Re: [U-Boot] [PATCH 23/93] arm: Remove omap3_overo board
Please hold off on the removal. I just became aware of this. We will get the board updated.
Thanks,
Andrew
---------- Forwarded message ---------
From: Simon Glass sjg@chromium.org Date: Mon, Nov 19, 2018 at 5:54 AM Subject: [PATCH 23/93] arm: Remove omap3_overo board To: U-Boot Mailing List u-boot@lists.denx.de
This board has not been converted to CONFIG_DM_BLK by the deadline. Remove it.
Signed-off-by: Simon Glass sjg@chromium.org
arch/arm/mach-omap2/omap3/Kconfig | 1 - board/overo/Kconfig | 9 - board/overo/MAINTAINERS | 6 - board/overo/Makefile | 10 - board/overo/common.c | 341 ------------------------ board/overo/overo.c | 420 ------------------------------ board/overo/overo.h | 169 ------------ board/overo/spl.c | 59 ----- configs/omap3_overo_defconfig | 51 ---- include/configs/omap3_overo.h | 192 -------------- 10 files changed, 1258 deletions(-) delete mode 100644 board/overo/Kconfig delete mode 100644 board/overo/MAINTAINERS delete mode 100644 board/overo/Makefile delete mode 100644 board/overo/common.c delete mode 100644 board/overo/overo.c delete mode 100644 board/overo/overo.h delete mode 100644 board/overo/spl.c delete mode 100644 configs/omap3_overo_defconfig delete mode 100644 include/configs/omap3_overo.h
diff --git a/arch/arm/mach-omap2/omap3/Kconfig b/arch/arm/mach-omap2/omap3/Kconfig index 9bd07dd8c55..4e8be5f9d04 100644 --- a/arch/arm/mach-omap2/omap3/Kconfig +++ b/arch/arm/mach-omap2/omap3/Kconfig @@ -200,7 +200,6 @@ source "board/compulab/cm_t35/Kconfig" source "board/compulab/cm_t3517/Kconfig" source "board/timll/devkit8000/Kconfig" source "board/ti/evm/Kconfig" -source "board/overo/Kconfig" source "board/ti/am3517crane/Kconfig" source "board/pandora/Kconfig" source "board/8dtech/eco5pk/Kconfig" diff --git a/board/overo/Kconfig b/board/overo/Kconfig deleted file mode 100644 index 74572a62be6..00000000000 --- a/board/overo/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_OMAP3_OVERO
-config SYS_BOARD
default "overo"
-config SYS_CONFIG_NAME
default "omap3_overo"
-endif diff --git a/board/overo/MAINTAINERS b/board/overo/MAINTAINERS deleted file mode 100644 index 8f089e87f8b..00000000000 --- a/board/overo/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -OVERO BOARD -M: Steve Sakoman sakoman@gmail.com -S: Maintained -F: board/overo/ -F: include/configs/omap3_overo.h -F: configs/omap3_overo_defconfig diff --git a/board/overo/Makefile b/board/overo/Makefile deleted file mode 100644 index b62bab9fe4f..00000000000 --- a/board/overo/Makefile +++ /dev/null @@ -1,10 +0,0 @@ -# SPDX-License-Identifier: GPL-2.0+ -# -# (C) Copyright 2000, 2001, 2002 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-ifdef CONFIG_SPL_BUILD -obj-y := spl.o common.o -else -obj-y := overo.o common.o -endif diff --git a/board/overo/common.c b/board/overo/common.c deleted file mode 100644 index fc02d66d531..00000000000 --- a/board/overo/common.c +++ /dev/null @@ -1,341 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/*
- Maintainer : Steve Sakoman steve@sakoman.com
- Derived from Beagle Board, 3430 SDP, and OMAP3EVM code by
Richard Woodruff <r-woodruff2@ti.com>
Syed Mohammed Khasim <khasim@ti.com>
Sunil Kumar <sunilsaini05@gmail.com>
Shashi Ranjan <shashiranjanmca05@gmail.com>
- (C) Copyright 2004-2008
- Texas Instruments, <www.ti.com>
-#include <twl4030.h> -#include <common.h> -#include <asm/io.h> -#include <asm/arch/mux.h> -#include <asm/arch/sys_proto.h> -#include <asm/gpio.h> -#include <asm/mach-types.h>
-DECLARE_GLOBAL_DATA_PTR;
-#define TWL4030_I2C_BUS 0
- Routine: board_init
- Description: Early hardware init.
-int board_init(void) -{
gpmc_init(); /* in SRAM or SDRAM, finish GPMC */
/* board id for Linux */
gd->bd->bi_arch_number = MACH_TYPE_OVERO;
/* boot param addr */
gd->bd->bi_boot_params = (OMAP34XX_SDRC_CS0 + 0x100);
-#define MUX_OVERO() \
- /*SDRC*/\
MUX_VAL(CP(SDRC_D0), (IEN | PTD | DIS | M0))
/*SDRC_D0*/\
MUX_VAL(CP(SDRC_D1), (IEN | PTD | DIS | M0))
/*SDRC_D1*/\
MUX_VAL(CP(SDRC_D2), (IEN | PTD | DIS | M0))
/*SDRC_D2*/\
MUX_VAL(CP(SDRC_D3), (IEN | PTD | DIS | M0))
/*SDRC_D3*/\
MUX_VAL(CP(SDRC_D4), (IEN | PTD | DIS | M0))
/*SDRC_D4*/\
MUX_VAL(CP(SDRC_D5), (IEN | PTD | DIS | M0))
/*SDRC_D5*/\
MUX_VAL(CP(SDRC_D6), (IEN | PTD | DIS | M0))
/*SDRC_D6*/\
MUX_VAL(CP(SDRC_D7), (IEN | PTD | DIS | M0))
/*SDRC_D7*/\
MUX_VAL(CP(SDRC_D8), (IEN | PTD | DIS | M0))
/*SDRC_D8*/\
MUX_VAL(CP(SDRC_D9), (IEN | PTD | DIS | M0))
/*SDRC_D9*/\
MUX_VAL(CP(SDRC_D10), (IEN | PTD | DIS | M0))
/*SDRC_D10*/\
MUX_VAL(CP(SDRC_D11), (IEN | PTD | DIS | M0))
/*SDRC_D11*/\
MUX_VAL(CP(SDRC_D12), (IEN | PTD | DIS | M0))
/*SDRC_D12*/\
MUX_VAL(CP(SDRC_D13), (IEN | PTD | DIS | M0))
/*SDRC_D13*/\
MUX_VAL(CP(SDRC_D14), (IEN | PTD | DIS | M0))
/*SDRC_D14*/\
MUX_VAL(CP(SDRC_D15), (IEN | PTD | DIS | M0))
/*SDRC_D15*/\
MUX_VAL(CP(SDRC_D16), (IEN | PTD | DIS | M0))
/*SDRC_D16*/\
MUX_VAL(CP(SDRC_D17), (IEN | PTD | DIS | M0))
/*SDRC_D17*/\
MUX_VAL(CP(SDRC_D18), (IEN | PTD | DIS | M0))
