[PATCH v2 0/5] board: imx8mm: Add Engicam i.Core MX8M Mini SoM
Patch series for Engicam i.Core MX8M Mini SOM and it's associated carrier board dts(i) support.
patch 1-2: add imx8mm-u-boot.dtsi, header improvement code
patch 3: Engicam i.Core MX8M Mini SoM dts
patch 4-5: EDIMM2.2, C.TOUCH 2.0 Carrier boards
Changes for v2: - add Linux commit sha1 in commit messages.
Any inputs? Jagan.
Jagan Teki (5): arm64: dts: imx8mm: Add common -u-boot.dtsi configs: Add imx8mm-common header arm64: dts: imx8mm: Add Engicam i.Core MX8M Mini SoM board: imx8mm: Add Engicam i.Core MX8M Mini EDIMM2.2 Starter Kit board: imx8mm: Add Engicam i.Core MX8M Mini C.TOUCH 2.0
arch/arm/dts/Makefile | 2 + arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi | 37 +- arch/arm/dts/imx8mm-evk-u-boot.dtsi | 37 +- .../imx8mm-icore-mx8mm-ctouch2-u-boot.dtsi | 31 + arch/arm/dts/imx8mm-icore-mx8mm-ctouch2.dts | 97 + .../imx8mm-icore-mx8mm-edimm2.2-u-boot.dtsi | 31 + arch/arm/dts/imx8mm-icore-mx8mm-edimm2.2.dts | 97 + arch/arm/dts/imx8mm-icore-mx8mm-u-boot.dtsi | 27 + arch/arm/dts/imx8mm-icore-mx8mm.dtsi | 232 +++ arch/arm/dts/imx8mm-u-boot.dtsi | 39 + arch/arm/dts/imx8mm-venice-gw700x-u-boot.dtsi | 35 +- arch/arm/dts/imx8mm-venice-u-boot.dtsi | 37 +- arch/arm/dts/imx8mm-verdin-u-boot.dtsi | 38 +- arch/arm/dts/phycore-imx8mm-u-boot.dtsi | 37 +- arch/arm/mach-imx/imx8m/Kconfig | 19 + board/engicam/imx8mm/Kconfig | 14 + board/engicam/imx8mm/MAINTAINERS | 13 + board/engicam/imx8mm/Makefile | 12 + board/engicam/imx8mm/icore_mx8mm.c | 85 + board/engicam/imx8mm/lpddr4_timing.c | 1846 +++++++++++++++++ board/engicam/imx8mm/spl.c | 101 + configs/imx8mm-icore-mx8mm-ctouch2_defconfig | 92 + configs/imx8mm-icore-mx8mm-edimm2.2_defconfig | 92 + include/configs/imx8mm-common.h | 48 + include/configs/imx8mm_beacon.h | 48 +- include/configs/imx8mm_evk.h | 45 +- include/configs/imx8mm_icore_mx8mm.h | 58 + include/configs/imx8mm_venice.h | 46 +- include/configs/phycore_imx8mm.h | 43 +- include/configs/verdin-imx8mm.h | 42 +- 30 files changed, 2968 insertions(+), 413 deletions(-) create mode 100644 arch/arm/dts/imx8mm-icore-mx8mm-ctouch2-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mm-icore-mx8mm-ctouch2.dts create mode 100644 arch/arm/dts/imx8mm-icore-mx8mm-edimm2.2-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mm-icore-mx8mm-edimm2.2.dts create mode 100644 arch/arm/dts/imx8mm-icore-mx8mm-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mm-icore-mx8mm.dtsi create mode 100644 arch/arm/dts/imx8mm-u-boot.dtsi create mode 100644 board/engicam/imx8mm/Kconfig create mode 100644 board/engicam/imx8mm/MAINTAINERS create mode 100644 board/engicam/imx8mm/Makefile create mode 100644 board/engicam/imx8mm/icore_mx8mm.c create mode 100644 board/engicam/imx8mm/lpddr4_timing.c create mode 100644 board/engicam/imx8mm/spl.c create mode 100644 configs/imx8mm-icore-mx8mm-ctouch2_defconfig create mode 100644 configs/imx8mm-icore-mx8mm-edimm2.2_defconfig create mode 100644 include/configs/imx8mm-common.h create mode 100644 include/configs/imx8mm_icore_mx8mm.h
/soc@0 aips1 aips2 aips3 clk iomuxc osc_24m
are common node enablements across imx8mm platform for dm-spi, dm-pre-reloc stages.
Move them into common dtsi, imx8mm-u-boot.dtsi
Cc: Tim Harvey tharvey@gateworks.com Cc: Adam Ford aford173@gmail.com Cc: Peng Fan peng.fan@nxp.com Cc: Teresa Remmet t.remmet@phytec.de Cc: Igor Opaniuk igor.opaniuk@toradex.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v2: - add venice changes
arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi | 37 +----------------- arch/arm/dts/imx8mm-evk-u-boot.dtsi | 37 +----------------- arch/arm/dts/imx8mm-u-boot.dtsi | 39 +++++++++++++++++++ arch/arm/dts/imx8mm-venice-gw700x-u-boot.dtsi | 35 +---------------- arch/arm/dts/imx8mm-venice-u-boot.dtsi | 37 +----------------- arch/arm/dts/imx8mm-verdin-u-boot.dtsi | 38 ++---------------- arch/arm/dts/phycore-imx8mm-u-boot.dtsi | 37 +----------------- 7 files changed, 51 insertions(+), 209 deletions(-) create mode 100644 arch/arm/dts/imx8mm-u-boot.dtsi
diff --git a/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi b/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi index 6d80a529ae..73ddfdade6 100644 --- a/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi @@ -3,6 +3,8 @@ * Copyright 2020 Compass Electronics Group, LLC */
+#include "imx8mm-u-boot.dtsi" + / { wdt-reboot { compatible = "wdt-reboot"; @@ -11,32 +13,6 @@ }; };
-&{/soc@0} { - u-boot,dm-pre-reloc; - u-boot,dm-spl; -}; - -&aips1 { - u-boot,dm-spl; - u-boot,dm-pre-reloc; -}; - -&aips2 { - u-boot,dm-spl; -}; - -&aips3 { - u-boot,dm-spl; -}; - -&clk { - u-boot,dm-spl; - u-boot,dm-pre-reloc; - /delete-property/ assigned-clocks; - /delete-property/ assigned-clock-parents; - /delete-property/ assigned-clock-rates; -}; - ®_usdhc2_vmmc { u-boot,off-on-delay-us = <20000>; }; @@ -65,15 +41,6 @@ u-boot,dm-spl; };
-&iomuxc { - u-boot,dm-spl; -}; - -&osc_24m { - u-boot,dm-spl; - u-boot,dm-pre-reloc; -}; - &pca6416_0 { compatible = "ti,tca6416"; }; diff --git a/arch/arm/dts/imx8mm-evk-u-boot.dtsi b/arch/arm/dts/imx8mm-evk-u-boot.dtsi index e843a5648e..79dffe7ccd 100644 --- a/arch/arm/dts/imx8mm-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-evk-u-boot.dtsi @@ -3,6 +3,8 @@ * Copyright 2019 NXP */
+#include "imx8mm-u-boot.dtsi" + / { wdt-reboot { compatible = "wdt-reboot"; @@ -11,41 +13,6 @@ }; };
-&{/soc@0} { - u-boot,dm-pre-reloc; - u-boot,dm-spl; -}; - -&clk { - u-boot,dm-spl; - u-boot,dm-pre-reloc; - /delete-property/ assigned-clocks; - /delete-property/ assigned-clock-parents; - /delete-property/ assigned-clock-rates; -}; - -&osc_24m { - u-boot,dm-spl; - u-boot,dm-pre-reloc; -}; - -&aips1 { - u-boot,dm-spl; - u-boot,dm-pre-reloc; -}; - -&aips2 { - u-boot,dm-spl; -}; - -&aips3 { - u-boot,dm-spl; -}; - -&iomuxc { - u-boot,dm-spl; -}; - ®_usdhc2_vmmc { u-boot,off-on-delay-us = <20000>; }; diff --git a/arch/arm/dts/imx8mm-u-boot.dtsi b/arch/arm/dts/imx8mm-u-boot.dtsi new file mode 100644 index 0000000000..f833d9df59 --- /dev/null +++ b/arch/arm/dts/imx8mm-u-boot.dtsi @@ -0,0 +1,39 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020 Jagan Teki jagan@amarulasolutions.com + */ + +&{/soc@0} { + u-boot,dm-pre-reloc; + u-boot,dm-spl; +}; + +&aips1 { + u-boot,dm-spl; + u-boot,dm-pre-reloc; +}; + +&aips2 { + u-boot,dm-spl; +}; + +&aips3 { + u-boot,dm-spl; +}; + +&clk { + u-boot,dm-spl; + u-boot,dm-pre-reloc; + /delete-property/ assigned-clocks; + /delete-property/ assigned-clock-parents; + /delete-property/ assigned-clock-rates; +}; + +&iomuxc { + u-boot,dm-spl; +}; + +&osc_24m { + u-boot,dm-spl; + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/imx8mm-venice-gw700x-u-boot.dtsi b/arch/arm/dts/imx8mm-venice-gw700x-u-boot.dtsi index a4487e20c3..1a15d6a2ad 100644 --- a/arch/arm/dts/imx8mm-venice-gw700x-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-venice-gw700x-u-boot.dtsi @@ -3,40 +3,7 @@ * Copyright 2021 Gateworks Corporation */
-&{/soc@0} { - u-boot,dm-pre-reloc; - u-boot,dm-spl; -}; - -&clk { - u-boot,dm-spl; - u-boot,dm-pre-reloc; - /delete-property/ assigned-clocks; - /delete-property/ assigned-clock-parents; - /delete-property/ assigned-clock-rates; -}; - -&osc_24m { - u-boot,dm-spl; - u-boot,dm-pre-reloc; -}; - -&aips1 { - u-boot,dm-spl; - u-boot,dm-pre-reloc; -}; - -&aips2 { - u-boot,dm-spl; -}; - -&aips3 { - u-boot,dm-spl; -}; - -&iomuxc { - u-boot,dm-spl; -}; +#include "imx8mm-u-boot.dtsi"
&gpio1 { u-boot,dm-spl; diff --git a/arch/arm/dts/imx8mm-venice-u-boot.dtsi b/arch/arm/dts/imx8mm-venice-u-boot.dtsi index 5b06d872c6..42b2903f04 100644 --- a/arch/arm/dts/imx8mm-venice-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-venice-u-boot.dtsi @@ -3,6 +3,8 @@ * Copyright 2021 Gateworks Corporation */
-&{/soc@0} { - u-boot,dm-pre-reloc; - u-boot,dm-spl; -}; - -&clk { - u-boot,dm-spl; - u-boot,dm-pre-reloc; - /delete-property/ assigned-clocks; - /delete-property/ assigned-clock-parents; - /delete-property/ assigned-clock-rates; -}; - -&osc_24m { - u-boot,dm-spl; - u-boot,dm-pre-reloc; -}; - -&aips1 { - u-boot,dm-spl; - u-boot,dm-pre-reloc; -}; - -&aips2 { - u-boot,dm-spl; -}; - -&aips3 { - u-boot,dm-spl; -}; - -&iomuxc { - u-boot,dm-spl; -}; - &gpio1 { u-boot,dm-spl; }; diff --git a/arch/arm/dts/imx8mm-verdin-u-boot.dtsi b/arch/arm/dts/imx8mm-verdin-u-boot.dtsi index 249b0f8f66..67c31c49b6 100644 --- a/arch/arm/dts/imx8mm-verdin-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-verdin-u-boot.dtsi @@ -2,6 +2,9 @@ /* * Copyright 2020 Toradex */ + +#include "imx8mm-u-boot.dtsi" + / { wdt-reboot { compatible = "wdt-reboot"; @@ -10,27 +13,6 @@ }; };
-&aips1 { - u-boot,dm-spl; - u-boot,dm-pre-reloc; -}; - -&aips2 { - u-boot,dm-spl; -}; - -&aips3 { - u-boot,dm-spl; -}; - -&clk { - u-boot,dm-spl; - u-boot,dm-pre-reloc; - /delete-property/ assigned-clocks; - /delete-property/ assigned-clock-parents; - /delete-property/ assigned-clock-rates; -}; - &gpio1 { u-boot,dm-spl; }; @@ -55,15 +37,6 @@ u-boot,dm-spl; };
-&iomuxc { - u-boot,dm-spl; -}; - -&osc_24m { - u-boot,dm-spl; - u-boot,dm-pre-reloc; -}; - &pinctrl_i2c1 { u-boot,dm-spl; }; @@ -84,11 +57,6 @@ u-boot,dm-spl; };
-&{/soc@0} { - u-boot,dm-pre-reloc; - u-boot,dm-spl; -}; - &{/soc@0/bus@30800000/i2c@30a20000/pmic} { u-boot,dm-spl; }; diff --git a/arch/arm/dts/phycore-imx8mm-u-boot.dtsi b/arch/arm/dts/phycore-imx8mm-u-boot.dtsi index fc0fa22d1b..91515b8df9 100644 --- a/arch/arm/dts/phycore-imx8mm-u-boot.dtsi +++ b/arch/arm/dts/phycore-imx8mm-u-boot.dtsi @@ -4,6 +4,8 @@ * Author: Teresa Remmet t.remmet@phytec.de */
+#include "imx8mm-u-boot.dtsi" + / { wdt-reboot { compatible = "wdt-reboot"; @@ -12,41 +14,6 @@ }; };
-&{/soc@0} { - u-boot,dm-pre-reloc; - u-boot,dm-spl; -}; - -&clk { - u-boot,dm-spl; - u-boot,dm-pre-reloc; - /delete-property/ assigned-clocks; - /delete-property/ assigned-clock-parents; - /delete-property/ assigned-clock-rates; -}; - -&osc_24m { - u-boot,dm-spl; - u-boot,dm-pre-reloc; -}; - -&aips1 { - u-boot,dm-spl; - u-boot,dm-pre-reloc; -}; - -&aips2 { - u-boot,dm-spl; -}; - -&aips3 { - u-boot,dm-spl; -}; - -&iomuxc { - u-boot,dm-spl; -}; - &pinctrl_uart3 { u-boot,dm-spl; };
This may conflict with https://patchwork.ozlabs.org/project/uboot/patch/20210406035904.26598-1-peng...
Thanks, Peng.
Changes for v2:
add venice changes
- Copyright 2020 Compass Electronics Group, LLC
- / { wdt-reboot { compatible = "wdt-reboot";
-&{/soc@0} {
- u-boot,dm-spl;
-&aips1 {
- u-boot,dm-spl;
-&aips2 {
- u-boot,dm-spl;
-&aips3 {
- u-boot,dm-spl;
-&clk {
- u-boot,dm-spl;
-&iomuxc {
- u-boot,dm-spl;
-&osc_24m {
- u-boot,dm-spl;
- Copyright 2019 NXP
-&{/soc@0} {
- u-boot,dm-spl;
-&clk {
- u-boot,dm-spl;
-&osc_24m {
- u-boot,dm-spl;
-&aips1 {
- u-boot,dm-spl;
-&aips2 {
- u-boot,dm-spl;
-&aips3 {
- u-boot,dm-spl;
-&iomuxc {
- u-boot,dm-spl;
- Copyright (C) 2020 Jagan Teki jagan@amarulasolutions.com
+&{/soc@0} {
- u-boot,dm-spl;
+&aips1 {
- u-boot,dm-spl;
+&aips2 {
- u-boot,dm-spl;
+&aips3 {
- u-boot,dm-spl;
+&clk {
- u-boot,dm-spl;
+&iomuxc {
- u-boot,dm-spl;
+&osc_24m {
- u-boot,dm-spl;
- Copyright 2021 Gateworks Corporation
-&{/soc@0} {
- u-boot,dm-spl;
-&clk {
- u-boot,dm-spl;
-&osc_24m {
- u-boot,dm-spl;
-&aips1 {
- u-boot,dm-spl;
-&aips2 {
- u-boot,dm-spl;
-&aips3 {
- u-boot,dm-spl;
-&iomuxc {
- u-boot,dm-spl;
-&{/soc@0} {
- u-boot,dm-spl;
-&clk {
- u-boot,dm-spl;
-&osc_24m {
- u-boot,dm-spl;
-&aips1 {
- u-boot,dm-spl;
-&aips2 {
- u-boot,dm-spl;
-&aips3 {
- u-boot,dm-spl;
-&iomuxc {
- u-boot,dm-spl;
- Copyright 2020 Toradex
-&aips1 {
- u-boot,dm-spl;
-&aips2 {
- u-boot,dm-spl;
-&aips3 {
- u-boot,dm-spl;
-&clk {
- u-boot,dm-spl;
-&iomuxc {
- u-boot,dm-spl;
-&osc_24m {
- u-boot,dm-spl;
-&{/soc@0} {
- u-boot,dm-spl;
- Author: Teresa Remmet t.remmet@phytec.de
-&{/soc@0} {
- u-boot,dm-spl;
-&clk {
- u-boot,dm-spl;
-&osc_24m {
- u-boot,dm-spl;
-&aips1 {
- u-boot,dm-spl;
-&aips2 {
- u-boot,dm-spl;
-&aips3 {
- u-boot,dm-spl;
-&iomuxc {
- u-boot,dm-spl;
Right - Jagan, I have merged Peng's PR, I am merging the other conversions to DM. Your choice if you prefer to wait until I push on the server (maybe the best way to do), then you can rebase on top of it.
