[PATCH 0/2] arm: mvebu: clearfog: support additional ddr
This series adds support for additional memory configuration that were been produced in the past - most notably a dual-channel configuration with two 512MB modules.
Josua Mayer (2): arm: mvebu: clearfog: read number of ddr channels from tlv data arm: mvebu: clearfog: support 512MB memory size from tlv eeprom
board/solidrun/clearfog/clearfog.c | 17 ++++++++++++++++- board/solidrun/common/tlv_data.c | 7 ++++++- board/solidrun/common/tlv_data.h | 1 + 3 files changed, 23 insertions(+), 2 deletions(-)
Extend the existing tlv vendor extension used for ram size by one byte to also store the number of ddr channels. The length of the tlv entry can indicate whether the new information is present. If not default to single channel.
Signed-off-by: Josua Mayer josua@solid-run.com --- board/solidrun/clearfog/clearfog.c | 14 +++++++++++++- board/solidrun/common/tlv_data.c | 7 ++++++- board/solidrun/common/tlv_data.h | 1 + 3 files changed, 20 insertions(+), 2 deletions(-)
diff --git a/board/solidrun/clearfog/clearfog.c b/board/solidrun/clearfog/clearfog.c index 6edb4221551..4f4532b537e 100644 --- a/board/solidrun/clearfog/clearfog.c +++ b/board/solidrun/clearfog/clearfog.c @@ -36,7 +36,7 @@ DECLARE_GLOBAL_DATA_PTR; #define BOARD_GPP_POL_LOW 0x0 #define BOARD_GPP_POL_MID 0x0
-static struct tlv_data cf_tlv_data; +static struct tlv_data cf_tlv_data = { 0 };
static void cf_read_tlv_data(void) { @@ -168,6 +168,18 @@ struct mv_ddr_topology_map *mv_ddr_topology_map_get(void) break; }
+ switch (cf_tlv_data.ram_channels) { + default: + case 1: + for (uint8_t i = 0; i < 5; i++) + ifp->as_bus_params[i].cs_bitmask = 0x1; + break; + case 2: + for (uint8_t i = 0; i < 5; i++) + ifp->as_bus_params[i].cs_bitmask = 0x3; + break; + } + /* Return the board topology as defined in the board code */ return &board_topology_map; } diff --git a/board/solidrun/common/tlv_data.c b/board/solidrun/common/tlv_data.c index 11d6e4a1380..cf5824886c3 100644 --- a/board/solidrun/common/tlv_data.c +++ b/board/solidrun/common/tlv_data.c @@ -45,9 +45,14 @@ static void parse_tlv_vendor_ext(struct tlvinfo_tlv *tlv_entry,
if (val[4] != SR_TLV_CODE_RAM_SIZE) return; - if (tlv_entry->length != 6) + if (tlv_entry->length < 6) return; td->ram_size = val[5]; + + /* extension with additional data field for number of ddr channels */ + if (tlv_entry->length >= 7) { + td->ram_channels = val[6]; + } }
static void parse_tlv_data(u8 *eeprom, struct tlvinfo_header *hdr, diff --git a/board/solidrun/common/tlv_data.h b/board/solidrun/common/tlv_data.h index a1432e4b8e1..be3f782ac4a 100644 --- a/board/solidrun/common/tlv_data.h +++ b/board/solidrun/common/tlv_data.h @@ -10,6 +10,7 @@ struct tlv_data { /* Store product name of both SOM and carrier */ char tlv_product_name[2][32]; unsigned int ram_size; + uint8_t ram_channels; };
void read_tlv_data(struct tlv_data *td);
Thanks, Stefan
- switch (cf_tlv_data.ram_channels) {
- default:
- case 1:
break;
- case 2:
break;
- /* Return the board topology as defined in the board code */ return &board_topology_map; }
Viele Grüße, Stefan Roese
Applied to u-boot-marvell/master
Thanks, Stefan
