[U-Boot-Users] [PATCH: cmdcfg: 04/19] common/ non-cmd: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).
This is a compatibility step that allows both the older form and the new form to co-exist for a while until the older can be removed entirely.
All transformations are of the form: Before: #if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) After: #if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
Signed-off-by: Jon Loeliger jdl@freescale.com --- common/bedbug.c | 2 +- common/command.c | 4 ++-- common/docecc.c | 2 +- common/env_flash.c | 2 +- common/env_nand.c | 2 +- common/exports.c | 2 +- common/hush.c | 2 +- common/kgdb.c | 2 +- common/lcd.c | 2 +- common/main.c | 4 ++-- common/miiphyutil.c | 2 +- common/usb.c | 2 +- common/usb_storage.c | 2 +- 13 files changed, 15 insertions(+), 15 deletions(-)
diff --git a/common/bedbug.c b/common/bedbug.c index 6966de7..1a793f8 100644 --- a/common/bedbug.c +++ b/common/bedbug.c @@ -2,7 +2,7 @@
#include <common.h>
-#if (CONFIG_COMMANDS & CFG_CMD_BEDBUG) +#if (CONFIG_COMMANDS & CFG_CMD_BEDBUG) || defined(CONFIG_CMD_BEDBUG)
#include <linux/ctype.h> #include <bedbug/bedbug.h> diff --git a/common/command.c b/common/command.c index e917975..f8bd16b 100644 --- a/common/command.c +++ b/common/command.c @@ -42,7 +42,7 @@ U_BOOT_CMD( NULL );
-#if (CONFIG_COMMANDS & CFG_CMD_ECHO) +#if (CONFIG_COMMANDS & CFG_CMD_ECHO) || defined(CONFIG_CMD_ECHO)
int do_echo (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) @@ -409,7 +409,7 @@ void install_auto_complete(void) { install_auto_complete_handler("printenv", var_complete); install_auto_complete_handler("setenv", var_complete); -#if (CONFIG_COMMANDS & CFG_CMD_RUN) +#if (CONFIG_COMMANDS & CFG_CMD_RUN) || defined(CONFIG_CMD_RUN) install_auto_complete_handler("run", var_complete); #endif } diff --git a/common/docecc.c b/common/docecc.c index 79adb48..d9c7a41 100644 --- a/common/docecc.c +++ b/common/docecc.c @@ -31,7 +31,7 @@ #undef ECC_DEBUG #undef PSYCHO_DEBUG
-#if (CONFIG_COMMANDS & CFG_CMD_DOC) +#if (CONFIG_COMMANDS & CFG_CMD_DOC) || defined(CONFIG_CMD_DOC)
#include <linux/mtd/doc2000.h>
diff --git a/common/env_flash.c b/common/env_flash.c index 1674b30..f9cf35a 100644 --- a/common/env_flash.c +++ b/common/env_flash.c @@ -37,7 +37,7 @@
DECLARE_GLOBAL_DATA_PTR;
-#if ((CONFIG_COMMANDS&(CFG_CMD_ENV|CFG_CMD_FLASH)) == (CFG_CMD_ENV|CFG_CMD_FLASH)) +#if ((CONFIG_COMMANDS&(CFG_CMD_ENV|CFG_CMD_FLASH)) == (CFG_CMD_ENV|CFG_CMD_FLASH)) || (defined(CONFIG_CMD_ENV) && defined(CONFIG_CMD_FLASH)) #define CMD_SAVEENV #elif defined(CFG_ENV_ADDR_REDUND) #error Cannot use CFG_ENV_ADDR_REDUND without CFG_CMD_ENV & CFG_CMD_FLASH diff --git a/common/env_nand.c b/common/env_nand.c index 67c4a4e..f97af20 100644 --- a/common/env_nand.c +++ b/common/env_nand.c @@ -39,7 +39,7 @@ #include <malloc.h> #include <nand.h>