Regards, Stefano
Thanks, Peng.
Changes for v2:
diff --git a/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi b/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi index 6d80a529ae..73ddfdade6 100644 --- a/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi @@ -3,6 +3,8 @@ * Copyright 2020 Compass Electronics Group, LLC */ +#include "imx8mm-u-boot.dtsi"
/ { wdt-reboot { compatible = "wdt-reboot"; @@ -11,32 +13,6 @@ }; }; -&{/soc@0} { - u-boot,dm-pre-reloc; - u-boot,dm-spl; -};
®_usdhc2_vmmc { u-boot,off-on-delay-us = <20000>; }; @@ -65,15 +41,6 @@ u-boot,dm-spl; }; -&iomuxc { - u-boot,dm-spl; -};
&pca6416_0 { compatible = "ti,tca6416"; }; diff --git a/arch/arm/dts/imx8mm-evk-u-boot.dtsi b/arch/arm/dts/imx8mm-evk-u-boot.dtsi index e843a5648e..79dffe7ccd 100644 --- a/arch/arm/dts/imx8mm-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-evk-u-boot.dtsi @@ -3,6 +3,8 @@ * Copyright 2019 NXP */ +#include "imx8mm-u-boot.dtsi"
/ { wdt-reboot { compatible = "wdt-reboot"; @@ -11,41 +13,6 @@ }; }; -&{/soc@0} { - u-boot,dm-pre-reloc; - u-boot,dm-spl; -};
+&osc_24m { + u-boot,dm-spl; + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/imx8mm-venice-gw700x-u-boot.dtsi b/arch/arm/dts/imx8mm-venice-gw700x-u-boot.dtsi index a4487e20c3..1a15d6a2ad 100644 --- a/arch/arm/dts/imx8mm-venice-gw700x-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-venice-gw700x-u-boot.dtsi @@ -3,40 +3,7 @@ * Copyright 2021 Gateworks Corporation */ -&{/soc@0} { - u-boot,dm-pre-reloc; - u-boot,dm-spl; -};
-&iomuxc { - u-boot,dm-spl; -}; +#include "imx8mm-u-boot.dtsi" &gpio1 { u-boot,dm-spl; diff --git a/arch/arm/dts/imx8mm-venice-u-boot.dtsi b/arch/arm/dts/imx8mm-venice-u-boot.dtsi index 5b06d872c6..42b2903f04 100644 --- a/arch/arm/dts/imx8mm-venice-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-venice-u-boot.dtsi @@ -3,6 +3,8 @@ * Copyright 2021 Gateworks Corporation */ +#include "imx8mm-u-boot.dtsi"
/ { wdt-reboot { compatible = "wdt-reboot"; @@ -10,27 +13,6 @@ }; }; -&aips1 { - u-boot,dm-spl; - u-boot,dm-pre-reloc; -};
&gpio1 { u-boot,dm-spl; }; @@ -55,15 +37,6 @@ u-boot,dm-spl; }; -&iomuxc { - u-boot,dm-spl; -};
&pinctrl_i2c1 { u-boot,dm-spl; }; @@ -84,11 +57,6 @@ u-boot,dm-spl; }; -&{/soc@0} { - u-boot,dm-pre-reloc; - u-boot,dm-spl; -};
&{/soc@0/bus@30800000/i2c@30a20000/pmic} { u-boot,dm-spl; }; diff --git a/arch/arm/dts/phycore-imx8mm-u-boot.dtsi b/arch/arm/dts/phycore-imx8mm-u-boot.dtsi index fc0fa22d1b..91515b8df9 100644 --- a/arch/arm/dts/phycore-imx8mm-u-boot.dtsi +++ b/arch/arm/dts/phycore-imx8mm-u-boot.dtsi @@ -4,6 +4,8 @@ * Author: Teresa Remmet t.remmet@phytec.de */ +#include "imx8mm-u-boot.dtsi"
/ { wdt-reboot { compatible = "wdt-reboot"; @@ -12,41 +14,6 @@ }; }; -&{/soc@0} { - u-boot,dm-pre-reloc; - u-boot,dm-spl; -};
Yes, would work. I will rebase on top of your changes and send v3.
Jagan.
Move the redundant config item like SPL, memory-related across all imx8mm config files in the common config header, imx8mm-common.h
Verified the built files, seems almost the same as before.
include/configs/imx8mm-common.h | 48 ++++++++++++++++++++++++++++++++ include/configs/imx8mm_beacon.h | 48 ++++---------------------------- include/configs/imx8mm_evk.h | 45 ++---------------------------- include/configs/imx8mm_venice.h | 46 ++++-------------------------- include/configs/phycore_imx8mm.h | 43 ++-------------------------- include/configs/verdin-imx8mm.h | 42 +++------------------------- 6 files changed, 68 insertions(+), 204 deletions(-) create mode 100644 include/configs/imx8mm-common.h
diff --git a/include/configs/imx8mm-common.h b/include/configs/imx8mm-common.h new file mode 100644 index 0000000000..f1afa5c5a9 --- /dev/null +++ b/include/configs/imx8mm-common.h @@ -0,0 +1,48 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2019 NXP + * Copyright (c) 2020 Amarula Solutions(India) + */ + +#ifndef __IMX8MM_COMMON_H +#define __IMX8MM_COMMON_H + +#include <linux/sizes.h> +#include <asm/arch/imx-regs.h> + +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SPL_MAX_SIZE (148 * 1024) +#define CONFIG_SPL_STACK 0x920000 +#define CONFIG_SPL_BSS_START_ADDR 0x910000 +#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K +#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 +#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K + +/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ +#define CONFIG_MALLOC_F_ADDR 0x930000 +/* For RAW image gives a error info not panic */ +#define CONFIG_SPL_ABORT_ON_RAW_IMAGE +#endif /* CONFIG_SPL_BUILD */ + +#define CONFIG_SYS_MONITOR_LEN SZ_512K +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 +#define CONFIG_SYS_UBOOT_BASE \ + (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) + +#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN SZ_32M + +#define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define PHYS_SDRAM 0x40000000 + +#define CONFIG_LOADADDR 0x40480000 +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#endif /* __IMX8MM_COMMON_H */ diff --git a/include/configs/imx8mm_beacon.h b/include/configs/imx8mm_beacon.h index 94f4a1232f..65a44a9ed9 100644 --- a/include/configs/imx8mm_beacon.h +++ b/include/configs/imx8mm_beacon.h @@ -6,29 +6,13 @@ #ifndef __IMX8MM_BEACON_H #define __IMX8MM_BEACON_H
-#include <linux/sizes.h> -#include <asm/arch/imx-regs.h> +#define CONFIG_SYS_INIT_RAM_SIZE 0x200000 +#define PHYS_SDRAM_SIZE 0x80000000 /* 2GB DDR */
-#define CONFIG_SPL_MAX_SIZE (148 * 1024) -#define CONFIG_SYS_MONITOR_LEN SZ_512K -#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR -#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 -#define CONFIG_SYS_UBOOT_BASE \ - (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) +#include "imx8mm-common.h"
-#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_STACK 0x920000 -#define CONFIG_SPL_BSS_START_ADDR 0x910000 -#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K /* 8 KB */ -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */ - -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x930000 -/* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE - -#endif +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (PHYS_SDRAM_SIZE >> 1))
/* Initial environment variables */ #define CONFIG_EXTRA_ENV_SETTINGS \ @@ -92,28 +76,6 @@ "fi; " \ "fi;"
-/* Link Definitions */ -#define CONFIG_LOADADDR 0x40480000 - -#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR - -#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 -#define CONFIG_SYS_INIT_RAM_SIZE 0x200000 -#define CONFIG_SYS_INIT_SP_OFFSET \ - (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_ADDR \ - (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) - -/* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN SZ_32M - -#define CONFIG_SYS_SDRAM_BASE 0x40000000 -#define PHYS_SDRAM 0x40000000 -#define PHYS_SDRAM_SIZE 0x80000000 /* 2GB DDR */ - -#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (PHYS_SDRAM_SIZE >> 1)) - #define CONFIG_MXC_UART_BASE UART2_BASE_ADDR
/* Monitor Command Prompt */ diff --git a/include/configs/imx8mm_evk.h b/include/configs/imx8mm_evk.h index fd9a6cbb8c..d74bc2ea4f 100644 --- a/include/configs/imx8mm_evk.h +++ b/include/configs/imx8mm_evk.h @@ -6,31 +6,11 @@ #ifndef __IMX8MM_EVK_H #define __IMX8MM_EVK_H
-#include <linux/sizes.h> -#include <linux/stringify.h> -#include <asm/arch/imx-regs.h> - #define CONFIG_SYS_BOOTM_LEN (32 * SZ_1M) -#define CONFIG_SPL_MAX_SIZE (148 * 1024) -#define CONFIG_SYS_MONITOR_LEN SZ_512K -#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR -#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 -#define CONFIG_SYS_UBOOT_BASE \ - (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) - -#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_STACK 0x920000 -#define CONFIG_SPL_BSS_START_ADDR 0x910000 -#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K /* 8 KB */ -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */ - -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x930000 -/* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE +#define CONFIG_SYS_INIT_RAM_SIZE 0x200000 +#define PHYS_SDRAM_SIZE 0x80000000 /* 2GB DDR */
-#endif +#include "imx8mm-common.h"
#ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ @@ -56,27 +36,8 @@ "mmcpart=" __stringify(CONFIG_SYS_MMC_IMG_LOAD_PART) "\0" \ "mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \
-/* Link Definitions */ -#define CONFIG_LOADADDR 0x40480000 - -#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR - -#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 -#define CONFIG_SYS_INIT_RAM_SIZE 0x200000 -#define CONFIG_SYS_INIT_SP_OFFSET \ - (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_ADDR \ - (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) - #define CONFIG_MMCROOT "/dev/mmcblk1p2" /* USDHC2 */
-/* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN SZ_32M - -#define CONFIG_SYS_SDRAM_BASE 0x40000000 -#define PHYS_SDRAM 0x40000000 -#define PHYS_SDRAM_SIZE 0x80000000 /* 2GB DDR */ - #define CONFIG_MXC_UART_BASE UART2_BASE_ADDR
/* Monitor Command Prompt */ diff --git a/include/configs/imx8mm_venice.h b/include/configs/imx8mm_venice.h index a406e91c84..bcd59628f6 100644 --- a/include/configs/imx8mm_venice.h +++ b/include/configs/imx8mm_venice.h @@ -6,29 +6,13 @@ #ifndef __IMX8MM_VENICE_H #define __IMX8MM_VENICE_H
-#include <asm/arch/imx-regs.h> -#include <linux/sizes.h> +#define CONFIG_SYS_INIT_RAM_SIZE SZ_2M
-#define CONFIG_SPL_MAX_SIZE (148 * 1024) -#define CONFIG_SYS_MONITOR_LEN SZ_512K -#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR -#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 -#define CONFIG_SYS_UBOOT_BASE \ - (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) - -#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_STACK 0x920000 -#define CONFIG_SPL_BSS_START_ADDR 0x910000 -#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K /* 8 KB */ -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */ - -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x930000 -/* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE +/* SDRAM configuration */ +#define PHYS_SDRAM_SIZE SZ_1G /* 1GB DDR */ +#define CONFIG_SYS_BOOTM_LEN SZ_256M
#define MEM_LAYOUT_ENV_SETTINGS \ "fdt_addr_r=0x44000000\0" \ @@ -36,10 +20,6 @@ "ramdisk_addr_r=0x46400000\0" \ "scriptaddr=0x46000000\0"
-/* Link Definitions */ -#define CONFIG_LOADADDR 0x40480000 -#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR - /* Enable Distro Boot */ #ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ @@ -80,22 +60,6 @@ "gzwrite mmc $dev $loadaddr $filesize\0" \ "erase_env=mmc dev $dev; mmc erase 0x7f08 0x40\0"
-#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 -#define CONFIG_SYS_INIT_RAM_SIZE SZ_2M -#define CONFIG_SYS_INIT_SP_OFFSET \ - (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_ADDR \ - (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) - -/* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN SZ_32M -#define CONFIG_SYS_SDRAM_BASE 0x40000000 - -/* SDRAM configuration */ -#define PHYS_SDRAM 0x40000000 -#define PHYS_SDRAM_SIZE SZ_1G /* 1GB DDR */ -#define CONFIG_SYS_BOOTM_LEN SZ_256M - /* UART */ #define CONFIG_MXC_UART_BASE UART2_BASE_ADDR
diff --git a/include/configs/phycore_imx8mm.h b/include/configs/phycore_imx8mm.h index fd69dc41a8..86f4ee3f23 100644 --- a/include/configs/phycore_imx8mm.h +++ b/include/configs/phycore_imx8mm.h @@ -7,30 +7,11 @@ #ifndef __PHYCORE_IMX8MM_H #define __PHYCORE_IMX8MM_H
-#include <linux/sizes.h> -#include <linux/stringify.h> -#include <asm/arch/imx-regs.h> - #define CONFIG_SYS_BOOTM_LEN SZ_64M -#define CONFIG_SPL_MAX_SIZE (148 * SZ_1K) -#define CONFIG_SYS_MONITOR_LEN SZ_512K -#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR -#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 -#define CONFIG_SYS_UBOOT_BASE \ - (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) - -#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_STACK 0x920000 -#define CONFIG_SPL_BSS_START_ADDR 0x910000 -#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K +#define CONFIG_SYS_INIT_RAM_SIZE SZ_512K +#define PHYS_SDRAM_SIZE SZ_2G /* 2GB DDR */
-/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x930000 -/* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE -#endif +#include "imx8mm-common.h"
#define CONFIG_EXTRA_ENV_SETTINGS \ "image=Image\0" \ @@ -81,26 +62,8 @@ "fi; " \ "fi;"
-/* Link Definitions */ -#define CONFIG_LOADADDR 0x40480000 -#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR - -#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 -#define CONFIG_SYS_INIT_RAM_SIZE SZ_512K -#define CONFIG_SYS_INIT_SP_OFFSET \ - (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_ADDR \ - (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) - #define CONFIG_MMCROOT "/dev/mmcblk2p2" /* USDHC3 */
-/* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN SZ_32M -#define CONFIG_SYS_SDRAM_BASE 0x40000000 - -#define PHYS_SDRAM SZ_1G -#define PHYS_SDRAM_SIZE SZ_2G /* 2GB DDR */ - /* UART */ #define CONFIG_MXC_UART_BASE UART3_BASE_ADDR
diff --git a/include/configs/verdin-imx8mm.h b/include/configs/verdin-imx8mm.h index 4751bf5a5a..5485bc23aa 100644 --- a/include/configs/verdin-imx8mm.h +++ b/include/configs/verdin-imx8mm.h @@ -6,28 +6,12 @@ #ifndef __VERDIN_IMX8MM_H #define __VERDIN_IMX8MM_H
-#include <asm/arch/imx-regs.h> -#include <linux/sizes.h> - -#define CONFIG_SPL_MAX_SIZE (148 * 1024) -#define CONFIG_SYS_MONITOR_LEN SZ_512K -#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR -#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 -#define CONFIG_SYS_UBOOT_BASE \ - (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) +#define CONFIG_SYS_INIT_RAM_SIZE SZ_2M
-#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_STACK 0x920000 -#define CONFIG_SPL_BSS_START_ADDR 0x910000 -#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K /* 8 KB */ -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */ +/* SDRAM configuration */ +#define PHYS_SDRAM_SIZE SZ_2G /* 2GB DDR */
#define MEM_LAYOUT_ENV_SETTINGS \ "fdt_addr_r=0x44000000\0" \ @@ -35,9 +19,6 @@ "ramdisk_addr_r=0x46400000\0" \ "scriptaddr=0x46000000\0"
-#define CONFIG_LOADADDR 0x40480000 -#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR - /* Enable Distro Boot */ #ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ @@ -75,25 +56,10 @@ "${blkcnt} / 0x200; mmc dev 0 1; mmc write ${loadaddr} 0x2 " \ "${blkcnt}; fi\0"
-#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 -#define CONFIG_SYS_INIT_RAM_SIZE SZ_2M -#define CONFIG_SYS_INIT_SP_OFFSET \ - (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_ADDR \ - (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) - #if defined(CONFIG_ENV_IS_IN_MMC) /* Environment in eMMC, before config block at the end of 1st "boot sector" */ #endif
-/* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN SZ_32M -#define CONFIG_SYS_SDRAM_BASE 0x40000000 - -/* SDRAM configuration */ -#define PHYS_SDRAM 0x40000000 -#define PHYS_SDRAM_SIZE SZ_2G /* 2GB DDR */ - /* UART */ #define CONFIG_MXC_UART_BASE UART1_BASE_ADDR
On Mon, Mar 15, 2021 at 10:46 AM Jagan Teki jagan@amarulasolutions.com wrote:
Changes for v2:
- Copyright (c) 2019 NXP
- Copyright (c) 2020 Amarula Solutions(India)
Jagan,
Seems like a good idea, thanks for your work here!
