[U-Boot] [PATCH 0/3] Moving Uartlite to DM
This patch series depends on microblaze cleanup series. All these patches will be available in git://git.denx.de/u-boot-microblaze.git also with patches which I am going to send now.
Thanks, Michal
Michal Simek (3): serial: uartlite: Move driver to DM serial: uartlite: Add support for debug console serial: uartlite: Add uartlite to Kconfig
arch/microblaze/Kconfig | 1 + board/xilinx/microblaze-generic/xparameters.h | 4 - configs/microblaze-generic_defconfig | 3 + doc/driver-model/serial-howto.txt | 1 - drivers/serial/Kconfig | 14 ++ drivers/serial/serial_xuartlite.c | 191 ++++++++++++-------------- include/configs/microblaze-generic.h | 7 +- 7 files changed, 106 insertions(+), 115 deletions(-)
Enable SPL DM too.
arch/microblaze/Kconfig | 1 + configs/microblaze-generic_defconfig | 2 + doc/driver-model/serial-howto.txt | 1 - drivers/serial/serial_xuartlite.c | 176 ++++++++++++++--------------------- 4 files changed, 71 insertions(+), 109 deletions(-)
diff --git a/arch/microblaze/Kconfig b/arch/microblaze/Kconfig index 604f6815af5b..30ea484f48aa 100644 --- a/arch/microblaze/Kconfig +++ b/arch/microblaze/Kconfig @@ -13,6 +13,7 @@ config TARGET_MICROBLAZE_GENERIC select SUPPORT_SPL select OF_CONTROL select DM + select DM_SERIAL
endchoice
diff --git a/configs/microblaze-generic_defconfig b/configs/microblaze-generic_defconfig index 54aa3ef3d26f..5df080b6a87c 100644 --- a/configs/microblaze-generic_defconfig +++ b/configs/microblaze-generic_defconfig @@ -1,9 +1,11 @@ CONFIG_MICROBLAZE=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_DM=y CONFIG_TARGET_MICROBLAZE_GENERIC=y CONFIG_DEFAULT_DEVICE_TREE="microblaze-generic" CONFIG_SPL=y CONFIG_SYS_PROMPT="U-Boot-mONStR> " CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y diff --git a/doc/driver-model/serial-howto.txt b/doc/driver-model/serial-howto.txt index 60483a4c49bc..6688abc4d9e3 100644 --- a/doc/driver-model/serial-howto.txt +++ b/doc/driver-model/serial-howto.txt @@ -19,7 +19,6 @@ is time for maintainers to start converting over the remaining serial drivers: serial_s3c24x0.c serial_sa1100.c serial_stm32.c - serial_xuartlite.c usbtty.c
You should complete this by the end of January 2016. diff --git a/drivers/serial/serial_xuartlite.c b/drivers/serial/serial_xuartlite.c index 988438e75471..10089f5a34b5 100644 --- a/drivers/serial/serial_xuartlite.c +++ b/drivers/serial/serial_xuartlite.c @@ -1,5 +1,5 @@ /* - * (C) Copyright 2008-2011 Michal Simek monstr@monstr.eu + * (C) Copyright 2008 - 2015 Michal Simek monstr@monstr.eu * Clean driver and add xilinx constant from header file * * (C) Copyright 2004 Atmark Techno, Inc. @@ -10,11 +10,17 @@
#include <config.h> #include <common.h> +#include <debug_uart.h> +#include <dm.h> #include <asm/io.h> #include <linux/compiler.h> #include <serial.h> +#include <watchdog.h> + +DECLARE_GLOBAL_DATA_PTR;
#define SR_TX_FIFO_FULL 0x08 /* transmit FIFO full */ +#define SR_TX_FIFO_EMPTY 0x04 /* transmit FIFO empty */ #define SR_RX_FIFO_VALID_DATA 0x01 /* data in receive FIFO */ #define SR_RX_FIFO_FULL 0x02 /* receive FIFO full */
@@ -28,135 +34,89 @@ struct uartlite { unsigned int control; };
-static struct uartlite *userial_ports[4] = { -#ifdef XILINX_UARTLITE_BASEADDR - [0] = (struct uartlite *)XILINX_UARTLITE_BASEADDR, -#endif -#ifdef XILINX_UARTLITE_BASEADDR1 - [1] = (struct uartlite *)XILINX_UARTLITE_BASEADDR1, -#endif -#ifdef XILINX_UARTLITE_BASEADDR2 - [2] = (struct uartlite *)XILINX_UARTLITE_BASEADDR2, -#endif -#ifdef XILINX_UARTLITE_BASEADDR3 - [3] = (struct uartlite *)XILINX_UARTLITE_BASEADDR3 -#endif +struct uartlite_priv { + struct uartlite *regs; };
