[U-Boot] [PATCH v4 0/1] nitrogen6x: Move setup_sata to common part
Move setup_sata function definition from platform file nitrogen6x.c to arch/arm/imx-common/sata.c to avoid code duplication.
Signed-off-by: Giuseppe Pagano giuseppe.pagano@seco.com CC: Stefano Babic sbabic@denx.de CC: Fabio Estevam fabio.estevam@freescale.com CC: Eric Nelson eric.nelson@boundarydevices.com ---
Changes in v4: - Correct Makefile patch to use: obj- instead of COBJS-.
Changes in v3: - Correct Makefile for filter sata.c to be compiled only for mx6 soc because in function setup_sata there are i.MX6 specific registers definition and this breaks mx5 boards. mx5 boards does not need setup_sata initialization.
Changes in v2: - Split previous patch between nitrogen6x udoo code changes. --- arch/arm/imx-common/Makefile | 3 +++ arch/arm/imx-common/sata.c | 33 ++++++++++++++++++++++++++++++++ arch/arm/include/asm/imx-common/sata.h | 17 ++++++++++++++++ board/boundary/nitrogen6x/nitrogen6x.c | 27 +------------------------- 4 files changed, 54 insertions(+), 26 deletions(-) create mode 100644 arch/arm/imx-common/sata.c create mode 100644 arch/arm/include/asm/imx-common/sata.h
diff --git a/arch/arm/imx-common/Makefile b/arch/arm/imx-common/Makefile index 2c80441..68f0f52 100644 --- a/arch/arm/imx-common/Makefile +++ b/arch/arm/imx-common/Makefile @@ -17,6 +17,9 @@ endif ifeq ($(SOC),$(filter $(SOC),mx6 mxs)) obj-y += misc.o endif +ifeq ($(SOC),$(filter $(SOC),mx6)) +objs-$(CONFIG_CMD_SATA) += sata.o +endif obj-$(CONFIG_CMD_BMODE) += cmd_bmode.o obj-$(CONFIG_CMD_HDMIDETECT) += cmd_hdmidet.o
diff --git a/arch/arm/imx-common/sata.c b/arch/arm/imx-common/sata.c new file mode 100644 index 0000000..1b4c502 --- /dev/null +++ b/arch/arm/imx-common/sata.c @@ -0,0 +1,33 @@ +/* + * Copyright 2011 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm/imx-common/iomux-v3.h> +#include <asm/arch/iomux.h> +#include <asm/io.h> + +int setup_sata(void) +{ + struct iomuxc_base_regs *const iomuxc_regs + = (struct iomuxc_base_regs *)IOMUXC_BASE_ADDR; + + int ret = enable_sata_clock(); + if (ret) + return ret; + + clrsetbits_le32(&iomuxc_regs->gpr[13], + IOMUXC_GPR13_SATA_MASK, + IOMUXC_GPR13_SATA_PHY_8_RXEQ_3P0DB + |IOMUXC_GPR13_SATA_PHY_7_SATA2M + |IOMUXC_GPR13_SATA_SPEED_3G + |(3<<IOMUXC_GPR13_SATA_PHY_6_SHIFT) + |IOMUXC_GPR13_SATA_SATA_PHY_5_SS_DISABLED + |IOMUXC_GPR13_SATA_SATA_PHY_4_ATTEN_9_16 + |IOMUXC_GPR13_SATA_PHY_3_TXBOOST_0P00_DB + |IOMUXC_GPR13_SATA_PHY_2_TX_1P104V + |IOMUXC_GPR13_SATA_PHY_1_SLOW); + + return 0; +} diff --git a/arch/arm/include/asm/imx-common/sata.h b/arch/arm/include/asm/imx-common/sata.h new file mode 100644 index 0000000..8bb4493 --- /dev/null +++ b/arch/arm/include/asm/imx-common/sata.h @@ -0,0 +1,17 @@ +/* + * Copyright 2011 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __IMX_SATA_H_ +#define __IMX_SATA_H_ + +/* + * SATA setup for