I ran into an issue with imx8mm-venice due to my FIT image being larger than 512KiB causing me to bump CONFIG_SYS_SPL_MALLOC_SIZE (I bumped to 1MiB).
I have a pending patch for that [1] which would collide with this and I wonder what your feelings are about SYS_SPL_MALLOC_SIZE. When I started work on imx8mm-venice support the SPL did not use a malloc buffer for loading the FIT image so I never ran into an issue but that changed with commit 03f1f78a9b44 ("spl: fit: Prefer a malloc()'d buffer for loading images")' and after that I was not able to load my FIT image. I'm honestly not sure how the other imx8mm boards are not affected unless they just barely fit with a 512K malloc pool.
I'm not sure what the downside would be to doubling it to 1MiB or even more and I would be boards using FIT with multiple dtb's would go over 512KiB pretty quickly (as opposed to having to undef and re-define it per board).
Tim [1] http://patchwork.ozlabs.org/project/uboot/patch/20210308215236.27722-2-tharv...
i.Core MX8M Mini is an EDIMM SoM based on NXP i.MX8M Mini from Engicam.
General features: - NXP i.MX8M Mini - Up to 2GB LDDR4 - 8/16GB eMMC - Gigabit Ethernet - USB 2.0 Host/OTG - PCIe Gen2 interface - I2S - MIPI DSI to LVDS - rest of i.MX8M Mini features
i.Core MX8M Mini needs to mount on top of Engicam baseboards for creating complete platform solutions.
Linux dts commit details:
commit <470d6dad5ddd> ("arm64: dts: imx8mm: Add Engicam i.Core MX8M Mini SoM")
Add support for it.
Signed-off-by: Matteo Lisi matteo.lisi@engicam.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v2: - add Linux commit details
arch/arm/dts/imx8mm-icore-mx8mm.dtsi | 232 +++++++++++++++++++++++++++ 1 file changed, 232 insertions(+) create mode 100644 arch/arm/dts/imx8mm-icore-mx8mm.dtsi
diff --git a/arch/arm/dts/imx8mm-icore-mx8mm.dtsi b/arch/arm/dts/imx8mm-icore-mx8mm.dtsi new file mode 100644 index 0000000000..b40148d728 --- /dev/null +++ b/arch/arm/dts/imx8mm-icore-mx8mm.dtsi @@ -0,0 +1,232 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2018 NXP + * Copyright (c) 2019 Engicam srl + * Copyright (c) 2020 Amarula Solutons(India) + */ + +/ { + compatible = "engicam,icore-mx8mm", "fsl,imx8mm"; +}; + +&A53_0 { + cpu-supply = <®_buck4>; +}; + +&A53_1 { + cpu-supply = <®_buck4>; +}; + +&A53_2 { + cpu-supply = <®_buck4>; +}; + +&A53_3 { + cpu-supply = <®_buck4>; +}; + +&fec1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec1>; + phy-mode = "rgmii-id"; + phy-handle = <ðphy>; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy: ethernet-phy@3 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <3>; + reset-gpios = <&gpio3 7 GPIO_ACTIVE_LOW>; + reset-assert-us = <10000>; + }; + }; +}; + +&i2c1 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; + + pmic@8 { + compatible = "nxp,pf8121a"; + reg = <0x08>; + + regulators { + reg_ldo1: ldo1 { + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + }; + + reg_ldo2: ldo2 { + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + }; + + reg_ldo3: ldo3 { + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + }; + + reg_ldo4: ldo4 { + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + }; + + reg_buck1: buck1 { + regulator-min-microvolt = <400000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + }; + + reg_buck2: buck2 { + regulator-min-microvolt = <400000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + }; + + reg_buck3: buck3 { + regulator-min-microvolt = <400000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + }; + + reg_buck4: buck4 { + regulator-min-microvolt = <400000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + }; + + reg_buck5: buck5 { + regulator-min-microvolt = <400000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + }; + + reg_buck6: buck6 { + regulator-min-microvolt = <400000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + }; + + reg_buck7: buck7 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + }; + + reg_vsnvs: vsnvs { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + }; + }; + }; +}; + +&iomuxc { + pinctrl_fec1: fec1grp { + fsl,pins = < + MX8MM_IOMUXC_ENET_MDC_ENET1_MDC 0x3 + MX8MM_IOMUXC_ENET_MDIO_ENET1_MDIO 0x3 + MX8MM_IOMUXC_ENET_TD3_ENET1_RGMII_TD3 0x1f + MX8MM_IOMUXC_ENET_TD2_ENET1_RGMII_TD2 0x1f + MX8MM_IOMUXC_ENET_TD1_ENET1_RGMII_TD1 0x1f + MX8MM_IOMUXC_ENET_TD0_ENET1_RGMII_TD0 0x1f + MX8MM_IOMUXC_ENET_RD3_ENET1_RGMII_RD3 0x91 + MX8MM_IOMUXC_ENET_RD2_ENET1_RGMII_RD2 0x91 + MX8MM_IOMUXC_ENET_RD1_ENET1_RGMII_RD1 0x91 + MX8MM_IOMUXC_ENET_RD0_ENET1_RGMII_RD0 0x91 + MX8MM_IOMUXC_ENET_TXC_ENET1_RGMII_TXC 0x1f + MX8MM_IOMUXC_ENET_RXC_ENET1_RGMII_RXC 0x91 + MX8MM_IOMUXC_ENET_RX_CTL_ENET1_RGMII_RX_CTL 0x91 + MX8MM_IOMUXC_ENET_TX_CTL_ENET1_RGMII_TX_CTL 0x1f + MX8MM_IOMUXC_NAND_DATA01_GPIO3_IO7 0x19 + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX8MM_IOMUXC_I2C1_SCL_I2C1_SCL 0x400001c3 + MX8MM_IOMUXC_I2C1_SDA_I2C1_SDA 0x400001c3 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + MX8MM_IOMUXC_NAND_WE_B_USDHC3_CLK 0x190 + MX8MM_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d0 + MX8MM_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d0 + MX8MM_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d0 + MX8MM_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d0 + MX8MM_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d0 + MX8MM_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d0 + MX8MM_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d0 + MX8MM_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d0 + MX8MM_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d0 + MX8MM_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d0 + MX8MM_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x190 + >; + }; + + pinctrl_usdhc3_100mhz: usdhc3-100mhzgrp { + fsl,pins = < + MX8MM_IOMUXC_NAND_WE_B_USDHC3_CLK 0x194 + MX8MM_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d4 + MX8MM_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d4 + MX8MM_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d4 + MX8MM_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d4 + MX8MM_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d4 + MX8MM_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d4 + MX8MM_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d4 + MX8MM_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d4 + MX8MM_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d4 + MX8MM_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x194 + >; + }; + + pinctrl_usdhc3_200mhz: usdhc3-200mhzgrp { + fsl,pins = < + MX8MM_IOMUXC_NAND_WE_B_USDHC3_CLK 0x196 + MX8MM_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d6 + MX8MM_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d6 + MX8MM_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d6 + MX8MM_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d6 + MX8MM_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d6 + MX8MM_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d6 + MX8MM_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d6 + MX8MM_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d6 + MX8MM_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d6 + MX8MM_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x196 + >; + }; +}; + +/* eMMC */ +&usdhc3 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc3>; + pinctrl-1 = <&pinctrl_usdhc3_100mhz>; + pinctrl-2 = <&pinctrl_usdhc3_200mhz>; + bus-width = <8>; + non-removable; + status = "okay"; +};
Engicam EDIMM2.2 Starter Kit is an EDIMM 2.2 Form Factor Capacitive Evaluation Board.
Genaral features: - LCD 7" C.Touch - microSD slot - Ethernet 1Gb - Wifi/BT - 2x LVDS Full HD interfaces - 3x USB 2.0 - 1x USB 3.0 - HDMI Out - Mini PCIe - MIPI CSI - 2x CAN - Audio Out
i.Core MX8M Mini needs to mount on top of this Evaluation board for creating complete i.Core MX8M Mini EDIMM2.2 Starter Kit.
commit <051c08eea682> ("arm64: dts: imx8mm: Add Engicam i.Core MX8M Mini EDIMM2.2 Starter Kit")
Add support for it.
arch/arm/dts/Makefile | 1 + .../imx8mm-icore-mx8mm-edimm2.2-u-boot.dtsi | 31 + arch/arm/dts/imx8mm-icore-mx8mm-edimm2.2.dts | 97 + arch/arm/dts/imx8mm-icore-mx8mm-u-boot.dtsi | 27 + arch/arm/mach-imx/imx8m/Kconfig | 14 + board/engicam/imx8mm/Kconfig | 14 + board/engicam/imx8mm/MAINTAINERS | 7 + board/engicam/imx8mm/Makefile | 12 + board/engicam/imx8mm/icore_mx8mm.c | 85 + board/engicam/imx8mm/lpddr4_timing.c | 1846 +++++++++++++++++ board/engicam/imx8mm/spl.c | 101 + configs/imx8mm-icore-mx8mm-edimm2.2_defconfig | 92 + include/configs/imx8mm_icore_mx8mm.h | 58 + 13 files changed, 2385 insertions(+) create mode 100644 arch/arm/dts/imx8mm-icore-mx8mm-edimm2.2-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mm-icore-mx8mm-edimm2.2.dts create mode 100644 arch/arm/dts/imx8mm-icore-mx8mm-u-boot.dtsi create mode 100644 board/engicam/imx8mm/Kconfig create mode 100644 board/engicam/imx8mm/MAINTAINERS create mode 100644 board/engicam/imx8mm/Makefile create mode 100644 board/engicam/imx8mm/icore_mx8mm.c create mode 100644 board/engicam/imx8mm/lpddr4_timing.c create mode 100644 board/engicam/imx8mm/spl.c create mode 100644 configs/imx8mm-icore-mx8mm-edimm2.2_defconfig create mode 100644 include/configs/imx8mm_icore_mx8mm.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index c6710826a0..08db525bc4 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -790,6 +790,7 @@ dtb-$(CONFIG_ARCH_IMX8) += \
dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mm-evk.dtb \ + imx8mm-icore-mx8mm-edimm2.2.dtb \ imx8mm-venice.dtb \ imx8mm-venice-gw71xx-0x.dtb \ imx8mm-venice-gw72xx-0x.dtb \ diff --git a/arch/arm/dts/imx8mm-icore-mx8mm-edimm2.2-u-boot.dtsi b/arch/arm/dts/imx8mm-icore-mx8mm-edimm2.2-u-boot.dtsi new file mode 100644 index 0000000000..8b67bcff7d --- /dev/null +++ b/arch/arm/dts/imx8mm-icore-mx8mm-edimm2.2-u-boot.dtsi @@ -0,0 +1,31 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2020 Engicam srl + * Copyright (c) 2020 Amarula Solutions(India) + */ + +#include "imx8mm-icore-mx8mm-u-boot.dtsi" + +&gpio1 { + u-boot,dm-spl; +}; + +&pinctrl_uart2 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc1_gpio { + u-boot,dm-spl; +}; + +&pinctrl_usdhc1 { + u-boot,dm-spl; +}; + +&uart2 { + u-boot,dm-spl; +}; + +&usdhc1 { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/imx8mm-icore-mx8mm-edimm2.2.dts b/arch/arm/dts/imx8mm-icore-mx8mm-edimm2.2.dts new file mode 100644 index 0000000000..a4a2ada148 --- /dev/null +++ b/arch/arm/dts/imx8mm-icore-mx8mm-edimm2.2.dts @@ -0,0 +1,97 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 NXP + * Copyright (c) 2019 Engicam srl + * Copyright (c) 2020 Amarula Solutions(India) + */ + +/dts-v1/; +#include "imx8mm.dtsi" +#include "imx8mm-icore-mx8mm.dtsi" + +/ { + model = "Engicam i.Core MX8M Mini EDIMM2.2 Starter Kit"; + compatible = "engicam,icore-mx8mm-edimm2.2", "engicam,icore-mx8mm", + "fsl,imx8mm"; + + chosen { + stdout-path = &uart2; + }; +}; + +&fec1 { + status = "okay"; +}; + +&i2c2 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; +}; + +&i2c4 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c4>; + status = "okay"; +}; + +&iomuxc { + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX8MM_IOMUXC_I2C2_SCL_I2C2_SCL 0x400001c3 + MX8MM_IOMUXC_I2C2_SDA_I2C2_SDA 0x400001c3 + >; + }; + + pinctrl_i2c4: i2c4grp { + fsl,pins = < + MX8MM_IOMUXC_I2C4_SCL_I2C4_SCL 0x400001c3 + MX8MM_IOMUXC_I2C4_SDA_I2C4_SDA 0x400001c3 + >; + }; + + pinctrl_uart2: uart2grp { + fsl,pins = < + MX8MM_IOMUXC_UART2_RXD_UART2_DCE_RX 0x140 + MX8MM_IOMUXC_UART2_TXD_UART2_DCE_TX 0x140 + >; + }; + + pinctrl_usdhc1_gpio: usdhc1gpiogrp { + fsl,pins = < + MX8MM_IOMUXC_GPIO1_IO06_GPIO1_IO6 0x41 + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + MX8MM_IOMUXC_SD1_CLK_USDHC1_CLK 0x190 + MX8MM_IOMUXC_SD1_CMD_USDHC1_CMD 0x1d0 + MX8MM_IOMUXC_SD1_DATA0_USDHC1_DATA0 0x1d0 + MX8MM_IOMUXC_SD1_DATA1_USDHC1_DATA1 0x1d0 + MX8MM_IOMUXC_SD1_DATA2_USDHC1_DATA2 0x1d0 + MX8MM_IOMUXC_SD1_DATA3_USDHC1_DATA3 0x1d0 + >; + }; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + status = "okay"; +}; + +/* SD */ +&usdhc1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc1>, <&pinctrl_usdhc1_gpio>; + cd-gpios = <&gpio1 6 GPIO_ACTIVE_LOW>; + max-frequency = <50000000>; + bus-width = <4>; + no-1-8-v; + pm-ignore-notify; + keep-power-in-suspend; + status = "okay"; +}; diff --git a/arch/arm/dts/imx8mm-icore-mx8mm-u-boot.dtsi b/arch/arm/dts/imx8mm-icore-mx8mm-u-boot.dtsi new file mode 100644 index 0000000000..e7d179d632 --- /dev/null +++ b/arch/arm/dts/imx8mm-icore-mx8mm-u-boot.dtsi @@ -0,0 +1,27 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2020 Engicam srl + * Copyright (c) 2020 Amarula Solutions(India) + */ + +#include "imx8mm-u-boot.dtsi" + +&iomuxc { + u-boot,dm-spl; +}; + +&pinctrl_usdhc3 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc3_100mhz { + u-boot,dm-spl; +}; + +&pinctrl_usdhc3_200mhz { + u-boot,dm-spl; +}; + +&usdhc3 { + u-boot,dm-spl; +}; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index 12b8d0d831..28a9a51e67 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -49,6 +49,19 @@ config TARGET_IMX8MM_VENICE select SUPPORT_SPL select IMX8M_LPDDR4
+config TARGET_IMX8MM_ICORE_MX8MM + bool "Engicam i.Core MX8M Mini SOM" + select IMX8MM + select SUPPORT_SPL + select IMX8M_LPDDR4 + help + i.Core MX8M Mini is an EDIMM SOM based on NXP i.MX8MM. + + i.Core MX8M Mini EDIMM2.2: + * EDIMM2.2 is a Form Factor Capacitive Evaluation Board. + * i.Core MX8M Mini needs to mount on top of EDIMM2.2 for + creating complete i.Core MX8M Mini EDIMM2.2 Starter Kit. + config TARGET_IMX8MN_DDR4_EVK bool "imx8mn DDR4 EVK board" select IMX8MN @@ -97,6 +110,7 @@ config TARGET_PHYCORE_IMX8MP select IMX8M_LPDDR4 endchoice
+source "board/engicam/imx8mm/Kconfig" source "board/freescale/imx8mq_evk/Kconfig" source "board/freescale/imx8mm_evk/Kconfig" source "board/freescale/imx8mn_evk/Kconfig" diff --git a/board/engicam/imx8mm/Kconfig b/board/engicam/imx8mm/Kconfig new file mode 100644 index 0000000000..ed68516df4 --- /dev/null +++ b/board/engicam/imx8mm/Kconfig @@ -0,0 +1,14 @@ +if TARGET_IMX8MM_ICORE_MX8MM + +config SYS_BOARD + default "imx8mm" + +config SYS_VENDOR + default "engicam" + +config SYS_CONFIG_NAME + default "imx8mm_icore_mx8mm" + +source "board/freescale/common/Kconfig" + +endif diff --git a/board/engicam/imx8mm/MAINTAINERS b/board/engicam/imx8mm/MAINTAINERS new file mode 100644 index 0000000000..044a9392ac --- /dev/null +++ b/board/engicam/imx8mm/MAINTAINERS @@ -0,0 +1,7 @@ +i.Core-MX8M-Mini-EDIMM2.2 +M: Jagan Teki jagan@amarulasolutions.com +M: Matteo Lisi matteo.lisi@engicam.com +S: Maintained +F: board/engicam/imx8mm +F: include/configs/imx8mm_icore_mx8mm.h +F: configs/imx8mm-icore-mx8mm-edimm2.2_defconfig diff --git a/board/engicam/imx8mm/Makefile b/board/engicam/imx8mm/Makefile new file mode 100644 index 0000000000..3392d61920 --- /dev/null +++ b/board/engicam/imx8mm/Makefile @@ -0,0 +1,12 @@ +# +# Copyright (C) 2020 Amarula Solutions(India) +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += icore_mx8mm.o + +ifdef CONFIG_SPL_BUILD +obj-y += spl.o +obj-y += lpddr4_timing.o +endif diff --git a/board/engicam/imx8mm/icore_mx8mm.c b/board/engicam/imx8mm/icore_mx8mm.c new file mode 100644 index 0000000000..4f7c699d7d --- /dev/null +++ b/board/engicam/imx8mm/icore_mx8mm.c @@ -0,0 +1,85 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Amarula Solutions B.V. + * Copyright (C) 2016 Engicam S.r.l. + * Author: Jagan Teki jagan@amarulasolutions.com + */ + +#include <common.h> +#include <miiphy.h> +#include <netdev.h> + +#include <asm/io.h> +#include <asm-generic/gpio.h> + +#include <linux/delay.h> + +#include <asm/arch/clock.h> +#include <asm/arch/imx8mm_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-imx/gpio.h> +#include <asm/mach-imx/iomux-v3.h> + +DECLARE_GLOBAL_DATA_PTR; + +#if IS_ENABLED(CONFIG_FEC_MXC) + +#define FEC_RST_PAD IMX_GPIO_NR(3, 7) +static iomux_v3_cfg_t const fec1_rst_pads[] = { + IMX8MM_PAD_NAND_DATA01_GPIO3_IO7 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static void setup_iomux_fec(void) +{ + imx_iomux_v3_setup_multiple_pads(fec1_rst_pads, + ARRAY_SIZE(fec1_rst_pads)); + + gpio_request(FEC_RST_PAD, "fec1_rst"); + gpio_direction_output(FEC_RST_PAD, 0); + udelay(500); + gpio_direction_output(FEC_RST_PAD, 1); +} + +static int setup_fec(void) +{ + struct iomuxc_gpr_base_regs *gpr = + (struct iomuxc_gpr_base_regs *)IOMUXC_GPR_BASE_ADDR; + + setup_iomux_fec(); + + /* Use 125M anatop REF_CLK1 for ENET1, not from external */ + clrsetbits_le32(&gpr->gpr[1], 13, 0); + + return set_clk_enet(ENET_125MHZ); +} + +int board_phy_config(struct phy_device *phydev) +{ + /* enable rgmii rxc skew and phy mode select to RGMII copper */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x1f); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x8); + + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x00); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x82ee); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x100); + + if (phydev->drv->config) + phydev->drv->config(phydev); + + return 0; +} +#endif + +int board_init(void) +{ + if (IS_ENABLED(CONFIG_FEC_MXC)) + setup_fec(); + + return 0; +} + +int board_mmc_get_env_dev(int devno) +{ + return devno; +} diff --git a/board/engicam/imx8mm/lpddr4_timing.c b/board/engicam/imx8mm/lpddr4_timing.c new file mode 100644 index 0000000000..821212740b --- /dev/null +++ b/board/engicam/imx8mm/lpddr4_timing.c @@ -0,0 +1,1846 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 NXP + * + * Generated code from MX8M_DDR_tool + * Align with uboot-imx_v2018.03_4.14.78_1.0.0_ga + */ + +#include <common.h> +#include <asm/arch/ddr.h> +#include <asm/arch/lpddr4_define.h> + +struct dram_cfg_param ddr_ddrc_cfg[] = { + /* Initialize DDRC registers */ + {0x3d400304, 0x1}, + {0x3d400030, 0x1}, + {0x3d400000, 0xa1080020}, + {0x3d400020, 0x223}, + {0x3d400024, 0x3a980}, + {0x3d400064, 0x5b0087}, + {0x3d4000d0, 0xc00305ba}, + {0x3d4000d4, 0x940000}, + {0x3d4000dc, 0xd4002d}, + {0x3d4000e0, 0x210000}, + {0x3d4000e8, 0x44004d}, + {0x3d4000ec, 0x14004d}, + {0x3d400100, 0x191f1920}, + {0x3d400104, 0x60630}, + {0x3d40010c, 0xb0b000}, + {0x3d400110, 0xe04080e}, + {0x3d400114, 0x2040c0c}, + {0x3d400118, 0x1010007}, + {0x3d40011c, 0x401}, + {0x3d400130, 0x20600}, + {0x3d400134, 0xc100002}, + {0x3d400138, 0x8d}, + {0x3d400144, 0x96004b}, + {0x3d400180, 0x2ee0017}, + {0x3d400184, 0x2605b8e}, + {0x3d400188, 0x0}, + {0x3d400190, 0x497820a}, + {0x3d400194, 0x80303}, + {0x3d4001b4, 0x170a}, + {0x3d4001a0, 0xe0400018}, + {0x3d4001a4, 0xdf00e4}, + {0x3d4001a8, 0x80000000}, + {0x3d4001b0, 0x11}, + {0x3d4001c0, 0x1}, + {0x3d4001c4, 0x0}, + {0x3d4000f4, 0xc99}, + {0x3d400108, 0x70e1617}, + {0x3d400200, 0x1f}, + {0x3d40020c, 0x0}, + {0x3d400210, 0x1f1f}, + {0x3d400204, 0x80808}, + {0x3d400214, 0x7070707}, + {0x3d400218, 0xf070707}, + {0x3d400250, 0x29001701}, + {0x3d400254, 0x2c}, + {0x3d40025c, 0x4000030}, + {0x3d400264, 0x900093e7}, + {0x3d40026c, 0x2005574}, + {0x3d400400, 0x111}, + {0x3d400408, 0x72ff}, + {0x3d400494, 0x2100e07}, + {0x3d400498, 0x620096}, + {0x3d40049c, 0x1100e07}, + {0x3d4004a0, 0xc8012c}, + {0x3d402020, 0x21}, + {0x3d402024, 0x7d00}, + {0x3d402050, 0x20d040}, + {0x3d402064, 0xc0012}, + {0x3d4020dc, 0x840000}, + {0x3d4020e0, 0x310000}, + {0x3d4020e8, 0x66004d}, + {0x3d4020ec, 0x16004d}, + {0x3d402100, 0xa050305}, + {0x3d402104, 0x30407}, + {0x3d402108, 0x203060b}, + {0x3d40210c, 0x505000}, + {0x3d402110, 0x2040202}, + {0x3d402114, 0x2030202}, + {0x3d402118, 0x1010004}, + {0x3d40211c, 0x301}, + {0x3d402130, 0x20300}, + {0x3d402134, 0xa100002}, + {0x3d402138, 0x13}, + {0x3d402144, 0x14000a}, + {0x3d402180, 0x640004}, + {0x3d402190, 0x3818200}, + {0x3d402194, 0x80303}, + {0x3d4021b4, 0x100}, + {0x3d403020, 0x21}, + {0x3d403024, 0x1f40}, + {0x3d403050, 0x20d040}, + {0x3d403064, 0x30005}, + {0x3d4030dc, 0x840000}, + {0x3d4030e0, 0x310000}, + {0x3d4030e8, 0x66004d}, + {0x3d4030ec, 0x16004d}, + {0x3d403100, 0xa020102}, + {0x3d403104, 0x30404}, + {0x3d403108, 0x203060b}, + {0x3d40310c, 0x505000}, + {0x3d403110, 0x2040202}, + {0x3d403114, 0x2030202}, + {0x3d403118, 0x1010004}, + {0x3d40311c, 0x301}, + {0x3d403130, 0x20300}, + {0x3d403134, 0xa100002}, + {0x3d403138, 0x5}, + {0x3d403144, 0x50003}, + {0x3d403180, 0x190004}, + {0x3d403190, 0x3818200}, + {0x3d403194, 0x80303}, + {0x3d4031b4, 0x100}, + {0x3d400028, 0x0}, +}; + +/* PHY Initialize Configuration */ +struct dram_cfg_param ddr_ddrphy_cfg[] = { + {0x100a0, 0x0}, + {0x100a1, 0x1}, + {0x100a2, 0x2}, + {0x100a3, 0x3}, + {0x100a4, 0x4}, + {0x100a5, 0x5}, + {0x100a6, 0x6}, + {0x100a7, 0x7}, + {0x110a0, 0x0}, + {0x110a1, 0x1}, + {0x110a2, 0x3}, + {0x110a3, 0x4}, + {0x110a4, 0x5}, + {0x110a5, 0x2}, + {0x110a6, 0x7}, + {0x110a7, 0x6}, + {0x120a0, 0x0}, + {0x120a1, 0x1}, + {0x120a2, 0x3}, + {0x120a3, 0x2}, + {0x120a4, 0x5}, + {0x120a5, 0x4}, + {0x120a6, 0x7}, + {0x120a7, 0x6}, + {0x130a0, 0x0}, + {0x130a1, 0x1}, + {0x130a2, 0x2}, + {0x130a3, 0x3}, + {0x130a4, 0x4}, + {0x130a5, 0x5}, + {0x130a6, 0x6}, + {0x130a7, 0x7}, + {0x1005f, 0x1ff}, + {0x1015f, 0x1ff}, + {0x1105f, 0x1ff}, + {0x1115f, 0x1ff}, + {0x1205f, 0x1ff}, + {0x1215f, 0x1ff}, + {0x1305f, 0x1ff}, + {0x1315f, 0x1ff}, + {0x11005f, 0x1ff}, + {0x11015f, 0x1ff}, + {0x11105f, 0x1ff}, + {0x11115f, 0x1ff}, + {0x11205f, 0x1ff}, + {0x11215f, 0x1ff}, + {0x11305f, 0x1ff}, + {0x11315f, 0x1ff}, + {0x21005f, 0x1ff}, + {0x21015f, 0x1ff}, + {0x21105f, 0x1ff}, + {0x21115f, 0x1ff}, + {0x21205f, 0x1ff}, + {0x21215f, 0x1ff}, + {0x21305f, 0x1ff}, + {0x21315f, 0x1ff}, + {0x55, 0x1ff}, + {0x1055, 0x1ff}, + {0x2055, 0x1ff}, + {0x3055, 0x1ff}, + {0x4055, 0x1ff}, + {0x5055, 0x1ff}, + {0x6055, 0x1ff}, + {0x7055, 0x1ff}, + {0x8055, 0x1ff}, + {0x9055, 0x1ff}, + {0x200c5, 0x19}, + {0x1200c5, 0x7}, + {0x2200c5, 0x7}, + {0x2002e, 0x2}, + {0x12002e, 0x2}, + {0x22002e, 0x2}, + {0x90204, 0x0}, + {0x190204, 0x0}, + {0x290204, 0x0}, + {0x20024, 0x1ab}, + {0x2003a, 0x0}, + {0x120024, 0x1ab}, + {0x2003a, 0x0}, + {0x220024, 0x1ab}, + {0x2003a, 0x0}, + {0x20056, 0x3}, + {0x120056, 0xa}, + {0x220056, 0xa}, + {0x1004d, 0xe00}, + {0x1014d, 0xe00}, + {0x1104d, 0xe00}, + {0x1114d, 0xe00}, + {0x1204d, 0xe00}, + {0x1214d, 0xe00}, + {0x1304d, 0xe00}, + {0x1314d, 0xe00}, + {0x11004d, 0xe00}, + {0x11014d, 0xe00}, + {0x11104d, 0xe00}, + {0x11114d, 0xe00}, + {0x11204d, 0xe00}, + {0x11214d, 0xe00}, + {0x11304d, 0xe00}, + {0x11314d, 0xe00}, + {0x21004d, 0xe00}, + {0x21014d, 0xe00}, + {0x21104d, 0xe00}, + {0x21114d, 0xe00}, + {0x21204d, 0xe00}, + {0x21214d, 