[U-Boot] [PATCH] sun6i: cpu_reset: Do not return from cpu_reset()
Currently on sun6i after a "reset" the prompt returns and the user can even type stuff until the watchdog triggers and does the actual reset.
This is somewhat unexpected behavior for the "reset" command, this commit adds an endless loop to wait for the watchdog to trigger so that we do not return to the prompt.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- arch/arm/cpu/armv7/sunxi/board.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/cpu/armv7/sunxi/board.c b/arch/arm/cpu/armv7/sunxi/board.c index bd0d819..0fe641f 100644 --- a/arch/arm/cpu/armv7/sunxi/board.c +++ b/arch/arm/cpu/armv7/sunxi/board.c @@ -220,6 +220,7 @@ void reset_cpu(ulong addr) writel(WDT_CFG_RESET, &wdog->cfg); writel(WDT_MODE_EN, &wdog->mode); writel(WDT_CTRL_KEY | WDT_CTRL_RESTART, &wdog->ctl); + while (1) { } #endif }
It certainly is!
Acked-by: Ian Campbell ijc@hellion.org.uk
Might be worth throwing a cpu_relax or some such in there too?
- while (1) { }
#endif }
Hans de Goede
Ian Campbell
