[U-Boot] [PATCH 1/2] gunzip: add gzwrite routine for extracting compresed images to block device
Initial filesystem images are generally highly compressible.
Add a routine gzwrite that allows gzip-compressed images to be written to block devices.
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com --- include/common.h | 39 +++++++++++ lib/gunzip.c | 194 ++++++++++++++++++++++++++++++++++++++++++++++++++++++- 2 files changed, 232 insertions(+), 1 deletion(-)
diff --git a/include/common.h b/include/common.h index 9129454..f96baea 100644 --- a/include/common.h +++ b/include/common.h @@ -713,6 +713,45 @@ int gunzip(void *, int, unsigned char *, unsigned long *); int zunzip(void *dst, int dstlen, unsigned char *src, unsigned long *lenp, int stoponerr, int offset);
+/** + * gzwrite progress indicators: defined weak to allow board-specific + * overrides: + * + * gzwrite_progress_init called on startup + * gzwrite_progress called during decompress/write loop + * gzwrite_progress_finish called at end of loop to + * indicate success (retcode=0) or failure + */ +void gzwrite_progress_init(u64 expected_size); + +void gzwrite_progress(int iteration, + u64 bytes_written, + u64 total_bytes); + +void gzwrite_progress_finish(int retcode, + u64 totalwritten, + u64 totalsize, + u32 expected_crc, + u32 calculated_crc); + +/** + * decompress and write gzipped image from memory to block device + * + * @param src compressed image address + * @param len compressed image length in bytes + * @param dev block device descriptor + * @param szwritebuf bytes per write (pad to erase size) + * @param startoffs offset in bytes of first write + * @param szexpected expected uncompressed length + * may be zero to use gzip trailer + * for files under 4GiB + */ +int gzwrite(unsigned char *src, int len, + struct block_dev_desc *dev, + unsigned long szwritebuf, + u64 startoffs, + u64 szexpected); + /* lib/qsort.c */ void qsort(void *base, size_t nmemb, size_t size, int(*compar)(const void *, const void *)); diff --git a/lib/gunzip.c b/lib/gunzip.c index f469fcb..d28fda8 100644 --- a/lib/gunzip.c +++ b/lib/gunzip.c @@ -12,6 +12,8 @@ #include <malloc.h> #include <u-boot/zlib.h>
+#define HEADER0 '\x1f' +#define HEADER1 '\x8b' #define ZALLOC_ALIGNMENT 16 #define HEAD_CRC 2 #define EXTRA_FIELD 4 @@ -66,6 +68,196 @@ int gunzip(void *dst, int dstlen, unsigned char *src, unsigned long *lenp) return zunzip(dst, dstlen, src, lenp, 1, i); }
+__weak +void gzwrite_progress_init(u64 expectedsize) +{ + putc('\n'); +} + +__weak +void gzwrite_progress(int iteration, + u64 bytes_written, + u64 total_bytes) +{ + if (0 == (iteration & 3)) + printf("%llu/%llu\r", bytes_written, total_bytes); +} + +__weak +void gzwrite_progress_finish(int returnval, + u64 bytes_written, + u64 total_bytes, + u32 expected_crc, + u32 calculated_crc) +{ + if (0 == returnval) { + printf("\n\t%llu bytes, crc 0x%08x\n", + total_bytes, calculated_crc); + } else { + printf("\n\tuncompressed %llu of %llu\n" + "\tcrcs == 0x%08x/0x%08x\n", + bytes_written, total_bytes, + expected_crc, calculated_crc); + } +} + +int gzwrite(unsigned char *src, int len, + struct block_dev_desc *dev, + unsigned long szwritebuf, + u64 startoffs, + u64 szexpected) +{ + int i, flags; + z_stream s; + int r = 0; + unsigned char *writebuf; + unsigned crc = 0; + u64 totalfilled = 0; + lbaint_t blksperbuf, outblock; + u32 expected_crc; + u32 payload_size; + int iteration = 0; + + if (!szwritebuf || + (szwritebuf % dev->blksz) || + (szwritebuf < dev->blksz)) { + printf("%s: size %lu not