[U-Boot] [PATCH 0/4] rockchip: sound: Add support for sound on chromebook_jerry
Sound support for jerry was never included in the initial port. Now that sound has been converted to driver model it seems like a good opportunity to fill this gap. Jerry uses an audio codec that is already supported by U-Boot.
Add the required drivers and enable the config so that 'sound play 500 400' can be used to play a beep. Also enable logging for this board.
Simon Glass (4): rockchip: rk3288: Add i2s pinctrl and clock support rockchip: Add an I2S driver rockchip: Add a sound driver sound: rockchip: Add sound support for jerry
arch/arm/dts/rk3288-veyron-jerry.dts | 12 ++ arch/arm/dts/rk3288-veyron.dtsi | 1 + arch/arm/dts/rk3288.dtsi | 1 + .../include/asm/arch-rockchip/cru_rk3288.h | 8 + .../include/asm/arch-rockchip/grf_rk3288.h | 96 +++++++++++ arch/arm/include/asm/arch-rockchip/periph.h | 1 + configs/chromebook_jerry_defconfig | 7 + drivers/clk/rockchip/clk_rk3288.c | 48 ++++++ drivers/pinctrl/rockchip/pinctrl_rk3288.c | 14 ++ drivers/sound/Kconfig | 9 ++ drivers/sound/Makefile | 1 + drivers/sound/rockchip_i2s.c | 149 ++++++++++++++++++ drivers/sound/rockchip_sound.c | 132 ++++++++++++++++ 13 files changed, 479 insertions(+) create mode 100644 drivers/sound/rockchip_i2s.c create mode 100644 drivers/sound/rockchip_sound.c
Add support for setting pinctrl and clock for I2S on rk3288. This allows the sound driver to operate. These settings were created by rkmux.py
.../include/asm/arch-rockchip/cru_rk3288.h | 8 ++ .../include/asm/arch-rockchip/grf_rk3288.h | 96 +++++++++++++++++++ arch/arm/include/asm/arch-rockchip/periph.h | 1 + drivers/clk/rockchip/clk_rk3288.c | 48 ++++++++++ drivers/pinctrl/rockchip/pinctrl_rk3288.c | 14 +++ 5 files changed, 167 insertions(+)
diff --git a/arch/arm/include/asm/arch-rockchip/cru_rk3288.h b/arch/arm/include/asm/arch-rockchip/cru_rk3288.h index 0475598b77b..e891f20b373 100644 --- a/arch/arm/include/asm/arch-rockchip/cru_rk3288.h +++ b/arch/arm/include/asm/arch-rockchip/cru_rk3288.h @@ -75,6 +75,14 @@ enum { MMC0_DIV_MASK = 0x3f << MMC0_DIV_SHIFT, };
+/* CRU_CLKSEL8_CON */ +enum { + I2S0_FRAC_DENOM_SHIFT = 0, + I2S0_FRAC_DENOM_MASK = 0xffff << I2S0_FRAC_DENOM_SHIFT, + I2S0_FRAC_NUMER_SHIFT = 16, + I2S0_FRAC_NUMER_MASK = 0xffffu << I2S0_FRAC_NUMER_SHIFT, +}; + /* CRU_CLKSEL12_CON */ enum { EMMC_PLL_SHIFT = 0xe, diff --git a/arch/arm/include/asm/arch-rockchip/grf_rk3288.h b/arch/arm/include/asm/arch-rockchip/grf_rk3288.h index c235607cee5..77295446c63 100644 --- a/arch/arm/include/asm/arch-rockchip/grf_rk3288.h +++ b/arch/arm/include/asm/arch-rockchip/grf_rk3288.h @@ -561,6 +561,49 @@ enum { GPIO5C0_TS0_SYNC, };
