[U-Boot] [PATCH] common/cmd_nand.c: Fix GCC 4.6 warning
cmd_nand.c: In function 'raw_access': cmd_nand.c:397:9: warning: variable 'rwsize' set but not used [-Wunused-but-set-variable]
Signed-off-by: Anatolij Gustschin agust@denx.de Cc: Scott Wood scottwood@freescale.com --- common/cmd_nand.c | 2 -- 1 files changed, 0 insertions(+), 2 deletions(-)
diff --git a/common/cmd_nand.c b/common/cmd_nand.c index f060a31..fa44295 100644 --- a/common/cmd_nand.c +++ b/common/cmd_nand.c @@ -394,7 +394,6 @@ static int raw_access(nand_info_t *nand, ulong addr, loff_t off, ulong count, int read) { int ret = 0; - size_t rwsize;
while (count--) { /* Raw access */ @@ -406,7 +405,6 @@ static int raw_access(nand_info_t *nand, ulong addr, loff_t off, ulong count, .mode = MTD_OOB_RAW };
- rwsize = nand->writesize + nand->oobsize; if (read) ret = nand->read_oob(nand, off, &ops); else
Dear Anatolij Gustschin,
Applied, thanks.
Anatolij Gustschin
