Falcon Mode Support For Uncompressed Kernel Images
Hi All,
While trying to bring up Falcon Mode boot on an ARM64 board, I discovered that there is no path which allows you to use an uncompressed kernel image (booti). I've added this path and attached the relevant patch.
I've made this a separate if/else CONFIG option instead of allowing both bootz+booti paths to coexist, as it seems unlikely to me that there would be such a board which needs both. Most architectures use either bootz or booti, but not both.
Sincerely, Nathan Barrett-Morrison
On Mon, Jan 17, 2022 at 07:58:00PM -0500, Nathan Barrett-Morrison wrote:
Hi All,
From d5542ccc2d4f81ac0442be8ca772a99e1a13b6dd Mon Sep 17 00:00:00 2001 From: Nathan Barrett-Morrison nathan.morrison@timesys.com Date: Mon, 17 Jan 2022 19:42:10 -0500 Subject: [PATCH] Add in the ability to load and boot an uncompressed kernel image during the Falcon Mode boot sequence. This is required for architectures which do not support compressed kernel image booting (i.e., ARM64)
Signed-off-by: Nathan Barrett-Morrison nathan.morrison@timesys.com Cc: Tom Rini trini@konsulko.com Cc: Aneesh V aneesh@ti.com
arch/arm/lib/Makefile | 2 +- common/spl/Kconfig | 6 ++++++ common/spl/spl.c | 21 +++++++++++++++++++++ 3 files changed, 28 insertions(+), 1 deletion(-)
diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index c48e1f622d..24c9e3c1e5 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -36,7 +36,7 @@ obj-$(CONFIG_CMD_BOOTZ) += bootm.o zimage.o obj-$(CONFIG_SYS_L2_PL310) += cache-pl310.o else obj-$(CONFIG_$(SPL_TPL_)FRAMEWORK) += spl.o -obj-$(CONFIG_SPL_FRAMEWORK) += zimage.o +obj-$(CONFIG_SPL_FRAMEWORK) += zimage.o image.o obj-$(CONFIG_OF_LIBFDT) += bootm-fdt.o endif ifdef CONFIG_ARM64 diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 4a739a7421..6d2ddddc9f 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -917,6 +917,12 @@ config SYS_OS_BASE Specify the address, where the OS image is found, which gets booted.
+config SPL_OS_BOOT_UNCOMPRESSED
- bool "Use uncompressed kernel image alongside Falcon Mode"
- depends on SPL_SPI_LOAD
- help
Use an uncompressed kernel image to boot. This is targetting
architectures which use booti instead of bootz (i.e, ARM64).
endif # SPL_OS_BOOT
We shouldn't need another CONFIG option here, and this would then I believe fail to boot uncompressed arm32 images. The real problem I think is that the code assumed bootm/bootz but needs to instead be more explicit in checking / supporting each and then also yes, adding booti support. Following up with also supporting compressed Images may or may not take additional logic, I'm not sure off-hand.
Hi Tom,
Yea, I'm not sure if uncompressed ARM32 would work, but I don't believe it was ever working to begin with... as bootz_setup is being called right now ( @ https://source.denx.de/u-boot/u-boot/-/blob/master/common/spl/spl.c#L366 )
My intent was for SPL_OS_BOOT_UNCOMPRESSED to only be used for platforms which need booti_setup (ARM64, ...).
So... I could add a dependency on ARM64 in the config option or I could remove the option altogether and let the booti_setup fail and fallback to bootz_setup. Would either of those work for you?
Sincerely, Nathan
Hi All,
(i.e.,
ARM64)
help
endif # SPL_OS_BOOT
-- Tom
On Mon, Jan 31, 2022 at 10:23:58AM -0500, Nathan Barrett-Morrison wrote:
Hi Tom,
The code and logic overall needs a bit of refactoring to support "booti", "bootz" and also FIT images. I believe FIT images are how anyone doing falcon mode on arm64 has worked thus far. booti/bootz should only be an option when CMD_BOOTI/Z is set, and FIT should depend on SPL_LOAD_FIT already.
