[U-Boot] [PATCH 1/2] 85xx: Use print_size to report amount of memory not mapped by TLBs
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- cpu/mpc85xx/tlb.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/cpu/mpc85xx/tlb.c b/cpu/mpc85xx/tlb.c index 8304ffe..46925f1 100644 --- a/cpu/mpc85xx/tlb.c +++ b/cpu/mpc85xx/tlb.c @@ -165,7 +165,7 @@ unsigned int setup_ddr_tlbs(unsigned int memsize_in_meg) }
if (memsize) - printf("%lldM left unmapped\n", memsize >> 20); + print_size(memsize, " left unmapped\n");
/* * Confirm that the requested amount of memory was mapped.
The ddr code computes most things as 64-bit quantities and had some places in the middle that it was using phy_addr_t and phys_size_t.
Instead we use unsigned long long through out and only at the last stage of setting the LAWs and reporting the amount of memory to the board code do we truncate down to what we can cover via phys_size_t.
This has the added benefit that the DDR controller itself is always setup the same way regardless of how much memory we have. Its only the LAW setup that limits what is visible to the system.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- cpu/mpc8xxx/ddr/ctrl_regs.c | 3 +- cpu/mpc8xxx/ddr/ddr.h | 2 +- cpu/mpc8xxx/ddr/ddr1_dimm_params.c | 4 +- cpu/mpc8xxx/ddr/ddr2_dimm_params.c | 4 +- cpu/mpc8xxx/ddr/ddr3_dimm_params.c | 4 +- cpu/mpc8xxx/ddr/main.c | 45 ++++++++++++++++------------------- cpu/mpc8xxx/ddr/util.c | 18 +++++++++---- 7 files changed, 41 insertions(+), 39 deletions(-)
diff --git a/cpu/mpc8xxx/ddr/ctrl_regs.c b/cpu/mpc8xxx/ddr/ctrl_regs.c index 490e3dc..1689d68 100644 --- a/cpu/mpc8xxx/ddr/ctrl_regs.c +++ b/cpu/mpc8xxx/ddr/ctrl_regs.c @@ -1199,8 +1199,7 @@ compute_fsl_memctl_config_regs(const memctl_options_t *popts,
/* Chip Select Memory Bounds (CSn_BNDS) */ for (i = 0; i < CONFIG_CHIP_SELECTS_PER_CTRL; i++) { - phys_size_t sa = 0; - phys_size_t ea = 0; + unsigned long long ea = 0, sa = 0;
if (popts->ba_intlv_ctl && (i > 0) && ((popts->ba_intlv_ctl & 0x60) != FSL_DDR_CS2_CS3 )) { diff --git a/cpu/mpc8xxx/ddr/ddr.h b/cpu/mpc8xxx/ddr/ddr.h index 9ffd548..f122075 100644 --- a/cpu/mpc8xxx/ddr/ddr.h +++ b/cpu/mpc8xxx/ddr/ddr.h @@ -54,7 +54,7 @@ typedef struct { #define STEP_PROGRAM_REGS (1 << 6) #define STEP_ALL 0xFFF
-extern phys_size_t +extern unsigned long long fsl_ddr_compute(fsl_ddr_info_t *pinfo, unsigned int start_step);
extern const char * step_to_string(unsigned int step); diff --git a/cpu/mpc8xxx/ddr/ddr1_dimm_params.c b/cpu/mpc8xxx/ddr/ddr1_dimm_params.c index 2e0a209..9184764 100644 --- a/cpu/mpc8xxx/ddr/ddr1_dimm_params.c +++ b/cpu/mpc8xxx/ddr/ddr1_dimm_params.c @@ -33,10 +33,10 @@ * 2 or 5 bits off and shifting them up to the top. */
-static phys_size_t +static unsigned long long compute_ranksize(unsigned int mem_type, unsigned char row_dens) { - phys_size_t bsize; + unsigned long long bsize;