-static void uartlite_serial_putc(const char c, const int port) +static int uartlite_serial_putc(struct udevice *dev, const char ch) { - struct uartlite *regs = userial_ports[port]; + struct uartlite_priv *priv = dev_get_priv(dev); + struct uartlite *regs = priv->regs;
- if (c == '\n') - uartlite_serial_putc('\r', port); + if (in_be32(®s->status) & SR_TX_FIFO_FULL) + return -EAGAIN;
- while (in_be32(®s->status) & SR_TX_FIFO_FULL) - ; - out_be32(®s->tx_fifo, c & 0xff); -} + out_be32(®s->tx_fifo, ch & 0xff);
-static void uartlite_serial_puts(const char *s, const int port) -{ - while (*s) - uartlite_serial_putc(*s++, port); + return 0; }
-static int uartlite_serial_getc(const int port) +static int uartlite_serial_getc(struct udevice *dev) { - struct uartlite *regs = userial_ports[port]; + struct uartlite_priv *priv = dev_get_priv(dev); + struct uartlite *regs = priv->regs; + + if (!(in_be32(®s->status) & SR_RX_FIFO_VALID_DATA)) + return -EAGAIN;
- while (!(in_be32(®s->status) & SR_RX_FIFO_VALID_DATA)) - ; return in_be32(®s->rx_fifo) & 0xff; }
-static int uartlite_serial_tstc(const int port) +static int uartlite_serial_pending(struct udevice *dev, bool input) { - struct uartlite *regs = userial_ports[port]; + struct uartlite_priv *priv = dev_get_priv(dev); + struct uartlite *regs = priv->regs; + + if (input) + return in_be32(®s->status) & SR_RX_FIFO_VALID_DATA;
- return in_be32(®s->status) & SR_RX_FIFO_VALID_DATA; + return in_be32(®s->status) & SR_TX_FIFO_EMPTY; }
-static int uartlite_serial_init(const int port) +static int uartlite_serial_probe(struct udevice *dev) { - struct uartlite *regs = userial_ports[port]; + struct uartlite_priv *priv = dev_get_priv(dev); + struct uartlite *regs = priv->regs;
- if (regs) { - out_be32(®s->control, 0); - out_be32(®s->control, - ULITE_CONTROL_RST_RX | ULITE_CONTROL_RST_TX); - in_be32(®s->control); - return 0; - } + out_be32(®s->control, 0); + out_be32(®s->control, ULITE_CONTROL_RST_RX | ULITE_CONTROL_RST_TX); + in_be32(®s->control);
- return -1; + return 0; }
-/* Multi serial device functions */ -#define DECLARE_ESERIAL_FUNCTIONS(port) \ - static int userial##port##_init(void) \ - { return uartlite_serial_init(port); } \ - static void userial##port##_setbrg(void) {} \ - static int userial##port##_getc(void) \ - { return uartlite_serial_getc(port); } \ - static int userial##port##_tstc(void) \ - { return uartlite_serial_tstc(port); } \ - static void userial##port##_putc(const char c) \ - { uartlite_serial_putc(c, port); } \ - static void userial##port##_puts(const char *s) \ - { uartlite_serial_puts(s, port); } - -/* Serial device descriptor */ -#define INIT_ESERIAL_STRUCTURE(port, __name) { \ - .name = __name, \ - .start = userial##port##_init, \ - .stop = NULL, \ - .setbrg = userial##port##_setbrg, \ - .getc = userial##port##_getc, \ - .tstc = userial##port##_tstc, \ - .putc = userial##port##_putc, \ - .puts = userial##port##_puts, \ -} - -DECLARE_ESERIAL_FUNCTIONS(0); -struct serial_device uartlite_serial0_device = - INIT_ESERIAL_STRUCTURE(0, "ttyUL0"); -DECLARE_ESERIAL_FUNCTIONS(1); -struct serial_device uartlite_serial1_device = - INIT_ESERIAL_STRUCTURE(1, "ttyUL1"); -DECLARE_ESERIAL_FUNCTIONS(2); -struct serial_device uartlite_serial2_device = - INIT_ESERIAL_STRUCTURE(2, "ttyUL2"); -DECLARE_ESERIAL_FUNCTIONS(3); -struct serial_device uartlite_serial3_device = - INIT_ESERIAL_STRUCTURE(3, "ttyUL3"); - -__weak struct serial_device *default_serial_console(void) +static int uartlite_serial_ofdata_to_platdata(struct udevice *dev) { - if (userial_ports[0]) - return &uartlite_serial0_device; - if (userial_ports[1]) - return &uartlite_serial1_device; - if (userial_ports[2]) - return &uartlite_serial2_device; - if (userial_ports[3]) - return &uartlite_serial3_device; - - return NULL; -} + struct uartlite_priv *priv = dev_get_priv(dev); + fdt_addr_t addr;
