[U-Boot] [PATCH] Revert "mmc: fsl_esdhc: fix sd/mmc ddr mode clock setting issue"
This reverts commit 72a89e0da5ac6a4ab929b15a2b656f04f50767f6, which causes the imx53 HSC to hang as the eMMC is not working properly anymore.
The exact error message: MMC write: dev # 0, block # 2, count 927 ... mmc write failed 0 blocks written: ERROR
imx53 is not using the DDR mode.
Debugging of pre_div and div generation showed that those values are generated in a way, which is not matching the ones from working setup.
As the original patch was performing code refactoring, let's revert this change, so all imx53 boards would work again.
Signed-off-by: Lukasz Majewski lukma@denx.de --- drivers/mmc/fsl_esdhc.c | 23 +++++------------------ 1 file changed, 5 insertions(+), 18 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 1b7de74a72..377b2673a3 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -621,31 +621,18 @@ static void set_sysctl(struct fsl_esdhc_priv *priv, struct mmc *mmc, uint clock) #else int pre_div = 2; #endif + int ddr_pre_div = mmc->ddr_mode ? 2 : 1; int sdhc_clk = priv->sdhc_clk; uint clk;
- /* - * For ddr mode, usdhc need to enable DDR mode first, after select - * this DDR mode, usdhc will automatically divide the usdhc clock - */ - if (mmc->ddr_mode) { - writel(readl(®s->mixctrl) | MIX_CTRL_DDREN, ®s->mixctrl); - sdhc_clk >>= 1; - } - if (clock < mmc->cfg->f_min) clock = mmc->cfg->f_min;
- if (sdhc_clk / 16 > clock) { - for (; pre_div < 256; pre_div *= 2) - if ((sdhc_clk / pre_div) <= (clock * 16)) - break; - } else - pre_div = 1; + while (sdhc_clk / (16 * pre_div * ddr_pre_div) > clock && pre_div < 256) + pre_div *= 2;
- for (div = 1; div <= 16; div++) - if ((sdhc_clk / (div * pre_div)) <= clock) - break; + while (sdhc_clk / (div * pre_div * ddr_pre_div) > clock && div < 16) + div++;
pre_div >>= 1; div -= 1;
Hi Lukasz,
Subject: [PATCH] Revert "mmc: fsl_esdhc: fix sd/mmc ddr mode clock setting issue"
Could you share what is the clock value for your board?
Thanks, Peng.
- int ddr_pre_div = mmc->ddr_mode ? 2 : 1; int sdhc_clk = priv->sdhc_clk; uint clk;
sdhc_clk >>= 1;
break;
} else
pre_div = 1;
- while (sdhc_clk / (16 * pre_div * ddr_pre_div) > clock && pre_div < 256)
pre_div *= 2;
break;
div++;
-- 2.11.0
Hi Peng,
Hi Lukasz,
Sure, no problem:
Working setup: --------------
MMC: set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 pre_div: 8 div: 12 set_sysctl: clk: 2240 FSL_SDHC: 0 Loading Environment from MMC... set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 pre_div: 8 div: 12 set_sysctl: clk: 2240
set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 pre_div: 1 div: 1 set_sysctl: clk: 272
set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 pre_div: 1 div: 0 set_sysctl: clk: 256
Broken: ------- MMC: set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 pre_div: 8 div: 12 set_sysctl: clk: 2240 FSL_SDHC: 0 Loading Environment from MMC... set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 pre_div: 8 div: 12 set_sysctl: clk: 2240
set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 pre_div: 0 div: 3 set_sysctl: clk: 48
set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 pre_div: 0 div: 1 set_sysctl: clk: 16
(Please also find attached patch to reproduce debug output).
Thanks, Peng.
after select
usdhc clock
®s->mixctrl);
sdhc_clk >>= 1;
break;
} else
pre_div = 1;
pre_div < 256)
pre_div *= 2;
break;
- while (sdhc_clk / (div * pre_div * ddr_pre_div) > clock &&
div < 16)
div++;
-- 2.11.0
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
On Wed, 8 May 2019 08:19:45 +0200 Lukasz Majewski lukma@denx.de wrote:
Hi Peng,
Hi Lukasz,
Sure, no problem:
Working setup:
Broken:
And maybe the most important question - why it was necessary to refactor this code?
Parts responsible for calculating pre_div and div seems not related to ddr problem (one spot issue is div <= 16 , but in the original code it was div < 16)?
Thanks, Peng.
after select
usdhc clock
®s->mixctrl);
sdhc_clk >>= 1;
break;
} else
pre_div = 1;
pre_div < 256)
pre_div *= 2;
break;
&& div < 16)
div++;
-- 2.11.0
Lukasz Majewski
Lukasz Majewski
Subject: Re: [PATCH] Revert "mmc: fsl_esdhc: fix sd/mmc ddr mode clock setting issue"
Hi Peng,
Hi Lukasz,
Sure, no problem:
Working setup:
Broken:
This patch is mostly to support HS400 DDR_EN mode, But after I check more, seems it is not a right fix, sorry for this regression.
