[U-Boot] Please pull u-boot-staging.git/sr@denx.de
Hi Albert!
I have collected all of the remaining ARM/SPEAr patches in my staging repository. There are some dependencies between the patches, so I also added the NOR, NAND and ethernet patches in this pull request. The patches have the Acked-by from the corresponding custodians (Joe for networking, Scott for NAND, myself for NOR).
Since most of the patches are ARM/SPEAr platform related, I'm pushing the patchset through your ARM repository. Please pull and push to Wolfgang.
Thanks, Stefan
The following changes since commit 4398d55991eb3c2484a2a8e991d701e5d7a64874:
net: sh-eth: Add support Gigabit of SH7734 (2012-05-23 17:53:09 -0500)
git://www.denx.de/git/u-boot-staging.git sr@denx.de
for you to fetch changes up to e94b7cb06a246532aba7af9e0f2040d4facba5db:
MTD: SPEAr SMI: Add write support for length < 4 bytes (2012-06-05 08:42:50 +0200)
---------------------------------------------------------------- Amit Virdi (10): st_smi: Return error in case TFF is not set st_smi: Change SMI timeout values st_smi: Enhance the error handling st_smi: Change timeout loop implementation SPEAr: Fix ARM relocation support SPEAr: Eliminate dependency on Xloader table SPEAr: Initialize SNOR in early_board_init_f SPEAr: Remove CONFIG_MTD_NAND_VERIFY_WRITE to speed up NAND access cleanup/SPEAr: Remove unnecessary parenthesis cleanup/SPEAr: Define configuration flags more elegantly
Armando Visconti (4): st_smi: Removed no needed dependency on ST_M25Pxx_ID st_smi: Change the flash probing method st_smi: Fix bug in flash_print_info() st_smi: Fixed page size for Winbond W25Q128FV flash
Shiraz Hashim (5): st_smi: Move status register read before modifying ctrl register SPEAr: Enable autoneg for ethernet SPEAr: Enable dcache for fast file transfer SPEAr: explicitly select clk src for UART SPEAr: Correct SoC ID offset in misc configuration space
Simon Glass (1): arm: Don't use printf() in SPL builds
Stefan Roese (10): net: Multiple updates/enhancements to designware.c GPIO: Add SPEAr GPIO driver SPL: common/Makefile: Add image.c to SPL build SPL: lib/Makefile: Add crc32.c to SPL build SPL: ARM: spear: Remove some objects from SPL build Makefile: Add u-boot.spr build target (SPEAr) SPL: ARM: spear: Add SPL support for SPEAr600 platform rtc/m41t62: Add support for M41T82 with HT (Halt Update) i2c: designware_i2c.c: Add support for the "i2c probe" command MTD: SPEAr SMI: Add write support for length < 4 bytes
Vipin KUMAR (14): mtd/NAND: Add FSMC driver support SPEAr: Configure FSMC driver for NAND interface mtd/NAND: Remove obsolete SPEAr specific NAND drivers st_smi: Add support for SPEAr SMI driver st_smi: Read status until timeout happens SPEAr: Place ethaddr write and read within CONFIG_CMD_NET SPEAr: Configure network support for spear SoCs SPEAr: Add macb driver support for spear310 and spear320 SPEAr: Add basic arch related support for SPEAr SoCs SPEAr: Add configuration options for spear3xx and spear6xx boards SPEAr: Remove unused flag (CONFIG_SYS_HZ_CLOCK) SPEAr: Change the default environment variables SPEAr: Enable usb device high speed support SPEAr: Enable udc and usb-console support only for usbtty configuration
