[PATCH V3] board: rockchip: add Powkiddy X55
The Powkiddy X55 is a Rockchip RK3566 based handheld gaming device. UART, ADC, eMMC, and SDMMC are tested to work in U-Boot and this successfully boots mainline Linux.
Kernel commit: e99adc97e21a ("arm64: dts: rockchip: Add Powkiddy X55")
Signed-off-by: Chris Morgan macromorgan@hotmail.com ---
Changes since V2: - Refactored to use the upstream device tree from Linux. - Removed logic for handling the adc button and instead simply try to boot from sdmmc0 as a valid target first.
--- arch/arm/dts/rk3566-powkiddy-x55-u-boot.dtsi | 9 +++ arch/arm/mach-rockchip/rk3568/Kconfig | 6 ++ board/powkiddy/x55/Kconfig | 15 +++++ board/powkiddy/x55/MAINTAINERS | 7 +++ board/powkiddy/x55/Makefile | 6 ++ board/powkiddy/x55/x55.c | 39 +++++++++++++ configs/powkiddy-x55-rk3566_defconfig | 59 ++++++++++++++++++++ doc/board/rockchip/rockchip.rst | 1 + include/configs/powkiddy-x55-rk3566.h | 12 ++++ 9 files changed, 154 insertions(+) create mode 100644 arch/arm/dts/rk3566-powkiddy-x55-u-boot.dtsi create mode 100644 board/powkiddy/x55/Kconfig create mode 100644 board/powkiddy/x55/MAINTAINERS create mode 100644 board/powkiddy/x55/Makefile create mode 100644 board/powkiddy/x55/x55.c create mode 100644 configs/powkiddy-x55-rk3566_defconfig create mode 100644 include/configs/powkiddy-x55-rk3566.h
diff --git a/arch/arm/dts/rk3566-powkiddy-x55-u-boot.dtsi b/arch/arm/dts/rk3566-powkiddy-x55-u-boot.dtsi new file mode 100644 index 0000000000..c440201ec7 --- /dev/null +++ b/arch/arm/dts/rk3566-powkiddy-x55-u-boot.dtsi @@ -0,0 +1,9 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +#include "rk356x-u-boot.dtsi" + +/ { + chosen { + u-boot,spl-boot-order = &sdmmc0, &sdmmc1, &sdhci; + }; +}; diff --git a/arch/arm/mach-rockchip/rk3568/Kconfig b/arch/arm/mach-rockchip/rk3568/Kconfig index af537d912a..014ebf9f0b 100644 --- a/arch/arm/mach-rockchip/rk3568/Kconfig +++ b/arch/arm/mach-rockchip/rk3568/Kconfig @@ -22,6 +22,11 @@ config TARGET_ODROID_M1_RK3568 help Hardkernel ODROID-M1 single board computer with a RK3568B2 SoC.
+config TARGET_POWKIDDY_X55_RK3566 + bool "Powkiddy X55" + help + Powkiddy X55 handheld gaming console with an RK3566 SoC. + config TARGET_QUARTZ64_RK3566 bool "Pine64 Quartz64" help @@ -48,5 +53,6 @@ source "board/rockchip/evb_rk3568/Kconfig" source "board/anbernic/rgxx3_rk3566/Kconfig" source "board/hardkernel/odroid_m1/Kconfig" source "board/pine64/quartz64_rk3566/Kconfig" +source "board/powkiddy/x55/Kconfig"
endif diff --git a/board/powkiddy/x55/Kconfig b/board/powkiddy/x55/Kconfig new file mode 100644 index 0000000000..a7b3ed4d0d --- /dev/null +++ b/board/powkiddy/x55/Kconfig @@ -0,0 +1,15 @@ +if TARGET_POWKIDDY_X55_RK3566 + +config SYS_BOARD + default "x55" + +config SYS_VENDOR + default "powkiddy" + +config SYS_CONFIG_NAME + default "powkiddy-x55-rk3566" + +config BOARD_SPECIFIC_OPTIONS + def_bool y + +endif diff --git a/board/powkiddy/x55/MAINTAINERS b/board/powkiddy/x55/MAINTAINERS new file mode 100644 index 0000000000..01ae8da19d --- /dev/null +++ b/board/powkiddy/x55/MAINTAINERS @@ -0,0 +1,7 @@ +X55 +M: Chris Morgan macromorgan@hotmail.com +S: Maintained +F: board/powkiddy/x55 +F: include/configs/powkiddy-x55-rk3566.h +F: configs/powkiddy-x55-rk3566_defconfig +F: arch/arm/dts/rk3566-powkiddy-x55-u-boot.dtsi diff --git a/board/powkiddy/x55/Makefile b/board/powkiddy/x55/Makefile new file mode 100644 index 0000000000..55c8c16aa1 --- /dev/null +++ b/board/powkiddy/x55/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (c) 2023 Chris Morgan macromorgan@hotmail.com +# + +obj-y += x55.o diff --git a/board/powkiddy/x55/x55.c b/board/powkiddy/x55/x55.c