/* Bottom 2 bits up to the top. */ bsize = ((row_dens >> 2) | ((row_dens & 3) << 6)); diff --git a/cpu/mpc8xxx/ddr/ddr2_dimm_params.c b/cpu/mpc8xxx/ddr/ddr2_dimm_params.c index 06a8eb6..d9d0fa7 100644 --- a/cpu/mpc8xxx/ddr/ddr2_dimm_params.c +++ b/cpu/mpc8xxx/ddr/ddr2_dimm_params.c @@ -32,10 +32,10 @@ * 2 or 5 bits off and shifting them up to the top. * */ -static phys_size_t +static unsigned long long compute_ranksize(unsigned int mem_type, unsigned char row_dens) { - phys_size_t bsize; + unsigned long long bsize;
/* Bottom 5 bits up to the top. */ bsize = ((row_dens >> 5) | ((row_dens & 31) << 3)); diff --git a/cpu/mpc8xxx/ddr/ddr3_dimm_params.c b/cpu/mpc8xxx/ddr/ddr3_dimm_params.c index ca4be78..8d686ac 100644 --- a/cpu/mpc8xxx/ddr/ddr3_dimm_params.c +++ b/cpu/mpc8xxx/ddr/ddr3_dimm_params.c @@ -52,10 +52,10 @@ * 011 32bits * */ -static phys_size_t +static unsigned long long compute_ranksize(const ddr3_spd_eeprom_t *spd) { - phys_size_t bsize; + unsigned long long bsize;
int nbit_sdram_cap_bsize = 0; int nbit_primary_bus_width = 0; diff --git a/cpu/mpc8xxx/ddr/main.c b/cpu/mpc8xxx/ddr/main.c index 305f7fb..6dae26b 100644 --- a/cpu/mpc8xxx/ddr/main.c +++ b/cpu/mpc8xxx/ddr/main.c @@ -215,9 +215,7 @@ int step_assign_addresses(fsl_ddr_info_t *pinfo, }
if (*memctl_interleaving) { - phys_addr_t addr; - phys_size_t total_mem_per_ctlr = 0; - + unsigned long long addr, total_mem_per_ctlr = 0; /* * If interleaving between memory controllers, * make each controller start at a base address @@ -235,14 +233,13 @@ int step_assign_addresses(fsl_ddr_info_t *pinfo,
for (i = 0; i < CONFIG_NUM_DDR_CONTROLLERS; i++) { addr = 0; - pinfo->common_timing_params[i].base_address = - (phys_addr_t)addr; + pinfo->common_timing_params[i].base_address = 0ull; for (j = 0; j < CONFIG_DIMM_SLOTS_PER_CTLR; j++) { unsigned long long cap = pinfo->dimm_params[i][j].capacity;
pinfo->dimm_params[i][j].base_address = addr; - addr += (phys_addr_t)(cap >> dbw_cap_adj[i]); + addr += cap >> dbw_cap_adj[i]; total_mem_per_ctlr += cap >> dbw_cap_adj[i]; } } @@ -252,18 +249,17 @@ int step_assign_addresses(fsl_ddr_info_t *pinfo, * Simple linear assignment if memory * controllers are not interleaved. */ - phys_size_t cur_memsize = 0; + unsigned long long cur_memsize = 0; for (i = 0; i < CONFIG_NUM_DDR_CONTROLLERS; i++) { - phys_size_t total_mem_per_ctlr = 0; + u64 total_mem_per_ctlr = 0; pinfo->common_timing_params[i].base_address = - (phys_addr_t)cur_memsize; + cur_memsize; for (j = 0; j < CONFIG_DIMM_SLOTS_PER_CTLR; j++) { /* Compute DIMM base addresses. */ unsigned long long cap = pinfo->dimm_params[i][j].capacity; - pinfo->dimm_params[i][j].base_address = - (phys_addr_t)cur_memsize; + cur_memsize; cur_memsize += cap >> dbw_cap_adj[i]; total_mem_per_ctlr += cap >> dbw_cap_adj[i]; } @@ -275,13 +271,13 @@ int step_assign_addresses(fsl_ddr_info_t *pinfo, return 0; }