It does almost the same calculation as before code expect writel(readl(®s->mixctrl) | MIX_CTRL_DDREN, ®s->mixctrl);
and one condition break others.
So the fix for you is diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 1b7de74a72..3347fbe738 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -640,8 +640,7 @@ static void set_sysctl(struct fsl_esdhc_priv *priv, struct mmc *mmc, uint clock) for (; pre_div < 256; pre_div *= 2) if ((sdhc_clk / pre_div) <= (clock * 16)) break; - } else - pre_div = 1; + }
for (div = 1; div <= 16; div++) if ((sdhc_clk / (div * pre_div)) <= clock)
With this patch, the i.MX8 HS400 will work at 100MHz not 200MHz, But it not hang anyway. To fix the i.MX8, need define ARCH_MXC, I'll add a new patch for ARCH_MXC part for i.MX family.
Regards, Peng.
Thanks, Peng.
after select
usdhc clock
®s->mixctrl);
sdhc_clk >>= 1;
break;
} else
pre_div = 1;
pre_div < 256)
pre_div *= 2;
break;
&& div < 16)
div++;
-- 2.11.0
Lukasz Majewski
Denk
Lukasz Majewski
Hi Peng,
Hi Peng,
Hi Lukasz,
Sure, no problem:
Working setup:
Broken:
} else
pre_div = 1;
} for (div = 1; div <= 16; div++) if ((sdhc_clk / (div * pre_div)) <= clock)
Thanks for the explanation.
I'm just wondering if we shall revert the original patch and wait for proper fix for IMX8 or will you prepare a separate patch to fix the current mainline (so the "revert" patch can be dropped) ?
Regards, Peng.
Thanks, Peng.
after select
usdhc clock
sdhc_clk >>= 1;
16))
break;
- } else
pre_div = 1;
pre_div *= 2;
break;
clock && div < 16)
div++;
-- 2.11.0
Lukasz Majewski
Denk
Lukasz Majewski
Lukasz Majewski
-----Original Message----- From: Lukasz Majewski [mailto:lukma@denx.de] Sent: 2019年5月8日 19:38 To: Peng Fan peng.fan@nxp.com Cc: u-boot@lists.denx.de; Tom Rini trini@konsulko.com; Marcel Ziswiler marcel.ziswiler@toradex.com; Fabio Estevam fabio.estevam@nxp.com; dl-uboot-imx uboot-imx@nxp.com; sbabic@denx.de; Stefan Agner stefan.agner@toradex.com; BOUGH CHEN haibo.chen@nxp.com; Ye Li ye.li@nxp.com Subject: Re: [PATCH] Revert "mmc: fsl_esdhc: fix sd/mmc ddr mode clock setting issue"
Hi Peng,
Hi Peng,
Hi Lukasz,
Sure, no problem:
Working setup:
Broken:
} else
pre_div = 1;
When we add the patch, we do not take the i.mx53 case into consideration. Sorry for this mistake. I prefer add a fix patch rather than 'revert', because I notice there is a claim in the RM:
If setting SDCLKFS and DVS can generate same clock frequency,(For example, in SDR mode, SDCLKFS = 01h is same as DVS = 01h.) SDCLKFS is highly recommended.
For both these methods, the current one or the previous one, the code prefer DVS rather than SDCLKFS, not align with the RM suggestion. So this time I plan to re-write the code to follow the RM suggestion. I will send a patch these week.
Regards, Bough Chen
Regards, Peng.
Thanks, Peng.
after select
usdhc clock
sdhc_clk >>= 1;
16))
break;
- } else
pre_div = 1;
pre_div *= 2;
break;
clock && div < 16)
div++;
-- 2.11.0
Lukasz Majewski
Denk
Lukasz Majewski
Lukasz Majewski
Hi Peng,
Hi Peng,
Hi Lukasz,
> Subject: [PATCH] Revert "mmc: fsl_esdhc: fix sd/mmc ddr > mode clock setting issue" > > This reverts commit > 72a89e0da5ac6a4ab929b15a2b656f04f50767f6, which causes > the imx53 HSC to hang as the eMMC is not working properly > anymore. > > The exact error message: > MMC write: dev # 0, block # 2, count 927 ... mmc write > failed 0 blocks written: ERROR > > imx53 is not using the DDR mode. > > Debugging of pre_div and div generation showed that those > values are generated in a way, which is not matching the > ones from working setup. > > As the original patch was performing code refactoring, > let's revert this change, so all imx53 boards would work > again.