a multiple of %lu\n", + __func__, szwritebuf, dev->blksz); + return -1; + } + + if (startoffs % dev->blksz) { + printf("%s: start offset %llu not a multiple of %lu\n", + __func__, startoffs, dev->blksz); + return -1; + } + + blksperbuf = szwritebuf / dev->blksz; + outblock = startoffs / dev->blksz; + + /* skip header */ + i = 10; + flags = src[3]; + if (src[2] != DEFLATED || (flags & RESERVED) != 0) { + puts("Error: Bad gzipped data\n"); + return -1; + } + if ((flags & EXTRA_FIELD) != 0) + i = 12 + src[10] + (src[11] << 8); + if ((flags & ORIG_NAME) != 0) + while (src[i++] != 0) + ; + if ((flags & COMMENT) != 0) + while (src[i++] != 0) + ; + if ((flags & HEAD_CRC) != 0) + i += 2; + + if (i >= len-8) { + puts("Error: gunzip out of data in header"); + return -1; + } + + payload_size = len - i - 8; + + memcpy(&expected_crc, src + len - 8, sizeof(expected_crc)); + expected_crc = le32_to_cpu(expected_crc); + u32 szuncompressed; + memcpy(&szuncompressed, src + len - 4, sizeof(szuncompressed)); + if (szexpected == 0) { + szexpected = le32_to_cpu(szuncompressed); + } else if (szuncompressed != (u32)szexpected) { + printf("size of %llx doesn't match trailer low bits %x\n", + szexpected, szuncompressed); + return -1; + } + if (szexpected / dev->blksz > (dev->lba - outblock)) { + printf("%s: uncompressed size %llu exceeds device size\n", + __func__, szexpected); + return -1; + } + + gzwrite_progress_init(szexpected); + + s.zalloc = gzalloc; + s.zfree = gzfree; + + r = inflateInit2(&s, -MAX_WBITS); + if (r != Z_OK) { + printf("Error: inflateInit2() returned %d\n", r); + return -1; + } + + s.next_in = src + i; + s.avail_in = payload_size+8; + writebuf = (unsigned char *)malloc(szwritebuf); + + /* decompress until deflate stream ends or end of file */ + do { + if (s.avail_in == 0) { + printf("%s: weird termination with result %d\n", + __func__, r); + break; + } + + /* run inflate() on input until output buffer not full */ + do { + unsigned long blocks_written; + int numfilled; + lbaint_t writeblocks; + + s.avail_out = szwritebuf; + s.next_out = writebuf; + r = inflate(&s, Z_SYNC_FLUSH); + if ((r != Z_OK) && + (r != Z_STREAM_END)) { + printf("Error: inflate() returned %d\n", r); + goto out; + } + numfilled = szwritebuf - s.avail_out; + crc = crc32(crc, writebuf, numfilled); + totalfilled += numfilled; + if (numfilled < szwritebuf) { + writeblocks = (numfilled+dev->blksz-1) + / dev->blksz; + memset(writebuf+numfilled, 0, + dev->blksz-(numfilled%dev->blksz)); + } else { + writeblocks = blksperbuf; + } + + gzwrite_progress(iteration++, + totalfilled, + szexpected); + blocks_written = dev->block_write(dev->dev, + outblock, + writeblocks, + writebuf); + outblock += blocks_written; + if (ctrlc()) { + puts("abort\n"); + goto out; + } + WATCHDOG_RESET(); + } while (s.avail_out == 0); + /* done when inflate() says it's done */ + } while (r != Z_STREAM_END); + + if ((szexpected != totalfilled) || + (crc != expected_crc)) + r = -1; + else + r = 0; + +out: + gzwrite_progress_finish(r, totalfilled, szexpected, + expected_crc, crc); + free(writebuf); + inflateEnd(&s); + + return r; +} + /* * Uncompress blocks compressed with zlib without headers */ @@ -81,7 +273,7 @@ int zunzip(void *dst, int dstlen, unsigned char *src, unsigned long *lenp,
r = inflateInit2(&s, -MAX_WBITS); if (r != Z_OK) { - printf ("Error: inflateInit2() returned %d\n", r); + printf("Error: inflateInit2() returned %d\n", r); return -1; } s.next_in = src + offset;
Add gzwrite command to write gzip-compressed images to block devices.
