[PATCH 1/3] mbedtls: fix incorrect kconfig dependencies on mbedtls
Currently building with WGET_HTTPS,NET_LWIP and MBEDTLS_LIB failed due to a few incorrect kconfig dependencies. Fix these and clarify what is the purpose of MBEDTLS_LIB_CRYPTO_ALT.
Signed-off-by: Raymond Mao raymond.mao@linaro.org --- cmd/Kconfig | 1 - lib/mbedtls/Kconfig | 8 +++++--- 2 files changed, 5 insertions(+), 4 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 1a0985ca479..071601b5ac2 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -2161,7 +2161,6 @@ config WGET_HTTPS select ASYMMETRIC_PUBLIC_KEY_SUBTYPE select X509_CERTIFICATE_PARSER select PKCS7_MESSAGE_PARSER - select MBEDTLS_LIB_CRYPTO select MBEDTLS_LIB_TLS select RSA_VERIFY_WITH_PKEY select X509_CERTIFICATE_PARSER diff --git a/lib/mbedtls/Kconfig b/lib/mbedtls/Kconfig index aa82336ef14..17ed2bc71de 100644 --- a/lib/mbedtls/Kconfig +++ b/lib/mbedtls/Kconfig @@ -116,6 +116,7 @@ endif # LEGACY_CRYPTO_BASIC
config LEGACY_CRYPTO_CERT bool "legacy certificate libraries" + depends on LEGACY_CRYPTO select ASN1_DECODER_LEGACY if ASN1_DECODER select ASYMMETRIC_PUBLIC_KEY_LEGACY if \ ASYMMETRIC_PUBLIC_KEY_SUBTYPE @@ -210,12 +211,13 @@ endif # LEGACY_CRYPTO if MBEDTLS_LIB
config MBEDTLS_LIB_CRYPTO_ALT - bool "MbedTLS crypto alternatives" + bool "Use legacy crypto libraries as MbedTLS alternatives" depends on MBEDTLS_LIB && !MBEDTLS_LIB_CRYPTO select LEGACY_CRYPTO_BASIC default y if MBEDTLS_LIB && !MBEDTLS_LIB_CRYPTO help - Enable MbedTLS crypto alternatives. + Enable MbedTLS crypto alternatives and replace it with legacy crypto + libraries. Mutually incompatible with MBEDTLS_LIB_CRYPTO.
config MBEDTLS_LIB_CRYPTO @@ -451,7 +453,7 @@ config MBEDTLS_LIB_TLS depends on ASYMMETRIC_PUBLIC_KEY_MBEDTLS depends on ASN1_DECODER_MBEDTLS depends on ASYMMETRIC_PUBLIC_KEY_MBEDTLS - depends on MBEDTLS_LIB_CRYPTO + depends on MBEDTLS_LIB help Enable MbedTLS TLS library. Required for HTTPs support in wget
U-Boot requires to access x509_internal.h, mbedtls_sha256_context and mbedtls_sha1_context in the porting layer, and this requires to enable MBEDTLS_ALLOW_PRIVATE_ACCESS.
Enable it to mscode and pkcs7_parser to fix a mbedtls internal building error when X509 is selected.
Moreover, Move it to a separate file to avoid enabling it in multiple places.
Signed-off-by: Raymond Mao raymond.mao@linaro.org --- include/crypto/mscode.h | 1 + include/crypto/pkcs7_parser.h | 1 + include/u-boot/sha1.h | 12 +----------- include/u-boot/sha256.h | 12 +----------- lib/mbedtls/port/mbedtls_options.h | 23 +++++++++++++++++++++++ 5 files changed, 27 insertions(+), 22 deletions(-) create mode 100644 lib/mbedtls/port/mbedtls_options.h
diff --git a/include/crypto/mscode.h b/include/crypto/mscode.h index 678e69001b9..55501c22acb 100644 --- a/include/crypto/mscode.h +++ b/include/crypto/mscode.h @@ -10,6 +10,7 @@ #include <crypto/hash_info.h> #endif #if CONFIG_IS_ENABLED(MBEDTLS_LIB_X509) +#include "mbedtls_options.h" #include <mbedtls/asn1.h> #include <mbedtls/oid.h> #endif diff --git a/include/crypto/pkcs7_parser.h b/include/crypto/pkcs7_parser.h index 469c2711fa6..fd1e48da09e 100644 --- a/include/crypto/pkcs7_parser.h +++ b/include/crypto/pkcs7_parser.h @@ -12,6 +12,7 @@ #include <crypto/pkcs7.h> #include <crypto/x509_parser.h> #if CONFIG_IS_ENABLED(MBEDTLS_LIB_X509) +#include "mbedtls_options.h" #include <mbedtls/pkcs7.h> #include <library/x509_internal.h> #include <mbedtls/asn1.h> diff --git a/include/u-boot/sha1.h b/include/u-boot/sha1.h index dd66258bbe9..c2d62e9cf0f 100644 --- a/include/u-boot/sha1.h +++ b/include/u-boot/sha1.h @@ -18,17 +18,7 @@ #include <linux/types.h>