/*SDRC_D18*/\
MUX_VAL(CP(SDRC_D19), (IEN | PTD | DIS | M0))
/*SDRC_D19*/\
MUX_VAL(CP(SDRC_D20), (IEN | PTD | DIS | M0))
/*SDRC_D20*/\
MUX_VAL(CP(SDRC_D21), (IEN | PTD | DIS | M0))
/*SDRC_D21*/\
MUX_VAL(CP(SDRC_D22), (IEN | PTD | DIS | M0))
/*SDRC_D22*/\
MUX_VAL(CP(SDRC_D23), (IEN | PTD | DIS | M0))
/*SDRC_D23*/\
MUX_VAL(CP(SDRC_D24), (IEN | PTD | DIS | M0))
/*SDRC_D24*/\
MUX_VAL(CP(SDRC_D25), (IEN | PTD | DIS | M0))
/*SDRC_D25*/\
MUX_VAL(CP(SDRC_D26), (IEN | PTD | DIS | M0))
/*SDRC_D26*/\
MUX_VAL(CP(SDRC_D27), (IEN | PTD | DIS | M0))
/*SDRC_D27*/\
MUX_VAL(CP(SDRC_D28), (IEN | PTD | DIS | M0))
/*SDRC_D28*/\
MUX_VAL(CP(SDRC_D29), (IEN | PTD | DIS | M0))
/*SDRC_D29*/\
MUX_VAL(CP(SDRC_D30), (IEN | PTD | DIS | M0))
/*SDRC_D30*/\
MUX_VAL(CP(SDRC_D31), (IEN | PTD | DIS | M0))
/*SDRC_D31*/\
MUX_VAL(CP(SDRC_CLK), (IEN | PTD | DIS | M0))
/*SDRC_CLK*/\
MUX_VAL(CP(SDRC_DQS0), (IEN | PTD | DIS | M0))
/*SDRC_DQS0*/\
MUX_VAL(CP(SDRC_DQS1), (IEN | PTD | DIS | M0))
/*SDRC_DQS1*/\
MUX_VAL(CP(SDRC_DQS2), (IEN | PTD | DIS | M0))
/*SDRC_DQS2*/\
MUX_VAL(CP(SDRC_DQS3), (IEN | PTD | DIS | M0))
/*SDRC_DQS3*/\
- /*GPMC*/\
MUX_VAL(CP(GPMC_A1), (IDIS | PTU | EN | M0))
/*GPMC_A1*/\
MUX_VAL(CP(GPMC_A2), (IDIS | PTU | EN | M0))
/*GPMC_A2*/\
MUX_VAL(CP(GPMC_A3), (IDIS | PTU | EN | M0))
/*GPMC_A3*/\
MUX_VAL(CP(GPMC_A4), (IDIS | PTU | EN | M0))
/*GPMC_A4*/\
MUX_VAL(CP(GPMC_A5), (IDIS | PTU | EN | M0))
/*GPMC_A5*/\
MUX_VAL(CP(GPMC_A6), (IDIS | PTU | EN | M0))
/*GPMC_A6*/\
MUX_VAL(CP(GPMC_A7), (IDIS | PTU | EN | M0))
/*GPMC_A7*/\
MUX_VAL(CP(GPMC_A8), (IDIS | PTU | EN | M0))
/*GPMC_A8*/\
MUX_VAL(CP(GPMC_A9), (IDIS | PTU | EN | M0))
/*GPMC_A9*/\
MUX_VAL(CP(GPMC_A10), (IDIS | PTU | EN | M0))
/*GPMC_A10*/\
MUX_VAL(CP(GPMC_D0), (IEN | PTU | EN | M0))
/*GPMC_D0*/\
MUX_VAL(CP(GPMC_D1), (IEN | PTU | EN | M0))
/*GPMC_D1*/\
MUX_VAL(CP(GPMC_D2), (IEN | PTU | EN | M0))
/*GPMC_D2*/\
MUX_VAL(CP(GPMC_D3), (IEN | PTU | EN | M0))
/*GPMC_D3*/\
MUX_VAL(CP(GPMC_D4), (IEN | PTU | EN | M0))
/*GPMC_D4*/\
MUX_VAL(CP(GPMC_D5), (IEN | PTU | EN | M0))
/*GPMC_D5*/\
MUX_VAL(CP(GPMC_D6), (IEN | PTU | EN | M0))
/*GPMC_D6*/\
MUX_VAL(CP(GPMC_D7), (IEN | PTU | EN | M0))
/*GPMC_D7*/\
MUX_VAL(CP(GPMC_D8), (IEN | PTU | EN | M0))
/*GPMC_D8*/\
MUX_VAL(CP(GPMC_D9), (IEN | PTU | EN | M0))
/*GPMC_D9*/\
MUX_VAL(CP(GPMC_D10), (IEN | PTU | EN | M0))
/*GPMC_D10*/\
MUX_VAL(CP(GPMC_D11), (IEN | PTU | EN | M0))
/*GPMC_D11*/\
MUX_VAL(CP(GPMC_D12), (IEN | PTU | EN | M0))
/*GPMC_D12*/\
MUX_VAL(CP(GPMC_D13), (IEN | PTU | EN | M0))
/*GPMC_D13*/\
MUX_VAL(CP(GPMC_D14), (IEN | PTU | EN | M0))
/*GPMC_D14*/\
MUX_VAL(CP(GPMC_D15), (IEN | PTU | EN | M0))
/*GPMC_D15*/\
MUX_VAL(CP(GPMC_NCS0), (IDIS | PTU | EN | M0))
/*GPMC_nCS0*/\
MUX_VAL(CP(GPMC_NCS2), (IDIS | PTU | EN | M0))
/*GPMC_nCS2*/\
MUX_VAL(CP(GPMC_NCS3), (IEN | PTU | EN | M4))
/*GPIO_54*/\
MMC1_WP*/\
MUX_VAL(CP(GPMC_NCS7), (IEN | PTU | EN | M0))
/*GPMC_nCS7*/\
MUX_VAL(CP(GPMC_NBE1), (IEN | PTD | DIS | M0))
/*GPMC_nCS3*/\
MUX_VAL(CP(GPMC_CLK), (IEN | PTU | EN | M0))
/*GPMC_CLK*/\
MUX_VAL(CP(GPMC_NADV_ALE), (IDIS | PTD | DIS | M0))
/*GPMC_nADV_ALE*/\
MUX_VAL(CP(GPMC_NOE), (IDIS | PTD | DIS | M0))
/*GPMC_nOE*/\
MUX_VAL(CP(GPMC_NWE), (IDIS | PTD | DIS | M0))
/*GPMC_nWE*/\
MUX_VAL(CP(GPMC_NBE0_CLE), (IDIS | PTD | DIS | M0))
/*GPMC_nBE0_CLE*/\
MUX_VAL(CP(GPMC_NWP), (IEN | PTD | DIS | M0))
/*GPMC_nWP*/\
MUX_VAL(CP(GPMC_WAIT0), (IEN | PTU | EN | M0))
/*GPMC_WAIT0*/\
- /*CAMERA*/\
MUX_VAL(CP(CAM_HS), (IEN | PTU | DIS | M0)) /*CAM_HS
MUX_VAL(CP(CAM_VS), (IEN | PTU | DIS | M0)) /*CAM_VS
MUX_VAL(CP(CAM_XCLKA), (IDIS | PTD | DIS | M0))
/*CAM_XCLKA*/\
MUX_VAL(CP(CAM_PCLK), (IEN | PTU | DIS | M0))
/*CAM_PCLK*/\
MUX_VAL(CP(CAM_D0), (IEN | PTD | DIS | M0))
/*CAM_D0*/\
MUX_VAL(CP(CAM_D1), (IEN | PTD | DIS | M0))
/*CAM_D1*/\
MUX_VAL(CP(CAM_D2), (IEN | PTD | DIS | M0))
/*CAM_D2*/\
MUX_VAL(CP(CAM_D3), (IEN | PTD | DIS | M0))
/*CAM_D3*/\
MUX_VAL(CP(CAM_D4), (IEN | PTD | DIS | M0))
/*CAM_D4*/\
MUX_VAL(CP(CAM_D5), (IEN | PTD | DIS | M0))
/*CAM_D5*/\
MUX_VAL(CP(CAM_D6), (IEN | PTD | DIS | M0))
/*CAM_D6*/\
MUX_VAL(CP(CAM_D7), (IEN | PTD | DIS | M0))
/*CAM_D7*/\
MUX_VAL(CP(CAM_D8), (IEN | PTD | DIS | M0))
/*CAM_D8*/\
MUX_VAL(CP(CAM_D9), (IEN | PTD | DIS | M0))
/*CAM_D9*/\
MUX_VAL(CP(CAM_D10), (IEN | PTD | DIS | M0))
/*CAM_D10*/\
MUX_VAL(CP(CAM_D11), (IEN | PTD | DIS | M0))
/*CAM_D11*/\
MUX_VAL(CP(CSI2_DX0), (IEN | PTD | EN | M4))
/*GPIO_112*/\
MUX_VAL(CP(CSI2_DY0), (IEN | PTD | EN | M4))
/*GPIO_113*/\
MUX_VAL(CP(CSI2_DY1), (IEN | PTD | EN | M4))
/*GPIO_115*/\
- /*Audio Interface */\
MUX_VAL(CP(MCBSP2_FSX), (IEN | PTD | DIS | M0))
/*McBSP2_FSX*/\
MUX_VAL(CP(MCBSP2_CLKX), (IEN | PTD | DIS | M0))
/*McBSP2_CLKX*/\
MUX_VAL(CP(MCBSP2_DR), (IEN | PTD | DIS | M0))
/*McBSP2_DR*/\
MUX_VAL(CP(MCBSP2_DX), (IDIS | PTD | DIS | M0))
/*McBSP2_DX*/\
- /*Expansion card */\
MUX_VAL(CP(MMC1_CLK), (IEN | PTU | EN | M0))
/*MMC1_CLK*/\
MUX_VAL(CP(MMC1_CMD), (IEN | PTU | EN | M0))
/*MMC1_CMD*/\
MUX_VAL(CP(MMC1_DAT0), (IEN | PTU | EN | M0))
/*MMC1_DAT0*/\
MUX_VAL(CP(MMC1_DAT1), (IEN | PTU | EN | M0))