Vipin Kumar (6): st_smi: Fix smi read status SPEAr: Add interface information in initialization SPEAr: Enable CONFIG_SYS_FLASH_PROTECTION SPEAr: Correct the definition of CONFIG_SYS_MONITOR_BASE SPEAr: Enable CONFIG_SYS_FLASH_EMPTY_INFO macro SPEAr: Enable ONFI nand flash detection for spear3xx and 6xx and evb
Makefile | 17 + arch/arm/cpu/arm926ejs/spear/Makefile | 25 +- arch/arm/cpu/arm926ejs/spear/cpu.c | 87 ++++ arch/arm/cpu/arm926ejs/spear/spear600.c | 236 ++++++++++ arch/arm/cpu/arm926ejs/spear/spl.c | 282 ++++++++++++ arch/arm/cpu/arm926ejs/spear/spl_boot.c | 197 ++++++++ .../spear/spr600_mt47h128m8_3_266_cl5_async.c | 130 ++++++ .../spear/spr600_mt47h32m16_333_cl5_psync.c | 135 ++++++ .../spear/spr600_mt47h32m16_37e_166_cl4_sync.c | 130 ++++++ .../spear/spr600_mt47h64m16_3_333_cl5_psync.c | 144 ++++++ arch/arm/cpu/arm926ejs/spear/start.S | 122 +++++ arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds | 87 ++++ arch/arm/include/asm/arch-spear/clk.h | 27 ++ arch/arm/include/asm/arch-spear/gpio.h | 40 ++ arch/arm/include/asm/arch-spear/hardware.h | 63 ++- arch/arm/include/asm/arch-spear/spr_defs.h | 23 + arch/arm/include/asm/arch-spear/spr_gpt.h | 4 +- arch/arm/include/asm/arch-spear/spr_misc.h | 147 +++++- arch/arm/include/asm/arch-spear/spr_nand.h | 57 --- arch/arm/include/asm/arch-spear/spr_ssp.h | 45 ++ arch/arm/include/asm/arch-spear/spr_syscntl.h | 14 + .../arm/include/asm/arch-spear/spr_xloader_table.h | 67 --- arch/arm/lib/eabi_compat.c | 3 +- board/spear/common/Makefile | 2 + board/spear/common/spr_misc.c | 102 ++-- board/spear/spear300/config.mk | 39 -- board/spear/spear300/spear300.c | 27 +- board/spear/spear310/config.mk | 44 -- board/spear/spear310/spear310.c | 44 +- board/spear/spear320/config.mk | 44 -- board/spear/spear320/spear320.c | 43 +- board/spear/spear600/Makefile | 2 + board/spear/spear600/config.mk | 39 -- board/spear/spear600/spear600.c | 30 +- boards.cfg | 24 +- common/Makefile | 2 +- config.mk | 4 + doc/README.spear | 54 ++- drivers/gpio/Makefile | 1 + drivers/gpio/spear_gpio.c | 102 ++++ drivers/i2c/designware_i2c.c | 16 +- drivers/mtd/Makefile | 2 +- drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/fsmc_nand.c | 486 ++++++++++++++++++++ drivers/mtd/nand/spr_nand.c | 124 ----- drivers/mtd/{spr_smi.c => st_smi.c} | 255 ++++++---- drivers/net/designware.c | 126 +++-- drivers/net/designware.h | 2 + drivers/rtc/m41t62.c | 10 +- include/configs/spear-common.h | 94 ++-- include/configs/{spear3xx.h => spear3xx_evb.h} | 62 ++- include/configs/{spear6xx.h => spear6xx_evb.h} | 20 +- include/linux/mtd/fsmc_nand.h | 101 ++++ .../spr_smi.h => include/linux/mtd/st_smi.h | 10 +- include/netdev.h | 2 +- lib/Makefile | 2 +- 56 files changed, 3229 insertions(+), 769 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/spear/cpu.c create mode 100644 arch/arm/cpu/arm926ejs/spear/spear600.c create mode 100644 arch/arm/cpu/arm926ejs/spear/spl.c create mode 100644 arch/arm/cpu/arm926ejs/spear/spl_boot.c create mode 100644 arch/arm/cpu/arm926ejs/spear/spr600_mt47h128m8_3_266_cl5_async.c create mode 100644 arch/arm/cpu/arm926ejs/spear/spr600_mt47h32m16_333_cl5_psync.c create mode 100644 arch/arm/cpu/arm926ejs/spear/spr600_mt47h32m16_37e_166_cl4_sync.c