#if CONFIG_IS_ENABLED(MBEDTLS_LIB_CRYPTO) -/* - * FIXME: - * MbedTLS define the members of "mbedtls_sha256_context" as private, - * but "state" needs to be access by arch/arm/cpu/armv8/sha1_ce_glue. - * MBEDTLS_ALLOW_PRIVATE_ACCESS needs to be enabled to allow the external - * access. - * Directly including <external/mbedtls/library/common.h> is not allowed, - * since this will include <malloc.h> and break the sandbox test. - */ -#define MBEDTLS_ALLOW_PRIVATE_ACCESS - +#include "mbedtls_options.h" #include <mbedtls/sha1.h> #endif
diff --git a/include/u-boot/sha256.h b/include/u-boot/sha256.h index d7a3403270b..2d86508332e 100644 --- a/include/u-boot/sha256.h +++ b/include/u-boot/sha256.h @@ -7,17 +7,7 @@ #include <linux/types.h>
#if CONFIG_IS_ENABLED(MBEDTLS_LIB_CRYPTO) -/* - * FIXME: - * MbedTLS define the members of "mbedtls_sha256_context" as private, - * but "state" needs to be access by arch/arm/cpu/armv8/sha256_ce_glue. - * MBEDTLS_ALLOW_PRIVATE_ACCESS needs to be enabled to allow the external - * access. - * Directly including <external/mbedtls/library/common.h> is not allowed, - * since this will include <malloc.h> and break the sandbox test. - */ -#define MBEDTLS_ALLOW_PRIVATE_ACCESS - +#include "mbedtls_options.h" #include <mbedtls/sha256.h> #endif
diff --git a/lib/mbedtls/port/mbedtls_options.h b/lib/mbedtls/port/mbedtls_options.h new file mode 100644 index 00000000000..885ed6990b6 --- /dev/null +++ b/lib/mbedtls/port/mbedtls_options.h @@ -0,0 +1,23 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Internal build options for MbedTLS + * + * Copyright (c) 2025 Linaro Limited + * Author: Raymond Mao raymond.mao@linaro.org + */ + +#ifndef _MBEDTLS_OPT_H +#define _MBEDTLS_OPT_H + +/* + * FIXME: + * U-Boot/MbedTLS port requires to access a few of members which are defined + * as private in MbedTLS context. + * E.g: x509_internal.h, mbedtls_sha256_context and mbedtls_sha1_context. + * MBEDTLS_ALLOW_PRIVATE_ACCESS needs to be enabled to allow the external + * access, but directly including <external/mbedtls/library/common.h> is not + * allowed, since this will include <malloc.h> and break the sandbox test. + */ +#define MBEDTLS_ALLOW_PRIVATE_ACCESS + +#endif /* _MBEDTLS_OPT_H */
Refactor the entire kconfig page for mbedtls, adapt mbedtls makefile and default config file using 'XPL_', in order to have independent mbedtls kconfig options in both U-Boot Proper and SPL. User can choose legacy or mbedtls libraries in SPL independently.
Set mbedtls native crypto libraries as default when MBEDTLS_LIB or SPL_MBEDTLS_LIB is selected.
Signed-off-by: Raymond Mao raymond.mao@linaro.org --- Makefile | 2 +- lib/mbedtls/Kconfig | 381 +++++++++++++++++++------------ lib/mbedtls/Makefile | 44 ++-- lib/mbedtls/mbedtls_def_config.h | 37 +-- 4 files changed, 276 insertions(+), 188 deletions(-)
diff --git a/Makefile b/Makefile index 5c6f467153c..406cd28595a 100644 --- a/Makefile +++ b/Makefile @@ -829,7 +829,7 @@ KBUILD_HOSTCFLAGS += $(if $(CONFIG_TOOLS_DEBUG),-g) UBOOTINCLUDE := \ -Iinclude \ $(if $(KBUILD_SRC), -I$(srctree)/include) \ - $(if $(CONFIG_MBEDTLS_LIB), \ + $(if $(CONFIG_$(XPL_)MBEDTLS_LIB), \ "-DMBEDTLS_CONFIG_FILE="mbedtls_def_config.h"" \ -I$(srctree)/lib/mbedtls \ -I$(srctree)/lib/mbedtls/port \ diff --git a/lib/mbedtls/Kconfig b/lib/mbedtls/Kconfig index 17ed2bc71de..821d13a0dd2 100644 --- a/lib/mbedtls/Kconfig +++ b/lib/mbedtls/Kconfig @@ -1,3 +1,5 @@ +# For U-Boot Proper + choice prompt "Select crypto libraries" default LEGACY_CRYPTO @@ -25,11 +27,6 @@ config LEGACY_CRYPTO_BASIC select SHA256_LEGACY if SHA256 select SHA512_LEGACY if SHA512 select SHA384_LEGACY if SHA384 - select SPL_MD5_LEGACY if SPL_MD5 - select SPL_SHA1_LEGACY if SPL_SHA1 - select SPL_SHA256_LEGACY if SPL_SHA256 - select SPL_SHA512_LEGACY if SPL_SHA512 - select SPL_SHA384_LEGACY if SPL_SHA384 help Enable legacy basic crypto libraries.
@@ -72,46 +69,6 @@ config MD5_LEGACY This option enables support of hashing using MD5 algorithm with legacy crypto library.
