[U-Boot-Users] [patch] master read fix mpc8245
Reading PPC Memory from another device with the PPC as PCI target device corrupts data due to interenal hardware buffering. Fix to disable these buffers with no performance influence.
a detailed description is available upon request (pdf, mailinglist bounces).
Thanks. [To be added later.]
Please send a _plain_text_ version to me and/or this list so we can add it to the doc/ directory if necessary.
Thanks.
Hello,
It seams that the second part of this patch is missing from current CVS thus MPC8245 cannot be compiled.
While we are on it can somebody tell me were PCMBCR register (0x800000e1) is documented?
--- u-boot-1.1.1.orig/cpu/mpc824x/cpu_init.c 2003-06-27 23:32:33.000000000 +0200 +++ u-boot-1.1.1/cpu/mpc824x/cpu_init.c 2004-05-10 14:08:17.000000000 +0200 @@ -102,7 +102,25 @@ cpu_init_f (void) CONFIG_WRITE_BYTE(AMBOR, val & 0xDF); CONFIG_WRITE_BYTE(AMBOR, val | 0x20); CONFIG_WRITE_BYTE(AMBOR, val & 0xDF); +#ifdef CONFIG_MPC8245
- /* silicon bug 28 MPC8245 */
- CONFIG_READ_BYTE(AMBOR,val);
- CONFIG_WRITE_BYTE(AMBOR,val|0x1);
- CONFIG_READ_BYTE(PCMBCR,val);
- /* in order not to corrupt data which is being read over the PCI bus
* with the PPC as master, we need to reduce the number of PCMRBs to 1,
* 4.11 in the processor user manual
+#if 1
- CONFIG_WRITE_BYTE(PCMBCR,(val|0xC0)); /* 1 PCMRB */
+#else
- CONFIG_WRITE_BYTE(PCMBCR,(val|0x80)); /* 2 PCMRBs */
- CONFIG_WRITE_BYTE(PCMBCR,(val|0x40)); /* 3 PCMRBs */
+#endif +#endif
- CONFIG_READ_WORD(PICR1, val);
#if defined(CONFIG_MPC8240) CONFIG_WRITE_WORD( PICR1,
--- u-boot-1.1.1.orig/include/mpc824x.h 2002-11-03 01:33:12.000000000 +0100 +++ u-boot-1.1.1/include/mpc824x.h 2004-05-10 14:03:56.000000000 +0200 @@ -297,6 +297,7 @@ #define PBESR 0x800000c7 /* PCI Bus Error Status Register */ #define PBEAR 0x800000c8 /* Processor/PCI Bus Error Status Register */ #define AMBOR 0x800000e0 /* Address Map B Options Register */ +#define PCMBCR 0x800000e1 /* PCI/Memory Buffer Copnfiguration */ #define MCCR1 0x800000f0 /* Memory Control Configuration Register 1 */ #define MCCR2 0x800000f4 /* Memory Control Configuration Register 2 */ #define MCCR3 0x800000f8 /* Memory Control Configuration Register 3 */
-- Gleb.
gleb@nbase.co.il
Marc Leeman