0xe00}, + {0x21304d, 0xe00}, + {0x21314d, 0xe00}, + {0x10049, 0xeba}, + {0x10149, 0xeba}, + {0x11049, 0xeba}, + {0x11149, 0xeba}, + {0x12049, 0xeba}, + {0x12149, 0xeba}, + {0x13049, 0xeba}, + {0x13149, 0xeba}, + {0x110049, 0xeba}, + {0x110149, 0xeba}, + {0x111049, 0xeba}, + {0x111149, 0xeba}, + {0x112049, 0xeba}, + {0x112149, 0xeba}, + {0x113049, 0xeba}, + {0x113149, 0xeba}, + {0x210049, 0xeba}, + {0x210149, 0xeba}, + {0x211049, 0xeba}, + {0x211149, 0xeba}, + {0x212049, 0xeba}, + {0x212149, 0xeba}, + {0x213049, 0xeba}, + {0x213149, 0xeba}, + {0x43, 0x63}, + {0x1043, 0x63}, + {0x2043, 0x63}, + {0x3043, 0x63}, + {0x4043, 0x63}, + {0x5043, 0x63}, + {0x6043, 0x63}, + {0x7043, 0x63}, + {0x8043, 0x63}, + {0x9043, 0x63}, + {0x20018, 0x3}, + {0x20075, 0x4}, + {0x20050, 0x0}, + {0x20008, 0x2ee}, + {0x120008, 0x64}, + {0x220008, 0x19}, + {0x20088, 0x9}, + {0x200b2, 0xdc}, + {0x10043, 0x5a1}, + {0x10143, 0x5a1}, + {0x11043, 0x5a1}, + {0x11143, 0x5a1}, + {0x12043, 0x5a1}, + {0x12143, 0x5a1}, + {0x13043, 0x5a1}, + {0x13143, 0x5a1}, + {0x1200b2, 0xdc}, + {0x110043, 0x5a1}, + {0x110143, 0x5a1}, + {0x111043, 0x5a1}, + {0x111143, 0x5a1}, + {0x112043, 0x5a1}, + {0x112143, 0x5a1}, + {0x113043, 0x5a1}, + {0x113143, 0x5a1}, + {0x2200b2, 0xdc}, + {0x210043, 0x5a1}, + {0x210143, 0x5a1}, + {0x211043, 0x5a1}, + {0x211143, 0x5a1}, + {0x212043, 0x5a1}, + {0x212143, 0x5a1}, + {0x213043, 0x5a1}, + {0x213143, 0x5a1}, + {0x200fa, 0x1}, + {0x1200fa, 0x1}, + {0x2200fa, 0x1}, + {0x20019, 0x1}, + {0x120019, 0x1}, + {0x220019, 0x1}, + {0x200f0, 0x660}, + {0x200f1, 0x0}, + {0x200f2, 0x4444}, + {0x200f3, 0x8888}, + {0x200f4, 0x5665}, + {0x200f5, 0x0}, + {0x200f6, 0x0}, + {0x200f7, 0xf000}, + {0x20025, 0x0}, + {0x2002d, 0x0}, + {0x12002d, 0x0}, + {0x22002d, 0x0}, + {0x200c7, 0x21}, + {0x1200c7, 0x21}, + {0x2200c7, 0x21}, + {0x200ca, 0x24}, + {0x1200ca, 0x24}, + {0x2200ca, 0x24}, +}; + +/* ddr phy trained csr */ +struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + { 0x200b2, 0x0 }, + { 0x1200b2, 0x0 }, + { 0x2200b2, 0x0 }, + { 0x200cb, 0x0 }, + { 0x10043, 0x0 }, + { 0x110043, 0x0 }, + { 0x210043, 0x0 }, + { 0x10143, 0x0 }, + { 0x110143, 0x0 }, + { 0x210143, 0x0 }, + { 0x11043, 0x0 }, + { 0x111043, 0x0 }, + { 0x211043, 0x0 }, + { 0x11143, 0x0 }, + { 0x111143, 0x0 }, + { 0x211143, 0x0 }, + { 0x12043, 0x0 }, + { 0x112043, 0x0 }, + { 0x212043, 0x0 }, + { 0x12143, 0x0 }, + { 0x112143, 0x0 }, + { 0x212143, 0x0 }, + { 0x13043, 0x0 }, + { 0x113043, 0x0 }, + { 0x213043, 0x0 }, + { 0x13143, 0x0 }, + { 0x113143, 0x0 }, + { 0x213143, 0x0 }, + { 0x80, 0x0 }, + { 0x100080, 0x0 }, + { 0x200080, 0x0 }, + { 0x1080, 0x0 }, + { 0x101080, 0x0 }, + { 0x201080, 0x0 }, + { 0x2080, 0x0 }, + { 0x102080, 0x0 }, + { 0x202080, 0x0 }, + { 0x3080, 0x0 }, + { 0x103080, 0x0 }, + { 0x203080, 0x0 }, + { 0x4080, 0x0 }, + { 0x104080, 0x0 }, + { 0x204080, 0x0 }, + { 0x5080, 0x0 }, + { 0x105080, 0x0 }, + { 0x205080, 0x0 }, + { 0x6080, 0x0 }, + { 0x106080, 0x0 }, + { 0x206080, 0x0 }, + { 0x7080, 0x0 }, + { 0x107080, 0x0 }, + { 0x207080, 0x0 }, + { 0x8080, 0x0 }, + { 0x108080, 0x0 }, + { 0x208080, 0x0 }, + { 0x9080, 0x0 }, + { 0x109080, 0x0 }, + { 0x209080, 0x0 }, + { 0x10080, 0x0 }, + { 0x110080, 0x0 }, + { 0x210080, 0x0 }, + { 0x10180, 0x0 }, + { 0x110180, 0x0 }, + { 0x210180, 0x0 }, + { 0x11080, 0x0 }, + { 0x111080, 0x0 }, + { 0x211080, 0x0 }, + { 0x11180, 0x0 }, + { 0x111180, 0x0 }, + { 0x211180, 0x0 }, + { 0x12080, 0x0 }, + { 0x112080, 0x0 }, + { 0x212080, 0x0 }, + { 0x12180, 0x0 }, + { 0x112180, 0x0 }, + { 0x212180, 0x0 }, + { 0x13080, 0x0 }, + { 0x113080, 0x0 }, + { 0x213080, 0x0 }, + { 0x13180, 0x0 }, + { 0x113180, 0x0 }, + { 0x213180, 0x0 }, + { 0x10081, 0x0 }, + { 0x110081, 0x0 }, + { 0x210081, 0x0 }, + { 0x10181, 0x0 }, + { 0x110181, 0x0 }, + { 0x210181, 0x0 }, + { 0x11081, 0x0 }, + { 0x111081, 0x0 }, + { 0x211081, 0x0 }, + { 0x11181, 0x0 }, + { 0x111181, 0x0 }, + { 0x211181, 0x0 }, + { 0x12081, 0x0 }, + { 0x112081, 0x0 }, + { 0x212081, 0x0 }, + { 0x12181, 0x0 }, + { 0x112181, 0x0 }, + { 0x212181, 0x0 }, + { 0x13081, 0x0 }, + { 0x113081, 0x0 }, + { 0x213081, 0x0 }, + { 0x13181, 0x0 }, + { 0x113181, 0x0 }, + { 0x213181, 0x0 }, + { 0x100d0, 0x0 }, + { 0x1100d0, 0x0 }, + { 0x2100d0, 0x0 }, + { 0x101d0, 0x0 }, + { 0x1101d0, 0x0 }, + { 0x2101d0, 0x0 }, + { 0x110d0, 0x0 }, + { 0x1110d0, 0x0 }, + { 0x2110d0, 0x0 }, + { 0x111d0, 0x0 }, + { 0x1111d0, 0x0 }, + { 0x2111d0, 0x0 }, + { 0x120d0, 0x0 }, + { 0x1120d0, 0x0 }, + { 0x2120d0, 0x0 }, + { 0x121d0, 0x0 }, + { 0x1121d0, 0x0 }, + { 0x2121d0, 0x0 }, + { 0x130d0, 0x0 }, + { 0x1130d0, 0x0 }, + { 0x2130d0, 0x0 }, + { 0x131d0, 0x0 }, + { 0x1131d0, 0x0 }, + { 0x2131d0, 0x0 }, + { 0x100d1, 0x0 }, + { 0x1100d1, 0x0 }, + { 0x2100d1, 0x0 }, + { 0x101d1, 0x0 }, + { 0x1101d1, 0x0 }, + { 0x2101d1, 0x0 }, + { 0x110d1, 0x0 }, + { 0x1110d1, 0x0 }, + { 0x2110d1, 0x0 }, + { 0x111d1, 0x0 }, + { 0x1111d1, 0x0 }, + { 0x2111d1, 0x0 }, + { 0x120d1, 0x0 }, + { 0x1120d1, 0x0 }, + { 0x2120d1, 0x0 }, + { 0x121d1, 0x0 }, + { 0x1121d1, 0x0 }, + { 0x2121d1, 0x0 }, + { 0x130d1, 0x0 }, + { 0x1130d1, 0x0 }, + { 0x2130d1, 0x0 }, + { 0x131d1, 0x0 }, + { 0x1131d1, 0x0 }, + { 0x2131d1, 0x0 }, + { 0x10068, 0x0 }, + { 0x10168, 0x0 }, + { 0x10268, 0x0 }, + { 0x10368, 0x0 }, + { 0x10468, 0x0 }, + { 0x10568, 0x0 }, + { 0x10668, 0x0 }, + { 0x10768, 0x0 }, + { 0x10868, 0x0 }, + { 0x11068, 0x0 }, + { 0x11168, 0x0 }, + { 0x11268, 0x0 }, + { 0x11368, 0x0 }, + { 0x11468, 0x0 }, + { 0x11568, 0x0 }, + { 0x11668, 0x0 }, + { 0x11768, 0x0 }, + { 0x11868, 0x0 }, + { 0x12068, 0x0 }, + { 0x12168, 0x0 }, + { 0x12268, 0x0 }, + { 0x12368, 0x0 }, + { 0x12468, 0x0 }, + { 0x12568, 0x0 }, + { 0x12668, 0x0 }, + { 0x12768, 0x0 }, + { 0x12868, 0x0 }, + { 0x13068, 0x0 }, + { 0x13168, 0x0 }, + { 0x13268, 0x0 }, + { 0x13368, 0x0 }, + { 0x13468, 0x0 }, + { 0x13568, 0x0 }, + { 0x13668, 0x0 }, + { 0x13768, 0x0 }, + { 0x13868, 0x0 }, + { 0x10069, 0x0 }, + { 0x10169, 0x0 }, + { 0x10269, 0x0 }, + { 0x10369, 0x0 }, + { 0x10469, 0x0 }, + { 0x10569, 0x0 }, + { 0x10669, 0x0 }, + { 0x10769, 0x0 }, + { 0x10869, 0x0 }, + { 0x11069, 0x0 }, + { 0x11169, 0x0 }, + { 0x11269, 0x0 }, + { 0x11369, 0x0 }, + { 0x11469, 0x0 }, + { 0x11569, 0x0 }, + { 0x11669, 0x0 }, + { 0x11769, 0x0 }, + { 0x11869, 0x0 }, + { 0x12069, 0x0 }, + { 0x12169, 0x0 }, + { 0x12269, 0x0 }, + { 0x12369, 0x0 }, + { 0x12469, 0x0 }, + { 0x12569, 0x0 }, + { 0x12669, 0x0 }, + { 0x12769, 0x0 }, + { 0x12869, 0x0 }, + { 0x13069, 0x0 }, + { 0x13169, 0x0 }, + { 0x13269, 0x0 }, + { 0x13369, 0x0 }, + { 0x13469, 0x0 }, + { 0x13569, 0x0 }, + { 0x13669, 0x0 }, + { 0x13769, 0x0 }, + { 0x13869, 0x0 }, + { 0x1008c, 0x0 }, + { 0x11008c, 0x0 }, + { 0x21008c, 0x0 }, + { 0x1018c, 0x0 }, + { 0x11018c, 0x0 }, + { 0x21018c, 0x0 }, + { 0x1108c, 0x0 }, + { 0x11108c, 0x0 }, + { 0x21108c, 0x0 }, + { 0x1118c, 0x0 }, + { 0x11118c, 0x0 }, + { 0x21118c, 0x0 }, + { 0x1208c, 0x0 }, + { 0x11208c, 0x0 }, + { 0x21208c, 0x0 }, + { 0x1218c, 0x0 }, + { 0x11218c, 0x0 }, + { 0x21218c, 0x0 }, + { 0x1308c, 0x0 }, + { 0x11308c, 0x0 }, + { 0x21308c, 0x0 }, + { 0x1318c, 0x0 }, + { 0x11318c, 0x0 }, + { 0x21318c, 0x0 }, + { 0x1008d, 0x0 }, + { 0x11008d, 0x0 }, + { 0x21008d, 0x0 }, + { 0x1018d, 0x0 }, + { 0x11018d, 0x0 }, + { 0x21018d, 0x0 }, + { 0x1108d, 0x0 }, + { 0x11108d, 0x0 }, + { 0x21108d, 0x0 }, + { 0x1118d, 0x0 }, + { 0x11118d, 0x0 }, + { 0x21118d, 0x0 }, + { 0x1208d, 0x0 }, + { 0x11208d, 0x0 }, + { 0x21208d, 0x0 }, + { 0x1218d, 0x0 }, + { 0x11218d, 0x0 }, + { 0x21218d, 0x0 }, + { 0x1308d, 0x0 }, + { 0x11308d, 0x0 }, + { 0x21308d, 0x0 }, + { 0x1318d, 0x0 }, + { 0x11318d, 0x0 }, + { 0x21318d, 0x0 }, + { 0x100c0, 0x0 }, + { 0x1100c0, 0x0 }, + { 0x2100c0, 0x0 }, + { 0x101c0, 0x0 }, + { 0x1101c0, 0x0 }, + { 0x2101c0, 0x0 }, + { 0x102c0, 0x0 }, + { 0x1102c0, 0x0 }, + { 0x2102c0, 0x0 }, + { 0x103c0, 0x0 }, + { 0x1103c0, 0x0 }, + { 0x2103c0, 0x0 }, + { 0x104c0, 0x0 }, + { 0x1104c0, 0x0 }, + { 0x2104c0, 0x0 }, + { 0x105c0, 0x0 }, + { 0x1105c0, 0x0 }, + { 0x2105c0, 0x0 }, + { 0x106c0, 0x0 }, + { 0x1106c0, 0x0 }, + { 0x2106c0, 0x0 }, + { 0x107c0, 0x0 }, + { 0x1107c0, 0x0 }, + { 0x2107c0, 0x0 }, + { 0x108c0, 0x0 }, + { 0x1108c0, 0x0 }, + { 0x2108c0, 0x0 }, + { 0x110c0, 0x0 }, + { 0x1110c0, 0x0 }, + { 0x2110c0, 0x0 }, + { 0x111c0, 0x0 }, + { 0x1111c0, 0x0 }, + { 0x2111c0, 0x0 }, + { 0x112c0, 0x0 }, + { 0x1112c0, 0x0 }, + { 0x2112c0, 0x0 }, + { 0x113c0, 0x0 }, + { 0x1113c0, 0x0 }, + { 0x2113c0, 0x0 }, + { 0x114c0, 0x0 }, + { 0x1114c0, 0x0 }, + { 0x2114c0, 0x0 }, + { 0x115c0, 0x0 }, + { 0x1115c0, 0x0 }, + { 0x2115c0, 0x0 }, + { 0x116c0, 0x0 }, + { 0x1116c0, 0x0 }, + { 0x2116c0, 0x0 }, + { 0x117c0, 0x0 }, + { 0x1117c0, 0x0 }, + { 0x2117c0, 0x0 }, + { 0x118c0, 0x0 }, + { 0x1118c0, 0x0 }, + { 0x2118c0, 0x0 }, + { 0x120c0, 0x0 }, + { 0x1120c0, 0x0 }, + { 0x2120c0, 0x0 }, + { 0x121c0, 0x0 }, + { 0x1121c0, 0x0 }, + { 0x2121c0, 0x0 }, + { 0x122c0, 0x0 }, + { 0x1122c0, 0x0 }, + { 0x2122c0, 0x0 }, + { 0x123c0, 0x0 }, + { 0x1123c0, 0x0 }, + { 0x2123c0, 0x0 }, + { 0x124c0, 0x0 }, + { 0x1124c0, 0x0 }, + { 0x2124c0, 0x0 }, + { 0x125c0, 0x0 }, + { 0x1125c0, 0x0 }, + { 0x2125c0, 0x0 }, + { 0x126c0, 0x0 }, + { 0x1126c0, 0x0 }, + { 0x2126c0, 0x0 }, + { 0x127c0, 0x0 }, + { 0x1127c0, 0x0 }, + { 0x2127c0, 0x0 }, + { 0x128c0, 0x0 }, + { 0x1128c0, 0x0 }, + { 0x2128c0, 0x0 }, + { 0x130c0, 0x0 }, + { 0x1130c0, 0x0 }, + { 0x2130c0, 0x0 }, + { 0x131c0, 0x0 }, + { 0x1131c0, 0x0 }, + { 0x2131c0, 0x0 }, + { 0x132c0, 0x0 }, + { 0x1132c0, 0x0 }, + { 0x2132c0, 0x0 }, + { 0x133c0, 0x0 }, + { 0x1133c0, 0x0 }, + { 0x2133c0, 0x0 }, + { 0x134c0, 0x0 }, + { 0x1134c0, 0x0 }, + { 0x2134c0, 0x0 }, + { 0x135c0, 0x0 }, + { 0x1135c0, 0x0 }, + { 0x2135c0, 0x0 }, + { 0x136c0, 0x0 }, + { 0x1136c0, 0x0 }, + { 0x2136c0, 0x0 }, + { 0x137c0, 0x0 }, + { 0x1137c0, 0x0 }, + { 0x2137c0, 0x0 }, + { 0x138c0, 0x0 }, + { 0x1138c0, 0x0 }, + { 0x2138c0, 0x0 }, + { 0x100c1, 0x0 }, + { 0x1100c1, 0x0 }, + { 0x2100c1, 0x0 }, + { 0x101c1, 0x0 }, + { 0x1101c1, 0x0 }, + { 0x2101c1, 0x0 }, + { 0x102c1, 0x0 }, + { 0x1102c1, 0x0 }, + { 0x2102c1, 0x0 }, + { 0x103c1, 0x0 }, + { 0x1103c1, 0x0 }, + { 0x2103c1, 0x0 }, + { 0x104c1, 0x0 }, + { 0x1104c1, 0x0 }, + { 0x2104c1, 0x0 }, + { 0x105c1, 0x0 }, + { 0x1105c1, 0x0 }, + { 0x2105c1, 0x0 }, + { 0x106c1, 0x0 }, + { 0x1106c1, 0x0 }, + { 0x2106c1, 0x0 }, + { 0x107c1, 0x0 }, + { 0x1107c1, 0x0 }, + { 0x2107c1, 0x0 }, + { 0x108c1, 0x0 }, + { 0x1108c1, 0x0 }, + { 0x2108c1, 0x0 }, + { 0x110c1, 0x0 }, + { 0x1110c1, 0x0 }, + { 0x2110c1, 0x0 }, + { 0x111c1, 0x0 }, + { 0x1111c1, 0x0 }, + { 0x2111c1, 0x0 }, + { 0x112c1, 0x0 }, + { 0x1112c1, 0x0 }, + { 0x2112c1, 0x0 }, + { 0x113c1, 0x0 }, + { 0x1113c1, 0x0 }, + { 0x2113c1, 0x0 }, + { 0x114c1, 0x0 }, + { 0x1114c1, 0x0 }, + { 0x2114c1, 0x0 }, + { 0x115c1, 0x0 }, + { 0x1115c1, 0x0 }, + { 0x2115c1, 0x0 }, + { 0x116c1, 0x0 }, + { 0x1116c1, 0x0 }, + { 0x2116c1, 0x0 }, + { 0x117c1, 0x0 }, + { 0x1117c1, 0x0 }, + { 0x2117c1, 0x0 }, + { 0x118c1, 0x0 }, + { 0x1118c1, 0x0 }, + { 0x2118c1, 0x0 }, + { 0x120c1, 0x0 }, + { 0x1120c1, 0x0 }, + { 0x2120c1, 0x0 }, + { 0x121c1, 0x0 }, + { 0x1121c1, 0x0 }, + { 0x2121c1, 0x0 }, + { 0x122c1, 0x0 }, + { 0x1122c1, 0x0 }, + { 0x2122c1, 0x0 }, + { 0x123c1, 0x0 }, + { 0x1123c1, 0x0 }, + { 0x2123c1, 0x0 }, + { 0x124c1, 0x0 }, + { 0x1124c1, 0x0 }, + { 0x2124c1, 0x0 }, + { 