[PATCH v2] bdinfo: Correct use of assertions
This test was written for the incorrect use of assertions. Update it to build with the previous approach, where tests fail at the first assertion.
All assertion functions return 0 on success and non-zero on failure. They can be nested into functions simply by declaring a function that returns an int and using ut_assertok() to call it.
Changes in v2: - Expand the commit message to be clearer
test/cmd/bdinfo.c | 79 +++++++++++++++++++++++++++++------------------ 1 file changed, 49 insertions(+), 30 deletions(-)
diff --git a/test/cmd/bdinfo.c b/test/cmd/bdinfo.c index 9068df79c4f2..cddf1a46d491 100644 --- a/test/cmd/bdinfo.c +++ b/test/cmd/bdinfo.c @@ -27,19 +27,25 @@ DECLARE_GLOBAL_DATA_PTR; /* Declare a new bdinfo test */ #define BDINFO_TEST(_name, _flags) UNIT_TEST(_name, _flags, bdinfo_test)
-static void bdinfo_test_num_l(struct unit_test_state *uts, - const char *name, ulong value) +static int test_num_l(struct unit_test_state *uts, const char *name, + ulong value) { - ut_assert_nextline("%-12s= 0x%0*lx", name, 2 * (int)sizeof(value), value); + ut_assert_nextline("%-12s= 0x%0*lx", name, 2 * (int)sizeof(value), + value); + + return 0; }
-static void bdinfo_test_num_ll(struct unit_test_state *uts, - const char *name, unsigned long long value) +static int test_num_ll(struct unit_test_state *uts, const char *name, + unsigned long long value) { - ut_assert_nextline("%-12s= 0x%.*llx", name, 2 * (int)sizeof(ulong), value); + ut_assert_nextline("%-12s= 0x%.*llx", name, 2 * (int)sizeof(ulong), + value); + + return 0; }
-static void test_eth(struct unit_test_state *uts) +static int test_eth(struct unit_test_state *uts) { const int idx = eth_get_dev_index(); uchar enetaddr[6]; @@ -59,9 +65,11 @@ static void test_eth(struct unit_test_state *uts) else ut_assert_nextline("%-12s= %pM", name, enetaddr); ut_assert_nextline("IP addr = %s", env_get("ipaddr")); + + return 0; }
-static void test_video_info(struct unit_test_state *uts) +static int test_video_info(struct unit_test_state *uts) { const struct udevice *dev; struct uclass *uc; @@ -73,22 +81,25 @@ static void test_video_info(struct unit_test_state *uts) struct video_priv *upriv = dev_get_uclass_priv(dev); struct video_uc_plat *plat = dev_get_uclass_plat(dev);
- bdinfo_test_num_ll(uts, "FB base", (ulong)upriv->fb); + ut_assertok(test_num_ll(uts, "FB base", + (ulong)upriv->fb)); if (upriv->copy_fb) { - bdinfo_test_num_ll(uts, "FB copy", - (ulong)upriv->copy_fb); - bdinfo_test_num_l(uts, " copy size", - plat->copy_size); + ut_assertok(test_num_ll(uts, "FB copy", + (ulong)upriv->copy_fb)); + ut_assertok(test_num_l(uts, " copy size", + plat->copy_size)); } ut_assert_nextline("%-12s= %dx%dx%d", "FB size", upriv->xsize, upriv->ysize, 1 << upriv->bpix); } } + + return 0; }
-static void lmb_test_dump_region(struct unit_test_state *uts, - struct lmb_region *rgn, char *name) +static int lmb_test_dump_region(struct unit_test_state *uts, + struct lmb_region *rgn, char *name) { unsigned long long base, size, end; enum lmb_flags flags; @@ -105,13 +116,17 @@ static void lmb_test_dump_region(struct unit_test_state *uts, ut_assert_nextline(" %s[%d]\t[0x%llx-0x%llx], 0x%08llx bytes flags: %x", name, i, base, end, size, flags); } + + return 0; }