+/* GRF_GPIO6A_IOMUX */ +enum { + GPIO6A7_SHIFT = 0xe, + GPIO6A7_MASK = 1, + GPIO6A7_GPIO = 0, + GPIO6A7_I2S_SDO3, + + GPIO6A6_SHIFT = 0xc, + GPIO6A6_MASK = 1, + GPIO6A6_GPIO = 0, + GPIO6A6_I2S_SDO2, + + GPIO6A5_SHIFT = 0xa, + GPIO6A5_MASK = 1, + GPIO6A5_GPIO = 0, + GPIO6A5_I2S_SDO1, + + GPIO6A4_SHIFT = 8, + GPIO6A4_MASK = 1, + GPIO6A4_GPIO = 0, + GPIO6A4_I2S_SDO0, + + GPIO6A3_SHIFT = 6, + GPIO6A3_MASK = 1, + GPIO6A3_GPIO = 0, + GPIO6A3_I2S_SDI, + + GPIO6A2_SHIFT = 4, + GPIO6A2_MASK = 1, + GPIO6A2_GPIO = 0, + GPIO6A2_I2S_LRCKTX, + + GPIO6A1_SHIFT = 2, + GPIO6A1_MASK = 1, + GPIO6A1_GPIO = 0, + GPIO6A1_I2S_LRCKRX, + + GPIO6A0_SHIFT = 0, + GPIO6A0_MASK = 1, + GPIO6A0_GPIO = 0, + GPIO6A0_I2S_SCLK, +}; + /* GRF_GPIO6B_IOMUX */ enum { GPIO6B3_SHIFT = 6, @@ -1042,6 +1085,59 @@ enum GRF_SOC_CON8 { RK3288_DPHY_TX0_TURNREQUEST_DIS = 0, };
+/* GRF_IO_VSEL */ +enum { + GPIO1830_V18SEL_SHIFT = 9, + GPIO1830_V18SEL_MASK = 1, + GPIO1830_V18SEL_3_3V = 0, + GPIO1830_V18SEL_1_8V, + + GPIO30_V18SEL_SHIFT = 8, + GPIO30_V18SEL_MASK = 1, + GPIO30_V18SEL_3_3V = 0, + GPIO30_V18SEL_1_8V, + + SDCARD_V18SEL_SHIFT = 7, + SDCARD_V18SEL_MASK = 1, + SDCARD_V18SEL_3_3V = 0, + SDCARD_V18SEL_1_8V, + + AUDIO_V18SEL_SHIFT = 6, + AUDIO_V18SEL_MASK = 1, + AUDIO_V18SEL_3_3V = 0, + AUDIO_V18SEL_1_8V, + + BB_V18SEL_SHIFT = 5, + BB_V18SEL_MASK = 1, + BB_V18SEL_3_3V = 0, + BB_V18SEL_1_8V, + + WIFI_V18SEL_SHIFT = 4, + WIFI_V18SEL_MASK = 1, + WIFI_V18SEL_3_3V = 0, + WIFI_V18SEL_1_8V, + + FLASH1_V18SEL_SHIFT = 3, + FLASH1_V18SEL_MASK = 1, + FLASH1_V18SEL_3_3V = 0, + FLASH1_V18SEL_1_8V, + + FLASH0_V18SEL_SHIFT = 2, + FLASH0_V18SEL_MASK = 1, + FLASH0_V18SEL_3_3V = 0, + FLASH0_V18SEL_1_8V, + + DVP_V18SEL_SHIFT = 1, + DVP_V18SEL_MASK = 1, + DVP_V18SEL_3_3V = 0, + DVP_V18SEL_1_8V, + + LCDC_V18SEL_SHIFT = 0, + LCDC_V18SEL_MASK = 1, + LCDC_V18SEL_3_3V = 0, + LCDC_V18SEL_1_8V, +}; + /* GPIO Bias settings */ enum GPIO_BIAS { GPIO_BIAS_2MA = 0, diff --git a/arch/arm/include/asm/arch-rockchip/periph.h b/arch/arm/include/asm/arch-rockchip/periph.h index 514baf6a535..2191b7d43a8 100644 --- a/arch/arm/include/asm/arch-rockchip/periph.h +++ b/arch/arm/include/asm/arch-rockchip/periph.h @@ -45,6 +45,7 @@ enum periph_id { PERIPH_ID_HDMI, PERIPH_ID_GMAC, PERIPH_ID_SFC, + PERIPH_ID_I2S,
PERIPH_ID_COUNT,
diff --git a/drivers/clk/rockchip/clk_rk3288.c b/drivers/clk/rockchip/clk_rk3288.c index 4a6e5c7113d..930c99f4d9f 100644 --- a/drivers/clk/rockchip/clk_rk3288.c +++ b/drivers/clk/rockchip/clk_rk3288.c @@ -6,6 +6,7 @@ #include <common.h> #include <bitfield.h> #include <clk-uclass.h> +#include <div64.h> #include <dm.h> #include <dt-structs.h> #include <errno.h> @@ -371,6 +372,50 @@ static int rockchip_vop_set_clk(struct rk3288_cru *cru, struct rk3288_grf *grf,