0x125c1, 0x0 }, + { 0x1125c1, 0x0 }, + { 0x2125c1, 0x0 }, + { 0x126c1, 0x0 }, + { 0x1126c1, 0x0 }, + { 0x2126c1, 0x0 }, + { 0x127c1, 0x0 }, + { 0x1127c1, 0x0 }, + { 0x2127c1, 0x0 }, + { 0x128c1, 0x0 }, + { 0x1128c1, 0x0 }, + { 0x2128c1, 0x0 }, + { 0x130c1, 0x0 }, + { 0x1130c1, 0x0 }, + { 0x2130c1, 0x0 }, + { 0x131c1, 0x0 }, + { 0x1131c1, 0x0 }, + { 0x2131c1, 0x0 }, + { 0x132c1, 0x0 }, + { 0x1132c1, 0x0 }, + { 0x2132c1, 0x0 }, + { 0x133c1, 0x0 }, + { 0x1133c1, 0x0 }, + { 0x2133c1, 0x0 }, + { 0x134c1, 0x0 }, + { 0x1134c1, 0x0 }, + { 0x2134c1, 0x0 }, + { 0x135c1, 0x0 }, + { 0x1135c1, 0x0 }, + { 0x2135c1, 0x0 }, + { 0x136c1, 0x0 }, + { 0x1136c1, 0x0 }, + { 0x2136c1, 0x0 }, + { 0x137c1, 0x0 }, + { 0x1137c1, 0x0 }, + { 0x2137c1, 0x0 }, + { 0x138c1, 0x0 }, + { 0x1138c1, 0x0 }, + { 0x2138c1, 0x0 }, + { 0x10020, 0x0 }, + { 0x110020, 0x0 }, + { 0x210020, 0x0 }, + { 0x11020, 0x0 }, + { 0x111020, 0x0 }, + { 0x211020, 0x0 }, + { 0x12020, 0x0 }, + { 0x112020, 0x0 }, + { 0x212020, 0x0 }, + { 0x13020, 0x0 }, + { 0x113020, 0x0 }, + { 0x213020, 0x0 }, + { 0x20072, 0x0 }, + { 0x20073, 0x0 }, + { 0x20074, 0x0 }, + { 0x100aa, 0x0 }, + { 0x110aa, 0x0 }, + { 0x120aa, 0x0 }, + { 0x130aa, 0x0 }, + { 0x20010, 0x0 }, + { 0x120010, 0x0 }, + { 0x220010, 0x0 }, + { 0x20011, 0x0 }, + { 0x120011, 0x0 }, + { 0x220011, 0x0 }, + { 0x100ae, 0x0 }, + { 0x1100ae, 0x0 }, + { 0x2100ae, 0x0 }, + { 0x100af, 0x0 }, + { 0x1100af, 0x0 }, + { 0x2100af, 0x0 }, + { 0x110ae, 0x0 }, + { 0x1110ae, 0x0 }, + { 0x2110ae, 0x0 }, + { 0x110af, 0x0 }, + { 0x1110af, 0x0 }, + { 0x2110af, 0x0 }, + { 0x120ae, 0x0 }, + { 0x1120ae, 0x0 }, + { 0x2120ae, 0x0 }, + { 0x120af, 0x0 }, + { 0x1120af, 0x0 }, + { 0x2120af, 0x0 }, + { 0x130ae, 0x0 }, + { 0x1130ae, 0x0 }, + { 0x2130ae, 0x0 }, + { 0x130af, 0x0 }, + { 0x1130af, 0x0 }, + { 0x2130af, 0x0 }, + { 0x20020, 0x0 }, + { 0x120020, 0x0 }, + { 0x220020, 0x0 }, + { 0x100a0, 0x0 }, + { 0x100a1, 0x0 }, + { 0x100a2, 0x0 }, + { 0x100a3, 0x0 }, + { 0x100a4, 0x0 }, + { 0x100a5, 0x0 }, + { 0x100a6, 0x0 }, + { 0x100a7, 0x0 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x0 }, + { 0x110a2, 0x0 }, + { 0x110a3, 0x0 }, + { 0x110a4, 0x0 }, + { 0x110a5, 0x0 }, + { 0x110a6, 0x0 }, + { 0x110a7, 0x0 }, + { 0x120a0, 0x0 }, + { 0x120a1, 0x0 }, + { 0x120a2, 0x0 }, + { 0x120a3, 0x0 }, + { 0x120a4, 0x0 }, + { 0x120a5, 0x0 }, + { 0x120a6, 0x0 }, + { 0x120a7, 0x0 }, + { 0x130a0, 0x0 }, + { 0x130a1, 0x0 }, + { 0x130a2, 0x0 }, + { 0x130a3, 0x0 }, + { 0x130a4, 0x0 }, + { 0x130a5, 0x0 }, + { 0x130a6, 0x0 }, + { 0x130a7, 0x0 }, + { 0x2007c, 0x0 }, + { 0x12007c, 0x0 }, + { 0x22007c, 0x0 }, + { 0x2007d, 0x0 }, + { 0x12007d, 0x0 }, + { 0x22007d, 0x0 }, + { 0x400fd, 0x0 }, + { 0x400c0, 0x0 }, + { 0x90201, 0x0 }, + { 0x190201, 0x0 }, + { 0x290201, 0x0 }, + { 0x90202, 0x0 }, + { 0x190202, 0x0 }, + { 0x290202, 0x0 }, + { 0x90203, 0x0 }, + { 0x190203, 0x0 }, + { 0x290203, 0x0 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x90205, 0x0 }, + { 0x190205, 0x0 }, + { 0x290205, 0x0 }, + { 0x90206, 0x0 }, + { 0x190206, 0x0 }, + { 0x290206, 0x0 }, + { 0x90207, 0x0 }, + { 0x190207, 0x0 }, + { 0x290207, 0x0 }, + { 0x90208, 0x0 }, + { 0x190208, 0x0 }, + { 0x290208, 0x0 }, + { 0x10062, 0x0 }, + { 0x10162, 0x0 }, + { 0x10262, 0x0 }, + { 0x10362, 0x0 }, + { 0x10462, 0x0 }, + { 0x10562, 0x0 }, + { 0x10662, 0x0 }, + { 0x10762, 0x0 }, + { 0x10862, 0x0 }, + { 0x11062, 0x0 }, + { 0x11162, 0x0 }, + { 0x11262, 0x0 }, + { 0x11362, 0x0 }, + { 0x11462, 0x0 }, + { 0x11562, 0x0 }, + { 0x11662, 0x0 }, + { 0x11762, 0x0 }, + { 0x11862, 0x0 }, + { 0x12062, 0x0 }, + { 0x12162, 0x0 }, + { 0x12262, 0x0 }, + { 0x12362, 0x0 }, + { 0x12462, 0x0 }, + { 0x12562, 0x0 }, + { 0x12662, 0x0 }, + { 0x12762, 0x0 }, + { 0x12862, 0x0 }, + { 0x13062, 0x0 }, + { 0x13162, 0x0 }, + { 0x13262, 0x0 }, + { 0x13362, 0x0 }, + { 0x13462, 0x0 }, + { 0x13562, 0x0 }, + { 0x13662, 0x0 }, + { 0x13762, 0x0 }, + { 0x13862, 0x0 }, + { 0x20077, 0x0 }, + { 0x10001, 0x0 }, + { 0x11001, 0x0 }, + { 0x12001, 0x0 }, + { 0x13001, 0x0 }, + { 0x10040, 0x0 }, + { 0x10140, 0x0 }, + { 0x10240, 0x0 }, + { 0x10340, 0x0 }, + { 0x10440, 0x0 }, + { 0x10540, 0x0 }, + { 0x10640, 0x0 }, + { 0x10740, 0x0 }, + { 0x10840, 0x0 }, + { 0x10030, 0x0 }, + { 0x10130, 0x0 }, + { 0x10230, 0x0 }, + { 0x10330, 0x0 }, + { 0x10430, 0x0 }, + { 0x10530, 0x0 }, + { 0x10630, 0x0 }, + { 0x10730, 0x0 }, + { 0x10830, 0x0 }, + { 0x11040, 0x0 }, + { 0x11140, 0x0 }, + { 0x11240, 0x0 }, + { 0x11340, 0x0 }, + { 0x11440, 0x0 }, + { 0x11540, 0x0 }, + { 0x11640, 0x0 }, + { 0x11740, 0x0 }, + { 0x11840, 0x0 }, + { 0x11030, 0x0 }, + { 0x11130, 0x0 }, + { 0x11230, 0x0 }, + { 0x11330, 0x0 }, + { 0x11430, 0x0 }, + { 0x11530, 0x0 }, + { 0x11630, 0x0 }, + { 0x11730, 0x0 }, + { 0x11830, 0x0 }, + { 0x12040, 0x0 }, + { 0x12140, 0x0 }, + { 0x12240, 0x0 }, + { 0x12340, 0x0 }, + { 0x12440, 0x0 }, + { 0x12540, 0x0 }, + { 0x12640, 0x0 }, + { 0x12740, 0x0 }, + { 0x12840, 0x0 }, + { 0x12030, 0x0 }, + { 0x12130, 0x0 }, + { 0x12230, 0x0 }, + { 0x12330, 0x0 }, + { 0x12430, 0x0 }, + { 0x12530, 0x0 }, + { 0x12630, 0x0 }, + { 0x12730, 0x0 }, + { 0x12830, 0x0 }, + { 0x13040, 0x0 }, + { 0x13140, 0x0 }, + { 0x13240, 0x0 }, + { 0x13340, 0x0 }, + { 0x13440, 0x0 }, + { 0x13540, 0x0 }, + { 0x13640, 0x0 }, + { 0x13740, 0x0 }, + { 0x13840, 0x0 }, + { 0x13030, 0x0 }, + { 0x13130, 0x0 }, + { 0x13230, 0x0 }, + { 0x13330, 0x0 }, + { 0x13430, 0x0 }, + { 0x13530, 0x0 }, + { 0x13630, 0x0 }, + { 0x13730, 0x0 }, + { 0x13830, 0x0 }, +}; + +/* P0 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp0_cfg[] = { + {0xd0000, 0x0}, + {0x54003, 0xbb8}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x131f}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400d, 0x100}, + {0x54012, 0x110}, + {0x54019, 0x2dd4}, + {0x5401a, 0x21}, + {0x5401b, 0x4d44}, + {0x5401c, 0x4d00}, + {0x5401e, 0x14}, + {0x5401f, 0x2dd4}, + {0x54020, 0x21}, + {0x54021, 0x4d44}, + {0x54022, 0x4d00}, + {0x54024, 0x14}, + {0x5402b, 0x1000}, + {0x5402c, 0x1}, + {0x54032, 0xd400}, + {0x54033, 0x212d}, + {0x54034, 0x4400}, + {0x54035, 0x4d}, + {0x54036, 0x4d}, + {0x54037, 0x1400}, + {0x54038, 0xd400}, + {0x54039, 0x212d}, + {0x5403a, 0x4400}, + {0x5403b, 0x4d}, + {0x5403c, 0x4d}, + {0x5403d, 0x1400}, + {0xd0000, 0x1}, +}; + +/* P1 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp1_cfg[] = { + {0xd0000, 0x0}, + {0x54002, 0x101}, + {0x54003, 0x190}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x121f}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400d, 0x100}, + {0x54012, 0x110}, + {0x54019, 0x84}, + {0x5401a, 0x31}, + {0x5401b, 0x4d66}, + {0x5401c, 0x4d00}, + {0x5401e, 0x16}, + {0x5401f, 0x84}, + {0x54020, 0x31}, + {0x54021, 0x4d66}, + {0x54022, 0x4d00}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x1}, + {0x54032, 0x8400}, + {0x54033, 0x3100}, + {0x54034, 0x6600}, + {0x54035, 0x4d}, + {0x54036, 0x4d}, + {0x54037, 0x1600}, + {0x54038, 0x8400}, + {0x54039, 0x3100}, + {0x5403a, 0x6600}, + {0x5403b, 0x4d}, + {0x5403c, 0x4d}, + {0x5403d, 0x1600}, + {0xd0000, 0x1}, +}; + +/* P2 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp2_cfg[] = { + {0xd0000, 0x0}, + {0x54002, 0x102}, + {0x54003, 0x64}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x121f}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400d, 0x100}, + {0x54012, 0x110}, + {0x54019, 0x84}, + {0x5401a, 0x31}, + {0x5401b, 0x4d66}, + {0x5401c, 0x4d00}, + {0x5401e, 0x16}, + {0x5401f, 0x84}, + {0x54020, 0x31}, + {0x54021, 0x4d66}, + {0x54022, 0x4d00}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x1}, + {0x54032, 0x8400}, + {0x54033, 0x3100}, + {0x54034, 0x6600}, + {0x54035, 0x4d}, + {0x54036, 0x4d}, + {0x54037, 0x1600}, + {0x54038, 0x8400}, + {0x54039, 0x3100}, + {0x5403a, 0x6600}, + {0x5403b, 0x4d}, + {0x5403c, 0x4d}, + {0x5403d, 0x1600}, + {0xd0000, 0x1}, +}; + +/* P0 2D message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + {0xd0000, 0x0}, + {0x54003, 0xbb8}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x61}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400f, 0x100}, + {0x54010, 0x1f7f}, + {0x54012, 0x110}, + {0x54019, 0x2dd4}, + {0x5401a, 0x21}, + {0x5401b, 0x4d44}, + {0x5401c, 0x4d00}, + {0x5401e, 0x14}, + {0x5401f, 0x2dd4}, + {0x54020, 0x21}, + {0x54021, 0x4d44}, + {0x54022, 0x4d00}, + {0x54024, 0x14}, + {0x5402b, 0x1000}, + {0x5402c, 0x1}, + {0x54032, 0xd400}, + {0x54033, 0x212d}, + {0x54034, 0x4400}, + {0x54035, 0x4d}, + {0x54036, 0x4d}, + {0x54037, 0x1400}, + {0x54038, 0xd400}, + {0x54039, 0x212d}, + {0x5403a, 0x4400}, + {0x5403b, 0x4d}, + {0x5403c, 0x4d}, + {0x5403d, 0x1400}, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +struct dram_cfg_param ddr_phy_pie[] = { + {0xd0000, 0x0}, + {0x90000, 0x10}, + {0x90001, 0x400}, + {0x90002, 0x10e}, + {0x90003, 0x0}, + {0x90004, 0x0}, + {0x90005, 0x8}, + {0x90029, 0xb}, + {0x9002a, 0x480}, + {0x9002b, 0x109}, + {0x9002c, 0x8}, + {0x9002d, 0x448}, + {0x9002e, 0x139}, + {0x9002f, 0x8}, + {0x90030, 0x478}, + {0x90031, 0x109}, + {0x90032, 0x0}, + {0x90033, 0xe8}, + {0x90034, 0x109}, + {0x90035, 0x2}, + {0x90036, 0x10}, + {0x90037, 0x139}, + {0x90038, 0xf}, + {0x90039, 0x7c0}, + {0x9003a, 0x139}, + {0x9003b, 0x44}, + {0x9003c, 0x630}, + {0x9003d, 0x159}, + {0x9003e, 0x14f}, + {0x9003f, 0x630}, + {0x90040, 0x159}, + {0x90041, 0x47}, + {0x90042, 0x630}, + {0x90043, 0x149}, + {0x90044, 0x4f}, + {0x90045, 0x630}, + {0x90046, 0x179}, + {0x90047, 0x8}, + {0x90048, 0xe0}, + {0x90049, 0x109}, + {0x9004a, 0x0}, + {0x9004b, 0x7c8}, + {0x9004c, 0x109}, + {0x9004d, 0x0}, + {0x9004e, 0x1}, + {0x9004f, 0x8}, + {0x90050, 0x0}, + {0x90051, 0x45a}, + {0x90052, 0x9}, + {0x90053, 0x0}, + {0x90054, 0x448}, + {0x90055, 0x109}, + {0x90056, 0x40}, + {0x90057, 0x630}, + {0x90058, 0x179}, + {0x90059, 0x1}, + {0x9005a, 0x618}, + {0x9005b, 0x109}, + {0x9005c, 0x40c0}, + {0x9005d, 0x630}, + {0x9005e, 0x149}, + {0x9005f, 0x8}, + {0x90060, 0x4}, + {0x90061, 0x48}, + {0x90062, 0x4040}, + {0x90063, 0x630}, + {0x90064, 0x149}, + {0x90065, 0x0}, + {0x90066, 0x4}, + {0x90067, 0x48}, + {0x90068, 0x40}, + {0x90069, 0x630}, + {0x9006a, 0x149}, + {0x9006b, 0x10}, + {0x9006c, 0x4}, + {0x9006d, 0x18}, + {0x9006e, 0x0}, + {0x9006f, 0x4}, + {0x90070, 0x78}, + {0x90071, 0x549}, + {0x90072, 0x630}, + {0x90073, 0x159}, + {0x90074, 0xd49}, + {0x90075, 0x630}, + {0x90076, 0x159}, + {0x90077, 0x94a}, + {0x90078, 0x630}, + {0x90079, 0x159}, + {0x9007a, 0x441}, + {0x9007b, 0x630}, + {0x9007c, 0x149}, + {0x9007d, 0x42}, + {0x9007e, 0x630}, + {0x9007f, 0x149}, + {0x90080, 0x1}, + {0x90081, 0x630}, + {0x90082, 0x149}, + {0x90083, 0x0}, + {0x90084, 0xe0}, + {0x90085, 0x109}, + {0x90086, 0xa}, + {0x90087, 0x10}, + {0x90088, 0x109}, + {0x90089, 0x9}, + {0x9008a, 0x3c0}, + {0x9008b, 0x149}, + {0x9008c, 0x9}, + {0x9008d, 0x3c0}, + {0x9008e, 0x159}, + {0x9008f, 0x18}, + {0x90090, 0x10}, + {0x90091, 0x109}, + {0x90092, 0x0}, + {0x90093, 0x3c0}, + {0x90094, 0x109}, + {0x90095, 0x18}, + {0x90096, 0x4}, + {0x90097, 0x48}, + {0x90098, 0x18}, + {0x90099, 0x4}, + {0x9009a, 0x58}, + {0x9009b, 0xa}, + {0x9009c, 0x10}, + {0x9009d, 0x109}, + {0x9009e, 0x2}, + {0x9009f, 0x10}, + {0x900a0, 0x109}, + {0x900a1, 0x5}, + {0x900a2, 0x7c0}, + {0x900a3, 0x109}, + {0x900a4, 0x10}, + {0x900a5, 0x10}, + {0x900a6, 0x109}, + {0x40000, 0x811}, + {0x40020, 0x880}, + {0x40040, 0x0}, + {0x40060, 