-if SPL - -config SPL_SHA1_LEGACY - bool "Enable SHA1 support in SPL with legacy crypto library" - depends on LEGACY_CRYPTO_BASIC && SPL_SHA1 - help - This option enables support of hashing using SHA1 algorithm - with legacy crypto library. - -config SPL_SHA256_LEGACY - bool "Enable SHA256 support in SPL with legacy crypto library" - depends on LEGACY_CRYPTO_BASIC && SPL_SHA256 - help - This option enables support of hashing using SHA256 algorithm - with legacy crypto library. - -config SPL_SHA512_LEGACY - bool "Enable SHA512 support in SPL with legacy crypto library" - depends on LEGACY_CRYPTO_BASIC && SPL_SHA512 - help - This option enables support of hashing using SHA512 algorithm - with legacy crypto library. - -config SPL_SHA384_LEGACY - bool "Enable SHA384 support in SPL with legacy crypto library" - depends on LEGACY_CRYPTO_BASIC && SPL_SHA384 - select SPL_SHA512_LEGACY - help - This option enables support of hashing using SHA384 algorithm - with legacy crypto library. - -config SPL_MD5_LEGACY - bool "Enable MD5 support in SPL with legacy crypto library" - depends on LEGACY_CRYPTO_BASIC && SPL_MD5 - help - This option enables support of hashing using MD5 algorithm - with legacy crypto library. - -endif # SPL - endif # LEGACY_CRYPTO_BASIC
config LEGACY_CRYPTO_CERT @@ -124,10 +81,6 @@ config LEGACY_CRYPTO_CERT select X509_CERTIFICATE_PARSER_LEGACY if X509_CERTIFICATE_PARSER select PKCS7_MESSAGE_PARSER_LEGACY if PKCS7_MESSAGE_PARSER select MSCODE_PARSER_LEGACY if MSCODE_PARSER - select SPL_ASN1_DECODER_LEGACY if SPL_ASN1_DECODER - select SPL_ASYMMETRIC_PUBLIC_KEY_LEGACY if \ - SPL_ASYMMETRIC_PUBLIC_KEY_SUBTYPE - select SPL_RSA_PUBLIC_KEY_PARSER_LEGACY if SPL_RSA_PUBLIC_KEY_PARSER help Enable legacy certificate libraries.
@@ -178,35 +131,9 @@ config MSCODE_PARSER_LEGACY This option chooses legacy certificate library for MS authenticode parser.
-if SPL - -config SPL_ASN1_DECODER_LEGACY - bool "ASN1 decoder with legacy certificate library in SPL" - depends on LEGACY_CRYPTO_CERT && SPL_ASN1_DECODER - help - This option chooses legacy certificate library for ASN1 decoder in - SPL. - -config SPL_ASYMMETRIC_PUBLIC_KEY_LEGACY - bool "Asymmetric public key crypto with legacy certificate library in SPL" - depends on LEGACY_CRYPTO_CERT && SPL_ASYMMETRIC_PUBLIC_KEY_SUBTYPE - help - This option chooses legacy certificate library for asymmetric public - key crypto algorithm in SPL. - -config SPL_RSA_PUBLIC_KEY_PARSER_LEGACY - bool "RSA public key parser with legacy certificate library in SPL" - depends on SPL_ASYMMETRIC_PUBLIC_KEY_LEGACY - select SPL_ASN1_DECODER_LEGACY - help - This option chooses legacy certificate library for RSA public key - parser in SPL. - -endif # SPL - endif # LEGACY_CRYPTO_CERT
-endif # LEGACY_CRYPTO +endif # LEGACY_CRYPTO || MBEDTLS_LIB_CRYPTO_ALT
if MBEDTLS_LIB
@@ -221,19 +148,15 @@ config MBEDTLS_LIB_CRYPTO_ALT Mutually incompatible with MBEDTLS_LIB_CRYPTO.
config MBEDTLS_LIB_CRYPTO - bool "MbedTLS crypto libraries" + bool "Use MbedTLS native crypto libraries" + default y if MBEDTLS_LIB select MD5_MBEDTLS if MD5 select SHA1_MBEDTLS if SHA1 select SHA256_MBEDTLS if SHA256 select SHA512_MBEDTLS if SHA512 select SHA384_MBEDTLS if SHA384 - select SPL_MD5_MBEDTLS if SPL_MD5 - select SPL_SHA1_MBEDTLS if SPL_SHA1 - select SPL_SHA256_MBEDTLS if SPL_SHA256 - select SPL_SHA512_MBEDTLS if SPL_SHA512 - select SPL_SHA384_MBEDTLS if SPL_SHA384 help - Enable MbedTLS crypto libraries. + Enable MbedTLS native crypto libraries. Mutually incompatible with MBEDTLS_LIB_CRYPTO_ALT.
if MBEDTLS_LIB_CRYPTO @@ -306,53 +229,6 @@ config HKDF_MBEDTLS This option enables support of key derivation using HKDF algorithm with MbedTLS crypto library.