/*MMC1_DAT1*/\
MUX_VAL(CP(MMC1_DAT2), (IEN | PTU | EN | M0))
/*MMC1_DAT2*/\
MUX_VAL(CP(MMC1_DAT3), (IEN | PTU | EN | M0))
/*MMC1_DAT3*/\
MUX_VAL(CP(MMC1_DAT4), (IEN | PTU | EN | M0))
/*MMC1_DAT4*/\
MUX_VAL(CP(MMC1_DAT5), (IEN | PTU | EN | M0))
/*MMC1_DAT5*/\
MUX_VAL(CP(MMC1_DAT6), (IEN | PTU | EN | M0))
/*MMC1_DAT6*/\
MUX_VAL(CP(MMC1_DAT7), (IEN | PTU | EN | M0))
/*MMC1_DAT7*/\
- /*Wireless LAN */\
MUX_VAL(CP(MMC2_CLK), (IEN | PTU | EN | M4))
/*GPIO_130*/\
MUX_VAL(CP(MMC2_CMD), (IEN | PTU | EN | M0))
/*MMC2_CMD*/\
MUX_VAL(CP(MMC2_DAT0), (IEN | PTU | EN | M0))
/*MMC2_DAT0*/\
MUX_VAL(CP(MMC2_DAT1), (IEN | PTU | EN | M0))
/*MMC2_DAT1*/\
MUX_VAL(CP(MMC2_DAT2), (IEN | PTU | EN | M0))
/*MMC2_DAT2*/\
MUX_VAL(CP(MMC2_DAT3), (IEN | PTU | EN | M0))
/*MMC2_DAT3*/\
MUX_VAL(CP(MMC2_DAT4), (IEN | PTU | EN | M1))
/*MMC2_DIR_DAT0*/\
MUX_VAL(CP(MMC2_DAT5), (IEN | PTU | EN | M1))
/*MMC2_DIR_DAT1*/\
MUX_VAL(CP(MMC2_DAT6), (IEN | PTU | EN | M1))
/*MMC2_DIR_CMD*/\
MUX_VAL(CP(MMC2_DAT7), (IEN | PTU | EN | M4))
/*GPIO_139*/\
- /*Bluetooth*/\
MUX_VAL(CP(MCBSP3_DX), (IEN | PTD | DIS | M1))
/*UART2_CTS*/\
MUX_VAL(CP(MCBSP3_DR), (IDIS | PTD | DIS | M1))
/*UART2_RTS*/\
MUX_VAL(CP(MCBSP3_CLKX), (IDIS | PTD | DIS | M1))
/*UART2_TX*/\
MUX_VAL(CP(MCBSP3_FSX), (IEN | PTD | DIS | M1))
/*UART2_RX*/\
MUX_VAL(CP(UART1_RTS), (IEN | PTU | DIS | M4))
/*GPIO_149*/ \
MUX_VAL(CP(MCBSP4_CLKX), (IEN | PTD | DIS | M0))
/*McBSP4_CLKX*/\
MUX_VAL(CP(MCBSP4_DR), (IEN | PTD | DIS | M0))
/*McBSP4_DR*/\
MUX_VAL(CP(MCBSP4_DX), (IEN | PTD | DIS | M0))
/*McBSP4_DX*/\
MUX_VAL(CP(MCBSP4_FSX), (IEN | PTD | DIS | M0))
/*McBSP4_FSX*/\
MUX_VAL(CP(MCBSP1_CLKR), (IEN | PTD | DIS | M0))
/*McBSP1_CLKR*/\
MUX_VAL(CP(MCBSP1_FSR), (IEN | PTD | DIS | M0))
/*McBSP1_FSR*/\
MUX_VAL(CP(MCBSP1_DX), (IEN | PTD | DIS | M0))
/*McBSP1_DX*/\
MUX_VAL(CP(MCBSP1_DR), (IEN | PTD | DIS | M0))
/*McBSP1_DR*/\
MUX_VAL(CP(MCBSP_CLKS), (IEN | PTU | DIS | M0))
/*McBSP_CLKS*/\
MUX_VAL(CP(MCBSP1_FSX), (IEN | PTD | DIS | M0))
/*McBSP1_FSX*/\
MUX_VAL(CP(MCBSP1_CLKX), (IEN | PTD | DIS | M0))
/*McBSP1_CLKX*/\
- /*Serial Interface*/\
MUX_VAL(CP(UART3_RTS_SD), (IEN | PTU | EN | M4))
/*GPIO_164 W2W_*/\
BT_NRESET*/\
MUX_VAL(CP(UART3_RX_IRRX), (IEN | PTU | EN | M0))
/*UART3_RX_IRRX*/\
MUX_VAL(CP(UART3_TX_IRTX), (IDIS | PTD | DIS | M0))
/*UART3_TX_IRTX*/\
MUX_VAL(CP(HSUSB0_CLK), (IEN | PTD | DIS | M0))
/*HSUSB0_CLK*/\
MUX_VAL(CP(HSUSB0_STP), (IDIS | PTU | EN | M0))
/*HSUSB0_STP*/\
MUX_VAL(CP(HSUSB0_DIR), (IEN | PTD | DIS | M0))
/*HSUSB0_DIR*/\
MUX_VAL(CP(HSUSB0_NXT), (IEN | PTD | DIS | M0))
/*HSUSB0_NXT*/\
MUX_VAL(CP(HSUSB0_DATA0), (IEN | PTD | DIS | M0))
/*HSUSB0_DATA0*/\
MUX_VAL(CP(HSUSB0_DATA1), (IEN | PTD | DIS | M0))
/*HSUSB0_DATA1*/\
MUX_VAL(CP(HSUSB0_DATA2), (IEN | PTD | DIS | M0))
/*HSUSB0_DATA2*/\
MUX_VAL(CP(HSUSB0_DATA3), (IEN | PTD | DIS | M0))
/*HSUSB0_DATA3*/\
MUX_VAL(CP(HSUSB0_DATA4), (IEN | PTD | DIS | M0))
/*HSUSB0_DATA4*/\
MUX_VAL(CP(HSUSB0_DATA5), (IEN | PTD | DIS | M0))
/*HSUSB0_DATA5*/\
MUX_VAL(CP(HSUSB0_DATA6), (IEN | PTD | DIS | M0))
/*HSUSB0_DATA6*/\
MUX_VAL(CP(HSUSB0_DATA7), (IEN | PTD | DIS | M0))
/*HSUSB0_DATA7*/\
MUX_VAL(CP(I2C1_SCL), (IEN | PTU | EN | M0))
/*I2C1_SCL*/\
MUX_VAL(CP(I2C1_SDA), (IEN | PTU | EN | M0))
/*I2C1_SDA*/\
MUX_VAL(CP(I2C2_SCL), (IEN | PTU | EN | M4))
/*GPIO_168*/\
USBH_CPEN*/\
MUX_VAL(CP(I2C2_SDA), (IEN | PTU | EN | M4))
/*GPIO_183*/\
USBH_RESET*/\
MUX_VAL(CP(I2C3_SCL), (IEN | PTU | EN | M0))
/*I2C3_SCL*/\
MUX_VAL(CP(I2C3_SDA), (IEN | PTU | EN | M0))
/*I2C3_SDA*/\
MUX_VAL(CP(I2C4_SCL), (IEN | PTU | EN | M0))
/*I2C4_SCL*/\
MUX_VAL(CP(I2C4_SDA), (IEN | PTU | EN | M0))
/*I2C4_SDA*/\
MUX_VAL(CP(MCSPI1_CS3), (IEN | PTD | DIS | M3))
/*HSUSB2_DATA2*/\
MUX_VAL(CP(MCSPI2_CLK), (IEN | PTD | DIS | M3))
/*HSUSB2_DATA7*/\
MUX_VAL(CP(MCSPI2_SIMO), (IEN | PTD | DIS | M3))
/*HSUSB2_DATA4*/\
MUX_VAL(CP(MCSPI2_SOMI), (IEN | PTD | DIS | M3))
/*HSUSB2_DATA5*/\
MUX_VAL(CP(MCSPI2_CS0), (IEN | PTD | DIS | M3))
/*HSUSB2_DATA6*/\
MUX_VAL(CP(MCSPI2_CS1), (IEN | PTD | DIS | M3))
/*HSUSB2_DATA3*/\
- /*Control and debug */\
MUX_VAL(CP(SYS_32K), (IEN | PTD | DIS | M0))
/*SYS_32K*/\
MUX_VAL(CP(SYS_CLKREQ), (IEN | PTD | DIS | M0))
/*SYS_CLKREQ*/\
MUX_VAL(CP(SYS_NIRQ), (IEN | PTU | EN | M0))
/*SYS_nIRQ*/\
MUX_VAL(CP(SYS_BOOT0), (IEN | PTD | DIS | M4))
/*GPIO_2*/\
MUX_VAL(CP(SYS_BOOT1), (IEN | PTD | DIS | M4)) /*GPIO_3
MUX_VAL(CP(SYS_BOOT2), (IEN | PTD | DIS | M4))
/*GPIO_4 - MMC1_WP*/\
MUX_VAL(CP(SYS_BOOT3), (IEN | PTD | DIS | M4))
/*GPIO_5*/\
MUX_VAL(CP(SYS_BOOT4), (IEN | PTD | DIS | M4))
/*GPIO_6*/\
MUX_VAL(CP(SYS_BOOT5), (IEN | PTD | DIS | M4))
/*GPIO_7*/\
MUX_VAL(CP(SYS_BOOT6), (IDIS | PTD | DIS | M4))
/*GPIO_8*/\
MUX_VAL(CP(SYS_OFF_MODE), (IEN | PTD | DIS | M0))
/*SYS_OFF_MODE*/\
MUX_VAL(CP(ETK_D1_ES2), (IEN | PTD | EN | M4))
/*GPIO_15 - X_GATE*/\
MUX_VAL(CP(ETK_D2_ES2), (IEN | PTU | EN | M4))
/*GPIO_16*/\
W2W_NRESET*/\
MUX_VAL(CP(ETK_D10_ES2), (IDIS | PTD | DIS | M3))
/*HSUSB2_CLK*/\
MUX_VAL(CP(ETK_D11_ES2), (IDIS | PTD | DIS | M3))
/*HSUSB2_STP*/\
MUX_VAL(CP(ETK_D12_ES2), (IEN | PTD | DIS | M3))
