[PATCH] net: ti: am65-cpsw-nuss: don't touch DMA after stop
From: Alexander Sverdlin alexander.sverdlin@siemens.com
Contrary to doc/develop/driver-model/ethernet.rst contract, eth_ops .free_pkt can be called after .stop, there are several error paths in TFTP, for instance:
eth_halt() <= tftp_handler() <= net_process_received_packet() <= eth_rx() ... am65_cpsw_free_pkt() <= eth_rx()
Which results in (deliberately "tftpboot"ing non-existing file):
TFTP error: 'File not found' (1) Not retrying... am65_cpsw_nuss_port ethernet@8000000port@1: RX dma free_pkt failed -22
Avoid the error message by checking that the interface is still not stopped in am65_cpsw_free_pkt().
Fixes: 9d0dca1199d1 ("net: ethernet: ti: Introduce am654 gigabit eth switch subsystem driver") Signed-off-by: Alexander Sverdlin alexander.sverdlin@siemens.com --- drivers/net/ti/am65-cpsw-nuss.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/net/ti/am65-cpsw-nuss.c b/drivers/net/ti/am65-cpsw-nuss.c index 65ade1afd05..646f618afcf 100644 --- a/drivers/net/ti/am65-cpsw-nuss.c +++ b/drivers/net/ti/am65-cpsw-nuss.c @@ -523,6 +523,9 @@ static int am65_cpsw_free_pkt(struct udevice *dev, uchar *packet, int length) struct am65_cpsw_common *common = priv->cpsw_common; int ret;
+ if (!common->started) + return -ENETDOWN; + if (length > 0) { u32 pkt = common->rx_next % UDMA_RX_DESC_NUM;
Hi Alexander,
Doesn't this mean we need to fix TFTP instead of patching the Ethernet driver? I'm sure the issue is present for all Ethernet drivers as none of them are checking if Ethernet is stopped. Just that most of them don't print any error message so it goes unnoticed.
eth_halt() <= tftp_handler() <= net_process_received_packet() <= eth_rx() ... am65_cpsw_free_pkt() <= eth_rx()> Which results in (deliberately "tftpboot"ing non-existing file):
- if (!common->started)
return -ENETDOWN;
- if (length > 0) { u32 pkt = common->rx_next % UDMA_RX_DESC_NUM;
Hi Roger!
Thanks for looking into this, your proposal makes sense to me! I'll rework!
A. Sverdlin
Roger Quadros
Sverdlin, Alexander