-#if ((CONFIG_COMMANDS&(CFG_CMD_ENV|CFG_CMD_NAND)) == (CFG_CMD_ENV|CFG_CMD_NAND)) +#if ((CONFIG_COMMANDS&(CFG_CMD_ENV|CFG_CMD_NAND)) == (CFG_CMD_ENV|CFG_CMD_NAND)) || (defined(CONFIG_CMD_ENV) && defined(CONFIG_CMD_NAND)) #define CMD_SAVEENV #elif defined(CFG_ENV_OFFSET_REDUND) #error Cannot use CFG_ENV_OFFSET_REDUND without CFG_CMD_ENV & CFG_CMD_NAND diff --git a/common/exports.c b/common/exports.c index 0cb4396..fc8060a 100644 --- a/common/exports.c +++ b/common/exports.c @@ -32,7 +32,7 @@ void jumptable_init (void) gd->jt[XF_install_hdlr] = (void *) irq_install_handler; gd->jt[XF_free_hdlr] = (void *) irq_free_handler; #endif /* I386 || PPC */ -#if (CONFIG_COMMANDS & CFG_CMD_I2C) +#if (CONFIG_COMMANDS & CFG_CMD_I2C) || defined(CONFIG_CMD_I2C) gd->jt[XF_i2c_write] = (void *) i2c_write; gd->jt[XF_i2c_read] = (void *) i2c_read; #endif /* CFG_CMD_I2C */ diff --git a/common/hush.c b/common/hush.c index feb5627..4ddbc64 100644 --- a/common/hush.c +++ b/common/hush.c @@ -1682,7 +1682,7 @@ static int run_pipe_real(struct pipe *pi) return -1; /* give up after bad command */ } else { int rcode; -#if (CONFIG_COMMANDS & CFG_CMD_BOOTD) +#if (CONFIG_COMMANDS & CFG_CMD_BOOTD) || defined(CONFIG_CMD_BOOTD) extern int do_bootd (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]);
/* avoid "bootd" recursion */ diff --git a/common/kgdb.c b/common/kgdb.c index 6de6ec9..7a3e6d6 100644 --- a/common/kgdb.c +++ b/common/kgdb.c @@ -92,7 +92,7 @@ #include <kgdb.h> #include <command.h>
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB)
#undef KGDB_DEBUG
diff --git a/common/lcd.c b/common/lcd.c index eaed2ab..3b6391b 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -571,7 +571,7 @@ void bitmap_plot (int x, int y) #endif /* CONFIG_LCD_LOGO */
/*----------------------------------------------------------------------*/ -#if (CONFIG_COMMANDS & CFG_CMD_BMP) || defined(CONFIG_SPLASH_SCREEN) +#if (CONFIG_COMMANDS & CFG_CMD_BMP) || defined(CONFIG_CMD_BMP) || defined(CONFIG_SPLASH_SCREEN) /* * Display the BMP file located at address bmp_image. * Only uncompressed. diff --git a/common/main.c b/common/main.c index 09ee64b..0f56781 100644 --- a/common/main.c +++ b/common/main.c @@ -1311,7 +1311,7 @@ int run_command (const char *cmd, int flag) continue; }
-#if (CONFIG_COMMANDS & CFG_CMD_BOOTD) +#if (CONFIG_COMMANDS & CFG_CMD_BOOTD) || defined(CONFIG_CMD_BOOTD) /* avoid "bootd" recursion */ if (cmdtp->cmd == do_bootd) { #ifdef DEBUG_PARSER @@ -1344,7 +1344,7 @@ int run_command (const char *cmd, int flag)
-#if (CONFIG_COMMANDS & CFG_CMD_RUN) +#if (CONFIG_COMMANDS & CFG_CMD_RUN) || defined(CONFIG_CMD_RUN) int do_run (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) { int i; diff --git a/common/miiphyutil.c b/common/miiphyutil.c index e411e57..6482728 100644 --- a/common/miiphyutil.c +++ b/common/miiphyutil.c @@ -29,7 +29,7 @@ #include <common.h> #include <miiphy.h>
-#if defined(CONFIG_MII) || (CONFIG_COMMANDS & CFG_CMD_MII) +#if defined(CONFIG_MII) || (CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII) #include <asm/types.h> #include <linux/list.h> #include <malloc.h> diff --git a/common/usb.c b/common/usb.c index 0857494..282c1d9 100644 --- a/common/usb.c +++ b/common/usb.c @@ -49,7 +49,7 @@ #include <asm/processor.h> #include <linux/ctype.h>
-#if (CONFIG_COMMANDS & CFG_CMD_USB) +#if (CONFIG_COMMANDS & CFG_CMD_USB) || defined(CONFIG_CMD_USB)
#include <usb.h> #ifdef CONFIG_4xx diff --git a/common/usb_storage.c b/common/usb_storage.c index 196ceb7..d556475 100644 --- a/common/usb_storage.c +++ b/common/usb_storage.c @@ -55,7 +55,7 @@ #include <asm/processor.h>
-#if (CONFIG_COMMANDS & CFG_CMD_USB) +#if (CONFIG_COMMANDS & CFG_CMD_USB) || defined(CONFIG_CMD_USB) #include <part.h> #include <usb.h>
Jon Loeliger