/*HSUSB2_DIR*/\
MUX_VAL(CP(ETK_D13_ES2), (IEN | PTD | DIS | M3))
/*HSUSB2_NXT*/\
MUX_VAL(CP(ETK_D14_ES2), (IEN | PTD | DIS | M3))
/*HSUSB2_DATA0*/\
MUX_VAL(CP(ETK_D15_ES2), (IEN | PTD | DIS | M3))
/*HSUSB2_DATA1*/\
- /* die to die */\
MUX_VAL(CP(D2D_MCAD1), (IEN | PTD | EN | M0))
/*d2d_mcad1*/\
MUX_VAL(CP(D2D_MCAD2), (IEN | PTD | EN | M0))
/*d2d_mcad2*/\
MUX_VAL(CP(D2D_MCAD3), (IEN | PTD | EN | M0))
/*d2d_mcad3*/\
MUX_VAL(CP(D2D_MCAD4), (IEN | PTD | EN | M0))
/*d2d_mcad4*/\
MUX_VAL(CP(D2D_MCAD5), (IEN | PTD | EN | M0))
/*d2d_mcad5*/\
MUX_VAL(CP(D2D_MCAD6), (IEN | PTD | EN | M0))
/*d2d_mcad6*/\
MUX_VAL(CP(D2D_MCAD7), (IEN | PTD | EN | M0))
/*d2d_mcad7*/\
MUX_VAL(CP(D2D_MCAD8), (IEN | PTD | EN | M0))
/*d2d_mcad8*/\
MUX_VAL(CP(D2D_MCAD9), (IEN | PTD | EN | M0))
/*d2d_mcad9*/\
MUX_VAL(CP(D2D_MCAD10), (IEN | PTD | EN | M0))
/*d2d_mcad10*/\
MUX_VAL(CP(D2D_MCAD11), (IEN | PTD | EN | M0))
/*d2d_mcad11*/\
MUX_VAL(CP(D2D_MCAD12), (IEN | PTD | EN | M0))
/*d2d_mcad12*/\
MUX_VAL(CP(D2D_MCAD13), (IEN | PTD | EN | M0))
/*d2d_mcad13*/\
MUX_VAL(CP(D2D_MCAD14), (IEN | PTD | EN | M0))
/*d2d_mcad14*/\
MUX_VAL(CP(D2D_MCAD15), (IEN | PTD | EN | M0))
/*d2d_mcad15*/\
MUX_VAL(CP(D2D_MCAD16), (IEN | PTD | EN | M0))
/*d2d_mcad16*/\
MUX_VAL(CP(D2D_MCAD17), (IEN | PTD | EN | M0))
/*d2d_mcad17*/\
MUX_VAL(CP(D2D_MCAD18), (IEN | PTD | EN | M0))
/*d2d_mcad18*/\
MUX_VAL(CP(D2D_MCAD19), (IEN | PTD | EN | M0))
/*d2d_mcad19*/\
MUX_VAL(CP(D2D_MCAD20), (IEN | PTD | EN | M0))
/*d2d_mcad20*/\
MUX_VAL(CP(D2D_MCAD21), (IEN | PTD | EN | M0))
/*d2d_mcad21*/\
MUX_VAL(CP(D2D_MCAD22), (IEN | PTD | EN | M0))
/*d2d_mcad22*/\
MUX_VAL(CP(D2D_MCAD23), (IEN | PTD | EN | M0))
/*d2d_mcad23*/\
MUX_VAL(CP(D2D_MCAD24), (IEN | PTD | EN | M0))
/*d2d_mcad24*/\
MUX_VAL(CP(D2D_MCAD25), (IEN | PTD | EN | M0))
/*d2d_mcad25*/\
MUX_VAL(CP(D2D_MCAD26), (IEN | PTD | EN | M0))
/*d2d_mcad26*/\
MUX_VAL(CP(D2D_MCAD27), (IEN | PTD | EN | M0))
/*d2d_mcad27*/\
MUX_VAL(CP(D2D_MCAD28), (IEN | PTD | EN | M0))
/*d2d_mcad28*/\
MUX_VAL(CP(D2D_MCAD29), (IEN | PTD | EN | M0))
/*d2d_mcad29*/\
MUX_VAL(CP(D2D_MCAD30), (IEN | PTD | EN | M0))
/*d2d_mcad30*/\
MUX_VAL(CP(D2D_MCAD31), (IEN | PTD | EN | M0))
/*d2d_mcad31*/\
MUX_VAL(CP(D2D_MCAD32), (IEN | PTD | EN | M0))
/*d2d_mcad32*/\
MUX_VAL(CP(D2D_MCAD33), (IEN | PTD | EN | M0))
/*d2d_mcad33*/\
MUX_VAL(CP(D2D_MCAD34), (IEN | PTD | EN | M0))
/*d2d_mcad34*/\
MUX_VAL(CP(D2D_MCAD35), (IEN | PTD | EN | M0))
/*d2d_mcad35*/\
MUX_VAL(CP(D2D_MCAD36), (IEN | PTD | EN | M0))
/*d2d_mcad36*/\
MUX_VAL(CP(D2D_CLK26MI), (IEN | PTD | DIS | M0))
/*d2d_clk26mi*/\
MUX_VAL(CP(D2D_NRESPWRON), (IEN | PTD | EN | M0))
/*d2d_nrespwron*/\
MUX_VAL(CP(D2D_NRESWARM), (IEN | PTU | EN | M0))
/*d2d_nreswarm */\
MUX_VAL(CP(D2D_ARM9NIRQ), (IEN | PTD | DIS | M0))
/*d2d_arm9nirq */\
MUX_VAL(CP(D2D_UMA2P6FIQ), (IEN | PTD | DIS | M0))
/*d2d_uma2p6fiq*/\
MUX_VAL(CP(D2D_SPINT), (IEN | PTD | EN | M0))
/*d2d_spint*/\
MUX_VAL(CP(D2D_FRINT), (IEN | PTD | EN | M0))
/*d2d_frint*/\
MUX_VAL(CP(D2D_DMAREQ0), (IEN | PTD | DIS | M0))
/*d2d_dmareq0*/\
MUX_VAL(CP(D2D_DMAREQ1), (IEN | PTD | DIS | M0))
/*d2d_dmareq1*/\
MUX_VAL(CP(D2D_DMAREQ2), (IEN | PTD | DIS | M0))
/*d2d_dmareq2*/\
MUX_VAL(CP(D2D_DMAREQ3), (IEN | PTD | DIS | M0))
/*d2d_dmareq3*/\
MUX_VAL(CP(D2D_N3GTRST), (IEN | PTD | DIS | M0))
/*d2d_n3gtrst*/\
MUX_VAL(CP(D2D_N3GTDI), (IEN | PTD | DIS | M0))
/*d2d_n3gtdi*/\
MUX_VAL(CP(D2D_N3GTDO), (IEN | PTD | DIS | M0))
/*d2d_n3gtdo*/\
MUX_VAL(CP(D2D_N3GTMS), (IEN | PTD | DIS | M0))
/*d2d_n3gtms*/\
MUX_VAL(CP(D2D_N3GTCK), (IEN | PTD | DIS | M0))
/*d2d_n3gtck*/\
MUX_VAL(CP(D2D_N3GRTCK), (IEN | PTD | DIS | M0))
/*d2d_n3grtck*/\
MUX_VAL(CP(D2D_MSTDBY), (IEN | PTU | EN | M0))
/*d2d_mstdby*/\
MUX_VAL(CP(D2D_SWAKEUP), (IEN | PTD | EN | M0))
/*d2d_swakeup*/\
MUX_VAL(CP(D2D_IDLEREQ), (IEN | PTD | DIS | M0))
/*d2d_idlereq*/\
MUX_VAL(CP(D2D_IDLEACK), (IEN | PTU | EN | M0))
/*d2d_idleack*/\
MUX_VAL(CP(D2D_MWRITE), (IEN | PTD | DIS | M0))
/*d2d_mwrite*/\
MUX_VAL(CP(D2D_SWRITE), (IEN | PTD | DIS | M0))
/*d2d_swrite*/\
MUX_VAL(CP(D2D_MREAD), (IEN | PTD | DIS | M0))
/*d2d_mread*/\
MUX_VAL(CP(D2D_SREAD), (IEN | PTD | DIS | M0))
/*d2d_sread*/\
MUX_VAL(CP(D2D_MBUSFLAG), (IEN | PTD | DIS | M0))
/*d2d_mbusflag*/\
MUX_VAL(CP(D2D_SBUSFLAG), (IEN | PTD | DIS | M0))
/*d2d_sbusflag*/\
MUX_VAL(CP(SDRC_CKE0), (IDIS | PTU | EN | M0))
/*sdrc_cke0*/\
MUX_VAL(CP(SDRC_CKE1), (IDIS | PTU | EN | M0))
/*sdrc_cke1*/
- Routine: get_board_revision
- Description: Returns the board revision
-int get_board_revision(void) -{
int revision;
if (!gpio_request(112, "") &&
!gpio_request(113, "") &&
!gpio_request(115, "")) {
gpio_direction_input(112);
gpio_direction_input(113);
gpio_direction_input(115);
revision = gpio_get_value(115) << 2 |
gpio_get_value(113) << 1 |
gpio_get_value(112);
} else {
puts("Error: unable to acquire board revision GPIOs\n");
revision = -1;
return revision;
- Routine: set_muxconf_regs
- Description: Setting up the configuration Mux registers specific to
the
hardware. Many pins need to be moved from protect to
primary
mode.