new file mode 100644 index 0000000000..b2703e6382 --- /dev/null +++ b/board/powkiddy/x55/x55.c @@ -0,0 +1,39 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2023 Chris Morgan macromorgan@hotmail.com + */ + +#include <asm/io.h> + +#define GPIO4_BASE 0xfe770000 +#define GPIO_SWPORT_DR_L 0x0000 +#define GPIO_SWPORT_DDR_L 0x0008 +#define GPIO_B4 BIT(12) +#define GPIO_B5 BIT(13) +#define GPIO_B6 BIT(14) + +#define GPIO_WRITEMASK(bits) ((bits) << 16) + +/* + * Start LED very early so user knows device is on. Set color + * to red. + */ +void spl_board_init(void) +{ + /* Set GPIO4_B4, GPIO4_B5, and GPIO4_B6 to output. */ + writel(GPIO_WRITEMASK(GPIO_B6 | GPIO_B5 | GPIO_B4) | \ + (GPIO_B6 | GPIO_B5 | GPIO_B4), + (GPIO4_BASE + GPIO_SWPORT_DDR_L)); + /* Set GPIO4_B5 and GPIO4_B6 to 0 and GPIO4_B4 to 1. */ + writel(GPIO_WRITEMASK(GPIO_B6 | GPIO_B5 | GPIO_B4) | GPIO_B4, + (GPIO4_BASE + GPIO_SWPORT_DR_L)); +} + +int rk_board_late_init(void) +{ + /* Turn off red LED and turn on orange LED. */ + writel(GPIO_WRITEMASK(GPIO_B6 | GPIO_B5 | GPIO_B4) | GPIO_B6, + (GPIO4_BASE + GPIO_SWPORT_DR_L)); + + return 0; +} diff --git a/configs/powkiddy-x55-rk3566_defconfig b/configs/powkiddy-x55-rk3566_defconfig new file mode 100644 index 0000000000..db996fd570 --- /dev/null +++ b/configs/powkiddy-x55-rk3566_defconfig @@ -0,0 +1,59 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3566-powkiddy-x55" +CONFIG_ROCKCHIP_RK3568=y +CONFIG_SPL_SERIAL=y +CONFIG_DEBUG_UART_BASE=0xFE660000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3566-powkiddy-x55.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_ATF=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_UPSTREAM=y +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_SPL_PINCTRL=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_SPL_RAM=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_SYSRESET=y +CONFIG_ERRNO_STR=y diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index 9a726e9cde..924a8d0886 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -104,6 +104,7 @@ List of mainline supported Rockchip boards: - Pine64 SOQuartz on Blade (soquartz-blade-rk3566) - Pine64 SOQuartz on CM4-IO (soquartz-cm4-rk3566) - Pine64 SOQuartz on Model A (soquartz-model-a-rk3566) + - Powkiddy X55 (powkiddy-x55-rk3566) - Radxa CM3 IO Board (radxa-cm3-io-rk3566)
* rk3568 diff --git a/include/configs/powkiddy-x55-rk3566.h b/include/configs/powkiddy-x55-rk3566.h new file mode 100644 index 0000000000..4b25c6a877 --- /dev/null +++ b/include/configs/powkiddy-x55-rk3566.h @@ -0,0 +1,12 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ + +#ifndef __POWKIDDY_X55_RK3566_H +#define __POWKIDDY_X55_RK3566_H + +#include <configs/rk3568_common.h> + +#define ROCKCHIP_DEVICE_SETTINGS \ + "stdout=serial,vidconsole\0" \ + "stderr=serial,vidconsole\0" + +#endif
Changes since V2:
- chosen {
- bool "Powkiddy X55"
- help
- config TARGET_QUARTZ64_RK3566 bool "Pine64 Quartz64" help
+config SYS_BOARD
- default "x55"
+config SYS_VENDOR
- default "powkiddy"
- default "powkiddy-x55-rk3566"
- def_bool y
- Copyright (c) 2023 Chris Morgan macromorgan@hotmail.com
- Start LED very early so user knows device is on. Set color
- to red.
- /* Set GPIO4_B4, GPIO4_B5, and GPIO4_B6 to output. */
- writel(GPIO_WRITEMASK(GPIO_B6 | GPIO_B5 | GPIO_B4) | \
- /* Set GPIO4_B5 and GPIO4_B6 to 0 and GPIO4_B4 to 1. */
- writel(GPIO_WRITEMASK(GPIO_B6 | GPIO_B5 | GPIO_B4) | GPIO_B4,
- /* Turn off red LED and turn on orange LED. */
- writel(GPIO_WRITEMASK(GPIO_B6 | GPIO_B5 | GPIO_B4) | GPIO_B6,
This option already enabled by ROCKCHIP_RK3568, pls remove it here.
Thanks,
- Kever
- rk3568
Chris Morgan
Kever Yang