create mode 100644 arch/arm/cpu/arm926ejs/spear/spr600_mt47h64m16_3_333_cl5_psync.c create mode 100644 arch/arm/cpu/arm926ejs/spear/start.S create mode 100644 arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds create mode 100644 arch/arm/include/asm/arch-spear/clk.h create mode 100644 arch/arm/include/asm/arch-spear/gpio.h delete mode 100644 arch/arm/include/asm/arch-spear/spr_nand.h create mode 100644 arch/arm/include/asm/arch-spear/spr_ssp.h delete mode 100644 arch/arm/include/asm/arch-spear/spr_xloader_table.h delete mode 100644 board/spear/spear300/config.mk delete mode 100644 board/spear/spear310/config.mk delete mode 100644 board/spear/spear320/config.mk delete mode 100644 board/spear/spear600/config.mk create mode 100644 drivers/gpio/spear_gpio.c create mode 100644 drivers/mtd/nand/fsmc_nand.c delete mode 100644 drivers/mtd/nand/spr_nand.c rename drivers/mtd/{spr_smi.c => st_smi.c} (62%) rename include/configs/{spear3xx.h => spear3xx_evb.h} (72%) rename include/configs/{spear6xx.h => spear6xx_evb.h} (74%) create mode 100644 include/linux/mtd/fsmc_nand.h rename arch/arm/include/asm/arch-spear/spr_smi.h => include/linux/mtd/st_smi.h (95%)
Hi Albert,
as you requested, here a short reminder...
On Tuesday 05 June 2012 08:58:26 Stefan Roese wrote:
Hi Albert!
Thanks, Stefan
Makefile | 17 + arch/arm/cpu/arm926ejs/spear/Makefile | 25 +- arch/arm/cpu/arm926ejs/spear/cpu.c | 87 ++++ arch/arm/cpu/arm926ejs/spear/spear600.c | 236 ++++++++++ arch/arm/cpu/arm926ejs/spear/spl.c | 282 ++++++++++++ arch/arm/cpu/arm926ejs/spear/spl_boot.c | 197 ++++++++ .../spear/spr600_mt47h128m8_3_266_cl5_async.c | 130 ++++++ .../spear/spr600_mt47h32m16_333_cl5_psync.c | 135 ++++++ .../spear/spr600_mt47h32m16_37e_166_cl4_sync.c | 130 ++++++ .../spear/spr600_mt47h64m16_3_333_cl5_psync.c | 144 ++++++ arch/arm/cpu/arm926ejs/spear/start.S | 122 +++++ arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds | 87 ++++ arch/arm/include/asm/arch-spear/clk.h | 27 ++ arch/arm/include/asm/arch-spear/gpio.h | 40 ++ arch/arm/include/asm/arch-spear/hardware.h | 63 ++- arch/arm/include/asm/arch-spear/spr_defs.h | 23 + arch/arm/include/asm/arch-spear/spr_gpt.h | 4 +- arch/arm/include/asm/arch-spear/spr_misc.h | 147 +++++- arch/arm/include/asm/arch-spear/spr_nand.h | 57 --- arch/arm/include/asm/arch-spear/spr_ssp.h | 45 ++ arch/arm/include/asm/arch-spear/spr_syscntl.h | 14 + .../arm/include/asm/arch-spear/spr_xloader_table.h | 67 --- arch/arm/lib/eabi_compat.c | 3 +- board/spear/common/Makefile | 2 + board/spear/common/spr_misc.c | 102 ++-- board/spear/spear300/config.mk | 39 -- board/spear/spear300/spear300.c | 27 +- board/spear/spear310/config.mk | 44 -- board/spear/spear310/spear310.c | 44 +- board/spear/spear320/config.mk | 44 -- board/spear/spear320/spear320.c | 43 +- board/spear/spear600/Makefile | 2 + board/spear/spear600/config.mk | 39 -- board/spear/spear600/spear600.c | 30 +- boards.cfg | 24 +- common/Makefile | 2 +- config.mk | 4 + doc/README.spear | 54 ++- drivers/gpio/Makefile | 1 + drivers/gpio/spear_gpio.c | 102 ++++ drivers/i2c/designware_i2c.c | 16 +- drivers/mtd/Makefile | 2 +- drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/fsmc_nand.c | 486 ++++++++++++++++++++ drivers/mtd/nand/spr_nand.c | 124 ----- drivers/mtd/{spr_smi.c => st_smi.c} | 255 ++++++---- drivers/net/designware.c | 126 +++-- drivers/net/designware.h | 2 + drivers/rtc/m41t62.c | 10 +- include/configs/spear-common.h | 94 ++-- include/configs/{spear3xx.h => spear3xx_evb.h} | 62 ++- include/configs/{spear6xx.h => spear6xx_evb.h} | 20 +- include/linux/mtd/fsmc_nand.h | 101 ++++ .../spr_smi.h => include/linux/mtd/st_smi.h | 10 +- include/netdev.h | 2 +- lib/Makefile | 2 +- 56 files changed, 3229 insertions(+), 769 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/spear/cpu.c create mode 100644 arch/arm/cpu/arm926ejs/spear/spear600.c create mode 100644 arch/arm/cpu/arm926ejs/spear/spl.c create mode 100644 arch/arm/cpu/arm926ejs/spear/spl_boot.c create mode 100644 arch/arm/cpu/arm926ejs/spear/spr600_mt47h128m8_3_266_cl5_async.c create mode 100644 arch/arm/cpu/arm926ejs/spear/spr600_mt47h32m16_333_cl5_psync.c create mode 100644 arch/arm/cpu/arm926ejs/spear/spr600_mt47h32m16_37e_166_cl4_sync.c create mode 100644 arch/arm/cpu/arm926ejs/spear/spr600_mt47h64m16_3_333_cl5_psync.c create mode 100644 arch/arm/cpu/arm926ejs/spear/start.S create mode 100644 arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds create mode 100644 arch/arm/include/asm/arch-spear/clk.h create mode 100644 arch/arm/include/asm/arch-spear/gpio.h delete mode 100644 arch/arm/include/asm/arch-spear/spr_nand.h create mode 100644 arch/arm/include/asm/arch-spear/spr_ssp.h delete mode 100644 arch/arm/include/asm/arch-spear/spr_xloader_table.h delete mode 100644 board/spear/spear300/config.mk delete mode 100644 board/spear/spear310/config.mk delete mode 100644 board/spear/spear320/config.mk delete mode 100644 board/spear/spear600/config.mk create mode 100644 drivers/gpio/spear_gpio.c create mode 100644 drivers/mtd/nand/fsmc_nand.c delete mode 100644 drivers/mtd/nand/spr_nand.c rename drivers/mtd/{spr_smi.c => st_smi.c} (62%) rename include/configs/{spear3xx.h => spear3xx_evb.h} (72%) rename include/configs/{spear6xx.h => spear6xx_evb.h} (74%) create mode 100644 include/linux/mtd/fsmc_nand.h rename arch/arm/include/asm/arch-spear/spr_smi.h => include/linux/mtd/st_smi.h (95%) _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi Stefan,
On Fri, 22 Jun 2012 08:01:15 +0200, Stefan Roese sr@denx.de wrote:
Hi Albert,
Hi Albert!
Thanks, Stefan
Assigned to myself under review in patchwork, thanks.
Amicalement,
Hi Albert,
as you seem to be working on U-Boot patches right now, here another short reminder from me. ;)
Thanks, Stefan
On Friday 22 June 2012 08:01:15 Stefan Roese wrote:
Hi Albert,
Hi Albert!
Thanks, Stefan
4398d55991eb3c2484a2a8e991d701e5d7a64874: net: sh-eth: Add support Gigabit of SH7734 (2012-05-23 17:53:09 -0500)
are available in the git repository at: git://www.denx.de/git/u-boot-staging.git sr@denx.de
for you to fetch changes up to e94b7cb06a246532aba7af9e0f2040d4facba5db: MTD: SPEAr SMI: Add write support for length < 4 bytes (2012-06-05
08:42:50 +0200)
configuration
Hi Stefan,
On Thu, 5 Jul 2012 15:10:26 +0200, Stefan Roese sr@denx.de wrote:
Hi Albert,
Thanks, Stefan
Can you rebase this on current uboot-arm? Sorry for the inconvenience.
Amicalement,
Albert ARIBAUD
Stefan Roese