return 0; } + +static u32 rockchip_clk_gcd(u32 a, u32 b) +{ + while (b != 0) { + int r = b; + + b = a % b; + a = r; + } + return a; +} + +static ulong rockchip_i2s_get_clk(struct rk3288_cru *cru, uint gclk_rate) +{ + unsigned long long rate; + uint val; + int n, d; + + val = readl(&cru->cru_clksel_con[8]); + n = (val & I2S0_FRAC_NUMER_MASK) >> I2S0_FRAC_NUMER_SHIFT; + d = (val & I2S0_FRAC_DENOM_MASK) >> I2S0_FRAC_DENOM_SHIFT; + + rate = (unsigned long long)gclk_rate * n; + do_div(rate, d); + + return (ulong)rate; +} + +static ulong rockchip_i2s_set_clk(struct rk3288_cru *cru, uint gclk_rate, + uint freq) +{ + int n, d; + int v; + + /* set frac divider */ + v = rockchip_clk_gcd(gclk_rate, freq); + n = gclk_rate / v; + d = freq / v; + assert(freq == gclk_rate / n * d); + writel(d << I2S0_FRAC_NUMER_SHIFT | n << I2S0_FRAC_DENOM_SHIFT, + &cru->cru_clksel_con[8]); + + return rockchip_i2s_get_clk(cru, gclk_rate); +} #endif /* CONFIG_SPL_BUILD */
static void rkclk_init(struct rk3288_cru *cru, struct rk3288_grf *grf) @@ -769,6 +814,9 @@ static ulong rk3288_clk_set_rate(struct clk *clk, ulong rate) new_rate = rockchip_spi_set_clk(cru, gclk_rate, clk->id, rate); break; #ifndef CONFIG_SPL_BUILD + case SCLK_I2S0: + new_rate = rockchip_i2s_set_clk(cru, gclk_rate, rate); + break; case SCLK_MAC: new_rate = rockchip_mac_set_clk(priv->cru, rate); break; diff --git a/drivers/pinctrl/rockchip/pinctrl_rk3288.c b/drivers/pinctrl/rockchip/pinctrl_rk3288.c index 3e01cfd98f4..fd19cfb51cc 100644 --- a/drivers/pinctrl/rockchip/pinctrl_rk3288.c +++ b/drivers/pinctrl/rockchip/pinctrl_rk3288.c @@ -531,6 +531,17 @@ static void pinctrl_rk3288_hdmi_config(struct rk3288_grf *grf, int hdmi_id) break; } } + +static void pinctrl_rk3288_i2s_config(struct rk3288_grf *grf) +{ + rk_setreg(&grf->gpio6a_iomux, GPIO6A4_I2S_SDO0 << GPIO6A4_SHIFT | + GPIO6A3_I2S_SDI << GPIO6A3_SHIFT | + GPIO6A2_I2S_LRCKTX << GPIO6A2_SHIFT | + GPIO6A1_I2S_LRCKRX << GPIO6A1_SHIFT | + GPIO6A0_I2S_SCLK << GPIO6A0_SHIFT); + rk_setreg(&grf->gpio6b_iomux, GPIO6B0_I2S_CLK << GPIO6B0_SHIFT); + rk_setreg(&grf->io_vsel, AUDIO_V18SEL_1_8V << AUDIO_V18SEL_SHIFT); +} #endif
static int rk3288_pinctrl_request(struct udevice *dev, int func, int flags) @@ -567,6 +578,9 @@ static int rk3288_pinctrl_request(struct udevice *dev, int func, int flags) pinctrl_rk3288_uart_config(priv->grf, func); break; #ifndef CONFIG_SPL_BUILD + case PERIPH_ID_I2S: + pinctrl_rk3288_i2s_config(priv->grf); + break; case PERIPH_ID_LCDC0: case PERIPH_ID_LCDC1: pinctrl_rk3288_lcdc_config(priv->grf, func);
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Applied to u-boot-rockchip, thanks!
