPI_CLK_PRED_MASK (0x7 << 25) +#define MXC_CCM_CSCDR2_CSPI_CLK_PODF_OFFSET (19) +#define MXC_CCM_CSCDR2_CSPI_CLK_PODF_MASK (0x3F << 19) +#define MXC_CCM_CSCDR2_SIM_CLK_PRED_OFFSET (16) +#define MXC_CCM_CSCDR2_SIM_CLK_PRED_MASK (0x7 << 16) +#define MXC_CCM_CSCDR2_SIM_CLK_PODF_OFFSET (9) +#define MXC_CCM_CSCDR2_SIM_CLK_PODF_MASK (0x3F << 9) +#define MXC_CCM_CSCDR2_SLIMBUS_CLK_PRED_OFFSET (6) +#define MXC_CCM_CSCDR2_SLIMBUS_PRED_MASK (0x7 << 6) +#define MXC_CCM_CSCDR2_SLIMBUS_PODF_OFFSET (0) +#define MXC_CCM_CSCDR2_SLIMBUS_PODF_MASK (0x3F) + +/* Define the bits in register CBCMR */ +#define MXC_CCM_CBCMR_VPU_AXI_CLK_SEL_OFFSET (14) +#define MXC_CCM_CBCMR_VPU_AXI_CLK_SEL_MASK (0x3 << 14) +#define MXC_CCM_CBCMR_PERIPH_CLK_SEL_OFFSET (12) +#define MXC_CCM_CBCMR_PERIPH_CLK_SEL_MASK (0x3 << 12) +#define MXC_CCM_CBCMR_DDR_CLK_SEL_OFFSET (10) +#define MXC_CCM_CBCMR_DDR_CLK_SEL_MASK (0x3 << 10) +#define MXC_CCM_CBCMR_ARM_AXI_CLK_SEL_OFFSET (8) +#define MXC_CCM_CBCMR_ARM_AXI_CLK_SEL_MASK (0x3 << 8) +#define MXC_CCM_CBCMR_IPU_HSP_CLK_SEL_OFFSET (6) +#define MXC_CCM_CBCMR_IPU_HSP_CLK_SEL_MASK (0x3 << 6) +#define MXC_CCM_CBCMR_GPU_CLK_SEL_OFFSET (4) +#define MXC_CCM_CBCMR_GPU_CLK_SEL_MASK (0x3 << 4) +#define MXC_CCM_CBCMR_PERCLK_LP_APM_CLK_SEL (0x1 << 1) +#define MXC_CCM_CBCMR_PERCLK_IPG_CLK_SEL (0x1 << 0) + +/* Define the bits in register CSCDR1 */ +#define MXC_CCM_CSCDR1_ESDHC2_MSHC2_CLK_PRED_OFFSET (22) +#define MXC_CCM_CSCDR1_ESDHC2_MSHC2_CLK_PRED_MASK (0x7 << 22) +#define MXC_CCM_CSCDR1_ESDHC2_MSHC2_CLK_PODF_OFFSET (19) +#define MXC_CCM_CSCDR1_ESDHC2_MSHC2_CLK_PODF_MASK (0x7 << 19) +#define MXC_CCM_CSCDR1_ESDHC1_MSHC1_CLK_PRED_OFFSET (16) +#define MXC_CCM_CSCDR1_ESDHC1_MSHC1_CLK_PRED_MASK (0x7 << 16) +#define MXC_CCM_CSCDR1_PGC_CLK_PODF_OFFSET (14) +#define MXC_CCM_CSCDR1_PGC_CLK_PODF_MASK (0x3 << 14) +#define MXC_CCM_CSCDR1_ESDHC1_MSHC1_CLK_PODF_OFFSET (11) +#define MXC_CCM_CSCDR1_ESDHC1_MSHC1_CLK_PODF_MASK (0x7 << 11) +#define MXC_CCM_CSCDR1_USBOH3_CLK_PRED_OFFSET (8) +#define MXC_CCM_CSCDR1_USBOH3_CLK_PRED_MASK (0x7 << 8) +#define MXC_CCM_CSCDR1_USBOH3_CLK_PODF_OFFSET (6) +#define MXC_CCM_CSCDR1_USBOH3_CLK_PODF_MASK (0x3 << 6) +#define MXC_CCM_CSCDR1_UART_CLK_PRED_OFFSET (3) +#define MXC_CCM_CSCDR1_UART_CLK_PRED_MASK (0x7 << 3) +#define MXC_CCM_CSCDR1_UART_CLK_PODF_OFFSET (0) +#define MXC_CCM_CSCDR1_UART_CLK_PODF_MASK (0x7) + +#endif /* __ARCH_ARM_MACH_MX51_CRM_REGS_H__ */ diff --git a/include/asm-arm/arch-mx51/imx-regs.h b/include/asm-arm/arch-mx51/imx-regs.h new file mode 100644 index 0000000..321555a --- /dev/null +++ b/include/asm-arm/arch-mx51/imx-regs.h @@ -0,0 +1,308 @@ +/* + * (C) Copyright 2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ASM_ARCH_MXC_MX51_H__ +#define __ASM_ARCH_MXC_MX51_H__ + +#define __REG(x) (*((volatile u32 *)(x))) +#define __REG16(x) (*((volatile u16 *)(x))) +#define __REG8(x) (*((volatile u8 *)(x))) +/* + * IRAM + */ +#define IRAM_BASE_ADDR 0x1FFE8000 /* internal ram */ +/* + * Graphics Memory of GPU + */ +#define GPU_BASE_ADDR 0x20000000 +#define GPU_CTRL_BASE_ADDR 0x30000000 +#define IPU_CTRL_BASE_ADDR 0x40000000 +/* + * Debug + */ +#define DEBUG_BASE_ADDR 0x60000000 +#define ETB_BASE_ADDR (DEBUG_BASE_ADDR + 0x00001000) +#define ETM_BASE_ADDR (DEBUG_BASE_ADDR + 0x00002000) +#define TPIU_BASE_ADDR (DEBUG_BASE_ADDR + 0x00003000) +#define CTI0_BASE_ADDR (DEBUG_BASE_ADDR + 0x00004000) +#define CTI1_BASE_ADDR (DEBUG_BASE_ADDR + 0x00005000) +#define CTI2_BASE_ADDR (DEBUG_BASE_ADDR + 0x00006000) +#define CTI3_BASE_ADDR (DEBUG_BASE_ADDR + 0x00007000) +#define CORTEX_DBG_BASE_ADDR (DEBUG_BASE_ADDR + 0x00008000) + +/* + * SPBA global module enabled #0 + */ +#define SPBA0_BASE_ADDR 0x70000000 + +#define MMC_SDHC1_BASE_ADDR (SPBA0_BASE_ADDR + 0x00004000) +#define MMC_SDHC2_BASE_ADDR (SPBA0_BASE_ADDR + 0x00008000) +#define UART3_BASE_ADDR (SPBA0_BASE_ADDR + 0x0000C000) +#define CSPI1_BASE_ADDR (SPBA0_BASE_ADDR + 0x00010000) +#define SSI2_BASE_ADDR (SPBA0_BASE_ADDR + 0x00014000) +#define MMC_SDHC3_BASE_ADDR (SPBA0_BASE_ADDR + 0x00020000) +#define MMC_SDHC4_BASE_ADDR (SPBA0_BASE_ADDR + 0x00024000) +#define SPDIF_BASE_ADDR (SPBA0_BASE_ADDR + 0x00028000) +#define ATA_DMA_BASE_ADDR (SPBA0_BASE_ADDR + 0x00030000) +#define SLIM_DMA_BASE_ADDR (SPBA0_BASE_ADDR + 0x00034000) +#define HSI2C_DMA_BASE_ADDR (SPBA0_BASE_ADDR + 0x00038000) +#define SPBA_CTRL_BASE_ADDR (SPBA0_BASE_ADDR + 0x0003C000) + +/* + * AIPS 1 + */ +#define AIPS1_BASE_ADDR 0x73F00000 + +#define OTG_BASE_ADDR (AIPS1_BASE_ADDR + 0x00080000) +#define GPIO1_BASE_ADDR (AIPS1_BASE_ADDR + 0x00084000) +#define GPIO2_BASE_ADDR (AIPS1_BASE_ADDR + 0x00088000) +#define GPIO3_BASE_ADDR (AIPS1_BASE_ADDR + 0x0008C000) +#define GPIO4_BASE_ADDR (AIPS1_BASE_ADDR + 0x00090000) +#define KPP_BASE_ADDR (AIPS1_BASE_ADDR + 0x00094000) +#define WDOG1_BASE_ADDR (AIPS1_BASE_ADDR + 0x00098000) +#define WDOG2_BASE_ADDR (AIPS1_BASE_ADDR + 0x0009C000) +#define GPT1_BASE_ADDR (AIPS1_BASE_ADDR + 0x000A0000) +#define SRTC_BASE_ADDR (AIPS1_BASE_ADDR + 0x000A4000) +#define IOMUXC_BASE_ADDR (AIPS1_BASE_ADDR + 0x000A8000) +#define EPIT1_BASE_ADDR (AIPS1_BASE_ADDR + 0x000AC000) +#define EPIT2_BASE_ADDR (AIPS1_BASE_ADDR + 0x000B0000) +#define PWM1_BASE_ADDR (AIPS1_BASE_ADDR + 0x000B4000) +#define PWM2_BASE_ADDR (AIPS1_BASE_ADDR + 0x000B8000) +#define UART1_BASE_ADDR (AIPS1_BASE_ADDR + 0x000BC000) +#define UART2_BASE_ADDR (AIPS1_BASE_ADDR + 0x000C0000) +#define SRC_BASE_ADDR (AIPS1_BASE_ADDR + 0x000D0000) +#define CCM_BASE_ADDR (AIPS1_BASE_ADDR + 0x000D4000) +#define GPC_BASE_ADDR (AIPS1_BASE_ADDR + 0x000D8000) + +/* + * AIPS 2 + */ +#define AIPS2_BASE_ADDR 0x83F00000 + +#define PLL1_BASE_ADDR (AIPS2_BASE_ADDR + 0x00080000) +#define PLL2_BASE_ADDR (AIPS2_BASE_ADDR + 0x00084000) +#define PLL3_BASE_ADDR (AIPS2_BASE_ADDR + 0x00088000) +#define AHBMAX_BASE_ADDR (AIPS2_BASE_ADDR + 0x00094000) +#define IIM_BASE_ADDR (AIPS2_BASE_ADDR + 0x00098000) +#define CSU_BASE_ADDR (AIPS2_BASE_ADDR + 0x0009C000) +#define ARM_BASE_ADDR (AIPS2_BASE_ADDR + 0x000A0000) +#define OWIRE_BASE_ADDR (AIPS2_BASE_ADDR + 0x000A4000) +#define FIRI_BASE_ADDR (AIPS2_BASE_ADDR + 0x000A8000) +#define CSPI2_BASE_ADDR (AIPS2_BASE_ADDR + 0x000AC000) +#define SDMA_BASE_ADDR (AIPS2_BASE_ADDR + 0x000B0000) +#define SCC_BASE_ADDR (AIPS2_BASE_ADDR + 0x000B4000) +#define ROMCP_BASE_ADDR (AIPS2_BASE_ADDR + 0x000B8000) +#define RTIC_BASE_ADDR (AIPS2_BASE_ADDR + 0x000BC000) +#define CSPI3_BASE_ADDR (AIPS2_BASE_ADDR + 0x000C0000) +#define I2C2_BASE_ADDR (AIPS2_BASE_ADDR + 0x000C4000) +#define I2C1_BASE_ADDR (AIPS2_BASE_ADDR + 0x000C8000) +#define SSI1_BASE_ADDR (AIPS2_BASE_ADDR + 0x000CC000) +#define AUDMUX_BASE_ADDR (AIPS2_BASE_ADDR + 0x000D0000) +#define M4IF_BASE_ADDR (AIPS2_BASE_ADDR + 0x000D8000) +#define ESDCTL_BASE_ADDR (AIPS2_BASE_ADDR + 0x000D9000) +#define WEIM_BASE_ADDR (AIPS2_BASE_ADDR + 0x000DA000) +#define NFC_BASE_ADDR (AIPS2_BASE_ADDR + 0x000DB000) +#define EMI_BASE_ADDR (AIPS2_BASE_ADDR + 0x000DBF00) +#define MIPI_HSC_BASE_ADDR (AIPS2_BASE_ADDR + 0x000DC000) +#define ATA_BASE_ADDR (AIPS2_BASE_ADDR + 0x000E0000) +#define SIM_BASE_ADDR (AIPS2_BASE_ADDR + 0x000E4000) +#define SSI3BASE_ADDR (AIPS2_BASE_ADDR + 0x000E8000) +#define FEC_BASE_ADDR (AIPS2_BASE_ADDR + 0x000EC000) +#define TVE_BASE_ADDR (AIPS2_BASE_ADDR + 0x000F0000) +#define VPU_BASE_ADDR (AIPS2_BASE_ADDR + 0x000F4000) +#define SAHARA_BASE_ADDR (AIPS2_BASE_ADDR + 0x000F8000) + +#define TZIC_BASE_ADDR 0x8FFFC000 + +/* + * Memory regions and CS + */ +#define CSD0_BASE_ADDR 0x90000000 +#define CSD1_BASE_ADDR 0xA0000000 +#define CS0_BASE_ADDR 0xB0000000 +#define CS1_BASE_ADDR 0xB8000000 +#define CS2_BASE_ADDR 0xC0000000 +#define CS3_BASE_ADDR 0xC8000000 +#define CS4_BASE_ADDR 0xCC000000 +#define CS5_BASE_ADDR 0xCE000000 + +/* + * NFC + */ +#define NFC_BASE_ADDR_AXI 0xCFFF0000 /* NAND flash AXI */ + +/*! + * Number of GPIO port as defined in the IC Spec + */ +#define GPIO_PORT_NUM 4 +/*! + * Number of GPIO pins per port + */ +#define GPIO_NUM_PIN 32 + +#define IIM_SREV 0x24 +#define ROM_SI_REV 0x48 + +#define NFC_BUF_SIZE 0x1000 + +/* WEIM registers */ +#define CSGCR1 0x00 +#define CSGCR2 0x04 +#define CSRCR1 0x08 +#define CSRCR2 0x0C +#define CSWCR1 0x10 + +/* M4IF */ +#define M4IF_FBPM0 0x40 +#define M4IF_FIDBP 0x48 + +/* ESDCTL */ +#define ESDCTL_ESDCTL0 0x00 +#define ESDCTL_ESDCFG0 0x04 +#define ESDCTL_ESDCTL1 0x08 +#define ESDCTL_ESDCFG1 0x0C +#define ESDCTL_ESDMISC 0x10 +#define ESDCTL_ESDSCR 0x14 +#define ESDCTL_ESDCDLY1 0x20 +#define ESDCTL_ESDCDLY2 0x24 +#define ESDCTL_ESDCDLY3 0x28 +#define ESDCTL_ESDCDLY4 0x2C +#define ESDCTL_ESDCDLY5 0x30 +#define ESDCTL_ESDCDLYGD 0x34 + +/* CCM */ +#define CLKCTL_CCR 0x00 +#define CLKCTL_CCDR 0x04 +#define CLKCTL_CSR 0x08 +#define CLKCTL_CCSR 0x0C +#define CLKCTL_CACRR 0x10 +#define CLKCTL_CBCDR 0x14 +#define CLKCTL_CBCMR 0x18 +#define CLKCTL_CSCMR1 0x1C +#define CLKCTL_CSCMR2 0x20 +#define CLKCTL_CSCDR1 0x24 +#define CLKCTL_CS1CDR 0x28 +#define CLKCTL_CS2CDR 0x2C +#define CLKCTL_CDCDR 0x30 +#define CLKCTL_CHSCCDR 0x34 +#define CLKCTL_CSCDR2 0x38 +#define CLKCTL_CSCDR3 0x3C +#define CLKCTL_CSCDR4 0x40 +#define CLKCTL_CWDR 0x44 +#define CLKCTL_CDHIPR 0x48 +#define CLKCTL_CDCR 0x4C +#define CLKCTL_CTOR 0x50 +#define CLKCTL_CLPCR 0x54 +#define CLKCTL_CISR 0x58 +#define CLKCTL_CIMR 0x5C +#define CLKCTL_CCOSR 0x60 +#define CLKCTL_CGPR 0x64 +#define CLKCTL_CCGR0 0x68 +#define CLKCTL_CCGR1 0x6C +#define CLKCTL_CCGR2 0x70 +#define CLKCTL_CCGR3 0x74 +#define CLKCTL_CCGR4 0x78 +#define CLKCTL_CCGR5 0x7C +#define CLKCTL_CCGR6 0x80 +#define CLKCTL_CMEOR 0x84 + +/* DPLL */ +#define PLL_DP_CTL 0x00 +#define PLL_DP_CONFIG 0x04 +#define PLL_DP_OP 0x08 +#define PLL_DP_MFD 0x0C +#define PLL_DP_MFN 0x10 +#define PLL_DP_MFNMINUS 0x14 +#define PLL_DP_MFNPLUS 0x18 +#define PLL_DP_HFS_OP 0x1C +#define PLL_DP_HFS_MFD 0x20 +#define PLL_DP_HFS_MFN 0x24 +#define PLL_DP_TOGC 0x28 +#define PLL_DP_DESTAT 0x2C + +/* Assuming 24MHz input clock with doubler ON */ +/* MFI PDF */ +#define DP_OP_850 ((8 << 4) + ((1 - 1) << 0)) +#define DP_MFD_850 (48 - 1) +#define DP_MFN_850 41 + +#define DP_OP_800 ((8 << 4) + ((1 - 1) << 0)) +#define DP_MFD_800 (3 - 1) +#define DP_MFN_800 1 + +#define DP_OP_700 ((7 << 4) + ((1 - 1) << 0)) +#define DP_MFD_700 (24 - 1) +#define DP_MFN_700 7 + +#define DP_OP_665 ((6 << 4) + ((1 - 1) << 0)) +#define DP_MFD_665 (96 - 1) +#define DP_MFN_665 89 + +#define DP_OP_532 ((5 << 4) + ((1 - 1) << 0)) +#define DP_MFD_532 (24 - 1) +#define DP_MFN_532 13 + +#define DP_OP_400 ((8 << 4) + ((2 - 1) << 0)) +#define DP_MFD_400 (3 - 1) +#define DP_MFN_400 1 + +#define DP_OP_216 ((6 << 4) + ((3 - 1) << 0)) +#define DP_MFD_216 (4 - 1) +#define DP_MFN_216 3 + +#define CHIP_REV_1_0 0x10 +#define CHIP_REV_1_1 0x11 +#define CHIP_REV_2_0 0x20 +#define CHIP_REV_2_5 0x25 +#define CHIP_REV_3_0 0x30 + +#define BOARD_REV_1_0 0x0 +#define BOARD_REV_2_0 0x1 + +#ifndef __ASSEMBLER__ + +enum mxc_clock { + MXC_ARM_CLK = 0, + MXC_AHB_CLK, + MXC_IPG_CLK, + MXC_IPG_PERCLK, + MXC_UART_CLK, + MXC_CSPI_CLK, + MXC_FEC_CLK, +}; + +/*! + * NFMS bit in RCSR register for pagesize of nandflash + */ +#define NFMS (*((volatile u32 *)(CCM_BASE_ADDR+0x18))) +#define NFMS_BIT 8 +#define NFMS_NF_DWIDTH 14 +#define NFMS_NF_PG_SZ 8 + +extern unsigned int mxc_get_clock(enum mxc_clock clk); +extern unsigned int imx_get_uartclk(void); +extern unsigned int get_board_rev(void); +extern int is_soc_rev(int rev); + +#endif /* __ASSEMBLER__*/ + +#endif /* __ASM_ARCH_MXC_MX51_H__ */
The patch add header files to support the pin multiplexer of the the Freescale i.MX51 processor.