-void set_muxconf_regs(void) -{
MUX_OVERO();
-} diff --git a/board/overo/overo.c b/board/overo/overo.c deleted file mode 100644 index 8fa41f81550..00000000000 --- a/board/overo/overo.c +++ /dev/null @@ -1,420 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/*
-#include <common.h> -#include <dm.h> -#include <ns16550.h> -#include <netdev.h> -#include <twl4030.h> -#include <linux/mtd/rawnand.h> -#include <asm/io.h> -#include <asm/arch/mmc_host_def.h> -#include <asm/arch/mux.h> -#include <asm/arch/mem.h> -#include <asm/arch/sys_proto.h> -#include <asm/gpio.h> -#include <asm/mach-types.h> -#include "overo.h"
-#ifdef CONFIG_USB_EHCI_HCD -#include <usb.h> -#include <asm/ehci-omap.h> -#endif
-#define TWL4030_I2C_BUS 0 -#define EXPANSION_EEPROM_I2C_BUS 2 -#define EXPANSION_EEPROM_I2C_ADDRESS 0x51
-#define GUMSTIX_EMPTY_EEPROM 0x0
-#define GUMSTIX_SUMMIT 0x01000200 -#define GUMSTIX_TOBI 0x02000200 -#define GUMSTIX_TOBI_DUO 0x03000200 -#define GUMSTIX_PALO35 0x04000200 -#define GUMSTIX_PALO43 0x05000200 -#define GUMSTIX_CHESTNUT43 0x06000200 -#define GUMSTIX_PINTO 0x07000200 -#define GUMSTIX_GALLOP43 0x08000200 -#define GUMSTIX_ALTO35 0x09000200 -#define GUMSTIX_STAGECOACH 0x0A000200 -#define GUMSTIX_THUMBO 0x0B000200 -#define GUMSTIX_TURTLECORE 0x0C000200 -#define GUMSTIX_ARBOR43C 0x0D000200
-#define ETTUS_USRP_E 0x01000300
-#define GUMSTIX_NO_EEPROM 0xffffffff
-static struct {
unsigned int device_vendor;
unsigned char revision;
unsigned char content;
char fab_revision[8];
char env_var[16];
char env_setting[64];
-} expansion_config = {0x0};
-static const struct ns16550_platdata overo_serial = {
.base = OMAP34XX_UART3,
.reg_shift = 2,
.clock = V_NS16550_CLK,
.fcr = UART_FCR_DEFVAL,
-U_BOOT_DEVICE(overo_uart) = {
"ns16550_serial",
&overo_serial
- Routine: get_sdio2_config
- Description: Return information about the wifi module connection
Returns 0 if the module connects though a level
translator
Returns 1 if the module connects directly
-int get_sdio2_config(void) -{
int sdio_direct;
if (!gpio_request(130, "") && !gpio_request(139, "")) {
gpio_direction_output(130, 0);
gpio_direction_input(139);
sdio_direct = 1;
gpio_set_value(130, 0);
if (gpio_get_value(139) == 0) {
gpio_set_value(130, 1);
if (gpio_get_value(139) == 1)
sdio_direct = 0;
gpio_direction_input(130);
} else {
puts("Error: unable to acquire sdio2 clk GPIOs\n");
sdio_direct = -1;
return sdio_direct;
- Routine: get_expansion_id
- Description: This function checks for expansion board by checking I2C
bus 2 for the availability of an AT24C01B serial EEPROM.
returns the device_vendor field from the EEPROM
-unsigned int get_expansion_id(void) -{
if (expansion_config.device_vendor != 0x0)
return expansion_config.device_vendor;
i2c_set_bus_num(EXPANSION_EEPROM_I2C_BUS);
/* return GUMSTIX_NO_EEPROM if eeprom doesn't respond */
if (i2c_probe(EXPANSION_EEPROM_I2C_ADDRESS) == 1) {
i2c_set_bus_num(TWL4030_I2C_BUS);
return GUMSTIX_NO_EEPROM;
/* read configuration data */
i2c_read(EXPANSION_EEPROM_I2C_ADDRESS, 0, 1, (u8
*)&expansion_config,
sizeof(expansion_config));
- Routine: misc_init_r
- Description: Configure board specific parts
-int misc_init_r(void) -{
unsigned int expansion_id;
twl4030_power_init();
twl4030_led_init(TWL4030_LED_LEDEN_LEDAON |
TWL4030_LED_LEDEN_LEDBON);
printf("Board revision: %d\n", get_board_revision());
switch (get_sdio2_config()) {
case 0:
puts("Tranceiver detected on mmc2\n");
MUX_OVERO_SDIO2_TRANSCEIVER();
break;
case 1:
puts("Direct connection on mmc2\n");
MUX_OVERO_SDIO2_DIRECT();
break;
default:
puts("Unable to detect mmc2 connection type\n");
expansion_id = get_expansion_id();
switch (expansion_id) {
case GUMSTIX_SUMMIT:
printf("Recognized Summit expansion board (rev %d %s)\n",
expansion_config.revision,
expansion_config.fab_revision);
MUX_GUMSTIX();
env_set("defaultdisplay", "dvi");
env_set("expansionname", "summit");
break;
case GUMSTIX_TOBI:
printf("Recognized Tobi expansion board (rev %d %s)\n",
MUX_GUMSTIX();
env_set("expansionname", "tobi");
break;
case GUMSTIX_TOBI_DUO:
printf("Recognized Tobi Duo expansion board (rev %d
%s)\n",
MUX_GUMSTIX();
env_set("expansionname", "tobiduo");
break;
case GUMSTIX_PALO35:
printf("Recognized Palo35 expansion board (rev %d %s)\n",
MUX_GUMSTIX();
env_set("defaultdisplay", "lcd35");
env_set("expansionname", "palo35");
break;
case GUMSTIX_PALO43:
printf("Recognized Palo43 expansion board (rev %d %s)\n",
MUX_GUMSTIX();
env_set("defaultdisplay", "lcd43");
env_set("expansionname", "palo43");
break;
case GUMSTIX_CHESTNUT43:
printf("Recognized Chestnut43 expansion board (rev %d
%s)\n",
MUX_GUMSTIX();
env_set("expansionname", "chestnut43");
break;
case GUMSTIX_PINTO:
printf("Recognized Pinto expansion board (rev %d %s)\n",
MUX_GUMSTIX();
break;
case GUMSTIX_GALLOP43:
printf("Recognized Gallop43 expansion board (rev %d
%s)\n",
MUX_GUMSTIX();
env_set("expansionname", "gallop43");
break;
case GUMSTIX_ALTO35:
printf("Recognized Alto35 expansion board (rev %d %s)\n",
MUX_GUMSTIX();
MUX_ALTO35();
env_set("expansionname", "alto35");
break;
case GUMSTIX_STAGECOACH:
printf("Recognized Stagecoach expansion board (rev %d
%s)\n",
MUX_GUMSTIX();
break;
case GUMSTIX_THUMBO:
printf("Recognized Thumbo expansion board (rev %d %s)\n",
MUX_GUMSTIX();
break;
case GUMSTIX_TURTLECORE:
printf("Recognized Turtlecore expansion board (rev %d
%s)\n",
MUX_GUMSTIX();
break;
case GUMSTIX_ARBOR43C:
printf("Recognized Arbor43C expansion board (rev %d
%s)\n",
MUX_GUMSTIX();
MUX_ARBOR43C();
env_set("expansionname", "arbor43c");
break;
case ETTUS_USRP_E:
printf("Recognized Ettus Research USRP-E (rev %d %s)\n",
MUX_GUMSTIX();
MUX_USRP_E();
break;
case GUMSTIX_NO_EEPROM:
case GUMSTIX_EMPTY_EEPROM:
puts("No or empty EEPROM on expansion board\n");
MUX_GUMSTIX();
break;
default:
printf("Unrecognized expansion board 0x%08x\n",
expansion_id);
break;
if (expansion_config.content == 1)
env_set(expansion_config.env_var,
expansion_config.env_setting);
omap_die_id_display();
if (get_cpu_family() == CPU_OMAP34XX)
env_set("boardname", "overo");
else
env_set("boardname", "overo-storm");
-#if defined(CONFIG_CMD_NET) -/* GPMC definitions for LAN9221 chips on Tobi expansion boards */ -static const u32 gpmc_lan_config[] = {
NET_LAN9221_GPMC_CONFIG1,
NET_LAN9221_GPMC_CONFIG2,
NET_LAN9221_GPMC_CONFIG3,
NET_LAN9221_GPMC_CONFIG4,
NET_LAN9221_GPMC_CONFIG5,
NET_LAN9221_GPMC_CONFIG6,
/*CONFIG7- computed as params */
- Routine: setup_net_chip
- Description: Setting up the configuration GPMC registers specific to
the
Ethernet hardware.
-static void setup_net_chip(void) -{
struct ctrl *ctrl_base = (struct ctrl *)OMAP34XX_CTRL_BASE;
/* Enable off mode for NWE in PADCONF_GPMC_NWE register */
writew(readw(&ctrl_base ->gpmc_nwe) | 0x0E00,
&ctrl_base->gpmc_nwe);
/* Enable off mode for NOE in PADCONF_GPMC_NADV_ALE register */
writew(readw(&ctrl_base->gpmc_noe) | 0x0E00,
&ctrl_base->gpmc_noe);
/* Enable off mode for ALE in PADCONF_GPMC_NADV_ALE register */
writew(readw(&ctrl_base->gpmc_nadv_ale) | 0x0E00,
&ctrl_base->gpmc_nadv_ale);
- Routine: reset_net_chip
- Description: Reset the Ethernet hardware.