0x0}, + {0x40001, 0x4008}, + {0x40021, 0x83}, + {0x40041, 0x4f}, + {0x40061, 0x0}, + {0x40002, 0x4040}, + {0x40022, 0x83}, + {0x40042, 0x51}, + {0x40062, 0x0}, + {0x40003, 0x811}, + {0x40023, 0x880}, + {0x40043, 0x0}, + {0x40063, 0x0}, + {0x40004, 0x720}, + {0x40024, 0xf}, + {0x40044, 0x1740}, + {0x40064, 0x0}, + {0x40005, 0x16}, + {0x40025, 0x83}, + {0x40045, 0x4b}, + {0x40065, 0x0}, + {0x40006, 0x716}, + {0x40026, 0xf}, + {0x40046, 0x2001}, + {0x40066, 0x0}, + {0x40007, 0x716}, + {0x40027, 0xf}, + {0x40047, 0x2800}, + {0x40067, 0x0}, + {0x40008, 0x716}, + {0x40028, 0xf}, + {0x40048, 0xf00}, + {0x40068, 0x0}, + {0x40009, 0x720}, + {0x40029, 0xf}, + {0x40049, 0x1400}, + {0x40069, 0x0}, + {0x4000a, 0xe08}, + {0x4002a, 0xc15}, + {0x4004a, 0x0}, + {0x4006a, 0x0}, + {0x4000b, 0x623}, + {0x4002b, 0x15}, + {0x4004b, 0x0}, + {0x4006b, 0x0}, + {0x4000c, 0x4028}, + {0x4002c, 0x80}, + {0x4004c, 0x0}, + {0x4006c, 0x0}, + {0x4000d, 0xe08}, + {0x4002d, 0xc1a}, + {0x4004d, 0x0}, + {0x4006d, 0x0}, + {0x4000e, 0x623}, + {0x4002e, 0x1a}, + {0x4004e, 0x0}, + {0x4006e, 0x0}, + {0x4000f, 0x4040}, + {0x4002f, 0x80}, + {0x4004f, 0x0}, + {0x4006f, 0x0}, + {0x40010, 0x2604}, + {0x40030, 0x15}, + {0x40050, 0x0}, + {0x40070, 0x0}, + {0x40011, 0x708}, + {0x40031, 0x5}, + {0x40051, 0x0}, + {0x40071, 0x2002}, + {0x40012, 0x8}, + {0x40032, 0x80}, + {0x40052, 0x0}, + {0x40072, 0x0}, + {0x40013, 0x2604}, + {0x40033, 0x1a}, + {0x40053, 0x0}, + {0x40073, 0x0}, + {0x40014, 0x708}, + {0x40034, 0xa}, + {0x40054, 0x0}, + {0x40074, 0x2002}, + {0x40015, 0x4040}, + {0x40035, 0x80}, + {0x40055, 0x0}, + {0x40075, 0x0}, + {0x40016, 0x60a}, + {0x40036, 0x15}, + {0x40056, 0x1200}, + {0x40076, 0x0}, + {0x40017, 0x61a}, + {0x40037, 0x15}, + {0x40057, 0x1300}, + {0x40077, 0x0}, + {0x40018, 0x60a}, + {0x40038, 0x1a}, + {0x40058, 0x1200}, + {0x40078, 0x0}, + {0x40019, 0x642}, + {0x40039, 0x1a}, + {0x40059, 0x1300}, + {0x40079, 0x0}, + {0x4001a, 0x4808}, + {0x4003a, 0x880}, + {0x4005a, 0x0}, + {0x4007a, 0x0}, + {0x900a7, 0x0}, + {0x900a8, 0x790}, + {0x900a9, 0x11a}, + {0x900aa, 0x8}, + {0x900ab, 0x7aa}, + {0x900ac, 0x2a}, + {0x900ad, 0x10}, + {0x900ae, 0x7b2}, + {0x900af, 0x2a}, + {0x900b0, 0x0}, + {0x900b1, 0x7c8}, + {0x900b2, 0x109}, + {0x900b3, 0x10}, + {0x900b4, 0x2a8}, + {0x900b5, 0x129}, + {0x900b6, 0x8}, + {0x900b7, 0x370}, + {0x900b8, 0x129}, + {0x900b9, 0xa}, + {0x900ba, 0x3c8}, + {0x900bb, 0x1a9}, + {0x900bc, 0xc}, + {0x900bd, 0x408}, + {0x900be, 0x199}, + {0x900bf, 0x14}, + {0x900c0, 0x790}, + {0x900c1, 0x11a}, + {0x900c2, 0x8}, + {0x900c3, 0x4}, + {0x900c4, 0x18}, + {0x900c5, 0xe}, + {0x900c6, 0x408}, + {0x900c7, 0x199}, + {0x900c8, 0x8}, + {0x900c9, 0x8568}, + {0x900ca, 0x108}, + {0x900cb, 0x18}, + {0x900cc, 0x790}, + {0x900cd, 0x16a}, + {0x900ce, 0x8}, + {0x900cf, 0x1d8}, + {0x900d0, 0x169}, + {0x900d1, 0x10}, + {0x900d2, 0x8558}, + {0x900d3, 0x168}, + {0x900d4, 0x70}, + {0x900d5, 0x788}, + {0x900d6, 0x16a}, + {0x900d7, 0x1ff8}, + {0x900d8, 0x85a8}, + {0x900d9, 0x1e8}, + {0x900da, 0x50}, + {0x900db, 0x798}, + {0x900dc, 0x16a}, + {0x900dd, 0x60}, + {0x900de, 0x7a0}, + {0x900df, 0x16a}, + {0x900e0, 0x8}, + {0x900e1, 0x8310}, + {0x900e2, 0x168}, + {0x900e3, 0x8}, + {0x900e4, 0xa310}, + {0x900e5, 0x168}, + {0x900e6, 0xa}, + {0x900e7, 0x408}, + {0x900e8, 0x169}, + {0x900e9, 0x6e}, + {0x900ea, 0x0}, + {0x900eb, 0x68}, + {0x900ec, 0x0}, + {0x900ed, 0x408}, + {0x900ee, 0x169}, + {0x900ef, 0x0}, + {0x900f0, 0x8310}, + {0x900f1, 0x168}, + {0x900f2, 0x0}, + {0x900f3, 0xa310}, + {0x900f4, 0x168}, + {0x900f5, 0x1ff8}, + {0x900f6, 0x85a8}, + {0x900f7, 0x1e8}, + {0x900f8, 0x68}, + {0x900f9, 0x798}, + {0x900fa, 0x16a}, + {0x900fb, 0x78}, + {0x900fc, 0x7a0}, + {0x900fd, 0x16a}, + {0x900fe, 0x68}, + {0x900ff, 0x790}, + {0x90100, 0x16a}, + {0x90101, 0x8}, + {0x90102, 0x8b10}, + {0x90103, 0x168}, + {0x90104, 0x8}, + {0x90105, 0xab10}, + {0x90106, 0x168}, + {0x90107, 0xa}, + {0x90108, 0x408}, + {0x90109, 0x169}, + {0x9010a, 0x58}, + {0x9010b, 0x0}, + {0x9010c, 0x68}, + {0x9010d, 0x0}, + {0x9010e, 0x408}, + {0x9010f, 0x169}, + {0x90110, 0x0}, + {0x90111, 0x8b10}, + {0x90112, 0x168}, + {0x90113, 0x0}, + {0x90114, 0xab10}, + {0x90115, 0x168}, + {0x90116, 0x0}, + {0x90117, 0x1d8}, + {0x90118, 0x169}, + {0x90119, 0x80}, + {0x9011a, 0x790}, + {0x9011b, 0x16a}, + {0x9011c, 0x18}, + {0x9011d, 0x7aa}, + {0x9011e, 0x6a}, + {0x9011f, 0xa}, + {0x90120, 0x0}, + {0x90121, 0x1e9}, + {0x90122, 0x8}, + {0x90123, 0x8080}, + {0x90124, 0x108}, + {0x90125, 0xf}, + {0x90126, 0x408}, + {0x90127, 0x169}, + {0x90128, 0xc}, + {0x90129, 0x0}, + {0x9012a, 0x68}, + {0x9012b, 0x9}, + {0x9012c, 0x0}, + {0x9012d, 0x1a9}, + {0x9012e, 0x0}, + {0x9012f, 0x408}, + {0x90130, 0x169}, + {0x90131, 0x0}, + {0x90132, 0x8080}, + {0x90133, 0x108}, + {0x90134, 0x8}, + {0x90135, 0x7aa}, + {0x90136, 0x6a}, + {0x90137, 0x0}, + {0x90138, 0x8568}, + {0x90139, 0x108}, + {0x9013a, 0xb7}, + {0x9013b, 0x790}, + {0x9013c, 0x16a}, + {0x9013d, 0x1f}, + {0x9013e, 0x0}, + {0x9013f, 0x68}, + {0x90140, 0x8}, + {0x90141, 0x8558}, + {0x90142, 0x168}, + {0x90143, 0xf}, + {0x90144, 0x408}, + {0x90145, 0x169}, + {0x90146, 0xc}, + {0x90147, 0x0}, + {0x90148, 0x68}, + {0x90149, 0x0}, + {0x9014a, 0x408}, + {0x9014b, 0x169}, + {0x9014c, 0x0}, + {0x9014d, 0x8558}, + {0x9014e, 0x168}, + {0x9014f, 0x8}, + {0x90150, 0x3c8}, + {0x90151, 0x1a9}, + {0x90152, 0x3}, + {0x90153, 0x370}, + {0x90154, 0x129}, + {0x90155, 0x20}, + {0x90156, 0x2aa}, + {0x90157, 0x9}, + {0x90158, 0x0}, + {0x90159, 0x400}, + {0x9015a, 0x10e}, + {0x9015b, 0x8}, + {0x9015c, 0xe8}, + {0x9015d, 0x109}, + {0x9015e, 0x0}, + {0x9015f, 0x8140}, + {0x90160, 0x10c}, + {0x90161, 0x10}, + {0x90162, 0x8138}, + {0x90163, 0x10c}, + {0x90164, 0x8}, + {0x90165, 0x7c8}, + {0x90166, 0x101}, + {0x90167, 0x8}, + {0x90168, 0x0}, + {0x90169, 0x8}, + {0x9016a, 0x8}, + {0x9016b, 0x448}, + {0x9016c, 0x109}, + {0x9016d, 0xf}, + {0x9016e, 0x7c0}, + {0x9016f, 0x109}, + {0x90170, 0x0}, + {0x90171, 0xe8}, + {0x90172, 0x109}, + {0x90173, 0x47}, + {0x90174, 0x630}, + {0x90175, 0x109}, + {0x90176, 0x8}, + {0x90177, 0x618}, + {0x90178, 0x109}, + {0x90179, 0x8}, + {0x9017a, 0xe0}, + {0x9017b, 0x109}, + {0x9017c, 0x0}, + {0x9017d, 0x7c8}, + {0x9017e, 0x109}, + {0x9017f, 0x8}, + {0x90180, 0x8140}, + {0x90181, 0x10c}, + {0x90182, 0x0}, + {0x90183, 0x1}, + {0x90184, 0x8}, + {0x90185, 0x8}, + {0x90186, 0x4}, + {0x90187, 0x8}, + {0x90188, 0x8}, + {0x90189, 0x7c8}, + {0x9018a, 0x101}, + {0x90006, 0x0}, + {0x90007, 0x0}, + {0x90008, 0x8}, + {0x90009, 0x0}, + {0x9000a, 0x0}, + {0x9000b, 0x0}, + {0xd00e7, 0x400}, + {0x90017, 0x0}, + {0x9001f, 0x2a}, + {0x90026, 0x6a}, + {0x400d0, 0x0}, + {0x400d1, 0x101}, + {0x400d2, 0x105}, + {0x400d3, 0x107}, + {0x400d4, 0x10f}, + {0x400d5, 0x202}, + {0x400d6, 0x20a}, + {0x400d7, 0x20b}, + {0x2003a, 0x2}, + {0x2000b, 0x5d}, + {0x2000c, 0xbb}, + {0x2000d, 0x753}, + {0x2000e, 0x2c}, + {0x12000b, 0xc}, + {0x12000c, 0x19}, + {0x12000d, 0xfa}, + {0x12000e, 0x10}, + {0x22000b, 0x3}, + {0x22000c, 0x6}, + {0x22000d, 0x3e}, + {0x22000e, 0x10}, + {0x9000c, 0x0}, + {0x9000d, 0x173}, + {0x9000e, 0x60}, + {0x9000f, 0x6110}, + {0x90010, 0x2152}, + {0x90011, 0xdfbd}, + {0x90012, 0x60}, + {0x90013, 0x6152}, + {0x20010, 0x5a}, + {0x20011, 0x3}, + {0x120010, 0x5a}, + {0x120011, 0x3}, + {0x220010, 0x5a}, + {0x220011, 0x3}, + {0x40080, 0xe0}, + {0x40081, 0x12}, + {0x40082, 0xe0}, + {0x40083, 0x12}, + {0x40084, 0xe0}, + {0x40085, 0x12}, + {0x140080, 0xe0}, + {0x140081, 0x12}, + {0x140082, 0xe0}, + {0x140083, 0x12}, + {0x140084, 0xe0}, + {0x140085, 0x12}, + {0x240080, 0xe0}, + {0x240081, 0x12}, + {0x240082, 0xe0}, + {0x240083, 0x12}, + {0x240084, 0xe0}, + {0x240085, 0x12}, + {0x400fd, 0xf}, + {0x10011, 0x1}, + {0x10012, 0x1}, + {0x10013, 0x180}, + {0x10018, 0x1}, + {0x10002, 0x6209}, + {0x100b2, 0x1}, + {0x101b4, 0x1}, + {0x102b4, 0x1}, + {0x103b4, 0x1}, + {0x104b4, 0x1}, + {0x105b4, 0x1}, + {0x106b4, 0x1}, + {0x107b4, 0x1}, + {0x108b4, 0x1}, + {0x11011, 0x1}, + {0x11012, 0x1}, + {0x11013, 0x180}, + {0x11018, 0x1}, + {0x11002, 0x6209}, + {0x110b2, 0x1}, + {0x111b4, 0x1}, + {0x112b4, 0x1}, + {0x113b4, 0x1}, + {0x114b4, 0x1}, + {0x115b4, 0x1}, + {0x116b4, 0x1}, + {0x117b4, 0x1}, + {0x118b4, 0x1}, + {0x12011, 0x1}, + {0x12012, 0x1}, + {0x12013, 0x180}, + {0x12018, 0x1}, + {0x12002, 0x6209}, + {0x120b2, 0x1}, + {0x121b4, 0x1}, + {0x122b4, 0x1}, + {0x123b4, 0x1}, + {0x124b4, 0x1}, + {0x125b4, 0x1}, + {0x126b4, 0x1}, + {0x127b4, 0x1}, + {0x128b4, 0x1}, + {0x13011, 0x1}, + {0x13012, 0x1}, + {0x13013, 0x180}, + {0x13018, 0x1}, + {0x13002, 0x6209}, + {0x130b2, 0x1}, + {0x131b4, 0x1}, + {0x132b4, 0x1}, + {0x133b4, 0x1}, + {0x134b4, 0x1}, + {0x135b4, 0x1}, + {0x136b4, 0x1}, + {0x137b4, 0x1}, + {0x138b4, 0x1}, + {0x2003a, 0x2}, + {0xc0080, 0x2}, + {0xd0000, 0x1} +}; + +struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 3000mts 1D */ + .drate = 3000, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 400mts 1D */ + .drate = 400, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, + { + /* P2 100mts 1D */ + .drate = 100, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp2_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp2_cfg), + }, + { + /* P0 3000mts 2D */ + .drate = 3000, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info dram_timing = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 3000, 400, 100, }, +}; diff --git a/board/engicam/imx8mm/spl.c b/board/engicam/imx8mm/spl.c new file mode 100644 index 0000000000..f9be769ec5 --- /dev/null +++ b/board/engicam/imx8mm/spl.c @@ -0,0 +1,101 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020 Engicam s.r.l. + * Copyright (C) 2020 Amarula Solutions(India) + * Author: Jagan Teki jagan@amarulasolutions.com + */ + +#include <common.h> +#include <hang.h> +#include <init.h> +#include <log.h> +#include <spl.