[PATCH 0/5] meson: add clk and adc support for JetHub D1 (j100)
Prepare to use ADC channel 1 in JetHub D1 (j100) to check the hardware revision of the board.
- add support for AXG in saradc driver - add simple clk-ao driver for AXG (base is taken from g12a) - enable saradc in dts and board config file - fix typo in the g12a-clk-ao driver name
Vyacheslav Bocharov (5): clk: meson: add minimal driver for axg-ao clocks clk: meson: fix driver name for g12a-ao clocks adc: meson-saradc: add AXG variant board: amlogic: jethub j100: enable saradc in dts board: amlogic: jethub j100: enable saradc in config
.../arm/dts/meson-axg-jethome-jethub-j100.dts | 5 ++ configs/jethub_j100_defconfig | 5 ++ drivers/adc/meson-saradc.c | 2 + drivers/clk/meson/Makefile | 1 + drivers/clk/meson/axg-ao.c | 83 +++++++++++++++++++ drivers/clk/meson/g12a-ao.c | 2 +- 6 files changed, 97 insertions(+), 1 deletion(-) create mode 100644 drivers/clk/meson/axg-ao.c
Add minimal driver AO clocks on meson AXG family. Only ADC related clocks are supported.
Signed-off-by: Vyacheslav Bocharov adeep@lexina.in --- drivers/clk/meson/Makefile | 1 + drivers/clk/meson/axg-ao.c | 83 ++++++++++++++++++++++++++++++++++++++ 2 files changed, 84 insertions(+) create mode 100644 drivers/clk/meson/axg-ao.c
diff --git a/drivers/clk/meson/Makefile b/drivers/clk/meson/Makefile index b9c6bd66cf..a486b13e9c 100644 --- a/drivers/clk/meson/Makefile +++ b/drivers/clk/meson/Makefile @@ -5,5 +5,6 @@
obj-$(CONFIG_CLK_MESON_GX) += gxbb.o obj-$(CONFIG_CLK_MESON_AXG) += axg.o +obj-$(CONFIG_CLK_MESON_AXG) += axg-ao.o obj-$(CONFIG_CLK_MESON_G12A) += g12a.o obj-$(CONFIG_CLK_MESON_G12A) += g12a-ao.o diff --git a/drivers/clk/meson/axg-ao.c b/drivers/clk/meson/axg-ao.c new file mode 100644 index 0000000000..264ec6f0d3 --- /dev/null +++ b/drivers/clk/meson/axg-ao.c @@ -0,0 +1,83 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <common.h> +#include <log.h> +#include <asm/io.h> +#include <clk-uclass.h> +#include <dm.h> +#include <regmap.h> +#include <syscon.h> +#include <dt-bindings/clock/axg-aoclkc.h> + +#include "clk_meson.h" + +struct meson_clk { + struct regmap *map; +}; + +#define AO_CLK_GATE0 0x40 +#define AO_SAR_CLK 0x90 + +static struct meson_gate gates[] = { + MESON_GATE(CLKID_AO_SAR_ADC, AO_CLK_GATE0, 7), + MESON_GATE(CLKID_AO_SAR_ADC_CLK, AO_SAR_CLK, 7), +}; + +static int meson_set_gate(struct clk *clk, bool on) +{ + struct meson_clk *priv = dev_get_priv(clk->dev); + struct meson_gate *gate; + + if (clk->id >= ARRAY_SIZE(gates)) + return -ENOENT; + + gate = &gates[clk->id]; + + if (gate->reg == 0) + return 0; + + regmap_update_bits(priv->map, gate->reg, + BIT(gate->bit), on ? BIT(gate->bit) : 0); + + return 0; +} + +static int meson_clk_enable(struct clk *clk) +{ + return meson_set_gate(clk, true); +} + +static int meson_clk_disable(struct clk *clk) +{ + return meson_set_gate(clk, false); +} + +static int meson_clk_probe(struct udevice *dev) +{ + struct meson_clk *priv = dev_get_priv(dev); + + priv->map = syscon_node_to_regmap(dev_ofnode(dev_get_parent(dev))); + if (IS_ERR(priv->map)) + return PTR_ERR(priv->map); + + return 0; +} + +static struct clk_ops meson_clk_ops = { + .disable = meson_clk_disable, + .enable = meson_clk_enable, +}; + +static const struct udevice_id meson_clk_ids[] = { + { .compatible = "amlogic,meson-axg-aoclkc" }, + { } +}; + +U_BOOT_DRIVER(meson_clk_axg_ao) = { + .name = "meson_clk_axg_ao", + .id = UCLASS_CLK, + .of_match = meson_clk_ids, + .priv_auto = sizeof(struct meson_clk), + .ops = &meson_clk_ops, + .probe = meson_clk_probe, +};
+struct meson_clk {
- struct regmap *map;
- MESON_GATE(CLKID_AO_SAR_ADC, AO_CLK_GATE0, 7),
- MESON_GATE(CLKID_AO_SAR_ADC_CLK, AO_SAR_CLK, 7),
- struct meson_clk *priv = dev_get_priv(clk->dev);
- struct meson_gate *gate;
- if (clk->id >= ARRAY_SIZE(gates))
return -ENOENT;
Do this check in request().