-static void reset_net_chip(void) -{
/* Make GPIO 64 as output pin and send a magic pulse through it */
if (!gpio_request(64, "")) {
gpio_direction_output(64, 0);
gpio_set_value(64, 1);
udelay(1);
gpio_set_value(64, 0);
udelay(1);
-int board_eth_init(bd_t *bis) -{
int rc = 0;
-#ifdef CONFIG_SMC911X
/* second lan chip */
enable_gpmc_cs_config(gpmc_lan_config, &gpmc_cfg->cs[4],
0x2B000000, GPMC_SIZE_16M);
/* no break */
case GUMSTIX_TOBI:
/* first lan chip */
enable_gpmc_cs_config(gpmc_lan_config, &gpmc_cfg->cs[5],
0x2C000000, GPMC_SIZE_16M);
setup_net_chip();
reset_net_chip();
rc = smc911x_initialize(0, CONFIG_SMC911X_BASE);
break;
default:
break;
-#endif
return rc;
-} -#endif
-#if defined(CONFIG_MMC) -int board_mmc_init(bd_t *bis) -{
return omap_mmc_init(0, 0, 0, -1, -1);
-} -#endif
-#if defined(CONFIG_MMC) -void board_mmc_power_init(void) -{
twl4030_power_mmc_init(0);
-} -#endif
-#if defined(CONFIG_USB_EHCI_HCD) -static struct omap_usbhs_board_data usbhs_bdata = {
.port_mode[0] = OMAP_USBHS_PORT_MODE_UNUSED,
.port_mode[1] = OMAP_EHCI_PORT_MODE_PHY,
.port_mode[2] = OMAP_USBHS_PORT_MODE_UNUSED
-#define GUMSTIX_GPIO_USBH_CPEN 168 -int ehci_hcd_init(int index, enum usb_init_type init,
struct ehci_hccr **hccr, struct ehci_hcor **hcor)
/* Enable USB power */
if (!gpio_request(GUMSTIX_GPIO_USBH_CPEN, "usbh_cpen"))
gpio_direction_output(GUMSTIX_GPIO_USBH_CPEN, 1);
return omap_ehci_hcd_init(index, &usbhs_bdata, hccr, hcor);
-int ehci_hcd_stop(void) -{
/* Disable USB power */
gpio_set_value(GUMSTIX_GPIO_USBH_CPEN, 0);
gpio_free(GUMSTIX_GPIO_USBH_CPEN);
return omap_ehci_hcd_stop();
-#endif /* CONFIG_USB_EHCI_HCD */ diff --git a/board/overo/overo.h b/board/overo/overo.h deleted file mode 100644 index 513a3e3d632..00000000000 --- a/board/overo/overo.h +++ /dev/null @@ -1,169 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/*
- (C) Copyright 2008
- Steve Sakoman steve@sakoman.com
-#ifndef _OVERO_H_ -#define _OVERO_H_
-const omap3_sysinfo sysinfo = {
DDR_STACKED,
"Gumstix Overo board",
-#if defined(CONFIG_ENV_IS_IN_ONENAND)
"OneNAND",
-#else
"NAND",
-#endif -};
-int get_board_revision(void);
-/* overo revisions */ -#define REVISION_0 0x0 -#define REVISION_1 0x1 -#define REVISION_2 0x2 -#define REVISION_3 0x3 -#define REVISION_4 0x4
- IEN - Input Enable
- IDIS - Input Disable
- PTD - Pull type Down
- PTU - Pull type Up
- DIS - Pull type selection is inactive
- EN - Pull type selection is active
- M0 - Mode 0
- The commented string gives the final mux configuration for that pin
-#define MUX_GUMSTIX() \
- /*GPMC*/\
MUX_VAL(CP(GPMC_NCS1), (IDIS | PTU | EN | M0))
/*GPMC_nCS1*/\
MUX_VAL(CP(GPMC_NCS4), (IDIS | PTU | EN | M0))
/*GPMC_nCS4*/\
MUX_VAL(CP(GPMC_NCS5), (IDIS | PTU | EN | M0))
/*GPMC_nCS5*/\
MUX_VAL(CP(GPMC_NCS6), (IEN | PTD | DIS | M0))
/*GPMC_nCS6*/\
MUX_VAL(CP(GPMC_WAIT1), (IEN | PTU | EN | M4))
/*GPIO_63*/\
CAM_IRQ*/\
MUX_VAL(CP(GPMC_WAIT2), (IEN | PTU | EN | M4))
/*GPIO_64*/\
SMSC911X_NRES*/\
MUX_VAL(CP(GPMC_WAIT3), (IEN | PTU | DIS | M4))
/*GPIO_65*/\
- /*DSS*/\
MUX_VAL(CP(DSS_PCLK), (IDIS | PTD | DIS | M0))
/*DSS_PCLK*/\
MUX_VAL(CP(DSS_HSYNC), (IDIS | PTD | DIS | M0))
/*DSS_HSYNC*/\
MUX_VAL(CP(DSS_VSYNC), (IDIS | PTD | DIS | M0))
/*DSS_VSYNC*/\
MUX_VAL(CP(DSS_ACBIAS), (IDIS | PTD | DIS | M0))
/*DSS_ACBIAS*/\
MUX_VAL(CP(DSS_DATA0), (IDIS | PTD | DIS | M0))
/*DSS_DATA0*/\
MUX_VAL(CP(DSS_DATA1), (IDIS | PTD | DIS | M0))
/*DSS_DATA1*/\
MUX_VAL(CP(DSS_DATA2), (IDIS | PTD | DIS | M0))
/*DSS_DATA2*/\
MUX_VAL(CP(DSS_DATA3), (IDIS | PTD | DIS | M0))
/*DSS_DATA3*/\
MUX_VAL(CP(DSS_DATA4), (IDIS | PTD | DIS | M0))
/*DSS_DATA4*/\
MUX_VAL(CP(DSS_DATA5), (IDIS | PTD | DIS | M0))
/*DSS_DATA5*/\
MUX_VAL(CP(DSS_DATA6), (IDIS | PTD | DIS | M0))
/*DSS_DATA6*/\
MUX_VAL(CP(DSS_DATA7), (IDIS | PTD | DIS | M0))
/*DSS_DATA7*/\
MUX_VAL(CP(DSS_DATA8), (IDIS | PTD | DIS | M0))
/*DSS_DATA8*/\
MUX_VAL(CP(DSS_DATA9), (IDIS | PTD | DIS | M0))
/*DSS_DATA9*/\
MUX_VAL(CP(DSS_DATA10), (IDIS | PTD | DIS | M0))
/*DSS_DATA10*/\
MUX_VAL(CP(DSS_DATA11), (IDIS | PTD | DIS | M0))
/*DSS_DATA11*/\
MUX_VAL(CP(DSS_DATA12), (IDIS | PTD | DIS | M0))
/*DSS_DATA12*/\
MUX_VAL(CP(DSS_DATA13), (IDIS | PTD | DIS | M0))
/*DSS_DATA13*/\
MUX_VAL(CP(DSS_DATA14), (IDIS | PTD | DIS | M0))
/*DSS_DATA14*/\
MUX_VAL(CP(DSS_DATA15), (IDIS | PTD | DIS | M0))
/*DSS_DATA15*/\
MUX_VAL(CP(DSS_DATA16), (IDIS | PTD | DIS | M0))
/*DSS_DATA16*/\
MUX_VAL(CP(DSS_DATA17), (IDIS | PTD | DIS | M0))
/*DSS_DATA17*/\
MUX_VAL(CP(DSS_DATA18), (IDIS | PTD | DIS | M0))
/*DSS_DATA18*/\
MUX_VAL(CP(DSS_DATA19), (IDIS | PTD | DIS | M0))
/*DSS_DATA19*/\
MUX_VAL(CP(DSS_DATA20), (IDIS | PTD | DIS | M0))