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm/arch/clock.h> +#include <asm/arch/imx8mm_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-imx/boot_mode.h> +#include <asm/arch/ddr.h> + +DECLARE_GLOBAL_DATA_PTR; + +int spl_board_boot_device(enum boot_device boot_dev_spl) +{ + switch (boot_dev_spl) { + case SD1_BOOT: + case SD2_BOOT: + case MMC2_BOOT: + return BOOT_DEVICE_MMC1; + case SD3_BOOT: + case MMC3_BOOT: + return BOOT_DEVICE_MMC2; + default: + return BOOT_DEVICE_NONE; + } +} + +static void spl_dram_init(void) +{ + ddr_init(&dram_timing); +} + +void spl_board_init(void) +{ + debug("Normal Boot\n"); +} + +#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + /* Just empty function now - can't decide what to choose */ + debug("%s: %s\n", __func__, name); + + return 0; +} +#endif + +#define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1) +#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) + +static iomux_v3_cfg_t const uart_pads[] = { + IMX8MM_PAD_UART2_RXD_UART2_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + IMX8MM_PAD_UART2_TXD_UART2_TX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +int board_early_init_f(void) +{ + imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); + + return 0; +} + +void board_init_f(ulong dummy) +{ + int ret; + + arch_cpu_init(); + + init_uart_clk(1); + + board_early_init_f(); + + timer_init(); + + preloader_console_init(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + ret = spl_early_init(); + if (ret) { + debug("spl_early_init() failed: %d\n", ret); + hang(); + } + + enable_tzc380(); + + /* DDR initialization */ + spl_dram_init(); + + board_init_r(NULL, 0); +} diff --git a/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig b/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig new file mode 100644 index 0000000000..cbdaed7333 --- /dev/null +++ b/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig @@ -0,0 +1,92 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX8M=y +CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x10000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x400000 +CONFIG_DM_GPIO=y +CONFIG_SPL_TEXT_BASE=0x7E1000 +CONFIG_TARGET_IMX8MM_ICORE_MX8MM=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_SPL=y +CONFIG_DEFAULT_DEVICE_TREE="imx8mm-icore-mx8mm-edimm2.2" +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/imx8m/imximage-8mm-lpddr4.cfg" +CONFIG_DEFAULT_FDT_FILE="imx8mm-icore-mx8mm-edimm2.2.dtb" +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="u-boot=> " +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_CLK=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_DEV=2 +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y +CONFIG_SPL_CLK_COMPOSITE_CCF=y +CONFIG_CLK_COMPOSITE_CCF=y +CONFIG_SPL_CLK_IMX8MM=y +CONFIG_CLK_IMX8MM=y +CONFIG_MXC_GPIO=y +CONFIG_DM_PCA953X=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MXC=y +CONFIG_DM_MMC=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_FSL_USDHC=y +CONFIG_PHYLIB=y +CONFIG_PHY_ATHEROS=y +CONFIG_DM_ETH=y +CONFIG_PHY_GIGE=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_DM_REGULATOR=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_CONS_INDEX=2 +CONFIG_DM_SERIAL=y +# CONFIG_SPL_DM_SERIAL is not set +CONFIG_MXC_UART=y +CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y +CONFIG_SYSRESET_PSCI=y +CONFIG_DM_THERMAL=y +CONFIG_IMX_TMU=y diff --git a/include/configs/imx8mm_icore_mx8mm.h b/include/configs/imx8mm_icore_mx8mm.h new file mode 100644 index 0000000000..9f63f32fc3 --- /dev/null +++ b/include/configs/imx8mm_icore_mx8mm.h @@ -0,0 +1,58 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2020 Engicam srl + * Copyright (c) 2020 Amarula Solutions(India) + */ + +#ifndef __IMX8MM_ICORE_MX8MM_H +#define __IMX8MM_ICORE_MX8MM_H + +#define CONFIG_SYS_INIT_RAM_SIZE 0x200000 +#define PHYS_SDRAM_SIZE 0x40000000 /* 2GB DDR */ + +#include "imx8mm-common.h" + +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (PHYS_SDRAM_SIZE >> 1)) + +#ifndef CONFIG_SPL_BUILD +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 2) \ + func(MMC, mmc, 0) +#include <config_distro_bootcmd.h> +#undef CONFIG_ISO_PARTITION +#else +#define BOOTENV +#endif + +#define ENV_MEM_LAYOUT_SETTINGS \ + "fdt_addr_r=0x44000000\0" \ + "kernel_addr_r=0x42000000\0" \ + "ramdisk_addr_r=0x46400000\0" \ + "scriptaddr=0x46000000\0" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + ENV_MEM_LAYOUT_SETTINGS \ + "fdt_addr=0x43000000\0" \ + "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "console=ttymxc1,115200\0" \ + BOOTENV + +#define CONFIG_MXC_UART_BASE UART2_BASE_ADDR + +/* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE 2048 +#define CONFIG_SYS_MAXARGS 64 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) + +/* USDHC */ +#define CONFIG_SYS_FSL_USDHC_NUM 2 +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define CONFIG_SYS_MMC_IMG_LOAD_PART 1 + +/* I2C */ +#define CONFIG_SYS_I2C_SPEED 100000 + +#endif /* __IMX8MM_ICORE_MX8MM_H */
Engicam C.TOUCH 2.0 is an EDIMM compliant general purpose Carrier board.
Genaral features: - Ethernet 10/100 - Wifi/BT - USB Type A/OTG - Audio Out - CAN - LVDS panel connector
i.Core MX8M Mini is an EDIMM SoM based on NXP i.MX8M Mini from Engicam.
i.Core MX8M Mini needs to mount on top of this Carrier board for creating complete i.Core MX8M Mini C.TOUCH 2.0 board.
Linux dts commit details:
commit <a142252061ff> ("arm64: dts: imx8mm: Add Engicam i.Core MX8M Mini C.TOUCH 2.0")
Add support for it.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v2: - add Linux commit details
arch/arm/dts/Makefile | 1 + .../imx8mm-icore-mx8mm-ctouch2-u-boot.dtsi | 31 ++++++ arch/arm/dts/imx8mm-icore-mx8mm-ctouch2.dts | 97 +++++++++++++++++++ arch/arm/mach-imx/imx8m/Kconfig | 5 + board/engicam/imx8mm/MAINTAINERS | 6 ++ configs/imx8mm-icore-mx8mm-ctouch2_defconfig | 92 ++++++++++++++++++ 6 files changed, 232 insertions(+) create mode 100644 arch/arm/dts/imx8mm-icore-mx8mm-ctouch2-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mm-icore-mx8mm-ctouch2.dts create mode 100644 configs/imx8mm-icore-mx8mm-ctouch2_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 08db525bc4..17cf936a1f 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -790,6 +790,7 @@ dtb-$(CONFIG_ARCH_IMX8) += \
dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mm-evk.dtb \ + imx8mm-icore-mx8mm-ctouch2.dtb \ imx8mm-icore-mx8mm-edimm2.2.dtb \ imx8mm-venice.dtb \ imx8mm-venice-gw71xx-0x.dtb \ diff --git a/arch/arm/dts/imx8mm-icore-mx8mm-ctouch2-u-boot.dtsi b/arch/arm/dts/imx8mm-icore-mx8mm-ctouch2-u-boot.dtsi new file mode 100644 index 0000000000..8b67bcff7d --- /dev/null +++ b/arch/arm/dts/imx8mm-icore-mx8mm-ctouch2-u-boot.dtsi @@ -0,0 +1,31 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2020 Engicam srl + * Copyright (c) 2020 Amarula Solutions(India) + */ + +#include "imx8mm-icore-mx8mm-u-boot.dtsi" + +&gpio1 { + u-boot,dm-spl; +}; + +&pinctrl_uart2 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc1_gpio { + u-boot,dm-spl; +}; + +&pinctrl_usdhc1 { + u-boot,dm-spl; +}; + +&uart2 { + u-boot,dm-spl; +}; + +&usdhc1 { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/imx8mm-icore-mx8mm-ctouch2.dts b/arch/arm/dts/imx8mm-icore-mx8mm-ctouch2.dts new file mode 100644 index 0000000000..5389d6f2be --- /dev/null +++ b/arch/arm/dts/imx8mm-icore-mx8mm-ctouch2.dts @@ -0,0 +1,97 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 NXP + * Copyright (c) 2019 Engicam srl + * Copyright (c) 2020 Amarula Solutions(India) + */ + +/dts-v1/; +#include "imx8mm.dtsi" +#include "imx8mm-icore-mx8mm.dtsi" + +/ { + model = "Engicam i.Core MX8M Mini C.TOUCH 2.0"; + compatible = "engicam,icore-mx8mm-ctouch2", "engicam,icore-mx8mm", + "fsl,imx8mm"; + + chosen { + stdout-path = &uart2; + }; +}; + +&fec1 { + status = "okay"; +}; + +&i2c2 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; +}; + +&i2c4 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c4>; + status = "okay"; +}; + +&iomuxc { + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX8MM_IOMUXC_I2C2_SCL_I2C2_SCL 0x400001c3 + MX8MM_IOMUXC_I2C2_SDA_I2C2_SDA 0x400001c3 + >; + }; + + pinctrl_i2c4: i2c4grp { + fsl,pins = < + MX8MM_IOMUXC_I2C4_SCL_I2C4_SCL 0x400001c3 + MX8MM_IOMUXC_I2C4_SDA_I2C4_SDA 0x400001c3 + >; + }; + + pinctrl_uart2: uart2grp { + fsl,pins = < + MX8MM_IOMUXC_UART2_RXD_UART2_DCE_RX 0x140 + MX8MM_IOMUXC_UART2_TXD_UART2_DCE_TX 0x140 + >; + }; + + pinctrl_usdhc1_gpio: usdhc1gpiogrp { + fsl,pins = < + MX8MM_IOMUXC_GPIO1_IO06_GPIO1_IO6 0x41 + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + MX8MM_IOMUXC_SD1_CLK_USDHC1_CLK 0x190 + MX8MM_IOMUXC_SD1_CMD_USDHC1_CMD 0x1d0 + MX8MM_IOMUXC_SD1_DATA0_USDHC1_DATA0 0x1d0 + MX8MM_IOMUXC_SD1_DATA1_USDHC1_DATA1 0x1d0 + MX8MM_IOMUXC_SD1_DATA2_USDHC1_DATA2 0x1d0 + MX8MM_IOMUXC_SD1_DATA3_USDHC1_DATA3 0x1d0 + >; + }; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + status = "okay"; +}; + +/* SD */ +&usdhc1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc1>, <&pinctrl_usdhc1_gpio>; + cd-gpios = <&gpio1 6 GPIO_ACTIVE_LOW>; + max-frequency = <50000000>; + bus-width = <4>; + no-1-8-v; + pm-ignore-notify; + keep-power-in-suspend; + status = "okay"; +}; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index 28a9a51e67..7262ab0517 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -62,6 +62,11 @@ config TARGET_IMX8MM_ICORE_MX8MM * i.Core MX8M Mini needs to mount on top of EDIMM2.2 for creating complete i.Core MX8M Mini EDIMM2.2 Starter Kit.
+ i.Core MX8M Mini C.TOUCH 2.0 + * C.TOUCH 2.0 is a general purpose Carrier board. + * i.Core MX8M Mini needs to mount on top of this Carrier board + for creating complete i.Core MX8M Mini C.TOUCH 2.0 board. + config TARGET_IMX8MN_DDR4_EVK bool "imx8mn DDR4 EVK board" select IMX8MN diff --git a/board/engicam/imx8mm/MAINTAINERS b/board/engicam/imx8mm/MAINTAINERS index 044a9392ac..2e99a5995f 100644 --- a/board/engicam/imx8mm/MAINTAINERS +++ b/board/engicam/imx8mm/MAINTAINERS @@ -1,3 +1,9 @@ +i.Core-MX8M-Mini-CTOUCH2.0 +M: Jagan Teki jagan@amarulasolutions.com +M: Matteo Lisi matteo.lisi@engicam.com +S: Maintained +F: configs/imx8mm-icore-mx8mm-ctouch2_defconfig + i.Core-MX8M-Mini-EDIMM2.2 M: Jagan Teki jagan@amarulasolutions.com M: Matteo Lisi matteo.lisi@engicam.com diff --git a/configs/imx8mm-icore-mx8mm-ctouch2_defconfig b/configs/imx8mm-icore-mx8mm-ctouch2_defconfig new file mode 100644 index 0000000000..f771ebdb50 --- /dev/null +++ b/configs/imx8mm-icore-mx8mm-ctouch2_defconfig @@ -0,0 +1,92 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX8M=y +CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x10000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x400000 +CONFIG_DM_GPIO=y +CONFIG_SPL_TEXT_BASE=0x7E1000 +CONFIG_TARGET_IMX8MM_ICORE_MX8MM=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_SPL=y +CONFIG_DEFAULT_DEVICE_TREE="imx8mm-icore-mx8mm-ctouch2" +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/imx8m/imximage-8mm-lpddr4.cfg" +CONFIG_DEFAULT_FDT_FILE="imx8mm-icore-mx8mm-ctouch2.dtb" +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="u-boot=> " +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_CLK=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_DEV=2 +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y +CONFIG_SPL_CLK_COMPOSITE_CCF=y +CONFIG_CLK_COMPOSITE_CCF=y +CONFIG_SPL_CLK_IMX8MM=y +CONFIG_CLK_IMX8MM=y +CONFIG_MXC_GPIO=y +CONFIG_DM_PCA953X=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MXC=y +CONFIG_DM_MMC=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_FSL_USDHC=y +CONFIG_PHYLIB=y +CONFIG_PHY_ATHEROS=y +CONFIG_DM_ETH=y +CONFIG_PHY_GIGE=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_DM_REGULATOR=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_CONS_INDEX=2 +CONFIG_DM_SERIAL=y +# CONFIG_SPL_DM_SERIAL is not set +CONFIG_MXC_UART=y +CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y +CONFIG_SYSRESET_PSCI=y +CONFIG_DM_THERMAL=y +CONFIG_IMX_TMU=y
Hi Stefano,
On Mon, Mar 15, 2021 at 11:16 PM Jagan Teki jagan@amarulasolutions.com wrote:
Patch series for Engicam i.Core MX8M Mini SOM and it's associated carrier board dts(i) support.
patch 1-2: add imx8mm-u-boot.dtsi, header improvement code
patch 3: Engicam i.Core MX8M Mini SoM dts
patch 4-5: EDIMM2.2, C.TOUCH 2.0 Carrier boards
Changes for v2:
- add Linux commit sha1 in commit messages.
Any inputs? Jagan.
Jagan Teki (5): arm64: dts: imx8mm: Add common -u-boot.dtsi configs: Add imx8mm-common header arm64: dts: imx8mm: Add Engicam i.Core MX8M Mini SoM board: imx8mm: Add Engicam i.Core MX8M Mini EDIMM2.2 Starter Kit board: imx8mm: Add Engicam i.Core MX8M Mini C.TOUCH 2.0
Any comments?
Jagan.
Jagan Teki
Peng Fan (OSS)
Stefano Babic
Tim Harvey