-if SPL - -config SPL_SHA1_MBEDTLS - bool "Enable SHA1 support in SPL with MbedTLS crypto library" - depends on MBEDTLS_LIB_CRYPTO && SPL_SHA1 - help - This option enables support of hashing using SHA1 algorithm - with MbedTLS crypto library. - -config SPL_SHA256_MBEDTLS - bool "Enable SHA256 support in SPL with MbedTLS crypto library" - depends on MBEDTLS_LIB_CRYPTO && SPL_SHA256 - help - This option enables support of hashing using SHA256 algorithm - with MbedTLS crypto library. - -config SPL_SHA512_MBEDTLS - bool "Enable SHA512 support in SPL with MbedTLS crypto library" - depends on MBEDTLS_LIB_CRYPTO && SPL_SHA512 - help - This option enables support of hashing using SHA512 algorithm - with MbedTLS crypto library. - -config SPL_SHA384_MBEDTLS - bool "Enable SHA384 support in SPL with MbedTLS crypto library" - depends on MBEDTLS_LIB_CRYPTO && SPL_SHA384 - select SPL_SHA512 - help - This option enables support of hashing using SHA384 algorithm - with MbedTLS crypto library. - -config SPL_MD5_MBEDTLS - bool "Enable MD5 support in SPL with MbedTLS crypto library" - depends on MBEDTLS_LIB_CRYPTO && SPL_MD5 - help - This option enables support of hashing using MD5 algorithm - with MbedTLS crypto library. - -config SPL_HKDF_MBEDTLS - bool "Enable HKDF support in SPL with MbedTLS crypto library" - depends on MBEDTLS_LIB_CRYPTO - help - This option enables support of key derivation using HKDF algorithm - with MbedTLS crypto library. - -endif # SPL - endif # MBEDTLS_LIB_CRYPTO
config MBEDTLS_LIB_X509 @@ -364,10 +240,6 @@ config MBEDTLS_LIB_X509 select X509_CERTIFICATE_PARSER_MBEDTLS if X509_CERTIFICATE_PARSER select PKCS7_MESSAGE_PARSER_MBEDTLS if PKCS7_MESSAGE_PARSER select MSCODE_PARSER_MBEDTLS if MSCODE_PARSER - select SPL_ASN1_DECODER_MBEDTLS if SPL_ASN1_DECODER - select SPL_ASYMMETRIC_PUBLIC_KEY_MBEDTLS if \ - SPL_ASYMMETRIC_PUBLIC_KEY_SUBTYPE - select SPL_RSA_PUBLIC_KEY_PARSER_MBEDTLS if SPL_RSA_PUBLIC_KEY_PARSER help Enable MbedTLS certificate libraries.
@@ -418,44 +290,249 @@ config MSCODE_PARSER_MBEDTLS This option chooses MbedTLS certificate library for MS authenticode parser.
+endif # MBEDTLS_LIB_X509 + +config MBEDTLS_LIB_TLS + bool "MbedTLS TLS library" + depends on RSA_PUBLIC_KEY_PARSER_MBEDTLS + depends on X509_CERTIFICATE_PARSER_MBEDTLS + depends on ASYMMETRIC_PUBLIC_KEY_MBEDTLS + depends on ASN1_DECODER_MBEDTLS + depends on MBEDTLS_LIB + help + Enable MbedTLS TLS library. Required for HTTPs support + in wget + +endif # MBEDTLS_LIB + +# For SPL + if SPL
+choice + prompt "Select crypto libraries (SPL)" + default SPL_LEGACY_CRYPTO + help + Select crypto libraries in SPL. + SPL_LEGACY_CRYPTO for legacy crypto libraries, + SPL_MBEDTLS_LIB for MbedTLS libraries. + +config SPL_LEGACY_CRYPTO + bool "legacy crypto libraries" + select SPL_LEGACY_CRYPTO_BASIC + select SPL_LEGACY_CRYPTO_CERT + +config SPL_MBEDTLS_LIB + bool "MbedTLS libraries" + select SPL_MBEDTLS_LIB_X509 +endchoice + +if SPL_LEGACY_CRYPTO || SPL_MBEDTLS_LIB_CRYPTO_ALT + +config SPL_LEGACY_CRYPTO_BASIC + bool "legacy basic crypto libraries (SPL)" + select SPL_MD5_LEGACY if SPL_MD5 + select SPL_SHA1_LEGACY if SPL_SHA1 + select SPL_SHA256_LEGACY if SPL_SHA256 + select SPL_SHA512_LEGACY if SPL_SHA512 + select SPL_SHA384_LEGACY if SPL_SHA384 + help + Enable legacy basic crypto libraries in SPL. + +if SPL_LEGACY_CRYPTO_BASIC + +config SPL_SHA1_LEGACY + bool "Enable SHA1 support with legacy crypto library (SPL)" + depends on SPL_LEGACY_CRYPTO_BASIC && SPL_SHA1 + help + This option enables support of hashing using SHA1 algorithm + with legacy crypto library in SPL. + +config SPL_SHA256_LEGACY + bool "Enable SHA256 support with legacy crypto library (SPL)" + depends on SPL_LEGACY_CRYPTO_BASIC && SPL_SHA256 + help + This option enables support of hashing using SHA256 algorithm + with legacy crypto library in SPL. + +config SPL_SHA512_LEGACY + bool "Enable SHA512 support with legacy crypto library (SPL)" + depends on SPL_LEGACY_CRYPTO_BASIC && SPL_SHA512 + help + This option enables support of hashing using SHA512 algorithm + with legacy crypto library in SPL. + +config SPL_SHA384_LEGACY + bool "Enable SHA384 support with legacy crypto library (SPL)" + depends on SPL_LEGACY_CRYPTO_BASIC && SPL_SHA384 + select SPL_SHA512_LEGACY + help + This option enables support of hashing using SHA384 algorithm + with legacy crypto library in SPL. + +config SPL_MD5_LEGACY + bool "Enable MD5 support with legacy crypto library (SPL)" + depends on SPL_LEGACY_CRYPTO_BASIC && SPL_MD5 + help + This option enables support of hashing using MD5 algorithm + with legacy crypto library in SPL. + +endif # SPL_LEGACY_CRYPTO_BASIC + +config SPL_LEGACY_CRYPTO_CERT + bool "legacy certificate libraries (SPL)" + depends on SPL_LEGACY_CRYPTO + select SPL_ASN1_DECODER_LEGACY if SPL_ASN1_DECODER + select SPL_ASYMMETRIC_PUBLIC_KEY_LEGACY if \ + SPL_ASYMMETRIC_PUBLIC_KEY_SUBTYPE + select SPL_RSA_PUBLIC_KEY_PARSER_LEGACY if SPL_RSA_PUBLIC_KEY_PARSER + help + Enable legacy certificate libraries in SPL. + +if SPL_LEGACY_CRYPTO_CERT + +config SPL_ASN1_DECODER_LEGACY + bool "ASN1 decoder with legacy certificate library (SPL)" + depends on SPL_LEGACY_CRYPTO_CERT && SPL_ASN1_DECODER + help + This option chooses legacy certificate library for ASN1 decoder in + SPL. + +config SPL_ASYMMETRIC_PUBLIC_KEY_LEGACY + bool "Asymmetric public key crypto with legacy certificate library (SPL)" + depends on SPL_LEGACY_CRYPTO_CERT && SPL_ASYMMETRIC_PUBLIC_KEY_SUBTYPE + help + This option chooses legacy certificate library for asymmetric public + key crypto algorithm in SPL. + +config SPL_RSA_PUBLIC_KEY_PARSER_LEGACY + bool "RSA public key parser with legacy certificate library (SPL)" + depends on SPL_ASYMMETRIC_PUBLIC_KEY_LEGACY + select SPL_ASN1_DECODER_LEGACY + help + This option chooses legacy certificate library for RSA public key + parser in SPL. + +endif # SPL_LEGACY_CRYPTO_CERT + +endif # SPL_LEGACY_CRYPTO || SPL_MBEDTLS_LIB_CRYPTO_ALT + +if SPL_MBEDTLS_LIB + +config SPL_MBEDTLS_LIB_CRYPTO_ALT + bool "Use legacy crypto libraries as MbedTLS alternatives (SPL)" + depends on SPL_MBEDTLS_LIB && !SPL_MBEDTLS_LIB_CRYPTO + select SPL_LEGACY_CRYPTO_BASIC + default y if SPL_MBEDTLS_LIB && !SPL_MBEDTLS_LIB_CRYPTO + help + Enable MbedTLS crypto alternatives and replace it with legacy crypto + libraries in SPL. + Mutually incompatible with SPL_MBEDTLS_LIB_CRYPTO. + +config SPL_MBEDTLS_LIB_CRYPTO + bool "Use MbedTLS native crypto libraries (SPL)" + default y if SPL_MBEDTLS_LIB + select SPL_MD5_MBEDTLS if SPL_MD5 + select SPL_SHA1_MBEDTLS if SPL_SHA1 + select SPL_SHA256_MBEDTLS if SPL_SHA256 + select SPL_SHA512_MBEDTLS if SPL_SHA512 + select SPL_SHA384_MBEDTLS if SPL_SHA384 + help + Enable MbedTLS native crypto libraries in SPL. + +if SPL_MBEDTLS_LIB_CRYPTO + +config SPL_SHA1_MBEDTLS + bool "Enable SHA1 support with MbedTLS crypto library (SPL)" + depends on SPL_MBEDTLS_LIB_CRYPTO && SPL_SHA1 + help + This option enables support of hashing using SHA1 algorithm + with MbedTLS crypto library in SPL. + +config SPL_SHA256_MBEDTLS + bool "Enable SHA256 support with MbedTLS crypto library (SPL)" + depends on SPL_MBEDTLS_LIB_CRYPTO && SPL_SHA256 + help + This option enables support of hashing using SHA256 algorithm + with MbedTLS crypto library in SPL. + +config SPL_SHA512_MBEDTLS + bool "Enable SHA512 support with MbedTLS crypto library (SPL)" + depends on SPL_MBEDTLS_LIB_CRYPTO && SPL_SHA512 + help + This option enables support of hashing using SHA512 algorithm + with MbedTLS crypto library in SPL. + +config SPL_SHA384_MBEDTLS + bool "Enable SHA384 support with MbedTLS crypto library (SPL)" + depends on SPL_MBEDTLS_LIB_CRYPTO && SPL_SHA384 + select SPL_SHA512 + help + This option enables support of hashing using SHA384 algorithm + with MbedTLS crypto library in SPL. + +config SPL_MD5_MBEDTLS + bool "Enable MD5 support with MbedTLS crypto library (SPL)" + depends on SPL_MBEDTLS_LIB_CRYPTO && SPL_MD5 + help + This option enables support of hashing using MD5 algorithm + with MbedTLS crypto library in SPL. + +config SPL_HKDF_MBEDTLS + bool "Enable HKDF support with MbedTLS crypto library (SPL)" + depends on SPL_MBEDTLS_LIB_CRYPTO + help + This option enables support of key derivation using HKDF algorithm + with MbedTLS crypto library in SPL. + +endif # SPL_MBEDTLS_LIB_CRYPTO + +config SPL_MBEDTLS_LIB_X509 + bool "MbedTLS certificate libraries (SPL)" + select SPL_ASN1_DECODER_MBEDTLS if SPL_ASN1_DECODER + select SPL_ASYMMETRIC_PUBLIC_KEY_MBEDTLS if \ + SPL_ASYMMETRIC_PUBLIC_KEY_SUBTYPE + select SPL_RSA_PUBLIC_KEY_PARSER_MBEDTLS if SPL_RSA_PUBLIC_KEY_PARSER + help + Enable MbedTLS certificate libraries in SPL. + +if SPL_MBEDTLS_LIB_X509 + config SPL_ASN1_DECODER_MBEDTLS - bool "ASN1 decoder with MbedTLS certificate library in SPL" - depends on MBEDTLS_LIB_X509 && SPL_ASN1_DECODER + bool "ASN1 decoder with MbedTLS certificate library (SPL)" + depends on SPL_MBEDTLS_LIB_X509 && SPL_ASN1_DECODER help This option chooses MbedTLS certificate library for ASN1 decoder in SPL.