/*DSS_DATA20*/\
MUX_VAL(CP(DSS_DATA21), (IDIS | PTD | DIS | M0))
/*DSS_DATA21*/\
MUX_VAL(CP(DSS_DATA22), (IDIS | PTD | DIS | M0))
/*DSS_DATA22*/\
MUX_VAL(CP(DSS_DATA23), (IDIS | PTD | DIS | M0))
/*DSS_DATA23*/\
- /*CAMERA*/\
MUX_VAL(CP(CAM_FLD), (IDIS | PTD | DIS | M4))
/*CAM_FLD*/\
MUX_VAL(CP(CAM_XCLKB), (IDIS | PTD | DIS | M0))
/*CAM_XCLKB*/\
MUX_VAL(CP(CAM_WEN), (IEN | PTD | DIS | M0))
/*CAM_WEN*/\
MUX_VAL(CP(CAM_STROBE), (IDIS | PTD | DIS | M0))
/*CAM_STROBE*/\
MUX_VAL(CP(CSI2_DX1), (IEN | PTD | EN | M4))
/*GPIO_114*/\
PEN_DOWN*/\
- /*Bluetooth*/\
MUX_VAL(CP(UART2_CTS), (IEN | PTD | DIS | M4))
/*GPIO_144 - LCD_EN*/\
MUX_VAL(CP(UART2_RTS), (IEN | PTD | DIS | M4))
/*GPIO_145*/\
MUX_VAL(CP(UART2_TX), (IEN | PTD | DIS | M4))
/*GPIO_146*/\
MUX_VAL(CP(UART2_RX), (IEN | PTD | DIS | M4))
/*GPIO_147*/\
MUX_VAL(CP(UART1_TX), (IDIS | PTD | DIS | M0))
/*UART1_TX*/\
MUX_VAL(CP(UART1_CTS), (IEN | PTU | DIS | M4))
/*GPIO_150-MMC3_WP*/\
MUX_VAL(CP(UART1_RX), (IEN | PTD | DIS | M0))
/*UART1_RX*/\
MUX_VAL(CP(UART3_CTS_RCTX), (IEN | PTD | EN | M0))
/*UART3_CTS_RCTX*/\
MUX_VAL(CP(HDQ_SIO), (IDIS | PTU | EN | M4))
/*HDQ_SIO*/\
MUX_VAL(CP(MCSPI1_CLK), (IEN | PTD | DIS | M0))
/*McSPI1_CLK*/\
MUX_VAL(CP(MCSPI1_SIMO), (IEN | PTD | DIS | M0))
/*McSPI1_SIMO */\
MUX_VAL(CP(MCSPI1_SOMI), (IEN | PTD | DIS | M0))
/*McSPI1_SOMI */\
MUX_VAL(CP(MCSPI1_CS0), (IEN | PTD | EN | M0))
/*McSPI1_CS0*/\
MUX_VAL(CP(MCSPI1_CS1), (IDIS | PTD | EN | M0))
/*McSPI1_CS1*/\
MUX_VAL(CP(MCSPI1_CS2), (IEN | PTU | DIS | M4))
/*GPIO_176 */\
LAN_INTR */\
MUX_VAL(CP(SYS_CLKOUT1), (IEN | PTU | EN | M4))
/*GPIO_10*/\
MUX_VAL(CP(SYS_CLKOUT2), (IEN | PTU | EN | M4))
/*GPIO_186*/\
MUX_VAL(CP(ETK_CLK_ES2), (IEN | PTU | EN | M2))
/*MMC3_CLK*/\
MUX_VAL(CP(ETK_CTL_ES2), (IEN | PTU | EN | M2))
/*MMC3_CMD*/\
MUX_VAL(CP(ETK_D0_ES2), (IEN | PTU | EN | M4))
/*GPIO_14*/\
MUX_VAL(CP(ETK_D3_ES2), (IEN | PTU | EN | M2))
/*MMC3_DAT3*/\
MUX_VAL(CP(ETK_D4_ES2), (IEN | PTU | EN | M2))
/*MMC3_DAT0*/\
MUX_VAL(CP(ETK_D5_ES2), (IEN | PTU | EN | M2))
/*MMC3_DAT1*/\
MUX_VAL(CP(ETK_D6_ES2), (IEN | PTU | EN | M2))
/*MMC3_DAT2*/\
MUX_VAL(CP(ETK_D7_ES2), (IEN | PTU | EN | M4))
/*GPIO_21*/\
MUX_VAL(CP(ETK_D8_ES2), (IEN | PTU | EN | M4))
/*GPIO_22*/\
MUX_VAL(CP(ETK_D9_ES2), (IEN | PTU | EN | M4))
/*GPIO_23*/\
-#define MUX_OVERO_SDIO2_DIRECT() \
MUX_VAL(CP(MMC2_CLK), (IEN | PTU | EN | M0))
/*MMC2_CLK*/\
/*MMC2_CMD*/\
/*MMC2_DAT0*/\
/*MMC2_DAT1*/\
/*MMC2_DAT2*/\
/*MMC2_DAT3*/\
MUX_VAL(CP(MMC2_DAT4), (IEN | PTU | EN | M0))
/*MMC2_DAT4*/\
MUX_VAL(CP(MMC2_DAT5), (IEN | PTU | EN | M0))
/*MMC2_DAT5*/\
MUX_VAL(CP(MMC2_DAT6), (IEN | PTU | EN | M0))
/*MMC2_DAT6*/\
MUX_VAL(CP(MMC2_DAT7), (IEN | PTU | EN | M0))
/*MMC2_DAT7*/\
MUX_VAL(CP(MMC1_DAT4), (IEN | PTD | EN | M4))
/*GPIO_126*/\
MUX_VAL(CP(MMC1_DAT5), (IEN | PTU | EN | M4))
/*GPIO_127*/\
MUX_VAL(CP(MMC1_DAT6), (IEN | PTU | EN | M4))
/*GPIO_128*/\
MUX_VAL(CP(MMC1_DAT7), (IEN | PTU | EN | M4))
/*GPIO_129*/
-#define MUX_OVERO_SDIO2_TRANSCEIVER() \
/*MMC2_CLK*/\
/*MMC2_CMD*/\
/*MMC2_DAT0*/\
/*MMC2_DAT1*/\
/*MMC2_DAT2*/\
/*MMC2_DAT3*/\
/*MMC2_DIR_DAT0*/\
/*MMC2_DIR_DAT1*/\
/*MMC2_DIR_CMD*/\
MUX_VAL(CP(MMC2_DAT7), (IEN | PTU | EN | M1))
/*MMC2_CLKIN*/\
MUX_VAL(CP(MMC1_DAT4), (IEN | PTU | EN | M4))
/*GPIO_126*/\
/*GPIO_127*/\
/*GPIO_128*/\
/*GPIO_129*/
-#define MUX_USRP_E() \
MUX_VAL(CP(MCSPI1_SOMI), (IEN | PTD | DIS | M4))
/*GPIO_173 */\
MUX_VAL(CP(MCSPI1_CS1), (IDIS | PTD | EN | M4))
/*GPIO_175 */\
-#define MUX_ALTO35() \
/*GPIO_10-BTN*/\
MUX_VAL(CP(UART1_TX), (IDIS | PTD | DIS | M4))
/*GPIO_148-RED LED*/\
MUX_VAL(CP(UART1_CTS), (IDIS | PTD | DIS | M4))
/*GPIO_150-YELLOW LED*/\
MUX_VAL(CP(UART1_RX), (IDIS | PTD | DIS | M4))
/*GPIO_151-BLUE LED*/\
MUX_VAL(CP(HDQ_SIO), (IDIS | PTD | DIS | M4))
/*GPIO_170-GREEN LED*/\
/*GPIO_175*/\
-#define MUX_ARBOR43C() \
MUX_VAL(CP(CSI2_DX1), (IDIS | PTD | DIS | M4))
/*GPIO_114-RED LED*/\
MUX_VAL(CP(HDQ_SIO), (IEN | PTU | EN | M4))
/*GPIO_170-BUTTON */\
MUX_VAL(CP(SYS_CLKOUT2), (IDIS | PTD | DIS | M4))
/*GPIO_186-BLUE LED*/\
MUX_VAL(CP(JTAG_EMU1), (IDIS | PTD | DIS | M4))
/*GPIO_31-CAP WAKE*/\
/*GPIO_10-CAP IRQ*/\
-#endif diff --git a/board/overo/spl.c b/board/overo/spl.c deleted file mode 100644 index d577e00fbca..00000000000 --- a/board/overo/spl.c +++ /dev/null @@ -1,59 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/*
-#include <asm/io.h> -#include <asm/arch/mem.h> -#include <asm/arch/sys_proto.h> -#include "overo.h"
- Routine: get_board_mem_timings
- Description: If we use SPL then there is no x-loader nor config header
- so we have to setup the DDR timings ourself on both banks.