Input must be gzip-compressed according to RFC1952, since the crc and file size in the trailer will be confirmed during operation. The decompressed file size must be specified on the command line for images with decompressed sizes >= 4GiB because the trailer only contains the low 32 bits of the original file size.
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com --- common/cmd_unzip.c | 47 +++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 47 insertions(+)
diff --git a/common/cmd_unzip.c b/common/cmd_unzip.c index b02c69e..0686be6 100644 --- a/common/cmd_unzip.c +++ b/common/cmd_unzip.c @@ -39,3 +39,50 @@ U_BOOT_CMD( "unzip a memory region", "srcaddr dstaddr [dstsize]" ); + +static int do_gzwrite(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + block_dev_desc_t *bdev; + int ret; + unsigned char *addr; + unsigned long length; + unsigned long writebuf = 1<<20; + u64 startoffs = 0; + u64 szexpected = 0; + + if (argc < 5) + return CMD_RET_USAGE; + ret = get_device(argv[1], argv[2], &bdev); + if (ret < 0) + return CMD_RET_FAILURE; + + addr = (unsigned char *)simple_strtoul(argv[3], NULL, 16); + length = simple_strtoul(argv[4], NULL, 16); + + if (5 < argc) { + writebuf = simple_strtoul(argv[5], NULL, 16); + if (6 < argc) { + startoffs = simple_strtoull(argv[6], NULL, 16); + if (7 < argc) + szexpected = simple_strtoull(argv[7], + NULL, 16); + } + } + + ret = gzwrite(addr, length, bdev, writebuf, startoffs, szexpected); + + return ret ? CMD_RET_FAILURE : CMD_RET_SUCCESS; +} + +U_BOOT_CMD( + gzwrite, 8, 0, do_gzwrite, + "unzip and write memory to block device", + "<interface> <dev> <addr> length [wbuf=1M [offs=0 [outsize=0]]]\n" + "\twbuf is the size in bytes (hex) of write buffer\n" + "\t\tand should be padded to erase size for SSDs\n" + "\toffs is the output start offset in bytes (hex)\n" + "\toutsize is the size of the expected output (hex bytes)\n" + "\t\tand is required for files with uncompressed lengths\n" + "\t\t4 GiB or larger\n" +);
Hi!
Stupid question -- can't you compress the thing in DRAM and then use fatwrite or ext4write to write it to FS? Or are you really after writing the data to a raw block device (in which case, you can use similar commands for raw block devices) ?
Best regards, Marek Vasut
Hi!
I _think_ (and I really hope so otherwise yes, this series needs more expanation) that was this adds is the ability to {de,}compress on the fly rather than need to duplicate in DDR which could be hard-to-impossible depending on the size of the data in question.
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
Hi Tom and Marek,
Hi!
(or explanation ;))
Sometimes words fail. I thought that was clear from the commit message but apparently not.
That's exactly right.
The purpose of this is to aid in loading images onto storage devices like eMMC where the storage size usually exceeds the size of RAM, but the compressed image size doesn't.
Even if the compressed image size does exceed RAM, the gzwrite routine and command give you the ability to do things piecewise, and save lots of read transfer time.
To give a quick concrete example, we were looking at programming a relatively small (100's) batch of boards that use a very light O/S, but have 4GiB of eMMC.
Using ums takes over 25 minutes per board, but loading board.img.gz and using gzwrite takes 5-6, which is pretty close to optimal given the speed of the eMMC chip.
My hope is that this is useful as is, and also that the gzwrite routine can be worked into the fastboot protocol.
Transferring gigabytes of data is slow over USB 2.0 and storage sizes keep getting bigger.
Regards,
Eric
On Monday, February 16, 2015 at 06:33:35 PM, Eric Nelson wrote:
Hi Tom and Marek,
Hi!