config SPL_ASYMMETRIC_PUBLIC_KEY_MBEDTLS - bool "Asymmetric public key crypto with MbedTLS certificate library in SPL" - depends on MBEDTLS_LIB_X509 && SPL_ASYMMETRIC_PUBLIC_KEY_SUBTYPE + bool "Asymmetric public key crypto with MbedTLS certificate library (SPL)" + depends on SPL_MBEDTLS_LIB_X509 && SPL_ASYMMETRIC_PUBLIC_KEY_SUBTYPE help This option chooses MbedTLS certificate library for asymmetric public key crypto algorithm in SPL.
config SPL_RSA_PUBLIC_KEY_PARSER_MBEDTLS - bool "RSA public key parser with MbedTLS certificate library in SPL" + bool "RSA public key parser with MbedTLS certificate library (SPL)" depends on SPL_ASYMMETRIC_PUBLIC_KEY_MBEDTLS select SPL_ASN1_DECODER_MBEDTLS help This option chooses MbedTLS certificate library for RSA public key parser in SPL.
-endif # SPL +endif # SPL_MBEDTLS_LIB_X509
-endif # MBEDTLS_LIB_X509 - -config MBEDTLS_LIB_TLS - bool "MbedTLS TLS library" - depends on RSA_PUBLIC_KEY_PARSER_MBEDTLS - depends on X509_CERTIFICATE_PARSER_MBEDTLS - depends on ASYMMETRIC_PUBLIC_KEY_MBEDTLS - depends on ASN1_DECODER_MBEDTLS - depends on ASYMMETRIC_PUBLIC_KEY_MBEDTLS - depends on MBEDTLS_LIB +config SPL_MBEDTLS_LIB_TLS + bool "MbedTLS TLS library (SPL)" + depends on SPL_RSA_PUBLIC_KEY_PARSER_MBEDTLS + depends on SPL_X509_CERTIFICATE_PARSER_MBEDTLS + depends on SPL_ASYMMETRIC_PUBLIC_KEY_MBEDTLS + depends on SPL_ASN1_DECODER_MBEDTLS + depends on SPL_MBEDTLS_LIB help - Enable MbedTLS TLS library. Required for HTTPs support + Enable MbedTLS TLS library in SPL. Required for HTTPs support in wget
-endif # MBEDTLS_LIB +endif # SPL_MBEDTLS_LIB + +endif # SPL diff --git a/lib/mbedtls/Makefile b/lib/mbedtls/Makefile index e66c2018d97..4bbe7ceec45 100644 --- a/lib/mbedtls/Makefile +++ b/lib/mbedtls/Makefile @@ -6,60 +6,60 @@ MBEDTLS_LIB_DIR = external/mbedtls/library
# shim layer for hash -obj-$(CONFIG_$(SPL_)MD5_MBEDTLS) += md5.o -obj-$(CONFIG_$(SPL_)SHA1_MBEDTLS) += sha1.o -obj-$(CONFIG_$(SPL_)SHA256_MBEDTLS) += sha256.o -obj-$(CONFIG_$(SPL_)SHA512_MBEDTLS) += sha512.o +obj-$(CONFIG_$(XPL_)MD5_MBEDTLS) += md5.o +obj-$(CONFIG_$(XPL_)SHA1_MBEDTLS) += sha1.o +obj-$(CONFIG_$(XPL_)SHA256_MBEDTLS) += sha256.o +obj-$(CONFIG_$(XPL_)SHA512_MBEDTLS) += sha512.o
# x509 libraries -obj-$(CONFIG_$(SPL_)ASYMMETRIC_PUBLIC_KEY_MBEDTLS) += \ +obj-$(CONFIG_$(XPL_)ASYMMETRIC_PUBLIC_KEY_MBEDTLS) += \ public_key.o -obj-$(CONFIG_$(SPL_)X509_CERTIFICATE_PARSER_MBEDTLS) += \ +obj-$(CONFIG_$(XPL_)X509_CERTIFICATE_PARSER_MBEDTLS) += \ x509_cert_parser.o -obj-$(CONFIG_$(SPL_)PKCS7_MESSAGE_PARSER_MBEDTLS) += pkcs7_parser.o -obj-$(CONFIG_$(SPL_)MSCODE_PARSER_MBEDTLS) += mscode_parser.o -obj-$(CONFIG_$(SPL_)RSA_PUBLIC_KEY_PARSER_MBEDTLS) += rsa_helper.o +obj-$(CONFIG_$(XPL_)PKCS7_MESSAGE_PARSER_MBEDTLS) += pkcs7_parser.o +obj-$(CONFIG_$(XPL_)MSCODE_PARSER_MBEDTLS) += mscode_parser.o +obj-$(CONFIG_$(XPL_)RSA_PUBLIC_KEY_PARSER_MBEDTLS) += rsa_helper.o