Add a driver for I2S which allows audio data to be sent from the SoC to the audio codec. The sample rate and other settings are hard-coded for now as there is no suitable device-tree binding available.
drivers/sound/Kconfig | 9 +++ drivers/sound/Makefile | 1 + drivers/sound/rockchip_i2s.c | 149 +++++++++++++++++++++++++++++++++++ 3 files changed, 159 insertions(+) create mode 100644 drivers/sound/rockchip_i2s.c
diff --git a/drivers/sound/Kconfig b/drivers/sound/Kconfig index cdd8d0f046c..fef6403a86f 100644 --- a/drivers/sound/Kconfig +++ b/drivers/sound/Kconfig @@ -21,6 +21,15 @@ config I2S I2S. It calls either of the two supported codecs (no use is made of driver model at present).
+config I2S_ROCKCHIP + bool "Enable I2S support for Rockchip SoCs" + depends on I2S + help + Rockchip SoCs support an I2S interface for sending audio data to an + audio codec. This option enables support for this, using one of the + available audio codec drivers. This driver does not make use of + DMA, but writes each word directly to the hardware. + config I2S_SAMSUNG bool "Enable I2C support for Samsung SoCs" depends on I2S diff --git a/drivers/sound/Makefile b/drivers/sound/Makefile index 6925f0b6ec2..061f5f7052a 100644 --- a/drivers/sound/Makefile +++ b/drivers/sound/Makefile @@ -9,6 +9,7 @@ obj-$(CONFIG_SOUND) += i2s-uclass.o obj-$(CONFIG_SOUND) += sound-uclass.o obj-$(CONFIG_I2S_SAMSUNG) += samsung-i2s.o obj-$(CONFIG_SOUND_SANDBOX) += sandbox.o +obj-$(CONFIG_I2S_ROCKCHIP) += rockchip_i2s.o obj-$(CONFIG_I2S_SAMSUNG) += samsung_sound.o obj-$(CONFIG_I2S_TEGRA) += tegra_ahub.o tegra_i2s.o tegra_sound.o obj-$(CONFIG_SOUND_WM8994) += wm8994.o diff --git a/drivers/sound/rockchip_i2s.c b/drivers/sound/rockchip_i2s.c new file mode 100644 index 00000000000..e5df8ca0d2b --- /dev/null +++ b/drivers/sound/rockchip_i2s.c @@ -0,0 +1,149 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 Google LLC + * Copyright 2014 Rockchip Electronics Co., Ltd. + * Taken from dc i2s/rockchip.c + */ + +#define LOG_CATEGORY UCLASS_I2S + +#include <common.h> +#include <dm.h> +#include <i2s.h> +#include <sound.h> +#include <asm/io.h> + +struct rk_i2s_regs { + u32 txcr; /* I2S_TXCR, 0x00 */ + u32 rxcr; /* I2S_RXCR, 0x04 */ + u32 ckr; /* I2S_CKR, 0x08 */ + u32 fifolr; /* I2S_FIFOLR, 0x0C */ + u32 dmacr; /* I2S_DMACR, 0x10 */ + u32 intcr; /* I2S_INTCR, 0x14 */ + u32 intsr; /* I2S_INTSR, 0x18 */ + u32 xfer; /* I2S_XFER, 0x1C */ + u32 clr; /* I2S_CLR, 0x20 */ + u32 txdr; /* I2S_TXDR, 0x24 */ + u32 rxdr; /* I2S_RXDR, 0x28 */ +}; + +enum { + /* I2S_XFER */ + I2S_RX_TRAN_BIT = BIT(1), + I2S_TX_TRAN_BIT = BIT(0), + I2S_TRAN_MASK = 3 << 0, + + /* I2S_TXCKR */ + I2S_MCLK_DIV_SHIFT = 16, + I2S_MCLK_DIV_MASK = (0xff << I2S_MCLK_DIV_SHIFT), + + I2S_RX_SCLK_DIV_SHIFT = 8, + I2S_RX_SCLK_DIV_MASK = 0xff << I2S_RX_SCLK_DIV_SHIFT, + I2S_TX_SCLK_DIV_SHIFT = 0, + I2S_TX_SCLK_DIV_MASK = 0xff << I2S_TX_SCLK_DIV_SHIFT, + + I2S_DATA_WIDTH_SHIFT = 0, + I2S_DATA_WIDTH_MASK = 0x1f << I2S_DATA_WIDTH_SHIFT, +}; + +static int rockchip_i2s_init(struct i2s_uc_priv *priv) +{ + struct rk_i2s_regs *regs = (struct rk_i2s_regs *)priv->base_address; + u32 bps = priv->bitspersample; + u32 lrf = priv->rfs; + u32 chn = priv->channels; + u32 mode = 0; + + clrbits_le32(®s->xfer, I2S_TX_TRAN_BIT); + mode = readl(®s->txcr) & ~0x1f; + switch (priv->bitspersample) { + case 16: + case 24: + mode |= (priv->bitspersample - 1) << I2S_DATA_WIDTH_SHIFT; + break; + default: + log_err("Invalid sample size input %d\n", priv->bitspersample); + return -EINVAL; + } + writel(mode, ®s->txcr); + + mode = readl(®s->ckr) & ~I2S_MCLK_DIV_MASK; + mode |= (lrf / (bps * chn) - 1) << I2S_MCLK_DIV_SHIFT; + + mode &= ~I2S_TX_SCLK_DIV_MASK; + mode |= (priv->bitspersample * priv->channels - 1) << + I2S_TX_SCLK_DIV_SHIFT; + writel(mode, ®s->ckr); + + return 0; +} + +static int i2s_send_data(struct rk_i2s_regs *regs, u32 *data, uint length) +{ + for (int i = 0; i < min(32u, length); i++) + writel(*data++, ®s->txdr); + + length -= min(32u, length); + + /* enable both tx and rx */ + setbits_le32(®s->xfer, I2S_TRAN_MASK); + while (length) { + if ((readl(®s->fifolr) & 0x3f) < 0x20) { + writel(*data++, ®s->txdr); + length--; + } + } + while (readl(®s->fifolr) & 0x3f) + /* wait until FIFO empty */; + clrbits_le32(®s->xfer, I2S_TRAN_MASK); + writel(0, ®s->clr); + + return 0; +} + +static int rockchip_i2s_tx_data(struct udevice *dev, void *data, uint data_size) +{ + struct i2s_uc_priv *priv = dev_get_uclass_priv(dev); + struct rk_i2s_regs *regs = (struct rk_i2s_regs *)priv->base_address; + + return i2s_send_data(regs, data, data_size / sizeof(u32)); +} + +static int rockchip_i2s_probe(struct udevice *dev) +{ + struct i2s_uc_priv *priv = dev_get_uclass_priv(dev); + ulong base; + + base = dev_read_addr(dev); + if (base == FDT_ADDR_T_NONE) { + log_debug("Missing i2s base\n"); + return -EINVAL; + } + priv->base_address = base; + priv->id = 1; + priv->audio_pll_clk = 4800000; + priv->samplingrate = 48000; + priv->bitspersample = 16; + priv->channels = 2; + priv->rfs = 256; + priv->bfs = 32; + + return rockchip_i2s_init(priv); +} + +static const struct i2s_ops rockchip_i2s_ops = { + .tx_data = rockchip_i2s_tx_data, +}; + +static const struct udevice_id rockchip_i2s_ids[] = { + { .compatible = "rockchip,rk3288-i2s" }, + { } +}; + +U_BOOT_DRIVER(rockchip_i2s) = { + .name = "rockchip_i2s", + .id = UCLASS_I2S, + .of_match = rockchip_i2s_ids, + .probe = rockchip_i2s_probe, + .ops = &rockchip_i2s_ops, +};
Add a sound driver for rk3288 supporting chromebook_jerry. This uses the I2S driver, and existing audio codec and the clock/pinmux support.
