[PATCH v2 0/2] Conclusive WHLE-LS1046A support
Hi all,
this is v2 of the Conclusive WHLE-LS1046A support series.
Patch [1/2] remains unchanged.
Patch [2/2] features a major clean-up to configs/whle_ls1046a.h, dropping unneeded/redundant defines, and moving some others to more appropriate locations in board code. The environment settings have been moved to plain text whle-ls1046a.env file, and distro_bootcmd macros dropped in favor of BOOTSTD. A non-DM_ETH case has also been removed.
In Device Tree bindings, i2c-mux node has been relocated to the correct parent and ext_i2c received an address correction.
Minor style clean-ups have been performed to eth.c and an incorrect value of CONFIG_MTDPARTS_DEFAULT removed from defconfigs.
Artur Rojek (1): board: Add support for Conclusive WHLE-LS1046A
Jakub Klama (1): armv8: layerscape: Enable ext4 environment storage
arch/arm/Kconfig | 19 ++ arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 5 + arch/arm/dts/Makefile | 1 + arch/arm/dts/fsl-ls1046a-whle.dts | 208 +++++++++++++++++ board/conclusive/whle-ls1046a/Kconfig | 15 ++ board/conclusive/whle-ls1046a/MAINTAINERS | 9 + board/conclusive/whle-ls1046a/Makefile | 7 + board/conclusive/whle-ls1046a/ddr.c | 21 ++ board/conclusive/whle-ls1046a/eth.c | 65 ++++++ board/conclusive/whle-ls1046a/whle-ls1046a.c | 215 ++++++++++++++++++ .../conclusive/whle-ls1046a/whle-ls1046a.env | 13 ++ configs/whle_ls1046a_emmc_defconfig | 83 +++++++ configs/whle_ls1046a_qspi_defconfig | 84 +++++++ include/configs/whle_ls1046a.h | 47 ++++ 14 files changed, 792 insertions(+) create mode 100644 arch/arm/dts/fsl-ls1046a-whle.dts create mode 100644 board/conclusive/whle-ls1046a/Kconfig create mode 100644 board/conclusive/whle-ls1046a/MAINTAINERS create mode 100644 board/conclusive/whle-ls1046a/Makefile create mode 100644 board/conclusive/whle-ls1046a/ddr.c create mode 100644 board/conclusive/whle-ls1046a/eth.c create mode 100644 board/conclusive/whle-ls1046a/whle-ls1046a.c create mode 100644 board/conclusive/whle-ls1046a/whle-ls1046a.env create mode 100644 configs/whle_ls1046a_emmc_defconfig create mode 100644 configs/whle_ls1046a_qspi_defconfig create mode 100644 include/configs/whle_ls1046a.h
Some boards keep their environment on MMC storage within an ext4 partition.
Signed-off-by: Jakub Klama jakub@conclusive.pl Signed-off-by: Artur Rojek artur@conclusive.pl Reviewed-by: Tom Rini trini@konsulko.com ---
v2: no change
arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index 12d31184ad91..3775cb493732 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -857,6 +857,11 @@ enum env_location arch_env_get_location(enum env_operation op, int prio) break; }
+#ifdef CONFIG_ENV_IS_IN_EXT4 + if (env_loc == ENVL_MMC) + return ENVL_EXT4; +#endif + return env_loc; } #endif /* CONFIG_TFABOOT */
Introduce support for Conclusive WHLE-LS1046A Single Board Computer.
