[cmd] "env import" command behaviour observation
Hi ,
Exporting environment variables to a memory location and trying to import them back. On certain occasions,the import command is displaying errors.
Board: rpi1ModelB/sandbox The console log (rpi1modelb) is : ------------------------------------------------------------------------------------- U-Boot> env export 0x82000000 U-Boot> md.b 0x82000000 82000000: 61 72 63 68 3d 61 72 6d 0a 62 61 75 64 72 61 74 arch=arm.baudrat 82000010: 65 3d 31 31 35 32 30 30 0a 62 6f 61 72 64 3d 72 e=115200.board=r 82000020: 70 69 0a 62 6f 61 72 64 5f 6e 61 6d 65 3d 4d 6f pi.board_name=Mo 82000030: 64 65 6c 20 42 20 72 65 76 32 0a 62 6f 61 72 64 del B rev2.board U-Boot> printenv filesize filesize=1004 U-Boot> env import 0x82000000 ## Warning: defaulting to text format ## Info: input data size = 4100 = 0x1004 ## Error: Can't overwrite "ethaddr" himport_r: can't insert "ethaddr=b8:27:eb:bb:2d:e6" into hash table ## Error: Can't overwrite "serial#" himport_r: can't insert "serial#=00000000ebbb2de6" into hash table U-Boot> ---------------------------------------------------------------------------------------- Is this expected?? or should it be raised as a BUG. Please advise.
Regards, Adarsh
Dear Adarsh Babu Kalepalli,
In message CAJgxa7cGG6JG_xfzzyh3zit7Gg43mSma0E-hcXVM=7+eM8Uu+w@mail.gmail.com you wrote:
Yes, this is expected behaviour. These variables are read-only (resp.write-once), so you cannot modify them if they are already set. [At least not without additional measures.]