drivers/sound/Makefile | 2 +- drivers/sound/rockchip_sound.c | 132 +++++++++++++++++++++++++++++++++ 2 files changed, 133 insertions(+), 1 deletion(-) create mode 100644 drivers/sound/rockchip_sound.c
diff --git a/drivers/sound/Makefile b/drivers/sound/Makefile index 061f5f7052a..15c3745b416 100644 --- a/drivers/sound/Makefile +++ b/drivers/sound/Makefile @@ -9,7 +9,7 @@ obj-$(CONFIG_SOUND) += i2s-uclass.o obj-$(CONFIG_SOUND) += sound-uclass.o obj-$(CONFIG_I2S_SAMSUNG) += samsung-i2s.o obj-$(CONFIG_SOUND_SANDBOX) += sandbox.o -obj-$(CONFIG_I2S_ROCKCHIP) += rockchip_i2s.o +obj-$(CONFIG_I2S_ROCKCHIP) += rockchip_i2s.o rockchip_sound.o obj-$(CONFIG_I2S_SAMSUNG) += samsung_sound.o obj-$(CONFIG_I2S_TEGRA) += tegra_ahub.o tegra_i2s.o tegra_sound.o obj-$(CONFIG_SOUND_WM8994) += wm8994.o diff --git a/drivers/sound/rockchip_sound.c b/drivers/sound/rockchip_sound.c new file mode 100644 index 00000000000..e7fb9fb1646 --- /dev/null +++ b/drivers/sound/rockchip_sound.c @@ -0,0 +1,132 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 Google, LLC + * Written by Simon Glass sjg@chromium.org + */ + +#define LOG_CATEGORY UCLASS_SOUND + +#include <common.h> +#include <audio_codec.h> +#include <clk.h> +#include <dm.h> +#include <i2s.h> +#include <misc.h> +#include <sound.h> +#include <asm/arch/periph.h> +#include <dm/pinctrl.h> + +static int rockchip_sound_setup(struct udevice *dev) +{ + struct sound_uc_priv *uc_priv = dev_get_uclass_priv(dev); + struct i2s_uc_priv *i2c_priv = dev_get_uclass_priv(uc_priv->i2s); + int ret; + + if (uc_priv->setup_done) + return -EALREADY; + ret = audio_codec_set_params(uc_priv->codec, i2c_priv->id, + i2c_priv->samplingrate, + i2c_priv->samplingrate * i2c_priv->rfs, + i2c_priv->bitspersample, + i2c_priv->channels); + if (ret) + return ret; + uc_priv->setup_done = true; + + return 0; +} + +static int rockchip_sound_play(struct udevice *dev, void *data, uint data_size) +{ + struct sound_uc_priv *uc_priv = dev_get_uclass_priv(dev); + + return i2s_tx_data(uc_priv->i2s, data, data_size); +} + +static int rockchip_sound_probe(struct udevice *dev) +{ + struct sound_uc_priv *uc_priv = dev_get_uclass_priv(dev); + struct ofnode_phandle_args args; + struct udevice *pinctrl; + struct clk clk; + ofnode node; + int ret; + + node = ofnode_find_subnode(dev_ofnode(dev), "cpu"); + if (!ofnode_valid(node)) { + log_debug("Failed to find /cpu subnode\n"); + return -EINVAL; + } + ret = ofnode_parse_phandle_with_args(node, "sound-dai", + "#sound-dai-cells", 0, 0, &args); + if (ret) { + log_debug("Cannot find i2s phandle: %d\n", ret); + return ret; + } + ret = uclass_get_device_by_ofnode(UCLASS_I2S, args.node, &uc_priv->i2s); + if (ret) { + log_debug("Cannot find i2s: %d\n", ret); + return ret; + } + + node = ofnode_find_subnode(dev_ofnode(dev), "codec"); + if (!ofnode_valid(node)) { + log_debug("Failed to find /codec subnode\n"); + return -EINVAL; + } + ret = ofnode_parse_phandle_with_args(node, "sound-dai", + "#sound-dai-cells", 0, 0, &args); + if (ret) { + log_debug("Cannot find codec phandle: %d\n", ret); + return ret; + } + ret = uclass_get_device_by_ofnode(UCLASS_AUDIO_CODEC, args.node, + &uc_priv->codec); + if (ret) { + log_debug("Cannot find audio codec: %d\n", ret); + return ret; + } + ret = clk_get_by_index(uc_priv->i2s, 1, &clk); + if (ret) { + log_debug("Cannot find clock: %d\n", ret); + return ret; + } + ret = clk_set_rate(&clk, 12288000); + if (ret < 0) { + log_debug("Cannot find clock: %d\n", ret); + return ret; + } + ret = uclass_get_device(UCLASS_PINCTRL, 0, &pinctrl); + if (ret) { + debug("%s: Cannot find pinctrl device\n", __func__); + return ret; + } + ret = pinctrl_request(pinctrl, PERIPH_ID_I2S, 0); + if (ret) { + debug("%s: Cannot select I2C pinctrl\n", __func__); + return ret; + } + + log_debug("Probed sound '%s' with codec '%s' and i2s '%s'\n", dev->name, + uc_priv->codec->name, uc_priv->i2s->name); + + return 0; +} + +static const struct sound_ops rockchip_sound_ops = { + .setup = rockchip_sound_setup, + .play = rockchip_sound_play, +}; + +static const struct udevice_id rockchip_sound_ids[] = { + { .compatible = "rockchip,audio-max98090-jerry" }, + { } +}; + +U_BOOT_DRIVER(rockchip_sound) = { + .name = "rockchip_sound", + .id = UCLASS_SOUND, + .of_match = rockchip_sound_ids, + .probe = rockchip_sound_probe, + .ops = &rockchip_sound_ops, +};
Jerry uses a max98090 audio codec and the internal SoC I2S peripheral. Enable sound support and add the required device-tree pieces.