- gate = &gates[clk->id];
- if (gate->reg == 0)
- regmap_update_bits(priv->map, gate->reg,
- return meson_set_gate(clk, true);
- return meson_set_gate(clk, false);
- struct meson_clk *priv = dev_get_priv(dev);
- priv->map = syscon_node_to_regmap(dev_ofnode(dev_get_parent(dev)));
- if (IS_ERR(priv->map))
- .disable = meson_clk_disable,
- .enable = meson_clk_enable,
- { .compatible = "amlogic,meson-axg-aoclkc" },
- .name = "meson_clk_axg_ao",
- .id = UCLASS_CLK,
- .of_match = meson_clk_ids,
- .priv_auto = sizeof(struct meson_clk),
- .ops = &meson_clk_ops,
- .probe = meson_clk_probe,
Otherwise LGTM
--Sean
20.04.2022 23:12, Sean Anderson пишет:
diff --git a/drivers/clk/meson/Makefile b/drivers/clk/meson/Makefile index b9c6bd66cf..a486b13e9c 100644 --- a/drivers/clk/meson/Makefile +++ b/drivers/clk/meson/Makefile @@ -5,5 +5,6 @@ obj-$(CONFIG_CLK_MESON_GX) += gxbb.o obj-$(CONFIG_CLK_MESON_AXG) += axg.o +obj-$(CONFIG_CLK_MESON_AXG) += axg-ao.o obj-$(CONFIG_CLK_MESON_G12A) += g12a.o obj-$(CONFIG_CLK_MESON_G12A) += g12a-ao.o diff --git a/drivers/clk/meson/axg-ao.c b/drivers/clk/meson/axg-ao.c new file mode 100644 index 0000000000..264ec6f0d3 --- /dev/null +++ b/drivers/clk/meson/axg-ao.c @@ -0,0 +1,83 @@ +// SPDX-License-Identifier: GPL-2.0+
Do you mean remove this check from meson_set_gate and add request function like this:
static int meson_clk_request(struct clk *clk) { struct npcm_clk_priv *priv = dev_get_priv(clk->dev);
if (clk->id >= ARRAY_SIZE(gates)) return -ENOENT;
return 0; }
static struct clk_ops meson_clk_ops = { .disable = meson_clk_disable, .enable = meson_clk_enable, .request = meson_clk_request, };
+ return 0; +}
+ return 0; +}
Otherwise LGTM
Thanks
--Sean
return 0; }
Yes.
--Sean
+ return 0; +}
+ return 0; +}
Otherwise LGTM
Thanks
--Sean
Update the clk-g12a-ao driver from "axg" to "g12a"
Signed-off-by: Vyacheslav Bocharov adeep@lexina.in --- drivers/clk/meson/g12a-ao.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/clk/meson/g12a-ao.c b/drivers/clk/meson/g12a-ao.c index 0148529e04..17b11eb52a 100644 --- a/drivers/clk/meson/g12a-ao.c +++ b/drivers/clk/meson/g12a-ao.c @@ -73,7 +73,7 @@ static const struct udevice_id meson_clk_ids[] = { { } };
-U_BOOT_DRIVER(meson_clk_axg) = { +U_BOOT_DRIVER(meson_clk_g12a_ao) = { .name = "meson_clk_g12a_ao", .id = UCLASS_CLK, .of_match = meson_clk_ids,
Add support for the SARADC variant found on the AXG SoCs family.
Signed-off-by: Vyacheslav Bocharov adeep@lexina.in --- drivers/adc/meson-saradc.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/adc/meson-saradc.c b/drivers/adc/meson-saradc.c index 1a45a3a265..37023512f0 100644 --- a/drivers/adc/meson-saradc.c +++ b/drivers/adc/meson-saradc.c @@ -737,6 +737,8 @@ static const struct udevice_id meson_saradc_ids[] = { .data = (ulong)&gxl_saradc_data }, { .compatible = "amlogic,meson-g12a-saradc", .data = (ulong)&gxl_saradc_data }, + { .compatible = "amlogic,meson-axg-saradc", + .data = (ulong)&gxl_saradc_data }, { } };
Prepare to use ADC channel 1 to check the hardware revision of the board.
Signed-off-by: Vyacheslav Bocharov adeep@lexina.in --- arch/arm/dts/meson-axg-jethome-jethub-j100.dts | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/dts/meson-axg-jethome-jethub-j100.dts b/arch/arm/dts/meson-axg-jethome-jethub-j100.dts index 5783732dc6..00a0b268af 100644 --- a/arch/arm/dts/meson-axg-jethome-jethub-j100.dts +++ b/arch/arm/dts/meson-axg-jethome-jethub-j100.dts @@ -359,3 +359,8 @@ &cpu3 { #cooling-cells = <2>; }; + +&saradc { + status = "okay"; + vref-supply = <&vddio_ao18>; +};
Enable ADC in board config file
Signed-off-by: Vyacheslav Bocharov adeep@lexina.in --- configs/jethub_j100_defconfig | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/configs/jethub_j100_defconfig b/configs/jethub_j100_defconfig index 1c6db9f6a0..a30940bf1c 100644 --- a/configs/jethub_j100_defconfig +++ b/configs/jethub_j100_defconfig @@ -17,6 +17,7 @@ CONFIG_REMAKE_ELF=y CONFIG_OF_BOARD_SETUP=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_MISC_INIT_R=y +CONFIG_CMD_ADC=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set CONFIG_CMD_EEPROM=y @@ -34,6 +35,10 @@ CONFIG_OF_CONTROL=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MESON=y +CONFIG_ADC=y +CONFIG_SARADC_MESON=y +CONFIG_CLK=y +CONFIG_CLK_MESON_AXG=y CONFIG_MMC_MESON_GX=y CONFIG_MTD_UBI=y CONFIG_PHY_REALTEK=y
Sean Anderson
Vyacheslav
Vyacheslav Bocharov