Hi Tom,
I've attached version 2 of the patch. I believe this should adhere more closely to your suggestions.
Keep in mind, CONFIG_IS_ENABLED will not work for checking CMD_BOOTI/CMD_BOOTZ in this case, as there is no CONFIG_SPL_CMD_BOOTx. So, I'm just directly checking if it's defined instead.
I verified both CONFIG_IS_ENABLED() and IS_ENABLED() did not work.
Sincerely, Nathan
Hi Tom,
it
now
-- Tom
On Wed, Feb 02, 2022 at 04:53:11PM -0500, Nathan Barrett-Morrison wrote:
Hi Tom,
Sincerely, Nathan
Hi Tom,
it
now
-- Tom
From 5d37f2a930e7cb3455b6ec925ec6e67b40d4c022 Mon Sep 17 00:00:00 2001 From: Nathan Barrett Morrison nathan.morrison@timesys.com Date: Wed, 2 Feb 2022 15:05:18 -0500 Subject: [PATCH v2] Add in the ability to load and boot an uncompressed kernel image during the Falcon Mode boot sequence.
This is required for architectures which do not support compressed kernel images (i.e. ARM64). This is only used while not booting via FIT image.
Changes for v2:
- Remove original SPL_OS_BOOT_UNCOMPRESSED option and check via CMD_BOOTI and CMD_BOOTZ instead
arch/arm/lib/Makefile | 5 ++++- common/spl/spl.c | 21 +++++++++++++++++++++ 2 files changed, 25 insertions(+), 1 deletion(-)
diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index c48e1f622d..57e49f69f7 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -36,7 +36,10 @@ obj-$(CONFIG_CMD_BOOTZ) += bootm.o zimage.o obj-$(CONFIG_SYS_L2_PL310) += cache-pl310.o else obj-$(CONFIG_$(SPL_TPL_)FRAMEWORK) += spl.o -obj-$(CONFIG_SPL_FRAMEWORK) += zimage.o +ifdef CONFIG_SPL_FRAMEWORK +obj-$(CONFIG_CMD_BOOTI) += image.o +obj-$(CONFIG_CMD_BOOTZ) += zimage.o +endif obj-$(CONFIG_OF_LIBFDT) += bootm-fdt.o endif ifdef CONFIG_ARM64 diff --git a/common/spl/spl.c b/common/spl/spl.c index f51d1f3205..1f6b3f1ac8 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -104,6 +104,11 @@ int __weak bootz_setup(ulong image, ulong *start, ulong *end) { return 1; }
+int __weak booti_setup(ulong image, ulong *relocated_addr, ulong *size, bool force_reloc) +{
return 1;
+} #endif
/* Weak default function for arch/board-specific fixups to the spl_image_info */ @@ -354,6 +359,21 @@ int spl_parse_image_header(struct spl_image_info *spl_image, #endif
#if CONFIG_IS_ENABLED(OS_BOOT) +#if defined(CMD_BOOTI)
ulong start, size;
if (!booti_setup((ulong)header, &start, &size, 0)) {
spl_image->name = "Linux";
spl_image->os = IH_OS_LINUX;
spl_image->load_addr = start;
spl_image->entry_point = start;
spl_image->size = size;
debug(SPL_TPL_PROMPT
"payload Image, load addr: 0x%lx size: %d\n",
spl_image->load_addr, spl_image->size);
+#elif defined(CMD_BOOTZ) ulong start, end;
if (!bootz_setup((ulong)header, &start, &end)) {
@@ -367,6 +387,7 @@ int spl_parse_image_header(struct spl_image_info *spl_image, spl_image->load_addr, spl_image->size); return 0; } +#endif #endif
if (!spl_parse_board_header(spl_image, (const void *)header, sizeof(*header)))
Sorry for the late response. Attached patches aren't picked up by patchwork. I think this looks OK, but can you please re-send it directly rather than as attachment? Thanks.