Sure, no problem:
Working setup:
Broken:
} else
pre_div = 1;
Ok. Thanks for the update.
I'm looking forward to test your patch.
Regards, Bough Chen
Regards, Peng.
Thanks, Peng.
> > Signed-off-by: Lukasz Majewski lukma@denx.de > --- > drivers/mmc/fsl_esdhc.c | 23 +++++------------------ > 1 file changed, 5 insertions(+), 18 deletions(-) > > diff --git a/drivers/mmc/fsl_esdhc.c > b/drivers/mmc/fsl_esdhc.c index 1b7de74a72..377b2673a3 > 100644 --- a/drivers/mmc/fsl_esdhc.c > +++ b/drivers/mmc/fsl_esdhc.c > @@ -621,31 +621,18 @@ static void set_sysctl(struct > fsl_esdhc_priv *priv, struct mmc *mmc, uint clock) #else > int pre_div = 2; > #endif > + int ddr_pre_div = mmc->ddr_mode ? 2 : 1; > int sdhc_clk = priv->sdhc_clk; > uint clk; > > - /* > - * For ddr mode, usdhc need to enable DDR mode > first, after select > - * this DDR mode, usdhc will automatically > divide the usdhc clock > - */ > - if (mmc->ddr_mode) { > - writel(readl(®s->mixctrl) | > MIX_CTRL_DDREN, ®s->mixctrl); > - sdhc_clk >>= 1; > - } > - > if (clock < mmc->cfg->f_min) > clock = mmc->cfg->f_min; > > - if (sdhc_clk / 16 > clock) { > - for (; pre_div < 256; pre_div *= 2) > - if ((sdhc_clk / pre_div) <= > (clock * 16)) > - break; > - } else > - pre_div = 1; > + while (sdhc_clk / (16 * pre_div * ddr_pre_div) > > clock && pre_div < 256) > + pre_div *= 2; > > - for (div = 1; div <= 16; div++) > - if ((sdhc_clk / (div * pre_div)) <= > clock) > - break; > + while (sdhc_clk / (div * pre_div * ddr_pre_div) > > clock && div < 16) > + div++; > > pre_div >>= 1; > div -= 1; > -- > 2.11.0
Lukasz Majewski
Denk
Lukasz Majewski
Lukasz Majewski
Lukasz Majewski
-----Original Message----- From: Lukasz Majewski [mailto:lukma@denx.de] Sent: 2019年5月8日 14:38 To: Peng Fan peng.fan@nxp.com Cc: u-boot@lists.denx.de; Tom Rini trini@konsulko.com; Marcel Ziswiler marcel.ziswiler@toradex.com; Fabio Estevam fabio.estevam@nxp.com; dl-uboot-imx uboot-imx@nxp.com; sbabic@denx.de; Stefan Agner stefan.agner@toradex.com; BOUGH CHEN haibo.chen@nxp.com; Ye Li ye.li@nxp.com Subject: Re: [PATCH] Revert "mmc: fsl_esdhc: fix sd/mmc ddr mode clock setting issue"
Hi Peng,
Hi Lukasz,
Sure, no problem:
Working setup:
Broken:
Could you help verify whether the patch fixes you issue?
Thanks, Peng.
Thanks, Peng.
after select
usdhc clock
®s->mixctrl);
sdhc_clk >>= 1;
break;
} else
pre_div = 1;
pre_div < 256)
pre_div *= 2;
break;
&& div < 16)
div++;
-- 2.11.0
Lukasz Majewski
Denk
Lukasz Majewski
Hi Peng,
Hi Lukasz,
Sure, no problem:
Working setup:
Broken:
} else
pre_div = 1;
Please examine this code thoroughly and provide patch.
The } else pre_div = 1;
was added there for a purpose, so I'm wondering why it can be easily removed now.
As I've stated above - is the above for() correct?
In the original code it was div < 16, but here it is div <= 16.
Thanks, Peng.
Thanks, Peng.
after select
usdhc clock
sdhc_clk >>= 1;
16))
break;
- } else
pre_div = 1;
pre_div *= 2;
break;
clock && div < 16)
div++;
-- 2.11.0
Lukasz Majewski
Denk
Lukasz Majewski
Lukasz Majewski
CHEN
Hi Peng,
Hi Lukasz,
This reverts commit
Sure, no problem:
Working setup:
Broken:
} else
pre_div = 1;
The pre_div should not override the initialization value at the beginning of the function.
The else was wrongly added. It is not correct.
Checking i.MX53 SDHC DVS, it supports [1,16], so should use "<=16", other i.MX has same.
Divisor: This register is used to provide a more exact divisor to generate the desired SD clock frequency. NOTE: The divider can even support odd divisor without deterioration of duty cycle. The setting are as following: 0x0 Divisor by 1 0x1 Divisor by 2 0xe Divisor by 15 0xf Divisor by 16
Regards, Peng.