-void uartlite_serial_initialize(void) -{ -#ifdef XILINX_UARTLITE_BASEADDR - serial_register(&uartlite_serial0_device); -#endif /* XILINX_UARTLITE_BASEADDR */ -#ifdef XILINX_UARTLITE_BASEADDR1 - serial_register(&uartlite_serial1_device); -#endif /* XILINX_UARTLITE_BASEADDR1 */ -#ifdef XILINX_UARTLITE_BASEADDR2 - serial_register(&uartlite_serial2_device); -#endif /* XILINX_UARTLITE_BASEADDR2 */ -#ifdef XILINX_UARTLITE_BASEADDR3 - serial_register(&uartlite_serial3_device); -#endif /* XILINX_UARTLITE_BASEADDR3 */ + addr = fdtdec_get_addr(gd->fdt_blob, dev->of_offset, "reg"); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + priv->regs = (struct uartlite *)addr; + + return 0; } + +static const struct dm_serial_ops uartlite_serial_ops = { + .putc = uartlite_serial_putc, + .pending = uartlite_serial_pending, + .getc = uartlite_serial_getc, +}; + +static const struct udevice_id uartlite_serial_ids[] = { + { .compatible = "xlnx,xps-uartlite-1.00.a" }, + { } +}; + +U_BOOT_DRIVER(serial_uartlite) = { + .name = "serial_uartlite", + .id = UCLASS_SERIAL, + .of_match = uartlite_serial_ids, + .ofdata_to_platdata = uartlite_serial_ofdata_to_platdata, + .priv_auto_alloc_size = sizeof(struct uartlite_priv), + .probe = uartlite_serial_probe, + .ops = &uartlite_serial_ops, + .flags = DM_FLAG_PRE_RELOC, +};
Hi Michal,
On 2015年12月11日 19:54, Michal Simek wrote:
Enable SPL DM too.
select DM_SERIAL
endchoice
- (C) Copyright 2008-2011 Michal Simek monstr@monstr.eu
- (C) Copyright 2008 - 2015 Michal Simek monstr@monstr.eu
- Clean driver and add xilinx constant from header file
- (C) Copyright 2004 Atmark Techno, Inc.
@@ -10,11 +10,17 @@
Move to debug uart section.
watchdog.h is not needed.
- struct uartlite *regs; };
- struct uartlite_priv *priv = dev_get_priv(dev);
- struct uartlite *regs = priv->regs;
- if (c == '\n')
- if (in_be32(®s->status) & SR_TX_FIFO_FULL)
return -EAGAIN;
- out_be32(®s->tx_fifo, ch & 0xff);
- while (*s)
- return 0; }
- if (!(in_be32(®s->status) & SR_RX_FIFO_VALID_DATA))
return -EAGAIN;
return in_be32(®s->rx_fifo) & 0xff; };
- if (input)
- return in_be32(®s->status) & SR_TX_FIFO_EMPTY; }
- if (regs) {
- out_be32(®s->control, ULITE_CONTROL_RST_RX | ULITE_CONTROL_RST_TX);
- return -1;
- return 0; }
- .name = __name, \
- .stop = NULL, \
- return NULL;
Since the conversion is "ofdatta to platdata", this should be platdata rather than priv. If there is not variable part, you may simply use platdata in the ops. In some cases, you may add device from platdata without ofdata.
- fdt_addr_t addr;
- addr = fdtdec_get_addr(gd->fdt_blob, dev->of_offset, "reg");
Use dev_get_addr() is preferred.
- if (addr == FDT_ADDR_T_NONE)
return -EINVAL;
- priv->regs = (struct uartlite *)addr;
- return 0; }
- .putc = uartlite_serial_putc,
- .pending = uartlite_serial_pending,
- .getc = uartlite_serial_getc,
- { .compatible = "xlnx,xps-uartlite-1.00.a" },
Please add binding to doc/device-tree-bindings/serial/ .
- .name = "serial_uartlite",
- .id = UCLASS_SERIAL,
- .of_match = uartlite_serial_ids,
- .ofdata_to_platdata = uartlite_serial_ofdata_to_platdata,
- .priv_auto_alloc_size = sizeof(struct uartlite_priv),
maybe platdata.