arch/arm/dts/rk3288-veyron-jerry.dts | 12 ++++++++++++ arch/arm/dts/rk3288-veyron.dtsi | 1 + arch/arm/dts/rk3288.dtsi | 1 + configs/chromebook_jerry_defconfig | 7 +++++++ 4 files changed, 21 insertions(+)
diff --git a/arch/arm/dts/rk3288-veyron-jerry.dts b/arch/arm/dts/rk3288-veyron-jerry.dts index 42f52d4d99a..c251d9d5942 100644 --- a/arch/arm/dts/rk3288-veyron-jerry.dts +++ b/arch/arm/dts/rk3288-veyron-jerry.dts @@ -52,6 +52,18 @@ vin-supply = <&vcc33_sys>; startup-delay-us = <15000>; }; + + sound { + compatible = "rockchip,audio-max98090-jerry"; + + cpu { + sound-dai = <&i2s 0>; + }; + + codec { + sound-dai = <&max98090 0>; + }; + }; };
&dmc { diff --git a/arch/arm/dts/rk3288-veyron.dtsi b/arch/arm/dts/rk3288-veyron.dtsi index 92b68878fd0..49ba3f3f143 100644 --- a/arch/arm/dts/rk3288-veyron.dtsi +++ b/arch/arm/dts/rk3288-veyron.dtsi @@ -484,6 +484,7 @@ max98090: max98090@10 { compatible = "maxim,max98090"; reg = <0x10>; + #sound-dai-cells = <0>; interrupt-parent = <&gpio6>; interrupts = <7 IRQ_TYPE_EDGE_FALLING>; pinctrl-names = "default"; diff --git a/arch/arm/dts/rk3288.dtsi b/arch/arm/dts/rk3288.dtsi index 273d38c84f5..487d22c9b01 100644 --- a/arch/arm/dts/rk3288.dtsi +++ b/arch/arm/dts/rk3288.dtsi @@ -649,6 +649,7 @@ interrupts = <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; + #sound-dai-cells = <1>; dmas = <&dmac_bus_s 0>, <&dmac_bus_s 1>; dma-names = "tx", "rx"; clock-names = "i2s_hclk", "i2s_clk"; diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index 94a1af01be0..b1e119f9a26 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -14,6 +14,8 @@ CONFIG_DEBUG_UART=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_SILENT_CONSOLE=y +CONFIG_LOG=y +CONFIG_LOG_DEFAULT_LEVEL=7 CONFIG_DEFAULT_FDT_FILE="rk3288-veyron-jerry.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y @@ -32,6 +34,7 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_SOUND=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y # CONFIG_SPL_DOS_PARTITION is not set @@ -76,6 +79,10 @@ CONFIG_RAM=y CONFIG_SPL_RAM=y CONFIG_DEBUG_UART_SHIFT=2 CONFIG_ROCKCHIP_SERIAL=y +CONFIG_SOUND=y +CONFIG_I2S=y +CONFIG_I2S_ROCKCHIP=y +CONFIG_SOUND_MAX98090=y CONFIG_ROCKCHIP_SPI=y CONFIG_SYSRESET=y CONFIG_USB=y
I hope to find time to add support for the RK3399 (which has a sufficiently closely related I2S controller)—and possibly even the RK3368—and for the SGTL5000 codec that we have on the Haikou reference baseboard.
If you don’t hear anything by mid-January, feel free to poke me. Philipp.
Hi Philipp,
On Fri, 28 Dec 2018 at 12:07, Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
Sounds good! Really interested to see how the API works out.
I have been meaning to add support for kevin but have not got to it.
- Simon
Philipp Tomsich