# MbedTLS crypto library -obj-$(CONFIG_MBEDTLS_LIB) += mbedtls_lib_crypto.o +obj-$(CONFIG_$(XPL_)MBEDTLS_LIB) += mbedtls_lib_crypto.o mbedtls_lib_crypto-y := \ $(MBEDTLS_LIB_DIR)/platform_util.o \ $(MBEDTLS_LIB_DIR)/constant_time.o \ $(MBEDTLS_LIB_DIR)/md.o
-mbedtls_lib_crypto-$(CONFIG_$(SPL_)MD5_MBEDTLS) += $(MBEDTLS_LIB_DIR)/md5.o -mbedtls_lib_crypto-$(CONFIG_$(SPL_)SHA1_MBEDTLS) += $(MBEDTLS_LIB_DIR)/sha1.o -mbedtls_lib_crypto-$(CONFIG_$(SPL_)SHA256_MBEDTLS) += \ +mbedtls_lib_crypto-$(CONFIG_$(XPL_)MD5_MBEDTLS) += $(MBEDTLS_LIB_DIR)/md5.o +mbedtls_lib_crypto-$(CONFIG_$(XPL_)SHA1_MBEDTLS) += $(MBEDTLS_LIB_DIR)/sha1.o +mbedtls_lib_crypto-$(CONFIG_$(XPL_)SHA256_MBEDTLS) += \ $(MBEDTLS_LIB_DIR)/sha256.o -mbedtls_lib_crypto-$(CONFIG_$(SPL_)SHA512_MBEDTLS) += \ +mbedtls_lib_crypto-$(CONFIG_$(XPL_)SHA512_MBEDTLS) += \ $(MBEDTLS_LIB_DIR)/sha512.o -mbedtls_lib_crypto-$(CONFIG_$(SPL_)HKDF_MBEDTLS) += \ +mbedtls_lib_crypto-$(CONFIG_$(XPL_)HKDF_MBEDTLS) += \ $(MBEDTLS_LIB_DIR)/hkdf.o
# MbedTLS X509 library -obj-$(CONFIG_MBEDTLS_LIB_X509) += mbedtls_lib_x509.o +obj-$(CONFIG_$(XPL_)MBEDTLS_LIB_X509) += mbedtls_lib_x509.o mbedtls_lib_x509-y := $(MBEDTLS_LIB_DIR)/x509.o -mbedtls_lib_x509-$(CONFIG_$(SPL_)ASN1_DECODER_MBEDTLS) += \ +mbedtls_lib_x509-$(CONFIG_$(XPL_)ASN1_DECODER_MBEDTLS) += \ $(MBEDTLS_LIB_DIR)/asn1parse.o \ $(MBEDTLS_LIB_DIR)/asn1write.o \ $(MBEDTLS_LIB_DIR)/oid.o -mbedtls_lib_x509-$(CONFIG_$(SPL_)RSA_PUBLIC_KEY_PARSER_MBEDTLS) += \ +mbedtls_lib_x509-$(CONFIG_$(XPL_)RSA_PUBLIC_KEY_PARSER_MBEDTLS) += \ $(MBEDTLS_LIB_DIR)/bignum.o \ $(MBEDTLS_LIB_DIR)/bignum_core.o \ $(MBEDTLS_LIB_DIR)/rsa.o \ $(MBEDTLS_LIB_DIR)/rsa_alt_helpers.o -mbedtls_lib_x509-$(CONFIG_$(SPL_)ASYMMETRIC_PUBLIC_KEY_MBEDTLS) += \ +mbedtls_lib_x509-$(CONFIG_$(XPL_)ASYMMETRIC_PUBLIC_KEY_MBEDTLS) += \ $(MBEDTLS_LIB_DIR)/pk.o \ $(MBEDTLS_LIB_DIR)/pk_wrap.o \ $(MBEDTLS_LIB_DIR)/pkparse.o -mbedtls_lib_x509-$(CONFIG_$(SPL_)X509_CERTIFICATE_PARSER_MBEDTLS) += \ +mbedtls_lib_x509-$(CONFIG_$(XPL_)X509_CERTIFICATE_PARSER_MBEDTLS) += \ $(MBEDTLS_LIB_DIR)/x509_crl.o \ $(MBEDTLS_LIB_DIR)/x509_crt.o -mbedtls_lib_x509-$(CONFIG_$(SPL_)PKCS7_MESSAGE_PARSER_MBEDTLS) += \ +mbedtls_lib_x509-$(CONFIG_$(XPL_)PKCS7_MESSAGE_PARSER_MBEDTLS) += \ $(MBEDTLS_LIB_DIR)/pkcs7.o
#mbedTLS TLS support -obj-$(CONFIG_MBEDTLS_LIB_TLS) += mbedtls_lib_tls.o +obj-$(CONFIG_$(XPL_)MBEDTLS_LIB_TLS) += mbedtls_lib_tls.o mbedtls_lib_tls-y := \ $(MBEDTLS_LIB_DIR)/mps_reader.o \ $(MBEDTLS_LIB_DIR)/mps_trace.o \ diff --git a/lib/mbedtls/mbedtls_def_config.h b/lib/mbedtls/mbedtls_def_config.h index fd440c392f9..2da88c95454 100644 --- a/lib/mbedtls/mbedtls_def_config.h +++ b/lib/mbedtls/mbedtls_def_config.h @@ -11,12 +11,12 @@ * Author: Raymond Mao raymond.mao@linaro.org */
-#if defined CONFIG_MBEDTLS_LIB +#if CONFIG_IS_ENABLED(MBEDTLS_LIB)