-phys_size_t +unsigned long long fsl_ddr_compute(fsl_ddr_info_t *pinfo, unsigned int start_step) { unsigned int i, j; unsigned int all_controllers_memctl_interleaving = 0; unsigned int all_controllers_rank_interleaving = 0; - phys_size_t total_mem = 0; + unsigned long long total_mem = 0;
fsl_ddr_cfg_regs_t *ddr_reg = pinfo->fsl_ddr_config_reg; common_timing_params_t *timing_params = pinfo->common_timing_params; @@ -424,15 +420,6 @@ fsl_ddr_compute(fsl_ddr_info_t *pinfo, unsigned int start_step) } }
-#if !defined(CONFIG_PHYS_64BIT) - /* Check for 4G or more with a 32-bit phys_addr_t. Bad. */ - if (max_end >= 0xff) { - printf("This U-Boot only supports < 4G of DDR\n"); - printf("You could rebuild it with CONFIG_PHYS_64BIT\n"); - return CONFIG_MAX_MEM_MAPPED; - } -#endif - total_mem = 1 + (((unsigned long long)max_end << 24ULL) | 0xFFFFFFULL); } @@ -450,7 +437,7 @@ phys_size_t fsl_ddr_sdram(void) { unsigned int i; unsigned int memctl_interleaved; - phys_size_t total_memory; + unsigned long long total_memory; fsl_ddr_info_t info;
/* Reset info structure. */ @@ -515,7 +502,17 @@ phys_size_t fsl_ddr_sdram(void) } }
- debug("total_memory = %llu\n", (u64)total_memory); + debug("total_memory = %llu\n", total_memory); + +#if !defined(CONFIG_PHYS_64BIT) + /* Check for 4G or more. Bad. */ + if (total_memory >= (1ull << 32)) { + printf("Detected %lld MB of memory\n", total_memory >> 20); + printf("This U-Boot only supports < 4G of DDR\n"); + printf("You could rebuild it with CONFIG_PHYS_64BIT\n"); + total_memory = CONFIG_MAX_MEM_MAPPED; + } +#endif
return total_memory; } diff --git a/cpu/mpc8xxx/ddr/util.c b/cpu/mpc8xxx/ddr/util.c index 27c135b..70dbee0 100644 --- a/cpu/mpc8xxx/ddr/util.c +++ b/cpu/mpc8xxx/ddr/util.c @@ -64,6 +64,9 @@ __fsl_ddr_set_lawbar(const common_timing_params_t *memctl_common_params, unsigned int memctl_interleaved, unsigned int ctrl_num) { + unsigned long long base = memctl_common_params->base_address; + unsigned long long size = memctl_common_params->total_mem; + /* * If no DIMMs on this controller, do not proceed any further. */ @@ -71,6 +74,13 @@ __fsl_ddr_set_lawbar(const common_timing_params_t *memctl_common_params, return; }
+#if !defined(CONFIG_PHYS_64BIT) + if (base >= CONFIG_MAX_MEM_MAPPED) + return; + if ((base + size) >= CONFIG_MAX_MEM_MAPPED) + size = CONFIG_MAX_MEM_MAPPED - base; +#endif + if (ctrl_num == 0) { /* * Set up LAW for DDR controller 1 space. @@ -78,16 +88,12 @@ __fsl_ddr_set_lawbar(const common_timing_params_t *memctl_common_params, unsigned int lawbar1_target_id = memctl_interleaved ? LAW_TRGT_IF_DDR_INTRLV : LAW_TRGT_IF_DDR_1;
- if (set_ddr_laws(memctl_common_params->base_address, - memctl_common_params->total_mem, - lawbar1_target_id) < 0) { + if (set_ddr_laws(base, size, lawbar1_target_id) < 0) { printf("ERROR\n"); return ; } } else if (ctrl_num == 1) { - if (set_ddr_laws(memctl_common_params->base_address, - memctl_common_params->total_mem, - LAW_TRGT_IF_DDR_2) < 0) { + if (set_ddr_laws(base, size, LAW_TRGT_IF_DDR_2) < 0) { printf("ERROR\n"); return ; }
Kumar Gala