Signed-off-by: Stefano Babic sbabic@denx.de Signed-off-by: Fred Fan fanyefeng@gmail.com --- include/asm-arm/arch-mx51/iomux.h | 250 ++++++++++++++++++++++ include/asm-arm/arch-mx51/mx51_pins.h | 376 +++++++++++++++++++++++++++++++++ 2 files changed, 626 insertions(+), 0 deletions(-) create mode 100644 include/asm-arm/arch-mx51/iomux.h create mode 100644 include/asm-arm/arch-mx51/mx51_pins.h
diff --git a/include/asm-arm/arch-mx51/iomux.h b/include/asm-arm/arch-mx51/iomux.h new file mode 100644 index 0000000..c898908 --- /dev/null +++ b/include/asm-arm/arch-mx51/iomux.h @@ -0,0 +1,250 @@ +/* + * (C) Copyright 2008-2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __MACH_MX51_IOMUX_H__ +#define __MACH_MX51_IOMUX_H__ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/mx51_pins.h> + +/*! + * @file iomux.h + * + * @brief I/O Muxing control definitions and functions + * + * @ingroup GPIO_MX51 + */ + +typedef unsigned int iomux_pin_name_t; + +/*! + * various IOMUX output functions + */ +typedef enum iomux_config { + IOMUX_CONFIG_ALT0, /*!< used as alternate function 0 */ + IOMUX_CONFIG_ALT1, /*!< used as alternate function 1 */ + IOMUX_CONFIG_ALT2, /*!< used as alternate function 2 */ + IOMUX_CONFIG_ALT3, /*!< used as alternate function 3 */ + IOMUX_CONFIG_ALT4, /*!< used as alternate function 4 */ + IOMUX_CONFIG_ALT5, /*!< used as alternate function 5 */ + IOMUX_CONFIG_ALT6, /*!< used as alternate function 6 */ + IOMUX_CONFIG_ALT7, /*!< used as alternate function 7 */ + IOMUX_CONFIG_GPIO, /*!< added to help user use GPIO mode */ + IOMUX_CONFIG_SION = 0x1 << 4, /*!< used as LOOPBACK:MUX SION bit */ +} iomux_pin_cfg_t; + +/*! + * various IOMUX pad functions + */ +typedef enum iomux_pad_config { + PAD_CTL_SRE_SLOW = 0x0 << 0, + PAD_CTL_SRE_FAST = 0x1 << 0, + PAD_CTL_DRV_LOW = 0x0 << 1, + PAD_CTL_DRV_MEDIUM = 0x1 << 1, + PAD_CTL_DRV_HIGH = 0x2 << 1, + PAD_CTL_DRV_MAX = 0x3 << 1, + PAD_CTL_ODE_OPENDRAIN_NONE = 0x0 << 3, + PAD_CTL_ODE_OPENDRAIN_ENABLE = 0x1 << 3, + PAD_CTL_100K_PD = 0x0 << 4, + PAD_CTL_47K_PU = 0x1 << 4, + PAD_CTL_100K_PU = 0x2 << 4, + PAD_CTL_22K_PU = 0x3 << 4, + PAD_CTL_PUE_KEEPER = 0x0 << 6, + PAD_CTL_PUE_PULL = 0x1 << 6, + PAD_CTL_PKE_NONE = 0x0 << 7, + PAD_CTL_PKE_ENABLE = 0x1 << 7, + PAD_CTL_HYS_NONE = 0x0 << 8, + PAD_CTL_HYS_ENABLE = 0x1 << 8, + PAD_CTL_DDR_INPUT_CMOS = 0x0 << 9, + PAD_CTL_DDR_INPUT_DDR = 0x1 << 9, + PAD_CTL_DRV_VOT_LOW = 0x0 << 13, + PAD_CTL_DRV_VOT_HIGH = 0x1 << 13, +} iomux_pad_config_t; + +/*! + * various IOMUX input select register index + */ +typedef enum iomux_input_select { + MUX_IN_AUDMUX_P4_INPUT_DA_AMX_SELECT_I = 0, + MUX_IN_AUDMUX_P4_INPUT_DB_AMX_SELECT_I, + MUX_IN_AUDMUX_P4_INPUT_TXCLK_AMX_SELECT_INPUT, + MUX_IN_AUDMUX_P4_INPUT_TXFS_AMX_SELECT_INPUT, + MUX_IN_AUDMUX_P5_INPUT_DA_AMX_SELECT_INPUT, + MUX_IN_AUDMUX_P5_INPUT_DB_AMX_SELECT_INPUT, + MUX_IN_AUDMUX_P5_INPUT_RXCLK_AMX_SELECT_INPUT, + MUX_IN_AUDMUX_P5_INPUT_RXFS_AMX_SELECT, + MUX_IN_AUDMUX_P5_INPUT_TXCLK_AMX_SELECT_INPUT, + MUX_IN_AUDMUX_P5_INPUT_TXFS_AMX_SELECT_INPUT, + MUX_IN_AUDMUX_P6_INPUT_DA_AMX_SELECT_INPUT, + MUX_IN_AUDMUX_P6_INPUT_DB_AMX_SELECT_INPUT, + MUX_IN_AUDMUX_P6_INPUT_RXCLK_AMX_SELECT_INPUT, + MUX_IN_AUDMUX_P6_INPUT_RXFS_AMX_SELECT_INPUT, + MUX_IN_AUDMUX_P6_INPUT_TXCLK_AMX_SELECT_INPUT, + MUX_IN_AUDMUX_P6_INPUT_TXFS_AMX_SELECT_INPUT, + MUX_IN_CCM_IPP_DI_CLK_SELECT_INPUT, + /* TO2 */ + MUX_IN_CCM_IPP_DI1_CLK_SELECT_INPUT, + MUX_IN_CCM_PLL1_BYPASS_CLK_SELECT_INPUT, + MUX_IN_CCM_PLL2_BYPASS_CLK_SELECT_INPUT, + MUX_IN_CSPI_IPP_CSPI_CLK_IN_SELECT_INPUT, + MUX_IN_CSPI_IPP_IND_MISO_SELECT_INPUT, + MUX_IN_CSPI_IPP_IND_MOSI_SELECT_INPUT, + MUX_IN_CSPI_IPP_IND_SS_B_1_SELECT_INPUT, + MUX_IN_CSPI_IPP_IND_SS_B_2_SELECT_INPUT, + MUX_IN_CSPI_IPP_IND_SS_B_3_SELECT_INPUT, + MUX_IN_DPLLIP1_L1T_TOG_EN_SELECT_INPUT, + /* TO2 */ + MUX_IN_ECSPI2_IPP_IND_SS_B_1_SELECT_INPUT, + MUX_IN_ECSPI2_IPP_IND_SS_B_3_SELECT_INPUT, + MUX_IN_EMI_IPP_IND_RDY_INT_SELECT_INPUT, + MUX_IN_ESDHC3_IPP_DAT0_IN_SELECT_INPUT, + MUX_IN_ESDHC3_IPP_DAT1_IN_SELECT_INPUT, + MUX_IN_ESDHC3_IPP_DAT2_IN_SELECT_INPUT, + MUX_IN_ESDHC3_IPP_DAT3_IN_SELECT_INPUT, + MUX_IN_FEC_FEC_COL_SELECT_INPUT, + MUX_IN_FEC_FEC_CRS_SELECT_INPUT, + MUX_IN_FEC_FEC_MDI_SELECT_INPUT, + MUX_IN_FEC_FEC_RDATA_0_SELECT_INPUT, + MUX_IN_FEC_FEC_RDATA_1_SELECT_INPUT, + MUX_IN_FEC_FEC_RDATA_2_SELECT_INPUT, + MUX_IN_FEC_FEC_RDATA_3_SELECT_INPUT, + MUX_IN_FEC_FEC_RX_CLK_SELECT_INPUT, + MUX_IN_FEC_FEC_RX_DV_SELECT_INPUT, + MUX_IN_FEC_FEC_RX_ER_SELECT_INPUT, + MUX_IN_FEC_FEC_TX_CLK_SELECT_INPUT, + MUX_IN_GPIO3_IPP_IND_G_IN_1_SELECT_INPUT, + MUX_IN_GPIO3_IPP_IND_G_IN_2_SELECT_INPUT, + MUX_IN_GPIO3_IPP_IND_G_IN_3_SELECT_INPUT, + MUX_IN_GPIO3_IPP_IND_G_IN_4_SELECT_INPUT, + MUX_IN_GPIO3_IPP_IND_G_IN_5_SELECT_INPUT, + MUX_IN_GPIO3_IPP_IND_G_IN_6_SELECT_INPUT, + MUX_IN_GPIO3_IPP_IND_G_IN_7_SELECT_INPUT, + MUX_IN_GPIO3_IPP_IND_G_IN_8_SELECT_INPUT, + /* TO2 */ + MUX_IN_GPIO3_IPP_IND_G_IN_12_SELECT_INPUT, + MUX_IN_HSC_MIPI_MIX_IPP_IND_SENS1_DATA_EN_SELECT_INPUT, + MUX_IN_HSC_MIPI_MIX_IPP_IND_SENS2_DATA_EN_SELECT_INPUT, + /* TO2 */ + MUX_IN_HSC_MIPI_MIX_PAR_VSYNC_SELECT_INPUT, + /* TO2 */ + MUX_IN_HSC_MIPI_MIX_PAR_DI_WAIT_SELECT_INPUT, + MUX_IN_HSC_MIPI_MIX_PAR_SISG_TRIG_SELECT_INPUT, + MUX_IN_I2C1_IPP_SCL_IN_SELECT_INPUT, + MUX_IN_I2C1_IPP_SDA_IN_SELECT_INPUT, + MUX_IN_I2C2_IPP_SCL_IN_SELECT_INPUT, + MUX_IN_I2C2_IPP_SDA_IN_SELECT_INPUT, + + MUX_IN_IPU_IPP_DI_0_IND_DISPB_SD_D_SELECT_INPUT, + + MUX_IN_IPU_IPP_DI_1_IND_DISPB_SD_D_SELECT_INPUT, + + MUX_IN_KPP_IPP_IND_COL_6_SELECT_INPUT, + MUX_IN_KPP_IPP_IND_COL_7_SELECT_INPUT, + MUX_IN_KPP_IPP_IND_ROW_4_SELECT_INPUT, + MUX_IN_KPP_IPP_IND_ROW_5_SELECT_INPUT, + MUX_IN_KPP_IPP_IND_ROW_6_SELECT_INPUT, + MUX_IN_KPP_IPP_IND_ROW_7_SELECT_INPUT, + MUX_IN_UART1_IPP_UART_RTS_B_SELECT_INPUT, + MUX_IN_UART1_IPP_UART_RXD_MUX_SELECT_INPUT, + MUX_IN_UART2_IPP_UART_RTS_B_SELECT_INPUT, + MUX_IN_UART2_IPP_UART_RXD_MUX_SELECT_INPUT, + MUX_IN_UART3_IPP_UART_RTS_B_SELECT_INPUT, + MUX_IN_UART3_IPP_UART_RXD_MUX_SELECT_INPUT, + MUX_IN_USBOH3_IPP_IND_UH3_CLK_SELECT_INPUT, + MUX_IN_USBOH3_IPP_IND_UH3_DATA_0_SELECT_INPUT, + MUX_IN_USBOH3_IPP_IND_UH3_DATA_1_SELECT_INPUT, + MUX_IN_USBOH3_IPP_IND_UH3_DATA_2_SELECT_INPUT, + MUX_IN_USBOH3_IPP_IND_UH3_DATA_3_SELECT_INPUT, + MUX_IN_USBOH3_IPP_IND_UH3_DATA_4_SELECT_INPUT, + MUX_IN_USBOH3_IPP_IND_UH3_DATA_5_SELECT_INPUT, + MUX_IN_USBOH3_IPP_IND_UH3_DATA_6_SELECT_INPUT, + MUX_IN_USBOH3_IPP_IND_UH3_DATA_7_SELECT_INPUT, + MUX_IN_USBOH3_IPP_IND_UH3_DIR_SELECT_INPUT, + MUX_IN_USBOH3_IPP_IND_UH3_NXT_SELECT_INPUT, + MUX_IN_USBOH3_IPP_IND_UH3_STP_SELECT_INPUT, + MUX_INPUT_NUM_MUX, +} iomux_input_select_t; + +/*! + * various IOMUX input functions + */ +typedef enum iomux_input_config { + INPUT_CTL_PATH0 = 0x0, + INPUT_CTL_PATH1, + INPUT_CTL_PATH2, + INPUT_CTL_PATH3, + INPUT_CTL_PATH4, + INPUT_CTL_PATH5, + INPUT_CTL_PATH6, + INPUT_CTL_PATH7, +} iomux_input_config_t; + +/*! + * Request ownership for an IO pin. This function has to be the first one + * being called before that pin is used. The caller has to check the + * return value to make sure it returns 0. + * + * @param pin a name defined by \b iomux_pin_name_t + * @param config config as defined in \b #iomux_pin_ocfg_t + * + * @return 0 if successful; Non-zero otherwise + */ +void mxc_request_iomux(iomux_pin_name_t pin, iomux_pin_cfg_t config); + +/*! + * Release ownership for an IO pin + * + * @param pin a name defined by \b iomux_pin_name_t + * @param config config as defined in \b #iomux_pin_ocfg_t + */ +void mxc_free_iomux(iomux_pin_name_t pin, iomux_pin_cfg_t config); + +/*! + * This function configures the pad value for a IOMUX pin. + * + * @param pin a pin number as defined in \b #iomux_pin_name_t + * @param config the ORed value of elements defined in + * \b #iomux_pad_config_t + */ +void mxc_iomux_set_pad(iomux_pin_name_t pin, u32 config); + +/*! + * This function gets the current pad value for a IOMUX pin. + * + * @param pin a pin number as defined in \b #iomux_pin_name_t + * @return current pad value + */ +unsigned int mxc_iomux_get_pad(iomux_pin_name_t pin); + +/*! + * This function configures input path. + * + * @param input index of input select register as defined in + * \b #iomux_input_select_t + * @param config the binary value of elements defined in + * \b #iomux_input_config_t + */ +void mxc_iomux_set_input(iomux_input_select_t input, u32 config); + +#endif /* __MACH_MX51_IOMUX_H__ */ diff --git a/include/asm-arm/arch-mx51/mx51_pins.h b/include/asm-arm/arch-mx51/mx51_pins.h new file mode 100644 index 0000000..42637f9 --- /dev/null +++ b/include/asm-arm/arch-mx51/mx51_pins.h @@ -0,0 +1,376 @@ +/* + * (C) Copyright 2008-2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ASM_ARCH_MXC_MX51_PINS_H__ +#define __ASM_ARCH_MXC_MX51_PINS_H__ + +#ifndef __ASSEMBLY__ + +/* + * In order to identify pins more effectively, each mux-controlled pin's + * enumerated value is constructed in the following way: + * + * ------------------------------------------------------------------- + * 31-29 | 28 - 24 | 23 - 21 | 20 - 10| 9 - 0 + * ------------------------------------------------------------------- + * IO_P | IO_I | GPIO_I | PAD_I | MUX_I + * ------------------------------------------------------------------- + * + * Bit 0 to 9 contains MUX_I used to identify the register + * offset (0-based. base is IOMUX_module_base) defined in the Section + * "sw_pad_ctl & sw_mux_ctl details" of the IC Spec. The + * similar field definitions are used for the pad control register. + * The IOMUX controller can be split in two parts. At the begeinning, + * there is the register definitions for the multiplexing each pin. + * Then there is a set of registers (PAD_I) to configure each pin + * (pullup, pulldown, etc). + * PAD_I defines the offset of the pad register for each pin. + * GPIO_I defines, if available, the number of gpio that can be + * connected to that pad + * IO_I defines the multiplexer mode required to set the pad in gpio mode + * IO_P defines the gpio structure (gpio1..gpio4) the pad belongs + * + * For example, the MX51_PIN_ETM_D0 is defined in the enumeration: + * ( (0x28 - MUX_I_START) << MUX_I)|( (0x250 - PAD_I_START) << PAD_I) + * It means the mux control register is at register offset 0x28. The pad control + * register offset is: 0x250 and also occupy the least significant bits + * within the register. + */ + +/*! + * Starting bit position within each entry of \b iomux_pins to represent the + * MUX control register offset + */ +#define MUX_I 0 +/*! + * Starting bit position within each entry of \b iomux_pins to represent the + * PAD control register offset + */ +#define PAD_I 10 +/*! + * Starting bit position within each entry of \b iomux_pins to represent which + * mux mode is for GPIO (0-based) + */ +#define GPIO_I 21 + +#define MUX_IO_P 29 +#define MUX_IO_I 24 +#define IOMUX_TO_GPIO(pin) ((((unsigned int)pin >> MUX_IO_P) * \ + GPIO_NUM_PIN) + ((pin >> MUX_IO_I) &\ + ((1 << (MUX_IO_P - MUX_IO_I)) - 1))) +#define IOMUX_TO_IRQ(pin) (MXC_GPIO_INT_BASE + IOMUX_TO_GPIO(pin)) +#define GPIO_TO_PORT(n) (n / GPIO_NUM_PIN) +#define GPIO_TO_INDEX(n) (n % GPIO_NUM_PIN) + +#define NON_GPIO_PORT 0x7 +#define PIN_TO_MUX_MASK ((1 << (PAD_I - MUX_I)) - 1) +#define PIN_TO_PAD_MASK ((1 << (GPIO_I - PAD_I)) - 1) +#define PIN_TO_ALT_GPIO_MASK ((1 << (MUX_IO_I - GPIO_I)) - 1) + +#define NON_MUX_I PIN_TO_MUX_MASK +#define MUX_I_START 0x001C +#define PAD_I_START 0x3F0 +#define INPUT_CTL_START 0x8C4 +#define INPUT_CTL_START_TO1 0x928 +#define MUX_I_END (PAD_I_START - 4) + +#define _MXC_BUILD_PIN(gp, gi, ga, mi, pi) \ + (((gp) << MUX_IO_P) | ((gi) << MUX_IO_I) | \ + ((mi) << MUX_I) | \ + ((pi - PAD_I_START) << PAD_I) | \ + ((ga) << GPIO_I)) + +#define _MXC_BUILD_GPIO_PIN(gp, gi, ga, mi, pi) \ + _MXC_BUILD_PIN(gp, gi, ga, mi, pi) + +#define _MXC_BUILD_NON_GPIO_PIN(mi, pi) \ + _MXC_BUILD_PIN(NON_GPIO_PORT, 0, 0, mi, pi) + +#define PIN_TO_IOMUX_MUX(pin) ((pin >> MUX_I) & PIN_TO_MUX_MASK) +#define PIN_TO_IOMUX_PAD(pin) ((pin >> PAD_I) & PIN_TO_PAD_MASK) +#define PIN_TO_ALT_GPIO(pin) ((pin >> GPIO_I) & PIN_TO_ALT_GPIO_MASK) +#define PIN_TO_IOMUX_INDEX(pin) (PIN_TO_IOMUX_MUX(pin) >> 2) + +/*! @} End IOMUX/PAD Bit field definitions */ + +/*! + * This enumeration is constructed based on the Section + * "sw_pad_ctl & sw_mux_ctl details" of the MX51 IC Spec. Each enumerated + * value is constructed based on the rules described above. + */ +enum iomux_pins { + MX51_PIN_EIM_DA0 = _MXC_BUILD_NON_GPIO_PIN(0x1C, 0x7A8), + MX51_PIN_EIM_DA1 = _MXC_BUILD_NON_GPIO_PIN(0x20, 0x7A8), + MX51_PIN_EIM_DA2 = _MXC_BUILD_NON_GPIO_PIN(0x24, 0x7A8), + MX51_PIN_EIM_DA3 = _MXC_BUILD_NON_GPIO_PIN(0x28, 0x7A8), + MX51_PIN_EIM_DA4 = _MXC_BUILD_NON_GPIO_PIN(0x2C, 0x7AC), + MX51_PIN_EIM_DA5 = _MXC_BUILD_NON_GPIO_PIN(0x30, 0x7AC), + MX51_PIN_EIM_DA6 = _MXC_BUILD_NON_GPIO_PIN(0x34, 0x7AC), + MX51_PIN_EIM_DA7 = _MXC_BUILD_NON_GPIO_PIN(0x38, 0x7AC), + MX51_PIN_EIM_DA8 = _MXC_BUILD_NON_GPIO_PIN(0x3C, 0x7B0), + MX51_PIN_EIM_DA9 = _MXC_BUILD_NON_GPIO_PIN(0x40, 0x7B0), + MX51_PIN_EIM_DA10 = _MXC_BUILD_NON_GPIO_PIN(0x44, 0x7B0), + MX51_PIN_EIM_DA11 = _MXC_BUILD_NON_GPIO_PIN(0x48, 0x7B0), + MX51_PIN_EIM_DA12 = _MXC_BUILD_NON_GPIO_PIN(0x4C, 0x7BC), + MX51_PIN_EIM_DA13 = _MXC_BUILD_NON_GPIO_PIN(0x50, 0x7BC), + MX51_PIN_EIM_DA14 = _MXC_BUILD_NON_GPIO_PIN(0x54, 0x7BC), + MX51_PIN_EIM_DA15 = _MXC_BUILD_NON_GPIO_PIN(0x58, 0x7BC), + MX51_PIN_EIM_D16 = _MXC_BUILD_GPIO_PIN(1, 0, 1, 0x5C, 0x3F0), + MX51_PIN_EIM_D17 = _MXC_BUILD_GPIO_PIN(1, 1, 1, 0x60, 0x3F4), + MX51_PIN_EIM_D18 = _MXC_BUILD_GPIO_PIN(1, 2, 1, 0x64, 0x3F8), + MX51_PIN_EIM_D19 = _MXC_BUILD_GPIO_PIN(1, 3, 1, 0x68, 0x3FC), + MX51_PIN_EIM_D20 = _MXC_BUILD_GPIO_PIN(1, 4, 1, 0x6C, 0x400), + MX51_PIN_EIM_D21 = _MXC_BUILD_GPIO_PIN(1, 5, 1, 0x70, 0x404), + MX51_PIN_EIM_D22 = _MXC_BUILD_GPIO_PIN(1, 6, 1, 0x74, 0x408), + MX51_PIN_EIM_D23 = _MXC_BUILD_GPIO_PIN(1, 7, 1, 0x78, 0x40C), + MX51_PIN_EIM_D24 = _MXC_BUILD_GPIO_PIN(1, 8, 1, 0x7C, 0x410), + MX51_PIN_EIM_D25 = _MXC_BUILD_NON_GPIO_PIN(0x80, 0x414), + MX51_PIN_EIM_D26 = _MXC_BUILD_NON_GPIO_PIN(0x84, 0x418), + MX51_PIN_EIM_D27 = _MXC_BUILD_GPIO_PIN(1, 9, 1, 0x88, 0x41C), + MX51_PIN_EIM_D28 = _MXC_BUILD_NON_GPIO_PIN(0x8C, 0x420), + MX51_PIN_EIM_D29 = _MXC_BUILD_NON_GPIO_PIN(0x90, 0x424), + MX51_PIN_EIM_D30 = _MXC_BUILD_NON_GPIO_PIN(0x94, 0x428), + MX51_PIN_EIM_D31 = _MXC_BUILD_NON_GPIO_PIN(0x98, 0x42C), + MX51_PIN_EIM_A16 = _MXC_BUILD_GPIO_PIN(1, 10, 1, 0x9C, 0x430), + MX51_PIN_EIM_A17 = _MXC_BUILD_GPIO_PIN(1, 11, 1, 0xA0, 0x434), + MX51_PIN_EIM_A18 = _MXC_BUILD_GPIO_PIN(1, 12, 1, 0xA4, 0x438), + MX51_PIN_EIM_A19 = _MXC_BUILD_GPIO_PIN(1, 13, 1, 0xA8, 0x43C), + MX51_PIN_EIM_A20 = _MXC_BUILD_GPIO_PIN(1, 14, 1, 0xAC, 0x440), + MX51_PIN_EIM_A21 = _MXC_BUILD_GPIO_PIN(1, 15, 1, 0xB0, 0x444), + MX51_PIN_EIM_A22 = _MXC_BUILD_GPIO_PIN(1, 16, 1, 0xB4, 0x448), + MX51_PIN_EIM_A23 = _MXC_BUILD_GPIO_PIN(1, 17, 1, 0xB8, 0x44C), + MX51_PIN_EIM_A24 = _MXC_BUILD_GPIO_PIN(1, 18, 1, 0xBC, 0x450), + MX51_PIN_EIM_A25 = _MXC_BUILD_GPIO_PIN(1, 19, 1, 0xC0, 0x454), + MX51_PIN_EIM_A26 = _MXC_BUILD_GPIO_PIN(1, 20, 1, 0xC4, 0x458), + MX51_PIN_EIM_A27 = _MXC_BUILD_GPIO_PIN(1, 21, 1, 0xC8, 0x45C), + MX51_PIN_EIM_EB0 = _MXC_BUILD_NON_GPIO_PIN(0xCC, 0x460), + MX51_PIN_EIM_EB1 = _MXC_BUILD_NON_GPIO_PIN(0xD0, 0x464), + MX51_PIN_EIM_EB2 = _MXC_BUILD_GPIO_PIN(1, 22, 1, 0xD4, 0x468), + MX51_PIN_EIM_EB3 = _MXC_BUILD_GPIO_PIN(1, 23, 1, 0xD8, 0x46C), + MX51_PIN_EIM_OE = _MXC_BUILD_GPIO_PIN(1, 24, 1, 0xDC, 0x470), + MX51_PIN_EIM_CS0 = _MXC_BUILD_GPIO_PIN(1, 25, 1, 0xE0, 0x474), + MX51_PIN_EIM_CS1 = _MXC_BUILD_GPIO_PIN(1, 26, 1, 0xE4, 0x478), + MX51_PIN_EIM_CS2 = _MXC_BUILD_GPIO_PIN(1, 27, 1, 0xE8, 0x47C), + MX51_PIN_EIM_CS3 = _MXC_BUILD_GPIO_PIN(1, 28, 1, 0xEC, 0x480), + MX51_PIN_EIM_CS4 = _MXC_BUILD_GPIO_PIN(1, 29, 1, 0xF0, 0x484), + MX51_PIN_EIM_CS5 = _MXC_BUILD_GPIO_PIN(1, 30, 1, 0xF4, 0x488), + MX51_PIN_EIM_DTACK = _MXC_BUILD_GPIO_PIN(1, 31, 1, 0xF8, 0x48C), + MX51_PIN_EIM_LBA = _MXC_BUILD_GPIO_PIN(2, 1, 1, 0xFC, 0x494), + MX51_PIN_EIM_CRE = _MXC_BUILD_GPIO_PIN(2, 2, 1, 0x100, 0x4A0), + MX51_PIN_DRAM_CS1 = _MXC_BUILD_NON_GPIO_PIN(0x104, 0x4D0), + MX51_PIN_NANDF_WE_B = _MXC_BUILD_GPIO_PIN(2, 3, 3, 0x108, 0x4E4), + MX51_PIN_NANDF_RE_B = _MXC_BUILD_GPIO_PIN(2, 4, 3, 0x10C, 0x4E8), + MX51_PIN_NANDF_ALE = _MXC_BUILD_GPIO_PIN(2, 5, 3, 0x110, 0x4EC), + MX51_PIN_NANDF_CLE = _MXC_BUILD_GPIO_PIN(2, 6, 3, 0x114, 0x4F0), + MX51_PIN_NANDF_WP_B = _MXC_BUILD_GPIO_PIN(2, 7, 3, 0x118, 0x4F4), + MX51_PIN_NANDF_RB0 = _MXC_BUILD_GPIO_PIN(2, 8, 3, 0x11C, 0x4F8), + MX51_PIN_NANDF_RB1 = _MXC_BUILD_GPIO_PIN(2, 9, 3, 0x120, 0x4FC), + MX51_PIN_NANDF_RB2 = _MXC_BUILD_GPIO_PIN(2, 10, 3, 0x124, 0x500), + MX51_PIN_NANDF_RB3 = _MXC_BUILD_GPIO_PIN(2, 11, 3, 0x128, 0x504), + MX51_PIN_GPIO_NAND = _MXC_BUILD_GPIO_PIN(2, 12, 3, 0x12C, 0x514), + MX51_PIN_NANDF_RB4 = MX51_PIN_GPIO_NAND, + MX51_PIN_NANDF_RB5 = _MXC_BUILD_GPIO_PIN(2, 13, 3, 0x130, 0x5D8), + MX51_PIN_NANDF_RB6 = _MXC_BUILD_GPIO_PIN(2, 14, 3, 0x134, 0x5DC), + MX51_PIN_NANDF_RB7 = _MXC_BUILD_GPIO_PIN(2, 15, 3, 0x138, 0x5E0), + MX51_PIN_NANDF_CS0 = _MXC_BUILD_GPIO_PIN(2, 16, 3, 0x130, 0x518), + MX51_PIN_NANDF_CS1 = _MXC_BUILD_GPIO_PIN(2, 17, 3, 0x134, 0x51C), + MX51_PIN_NANDF_CS2 = _MXC_BUILD_GPIO_PIN(2, 18, 3, 0x138, 0x520), + MX51_PIN_NANDF_CS3 = _MXC_BUILD_GPIO_PIN(2, 19, 3, 0x13C, 0x524), + MX51_PIN_NANDF_CS4 = _MXC_BUILD_GPIO_PIN(2, 20, 3, 0x140, 