-static void lmb_test_dump_all(struct unit_test_state *uts, struct lmb *lmb) +static int lmb_test_dump_all(struct unit_test_state *uts, struct lmb *lmb) { ut_assert_nextline("lmb_dump_all:"); lmb_test_dump_region(uts, &lmb->memory, "memory"); lmb_test_dump_region(uts, &lmb->reserved, "reserved"); + + return 0; }
static int bdinfo_test_move(struct unit_test_state *uts) @@ -123,44 +138,48 @@ static int bdinfo_test_move(struct unit_test_state *uts) ut_assertok(console_record_reset_enable()); ut_assertok(run_commandf("bdinfo"));
- bdinfo_test_num_l(uts, "boot_params", 0); + ut_assertok(test_num_l(uts, "boot_params", 0));
for (i = 0; i < CONFIG_NR_DRAM_BANKS; ++i) { if (bd->bi_dram[i].size) { - bdinfo_test_num_l(uts, "DRAM bank", i); - bdinfo_test_num_ll(uts, "-> start", bd->bi_dram[i].start); - bdinfo_test_num_ll(uts, "-> size", bd->bi_dram[i].size); + ut_assertok(test_num_l(uts, "DRAM bank", i)); + ut_assertok(test_num_ll(uts, "-> start", + bd->bi_dram[i].start)); + ut_assertok(test_num_ll(uts, "-> size", + bd->bi_dram[i].size)); } }
/* CONFIG_SYS_HAS_SRAM testing not supported */ - bdinfo_test_num_l(uts, "flashstart", 0); - bdinfo_test_num_l(uts, "flashsize", 0); - bdinfo_test_num_l(uts, "flashoffset", 0); + ut_assertok(test_num_l(uts, "flashstart", 0)); + ut_assertok(test_num_l(uts, "flashsize", 0)); + ut_assertok(test_num_l(uts, "flashoffset", 0)); ut_assert_nextline("baudrate = %lu bps", env_get_ulong("baudrate", 10, 1234)); - bdinfo_test_num_l(uts, "relocaddr", gd->relocaddr); - bdinfo_test_num_l(uts, "reloc off", gd->reloc_off); + ut_assertok(test_num_l(uts, "relocaddr", gd->relocaddr)); + ut_assertok(test_num_l(uts, "reloc off", gd->reloc_off)); ut_assert_nextline("%-12s= %u-bit", "Build", (uint)sizeof(void *) * 8);
if (IS_ENABLED(CONFIG_CMD_NET)) - test_eth(uts); + ut_assertok(test_eth(uts));
/* * Make sure environment variable "fdtcontroladdr" address * matches mapped control DT address. */ ut_assert(map_to_sysmem(gd->fdt_blob) == env_get_hex("fdtcontroladdr", 0x1234)); - bdinfo_test_num_l(uts, "fdt_blob", (ulong)map_to_sysmem(gd->fdt_blob)); - bdinfo_test_num_l(uts, "new_fdt", (ulong)map_to_sysmem(gd->new_fdt)); - bdinfo_test_num_l(uts, "fdt_size", (ulong)gd->fdt_size); + ut_assertok(test_num_l(uts, "fdt_blob", + (ulong)map_to_sysmem(gd->fdt_blob))); + ut_assertok(test_num_l(uts, "new_fdt", + (ulong)map_to_sysmem(gd->new_fdt))); + ut_assertok(test_num_l(uts, "fdt_size", (ulong)gd->fdt_size));
if (IS_ENABLED(CONFIG_VIDEO)) test_video_info(uts);
/* The gd->multi_dtb_fit may not be available, hence, #if below. */ #if CONFIG_IS_ENABLED(MULTI_DTB_FIT) - bdinfo_test_num_l(uts, "multi_dtb_fit", (ulong)gd->multi_dtb_fit); + ut_assertok(test_num_l(uts, "multi_dtb_fit", (ulong)gd->multi_dtb_fit)); #endif
if (IS_ENABLED(CONFIG_LMB) && gd->fdt_blob) {
Thanks
