[U-Boot-Users] Marvell db64460 / mpc7447 migration from U-boot 1.1.2 to U-boot 1.3.3
Hello folks,
In a current work project, I have inherited a compactPCI board that has an mpc7447/7448 powerpc processor as well as a Marvell system controller, model mv64462 (stripped down mv64460). The board has a somewhat working U-boot 1.1.2 loader (using db64460 platform) and a Gentoo Linux port (kernel version 2.6.9 built using arch/ppc) running on it from long ago and a company far far away. It looks like the company contracted with Timesys to pull together the initial software. To prepare for an upcoming deployment, I would like to bring the OS up-to-date on this board with a newer kernel (targeting 2.6.24r3), as well as migrate U-boot to 1.3.3 and fix some bugs along the way.
My Linux kernel work is going very well, but with U-boot I'm stuck. I have what I believe 'may' be the working U-boot 1.1.2 source code, and I have migrated all of the board's customizations from various files into the 1.3.3 stream; however, I can get -no- console output on the serial port. I don't have access to a remote debugger, so I'm working in the dark and have no idea how far, if at all, the initialization is progressing. Does anyone know of any tips to help me along? Any changes in mpsc device initialization from 1.1.2 to 1.3.3 that could help me? Any clues?
Regards,
Stephen
In message 295C5089A56CE143B316E5F67CA99CB001D0692F@cowboy.inovate.inovate.com you wrote:
Ummm... if this is recent work, then why do you use such an old Linux kernel and not 2.6.27-rc1 or later?
Get access to a JTAG debugger (BDI3000).
------_=_NextPart_001_01C8F1E0.BD29C28E Content-Type: text/html; charset="us-ascii" Content-Transfer-Encoding: quoted-printable
And please do not post HTML.
Stephen Horton wrote:
Hello folks,
My Linux kernel work is going very well, but with U-boot I’m stuck. I have what I believe ‘may’ be the working U-boot 1.1.2 source code, and I have migrated all of the board’s customizations from various files into the 1.3.3 stream; however, I can get –no- console output on the serial port. I don’t have access to a remote debugger, so I’m working in the dark and have no idea how far, if at all, the initialization is progressing. Does anyone know of any tips to help me along? Any changes in mpsc device initialization from 1.1.2 to 1.3.3 that could help me? Any clues?
Regards,
Stephen
Suggestion: first make sure your 1.1.2 source is working (fix as necessary) before trying to pull it forward.
How are you reloading flash when you brick the board? What capabilities does your hardware have for debugging - can it halt the processor and show the registers?
Are there any LEDs you can blink when you get to a certain place in the code, and then move the blinkin' successfully further in the init sequence? Can you hook a logic analyzer or scope to a bus and do a bus write to indicate progress?
Is is a memory size / organization issue? Despite Wolfgang's best efforts, u-boot keeps growing. :-/ If you are lucky, the problem is simply that a memory section outgrew its allocation.
Good luck, gvb
Jerry Van Baren
Stephen Horton