0x528), + MX51_PIN_NANDF_CS5 = _MXC_BUILD_GPIO_PIN(2, 21, 3, 0x144, 0x52C), + MX51_PIN_NANDF_CS6 = _MXC_BUILD_GPIO_PIN(2, 22, 3, 0x148, 0x530), + MX51_PIN_NANDF_CS7 = _MXC_BUILD_GPIO_PIN(2, 23, 3, 0x14C, 0x534), + MX51_PIN_NANDF_RDY_INT = _MXC_BUILD_GPIO_PIN(2, 24, 3, 0x150, 0x538), + MX51_PIN_NANDF_D15 = _MXC_BUILD_GPIO_PIN(2, 25, 3, 0x154, 0x53C), + MX51_PIN_NANDF_D14 = _MXC_BUILD_GPIO_PIN(2, 26, 3, 0x158, 0x540), + MX51_PIN_NANDF_D13 = _MXC_BUILD_GPIO_PIN(2, 27, 3, 0x15C, 0x544), + MX51_PIN_NANDF_D12 = _MXC_BUILD_GPIO_PIN(2, 28, 3, 0x160, 0x548), + MX51_PIN_NANDF_D11 = _MXC_BUILD_GPIO_PIN(2, 29, 3, 0x164, 0x54C), + MX51_PIN_NANDF_D10 = _MXC_BUILD_GPIO_PIN(2, 30, 3, 0x168, 0x550), + MX51_PIN_NANDF_D9 = _MXC_BUILD_GPIO_PIN(2, 31, 3, 0x16C, 0x554), + MX51_PIN_NANDF_D8 = _MXC_BUILD_GPIO_PIN(3, 0, 3, 0x170, 0x558), + MX51_PIN_NANDF_D7 = _MXC_BUILD_GPIO_PIN(3, 1, 3, 0x174, 0x55C), + MX51_PIN_NANDF_D6 = _MXC_BUILD_GPIO_PIN(3, 2, 3, 0x178, 0x560), + MX51_PIN_NANDF_D5 = _MXC_BUILD_GPIO_PIN(3, 3, 3, 0x17C, 0x564), + MX51_PIN_NANDF_D4 = _MXC_BUILD_GPIO_PIN(3, 4, 3, 0x180, 0x568), + MX51_PIN_NANDF_D3 = _MXC_BUILD_GPIO_PIN(3, 5, 3, 0x184, 0x56C), + MX51_PIN_NANDF_D2 = _MXC_BUILD_GPIO_PIN(3, 6, 3, 0x188, 0x570), + MX51_PIN_NANDF_D1 = _MXC_BUILD_GPIO_PIN(3, 7, 3, 0x18C, 0x574), + MX51_PIN_NANDF_D0 = _MXC_BUILD_GPIO_PIN(3, 8, 3, 0x190, 0x578), + MX51_PIN_CSI1_D8 = _MXC_BUILD_GPIO_PIN(2, 12, 3, 0x194, 0x57C), + MX51_PIN_CSI1_D9 = _MXC_BUILD_GPIO_PIN(2, 13, 3, 0x198, 0x580), + MX51_PIN_CSI1_D10 = _MXC_BUILD_NON_GPIO_PIN(0x19C, 0x584), + MX51_PIN_CSI1_D11 = _MXC_BUILD_NON_GPIO_PIN(0x1A0, 0x588), + MX51_PIN_CSI1_D12 = _MXC_BUILD_NON_GPIO_PIN(0x1A4, 0x58C), + MX51_PIN_CSI1_D13 = _MXC_BUILD_NON_GPIO_PIN(0x1A8, 0x590), + MX51_PIN_CSI1_D14 = _MXC_BUILD_NON_GPIO_PIN(0x1AC, 0x594), + MX51_PIN_CSI1_D15 = _MXC_BUILD_NON_GPIO_PIN(0x1B0, 0x598), + MX51_PIN_CSI1_D16 = _MXC_BUILD_NON_GPIO_PIN(0x1B4, 0x59C), + MX51_PIN_CSI1_D17 = _MXC_BUILD_NON_GPIO_PIN(0x1B8, 0x5A0), + MX51_PIN_CSI1_D18 = _MXC_BUILD_NON_GPIO_PIN(0x1BC, 0x5A4), + MX51_PIN_CSI1_D19 = _MXC_BUILD_NON_GPIO_PIN(0x1C0, 0x5A8), + MX51_PIN_CSI1_VSYNC = _MXC_BUILD_NON_GPIO_PIN(0x1C4, 0x5AC), + MX51_PIN_CSI1_HSYNC = _MXC_BUILD_NON_GPIO_PIN(0x1C8, 0x5B0), + MX51_PIN_CSI1_PIXCLK = _MXC_BUILD_NON_GPIO_PIN(NON_MUX_I, 0x5B4), + MX51_PIN_CSI1_MCLK = _MXC_BUILD_NON_GPIO_PIN(NON_MUX_I, 0x5B8), + MX51_PIN_CSI1_PKE0 = _MXC_BUILD_NON_GPIO_PIN(NON_MUX_I, 0x860), + MX51_PIN_CSI2_D12 = _MXC_BUILD_GPIO_PIN(3, 9, 3, 0x1CC, 0x5BC), + MX51_PIN_CSI2_D13 = _MXC_BUILD_GPIO_PIN(3, 10, 3, 0x1D0, 0x5C0), + MX51_PIN_CSI2_D14 = _MXC_BUILD_GPIO_PIN(3, 11, 3, 0x1D4, 0x5C4), + MX51_PIN_CSI2_D15 = _MXC_BUILD_GPIO_PIN(3, 12, 3, 0x1D8, 0x5C8), + MX51_PIN_CSI2_D16 = _MXC_BUILD_GPIO_PIN(3, 11, 3, 0x1DC, 0x5CC), + MX51_PIN_CSI2_D17 = _MXC_BUILD_GPIO_PIN(3, 12, 3, 0x1E0, 0x5D0), + MX51_PIN_CSI2_D18 = _MXC_BUILD_GPIO_PIN(3, 11, 3, 0x1E4, 0x5D4), + MX51_PIN_CSI2_D19 = _MXC_BUILD_GPIO_PIN(3, 12, 3, 0x1E8, 0x5D8), + MX51_PIN_CSI2_VSYNC = _MXC_BUILD_GPIO_PIN(3, 13, 3, 0x1EC, 0x5DC), + MX51_PIN_CSI2_HSYNC = _MXC_BUILD_GPIO_PIN(3, 14, 3, 0x1F0, 0x5E0), + MX51_PIN_CSI2_PIXCLK = _MXC_BUILD_GPIO_PIN(3, 15, 3, 0x1F4, 0x5E4), + MX51_PIN_CSI2_PKE0 = _MXC_BUILD_NON_GPIO_PIN(NON_MUX_I, 0x81C), + MX51_PIN_I2C1_CLK = _MXC_BUILD_GPIO_PIN(3, 16, 3, 0x1F8, 0x5E8), + MX51_PIN_I2C1_DAT = _MXC_BUILD_GPIO_PIN(3, 17, 3, 0x1FC, 0x5EC), + MX51_PIN_AUD3_BB_TXD = _MXC_BUILD_GPIO_PIN(3, 18, 3, 0x200, 0x5F0), + MX51_PIN_AUD3_BB_RXD = _MXC_BUILD_GPIO_PIN(3, 19, 3, 0x204, 0x5F4), + MX51_PIN_AUD3_BB_CK = _MXC_BUILD_GPIO_PIN(3, 20, 3, 0x208, 0x5F8), + MX51_PIN_AUD3_BB_FS = _MXC_BUILD_GPIO_PIN(3, 21, 3, 0x20C, 0x5FC), + MX51_PIN_CSPI1_MOSI = _MXC_BUILD_GPIO_PIN(3, 22, 3, 0x210, 0x600), + MX51_PIN_CSPI1_MISO = _MXC_BUILD_GPIO_PIN(3, 23, 3, 0x214, 0x604), + MX51_PIN_CSPI1_SS0 = _MXC_BUILD_GPIO_PIN(3, 24, 3, 0x218, 0x608), + MX51_PIN_CSPI1_SS1 = _MXC_BUILD_GPIO_PIN(3, 25, 3, 0x21C, 0x60C), + MX51_PIN_CSPI1_RDY = _MXC_BUILD_GPIO_PIN(3, 26, 3, 0x220, 0x610), + MX51_PIN_CSPI1_SCLK = _MXC_BUILD_GPIO_PIN(3, 27, 3, 0x224, 0x614), + MX51_PIN_UART1_RXD = _MXC_BUILD_GPIO_PIN(3, 28, 3, 0x228, 0x618), + MX51_PIN_UART1_TXD = _MXC_BUILD_GPIO_PIN(3, 29, 3, 0x22C, 0x61C), + MX51_PIN_UART1_RTS = _MXC_BUILD_GPIO_PIN(3, 30, 3, 0x230, 0x620), + MX51_PIN_UART1_CTS = _MXC_BUILD_GPIO_PIN(3, 31, 3, 0x234, 0x624), + MX51_PIN_UART2_RXD = _MXC_BUILD_GPIO_PIN(0, 20, 3, 0x238, 0x628), + MX51_PIN_UART2_TXD = _MXC_BUILD_GPIO_PIN(0, 21, 3, 0x23C, 0x62C), + MX51_PIN_UART3_RXD = _MXC_BUILD_GPIO_PIN(0, 22, 3, 0x240, 0x630), + MX51_PIN_UART3_TXD = _MXC_BUILD_GPIO_PIN(0, 23, 3, 0x244, 0x634), + MX51_PIN_OWIRE_LINE = _MXC_BUILD_GPIO_PIN(0, 24, 3, 0x248, 0x638), + MX51_PIN_KEY_ROW0 = _MXC_BUILD_NON_GPIO_PIN(0x24C, 0x63C), + MX51_PIN_KEY_ROW1 = _MXC_BUILD_NON_GPIO_PIN(0x250, 0x640), + MX51_PIN_KEY_ROW2 = _MXC_BUILD_NON_GPIO_PIN(0x254, 0x644), + MX51_PIN_KEY_ROW3 = _MXC_BUILD_NON_GPIO_PIN(0x258, 0x648), + MX51_PIN_KEY_COL0 = _MXC_BUILD_NON_GPIO_PIN(0x25C, 0x64C), + MX51_PIN_KEY_COL1 = _MXC_BUILD_NON_GPIO_PIN(0x260, 0x650), + MX51_PIN_KEY_COL2 = _MXC_BUILD_NON_GPIO_PIN(0x264, 0x654), + MX51_PIN_KEY_COL3 = _MXC_BUILD_NON_GPIO_PIN(0x268, 0x658), + MX51_PIN_KEY_COL4 = _MXC_BUILD_NON_GPIO_PIN(0x26C, 0x65C), + MX51_PIN_KEY_COL5 = _MXC_BUILD_NON_GPIO_PIN(0x270, 0x660), + MX51_PIN_USBH1_CLK = _MXC_BUILD_GPIO_PIN(0, 25, 2, 0x278, 0x678), + MX51_PIN_USBH1_DIR = _MXC_BUILD_GPIO_PIN(0, 26, 2, 0x27C, 0x67C), + MX51_PIN_USBH1_STP = _MXC_BUILD_GPIO_PIN(0, 27, 2, 0x280, 0x680), + MX51_PIN_USBH1_NXT = _MXC_BUILD_GPIO_PIN(0, 28, 2, 0x284, 0x684), + MX51_PIN_USBH1_DATA0 = _MXC_BUILD_GPIO_PIN(0, 11, 2, 0x288, 0x688), + MX51_PIN_USBH1_DATA1 = _MXC_BUILD_GPIO_PIN(0, 12, 2, 0x28C, 0x68C), + MX51_PIN_USBH1_DATA2 = _MXC_BUILD_GPIO_PIN(0, 13, 2, 0x290, 0x690), + MX51_PIN_USBH1_DATA3 = _MXC_BUILD_GPIO_PIN(0, 14, 2, 0x294, 0x694), + MX51_PIN_USBH1_DATA4 = _MXC_BUILD_GPIO_PIN(0, 15, 2, 0x298, 0x698), + MX51_PIN_USBH1_DATA5 = _MXC_BUILD_GPIO_PIN(0, 16, 2, 0x29C, 0x69C), + MX51_PIN_USBH1_DATA6 = _MXC_BUILD_GPIO_PIN(0, 17, 2, 0x2A0, 0x6A0), + MX51_PIN_USBH1_DATA7 = _MXC_BUILD_GPIO_PIN(0, 18, 2, 0x2A4, 0x6A4), + MX51_PIN_DI1_PIN11 = _MXC_BUILD_GPIO_PIN(2, 0, 4, 0x2A8, 0x6A8), + MX51_PIN_DI1_PIN12 = _MXC_BUILD_GPIO_PIN(2, 1, 4, 0x2AC, 0x6AC), + MX51_PIN_DI1_PIN13 = _MXC_BUILD_GPIO_PIN(2, 2, 4, 0x2B0, 0x6B0), + MX51_PIN_DI1_D0_CS = _MXC_BUILD_GPIO_PIN(2, 3, 4, 0x2B4, 0x6B4), + MX51_PIN_DI1_D1_CS = _MXC_BUILD_GPIO_PIN(2, 4, 4, 0x2B8, 0x6B8), + MX51_PIN_DISPB2_SER_DIN = _MXC_BUILD_GPIO_PIN(2, 5, 4, 0x2BC, 0x6BC), + MX51_PIN_DISPB2_SER_DIO = _MXC_BUILD_GPIO_PIN(2, 6, 4, 0x2C0, 0x6C0), + MX51_PIN_DISPB2_SER_CLK = _MXC_BUILD_GPIO_PIN(2, 7, 4, 0x2C4, 0x6C4), + MX51_PIN_DISPB2_SER_RS = _MXC_BUILD_GPIO_PIN(2, 8, 4, 0x2C8, 0x6C8), + MX51_PIN_DISP1_DAT0 = _MXC_BUILD_NON_GPIO_PIN(0x2CC, 0x6CC), + MX51_PIN_DISP1_DAT1 = _MXC_BUILD_NON_GPIO_PIN(0x2D0, 0x6D0), + MX51_PIN_DISP1_DAT2 = _MXC_BUILD_NON_GPIO_PIN(0x2D4, 0x6D4), + MX51_PIN_DISP1_DAT3 = _MXC_BUILD_NON_GPIO_PIN(0x2D8, 0x6D8), + MX51_PIN_DISP1_DAT4 = _MXC_BUILD_NON_GPIO_PIN(0x2DC, 0x6DC), + MX51_PIN_DISP1_DAT5 = _MXC_BUILD_NON_GPIO_PIN(0x2E0, 0x6E0), + MX51_PIN_DISP1_DAT6 = _MXC_BUILD_NON_GPIO_PIN(0x2E4, 0x6E4), + MX51_PIN_DISP1_DAT7 = _MXC_BUILD_NON_GPIO_PIN(0x2E8, 0x6E8), + MX51_PIN_DISP1_DAT8 = _MXC_BUILD_NON_GPIO_PIN(0x2EC, 0x6EC), + MX51_PIN_DISP1_DAT9 = _MXC_BUILD_NON_GPIO_PIN(0x2F0, 0x6F0), + MX51_PIN_DISP1_DAT10 = _MXC_BUILD_NON_GPIO_PIN(0x2F4, 0x6F4), + MX51_PIN_DISP1_DAT11 = _MXC_BUILD_NON_GPIO_PIN(0x2F8, 0x6F8), + MX51_PIN_DISP1_DAT12 = _MXC_BUILD_NON_GPIO_PIN(0x2FC, 0x6FC), + MX51_PIN_DISP1_DAT13 = _MXC_BUILD_NON_GPIO_PIN(0x300, 0x700), + MX51_PIN_DISP1_DAT14 = _MXC_BUILD_NON_GPIO_PIN(0x304, 0x704), + MX51_PIN_DISP1_DAT15 = _MXC_BUILD_NON_GPIO_PIN(0x308, 0x708), + MX51_PIN_DISP1_DAT16 = _MXC_BUILD_NON_GPIO_PIN(0x30C, 0x70C), + MX51_PIN_DISP1_DAT17 = _MXC_BUILD_NON_GPIO_PIN(0x310, 0x710), + MX51_PIN_DISP1_DAT18 = _MXC_BUILD_NON_GPIO_PIN(0x314, 0x714), + MX51_PIN_DISP1_DAT19 = _MXC_BUILD_NON_GPIO_PIN(0x318, 0x718), + MX51_PIN_DISP1_DAT20 = _MXC_BUILD_NON_GPIO_PIN(0x31C, 0x71C), + MX51_PIN_DISP1_DAT21 = _MXC_BUILD_NON_GPIO_PIN(0x320, 0x720), + MX51_PIN_DISP1_DAT22 = _MXC_BUILD_NON_GPIO_PIN(0x324, 0x724), + MX51_PIN_DISP1_DAT23 = _MXC_BUILD_NON_GPIO_PIN(0x328, 0x728), + MX51_PIN_DI1_PIN3 = _MXC_BUILD_NON_GPIO_PIN(0x32C, 0x72C), + MX51_PIN_DI1_PIN2 = _MXC_BUILD_NON_GPIO_PIN(0x330, 0x734), + MX51_PIN_DI_GP1 = _MXC_BUILD_NON_GPIO_PIN(0x334, 0x73C), + MX51_PIN_DI_GP2 = _MXC_BUILD_NON_GPIO_PIN(0x338, 0x740), + MX51_PIN_DI_GP3 = _MXC_BUILD_NON_GPIO_PIN(0x33C, 0x744), + MX51_PIN_DI2_PIN4 = _MXC_BUILD_NON_GPIO_PIN(0x340, 0x748), + MX51_PIN_DI2_PIN2 = _MXC_BUILD_NON_GPIO_PIN(0x344, 