Co-developed-by: Jakub Klama jakub@conclusive.pl Signed-off-by: Jakub Klama jakub@conclusive.pl Signed-off-by: Artur Rojek artur@conclusive.pl ---
v2: - drop non-DM_ETH case - clean-up defines in configs/whle_ls1046a.h: remove unneeded ones, move others to appropriate files in board directory - move environment variables to whle-ls1046a.env - move away from distro_bootcmd and use BOOTSTD - fix i2c-mux node parent and ext_i2c address in Device Tree - style changes to eth.c - fix CONFIG_MTDPARTS_DEFAULT value in defconfigs
arch/arm/Kconfig | 19 ++ arch/arm/dts/Makefile | 1 + arch/arm/dts/fsl-ls1046a-whle.dts | 208 +++++++++++++++++ board/conclusive/whle-ls1046a/Kconfig | 15 ++ board/conclusive/whle-ls1046a/MAINTAINERS | 9 + board/conclusive/whle-ls1046a/Makefile | 7 + board/conclusive/whle-ls1046a/ddr.c | 21 ++ board/conclusive/whle-ls1046a/eth.c | 65 ++++++ board/conclusive/whle-ls1046a/whle-ls1046a.c | 215 ++++++++++++++++++ .../conclusive/whle-ls1046a/whle-ls1046a.env | 13 ++ configs/whle_ls1046a_emmc_defconfig | 83 +++++++ configs/whle_ls1046a_qspi_defconfig | 84 +++++++ include/configs/whle_ls1046a.h | 47 ++++ 13 files changed, 787 insertions(+) create mode 100644 arch/arm/dts/fsl-ls1046a-whle.dts create mode 100644 board/conclusive/whle-ls1046a/Kconfig create mode 100644 board/conclusive/whle-ls1046a/MAINTAINERS create mode 100644 board/conclusive/whle-ls1046a/Makefile create mode 100644 board/conclusive/whle-ls1046a/ddr.c create mode 100644 board/conclusive/whle-ls1046a/eth.c create mode 100644 board/conclusive/whle-ls1046a/whle-ls1046a.c create mode 100644 board/conclusive/whle-ls1046a/whle-ls1046a.env create mode 100644 configs/whle_ls1046a_emmc_defconfig create mode 100644 configs/whle_ls1046a_qspi_defconfig create mode 100644 include/configs/whle_ls1046a.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index d812685c9842..609571e6e421 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1851,6 +1851,24 @@ config TARGET_SL28 help Support for Kontron SMARC-sAL28 board.
+config TARGET_WHLE_LS1046A + bool "Support Conclusive WHLE-LS1046A" + select ARCH_LS1046A + select ARM64 + select ARMV8_MULTIENTRY + select ARCH_SUPPORT_TFABOOT + select BOARD_EARLY_INIT_F + select BOARD_LATE_INIT + select GPIO_EXTRA_HEADER + select DM_SPI_FLASH if DM_SPI + imply SCSI + help + Support for Conclusive WHLE-LS1046A platform. + The WHLE-LS1046A is a high-performance Single Board Computer with + extensive connectivity features that supports the QorIQ LS1046A + Layerscape Architecture processor: + https://conclusive.tech/products/whle-ls1-sbc/ + config TARGET_TEN64 bool "Support ten64" select ARCH_LS1088A @@ -2299,6 +2317,7 @@ source "board/cortina/presidio-asic/Kconfig" source "board/broadcom/bcmns/Kconfig" source "board/broadcom/bcmns3/Kconfig" source "board/cavium/thunderx/Kconfig" +source "board/conclusive/whle-ls1046a/Kconfig" source "board/eets/pdu001/Kconfig" source "board/emulation/qemu-arm/Kconfig" source "board/freescale/ls2080aqds/Kconfig" diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 1be08c5fdc2e..8dcbf29df363 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -615,6 +615,7 @@ dtb-$(CONFIG_FSL_LSCH2) += fsl-ls1043a-qds-duart.dtb \ fsl-ls1046a-qds-lpuart.dtb \ fsl-ls1046a-rdb.dtb \ fsl-ls1046a-frwy.dtb \ + fsl-ls1046a-whle.dtb \ fsl-ls1012a-qds.dtb \ fsl-ls1012a-rdb.dtb \ fsl-ls1012a-2g5rdb.dtb \ diff --git a/arch/arm/dts/fsl-ls1046a-whle.dts b/arch/arm/dts/fsl-ls1046a-whle.dts new file mode 100644 index 000000000000..1aed3e8c4701 --- /dev/null +++ b/arch/arm/dts/fsl-ls1046a-whle.dts @@ -0,0 +1,208 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * Copyright 2020-2023 Conclusive Engineering Sp. z o. o. + */ + +#include <dt-bindings/gpio/gpio.h> + +/dts-v1/; +#include "fsl-ls1046a.dtsi" + +/ { + model = "Conclusive WHLE-LS1046A"; + compatible = "conclusive,whle-ls1046a", "fsl,ls1046a"; + + chosen { + stdout-path = &duart0; + }; + + aliases { + spi0 = &qspi; + }; +}; + +&soc { + pcie@3400000 { + status = "okay"; + }; +}; + +&qspi { + status = "okay"; + + gd25lq128: flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + spi-max-frequency = <50000000>; + reg = <0>; + + partitions { + #address-cells = <1>; + #size-cells = <1>; + compatible = "fixed-partitions"; + + partition@0 { + label = "bl2"; + reg = <0 0x100000>; + }; + + partition@100000 { + label = "fip1"; + reg = <0x100000 0x400000>; + }; + + partition@500000 { + label = "fip2"; + reg = <0x500000 0x400000>; + }; + + partition@900000 { + label = "uboot-env"; + reg = <0x900000 0x10000>; + }; + + partition@910000 { + label = "fman-firmware"; + reg = <0x910000 0x200000>; + }; + + partition@a10000 { + label = "dtb"; + reg = <0xa10000 0x10000>; + }; + }; + }; +}; + +&i2c0 { + status = "okay"; + + spd@50 { + compatible = "spd"; + reg = <0x50>; + status = "okay"; + }; + + eeprom@56 { + compatible = "atmel,24c64"; + reg = <0x56>; + status = "okay"; + }; + + eeprom@57 { + compatible = "24c01"; + reg = <0x57>; + status = "okay"; + }; + + leds@62 { + compatible = "nxp,pca9633"; + reg = <0x62>; + status = "okay"; + }; + + rtc@6f { + compatible = "microchip,mcp7941x"; + reg = <0x6f>; + status = "okay"; + }; +}; + +&i2c2 { + status = "okay"; + + i2c-mux@70 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "nxp,pca9546"; + reg = <0x70>; + status = "okay"; + + pcie0_i2c: i2c@0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0>; + }; + + sfp0_i2c: i2c@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + }; + + sfp1_i2c: i2c@2 { + #address-cells = <1>; + #size-cells = <0>; + reg = <2>; + }; + + ext_i2c: i2c@3 { + #address-cells = <1>; + #size-cells = <0>; + reg = <3>; + }; + }; +}; + +#include "fsl-ls1046-post.dtsi" + +&fman0 { + ethernet@e4000 { + phy-handle = <&rgmii_phy0>; + phy-connection-type = "rgmii-id"; + status = "okay"; + }; + + ethernet@e6000 { + phy-handle = <&rgmii_phy1>; + phy-connection-type = "rgmii-id"; + status = "okay"; + }; + + ethernet@e8000 { + phy-handle = <&sgmii_phy2>; + phy-connection-type = "sgmii"; + status = "okay"; + }; + + ethernet@ea000 { + phy-handle = <&sgmii_phy3>; + phy-connection-type = "sgmii"; + status = "okay"; + }; + + ethernet@f0000 { /* 10GEC1 */ + fixed-link = <0 1 1000 0 0>; + phy-connection-type = "xgmii"; + status = "okay"; + }; + + ethernet@f2000 { /* 10GEC2 */ + fixed-link = <0 1 1000 0 0>; + phy-connection-type = "xgmii"; + status = "okay"; + }; + + mdio@fc000 { + rgmii_phy0: ethernet-phy@1 { + reg = <0x1>; + }; + + rgmii_phy1: ethernet-phy@2 { + reg = <0x2>; + }; + + sgmii_phy2: ethernet-phy@3 { + reg = <0x3>; + }; + + sgmii_phy3: ethernet-phy@4 { + reg = <0x4>; + }; + }; +}; + +&duart0 { + status = "okay"; +}; diff --git a/board/conclusive/whle-ls1046a/Kconfig b/board/conclusive/whle-ls1046a/Kconfig new file mode 100644 index 000000000000..5778fbd5cd22 --- /dev/null +++ b/board/conclusive/whle-ls1046a/Kconfig @@ -0,0 +1,15 @@ +if TARGET_WHLE_LS1046A + +config SYS_BOARD + default "whle-ls1046a" + +config SYS_VENDOR + default "conclusive" + +config SYS_SOC + default "fsl-layerscape" + +config SYS_CONFIG_NAME + default "whle_ls1046a" + +endif diff --git a/board/conclusive/whle-ls1046a/MAINTAINERS b/board/conclusive/whle-ls1046a/MAINTAINERS new file mode 100644 index 000000000000..1dcf067a06d8 --- /dev/null +++ b/board/conclusive/whle-ls1046a/MAINTAINERS @@ -0,0 +1,9 @@ +WHLE-LS1046A Board +M: Jakub Klama jakub@conclusive.pl +M: Artur Rojek artur@conclusive.pl +S: Maintained +F: board/conclusive/whle-ls1046a +F: include/configs/whle_ls1046a.h +F: configs/whle_ls1046a_emmc_defconfig +F: configs/whle_ls1046a_qspi_defconfig +F: arch/arm/dts/fsl-ls1046a-whle.dts diff --git a/board/conclusive/whle-ls1046a/Makefile b/board/conclusive/whle-ls1046a/Makefile new file mode 100644 index 000000000000..9197ec93a6de --- /dev/null +++ b/board/conclusive/whle-ls1046a/Makefile @@ -0,0 +1,7 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright 2020-2023 Conclusive Engineering Sp. z o. o. + +obj-y += ddr.o +obj-y += whle-ls1046a.o +obj-$(CONFIG_NET) += eth.o diff --git a/board/conclusive/whle-ls1046a/ddr.c b/board/conclusive/whle-ls1046a/ddr.c new file mode 100644 index 000000000000..cbefc779d55d --- /dev/null +++ b/board/conclusive/whle-ls1046a/ddr.c @@ -0,0 +1,21 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 NXP + * Copyright 2020-2023 Conclusive Engineering Sp. z o. o. + */ + +#include <config.h> +#include <fsl_ddr_sdram.h> +#include <asm/global_data.h> + +DECLARE_GLOBAL_DATA_PTR; + +int fsl_initdram(void) +{ + gd->ram_size = tfa_get_dram_size(); + + if (!gd->ram_size) + gd->ram_size = fsl_ddr_sdram_size(); + + return 0; +} diff --git a/board/conclusive/whle-ls1046a/eth.c b/board/conclusive/whle-ls1046a/eth.c new file mode 100644 index 000000000000..05b83352b0ab --- /dev/null +++ b/board/conclusive/whle-ls1046a/eth.c @@ -0,0 +1,65 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 NXP + * Copyright 2020-2023 Conclusive Engineering Sp. z o. o. + */ +#include <config.h> +#include <fdt_support.h> +#include <net.h> +#include <asm/io.h> +#include <netdev.h> +#include <fm_eth.h> +#include <fsl_dtsec.h> +#include <fsl_mdio.h> + +#define RGMII_PHY1_ADDR 0x01 +#define RGMII_PHY2_ADDR 0x02 +#define SGMII_PHY3_ADDR 0x03 +#define SGMII_PHY4_ADDR 0x04 + +int board_eth_init(struct bd_info *bis) +{ +#ifdef CONFIG_FMAN_ENET + struct memac_mdio_info dtsec_mdio_info; + struct memac_mdio_controller *regs; + struct mii_dev *dev; + u32 srds; + struct ccsr_gur *gur = (struct ccsr_gur *)(CFG_SYS_FSL_GUTS_ADDR); + + srds = in_be32(&gur->rcwsr[4]) & FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_MASK; + srds >>= FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_SHIFT; + + if (srds != 0x1133 && srds != 0x3333) + printf("Invalid SerDes protocol 0x%x for WHLE-LS1046A\n", srds); + + regs = (struct memac_mdio_controller *)CFG_SYS_FM1_DTSEC_MDIO_ADDR; + dtsec_mdio_info.regs = regs; + dtsec_mdio_info.name = DEFAULT_FM_MDIO_NAME; + + /* Register the 1G MDIO bus */ + fm_memac_mdio_init(bis, &dtsec_mdio_info); + + /* RGMII on MAC 3 and 4, SGMII on MAC 5 and 6 */ + fm_info_set_phy_address(FM1_DTSEC3, RGMII_PHY1_ADDR); + fm_info_set_phy_address(FM1_DTSEC4, RGMII_PHY2_ADDR); + fm_info_set_phy_address(FM1_DTSEC5, SGMII_PHY3_ADDR); + fm_info_set_phy_address(FM1_DTSEC6, SGMII_PHY4_ADDR); + + dev = miiphy_get_dev_by_name(DEFAULT_FM_MDIO_NAME); + fm_info_set_mdio(FM1_DTSEC3, dev); + fm_info_set_mdio(FM1_DTSEC4, dev); + fm_info_set_mdio(FM1_DTSEC5, dev); + fm_info_set_mdio(FM1_DTSEC6, dev); + + cpu_eth_init(bis); +#endif + + return pci_eth_init(bis); +} + +#ifdef CONFIG_FMAN_ENET +int fdt_update_ethernet_dt(void *blob) +{ + return 0; +} +#endif diff --git a/board/conclusive/whle-ls1046a/whle-ls1046a.c b/board/conclusive/whle-ls1046a/whle-ls1046a.c new file mode 100644 index 000000000000..6b4bd149cdb2 --- /dev/null +++ b/board/conclusive/whle-ls1046a/whle-ls1046a.c @@ -0,0 +1,215 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * whle-ls1046a.c - Board init file for Conclusive WHLE-LS1046A board + * Copyright (C) 2020-2023 Conclusive Engineering Sp. z o. o. + */ + +#include <config.h> +#include <i2c.h> +#include <fdt_support.h> +#include <init.h> +#include <env.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/fsl_serdes.h> +#include <asm/arch/soc.h> +#include <asm/arch-fsl-layerscape/fsl_icid.h> +#include <hwconfig.h> +#include <ahci.h> +#include <mmc.h> +#include <scsi.h> +#include <fm_eth.h> +#include <fsl_csu.h> +#include <fsl_esdhc.h> +#include <fsl_sec.h> +#include <fsl_dspi.h> + +#define BOARD_REV_MASK 0x0f +#define SPI_MCR_REG 0x2100000 + +/* Retimer */ +#define I2C_RETIMER_BUS 0 +#define I2C_RETIMER_ADDR 0x18 + +DECLARE_GLOBAL_DATA_PTR; + +static inline void set_spi_cs_signal_inactive(void) +{ + /* default: all CS signals inactive state is high */ + uint mcr_val; + uint mcr_cfg_val = DSPI_MCR_MSTR | DSPI_MCR_PCSIS_MASK | + DSPI_MCR_CRXF | DSPI_MCR_CTXF; + + mcr_val = in_be32(SPI_MCR_REG); + mcr_val |= DSPI_MCR_HALT; + out_be32(SPI_MCR_REG, mcr_val); + out_be32(SPI_MCR_REG, mcr_cfg_val); + mcr_val = in_be32(SPI_MCR_REG); + mcr_val &= ~DSPI_MCR_HALT; + out_be32(SPI_MCR_REG, mcr_val); +} + +int board_early_init_f(void) +{ + fsl_lsch2_early_init_f(); + + return 0; +} + +static inline uint8_t get_board_version(void) +{ + struct ccsr_gur __iomem *gur = (void *)(CFG_SYS_FSL_GUTS_ADDR); + + return in_be32(&gur->gpporcr1) & BOARD_REV_MASK; +} + +static int settings_r(void) +{ + serial_read_from_eeprom(0); + + return 0; +} +EVENT_SPY_SIMPLE(EVT_SETTINGS_R, settings_r); + +#if defined(CONFIG_DISPLAY_BOARDINFO_LATE) +int checkboard(void) +{ + const char *serial_number = env_get("serial#"); + + printf("Board: WHLE-LS1046A, Rev: %s\n", + get_board_version() == 0x00 ? "0" : "unknown"); + + if (!serial_number) + printf("Warning: unknown serial number.