i.mx6 quad based platform + */ + +int setup_sata(void); + +#endif + diff --git a/board/boundary/nitrogen6x/nitrogen6x.c b/board/boundary/nitrogen6x/nitrogen6x.c index 616ad55..3f4cfa1 100644 --- a/board/boundary/nitrogen6x/nitrogen6x.c +++ b/board/boundary/nitrogen6x/nitrogen6x.c @@ -17,6 +17,7 @@ #include <asm/gpio.h> #include <asm/imx-common/iomux-v3.h> #include <asm/imx-common/mxc_i2c.h> +#include <asm/imx-common/sata.h> #include <asm/imx-common/boot_mode.h> #include <mmc.h> #include <fsl_esdhc.h> @@ -401,32 +402,6 @@ static void setup_buttons(void) ARRAY_SIZE(button_pads)); }
-#ifdef CONFIG_CMD_SATA - -int setup_sata(void) -{ - struct iomuxc_base_regs *const iomuxc_regs - = (struct iomuxc_base_regs *) IOMUXC_BASE_ADDR; - int ret = enable_sata_clock(); - if (ret) - return ret; - - clrsetbits_le32(&iomuxc_regs->gpr[13], - IOMUXC_GPR13_SATA_MASK, - IOMUXC_GPR13_SATA_PHY_8_RXEQ_3P0DB - |IOMUXC_GPR13_SATA_PHY_7_SATA2M - |IOMUXC_GPR13_SATA_SPEED_3G - |(3<<IOMUXC_GPR13_SATA_PHY_6_SHIFT) - |IOMUXC_GPR13_SATA_SATA_PHY_5_SS_DISABLED - |IOMUXC_GPR13_SATA_SATA_PHY_4_ATTEN_9_16 - |IOMUXC_GPR13_SATA_PHY_3_TXBOOST_0P00_DB - |IOMUXC_GPR13_SATA_PHY_2_TX_1P104V - |IOMUXC_GPR13_SATA_PHY_1_SLOW); - - return 0; -} -#endif - #if defined(CONFIG_VIDEO_IPUV3)
static iomux_v3_cfg_t const backlight_pads[] = {
Add SATA support on uDoo Board.
Signed-off-by: Giuseppe Pagano giuseppe.pagano@seco.com CC: Stefano Babic sbabic@denx.de CC: Fabio Estevam fabio.estevam@freescale.com ---
Changes in v4: - No changes.
Changes in v3: - No changes.
Changes in v2: - Split previous patch between nitrogen6x udoo code changes. --- board/udoo/udoo.c | 4 ++++ include/configs/udoo.h | 12 ++++++++++++ 2 files changed, 16 insertions(+)
diff --git a/board/udoo/udoo.c b/board/udoo/udoo.c index 081d517..e9236d4 100644 --- a/board/udoo/udoo.c +++ b/board/udoo/udoo.c @@ -14,6 +14,7 @@ #include <asm/errno.h> #include <asm/gpio.h> #include <asm/imx-common/iomux-v3.h> +#include <asm/imx-common/sata.h> #include <mmc.h> #include <fsl_esdhc.h> #include <asm/arch/crm_regs.h> @@ -240,6 +241,9 @@ int board_init(void) /* address of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
+#ifdef CONFIG_CMD_SATA + setup_sata(); +#endif return 0; }
diff --git a/include/configs/udoo.h b/include/configs/udoo.h index b9a493c..a1a1750 100644 --- a/include/configs/udoo.h +++ b/include/configs/udoo.h @@ -34,6 +34,18 @@ #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART2_BASE
+/* SATA Configs */ + +#define CONFIG_CMD_SATA +#ifdef CONFIG_CMD_SATA +#define CONFIG_DWC_AHSATA +#define CONFIG_SYS_SATA_MAX_DEVICE 1 +#define CONFIG_DWC_AHSATA_PORT_ID 0 +#define CONFIG_DWC_AHSATA_BASE_ADDR SATA_ARB_BASE_ADDR +#define CONFIG_LBA48 +#define CONFIG_LIBATA +#endif + /* Network support */
#define CONFIG_CMD_PING
Applied to u-boot-imx, thanks.
Best regards, Stefano Babic
Giuseppe Pagano
Stefano Babic
