[PATCH] power: zynqmp: Use zynqmp_pmufw_node() from firmware
Remove private xpm_configobject[] and use zynqmp_pmufw_node() which provides the same functionality. Also add debug messages for easier debugging.
Fixes: e0283cbdfd49 ("power: zynqmp: Add power domain driver for ZynqMP") Signed-off-by: Michal Simek michal.simek@xilinx.com ---
drivers/power/domain/zynqmp-power-domain.c | 29 ++++------------------ 1 file changed, 5 insertions(+), 24 deletions(-)
diff --git a/drivers/power/domain/zynqmp-power-domain.c b/drivers/power/domain/zynqmp-power-domain.c index 5383d0989698..6943658be429 100644 --- a/drivers/power/domain/zynqmp-power-domain.c +++ b/drivers/power/domain/zynqmp-power-domain.c @@ -5,6 +5,7 @@
#include <common.h> #include <dm.h> +#include <dm/device_compat.h> #include <log.h> #include <malloc.h> #include <misc.h> @@ -13,25 +14,6 @@
#include <zynqmp_firmware.h>
-#define NODE_ID_LOCATION 5 - -static unsigned int xpm_configobject[] = { - /* HEADER */ - 2, /* Number of remaining words in the header */ - 1, /* Number of sections included in config object */ - PM_CONFIG_OBJECT_TYPE_OVERLAY, /* Type of Config object as overlay */ - /* SLAVE SECTION */ - - PM_CONFIG_SLAVE_SECTION_ID, /* Section ID */ - 1, /* Number of slaves */ - - 0, /* Node ID which will be changed below */ - PM_SLAVE_FLAG_IS_SHAREABLE, - PM_CONFIG_IPI_PSU_CORTEXA53_0_MASK | - PM_CONFIG_IPI_PSU_CORTEXR5_0_MASK | - PM_CONFIG_IPI_PSU_CORTEXR5_1_MASK, /* IPI Mask */ -}; - static int zynqmp_pm_request_node(const u32 node, const u32 capabilities, const u32 qos, const enum zynqmp_pm_request_ack ack) { @@ -41,12 +23,9 @@ static int zynqmp_pm_request_node(const u32 node, const u32 capabilities,
static int zynqmp_power_domain_request(struct power_domain *power_domain) { - /* Record power domain id */ - xpm_configobject[NODE_ID_LOCATION] = power_domain->id; - - zynqmp_pmufw_load_config_object(xpm_configobject, sizeof(xpm_configobject)); + dev_dbg(power_domain->dev, "Request for id: %ld\n", power_domain->id);
- return 0; + return zynqmp_pmufw_node(power_domain->id); }
static int zynqmp_power_domain_free(struct power_domain *power_domain) @@ -57,6 +36,8 @@ static int zynqmp_power_domain_free(struct power_domain *power_domain)
static int zynqmp_power_domain_on(struct power_domain *power_domain) { + dev_dbg(power_domain->dev, "Domain ON for id: %ld\n", power_domain->id); + return zynqmp_pm_request_node(power_domain->id, ZYNQMP_PM_CAPABILITY_ACCESS, ZYNQMP_PM_MAX_QOS,
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
- /* HEADER */
- dev_dbg(power_domain->dev, "Request for id: %ld\n", power_domain->id);
- return zynqmp_pmufw_node(power_domain->id);
- dev_dbg(power_domain->dev, "Domain ON for id: %ld\n", power_domain->id);
- return zynqmp_pm_request_node(power_domain->id, ZYNQMP_PM_CAPABILITY_ACCESS, ZYNQMP_PM_MAX_QOS,
Ășt 1. 3. 2022 v 9:11 odesĂlatel Michal Simek michal.simek@xilinx.com napsal:
/* HEADER */
/* SLAVE SECTION */
-- 2.35.1
Applied. M
Jaehoon Chung
Michal Simek
Michal Simek