0x74C), + MX51_PIN_DI2_PIN3 = _MXC_BUILD_NON_GPIO_PIN(0x348, 0x750), + MX51_PIN_DI2_DISP_CLK = _MXC_BUILD_NON_GPIO_PIN(0x34C, 0x754), + MX51_PIN_DI_GP4 = _MXC_BUILD_NON_GPIO_PIN(0x350, 0x758), + MX51_PIN_DISP2_DAT0 = _MXC_BUILD_NON_GPIO_PIN(0x354, 0x75C), + MX51_PIN_DISP2_DAT1 = _MXC_BUILD_NON_GPIO_PIN(0x358, 0x760), + MX51_PIN_DISP2_DAT2 = _MXC_BUILD_NON_GPIO_PIN(0x35C, 0x764), + MX51_PIN_DISP2_DAT3 = _MXC_BUILD_NON_GPIO_PIN(0x360, 0x768), + MX51_PIN_DISP2_DAT4 = _MXC_BUILD_NON_GPIO_PIN(0x364, 0x76C), + MX51_PIN_DISP2_DAT5 = _MXC_BUILD_NON_GPIO_PIN(0x368, 0x770), + MX51_PIN_DISP2_DAT6 = _MXC_BUILD_GPIO_PIN(0, 19, 5, 0x36C, 0x774), + MX51_PIN_DISP2_DAT7 = _MXC_BUILD_GPIO_PIN(0, 29, 5, 0x370, 0x778), + MX51_PIN_DISP2_DAT8 = _MXC_BUILD_GPIO_PIN(0, 30, 5, 0x374, 0x77C), + MX51_PIN_DISP2_DAT9 = _MXC_BUILD_GPIO_PIN(0, 31, 5, 0x378, 0x780), + MX51_PIN_DISP2_DAT10 = _MXC_BUILD_NON_GPIO_PIN(0x37C, 0x784), + MX51_PIN_DISP2_DAT11 = _MXC_BUILD_NON_GPIO_PIN(0x380, 0x788), + MX51_PIN_DISP2_DAT12 = _MXC_BUILD_NON_GPIO_PIN(0x384, 0x78C), + MX51_PIN_DISP2_DAT13 = _MXC_BUILD_NON_GPIO_PIN(0x388, 0x790), + MX51_PIN_DISP2_DAT14 = _MXC_BUILD_NON_GPIO_PIN(0x38C, 0x794), + MX51_PIN_DISP2_DAT15 = _MXC_BUILD_NON_GPIO_PIN(0x390, 0x798), + MX51_PIN_SD1_CMD = _MXC_BUILD_NON_GPIO_PIN(0x394, 0x79C), + MX51_PIN_SD1_CLK = _MXC_BUILD_NON_GPIO_PIN(0x398, 0x7A0), + MX51_PIN_SD1_DATA0 = _MXC_BUILD_NON_GPIO_PIN(0x39C, 0x7A4), + MX51_PIN_SD1_DATA1 = _MXC_BUILD_NON_GPIO_PIN(0x3A0, 0x7A8), + MX51_PIN_SD1_DATA2 = _MXC_BUILD_NON_GPIO_PIN(0x3A4, 0x7AC), + MX51_PIN_SD1_DATA3 = _MXC_BUILD_NON_GPIO_PIN(0x3A8, 0x7B0), + MX51_PIN_GPIO1_0 = _MXC_BUILD_GPIO_PIN(0, 0, 1, 0x3AC, 0x7B4), + MX51_PIN_GPIO1_1 = _MXC_BUILD_GPIO_PIN(0, 1, 1, 0x3B0, 0x7B8), + MX51_PIN_SD2_CMD = _MXC_BUILD_NON_GPIO_PIN(0x3B4, 0x7BC), + MX51_PIN_SD2_CLK = _MXC_BUILD_NON_GPIO_PIN(0x3B8, 0x7C0), + MX51_PIN_SD2_DATA0 = _MXC_BUILD_NON_GPIO_PIN(0x3BC, 0x7C4), + MX51_PIN_SD2_DATA1 = _MXC_BUILD_NON_GPIO_PIN(0x3C0, 0x7C8), + MX51_PIN_SD2_DATA2 = _MXC_BUILD_NON_GPIO_PIN(0x3C4, 0x7CC), + MX51_PIN_SD2_DATA3 = _MXC_BUILD_NON_GPIO_PIN(0x3C8, 0x7D0), + MX51_PIN_GPIO1_2 = _MXC_BUILD_GPIO_PIN(0, 2, 0, 0x3CC, 0x7D4), + MX51_PIN_GPIO1_3 = _MXC_BUILD_GPIO_PIN(0, 3, 0, 0x3D0, 0x7D8), + MX51_PIN_PMIC_INT_REQ = _MXC_BUILD_NON_GPIO_PIN(0x3D4, 0x7FC), + MX51_PIN_GPIO1_4 = _MXC_BUILD_GPIO_PIN(0, 4, 0, 0x3D8, 0x804), + MX51_PIN_GPIO1_5 = _MXC_BUILD_GPIO_PIN(0, 5, 0, 0x3DC, 0x808), + MX51_PIN_GPIO1_6 = _MXC_BUILD_GPIO_PIN(0, 6, 0, 0x3E0, 0x80C), + MX51_PIN_GPIO1_7 = _MXC_BUILD_GPIO_PIN(0, 7, 0, 0x3E4, 0x810), + MX51_PIN_GPIO1_8 = _MXC_BUILD_GPIO_PIN(0, 8, 0, 0x3E8, 0x814), + MX51_PIN_GPIO1_9 = _MXC_BUILD_GPIO_PIN(0, 9, 0, 0x3EC, 0x818), +}; + +#endif /* __ASSEMBLY__ */ +#endif /* __ASM_ARCH_MXC_MX51_PINS_H__ */
The patch adds support for the Freescale mx51 processor.
Signed-off-by: Stefano Babic sbabic@denx.de Signed-off-by: Fred Fan fanyefeng@gmail.com --- drivers/serial/serial_mxc.c | 12 +++++++++++- 1 files changed, 11 insertions(+), 1 deletions(-)
diff --git a/drivers/serial/serial_mxc.c b/drivers/serial/serial_mxc.c index acc5b7d..4718775 100644 --- a/drivers/serial/serial_mxc.c +++ b/drivers/serial/serial_mxc.c @@ -20,6 +20,8 @@ #include <common.h> #ifdef CONFIG_MX31 #include <asm/arch/mx31.h> +#elif defined(CONFIG_MX51) +#include <asm/arch/imx-regs.h> #else #include <asm/arch/imx-regs.h> #include <asm/arch/clock.h> @@ -49,8 +51,14 @@ #define UART_PHYS 0x1001b000 #elif defined(CONFIG_SYS_MX27_UART6) #define UART_PHYS 0x1001c000 +#elif defined(CONFIG_SYS_MX51_UART1) +#define UART_PHYS UART1_BASE_ADDR +#elif defined(CONFIG_SYS_MX51_UART2) +#define UART_PHYS UART2_BASE_ADDR +#elif defined(CONFIG_SYS_MX51_UART3) +#define UART_PHYS UART3_BASE_ADDR #else -#error "define CONFIG_SYS_MX31_UARTx to use the mx31 UART driver" +#error "define CONFIG_SYS_MXxx_UARTx to use the mxxx UART driver" #endif
/* Register definitions */ @@ -168,6 +176,8 @@ void serial_setbrg (void) { #ifdef CONFIG_MX31 u32 clk = mx31_get_ipg_clk(); +#elif defined(CONFIG_MX51) + u32 clk = imx_get_uartclk(); #else u32 clk = imx_get_perclk1(); #endif
The patch add support for the Freescale mx51 processor to the FEC ethernet driver.
Signed-off-by: Stefano Babic sbabic@denx.de --- drivers/net/fec_mxc.c | 57 ++++++++++++++++++++++++++++++------------------- 1 files changed, 35 insertions(+), 22 deletions(-)
diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index 19116f2..203832e 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -27,8 +27,10 @@ #include <miiphy.h> #include "fec_mxc.h"
-#include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> +#ifndef CONFIG_MX51 +#include <asm/arch/clock.h> +#endif #include <asm/io.h> #include <asm/errno.h>
@@ -108,6 +110,23 @@ static int fec_miiphy_read(char *dev, uint8_t phyAddr, uint8_t regAddr, return 0; }
+static void fec_mii_setspeed(struct fec_priv *fec) +{ +#ifdef CONFIG_MX51 + writel((((mxc_get_clock(MXC_IPG_CLK) + 499999) / 5000000) << 1), + &fec->eth->mii_speed); +#else + /* + * Set MII_SPEED = (1/(mii_speed * 2)) * System Clock + * and do not drop the Preamble. + */ + writel((((imx_get_ahbclk() / 1000000) + 2) / 5) << 1, + &fec->eth->mii_speed); + debug("fec_init: mii_speed %#lx\n", + (((imx_get_ahbclk() / 1000000) + 2) / 5) << 1); +#endif + +} static int fec_miiphy_write(char *dev, uint8_t phyAddr, uint8_t regAddr, uint16_t data) { @@ -236,7 +255,7 @@ static int fec_rbd_init(struct fec_priv *fec, int count, int size) fec->rdb_ptr = malloc(size * count + DB_DATA_ALIGNMENT); p = (uint32_t)fec->rdb_ptr; if (!p) { - puts("fec_imx27: not enough malloc memory!\n"); + puts("fec_mxc: not enough malloc memory!\n"); return -ENOMEM; } memset((void *)p, 0, size * count + DB_DATA_ALIGNMENT); @@ -299,6 +318,7 @@ static void fec_rbd_clean(int last, struct fec_bd *pRbd)
static int fec_get_hwaddr(struct eth_device *dev, unsigned char *mac) { +#ifndef CONFIG_MX51 struct iim_regs *iim = (struct iim_regs *)IMX_IIM_BASE; int i;
@@ -306,6 +326,9 @@ static int fec_get_hwaddr(struct eth_device *dev, unsigned char *mac) mac[6-1-i] = readl(&iim->iim_bank_area0[IIM0_MAC + i]);
return is_valid_ether_addr(mac); +#else + return -1; +#endif }
static int fec_set_hwaddr(struct eth_device *dev, unsigned char *mac) @@ -373,7 +396,7 @@ static int fec_init(struct eth_device *dev, bd_t* bd) sizeof(struct fec_bd) + DB_ALIGNMENT); base = (uint32_t)fec->base_ptr; if (!base) { - puts("fec_imx27: not enough malloc memory!\n"); + puts("fec_mxc: not enough malloc memory!\n"); return -ENOMEM; } memset((void *)base, 0, (2 + FEC_RBD_NUM) * @@ -411,14 +434,8 @@ static int fec_init(struct eth_device *dev, bd_t* bd) * Frame length=1518; MII mode; */ writel(0x05ee0024, &fec->eth->r_cntrl); /* FIXME 0x05ee0004 */ - /* - * Set MII_SPEED = (1/(mii_speed * 2)) * System Clock - * and do not drop the Preamble. - */ - writel((((imx_get_ahbclk() / 1000000) + 2) / 5) << 1, - &fec->eth->mii_speed); - debug("fec_init: mii_speed %#lx\n", - (((imx_get_ahbclk() / 1000000) + 2) / 5) << 1); + + fec_mii_setspeed(fec); } /* * Set Opcode/Pause Duration Register @@ -651,22 +668,24 @@ static int fec_recv(struct eth_device *dev)
static int fec_probe(bd_t *bd) { - struct pll_regs *pll = (struct pll_regs *)IMX_PLL_BASE; struct eth_device *edev; struct fec_priv *fec = &gfec; unsigned char ethaddr_str[20]; unsigned char ethaddr[6]; - char *tmp = getenv("ethaddr"); + char *tmp; char *end; +#ifndef CONFIG_MX51 + struct pll_regs *pll = (struct pll_regs *)IMX_PLL_BASE;
/* enable FEC clock */ writel(readl(&pll->pccr1) | PCCR1_HCLK_FEC, &pll->pccr1); writel(readl(&pll->pccr0) | PCCR0_FEC_EN, &pll->pccr0); +#endif
/* create and fill edev struct */ edev = (struct eth_device *)malloc(sizeof(struct eth_device)); if (!edev) { - puts("fec_imx27: not enough malloc memory!\n"); + puts("fec_mxc: not enough malloc memory!\n"); return -ENOMEM; } edev->priv = fec; @@ -702,14 +721,7 @@ static int fec_probe(bd_t *bd) * Frame length=1518; MII mode; */ writel(0x05ee0024, &fec->eth->r_cntrl); /* FIXME 0x05ee0004 */ - /* - * Set MII_SPEED = (1/(mii_speed * 2)) * System Clock - * and do not drop the Preamble. - */ - writel((((imx_get_ahbclk() / 1000000) + 2) / 5) << 1, - &fec->eth->mii_speed); - debug("fec_init: mii_speed %#lx\n", - (((imx_get_ahbclk() / 1000000) + 2) / 5) << 1); + fec_mii_setspeed(fec);
sprintf(edev->name, "FEC_MXC");
@@ -717,6 +729,7 @@ static int fec_probe(bd_t *bd)
eth_register(edev);
+ tmp = getenv("ethaddr"); if ((NULL != tmp) && (12 <= strlen(tmp))) { int i; /* convert MAC from string to int */
The esdhc controller in the mx51 processor is quite the same as the one in some powerpc processors (MPC83xx, MPC85xx). This patches adapts the driver to support the arm mx51.