(or explanation ;))
Cool, thanks for explaining :)
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com --- V2 removes floating point references from u64 division include/common.h | 39 +++++++++++ lib/gunzip.c | 195 ++++++++++++++++++++++++++++++++++++++++++++++++++++++- 2 files changed, 233 insertions(+), 1 deletion(-)
+/** + * gzwrite progress indicators: defined weak to allow board-specific + * overrides: + * + * gzwrite_progress_init called on startup + * gzwrite_progress called during decompress/write loop + * gzwrite_progress_finish called at end of loop to + * indicate success (retcode=0) or failure + */ +void gzwrite_progress_init(u64 expected_size); + +void gzwrite_progress(int iteration, + u64 bytes_written, + u64 total_bytes); + +void gzwrite_progress_finish(int retcode, + u64 totalwritten, + u64 totalsize, + u32 expected_crc, + u32 calculated_crc); + +/** + * decompress and write gzipped image from memory to block device + * + * @param src compressed image address + * @param len compressed image length in bytes + * @param dev block device descriptor + * @param szwritebuf bytes per write (pad to erase size) + * @param startoffs offset in bytes of first write + * @param szexpected expected uncompressed length + * may be zero to use gzip trailer + * for files under 4GiB + */ +int gzwrite(unsigned char *src, int len, + struct block_dev_desc *dev, + unsigned long szwritebuf, + u64 startoffs, + u64 szexpected); + /* lib/qsort.c */ void qsort(void *base, size_t nmemb, size_t size, int(*compar)(const void *, const void *)); diff --git a/lib/gunzip.c b/lib/gunzip.c index f469fcb..4128a18 100644 --- a/lib/gunzip.c +++ b/lib/gunzip.c @@ -11,7 +11,10 @@ #include <image.h> #include <malloc.h> #include <u-boot/zlib.h> +#include <div64.h>
+#define HEADER0 '\x1f' +#define HEADER1 '\x8b' #define ZALLOC_ALIGNMENT 16 #define HEAD_CRC 2 #define EXTRA_FIELD 4 @@ -66,6 +69,196 @@ int gunzip(void *dst, int dstlen, unsigned char *src, unsigned long *lenp) return zunzip(dst, dstlen, src, lenp, 1, i); }
+__weak +void gzwrite_progress_init(u64 expectedsize) +{ + putc('\n'); +} + +__weak +void gzwrite_progress(int iteration, + u64 bytes_written, + u64 total_bytes) +{ + if (0 == (iteration & 3)) + printf("%llu/%llu\r", bytes_written, total_bytes); +} + +__weak +void gzwrite_progress_finish(int returnval, + u64 bytes_written, + u64 total_bytes, + u32 expected_crc, + u32 calculated_crc) +{ + if (0 == returnval) { + printf("\n\t%llu bytes, crc 0x%08x\n", + total_bytes, calculated_crc); + } else { + printf("\n\tuncompressed %llu of %llu\n" + "\tcrcs == 0x%08x/0x%08x\n", + bytes_written, total_bytes, + expected_crc, calculated_crc); + } +} + +int gzwrite(unsigned char *src, int len, + struct block_dev_desc *dev, + unsigned long szwritebuf, + u64 startoffs, + u64 szexpected) +{ + int i, flags; + z_stream s; + int r = 0; + unsigned char *writebuf; + unsigned crc = 0; + u64 totalfilled = 0; + lbaint_t blksperbuf, outblock; + u32 expected_crc; + u32 payload_size; + int iteration = 0; + + if (!szwritebuf || + (szwritebuf % dev->blksz) || + (szwritebuf < dev->blksz)) { + printf("%s: size %lu not a multiple of %lu\n", + __func__, szwritebuf, dev->blksz); + return -1; + } + + if (startoffs & (dev->blksz-1)) { + printf("%s: start offset %llu not a multiple of %lu\n", + __func__, startoffs, dev->blksz); + return -1; + } + + blksperbuf = szwritebuf / dev->blksz; + outblock = lldiv(startoffs, dev->blksz); + + /* skip header */ + i = 10; + flags = src[3]; + if (src[2] != DEFLATED || (flags & RESERVED) != 0) { + puts("Error: Bad gzipped data\n"); + return -1; + } + if ((flags & EXTRA_FIELD) != 0) + i = 12 + src[10] + (src[11] << 8); + if ((flags & ORIG_NAME) != 0) + while (src[i++] != 0) + ; + if ((flags & COMMENT) != 0) + while (src[i++] != 0) + ; + if ((flags & HEAD_CRC) != 0) + i += 2; + + if (i >= len-8) { + puts("Error: gunzip out of data in header"); + return -1; + } + + payload_size = len - i - 8; + + memcpy(&expected_crc, src + len - 8, sizeof(expected_crc)); + expected_crc = le32_to_cpu(expected_crc); + u32 szuncompressed; + memcpy(&szuncompressed, src + len - 4, sizeof(szuncompressed)); + if (szexpected == 0) { + szexpected = le32_to_cpu(szuncompressed); + } else if (szuncompressed != (u32)szexpected) { + printf("size of %llx doesn't match trailer low bits %x\n", + szexpected, szuncompressed); + return -1; + } + if (lldiv(szexpected, dev->blksz) > (dev->lba - outblock)) { + printf("%s: uncompressed size %llu exceeds device size\n", + __func__, szexpected); + return -1; + } + + gzwrite_progress_init(szexpected); + + s.zalloc = gzalloc; + s.zfree = gzfree; + + r = inflateInit2(&s, -MAX_WBITS); + if (r != Z_OK) { + printf("Error: inflateInit2() returned %d\n", r); + return -1; + } + + s.next_in = src + i; + s.avail_in = payload_size+8; + writebuf = (unsigned char *)malloc(szwritebuf); + + /* decompress until deflate stream ends or end of file */ + do { + if (s.avail_in == 0) { + printf("%s: weird termination with result %d\n", + __func__, r); + break; + } + + /* run inflate() on input until output buffer not full */ + do { + unsigned long blocks_written; + int numfilled; + lbaint_t writeblocks; + + s.avail_out = szwritebuf; + s.next_out = writebuf; + r = inflate(&s, Z_SYNC_FLUSH); + if ((r != Z_OK) && + (r != Z_STREAM_END)) { + printf("Error: inflate() returned %d\n", r); + goto out; + } + numfilled = szwritebuf - s.avail_out; + crc = crc32(crc, writebuf, numfilled); + totalfilled += numfilled; + if (numfilled < szwritebuf) { + writeblocks = (numfilled+dev->blksz-1) + / dev->blksz; + memset(writebuf+numfilled, 0, + dev->blksz-(numfilled%dev->blksz)); + } else { + writeblocks = blksperbuf; + } + + gzwrite_progress(iteration++, + totalfilled, + szexpected); + blocks_written = dev->block_write(dev->dev, + outblock, + writeblocks, + writebuf); + outblock += blocks_written; + if (ctrlc()) { + puts("abort\n"); + goto out; + } + WATCHDOG_RESET(); + } while (s.avail_out == 0); + /* done when inflate() says it's done */ + } while (r != Z_STREAM_END); + + if ((szexpected != totalfilled) || + (crc != expected_crc)) + r = -1; + else + r = 0; + +out: + gzwrite_progress_finish(r, totalfilled, szexpected, + expected_crc, crc); + free(writebuf); + inflateEnd(&s); + + return r; +} + /* * Uncompress blocks compressed with zlib without headers */ @@ -81,7 +274,7 @@ int zunzip(void *dst, int dstlen, unsigned char *src, unsigned long *lenp,
Hi all,
Ping.
Is this falling through the cracks because there's no maintainer for 'gunzip'?
Please advise,
Eric
Seems fine so: Reviewed-by: Tom Rini trini@ti.com
Missed the merge window so I'll pick this up in a long while or do a next again, not sure.
Thanks Tom,
No worries about the timing here. I was just hoping to get an ack before using this syntax and such for downstream things.
And before looking at how it could be glued to fastboot!
Regards,
Eric
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com Reviewed-by: Tom Rini trini@ti.com
Eric Nelson
