[U-Boot] [PATCH][NEXT] arm-reloc: don't undef CONFIG_SYS_ARM_WITHOUT_RELOC
There were some #undef's of CONFIG_SYS_ARM_WITHOUT_RELOC added to a few board configs as part of the arm relocation series; but these are not needed now as we do not #undef what is not #defined in the first place.
Signed-off-by: Ben Gardiner bengardiner@nanometrics.ca CC: Heiko Schocher hs@denx.de
--- include/configs/da850evm.h | 1 - include/configs/imx27lite-common.h | 1 - include/configs/omap3_beagle.h | 1 - include/configs/qong.h | 1 - include/configs/tx25.h | 1 - 5 files changed, 0 insertions(+), 5 deletions(-)
diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index d02b196..e0a3bae 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -138,7 +138,6 @@ #endif
/* additions for new relocation code, must added to all boards */ -#undef CONFIG_SYS_ARM_WITHOUT_RELOC /* This board is tested with relocation support */ #define CONFIG_SYS_SDRAM_BASE 0xc0000000 #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x1000 - /* Fix this */ \ CONFIG_SYS_GBL_DATA_SIZE) diff --git a/include/configs/imx27lite-common.h b/include/configs/imx27lite-common.h index 812e5f2..4f7d61d 100644 --- a/include/configs/imx27lite-common.h +++ b/include/configs/imx27lite-common.h @@ -236,7 +236,6 @@ "mtdparts=" MTDPARTS_DEFAULT "\0" \
/* additions for new relocation code, must added to all boards */ -#undef CONFIG_SYS_ARM_WITHOUT_RELOC /* This board is tested with relocation support */ #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x1000 - /* Fix this */ \ CONFIG_SYS_GBL_DATA_SIZE) diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 2463be4..ce658d1 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -341,7 +341,6 @@ extern unsigned int boot_flash_type; #endif
/* additions for new relocation code, must added to all boards */ -#undef CONFIG_SYS_ARM_WITHOUT_RELOC /* This board is tested with relocation support */ #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 #define CONFIG_SYS_INIT_SP_ADDR (LOW_LEVEL_SRAM_STACK - CONFIG_SYS_GBL_DATA_SIZE)
diff --git a/include/configs/qong.h b/include/configs/qong.h index 7a68b7b..b9144eb 100644 --- a/include/configs/qong.h +++ b/include/configs/qong.h @@ -283,7 +283,6 @@ extern int qong_nand_rdy(void *chip); "128k(env2),2432k(kernel),13m(ramdisk),-(user)"
/* additions for new relocation code, must added to all boards */ -#undef CONFIG_SYS_ARM_WITHOUT_RELOC /* This board is tested with relocation support */ #define CONFIG_SYS_SDRAM_BASE 0x80000000 #define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR #define CONFIG_SYS_INIT_RAM_END IRAM_SIZE diff --git a/include/configs/tx25.h b/include/configs/tx25.h index c798570..85f166e 100644 --- a/include/configs/tx25.h +++ b/include/configs/tx25.h @@ -177,7 +177,6 @@ "upd=run load update\0" \
Hello Ben,
Good catch, thanks!
Acked-by: Heiko Schocherhs@denx.de
bye, Heiko
Dear Ben Gardiner,
In message 1285191169-32552-1-git-send-email-bengardiner@nanometrics.ca you wrote:
Aplied to u-boot-arm, thanks.
Ben Gardiner
Heiko Schocher