#if CONFIG_IS_ENABLED(MD5) #define MBEDTLS_MD_C #define MBEDTLS_MD5_C -#if defined CONFIG_MBEDTLS_LIB_CRYPTO_ALT +#if CONFIG_IS_ENABLED(MBEDTLS_LIB_CRYPTO_ALT) #define MBEDTLS_MD5_ALT #endif #endif @@ -24,7 +24,7 @@ #if CONFIG_IS_ENABLED(SHA1) #define MBEDTLS_MD_C #define MBEDTLS_SHA1_C -#if defined CONFIG_MBEDTLS_LIB_CRYPTO_ALT +#if CONFIG_IS_ENABLED(MBEDTLS_LIB_CRYPTO_ALT) #define MBEDTLS_SHA1_ALT #endif #endif @@ -32,7 +32,7 @@ #if CONFIG_IS_ENABLED(SHA256) #define MBEDTLS_MD_C #define MBEDTLS_SHA256_C -#if defined CONFIG_MBEDTLS_LIB_CRYPTO_ALT +#if CONFIG_IS_ENABLED(MBEDTLS_LIB_CRYPTO_ALT) #define MBEDTLS_SHA256_ALT #endif #if CONFIG_IS_ENABLED(SHA256_SMALLER) @@ -48,7 +48,7 @@ #if CONFIG_IS_ENABLED(SHA512) #define MBEDTLS_MD_C #define MBEDTLS_SHA512_C -#if defined CONFIG_MBEDTLS_LIB_CRYPTO_ALT +#if CONFIG_IS_ENABLED(MBEDTLS_LIB_CRYPTO_ALT) #define MBEDTLS_SHA512_ALT #endif #if CONFIG_IS_ENABLED(SHA512_SMALLER) @@ -60,7 +60,7 @@ #define MBEDTLS_HKDF_C #endif
-#if defined CONFIG_MBEDTLS_LIB_X509 +#if CONFIG_IS_ENABLED(MBEDTLS_LIB_X509)
#if CONFIG_IS_ENABLED(X509_CERTIFICATE_PARSER) #define MBEDTLS_X509_USE_C @@ -89,9 +89,9 @@ #define MBEDTLS_ASN1_WRITE_C #endif
-#endif /* #if defined CONFIG_MBEDTLS_LIB_X509 */ +#endif /* #if CONFIG_IS_ENABLED(MBEDTLS_LIB_X509) */
-#if IS_ENABLED(CONFIG_MBEDTLS_LIB_TLS) +#if CONFIG_IS_ENABLED(MBEDTLS_LIB_TLS) #include "rtc.h"
/* Generic options */ @@ -106,25 +106,36 @@ #define MBEDTLS_ENTROPY_C #define MBEDTLS_NO_PLATFORM_ENTROPY #define MBEDTLS_SSL_PROTO_TLS1_2 +#if CONFIG_IS_ENABLED(X509_CERTIFICATE_PARSER) #define MBEDTLS_SSL_SERVER_NAME_INDICATION +#endif #define MBEDTLS_KEY_EXCHANGE_PSK_ENABLED
/* RSA */ +#if CONFIG_IS_ENABLED(X509_CERTIFICATE_PARSER) && \ + CONFIG_IS_ENABLED(RSA_PUBLIC_KEY_PARSER) #define MBEDTLS_KEY_EXCHANGE_RSA_ENABLED #define MBEDTLS_KEY_EXCHANGE_ECDHE_RSA_ENABLED #define MBEDTLS_KEY_EXCHANGE_ECDH_RSA_ENABLED +#endif #define MBEDTLS_GCM_C
/* ECDSA */ +#if CONFIG_IS_ENABLED(ASN1_DECODER) #define MBEDTLS_ECDSA_C +#define MBEDTLS_ECP_C #define MBEDTLS_ECDH_C +#endif #define MBEDTLS_ECDSA_DETERMINISTIC #define MBEDTLS_HMAC_DRBG_C -#define MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED -#define MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA_ENABLED + #define MBEDTLS_CAN_ECDH #define MBEDTLS_PK_CAN_ECDSA_SIGN -#define MBEDTLS_ECP_C +#if CONFIG_IS_ENABLED(X509_CERTIFICATE_PARSER) +#define MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA_ENABLED +#define MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED +#endif + #define MBEDTLS_ECP_DP_SECP256K1_ENABLED #define MBEDTLS_ECP_DP_SECP192R1_ENABLED #define MBEDTLS_ECP_DP_SECP224R1_ENABLED @@ -138,6 +149,6 @@ #define MBEDTLS_ECP_DP_BP384R1_ENABLED #define MBEDTLS_ECP_DP_BP512R1_ENABLED
-#endif /* #if defined CONFIG_MBEDTLS_LIB_TLS */ +#endif /* #if CONFIG_IS_ENABLED(MBEDTLS_LIB_TLS) */
-#endif /* #if defined CONFIG_MBEDTLS_LIB */ +#endif /* #if CONFIG_IS_ENABLED(MBEDTLS_LIB) */
Raymond Mao
