[U-Boot] Pull request: u-boot-spi/master-xlnx
Hi Tom,
Sending this PR for more zynq board support - waited since long time.
-- Thanks, Jagan.
The following changes since commit 39859fc42750c6a82f5c9484ddf4c0992be97c36:
sandbox: spi: Adjust 'sf test' to work on sandbox (2013-12-21 11:46:45 +0530)
git://git.denx.de/u-boot-spi.git master-xlnx
for you to fetch changes up to 19992190ebd7fe2df9e0720961e2c67f3eea4b0a:
doc: Update the zynq u-boot status (2013-12-21 12:07:09 +0530)
---------------------------------------------------------------- Jagannadha Sutradharudu Teki (29): zynq: Enable CONFIG_FIT_VERBOSE zynq: Enable Boot FreeBSD/vxWorks zynq: Cleanup on miscellaneous configs zynq: Cleanup on memory configs zynq: Minor config cleanup zynq: Enable cache options zynq: Add UART0, UART1 configs support zynq: Add GEM0, GEM1 configs support zynq-common: Rename zynq with zynq-common doc: zynq: Add information on zynq u-boot zynq: Add zynq zc70x board support zynq: Add zynq zed board support zynq: Move CONFIG_SYS_SDRAM_SIZE to pre-board configs zynq-common: Define exact TEXT_BASE zynq: zc70x: Add Catalyst 24WC08 EEPROM config support zynq: Add zynq microzed board support zynq: Add zynq_zc770 xm010 board support zynq: Add zynq_zc770 xm013 board support zynq: Add zynq_zc770 xm012 board support zynq: Add support to find bootmode zynq-common: Define default environment zynq-common: Change Env. Sector size to 128Kb zynq-common: Define flash env. partition zynq-common: Define CONFIG_ENV_OVERWRITE dts: zynq: Add basic fdt support gpio: zynq: Add dummy gpio routines zynq-common: Enable verified boot(RSA) dts: zynq: Add more zynq dts files doc: Update the zynq u-boot status
arch/arm/cpu/armv7/zynq/slcr.c | 6 + arch/arm/dts/zynq-7000.dtsi | 13 ++ arch/arm/include/asm/arch-zynq/gpio.h | 25 +++ arch/arm/include/asm/arch-zynq/sys_proto.h | 1 + board/xilinx/dts/zynq-microzed.dts | 14 ++ board/xilinx/dts/zynq-zc702.dts | 14 ++ board/xilinx/dts/zynq-zc706.dts | 14 ++ board/xilinx/dts/zynq-zc770-xm010.dts | 14 ++ board/xilinx/dts/zynq-zc770-xm012.dts | 14 ++ board/xilinx/dts/zynq-zc770-xm013.dts | 14 ++ board/xilinx/dts/zynq-zed.dts | 14 ++ board/xilinx/zynq/board.c | 25 +++ boards.cfg | 8 +- doc/README.zynq | 91 +++++++++++ include/configs/zynq-common.h | 238 +++++++++++++++++++++++++++++ include/configs/zynq.h | 139 ----------------- include/configs/zynq_microzed.h | 25 +++ include/configs/zynq_zc70x.h | 28 ++++ include/configs/zynq_zc770.h | 39 +++++ include/configs/zynq_zed.h | 26 ++++ 20 files changed, 621 insertions(+), 141 deletions(-) create mode 100644 arch/arm/dts/zynq-7000.dtsi create mode 100644 arch/arm/include/asm/arch-zynq/gpio.h create mode 100644 board/xilinx/dts/zynq-microzed.dts create mode 100644 board/xilinx/dts/zynq-zc702.dts create mode 100644 board/xilinx/dts/zynq-zc706.dts create mode 100644 board/xilinx/dts/zynq-zc770-xm010.dts create mode 100644 board/xilinx/dts/zynq-zc770-xm012.dts create mode 100644 board/xilinx/dts/zynq-zc770-xm013.dts create mode 100644 board/xilinx/dts/zynq-zed.dts create mode 100644 doc/README.zynq create mode 100644 include/configs/zynq-common.h delete mode 100644 include/configs/zynq.h create mode 100644 include/configs/zynq_microzed.h create mode 100644 include/configs/zynq_zc70x.h create mode 100644 include/configs/zynq_zc770.h create mode 100644 include/configs/zynq_zed.h
Hi Tom/Albert,
On Sat, Jan 4, 2014 at 8:23 PM, Jagannadha Sutradharudu Teki jagannadha.sutradharudu-teki@xilinx.com wrote:
Hi Tom,
-- Thanks, Jagan.
Can anyone pull this PR?
Jagan Teki
