[PATCH] configs: m68k: Use default shell prompt
The current shell prompt '->' interferes with CI matching on 'bdinfo' output. When CI test.py attempts to locate memory information in the 'bdinfo' output, it matches on '->' prefix which is identical to the shell prefix. Switch the prompt to default '=>' one to avoid this interference.
Suggested-by: Tom Rini trini@konsulko.com # found the CI oddity Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Cc: Angelo Dureghello angelo@kernel-space.org Cc: Huan Wang alison.wang@nxp.com Cc: Marek Vasut marek.vasut+renesas@mailbox.org Cc: Simon Glass sjg@chromium.org Cc: Stefan Roese sr@denx.de Cc: Tom Rini trini@konsulko.com --- configs/M5208EVBE_defconfig | 1 - configs/M5235EVB_defconfig | 1 - configs/M5272C3_defconfig | 1 - configs/M5275EVB_defconfig | 1 - configs/M5282EVB_defconfig | 1 - configs/M53017EVB_defconfig | 1 - configs/M5329AFEE_defconfig | 1 - configs/M5329BFEE_defconfig | 1 - configs/M5373EVB_defconfig | 1 - 9 files changed, 9 deletions(-)
diff --git a/configs/M5208EVBE_defconfig b/configs/M5208EVBE_defconfig index 3263414d1c2..bc98d7fd641 100644 --- a/configs/M5208EVBE_defconfig +++ b/configs/M5208EVBE_defconfig @@ -4,7 +4,6 @@ CONFIG_SYS_MALLOC_LEN=0x20000 CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_DEFAULT_DEVICE_TREE="M5208EVBE" -CONFIG_SYS_PROMPT="-> " CONFIG_SYS_LOAD_ADDR=0x40010000 CONFIG_ENV_ADDR=0x2000 CONFIG_TARGET_M5208EVBE=y diff --git a/configs/M5235EVB_defconfig b/configs/M5235EVB_defconfig index fbd3e086ec3..ac696d8a8d6 100644 --- a/configs/M5235EVB_defconfig +++ b/configs/M5235EVB_defconfig @@ -4,7 +4,6 @@ CONFIG_SYS_MALLOC_LEN=0x20000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_DEFAULT_DEVICE_TREE="M5235EVB" -CONFIG_SYS_PROMPT="-> " CONFIG_SYS_LOAD_ADDR=0x20000 CONFIG_ENV_ADDR=0xFFE04000 CONFIG_TARGET_M5235EVB=y diff --git a/configs/M5272C3_defconfig b/configs/M5272C3_defconfig index 1c51c4a1666..6b46c6f4f51 100644 --- a/configs/M5272C3_defconfig +++ b/configs/M5272C3_defconfig @@ -4,7 +4,6 @@ CONFIG_SYS_MALLOC_LEN=0x40000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_DEFAULT_DEVICE_TREE="M5272C3" -CONFIG_SYS_PROMPT="-> " CONFIG_SYS_LOAD_ADDR=0x20000 CONFIG_ENV_ADDR=0xFFE04000 CONFIG_TARGET_M5272C3=y diff --git a/configs/M5275EVB_defconfig b/configs/M5275EVB_defconfig index ca1c18420ff..8eb551678b9 100644 --- a/configs/M5275EVB_defconfig +++ b/configs/M5275EVB_defconfig @@ -4,7 +4,6 @@ CONFIG_SYS_MALLOC_LEN=0x40000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_DEFAULT_DEVICE_TREE="M5275EVB" -CONFIG_SYS_PROMPT="-> " CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0xFFE04000 CONFIG_TARGET_M5275EVB=y diff --git a/configs/M5282EVB_defconfig b/configs/M5282EVB_defconfig index 2b053e3bbfe..1997f3800bb 100644 --- a/configs/M5282EVB_defconfig +++ b/configs/M5282EVB_defconfig @@ -4,7 +4,6 @@ CONFIG_SYS_MALLOC_LEN=0x40000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_DEFAULT_DEVICE_TREE="M5282EVB" -CONFIG_SYS_PROMPT="-> " CONFIG_SYS_LOAD_ADDR=0x20000 CONFIG_ENV_ADDR=0xFFE04000 CONFIG_TARGET_M5282EVB=y diff --git a/configs/M53017EVB_defconfig b/configs/M53017EVB_defconfig index c70964f7aa0..92445feb7d2 100644 --- a/configs/M53017EVB_defconfig +++ b/configs/M53017EVB_defconfig @@ -4,7 +4,6 @@ CONFIG_SYS_MALLOC_LEN=0x20000 CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_SECT_SIZE=0x8000 CONFIG_DEFAULT_DEVICE_TREE="M53017EVB" -CONFIG_SYS_PROMPT="-> " CONFIG_SYS_LOAD_ADDR=0x40010000 CONFIG_ENV_ADDR=0x40000 CONFIG_TARGET_M53017EVB=y diff --git a/configs/M5329AFEE_defconfig b/configs/M5329AFEE_defconfig index 455eea255ae..238413d2d5c 100644 --- a/configs/M5329AFEE_defconfig +++ b/configs/M5329AFEE_defconfig @@ -4,7 +4,6 @@ CONFIG_SYS_MALLOC_LEN=0x20000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_DEFAULT_DEVICE_TREE="M5329AFEE" -CONFIG_SYS_PROMPT="-> " CONFIG_SYS_LOAD_ADDR=0x40010000 CONFIG_ENV_ADDR=0x4000 CONFIG_TARGET_M5329EVB=y diff --git a/configs/M5329BFEE_defconfig b/configs/M5329BFEE_defconfig index 0251444b3bf..43cfc0e94db 100644 --- a/configs/M5329BFEE_defconfig +++ b/configs/M5329BFEE_defconfig @@ -4,7 +4,6 @@ CONFIG_SYS_MALLOC_LEN=0x20000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_DEFAULT_DEVICE_TREE="M5329BFEE" -CONFIG_SYS_PROMPT="-> " CONFIG_SYS_LOAD_ADDR=0x40010000 CONFIG_ENV_ADDR=0x4000 CONFIG_TARGET_M5329EVB=y diff --git a/configs/M5373EVB_defconfig b/configs/M5373EVB_defconfig index eec95da8573..db85e3401f4 100644 --- a/configs/M5373EVB_defconfig +++ b/configs/M5373EVB_defconfig @@ -4,7 +4,6 @@ CONFIG_SYS_MALLOC_LEN=0x20000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_SECT_SIZE=0x2000 CONFIG_DEFAULT_DEVICE_TREE="M5373EVB" -CONFIG_SYS_PROMPT="-> " CONFIG_SYS_LOAD_ADDR=0x40010000 CONFIG_ENV_ADDR=0x4000 CONFIG_TARGET_M5373EVB=y
Hi Marek,
Applied to u-boot-coldfire/master, thanks!
angelo
Angelo Dureghello