- .probe = uartlite_serial_probe,
- .ops = &uartlite_serial_ops,
- .flags = DM_FLAG_PRE_RELOC,
Thanks.
Best regards, Thomas
On 14.12.2015 15:47, Thomas Chou wrote:
Hi Michal,
Enable SPL DM too.
select DM_SERIAL
endchoice
@@ -10,11 +10,17 @@
ok these two should be added when debug_uart is added. The rest is in the second reply.
- if (c == '\n')
return -EAGAIN;
- while (*s)
- return 0; }
return -EAGAIN;
}; return in_be32(®s->rx_fifo) & 0xff;
- if (input)
- if (regs) {
- return -1;
- return 0; }
- .name = __name, \
- .stop = NULL, \
- return NULL;
look below.
- fdt_addr_t addr;
Will fix thanks.
return -EINVAL;
- return 0; }
ok.
maybe platdata.
no problem with it.
Thanks, Michal
drivers/serial/Kconfig | 7 +++++++ drivers/serial/serial_xuartlite.c | 23 +++++++++++++++++++++++ 2 files changed, 30 insertions(+)
diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 1fc287ee98ec..f1e221799b81 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -92,6 +92,13 @@ config DEBUG_UART_S5P will need to provide parameters to make this work. The driver will be available until the real driver-model serial is running.
+config DEBUG_UART_UARTLITE + bool "Xilinx Uartlite" + help + Select this to enable a debug UART using the serial_uartlite driver. + You will need to provide parameters to make this work. The driver will + be available until the real driver-model serial is running. + config DEBUG_UART_ZYNQ bool "Xilinx Zynq" help diff --git a/drivers/serial/serial_xuartlite.c b/drivers/serial/serial_xuartlite.c index 10089f5a34b5..fe87b515d902 100644 --- a/drivers/serial/serial_xuartlite.c +++ b/drivers/serial/serial_xuartlite.c @@ -120,3 +120,26 @@ U_BOOT_DRIVER(serial_uartlite) = { .ops = &uartlite_serial_ops, .flags = DM_FLAG_PRE_RELOC, }; + +#ifdef CONFIG_DEBUG_UART_UARTLITE +void _debug_uart_init(void) +{ + struct uartlite *regs = (struct uartlite *)CONFIG_DEBUG_UART_BASE; + + out_be32(®s->control, 0); + out_be32(®s->control, ULITE_CONTROL_RST_RX | ULITE_CONTROL_RST_TX); + in_be32(®s->control); +} + +static inline void _debug_uart_putc(int ch) +{ + struct uartlite *regs = (struct uartlite *)CONFIG_DEBUG_UART_BASE; + + while (in_be32(®s->status) & SR_TX_FIFO_FULL) + WATCHDOG_RESET(); + + out_be32(®s->tx_fifo, ch & 0xff); +} + +DEBUG_UART_FUNCS +#endif
Hi Michal,
- bool "Xilinx Uartlite"
- help
- config DEBUG_UART_ZYNQ bool "Xilinx Zynq" help
Better move the "#include <debug_uart.h>" here.
Please add "static inline" to void _debug_uart_init(void).
- struct uartlite *regs = (struct uartlite *)CONFIG_DEBUG_UART_BASE;
WATCHDOG_RESET();
WATCHDOG_RESET() is not really needed for debug serial output.
On 14.12.2015 14:14, Thomas Chou wrote:
Hi Michal,
- help
driver.
driver will
This is the patch I sent some days ago about removing it from this location and it was Reviewed twice. http://lists.denx.de/pipermail/u-boot/2015-December/236341.html
Ok. Will fix this for uartlite and zynq uart in follow up patch.
WATCHDOG_RESET();
TBH I don't think so. There could be watchdog running from early bootloader and needs to be service even for debugging purpose.
Thanks, Michal
Hi Michal,
Hi Michal,
- help
driver.
driver will
This is because commit 42800ffa7997 ("arm: zynq: Move serial driver to driver model") added the extra #include <debug_uart.h>. It is this one should be removed. The original one in commit c54c0a4c1c74 ("arm: zynq: Support the debug UART") is good. The wrong one was removed.
WATCHDOG_RESET();
Unless the serial input clock is dead, the serial shift out in UART won't take so long to trigger watchdog.
On 15.12.2015 05:01, Thomas Chou wrote:
Hi Michal,
Hi Michal,
- help
driver.
driver will
I tend to have headers in the same location for the whole file It will be easier to include this file when CONFIG_DEBUG_UART is enabled. But no problem to move it. It is not causing any difference for me.
