[U-Boot] [PATCH] arm: spl: Do not set the stack pointer twice
Because the stack pointer is already set in arch/arm/lib/crt0.S, we do not need to set it in arch/arm/lib/spl.c.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- arch/arm/lib/spl.c | 3 --- 1 file changed, 3 deletions(-)
diff --git a/arch/arm/lib/spl.c b/arch/arm/lib/spl.c index 301f082..b5a1324 100644 --- a/arch/arm/lib/spl.c +++ b/arch/arm/lib/spl.c @@ -41,9 +41,6 @@ gd_t gdata __attribute__ ((section(".data"))); */ void __weak board_init_f(ulong dummy) { - /* Set the stack pointer. */ - asm volatile("mov sp, %0\n" : : "r"(CONFIG_SPL_STACK)); - /* Clear the BSS. */ memset(__bss_start, 0, __bss_end - __bss_start);
Hi Masahiro,
On Wed, 17 Jul 2013 20:35:55 +0900, Masahiro Yamada yamada.m@jp.panasonic.com wrote:
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Masahiro Yamada
