[U-Boot] fs: ext4: fix symlink read function
Hi Gary, Recently you submitted a patch to fix the ext4 symlnik issue.
Can you please tell me the actual commands that failed or gave wrong results?
I ask cause I am trying to do the below: 1. Incorporate symlnk test in fs-test.sh 2. use host instead of sb as sb is deprecated 3. Reproduce the issue without your fix, so I can see what is failing
I haven't been able to do 3. above (by reverting your fix to recreate the error conditions). I tried the below commands in sandbox and they worked as expected. (by creating a soft link pointing to 1MB.file)
# generic command check
ls host 0:0
size host 0:0 1MB.file.link
load host 0:0 0x01000008 1MB.file.link
md5sum 0x01000008 $filesize
# ext command check
ext4size host 0:0 1MB.file.link
ext4load host 0:0 0x01000008 1MB.file.link md5sum 0x01000008 $filesize
Would be nice to throw some light on this issue so I can build a test case.
Hello Simon, Are you aware that while building sandbox, we get : CC drivers/misc/cros_ec_sandbox.o drivers/misc/cros_ec_sandbox.c: In function ‘cros_ec_sandbox_packet’: drivers/misc/cros_ec_sandbox.c:483:5: warning: ‘len’ may be used uninitialized in this function [-Wmaybe-uninitialized] if (len < 0) ^
Thanks - Suriyan
Hi Suriyan,
On Sun, Sep 27, 2015 at 8:05 AM, Suriyan Bhavani suriyanandbhavani@gmail.com wrote:
The load command (tested on ext4 partition) was failing with an error that said the file didn't exist since ext4fs_read_file was returning 0 (success) but this return value was considered a failure.
- Incorporate symlnk test in fs-test.sh
- use host instead of sb as sb is deprecated
- Reproduce the issue without your fix, so I can see what is failing
Have you reverted my patch only or did you go back to a prior commit of 9f12cd0 which is where the API changed?
ls host 0:0
# ext command check
That sounds about right, that is the kind of test I wanted to add. Could you share the output of the ls command on the link file?
Well I hope my answer will help. I wanted to update the test script but the sandbox didn't seem to work (I've sent an email about it).
Regards, Gary
Gary Bisson
Suriyan Bhavani
