[U-Boot] [PATCH 0/4] mx35, flea3: updates for the imx35 based flea3 board
post some small updates for the imx35 based flea3 board - add DT support - factorize SDRAM setup - add GPIO setup - adjust default environment
Heiko Schocher (2): mx35: add DT support to flea3 board mx35: adjust default environment for flea3 board
Stefano Babic (2): mx35: factorize SDRAM setup in flea3 mx35: add GPIO setup on flea3 board
board/CarMediaLab/flea3/flea3.c | 124 +++++++++++----------------------------- configs/flea3_defconfig | 4 ++ include/configs/flea3.h | 9 ++- 3 files changed, 42 insertions(+), 95 deletions(-)
Signed-off-by: Heiko Schocher hs@denx.de ---
board/CarMediaLab/flea3/flea3.c | 24 ++++++++++++++++++++++++ configs/flea3_defconfig | 4 ++++ 2 files changed, 28 insertions(+)
diff --git a/board/CarMediaLab/flea3/flea3.c b/board/CarMediaLab/flea3/flea3.c index 2463077..be42863 100644 --- a/board/CarMediaLab/flea3/flea3.c +++ b/board/CarMediaLab/flea3/flea3.c @@ -19,6 +19,9 @@ #include <asm/gpio.h> #include <asm/arch/sys_proto.h> #include <netdev.h> +#include <fdt_support.h> +#include <mtd_node.h> +#include <jffs2/load_kernel.h>
#ifndef CONFIG_BOARD_EARLY_INIT_F #error "CONFIG_BOARD_EARLY_INIT_F must be set for this board" @@ -276,3 +279,24 @@ u32 get_board_rev(void)
return (get_cpu_rev() & ~(0xF << 8)) | (rev & 0xF) << 8; } + +/* + * called prior to booting kernel or by 'fdt boardsetup' command + * + */ +int ft_board_setup(void *blob, bd_t *bd) +{ + struct node_info nodes[] = { + { "physmap-flash.0", MTD_DEV_TYPE_NOR, }, /* NOR flash */ + { "mxc_nand", MTD_DEV_TYPE_NAND, }, /* NAND flash */ + }; + + if (getenv("fdt_noauto")) { + puts(" Skiping ft_board_setup (fdt_noauto defined)\n"); + return 0; + } + + fdt_fixup_mtdparts(blob, nodes, ARRAY_SIZE(nodes)); + + return 0; +} diff --git a/configs/flea3_defconfig b/configs/flea3_defconfig index 7aa1ba8..c5ccbd6 100644 --- a/configs/flea3_defconfig +++ b/configs/flea3_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_FLEA3=y CONFIG_FIT=y +CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y @@ -12,3 +13,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +CONFIG_OF_LIBFDT=y +CONFIG_FDT_FIXUP_PARTITIONS=y +# CONFIG_EFI_LOADER is not set
Drop local function to setup SDRAM controller and use the common one for i.MX35.
Signed-off-by: Stefano Babic sbabic@denx.de Signed-off-by: Heiko Schocher hs@denx.de ---
board/CarMediaLab/flea3/flea3.c | 93 ++--------------------------------------- 1 file changed, 3 insertions(+), 90 deletions(-)
diff --git a/board/CarMediaLab/flea3/flea3.c b/board/CarMediaLab/flea3/flea3.c index be42863..ca3e44b 100644 --- a/board/CarMediaLab/flea3/flea3.c +++ b/board/CarMediaLab/flea3/flea3.c @@ -30,18 +30,6 @@ #define CCM_CCMR_CONFIG 0x003F4208
#define ESDCTL_DDR2_CONFIG 0x007FFC3F -#define ESDCTL_0x92220000 0x92220000 -#define ESDCTL_0xA2220000 0xA2220000 -#define ESDCTL_0xB2220000 0xB2220000 -#define ESDCTL_0x82228080 0x82228080 -#define ESDCTL_DDR2_EMR2 0x04000000 -#define ESDCTL_DDR2_EMR3 0x06000000 -#define ESDCTL_PRECHARGE 0x00000400 -#define ESDCTL_DDR2_EN_DLL 0x02000400 -#define ESDCTL_DDR2_RESET_DLL 0x00000333 -#define ESDCTL_DDR2_MR 0x00000233 -#define ESDCTL_DDR2_OCD_DEFAULT 0x02000780 -#define ESDCTL_DELAY_LINE5 0x00F49F00
static inline void dram_wait(unsigned int count) { @@ -61,83 +49,6 @@ int dram_init(void) return 0; }
