[U-Boot] [PATCH] i2c: mxc: add CONFIG_CLK support
When CONFIG_CLK enabled, use CLK UCLASS for clk related settings.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/include/asm/mach-imx/mxc_i2c.h | 6 ++++++ drivers/i2c/mxc_i2c.c | 17 +++++++++++++++++ 2 files changed, 23 insertions(+)
diff --git a/arch/arm/include/asm/mach-imx/mxc_i2c.h b/arch/arm/include/asm/mach-imx/mxc_i2c.h index 8e1ea9af19..81fd981444 100644 --- a/arch/arm/include/asm/mach-imx/mxc_i2c.h +++ b/arch/arm/include/asm/mach-imx/mxc_i2c.h @@ -6,6 +6,9 @@ #define __ASM_ARCH_MXC_MXC_I2C_H__ #include <asm-generic/gpio.h> #include <asm/mach-imx/iomux-v3.h> +#if CONFIG_IS_ENABLED(CLK) +#include <clk.h> +#endif
struct i2c_pin_ctrl { iomux_v3_cfg_t i2c_mode; @@ -47,6 +50,9 @@ struct mxc_i2c_bus { ulong driver_data; int speed; struct i2c_pads_info *pads_info; +#if CONFIG_IS_ENABLED(CLK) + struct clk per_clk; +#endif #ifndef CONFIG_DM_I2C int (*idle_bus_fn)(void *p); void *idle_bus_data; diff --git a/drivers/i2c/mxc_i2c.c b/drivers/i2c/mxc_i2c.c index 23119cce65..2e157bca58 100644 --- a/drivers/i2c/mxc_i2c.c +++ b/drivers/i2c/mxc_i2c.c @@ -890,9 +890,22 @@ static int mxc_i2c_probe(struct udevice *bus) i2c_bus->bus = bus;
/* Enable clk */ +#if CONFIG_IS_ENABLED(CLK) + ret = clk_get_by_index(bus, 0, &i2c_bus->per_clk); + if (ret) { + printf("Failed to get i2c clk\n"); + return ret; + } + ret = clk_enable(&i2c_bus->per_clk); + if (ret) { + printf("Failed to enable i2c clk\n"); + return ret; + } +#else ret = enable_i2c_clk(1, bus->seq); if (ret < 0) return ret; +#endif
/* * See Documentation/devicetree/bindings/i2c/i2c-imx.txt @@ -919,7 +932,11 @@ static int mxc_i2c_probe(struct udevice *bus) ret = i2c_idle_bus(i2c_bus); if (ret < 0) { /* Disable clk */ +#if CONFIG_IS_ENABLED(CLK) + clk_disable(&i2c_bus->per_clk); +#else enable_i2c_clk(0, bus->seq); +#endif return ret; }
- struct clk per_clk;
- ret = clk_get_by_index(bus, 0, &i2c_bus->per_clk);
- if (ret) {
return ret;
- ret = clk_enable(&i2c_bus->per_clk);
- if (ret) {
return ret;
Reviewed-by: Ye Li ye.li@nxp.com
Best regards, Ye Li
Hi Peng,
I already commented on a previous version of this patch and the following change is still missing here:
@@ -149,7 +149,11 @@ static uint8_t i2c_imx_get_clk(struct mxc_i2c_bus *i2c_bus, unsigned int rate) #endif
/* Divider value calculation */ +#if CONFIG_IS_ENABLED(CLK) + i2c_clk_rate = clk_get_rate(&i2c_bus->per_clk); +#else i2c_clk_rate = mxc_get_clock(MXC_I2C_CLK); +#endif div = (i2c_clk_rate + rate - 1) / rate; if (div < i2c_clk_div[0][0]) clk_div = 0;
Regards, Frieder
- if (ret) {
return ret;
- if (ret) {
return ret;
Hi Schrempf,
Subject: Re: [U-Boot] [PATCH] i2c: mxc: add CONFIG_CLK support
Hi Peng,
Thanks, I forgot to addressed your comments. Sent out v2, please help review.
Thanks, Peng.
i2c_clk_rate = clk_get_rate(&i2c_bus->per_clk); #else i2c_clk_rate = mxc_get_clock(MXC_I2C_CLK);
Regards, Frieder
- if (ret) {
return ret;
- if (ret) {
return ret;
- if (ret) {
return ret;
- if (ret) {
return ret;
Reviewed-by: Lukasz Majewski lukma@denx.de
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
Hi Lukasz,
Subject: Re: [PATCH] i2c: mxc: add CONFIG_CLK support
#define
#include
- if (ret) {
return ret;
- if (ret) {
return ret;
There is a v2 patch to fix an issue. Please help review there.
Thanks, Peng.
Lukasz Majewski
Lukasz Majewski
Peng Fan
Schrempf Frieder
Ye Li