WATCHDOG_RESET();
Uartlite driver is also the part of MDM which is console over jtag which can take some time. But TBH if you like, I will remove it in v2.
Thanks, Michal
Hi Michal,
Hi Michal,
Hi Michal,
- help
driver.
driver will
WATCHDOG_RESET();
Now I understand. Either is fine. Thanks for the explanation.
- Move config option out of board file. - Remove uartlite address from config file
board/xilinx/microblaze-generic/xparameters.h | 4 ---- configs/microblaze-generic_defconfig | 1 + drivers/serial/Kconfig | 7 +++++++ include/configs/microblaze-generic.h | 7 +------ 4 files changed, 9 insertions(+), 10 deletions(-)
diff --git a/board/xilinx/microblaze-generic/xparameters.h b/board/xilinx/microblaze-generic/xparameters.h index 8ba146cb88db..11b3c9a4846e 100644 --- a/board/xilinx/microblaze-generic/xparameters.h +++ b/board/xilinx/microblaze-generic/xparameters.h @@ -28,10 +28,6 @@ #define XILINX_TIMER_BASEADDR 0x41c00000 #define XILINX_TIMER_IRQ 0
-/* Uart pheriphery is RS232_Uart */ -#define XILINX_UARTLITE_BASEADDR 0x40600000 -#define XILINX_UARTLITE_BAUDRATE 115200 - /* IIC pheriphery is IIC_EEPROM */ #define XILINX_IIC_0_BASEADDR 0x40800000 #define XILINX_IIC_0_FREQ 100000 diff --git a/configs/microblaze-generic_defconfig b/configs/microblaze-generic_defconfig index 5df080b6a87c..9a7bb915466f 100644 --- a/configs/microblaze-generic_defconfig +++ b/configs/microblaze-generic_defconfig @@ -9,3 +9,4 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_XILINX_UARTLITE=y diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index f1e221799b81..ddf49ba9cef3 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -230,4 +230,11 @@ config UNIPHIER_SERIAL If you have a UniPhier based board and want to use the on-chip serial ports, say Y to this option. If unsure, say N.
+config XILINX_UARTLITE + bool "Xilinx Uarlite support" + depends on DM_SERIAL && (MICROBLAZE || ARCH_ZYNQ || ARCH_ZYNQMP) + help + If you have a Xilinx based board and want to use the uartlite + serial ports, say Y to this option. If unsure, say N. + endmenu diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index 10ac8328b8ff..6e3c80b14350 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -37,10 +37,7 @@ # define CONFIG_SYS_BAUDRATE_TABLE \ {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200, 230400}
-#ifdef XILINX_UARTLITE_BASEADDR -# define CONFIG_XILINX_UARTLITE -# define CONFIG_SERIAL_BASE XILINX_UARTLITE_BASEADDR -#elif XILINX_UART16550_BASEADDR +#if XILINX_UART16550_BASEADDR # define CONFIG_SYS_NS16550_SERIAL # if defined(__MICROBLAZEEL__) # define CONFIG_SYS_NS16550_REG_SIZE -4 @@ -51,8 +48,6 @@ # define CONFIG_SYS_NS16550_COM1 \ ((XILINX_UART16550_BASEADDR & ~0xF) + 0x1000) # define CONFIG_SYS_NS16550_CLK XILINX_UART16550_CLOCK_HZ -#else -# error Undefined uart #endif
/* setting reset address */
Hi Michal,
- bool "Xilinx Uarlite support"
- depends on DM_SERIAL && (MICROBLAZE || ARCH_ZYNQ || ARCH_ZYNQMP)
- help
- endmenu
Kconfig should be with the driver 1/3. Others are boards related.
Thanks.
On 14.12.2015 15:35, Thomas Chou wrote:
Hi Michal,
- help
- endmenu
It can be. Adding Kconfig fragment can be separate patch out of move to DM. There is no connection too. My intention was to show all related changes which are done by this one step.
Thanks, Michal
Hi Michal,
Hi Michal,
- help
- endmenu
Please also make sure the patch series are bisectable.
On 15.12.2015 05:02, Thomas Chou wrote:
Hi Michal,
Hi Michal,
- help
- endmenu
I am not aware about anything what would caused that this series is not bisectable. Do you see something like that?
Thanks, Michal
Hi Michal,
Hi Michal,
Hi Michal,
- help
- endmenu
No. Sorry. I didn't find DM and DM_serial in the microblaze repo at first. Then I found them in the patches earlier.
Michal Simek
Thomas Chou
