[PATCH] boot: Update default on USE_SPL_FIT_GENERATOR
The use of CONFIG_SPL_FIT_GENERATOR is deprecated and should not be used. Start by changing the current default option from enabled to only enabled for the platforms still using it.
Cc: Simon Glass sjg@chromium.org Signed-off-by: Tom Rini trini@konsulko.com --- This change completes the migration for a number of platforms that were tripping the warning before but not actually using a generator. --- boot/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/boot/Kconfig b/boot/Kconfig index c8d5906cd304..38fc64595ca7 100644 --- a/boot/Kconfig +++ b/boot/Kconfig @@ -275,7 +275,7 @@ config SPL_FIT_SOURCE
config USE_SPL_FIT_GENERATOR bool "Use a script to generate the .its script" - default y if SPL_FIT && (!ARCH_SUNXI && !RISCV) + default y if SPL_FIT && SPL_LOAD_FIT && (ARCH_ROCKCHIP || ARCH_ZYNQMP)
config SPL_FIT_GENERATOR string ".its file generator script for U-Boot FIT image"
Hi Tom,
This landed in spam so I missed it. I have a similar patch in my series if I ever get time to finish it. But we can deal with any conflict later.
On Tue, Feb 08, 2022 at 08:13:33AM -0700, Simon Glass wrote:
Hi Tom,
OK. Now that the first iMX PR has come through I _think_ the implicitly depended on binman patches there have come in and so this patch won't break anything. I'll pick this up soon along with other Kconfig migration/etc patches in the next day or two.
Hi Tom,
So, I was wrong. There's still: configs/cgtqmx8_defconfig configs/imx8mm-icore-mx8mm-ctouch2_defconfig configs/imx8mm-icore-mx8mm-edimm2.2_defconfig configs/imx8qm_rom7720_a1_4G_defconfig that need migration and only the last of which has a patch that I see right now: https://patchwork.ozlabs.org/project/uboot/patch/20220126155204.25099-1-oliv... but I assume the other 3 could be done fairly quickly.
Hi Tom,
Hi Tom,
See the cover letter for the series I just sent for another one that is hidden in a Makefile.
My series disables the IMX8 stuff which might be good enough since it is easy to migrate.