\n"); + else + printf("S/N: %s\n", serial_number); + + return 0; +} +#endif + +static void board_retimer_init_rx(struct udevice *dev, int chnum) +{ + /* Select channel */ + dm_i2c_reg_write(dev, 0xff, chnum); + + /* Initialize receive channel */ + dm_i2c_reg_clrset(dev, 0x00, 0x04, 0x04); + dm_i2c_reg_clrset(dev, 0x0a, 0x0c, 0x0c); + dm_i2c_reg_clrset(dev, 0x2f, 0xf0, 0xc0); + dm_i2c_reg_clrset(dev, 0x31, 0x60, 0x00); + dm_i2c_reg_clrset(dev, 0x03, 0xff, 0x00); + dm_i2c_reg_clrset(dev, 0x3a, 0xff, 0x00); + dm_i2c_reg_clrset(dev, 0x40, 0xff, 0x00); + dm_i2c_reg_clrset(dev, 0x1e, 0x08, 0x08); + dm_i2c_reg_clrset(dev, 0x2d, 0x08, 0x08); + dm_i2c_reg_clrset(dev, 0x2d, 0x07, 0x02); + dm_i2c_reg_clrset(dev, 0x15, 0x47, 0x00); + dm_i2c_reg_clrset(dev, 0x0a, 0x0c, 0x00); +} + +static void board_retimer_init_tx(struct udevice *dev, int chnum) +{ + /* Select channel */ + dm_i2c_reg_write(dev, 0xff, chnum); + + /* Initialize transmit channel */ + dm_i2c_reg_clrset(dev, 0x00, 0x04, 0x04); + dm_i2c_reg_clrset(dev, 0x0a, 0x0c, 0x0c); + dm_i2c_reg_clrset(dev, 0x2f, 0xf0, 0xc0); + dm_i2c_reg_clrset(dev, 0x31, 0x20, 0x20); + dm_i2c_reg_clrset(dev, 0x3a, 0xff, 0x00); + dm_i2c_reg_clrset(dev, 0x1e, 0x08, 0x08); + dm_i2c_reg_clrset(dev, 0x2d, 0x07, 0x00); + dm_i2c_reg_clrset(dev, 0x15, 0x47, 0x00); + dm_i2c_reg_clrset(dev, 0x0a, 0x0c, 0x00); +} + +static void board_retimer_init(void) +{ + struct udevice *dev; + + i2c_get_chip_for_busnum(I2C_RETIMER_BUS, I2C_RETIMER_ADDR, 1, &dev); + board_retimer_init_tx(dev, 0x04); + board_retimer_init_rx(dev, 0x05); + board_retimer_init_tx(dev, 0x06); + board_retimer_init_rx(dev, 0x07); +} + +int board_init(void) +{ +#ifdef CONFIG_NXP_ESBC + /* + * In case of Secure Boot, the IBR configures the SMMU + * to allow only Secure transactions. + * SMMU must be reset in bypass mode. + * Set the ClientPD bit and Clear the USFCFG Bit + */ + u32 val; + + val = (in_le32(SMMU_SCR0) | SCR0_CLIENTPD_MASK) & ~(SCR0_USFCFG_MASK); + out_le32(SMMU_SCR0, val); + val = (in_le32(SMMU_NSCR0) | SCR0_CLIENTPD_MASK) & ~(SCR0_USFCFG_MASK); + out_le32(SMMU_NSCR0, val); +#endif + +#ifdef CONFIG_FSL_CAAM + sec_init(); +#endif + + board_retimer_init(); + return 0; +} + +int board_setup_core_volt(u32 vdd) +{ + return 0; +} + +static void board_config_mux(void) +{ + struct ccsr_scfg *scfg = (struct ccsr_scfg *)CFG_SYS_FSL_SCFG_ADDR; + u32 usb_pwrfault; + + /* Configure IRQ01 and IRQ02 lines polarity to negated */ + out_be32(&scfg->intpcr, 0x60000000); + + /* + * IIC3 is used, configure mux to IIC3_SCL/IIC3/SDA + * IIC4 is not used, configure mux to USB3_DRVVBUS/USB3_PWRFAULT + */ + out_be32(&scfg->rcwpmuxcr0, 0x0033); + out_be32(&scfg->usbdrvvbus_selcr, SCFG_USBDRVVBUS_SELCR_USB1); + usb_pwrfault = + (SCFG_USBPWRFAULT_DEDICATED << SCFG_USBPWRFAULT_USB3_SHIFT) | + (SCFG_USBPWRFAULT_SHARED << SCFG_USBPWRFAULT_USB2_SHIFT) | + (SCFG_USBPWRFAULT_SHARED << SCFG_USBPWRFAULT_USB1_SHIFT); + out_be32(&scfg->usbpwrfault_selcr, usb_pwrfault); + set_spi_cs_signal_inactive(); +} + +#ifdef CONFIG_MISC_INIT_R +int misc_init_r(void) +{ + board_config_mux(); + return 0; +} +#endif + +int ft_board_setup(void *blob, struct bd_info *bd) +{ + u64 base[CONFIG_NR_DRAM_BANKS]; + u64 size[CONFIG_NR_DRAM_BANKS]; + + /* fixup DT for the two DDR banks */ + base[0] = gd->bd->bi_dram[0].start; + size[0] = gd->bd->bi_dram[0].size; + base[1] = gd->bd->bi_dram[1].start; + size[1] = gd->bd->bi_dram[1].size; + + fdt_fixup_memory_banks(blob, base, size, 2); + ft_cpu_setup(blob, bd); + fdt_fixup_icid(blob); + + return 0; +} diff --git