Signed-off-by: Stefano Babic sbabic@denx.de --- drivers/mmc/fsl_esdhc.c | 72 +++++++++++++++++++++++++++++++++++++++------- include/asm-arm/io.h | 21 +++++++++++++ include/fsl_esdhc.h | 6 +++- include/mmc.h | 1 + 4 files changed, 88 insertions(+), 12 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index c6e9e6e..d9574d0 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -37,6 +37,10 @@ #include <fdt_support.h> #include <asm/io.h>
+#ifndef CONFIG_PPC +#define out_be32(a, v) writel(v, a) +#define in_be32(a) __raw_readl(a) +#endif
DECLARE_GLOBAL_DATA_PTR;
@@ -129,7 +133,7 @@ static int esdhc_setup_data(struct mmc *mmc, struct mmc_data *data) out_be32(®s->blkattr, data->blocks << 16 | data->blocksize);
/* Calculate the timeout period for data transactions */ - timeout = __ilog2(mmc->tran_speed/10); + timeout = fls(mmc->tran_speed/10) - 1; timeout -= 13;
if (timeout > 14) @@ -236,11 +240,18 @@ esdhc_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, struct mmc_data *data)
void set_sysctl(struct mmc *mmc, uint clock) { +#ifdef CONFIG_PPC int sdhc_clk = gd->sdhc_clk; +#else + int sdhc_clk = mxc_get_clock(MXC_IPG_PERCLK); +#endif int div, pre_div; volatile struct fsl_esdhc *regs = mmc->priv; uint clk;
+ if (clock < mmc->f_min) + clock = mmc->f_min; + if (sdhc_clk / 16 > clock) { for (pre_div = 2; pre_div < 256; pre_div *= 2) if ((sdhc_clk / pre_div) <= (clock * 16)) @@ -257,11 +268,14 @@ void set_sysctl(struct mmc *mmc, uint clock)
clk = (pre_div << 8) | (div << 4);
+ /* On imx the clock must be stopped before changing frequency */ + clrbits_be32(®s->sysctl, SYSCTL_CKEN); + clrsetbits_be32(®s->sysctl, SYSCTL_CLOCK_MASK, clk);
udelay(10000);
- setbits_be32(®s->sysctl, SYSCTL_PEREN); + setbits_be32(®s->sysctl, SYSCTL_PEREN | SYSCTL_CKEN); }
static void esdhc_set_ios(struct mmc *mmc) @@ -278,15 +292,26 @@ static void esdhc_set_ios(struct mmc *mmc) setbits_be32(®s->proctl, PROCTL_DTW_4); else if (mmc->bus_width == 8) setbits_be32(®s->proctl, PROCTL_DTW_8); + }
static int esdhc_init(struct mmc *mmc) { struct fsl_esdhc *regs = mmc->priv; int timeout = 1000; + int ret = 0;
+#ifdef CONFIG_PPC /* Enable cache snooping */ out_be32(®s->scr, 0x00000040); +#endif + + /* Reset the entire host controller */ + out_be32(®s->sysctl, SYSCTL_RSTA); + + /* Wait until the controller is available */ + while ((in_be32(®s->sysctl) & SYSCTL_RSTA) && --timeout) + udelay(1000);
out_be32(®s->sysctl, SYSCTL_HCKEN | SYSCTL_IPGEN);
@@ -299,24 +324,44 @@ static int esdhc_init(struct mmc *mmc) /* Put the PROCTL reg back to the default */ out_be32(®s->proctl, PROCTL_INIT);
- while (!(in_be32(®s->prsstat) & PRSSTAT_CINS) && --timeout) - udelay(1000); + /* Set timout to the maximum value */ + clrsetbits_be32(®s->sysctl, SYSCTL_TIMEOUT_MASK, 14 << 16);
- if (timeout <= 0) - return NO_CARD_ERR; + /* Check if there is a callback for detecting the card */ + if (!mmc->getcd) { + timeout = 1000; + while (!(in_be32(®s->prsstat) & PRSSTAT_CINS) && --timeout) + udelay(1000);
- return 0; + if (timeout <= 0) + ret = NO_CARD_ERR; + } else { + if (mmc->getcd(mmc)) + ret = NO_CARD_ERR; + } + + return ret; }
-static int esdhc_initialize(bd_t *bis) +int fsl_esdhc_initialize(bd_t *bis, uint32_t esdhc_addr, + int (*getcd)(struct mmc *mmc)) { - struct fsl_esdhc *regs = (struct fsl_esdhc *)CONFIG_SYS_FSL_ESDHC_ADDR; +#ifdef CONFIG_PPC + int sdhc_clk = gd->sdhc_clk; +#else + int sdhc_clk = mxc_get_clock(MXC_IPG_PERCLK); +#endif + struct fsl_esdhc *regs; struct mmc *mmc; u32 caps;
mmc = malloc(sizeof(struct mmc));
sprintf(mmc->name, "FSL_ESDHC"); + regs = (struct fsl_esdhc *)CONFIG_SYS_FSL_ESDHC_ADDR; + if (esdhc_addr) + regs = (struct fsl_esdhc *)esdhc_addr; + mmc->priv = regs; mmc->send_cmd = esdhc_send_cmd; mmc->set_ios = esdhc_set_ios; @@ -337,7 +382,10 @@ static int esdhc_initialize(bd_t *bis) mmc->host_caps |= MMC_MODE_HS_52MHz | MMC_MODE_HS;
mmc->f_min = 400000; - mmc->f_max = MIN(gd->sdhc_clk, 50000000); + mmc->f_max = MIN(sdhc_clk, 50000000); + + if (getcd) + mmc->getcd = getcd;
mmc_register(mmc);
@@ -346,9 +394,10 @@ static int esdhc_initialize(bd_t *bis)
int fsl_esdhc_mmc_init(bd_t *bis) { - return esdhc_initialize(bis); + return fsl_esdhc_initialize(bis, 0, NULL); }
+#ifdef CONFIG_PPC void fdt_fixup_esdhc(void *blob, bd_t *bd) { const char *compat = "fsl,esdhc"; @@ -365,3 +414,4 @@ out: do_fixup_by_compat(blob, compat, "status", status, strlen(status) + 1, 1); } +#endif diff --git a/include/asm-arm/io.h b/include/asm-arm/io.h index fec3a7e..fb104aa 100644 --- a/include/asm-arm/io.h +++ b/include/asm-arm/io.h @@ -33,6 +33,27 @@ static inline void sync(void) { }
+/* Clear and set bits in one shot. These macros can be used to clear and + * set multiple bits in a register using a single call. These macros can + * also be used to set a multiple-bit bit pattern using a mask, by + * specifying the mask in the 'clear' parameter and the new bit pattern + * in the 'set' parameter. + */ + +#define clrbits(type, addr, clear) \ + write##type(__raw_read##type(addr) & ~(clear), (addr)) + +#define setbits(type, addr, set) \ + write##type(__raw_read##type(addr) | (set), (addr)) + +#define clrsetbits(type, addr, clear, set) \ + write##type((__raw_read##type(addr) & ~(clear)) | (set), (addr)) + +#define clrbits_be32(addr, clear) clrbits(l, addr, clear) +#define setbits_be32(addr, set) setbits(l, addr, set) +#define clrsetbits_be32(addr, clear, set) clrsetbits(l, addr, clear, set) + + /* * Given a physical address and a length, return a virtual address * that can be used to access the memory range with the caching diff --git a/include/fsl_esdhc.h b/include/fsl_esdhc.h index 89b8304..605e065 100644 --- a/include/fsl_esdhc.h +++ b/include/fsl_esdhc.h @@ -32,7 +32,9 @@ #define SYSCTL 0x0002e02c #define SYSCTL_INITA 0x08000000 #define SYSCTL_TIMEOUT_MASK 0x000f0000 -#define SYSCTL_CLOCK_MASK 0x00000fff +#define SYSCTL_CLOCK_MASK 0x0000ffff +#define SYSCTL_RSTA 0x01000000 +#define SYSCTL_CKEN 0x00000008 #define SYSCTL_PEREN 0x00000004 #define SYSCTL_HCKEN 0x00000002 #define SYSCTL_IPGEN 0x00000001 @@ -144,6 +146,8 @@
#ifdef CONFIG_FSL_ESDHC int fsl_esdhc_mmc_init(bd_t *bis); +int fsl_esdhc_initialize(bd_t *bis, uint32_t esdhc_addr, + int (*getcd)(struct mmc *mmc)); void fdt_fixup_esdhc(void *blob, bd_t *bd); #else static inline int fsl_esdhc_mmc_init(bd_t *bis) { return -ENOSYS; } diff --git a/include/mmc.h b/include/mmc.h index 2dc69ab..bc29953 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -264,6 +264,7 @@ struct mmc { struct mmc_cmd *cmd, struct mmc_data *data); void (*set_ios)(struct mmc *mmc); int (*init)(struct mmc *mmc); + int (*getcd)(struct mmc *mmc); };
int mmc_register(struct mmc *mmc);
Most cards do not answer if some reserved bits in the ocr are set. However, some controllers can set bit 7 (reserved for low voltages), but how to manage low voltages SD card is not yet specified.
Signed-off-by: Stefano Babic sbabic@denx.de --- drivers/mmc/mmc.c | 10 +++++++++- 1 files changed, 9 insertions(+), 1 deletions(-)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index b69ce15..d91b9b7 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -273,7 +273,15 @@ sd_send_op_cond(struct mmc *mmc)
cmd.cmdidx = SD_CMD_APP_SEND_OP_COND; cmd.resp_type = MMC_RSP_R3; - cmd.cmdarg = mmc->voltages; + + /* + * Most cards do not answer if some reserved bits + * in the ocr are set. However, Some controller + * can set bit 7 (reserved for low voltages), but + * how to manage low voltages SD card is not yet + * specified. + */ + cmd.cmdarg = mmc->voltages & 0xff8000;
if (mmc->version == SD_VERSION_2) cmd.cmdarg |= OCR_HCS;
The patch adds initial support for the Freescale mx51evk board. Network (FEC) and SD controller (fsl_esdhc) are supported.
Signed-off-by: Stefano Babic sbabic@denx.de Signed-off-by: Fred Fan fanyefeng@gmail.com --- MAINTAINERS | 4 + MAKEALL | 1 + Makefile | 8 + board/freescale/mx51evk/Makefile | 48 ++++ board/freescale/mx51evk/config.mk | 25 ++ board/freescale/mx51evk/imximage.cfg | 119 ++++++++++ board/freescale/mx51evk/mx51evk.c | 432 ++++++++++++++++++++++++++++++++++ board/freescale/mx51evk/mx51evk.h | 51 ++++ include/configs/mx51evk.h | 175 ++++++++++++++ 9 files changed, 863 insertions(+), 0 deletions(-) create mode 100644 board/freescale/mx51evk/Makefile create mode 100644 board/freescale/mx51evk/config.mk create mode 100644 board/freescale/mx51evk/imximage.cfg create mode 100644 board/freescale/mx51evk/mx51evk.c create mode 100644 board/freescale/mx51evk/mx51evk.h create mode 100644 include/configs/mx51evk.h
diff --git a/MAINTAINERS b/MAINTAINERS index 9734b1d..8637550 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -151,6 +151,10 @@ Dave Ellis DGE@sixnetio.com
SXNI855T MPC8xx
+Fred Fan fanyefeng@gmail.com + + mx51evk i.MX51 + Thomas Frieden ThomasF@hyperion-entertainment.com
AmigaOneG3SE MPC7xx diff --git a/MAKEALL b/MAKEALL index ab1bb6f..485107a 100755 --- a/MAKEALL +++ b/MAKEALL @@ -617,6 +617,7 @@ LIST_ARM11=" \ ######################################################################### LIST_ARM_CORTEX_A8=" \ devkit8000 \ + mx51evk \ omap3_beagle \ omap3_overo \ omap3_evm \ diff --git a/Makefile b/Makefile index ed6156f..01bf9a2 100644 --- a/Makefile +++ b/Makefile @@ -324,6 +324,10 @@ $(obj)u-boot.img: $(obj)u-boot.bin sed -e 's/"[ ]*$$/ for $(BOARD) board"/') \ -d $< $@
+$(obj)u-boot.imx: $(obj)u-boot.bin + $(obj)tools/mkimage -n $(IMX_CONFIG) -T imximage \ + -e $(TEXT_BASE) -d $< $@ + $(obj)u-boot.kwb: $(obj)u-boot.bin $(obj)tools/mkimage -n $(KWD_CONFIG) -T kwbimage \ -a $(TEXT_BASE) -e $(TEXT_BASE) -d $< $@ @@ -3263,6 +3267,9 @@ mx31pdk_nand_config : unconfig fi @$(MKCONFIG) -a mx31pdk arm arm1136 mx31pdk freescale mx31
+mx51evk_config : unconfig + @$(MKCONFIG) $(@:_config=) arm arm_cortexa8 mx51evk freescale mx51 + omap2420h4_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm1136 omap2420h4 ti omap24xx
@@ -3729,6 +3736,7 @@ clobber: clean $(obj)cscope.* $(obj)*.*~ @rm -f $(obj)u-boot $(obj)u-boot.map $(obj)u-boot.hex $(ALL) @rm -f $(obj)u-boot.kwb + @rm -f $(obj)u-boot.imx @rm -f $(obj)tools/{env/crc32.c,inca-swap-bytes} @rm -f $(obj)cpu/mpc824x/bedbug_603e.c @rm -f $(obj)include/asm/proc $(obj)include/asm/arch $(obj)include/asm diff --git a/board/freescale/mx51evk/Makefile b/board/freescale/mx51evk/Makefile new file mode 100644 index 0000000..eb12fc5 --- /dev/null +++ b/board/freescale/mx51evk/Makefile @@ -0,0 +1,48 @@ +# +# Copyright (C) 2007, Guennadi Liakhovetski lg@denx.de +# +# (C) Copyright 2009 Freescale Semiconductor, Inc. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := mx51evk.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/freescale/mx51evk/config.mk b/board/freescale/mx51evk/config.mk new file mode 100644 index 0000000..c8279ec --- /dev/null +++ b/board/freescale/mx51evk/config.mk @@ -0,0 +1,25 @@ +# +# Copyright 2009 Freescale Semiconductor, Inc. All Rights Reserved. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +LDSCRIPT = cpu/$(CPU)/$(SOC)/u-boot.lds +TEXT_BASE = 0x97800000 +IMX_CONFIG = $(SRCTREE)/board/$(BOARDDIR)/imximage.cfg diff --git a/board/freescale/mx51evk/imximage.cfg b/board/freescale/mx51evk/imximage.cfg new file mode 100644 index 0000000..db09913 --- /dev/null +++ b/board/freescale/mx51evk/imximage.cfg @@ -0,0 +1,119 @@ +# +# (C Copyright 2009 +# Stefano Babic DENX Software Engineering sbabic@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not write to the Free Software +# Foundation Inc. 51 Franklin Street Fifth Floor Boston, +# MA 02110-1301 USA +# +# Refer docs/README.imxmage for more details about how-to configure +# and create imximage boot image +# +# The syntax is taken as close as possible with the kwbimage + +# Boot Device : one of +# spi_flash, nand, onenand, sd_card + +BOOT_FROM spi + +# Device Configuration Data (DCD) +# +# Each entry must have the format: +# Addr-type Address Value +# +# where: +# Addr-type register length (1,2 or 4 bytes) +# Address absolute address of the register +# value value to be stored in the register + +# Setting IOMUXC +DATA 4 0x73FA88a0 0x200 +DATA 4 0x73FA850c 0x20c5 +DATA 4 0x73FA8510 0x20c5 +DATA 4 0x73FA883c 0x2 +DATA 4 0x73FA8848 0x2 +DATA 4 0x73FA84b8 0xe7 +DATA 4 0x73FA84bc 0x45 +DATA 4 0x73FA84c0 0x45 +DATA 4 0x73FA84c4 0x45 +DATA 4 0x73FA84c8 0x45 +DATA 4 0x73FA8820 0x0 +DATA 4 0x73FA84a4 0x3 +DATA 4 0x73FA84a8 0x3 +DATA 4 0x73FA84ac 0xe3 +DATA 4 0x73FA84b0 0xe3 +DATA 4 0x73FA84b4 0xe3 +DATA 4 0x73FA84cc 0xe3 +DATA 4 0x73FA84d0 0xe2 + +DATA 4 0x73FA882c 0x6 +DATA 4 0x73FA88a4 0x6 +DATA 4 0x73FA88ac 0x6 +DATA 4 0x73FA88b8 0x6 + +# Setting DDR for micron +# 13 Rows, 10 Cols, 32 bit, SREF=4 Micron Model +# CAS=3 BL=4 +# ESDCTL_ESDCTL0 +DATA 4 0x83FD9000 0x82a20000 +# ESDCTL_ESDCTL1 +DATA 4 0x83FD9008 0x82a20000 +# ESDCTL_ESDMISC +DATA 4 0x83FD9010 0x000ad0d0 +# ESDCTL_ESDCFG0 +DATA 4 0x83FD9004 0x333574aa +# ESDCTL_ESDCFG1 +DATA 4 0x83FD900C 0x333574aa + +# Init DRAM on CS0 +# ESDCTL_ESDSCR +DATA 4 0x83FD9014 0x04008008 +DATA 4 0x83FD9014 0x0000801a +DATA 4 0x83FD9014 0x0000801b +DATA 4 0x83FD9014 0x00448019 +DATA 4 0x83FD9014 0x07328018 +DATA 4 0x83FD9014 0x04008008 +DATA 4 0x83FD9014 0x00008010 +DATA 4 0x83FD9014 0x00008010 +DATA 4 0x83FD9014 0x06328018 +DATA 4 0x83FD9014 0x03808019 +DATA 4 0x83FD9014 0x00408019 +DATA 4 0x83FD9014 0x00008000 + +# Init DRAM on CS1 +DATA 4 0x83FD9014 0x0400800c +DATA 4 0x83FD9014 0x0000801e +DATA 4 0x83FD9014 0x0000801f +DATA 4 0x83FD9014 0x0000801d +DATA 4 0x83FD9014 0x0732801c +DATA 4 0x83FD9014 0x0400800c +DATA 4 0x83FD9014 0x00008014 +DATA 4 0x83FD9014 0x00008014 +DATA 4 0x83FD9014 0x0632801c +DATA 4 0x83FD9014 0x0380801d +DATA 4 0x83FD9014 0x0040801d +DATA 4 0x83FD9014 0x00008004 + +# Write to CTL0 +DATA 4 0x83FD9000 0xb2a20000 +# Write to CTL1 +DATA 4 0x83FD9008 0xb2a20000 +# ESDMISC +DATA 4 0x83FD9010 0x000ad6d0 +#ESDCTL_ESDCDLYGD +DATA 4 0x83FD9034 0x90000000 +DATA 4 0x83FD9014 0x00000000 diff --git a/board/freescale/mx51evk/mx51evk.c b/board/freescale/mx51evk/mx51evk.c new file mode 100644 index 0000000..82f73f0 --- /dev/null +++ b/board/freescale/mx51evk/mx51evk.c @@ -0,0 +1,432 @@ +/* + * (C) Copyright 2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/mx51_pins.h> +#include <asm/arch/iomux.h> +#include <asm/errno.h> +#include <i2c.h> +#include <mmc.h> +#include <fsl_esdhc.h> +#include "mx51evk.h" + +DECLARE_GLOBAL_DATA_PTR; + +static u32 system_rev; +struct io_board_ctrl *mx51_io_board; + +u32 get_board_rev(void) +{ + return system_rev; +} + +static inline void setup_soc_rev(void) +{ + int reg; + + reg = __raw_readl(ROM_SI_REV); + switch (reg) { + case 0x02: + system_rev = 0x51000 | CHIP_REV_1_1; + break; + case 0x10: + if ((__raw_readl(GPIO1_BASE_ADDR + 0x0) & (0x1 << 22)) == 0) + system_rev = 0x51000 | CHIP_REV_2_5; + else + system_rev = 0x51000 | CHIP_REV_2_0; + break; + case 0x20: + system_rev = 0x51000 | CHIP_REV_3_0; + break; + default: + system_rev = 0x51000 | CHIP_REV_1_0; + break; + } +} + +static inline void set_board_rev(int rev) +{ + system_rev |= (rev & 0xF) << 8; +} + +inline int is_soc_rev(int rev) +{ + return (system_rev & 0xFF) - rev; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = get_ram_size((long *)PHYS_SDRAM_1, + PHYS_SDRAM_1_SIZE); + return 0; +} + +static void setup_uart(void) +{ + unsigned int pad = PAD_CTL_HYS_ENABLE | PAD_CTL_PKE_ENABLE | + PAD_CTL_PUE_PULL | PAD_CTL_DRV_HIGH; + + mxc_request_iomux(MX51_PIN_UART1_RXD, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX51_PIN_UART1_RXD, pad | PAD_CTL_SRE_FAST); + mxc_request_iomux(MX51_PIN_UART1_TXD, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX51_PIN_UART1_TXD, pad | PAD_CTL_SRE_FAST); + mxc_request_iomux(MX51_PIN_UART1_RTS, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX51_PIN_UART1_RTS, pad); + mxc_request_iomux(MX51_PIN_UART1_CTS, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX51_PIN_UART1_CTS, pad); +} + +static void setup_expio(void) +{ + u32 reg; + + /* CS5 setup */ + mxc_request_iomux(MX51_PIN_EIM_CS5, IOMUX_CONFIG_ALT0); + writel(0x00410089, WEIM_BASE_ADDR + 0x78 + CSGCR1); + writel(0x00000002, WEIM_BASE_ADDR + 0x78 + CSGCR2); + /* RWSC=50, RADVA=2, RADVN=6, OEA=0, OEN=0, RCSA=0, RCSN=0 */ + writel(0x32260000, WEIM_BASE_ADDR + 0x78 + CSRCR1); + /* APR = 0 */ + writel(0x00000000, WEIM_BASE_ADDR + 0x78 + CSRCR2); + /* + * WAL=0, WBED=1, WWSC=50, WADVA=2, WADVN=6, WEA=0, WEN=0, + * WCSA=0, WCSN=0 + */ + writel(0x72080F00, WEIM_BASE_ADDR + 0x78 + CSWCR1); + + mx51_io_board = (struct io_board_ctrl *)(CS5_BASE_ADDR + + IO_BOARD_OFFSET); + if ((readw(&mx51_io_board->id1) == 0xAAAA) && + (readw(&mx51_io_board->id2) == 0x5555)) { + if (is_soc_rev(CHIP_REV_2_0) < 0) { + reg = readl(CCM_BASE_ADDR + CLKCTL_CBCDR); + reg = (reg & (~0x70000)) | 0x30000; + writel(reg, CCM_BASE_ADDR + CLKCTL_CBCDR); + /* make sure divider effective */ + while (readl(CCM_BASE_ADDR + CLKCTL_CDHIPR) != 0) + ; + writel(0x0, CCM_BASE_ADDR + CLKCTL_CCDR); + } + } else { + /* CS1 */ + writel(0x00410089, WEIM_BASE_ADDR + 0x18 + CSGCR1); + writel(0x00000002, WEIM_BASE_ADDR + 0x18 + CSGCR2); + /* RWSC=50, RADVA=2, RADVN=6, OEA=0, OEN=0, RCSA=0, RCSN=0 */ + writel(0x32260000, WEIM_BASE_ADDR + 0x18 + CSRCR1); + /* APR=0 */ + writel(0x00000000, WEIM_BASE_ADDR + 0x18 + CSRCR2); + /* WAL=0, WBED=1, WWSC=50, WADVA=2, WADVN=6, WEA=0, + * WEN=0, WCSA=0, WCSN=0 + */ + writel(0x72080F00, WEIM_BASE_ADDR + 0x18 + CSWCR1); + mx51_io_board = (struct io_board_ctrl *)(CS1_BASE_ADDR + + IO_BOARD_OFFSET); + } + + /* Reset interrupt status reg */ + writew(0x1F, &(mx51_io_board->int_rest)); + writew(0x00, &(mx51_io_board->int_rest)); + writew(0xFFFF, &(mx51_io_board->int_mask)); + + /* Reset the XUART and Ethernet controllers */ + reg = readw(&(mx51_io_board->sw_reset)); + reg |= 0x9; + writew(reg, &(mx51_io_board->sw_reset)); + reg &= ~0x9; + writew(reg, &(mx51_io_board->sw_reset)); +} + +static void setup_fec(void) +{ + /*FEC_MDIO*/ + mxc_request_iomux(MX51_PIN_EIM_EB2 , IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX51_PIN_EIM_EB2 , 0x1FD); + + /*FEC_MDC*/ + mxc_request_iomux(MX51_PIN_NANDF_CS3, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_NANDF_CS3, 0x2004); + + /* FEC RDATA[3] */ + mxc_request_iomux(MX51_PIN_EIM_CS3, IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX51_PIN_EIM_CS3, 0x180); + + /* FEC RDATA[2] */ + mxc_request_iomux(MX51_PIN_EIM_CS2, IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX51_PIN_EIM_CS2, 0x180); + + /* FEC RDATA[1] */ + mxc_request_iomux(MX51_PIN_EIM_EB3, IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX51_PIN_EIM_EB3, 0x180); + + /* FEC RDATA[0] */ + mxc_request_iomux(MX51_PIN_NANDF_D9, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_NANDF_D9, 0x2180); + + /* FEC TDATA[3] */ + mxc_request_iomux(MX51_PIN_NANDF_CS6, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_NANDF_CS6, 0x2004); + + /* FEC TDATA[2] */ + mxc_request_iomux(MX51_PIN_NANDF_CS5, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_NANDF_CS5, 0x2004); + + /* FEC TDATA[1] */ + mxc_request_iomux(MX51_PIN_NANDF_CS4, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_NANDF_CS4, 0x2004); + + /* FEC TDATA[0] */ + mxc_request_iomux(MX51_PIN_NANDF_D8, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_NANDF_D8, 0x2004); + + /* FEC TX_EN */ + mxc_request_iomux(MX51_PIN_NANDF_CS7, IOMUX_CONFIG_ALT1); + mxc_iomux_set_pad(MX51_PIN_NANDF_CS7, 0x2004); + + /* FEC TX_ER */ + mxc_request_iomux(MX51_PIN_NANDF_CS2, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_NANDF_CS2, 0x2004); + + /* FEC TX_CLK */ + mxc_request_iomux(MX51_PIN_NANDF_RDY_INT, IOMUX_CONFIG_ALT1); + mxc_iomux_set_pad(MX51_PIN_NANDF_RDY_INT, 0x2180); + + /* FEC TX_COL */ + mxc_request_iomux(MX51_PIN_NANDF_RB2, IOMUX_CONFIG_ALT1); + mxc_iomux_set_pad(MX51_PIN_NANDF_RB2, 0x2180); + + /* FEC RX_CLK */ + mxc_request_iomux(MX51_PIN_NANDF_RB3, IOMUX_CONFIG_ALT1); + mxc_iomux_set_pad(MX51_PIN_NANDF_RB3, 0x2180); + + /* FEC RX_CRS */ + mxc_request_iomux(MX51_PIN_EIM_CS5, IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX51_PIN_EIM_CS5, 0x180); + + /* FEC RX_ER */ + mxc_request_iomux(MX51_PIN_EIM_CS4, IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX51_PIN_EIM_CS4, 0x180); + + /* FEC RX_DV */ + mxc_request_iomux(MX51_PIN_NANDF_D11, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_NANDF_D11, 0x2180); +} + +#ifdef CONFIG_NET_MULTI +int board_eth_init(bd_t *bis) +{ + int rc = -ENODEV; + +#ifdef CONFIG_FEC_MXC + rc = fecmxc_initialize(bis); +#endif + return rc; +} +#endif + +#ifdef CONFIG_FSL_ESDHC +int get_mmc_cd(struct mmc *mmc) +{ + uint32_t reg_base = (uint32_t)mmc->priv; + int ret; + + if (reg_base == MMC_SDHC1_BASE_ADDR) + ret = readl(GPIO1_BASE_ADDR) & 0x01; + else + ret = readl(GPIO1_BASE_ADDR) & 0x40; + + return ret; +} + +int board_mmc_init(bd_t *bis) +{ + u32 interface_esdhc = 0; + s32 status = 0; + u32 esdhc_base_pointer; + + for (interface_esdhc = 0; interface_esdhc < CONFIG_SYS_FSL_ESDHC_NUM; + interface_esdhc++) { + switch (interface_esdhc) { + case 0: + esdhc_base_pointer = MMC_SDHC1_BASE_ADDR; + + mxc_request_iomux(MX51_PIN_SD1_CMD, + IOMUX_CONFIG_ALT0 | IOMUX_CONFIG_SION); + mxc_request_iomux(MX51_PIN_SD1_CLK, + IOMUX_CONFIG_ALT0 | IOMUX_CONFIG_SION); + mxc_request_iomux(MX51_PIN_SD1_DATA0, + IOMUX_CONFIG_ALT0 | IOMUX_CONFIG_SION); + mxc_request_iomux(MX51_PIN_SD1_DATA1, + IOMUX_CONFIG_ALT0 | IOMUX_CONFIG_SION); + mxc_request_iomux(MX51_PIN_SD1_DATA2, + IOMUX_CONFIG_ALT0 | IOMUX_CONFIG_SION); + mxc_request_iomux(MX51_PIN_SD1_DATA3, + IOMUX_CONFIG_ALT0 | IOMUX_CONFIG_SION); + mxc_iomux_set_pad(MX51_PIN_SD1_CMD, + PAD_CTL_DRV_MAX | PAD_CTL_DRV_VOT_HIGH | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU | + PAD_CTL_PUE_PULL | + PAD_CTL_PKE_ENABLE | PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_SD1_CLK, + PAD_CTL_DRV_MAX | PAD_CTL_DRV_VOT_HIGH | + PAD_CTL_HYS_NONE | PAD_CTL_47K_PU | + PAD_CTL_PUE_PULL | + PAD_CTL_PKE_ENABLE | PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_SD1_DATA0, + PAD_CTL_DRV_MAX | PAD_CTL_DRV_VOT_HIGH | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU | + PAD_CTL_PUE_PULL | + PAD_CTL_PKE_ENABLE | PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_SD1_DATA1, + PAD_CTL_DRV_MAX | PAD_CTL_DRV_VOT_HIGH | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU | + PAD_CTL_PUE_PULL | + PAD_CTL_PKE_ENABLE | PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_SD1_DATA2, + PAD_CTL_DRV_MAX | PAD_CTL_DRV_VOT_HIGH | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU | + PAD_CTL_PUE_PULL | + PAD_CTL_PKE_ENABLE | PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_SD1_DATA3, + PAD_CTL_DRV_MAX | PAD_CTL_DRV_VOT_HIGH | + PAD_CTL_HYS_ENABLE | PAD_CTL_100K_PD | + PAD_CTL_PUE_PULL | + PAD_CTL_PKE_ENABLE | PAD_CTL_SRE_FAST); + mxc_request_iomux(MX51_PIN_GPIO1_0, + IOMUX_CONFIG_ALT0 | IOMUX_CONFIG_SION); + mxc_iomux_set_pad(MX51_PIN_GPIO1_0, + PAD_CTL_HYS_ENABLE); + mxc_request_iomux(MX51_PIN_GPIO1_1, + IOMUX_CONFIG_ALT0 | IOMUX_CONFIG_SION); + mxc_iomux_set_pad(MX51_PIN_GPIO1_1, + PAD_CTL_HYS_ENABLE); + break; + case 1: + esdhc_base_pointer = MMC_SDHC2_BASE_ADDR; + + mxc_request_iomux(MX51_PIN_SD2_CMD, + IOMUX_CONFIG_ALT0 | IOMUX_CONFIG_SION); + mxc_request_iomux(MX51_PIN_SD2_CLK, + IOMUX_CONFIG_ALT0 | IOMUX_CONFIG_SION); + mxc_request_iomux(MX51_PIN_SD2_DATA0, + IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX51_PIN_SD2_DATA1, + IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX51_PIN_SD2_DATA2, + IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX51_PIN_SD2_DATA3, + IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX51_PIN_SD2_CMD, + PAD_CTL_DRV_MAX | PAD_CTL_22K_PU | + PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_SD2_CLK, + PAD_CTL_DRV_MAX | PAD_CTL_22K_PU | + PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_SD2_DATA0, + PAD_CTL_DRV_MAX | PAD_CTL_22K_PU | + PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_SD2_DATA1, + PAD_CTL_DRV_MAX | PAD_CTL_22K_PU | + PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_SD2_DATA2, + PAD_CTL_DRV_MAX | PAD_CTL_22K_PU | + PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_SD2_DATA3, + PAD_CTL_DRV_MAX | PAD_CTL_22K_PU | + PAD_CTL_SRE_FAST); + mxc_request_iomux(MX51_PIN_SD2_CMD, + IOMUX_CONFIG_ALT0 | IOMUX_CONFIG_SION); + mxc_request_iomux(MX51_PIN_GPIO1_6, + IOMUX_CONFIG_ALT0 | IOMUX_CONFIG_SION); + mxc_iomux_set_pad(MX51_PIN_GPIO1_6, + PAD_CTL_HYS_ENABLE); + mxc_request_iomux(MX51_PIN_GPIO1_5, + IOMUX_CONFIG_ALT0 | IOMUX_CONFIG_SION); + mxc_iomux_set_pad(MX51_PIN_GPIO1_5, + PAD_CTL_HYS_ENABLE); + break; + } + status |= fsl_esdhc_initialize(bis, esdhc_base_pointer, + get_mmc_cd); + } + return status; +} + +#endif + +int board_init(void) +{ + setup_soc_rev(); + + gd->bd->bi_arch_number = MACH_TYPE_MX51_BABBAGE; /* board id for linux */ + /* address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; + + setup_uart(); + setup_expio(); + setup_fec(); + return 0; +} + +int checkboard(void) +{ + puts("Board: MX51EVK "); + + switch (system_rev & 0xff) { + case CHIP_REV_3_0: + puts("3.0 ["); + break; + case CHIP_REV_2_5: + puts("2.5 ["); + break; + case CHIP_REV_2_0: + puts("2.0 ["); + break; + case CHIP_REV_1_1: + puts("1.1 ["); + break; + case CHIP_REV_1_0: + default: + puts("1.0 ["); + break; + } + + switch (__raw_readl(SRC_BASE_ADDR + 0x8)) { + case 0x0001: + puts("POR"); + break; + case 0x0009: + puts("RST"); + break; + case 0x0010: + case 0x0011: + puts("WDOG"); + break; + default: + puts("unknown"); + } + puts("]\n"); + return 0; +} + diff --git a/board/freescale/mx51evk/mx51evk.h b/board/freescale/mx51evk/mx51evk.h new file mode 100644 index 0000000..524cdcc --- /dev/null +++ b/board/freescale/mx51evk/mx51evk.h @@ -0,0 +1,51 @@ +/* + * (C) Copyright 2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __BOARD_FREESCALE_MX51_EVK_H__ +#define __BOARD_FREESCALE_MX51_EVK_H__ + +#ifndef __ASSEMBLY__ +struct io_board_ctrl { + u16 led_ctrl; /* 0x00 */ + u16 resv1[0x03]; + u16 sb_stat; /* 0x08 */ + u16 resv2[0x03]; + u16 int_stat; /* 0x10 */ + u16 resv3[0x07]; + u16 int_rest; /* 0x20 */ + u16 resv4[0x0B]; + u16 int_mask; /* 0x38 */ + u16 resv5[0x03]; + u16 id1; /* 0x40 */ + u16 resv6[0x03]; + u16 id2; /* 0x48 */ + u16 resv7[0x03]; + u16 version; /* 0x50 */ + u16 resv8[0x03]; + u16 id3; /* 0x58 */ + u16 resv9[0x03]; + u16 sw_reset; /* 0x60 */ +}; +#endif + +#define IO_BOARD_OFFSET (0x20000) +#endif diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h new file mode 100644 index 0000000..42b1bf5 --- /dev/null +++ b/include/configs/mx51evk.h @@ -0,0 +1,175 @@ +/* + * Copyright (C) 2007, Guennadi Liakhovetski lg@denx.de + * + * (C) Copyright 2009 Freescale Semiconductor, Inc. + * + * Configuration settings for the MX51-3Stack Freescale board. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/arch/imx-regs.h> + + /* High Level Configuration Options */ +#define CONFIG_SYS_APCS_GNU +#define CONFIG_L2_OFF + +#define CONFIG_MX51 /* in a mx51 */ + +#define CONFIG_SKIP_RELOCATE_UBOOT + +#define CONFIG_MX51_HCLK_FREQ 24000000 /* RedBoot says 26MHz */ +#define CONFIG_MX51_CLK32 32768 +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +/* + * Disabled for now due to build problems under Debian and a significant + * increase in the final file size: 144260 vs. 109536 Bytes. + */ + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_REVISION_TAG 1 +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024) +/* size in bytes reserved for initial data */ +#define CONFIG_SYS_GBL_DATA_SIZE 128 + +/* + * Hardware drivers + */ +#define CONFIG_MXC_UART +#define CONFIG_SYS_MX51_UART1 + +/* + * MMC Configs + * */ +#define CONFIG_FSL_ESDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR MMC_SDHC1_BASE_ADDR +#define CONFIG_SYS_FSL_ESDHC_NUM 2 + +#define CONFIG_MMC + +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION + +/* + * Eth Configs + */ +#define CONFIG_HAS_ETH1 +#define CONFIG_NET_MULTI +#define CONFIG_MII +#define CONFIG_DISCOVER_PHY + +#define CONFIG_FEC_MXC +#define IMX_FEC_BASE FEC_BASE_ADDR +#define CONFIG_FEC_MXC_PHYADDR 0x1F + +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MII +#define CONFIG_CMD_NET + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {9600, 19200, 38400, 57600, 115200} + +/*********************************************************** + * Command definition + ***********************************************************/ + +#include <config_cmd_default.h> + +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#undef CONFIG_CMD_IMLS + +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_PRIME "FEC0" + +#define CONFIG_LOADADDR 0x90800000 /* loadaddr env var */ + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netdev=eth0\0" \ + "uboot_addr=0xa0000000\0" \ + "uboot=u-boot.bin\0" \ + "loadaddr=0x90800000\0" \ + "bootargs_base=setenv bootargs console= tty console=ttymxc0,${baudrate}\0"\ + "bootargs_nfs=setenv bootargs ${bootargs} root=/dev/nfs "\ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0"\ + "bootcmd=run bootcmd_net\0" \ + "bootcmd_net=run bootargs_base bootargs_nfs; " \ + "tftpboot ${loadaddr} ${kernel}; bootm\0" + +#define CONFIG_ARP_TIMEOUT 200UL + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_PROMPT "MX51EVK U-Boot > " +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ + +#define CONFIG_SYS_MEMTEST_START CSD0_BASE_ADDR +#define CONFIG_SYS_MEMTEST_END 0x10000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#define CONFIG_SYS_HZ 1000 +#define CONFIG_CMDLINE_EDITING + +/*----------------------------------------------------------------------- + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128 * 1024) /* regular stack */ + +/*----------------------------------------------------------------------- + * Physical Memory Map + */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM_1 CSD0_BASE_ADDR +#define PHYS_SDRAM_1_SIZE (512 * 1024 * 1024) + +/*----------------------------------------------------------------------- + * FLASH and environment organization + */ +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_ENV_SECT_SIZE (128 * 1024) +#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE +#define CONFIG_ENV_IS_NOWHERE + +#endif /* __CONFIG_H */