-void get_board_mem_timings(struct board_sdrc_timings *timings) -{
timings->mr = MICRON_V_MR_165;
switch (get_board_revision()) {
case REVISION_0: /* Micron 1286MB/256MB, 1/2 banks of 128MB */
timings->mcfg = MICRON_V_MCFG_165(256 << 20);
timings->ctrla = MICRON_V_ACTIMA_165;
timings->ctrlb = MICRON_V_ACTIMB_165;
timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz;
break;
case REVISION_1: /* Micron 256MB/512MB, 1/2 banks of 256MB */
case REVISION_4:
timings->mcfg = MICRON_V_MCFG_200(256 << 20);
timings->ctrla = MICRON_V_ACTIMA_200;
timings->ctrlb = MICRON_V_ACTIMB_200;
timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_200MHz;
break;
case REVISION_2: /* Hynix 256MB/512MB, 1/2 banks of 256MB */
timings->mcfg = HYNIX_V_MCFG_200(256 << 20);
timings->ctrla = HYNIX_V_ACTIMA_200;
timings->ctrlb = HYNIX_V_ACTIMB_200;
break;
case REVISION_3: /* Micron 512MB/1024MB, 1/2 banks of 512MB */
timings->mcfg = MCFG(512 << 20, 15);
break;
default:
timings->mcfg = MICRON_V_MCFG_165(128 << 20);
-} diff --git a/configs/omap3_overo_defconfig b/configs/omap3_overo_defconfig deleted file mode 100644 index 1e7e5f7d835..00000000000 --- a/configs/omap3_overo_defconfig +++ /dev/null @@ -1,51 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_OMAP2PLUS=y -CONFIG_SYS_MALLOC_F_LEN=0x2000 -CONFIG_TARGET_OMAP3_OVERO=y -CONFIG_SPL=y -CONFIG_DISTRO_DEFAULTS=y -CONFIG_NR_DRAM_BANKS=2 -# CONFIG_USE_BOOTCOMMAND is not set -CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_MTD_SUPPORT=y -CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_PROMPT="Overo # " -# CONFIG_CMD_IMI is not set -CONFIG_CMD_SPL=y -CONFIG_CMD_SPL_NAND_OFS=0x240000 -CONFIG_CMD_ASKENV=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_NAND=y -CONFIG_CMD_SPI=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_MTDPARTS=y -CONFIG_MTDIDS_DEFAULT="nand0=omap2-nand.0"
-CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:512k(xloader),1792k(u-boot),256k(environ),8m(linux),-(rootfs)" -CONFIG_CMD_UBI=y -CONFIG_ENV_IS_IN_NAND=y -CONFIG_TWL4030_LED=y -CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y -CONFIG_SYS_NAND_BUSWIDTH_16BIT=y -CONFIG_SPL_NAND_SIMPLE=y -CONFIG_SMC911X=y -CONFIG_SMC911X_BASE=0x2C000000 -CONFIG_SMC911X_32_BIT=y -CONFIG_CONS_INDEX=3 -CONFIG_SPI=y -CONFIG_OMAP3_SPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y -CONFIG_FAT_WRITE=y -CONFIG_BCH=y -CONFIG_OF_LIBFDT=y diff --git a/include/configs/omap3_overo.h b/include/configs/omap3_overo.h deleted file mode 100644 index 35f3af4ae9a..00000000000 --- a/include/configs/omap3_overo.h +++ /dev/null @@ -1,192 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/*
- Configuration settings for the Gumstix Overo board.
-#ifndef __CONFIG_H -#define __CONFIG_H
-#include <configs/ti_omap3_common.h> -/*
- We are only ever GP parts and will utilize all of the "downloaded
image"
- area in SRAM which starts at 0x40200000 and ends at 0x4020FFFF (64KB).
-#undef CONFIG_SPL_TEXT_BASE -#define CONFIG_SPL_TEXT_BASE 0x40200000
-/* call misc_init_r */
-/* pass the revision tag */ -#define CONFIG_REVISION_TAG
-/* override size of malloc() pool */ -#undef CONFIG_SYS_MALLOC_LEN -#define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB sector */ -/* Shift 128 << 15 provides 4 MiB heap to support UBI commands.
- Shift 128 << 10 provides 128 KiB heap for limited-memory devices. */
-#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (128 << 15))
-/* I2C Support */
-/* TWL4030 LED */
-/* USB EHCI */ -#define CONFIG_OMAP_EHCI_PHY1_RESET_GPIO 183
-/* commands to include */
-#ifdef CONFIG_NAND -/* NAND block size is 128 KiB. Synchronize these values with
- overo_nand_partitions in mach-omap2/board-overo.c in Linux:
- xloader 4 * NAND_BLOCK_SIZE = 512 KiB
- uboot 14 * NAND_BLOCK_SIZE = 1792 KiB
- uboot environtment 2 * NAND_BLOCK_SIZE = 256 KiB
- linux 64 * NAND_BLOCK_SIZE = 8 MiB
- rootfs remainder
-#endif /* CONFIG_NAND */
-/* Board NAND Info. */ -/* Environment information */ -#define CONFIG_EXTRA_ENV_SETTINGS \
DEFAULT_LINUX_BOOT_ENV \
"bootdir=/boot\0" \
"bootfile=zImage\0" \
"usbtty=cdc_acm\0" \
"console=ttyO2,115200n8\0" \
"mpurate=auto\0" \
"optargs=\0" \
"vram=12M\0" \
"dvimode=1024x768MR-16@60\0" \
"defaultdisplay=dvi\0" \
"mmcdev=0\0" \
"mmcroot=/dev/mmcblk0p2 rw\0" \
"mmcrootfstype=ext4 rootwait\0" \
"nandroot=ubi0:rootfs ubi.mtd=4\0" \
"nandrootfstype=ubifs\0" \
"mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \
"mmcargs=setenv bootargs console=${console} " \
"${optargs} " \
"mpurate=${mpurate} " \
"vram=${vram} " \
"omapfb.mode=dvi:${dvimode} " \
"omapdss.def_disp=${defaultdisplay} " \
"root=${mmcroot} " \
"rootfstype=${mmcrootfstype}\0" \
"nandargs=setenv bootargs console=${console} " \
"${optargs} " \
"vram=${vram} " \
"root=${nandroot} " \
"rootfstype=${nandrootfstype}\0" \
"loadbootscript=load mmc ${mmcdev} ${loadaddr} boot.scr\0" \
"bootscript=echo Running boot script from mmc ...; " \
"source ${loadaddr}\0" \
"loadbootenv=load mmc ${mmcdev} ${loadaddr} uEnv.txt\0" \
"importbootenv=echo Importing environment from mmc ...; " \
"env import -t ${loadaddr} ${filesize}\0" \
"loaduimage=load mmc ${mmcdev} ${loadaddr} uImage\0" \
"mmcboot=echo Booting from mmc...; " \
"run mmcargs; " \
"bootm ${loadaddr}\0" \
"loadzimage=load mmc ${mmcdev}:2 ${loadaddr}
${bootdir}/${bootfile}\0" \
"loadfdt=load mmc ${mmcdev}:2 ${fdtaddr} ${bootdir}/${fdtfile}\0"
"loadubizimage=ubifsload ${loadaddr} ${bootdir}/${bootfile}\0" \
"loadubifdt=ubifsload ${fdtaddr} ${bootdir}/${fdtfile}\0" \
"mmcbootfdt=echo Booting with DT from mmc ...; " \
"run mmcargs; " \
"bootz ${loadaddr} - ${fdtaddr}\0" \
"nandboot=echo Booting from nand ...; " \
"run nandargs; " \
"if nand read ${loadaddr} linux; then " \
"bootm ${loadaddr};" \
"fi;\0" \
"nanddtsboot=echo Booting from nand with DTS...; " \
"run nandargs; " \
"ubi part rootfs; "\
"ubifsmount ubi0:rootfs; "\
"run loadubifdt; "\
"run loadubizimage; "\
-#define CONFIG_BOOTCOMMAND \
"mmc dev ${mmcdev}; if mmc rescan; then " \
"if run loadbootscript; then " \
"run bootscript; " \
"fi;" \
"if run loadbootenv; then " \
"echo Loaded environment from ${bootenv};" \
"run importbootenv;" \
"fi;" \
"if test -n $uenvcmd; then " \
"echo Running uenvcmd ...;" \
"run uenvcmd;" \
"fi;" \
"if run loaduimage; then " \
"run mmcboot;" \
"fi;" \
"if run loadzimage; then " \
"if test -z \"${fdtfile}\"; then " \
"setenv fdtfile
omap3-${boardname}-${expansionname}.dtb;" \
"fi;" \
"if run loadfdt; then " \
"run mmcbootfdt;" \
"fi;" \
"fi;" \
"fi;" \
"run nandboot; " \
"if test -z \"${fdtfile}\"; then "\
"setenv fdtfile omap3-${boardname}-${expansionname}.dtb;"
"fi;" \
"run nanddtsboot; " \
-/* memtest works on */ -#define CONFIG_SYS_MEMTEST_START (OMAP34XX_SDRC_CS0) -#define CONFIG_SYS_MEMTEST_END (OMAP34XX_SDRC_CS0 + \
0x01F00000) /* 31MB */
-/* FLASH and environment organization */ -#if defined(CONFIG_NAND) -#define CONFIG_SYS_FLASH_BASE NAND_BASE -#endif
-/* Monitor at start of flash */ -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_ONENAND_BASE ONENAND_MAP
-#define ONENAND_ENV_OFFSET 0x240000 /* environment starts here */ -#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ -#define CONFIG_ENV_OFFSET 0x240000 -#define CONFIG_ENV_ADDR 0x240000
-/* Initial RAM setup */ -#define CONFIG_SYS_INIT_RAM_ADDR 0x4020f800 -#define CONFIG_SYS_INIT_RAM_SIZE 0x800
-/* NAND boot config */ -#define CONFIG_SYS_NAND_MAX_ECCPOS 56 -#define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_COUNT 64 -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -#define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) -#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS -#define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, \
13, 14, 16, 17, 18, 19, 20, 21,
22, \
23, 24, 25, 26, 27, 28, 30, 31,
32, \
33, 34, 35, 36, 37, 38, 39, 40,
41, \
42, 44, 45, 46, 47, 48, 49, 50,
51, \
52, 53, 54, 55, 56}
-#define CONFIG_SYS_NAND_ECCSIZE 512 -#define CONFIG_SYS_NAND_ECCBYTES 13 -#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW_DETECTION_SW -#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 -/* NAND: SPL falcon mode configs */ -#ifdef CONFIG_SPL_OS_BOOT -#define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x280000 -#endif
-#endif /* __CONFIG_H */
2.19.1.1215.g8438c0b245-goog
Thank you, Andrew.
- Simon
Andrew C. Smith
