[U-Boot] [PATCH 1/2] B4860/B4420: Add PLL_NUM define for B4420/B4860 to use SerDes2 Refclks re-configuration
- B4860 has two PLL per SerDes whereas B4420 has one PLL per SerDes, add their defines in arch/powerpc/include/asm/config_mpc85xx.h
Signed-off-by: Shaveta Leekha shaveta@freescale.com --- arch/powerpc/include/asm/config_mpc85xx.h | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 56587ae..0ec1417 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -667,6 +667,7 @@ #ifdef CONFIG_PPC_B4860 #define CONFIG_SYS_FSL_CORES_PER_CLUSTER 4 #define CONFIG_MAX_CPUS 4 +#define CONFIG_SYS_FSL_SRDS_NUM_PLLS 2 #define CONFIG_SYS_FSL_NUM_CC_PLLS 4 #define CONFIG_SYS_FSL_CLUSTER_CLOCKS { 1, 4, 4, 4 } #define CONFIG_SYS_NUM_FM1_DTSEC 6 @@ -679,6 +680,7 @@ #define CONFIG_SYS_FSL_SRIO_LIODN #else #define CONFIG_MAX_CPUS 2 +#define CONFIG_SYS_FSL_SRDS_NUM_PLLS 1 #define CONFIG_SYS_FSL_CORES_PER_CLUSTER 2 #define CONFIG_SYS_FSL_NUM_CC_PLLS 4 #define CONFIG_SYS_FSL_CLUSTER_CLOCKS { 1, 4 }
Applied to u-boot-mpc85xx/master. Thanks.
York
Shaveta Leekha
York Sun