Wolfgang has already covered most of this, but I have a few other comments (plus a couple of redundant ones)
I know why you did this, but I really think it's a bad idea to "trick" the driver into doing the right thing. It's more painful, but we need to change all of the out_be32/in_be32 commands into something generic, and then add support for big and little endian accesses. This is just a hack. :(
- timeout = fls(mmc->tran_speed/10) - 1;
timeout -= 13;
- int sdhc_clk = mxc_get_clock(MXC_IPG_PERCLK);
Let's try to use #ifdefs sparingly, and definitely have them trigger on constants that are directly related to the difference. This isn't a PPC/ARM problem. I see you've already agreed to use gd->sdhc_clk, though, so that's good.
- if (clock < mmc->f_min)
- clock = mmc->f_min;
- /* On imx the clock must be stopped before changing frequency */
- clrbits_be32(®s->sysctl, SYSCTL_CKEN);
udelay(10000);
- setbits_be32(®s->sysctl, SYSCTL_PEREN | SYSCTL_CKEN);
- int ret = 0;
You have two choices, here. Either create a new CONFIG_SYS option that declares the existence of this register for platforms that have it, OR (my preference) design a configuration mechanism which allows board/cpu code to declare such things. Ideally, the driver could detect this based on a version register, but I'm well aware that FSL's hardware designers frequently forget to increment their version numbers for such "small" changes. What is certain is that CONFIG_PPC is wrong.
- /* Reset the entire host controller */
- out_be32(®s->sysctl, SYSCTL_RSTA);
- /* Wait until the controller is available */
- while ((in_be32(®s->sysctl) & SYSCTL_RSTA) && --timeout)
- udelay(1000);
- udelay(1000);
- /* Set timout to the maximum value */
- clrsetbits_be32(®s->sysctl, SYSCTL_TIMEOUT_MASK, 14 << 16);
- if (timeout <= 0)
- /* Check if there is a callback for detecting the card */
- if (!mmc->getcd) {
- timeout = 1000;
- udelay(1000);
- if (timeout <= 0)
- ret = NO_CARD_ERR;
- } else {
- if (mmc->getcd(mmc))
- return ret;
- int (*getcd)(struct mmc *mmc))
+#ifdef CONFIG_PPC
- int sdhc_clk = gd->sdhc_clk;
+#else
- struct fsl_esdhc *regs;
- regs = (struct fsl_esdhc *)CONFIG_SYS_FSL_ESDHC_ADDR;
- if (esdhc_addr)
- regs = (struct fsl_esdhc *)esdhc_addr;
I agree with Wolfgang, here. Also, it's a bit iffy to set it, then optionally overwrite it.
- mmc->f_max = MIN(sdhc_clk, 50000000);
- if (getcd)
- mmc->getcd = getcd;
I don't fundamentally object to this change, but I have more comments on it later.
mmc_register(mmc);
- return fsl_esdhc_initialize(bis, 0, NULL);
Use the OF config option, here.
- set multiple bits in a register using a single call. These macros can
- also be used to set a multiple-bit bit pattern using a mask, by
- specifying the mask in the 'clear' parameter and the new bit pattern
- in the 'set' parameter.
- write##type(__raw_read##type(addr) & ~(clear), (addr))
- write##type(__raw_read##type(addr) | (set), (addr))
- write##type((__raw_read##type(addr) & ~(clear)) | (set), (addr))
This should be part of a completely different patch. Also, I'm positive that it's completely wrong. setbits_be32 is big endian, writel is little endian.
- int (*getcd)(struct mmc *mmc));
Hmmm....this doesn't scale well. Rather than pass in an address and a function pointer, create a structure with that information, and then pass *that* in. That way, when we discover we want some other information/functions, we can add them without having to modify the API.
Also, I'm not entirely sold on the idea that getcd should be a function pointer. It might be more appropriate as a weakly defined function that a board can choose to implement.
- int (*getcd)(struct mmc *mmc);
I think getcd needs more discussion, but even if it doesn't, this clearly belongs in a separate patch. You are modifying the U-Boot MMC API, here, not just the fsl_esdhc driver.
Andy
Hi Andy,
I agree, I wanted only to point out why I need to do this ;)
Ok, let's see if I have really understood and I can proceed with the modifications. I start to change the driver replacing all _be32 functions with a more neutral name (write_register/read_register or something like that). I will define these functions then in asm-ppc/io.h and asm-arm/io.h, setting them to the desired function.
I agree, using global data is a good idea.
In this case we will probably get a lot of CONFIG_SYS options when Freescale changes version or uses this controller on other processors. There are some different registers, not only for snooping. In most cases, some further bits are added. At least I need to know if the SDCLK_EN bit is present in the control register (present in the MX.51 implementation, absent in PowerQuick).
I agree with you. I have already changed the initialization procedure and I can pass (as you suggest later) a configuration structure that describe the feature of the controller. The board can set this structure in board_mmc_init(). If it is not set, the driver should work as now (powerpc), so the structure must be filled only by arm boards.
I know, the version register is not reliable enough...
Absolutely agree, I get rid of it.
Ok, thanks.
Agree. I will set a separate patch to setup the newer functions to access the registers.
You are right. I will create a structure that I can use to describe the feature of the controller, as you already suggested.
Probably I do not need anymore. I can implement as you suggest a weakly defined function, something like:
int board_mmc_getcd(u8 *cd, struct mmc *mmc)__attribute__((weak, alias("__board_mmc_getcd")))
If this failed, I can use the internal bits of the controller to check the presence of the card.
Stefano
Hi Stefano,
--- On Wed, 1/13/10, Stefano Babic sbabic@denx.de wrote:
From: Stefano Babic sbabic@denx.de Subject: [U-Boot] [PATCH V2 1/9] mkimage: Add Freescale imx Boot Image support (imximage) To: u-boot@lists.denx.de Date: Wednesday, January 13, 2010, 7:50 AM This patch adds support for "imximage" (MX Boot Image) to the mkimage utility. The imximage is used on the Freescales's MX.51 processors.
I like the way you handle the internal boot on the MX51. Very smart approach ;-)
MX25 and MX35 can also benefit from the imximage utility that you proposed, so please change the description to make it more generic, such as:
"The imximage can be used on MX25, MX35 and MX51 processors for handling internal boot mode."
+--------------------------------------------- +Imximage Boot Image generation using mkimage +---------------------------------------------
+This document describes how to set up a U-Boot image +that can be booted by the Freescale i.MX51 processor.
You could write: "... that can be booted by Freescale MX25, MX35 and MX51 processors via internal boot mode"
+#define MAX_HW_CFG_SIZE 60 /* Max number of registers imx.51 can set */
MX25, MX35, MX51 can set
+ /* Init Freescale imx.51 Boot image generation/list support */
MX25, MX35 and MX51 Boot image ...
Regards,
Fabio Estevam
Fabio Estevam wrote:
Hi Stefano,
Hi Fabio,
Thanks !
Understood. I will change this point. I will add to the description a short "how to" to set up a SD card with an IMX image for booting, too.
Stefano
Hi Stefano,
+2. Following are the valid command strings and associated data strings:- + Command string data string
I think that the BOOT_FROM command can be removed, right?
We can flash the same binary on a SD or NAND flash.
Regards,
Fabio Estevam
+ -------------- ----------- + BOOT_FROM nand/spi/sd/onenand + Example: + BOOT_FROM spi + DATA type address value
I think that the BOOT_FROM command is not needed.
We can flash the same binary on an SD or NAND flash.
The boot pins configure the media boot type.
Regards,
Fabio Estevam
Quoting Fabio Estevam fabioestevam@yahoo.com:
Hi Stefano,
Hi Fabio,
No, we can't if the processor boots from OneNand device. According to the manual, the offset must be set to 0x100 instead of 0x400.
Correct,but there is still the OneNand case.
Stefano
---------------------------------------------------------------- This message was sent using IMP, the Internet Messaging Program.
Hi Stefano,
right?
Yes, it is still the same binary, but just needs a different offset.
BTW, I don't see the following offset defines used anywhere in the code:
+#define FLASH_OFFSET_STANDARD 0x400 +#define FLASH_OFFSET_NAND FLASH_OFFSET_STANDARD +#define FLASH_OFFSET_SD FLASH_OFFSET_STANDARD +#define FLASH_OFFSET_SPI FLASH_OFFSET_STANDARD +#define FLASH_OFFSET_ONENAND 0x100
Regards,
Fabio Estevam
Hi Stefano,
Hi Fabio,
This is not what I have understood from the manual. In the chapter regarding the flash header ("Flash header structure", figure 2.9), there is the field "app_dest_ptr". This pointer must be set to the start address of the flash/storage media. This means we have different binaries due only to the value of this field. To set this field we need to know the media where the system boots.
They are used in the imximage_bootops structure in imximage.c. This field is later used to set the app_dest_ptr field:
239 fhdr->app_dest_ptr = params->ep - hdr->flash_offset - 240 sizeof(struct imx_header);
Regards, Stefano
Dear Stefano Babic,
Further details under doc/README.imximage.
This patch was tested on a Freescale mx51evk board.
diff --git a/tools/Makefile b/tools/Makefile index 5b8c3c3..afc1d44 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -73,6 +73,7 @@ OBJ_FILES-$(CONFIG_CMD_NET) += gen_eth_addr.o OBJ_FILES-$(CONFIG_CMD_LOADS) += img2srec.o OBJ_FILES-$(CONFIG_INCA_IP) += inca-swap-bytes.o NOPED_OBJ_FILES-y += kwbimage.o +NOPED_OBJ_FILES-y += imximage.o NOPED_OBJ_FILES-y += mkimage.o OBJ_FILES-$(CONFIG_NETCONSOLE) += ncb.o NOPED_OBJ_FILES-y += os_support.o @@ -159,6 +160,7 @@ $(obj)mkimage$(SFX): $(obj)crc32.o \ $(obj)fit_image.o \ $(obj)image.o \ $(obj)kwbimage.o \
$(obj)imximage.o \ $(obj)md5.o \ $(obj)mkimage.o \ $(obj)os_support.o \
Please keep lists sorted.
case CFG_COMMAND:
cmd = get_table_entry_id(imximage_cmds,
"imximage commands", token);
if (cmd < 0) {
fprintf(stderr, "Error: %s[%d] - Invalid command (%s)\n",
Line to long. And please try to stick with a consistent error message format.
case CFG_REG_SIZE:
switch (cmd) {
case CMD_BOOT_FROM:
/* Get flash header offset */
imxhdr->flash_offset = get_table_entry_id(imximage_bootops,
Ditto, and so on. Please fix globally.
+int imximage_check_params(struct mkimage_params *params) +{
- if (!params)
return CFG_INVALID;
- if (!strlen(params->imagename)) {
fprintf(stderr, "Error:%s - Configuration file not specified, "
"it is needed for imximage generation\n",
params->cmdname);
return CFG_INVALID;
- return (params->dflag && (params->fflag || params->lflag)) ||
(params->fflag && (params->dflag || params->lflag)) ||
(params->lflag && (params->dflag || params->fflag)) ||
(params->xflag) || !(strlen(params->imagename));
I cannot understand this code.
+static struct image_type_params imximage_params = {
- .name = "Freescale i.MX 51 Boot Image support",
- .header_size = sizeof(struct imx_header),
- .hdr = (void *)&imximage_header,
- .check_image_type = imximage_check_image_types,
- .verify_header = imximage_verify_header,
- .print_header = imximage_print_header,
- .set_header = imximage_set_header,
- .check_params = imximage_check_params,
How about using TABs to make this easier to read, say:
static struct image_type_params imximage_params = { .name = "Freescale i.MX 51 Boot Image support", .header_size = sizeof(struct imx_header), .hdr = (void *)&imximage_header, .check_image_type = imximage_check_image_types, .verify_header = imximage_verify_header, .print_header = imximage_print_header, .set_header = imximage_set_header, .check_params = imximage_check_params, };
Wolfgang Denk wrote:
Dear Stefano Babic,
Hi Wolfgang,
I see I have too long lines in all patches I have sent. I check this issue for all of them.
Well, I will try to simplify this check and, if not possible, I add comments to explain what the code is doing.
Best regards, Stefano Babic
participants (5)
Andy Fleming
Fabio Estevam
Stefano Babic
stefano@babic.homelinux.org