-static void board_setup_sdram_bank(u32 start_address) - -{ - struct esdc_regs *esdc = (struct esdc_regs *)ESDCTL_BASE_ADDR; - u32 *cfg_reg, *ctl_reg; - u32 val; - - switch (start_address) { - case CSD0_BASE_ADDR: - cfg_reg = &esdc->esdcfg0; - ctl_reg = &esdc->esdctl0; - break; - case CSD1_BASE_ADDR: - cfg_reg = &esdc->esdcfg1; - ctl_reg = &esdc->esdctl1; - break; - default: - return; - } - - /* Initialize MISC register for DDR2 */ - val = ESDC_MISC_RST | ESDC_MISC_MDDR_EN | ESDC_MISC_MDDR_DL_RST | - ESDC_MISC_DDR_EN | ESDC_MISC_DDR2_EN; - writel(val, &esdc->esdmisc); - val &= ~(ESDC_MISC_RST | ESDC_MISC_MDDR_DL_RST); - writel(val, &esdc->esdmisc); - - /* - * according to DDR2 specs, wait a while before - * the PRECHARGE_ALL command - */ - dram_wait(0x20000); - - /* Load DDR2 config and timing */ - writel(ESDCTL_DDR2_CONFIG, cfg_reg); - - /* Precharge ALL */ - writel(ESDCTL_0x92220000, - ctl_reg); - writel(0xda, start_address + ESDCTL_PRECHARGE); - - /* Load mode */ - writel(ESDCTL_0xB2220000, - ctl_reg); - writeb(0xda, start_address + ESDCTL_DDR2_EMR2); /* EMRS2 */ - writeb(0xda, start_address + ESDCTL_DDR2_EMR3); /* EMRS3 */ - writeb(0xda, start_address + ESDCTL_DDR2_EN_DLL); /* Enable DLL */ - writeb(0xda, start_address + ESDCTL_DDR2_RESET_DLL); /* Reset DLL */ - - /* Precharge ALL */ - writel(ESDCTL_0x92220000, - ctl_reg); - writel(0xda, start_address + ESDCTL_PRECHARGE); - - /* Set mode auto refresh : at least two refresh are required */ - writel(ESDCTL_0xA2220000, - ctl_reg); - writel(0xda, start_address); - writel(0xda, start_address); - - writel(ESDCTL_0xB2220000, - ctl_reg); - writeb(0xda, start_address + ESDCTL_DDR2_MR); - writeb(0xda, start_address + ESDCTL_DDR2_OCD_DEFAULT); - - /* OCD mode exit */ - writeb(0xda, start_address + ESDCTL_DDR2_EN_DLL); /* Enable DLL */ - - /* Set normal mode */ - writel(ESDCTL_0x82228080, - ctl_reg); - - dram_wait(0x20000); - - /* Do not set delay lines, only for MDDR */ -} - static void board_setup_sdram(void) { struct esdc_regs *esdc = (struct esdc_regs *)ESDCTL_BASE_ADDR; @@ -146,7 +57,9 @@ static void board_setup_sdram(void) writel(0x2000, &esdc->esdctl0); writel(0x2000, &esdc->esdctl1);
- board_setup_sdram_bank(CSD0_BASE_ADDR); + + mx3_setup_sdram_bank(CSD0_BASE_ADDR, ESDCTL_DDR2_CONFIG, + 13, 10, 2, 0x8080); }
static void setup_iomux_uart3(void)
Hardware revision "e" of the board introduces a GPIO to reduce power consumption in stand-by mode. This must be enable (active low) at the startup for normal behaviour.
board/CarMediaLab/flea3/flea3.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/board/CarMediaLab/flea3/flea3.c b/board/CarMediaLab/flea3/flea3.c index ca3e44b..3cd4dc9 100644 --- a/board/CarMediaLab/flea3/flea3.c +++ b/board/CarMediaLab/flea3/flea3.c @@ -122,6 +122,8 @@ static void setup_iomux_fec(void) MX35_PAD_FEC_TDATA2__FEC_TDATA_2, MX35_PAD_FEC_RDATA3__FEC_RDATA_3, MX35_PAD_FEC_TDATA3__FEC_TDATA_3, + /* GPIO used to power off ethernet */ + MX35_PAD_STXFS4__GPIO2_31, };
/* setup pins for FEC */ @@ -183,6 +185,11 @@ int board_init(void) /* address of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100;
+ /* Enable power for ethernet */ + gpio_direction_output(63, 0); + + udelay(2000); + return 0; }
include/configs/flea3.h | 9 ++++----- 1 file changed, 4 insertions(+), 5 deletions(-)
diff --git a/include/configs/flea3.h b/include/configs/flea3.h index 11d9391..0f7b3c8 100644 --- a/include/configs/flea3.h +++ b/include/configs/flea3.h @@ -101,10 +101,9 @@ #define CONFIG_CMDLINE_EDITING
#define CONFIG_AUTO_COMPLETE -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ /* Print Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_MAXARGS 32 /* max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */
#define CONFIG_SYS_MEMTEST_START 0 /* memtest works on */ @@ -227,8 +226,8 @@ "u-boot=" __stringify(CONFIG_HOSTNAME) "/u-boot.bin\0" \ "load=tftp ${loadaddr} ${u-boot}\0" \ "uboot_addr=" __stringify(CONFIG_SYS_MONITOR_BASE) "\0" \ - "update=protect off ${uboot_addr} +40000;" \ - "erase ${uboot_addr} +40000;" \ + "update=protect off ${uboot_addr} +80000;" \ + "erase ${uboot_addr} +80000;" \ "cp.b ${loadaddr} ${uboot_addr} ${filesize}\0" \ "upd=if run load;then echo Updating u-boot;if run update;" \ "then echo U-Boot updated;" \
- add DT support
- add GPIO setup
Applied to u-boot-imx, -next branch, thanks !
Best regards, Stefano Babic
Heiko Schocher
Stefano Babic