a/board/conclusive/whle-ls1046a/whle-ls1046a.env b/board/conclusive/whle-ls1046a/whle-ls1046a.env new file mode 100644 index 000000000000..fd82a9a6b1d8 --- /dev/null +++ b/board/conclusive/whle-ls1046a/whle-ls1046a.env @@ -0,0 +1,13 @@ +hwconfig=fsl_ddr:bank_intlv=auto +kernel_addr_r=0x81000000 +kernel_size=0x07000000 +kernel_comp_addr_r=0x88000000 +kernel_comp_size=0x04000000 +ramdisk_addr_r=0x90000000 +ramdisk_size=0x08000000 +fdt_addr_r=0x98000000 +pxefile_addr_r=0x99000000 +scriptaddr=0x9a000000 +fdtfile=fsl-ls1046a-whle.dtb +console=ttyS0,115200 +fsl_bootcmd_mcinitcmd_set=y diff --git a/configs/whle_ls1046a_emmc_defconfig b/configs/whle_ls1046a_emmc_defconfig new file mode 100644 index 000000000000..a3104b0023e9 --- /dev/null +++ b/configs/whle_ls1046a_emmc_defconfig @@ -0,0 +1,83 @@ +CONFIG_ARM=y +CONFIG_COUNTER_FREQUENCY=25000000 +CONFIG_TARGET_WHLE_LS1046A=y +CONFIG_TFABOOT=y +CONFIG_TEXT_BASE=0x82000000 +CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SIZE=0x2000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-whle" +CONFIG_QSPI_AHB_INIT=y +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y +CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_PCI=y +CONFIG_AHCI=y +CONFIG_MP=y +CONFIG_FIT_VERBOSE=y +CONFIG_BOOTSTD_FULL=y +CONFIG_BOOTSTD_DEFAULTS=y +CONFIG_BOOTSTD_BOOTCOMMAND=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_BOOTDELAY=10 +CONFIG_OF_BOARD_SETUP=y +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mmcblk0p1 earlycon=uart8250,mmio,0x21c0500" +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_MISC_INIT_R=y +CONFIG_CMD_TLV_EEPROM=y +CONFIG_CMD_BOOTMENU=y +CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=5 +CONFIG_CMD_DM=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_PCI=y +CONFIG_CMD_USB=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_EXT4=y +CONFIG_ENV_EXT4_INTERFACE="mmc" +CONFIG_ENV_EXT4_DEVICE_AND_PART="0:1" +CONFIG_ENV_EXT4_FILE="/boot/uboot.env" +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_USE_ETHPRIME=y +CONFIG_ETHPRIME="fm1-mac3" +CONFIG_FSL_CAAM=y +CONFIG_MPC8XXX_GPIO=y +CONFIG_DM_I2C=y +CONFIG_I2C_SET_DEFAULT_BUS_NUM=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y +CONFIG_I2C_EEPROM=y +CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_SPI_NAND=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_PHYLIB=y +CONFIG_PHY_REALTEK=y +CONFIG_PHY_FIXED=y +CONFIG_DM_MDIO=y +CONFIG_PHY_GIGE=y +CONFIG_E1000=y +CONFIG_FMAN_ENET=y +CONFIG_SYS_FMAN_FW_ADDR=0x900000 +CONFIG_NVME_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE_RC=y +CONFIG_SYS_QE_FMAN_FW_IN_MMC=y +CONFIG_DM_SCSI=y +CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_DM_SERIAL=y +CONFIG_SYS_NS16550=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_FSL_QSPI=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y diff --git a/configs/whle_ls1046a_qspi_defconfig b/configs/whle_ls1046a_qspi_defconfig new file mode 100644 index 000000000000..7d6a6ba50eaf --- /dev/null +++ b/configs/whle_ls1046a_qspi_defconfig @@ -0,0 +1,84 @@ +CONFIG_ARM=y +CONFIG_COUNTER_FREQUENCY=25000000 +CONFIG_TARGET_WHLE_LS1046A=y +CONFIG_TFABOOT=y +CONFIG_TEXT_BASE=0x82000000 +CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x900000 +CONFIG_ENV_SECT_SIZE=0x1000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-whle" +CONFIG_QSPI_AHB_INIT=y +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y +CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_PCI=y +CONFIG_AHCI=y +CONFIG_MP=y +CONFIG_FIT_VERBOSE=y +CONFIG_BOOTSTD_FULL=y +CONFIG_BOOTSTD_DEFAULTS=y +CONFIG_BOOTSTD_BOOTCOMMAND=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_BOOTDELAY=10 +CONFIG_OF_BOARD_SETUP=y +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mmcblk0p1 earlycon=uart8250,mmio,0x21c0500" +CONFIG_BOOTCOMMAND="sf probe; mtd read dtb $fdt_addr_r; bootflow scan -lb" +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_MISC_INIT_R=y +CONFIG_CMD_TLV_EEPROM=y +CONFIG_CMD_BOOTMENU=y +CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=5 +CONFIG_CMD_DM=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_PCI=y +CONFIG_CMD_USB=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_SECT_SIZE_AUTO=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_USE_ETHPRIME=y +CONFIG_ETHPRIME="fm1-mac3" +CONFIG_FSL_CAAM=y +CONFIG_MPC8XXX_GPIO=y +CONFIG_DM_I2C=y +CONFIG_I2C_SET_DEFAULT_BUS_NUM=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y +CONFIG_I2C_EEPROM=y +CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_SPI_NAND=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_PHYLIB=y +CONFIG_PHY_REALTEK=y +CONFIG_PHY_FIXED=y +CONFIG_DM_MDIO=y +CONFIG_PHY_GIGE=y +CONFIG_E1000=y +CONFIG_FMAN_ENET=y +CONFIG_SYS_FMAN_FW_ADDR=0x910000 +CONFIG_NVME_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE_RC=y +CONFIG_SYS_QE_FMAN_FW_IN_SPIFLASH=y +CONFIG_DM_SCSI=y +CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_DM_SERIAL=y +CONFIG_SYS_NS16550=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_FSL_QSPI=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y diff --git a/include/configs/whle_ls1046a.h b/include/configs/whle_ls1046a.h new file mode 100644 index 000000000000..597d1b274940 --- /dev/null +++ b/include/configs/whle_ls1046a.h @@ -0,0 +1,47 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019-2020 NXP + * Copyright 2020-2023 Conclusive Engineering Sp. z o. o. + */ + +#ifndef __WHLE_LS1046A_H__ +#define __WHLE_LS1046A_H__ + +#include <asm/arch/config.h> +#include <asm/arch/stream_id_lsch2.h> +#include <asm/arch/soc.h> + +#define CFG_SYS_UBOOT_BASE 0x40100000 +#define CFG_SYS_DDR_SDRAM_BASE 0x80000000 +#define CFG_SYS_SDRAM_BASE CFG_SYS_DDR_SDRAM_BASE +#define CFG_SYS_FSL_DDR_SDRAM_BASE_PHY 0 +#define CFG_SYS_DDR_BLOCK2_BASE 0x880000000ULL +#define CPU_RELEASE_ADDR secondary_boot_addr + +/* Serial Port */ +#define CFG_SYS_NS16550_CLK (get_serial_clock()) + +/* Miscellaneous configurable options */ +#define HWCONFIG_BUFFER_SIZE 128 + +/* I2C bus multiplexer */ +#define I2C_MUX_PCA_ADDR_PRI 0x77 /* Primary Mux*/ +#define I2C_MUX_CH_DEFAULT 0x1 /* Channel 0*/ + +/* RTC */ +#define RTC +#define CFG_SYS_I2C_RTC_ADDR 0x51 /* Channel 0 I2C bus 0*/ +#define CFG_SYS_RTC_BUS_NUM 0 + +/* FMan */ +#ifdef CONFIG_FMAN_ENET +#define CFG_SYS_FM_MURAM_SIZE 0x60000 +#define FDT_SEQ_MACADDR_FROM_ENV +#endif + +/* TF-A */ +#define QSPI_NOR_BOOTCOMMAND CONFIG_BOOTCOMMAND +#define QSPI_NAND_BOOTCOMMAND CONFIG_BOOTCOMMAND +#define SD_BOOTCOMMAND CONFIG_BOOTCOMMAND + +#endif /* __WHLE_LS1046A_H__ */
Artur Rojek