Hi Tom,
Let's see if this works any better. Using a new mail client that is supposed to not modify whitespace:
From f1c34333f79996bd2927a60f4858c01699431cba Mon Sep 17 00:00:00 2001
Signed-off-by: Nathan Barrett-Morrison nathan.morrison@timesys.com Cc: Tom Rini trini@konsulko.com --- Changes for v2: - Remove original SPL_OS_BOOT_UNCOMPRESSED option and check via CMD_BOOTI and CMD_BOOTZ instead
diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index c603fe61bc..08b7475e37 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -36,7 +36,10 @@ obj-$(CONFIG_CMD_BOOTZ) += bootm.o zimage.o obj-$(CONFIG_SYS_L2_PL310) += cache-pl310.o else obj-$(CONFIG_$(SPL_TPL_)FRAMEWORK) += spl.o -obj-$(CONFIG_SPL_FRAMEWORK) += zimage.o +ifdef CONFIG_SPL_FRAMEWORK +obj-$(CONFIG_CMD_BOOTI) += image.o +obj-$(CONFIG_CMD_BOOTZ) += zimage.o +endif obj-$(CONFIG_OF_LIBFDT) += bootm-fdt.o endif ifdef CONFIG_ARM64 diff --git a/common/spl/spl.c b/common/spl/spl.c index c9750ee163..7b86443f1b 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -107,6 +107,11 @@ int __weak bootz_setup(ulong image, ulong *start, ulong *end) { return 1; } + +int __weak booti_setup(ulong image, ulong *relocated_addr, ulong *size, bool force_reloc) +{ + return 1; +} #endif
/* Weak default function for arch/board-specific fixups to the spl_image_info */ @@ -366,6 +371,21 @@ int spl_parse_image_header(struct spl_image_info *spl_image, #endif
#if CONFIG_IS_ENABLED(OS_BOOT) +#if defined(CMD_BOOTI) + ulong start, size; + + if (!booti_setup((ulong)header, &start, &size, 0)) { + spl_image->name = "Linux"; + spl_image->os = IH_OS_LINUX; + spl_image->load_addr = start; + spl_image->entry_point = start; + spl_image->size = size; + debug(SPL_TPL_PROMPT + "payload Image, load addr: 0x%lx size: %d\n", + spl_image->load_addr, spl_image->size); + return 0; + } +#elif defined(CMD_BOOTZ) ulong start, end;
if (!bootz_setup((ulong)header, &start, &end)) { @@ -379,6 +399,7 @@ int spl_parse_image_header(struct spl_image_info *spl_image, spl_image->load_addr, spl_image->size); return 0; } +#endif #endif
if (!spl_parse_board_header(spl_image, bootdev, (const void *)header, sizeof(*header)))
One more time --
From: Nathan Barrett-Morrison nathan.morrison@timesys.com Date: Wed, 2 Feb 2022 15:05:18 -0500 Subject: [PATCH v2] Add in the ability to load and boot an uncompressed kernel image during the Falcon Mode boot sequence.
On Tue, Apr 19, 2022 at 05:16:21PM -0400, Nathan Barrett-Morrison wrote:
Hi Tom,
From f1c34333f79996bd2927a60f4858c01699431cba Mon Sep 17 00:00:00 2001 From: Nathan Barrett Morrison nathan.morrison@timesys.com Date: Wed, 2 Feb 2022 15:05:18 -0500 Subject: [PATCH v2] Add in the ability to load and boot an uncompressed kernel image during the Falcon Mode boot sequence.
Changes for v2:
Whitespace is fine, but since it's in reply to the previous email, that really throws patchwork for a loop so this doesn't show up yet. Please do this is a new thread, thanks.
return 1;
+} #endif
ulong start, size;
-- 2.30.2
Hi Tom,
Sincerely, Nathan
Hi Tom,
it
now
-- Tom
Changes for v2:
return 1;
+} #endif
ulong start, size;