Thanks, Stefan
diff --git a/board/solidrun/clearfog/clearfog.c b/board/solidrun/clearfog/clearfog.c index 6edb4221551..4f4532b537e 100644 --- a/board/solidrun/clearfog/clearfog.c +++ b/board/solidrun/clearfog/clearfog.c @@ -36,7 +36,7 @@ DECLARE_GLOBAL_DATA_PTR; #define BOARD_GPP_POL_LOW 0x0 #define BOARD_GPP_POL_MID 0x0 -static struct tlv_data cf_tlv_data; +static struct tlv_data cf_tlv_data = { 0 }; static void cf_read_tlv_data(void) { @@ -168,6 +168,18 @@ struct mv_ddr_topology_map *mv_ddr_topology_map_get(void) break; } + switch (cf_tlv_data.ram_channels) { + default: + case 1: + for (uint8_t i = 0; i < 5; i++) + ifp->as_bus_params[i].cs_bitmask = 0x1; + break; + case 2: + for (uint8_t i = 0; i < 5; i++) + ifp->as_bus_params[i].cs_bitmask = 0x3; + break; + }
/* Return the board topology as defined in the board code */ return &board_topology_map; } diff --git a/board/solidrun/common/tlv_data.c b/board/solidrun/common/tlv_data.c index 11d6e4a1380..cf5824886c3 100644 --- a/board/solidrun/common/tlv_data.c +++ b/board/solidrun/common/tlv_data.c @@ -45,9 +45,14 @@ static void parse_tlv_vendor_ext(struct tlvinfo_tlv *tlv_entry, if (val[4] != SR_TLV_CODE_RAM_SIZE) return; - if (tlv_entry->length != 6) + if (tlv_entry->length < 6) return; td->ram_size = val[5];
+ /* extension with additional data field for number of ddr channels */ + if (tlv_entry->length >= 7) { + td->ram_channels = val[6]; + } } static void parse_tlv_data(u8 *eeprom, struct tlvinfo_header *hdr, diff --git a/board/solidrun/common/tlv_data.h b/board/solidrun/common/tlv_data.h index a1432e4b8e1..be3f782ac4a 100644 --- a/board/solidrun/common/tlv_data.h +++ b/board/solidrun/common/tlv_data.h @@ -10,6 +10,7 @@ struct tlv_data { /* Store product name of both SOM and carrier */ char tlv_product_name[2][32]; unsigned int ram_size; + uint8_t ram_channels; }; void read_tlv_data(struct tlv_data *td);
Handle 2GBit memory size value "2" from tlv eeprom on ddr initialisation, to support SoMs with 512MB ddr memory.
Signed-off-by: Josua Mayer josua@solid-run.com --- board/solidrun/clearfog/clearfog.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/board/solidrun/clearfog/clearfog.c b/board/solidrun/clearfog/clearfog.c index 4f4532b537e..6fa2fe5fe3e 100644 --- a/board/solidrun/clearfog/clearfog.c +++ b/board/solidrun/clearfog/clearfog.c @@ -159,6 +159,9 @@ struct mv_ddr_topology_map *mv_ddr_topology_map_get(void) cf_read_tlv_data();
switch (cf_tlv_data.ram_size) { + case 2: + ifp->memory_size = MV_DDR_DIE_CAP_2GBIT; + break; case 4: default: ifp->memory_size = MV_DDR_DIE_CAP_4GBIT;
Thanks, Stefan
- case 2:
case 4: default: ifp->memory_size = MV_DDR_DIE_CAP_4GBIT;break;
Thanks, Stefan
Thanks, Stefan
diff --git a/board/solidrun/clearfog/clearfog.c b/board/solidrun/clearfog/clearfog.c index 4f4532b537e..6fa2fe5fe3e 100644 --- a/board/solidrun/clearfog/clearfog.c +++ b/board/solidrun/clearfog/clearfog.c @@ -159,6 +159,9 @@ struct mv_ddr_topology_map *mv_ddr_topology_map_get(void) cf_read_tlv_data(); switch (cf_tlv_data.ram_size) { + case 2: + ifp->memory_size = MV_DDR_DIE_CAP_2GBIT; + break; case 4: default: ifp->memory_size = MV_DDR_DIE_CAP_4GBIT;
Josua Mayer
Stefan Roese