Thanks, Peng.
Thanks, Peng.
after select
usdhc clock
sdhc_clk >>= 1;
16))
break;
- } else
pre_div = 1;
pre_div *= 2;
break;
clock && div < 16)
div++;
-- 2.11.0
Lukasz Majewski
Denk
Lukasz Majewski
Lukasz Majewski
Subject: RE: [PATCH] Revert "mmc: fsl_esdhc: fix sd/mmc ddr mode clock setting issue"
CHEN
Hi Peng,
Hi Lukasz,
> Subject: [PATCH] Revert "mmc: fsl_esdhc: fix sd/mmc ddr mode > clock setting issue" > > This reverts commit
> which causes the imx53 HSC to hang as the eMMC is not > working properly anymore. > > The exact error message: > MMC write: dev # 0, block # 2, count 927 ... mmc write > failed > 0 blocks written: ERROR > > imx53 is not using the DDR mode. > > Debugging of pre_div and div generation showed that those > values are generated in a way, which is not matching the > ones from working setup. > > As the original patch was performing code refactoring, let's > revert this change, so all imx53 boards would work again.
Sure, no problem:
Working setup:
Broken:
} else
pre_div = 1;
Should use "<16". Will pick up your revert to avoid regression.
Thanks, Peng.
Regards, Peng.
Thanks, Peng.
Thanks, Peng.
> > Signed-off-by: Lukasz Majewski lukma@denx.de > --- > drivers/mmc/fsl_esdhc.c | 23 +++++------------------ > 1 file changed, 5 insertions(+), 18 deletions(-) > > diff --git a/drivers/mmc/fsl_esdhc.c > b/drivers/mmc/fsl_esdhc.c index 1b7de74a72..377b2673a3 > 100644 > --- a/drivers/mmc/fsl_esdhc.c > +++ b/drivers/mmc/fsl_esdhc.c > @@ -621,31 +621,18 @@ static void set_sysctl(struct > fsl_esdhc_priv *priv, struct mmc *mmc, uint clock) #else > int pre_div = 2; > #endif > + int ddr_pre_div = mmc->ddr_mode ? 2 : 1; > int sdhc_clk = priv->sdhc_clk; > uint clk; > > - /* > - * For ddr mode, usdhc need to enable DDR mode first, > after select > - * this DDR mode, usdhc will automatically divide the > usdhc clock > - */ > - if (mmc->ddr_mode) { > - writel(readl(®s->mixctrl) | > MIX_CTRL_DDREN, ®s->mixctrl); > - sdhc_clk >>= 1; > - } > - > if (clock < mmc->cfg->f_min) > clock = mmc->cfg->f_min; > > - if (sdhc_clk / 16 > clock) { > - for (; pre_div < 256; pre_div *= 2) > - if ((sdhc_clk / pre_div) <= (clock * > 16)) > - break; > - } else > - pre_div = 1; > + while (sdhc_clk / (16 * pre_div * ddr_pre_div) > > clock && pre_div < 256) > + pre_div *= 2; > > - for (div = 1; div <= 16; div++) > - if ((sdhc_clk / (div * pre_div)) <= clock) > - break; > + while (sdhc_clk / (div * pre_div * ddr_pre_div) > > clock && div < 16) > + div++; > > pre_div >>= 1; > div -= 1; > -- > 2.11.0
Lukasz Majewski
Wolfgang
Denk
Email:
lukma@denx.de
Lukasz Majewski
Lukasz Majewski
Denk
Hi Lukasz,
Do you expect me to pick this patch, just see this patch was delegated to Stefano?
Regards, Peng.
CHEN
Hi Peng,
> Hi Lukasz, > > > Subject: [PATCH] Revert "mmc: fsl_esdhc: fix sd/mmc ddr > > mode clock setting issue" > > > > This reverts commit
> > which causes the imx53 HSC to hang as the eMMC is not > > working properly anymore. > > > > The exact error message: > > MMC write: dev # 0, block # 2, count 927 ... mmc write > > failed > > 0 blocks written: ERROR > > > > imx53 is not using the DDR mode. > > > > Debugging of pre_div and div generation showed that those > > values are generated in a way, which is not matching the > > ones from working setup. > > > > As the original patch was performing code refactoring, > > let's revert this change, so all imx53 boards would work again. > > Could you share what is the clock value for your board?
Sure, no problem:
Working setup:
Broken:
} else
pre_div = 1;
Thanks, Peng.
Regards, Peng.
Thanks, Peng.
> > Thanks, > Peng. > > > > > Signed-off-by: Lukasz Majewski lukma@denx.de > > --- > > drivers/mmc/fsl_esdhc.c | 23 +++++------------------ > > 1 file changed, 5 insertions(+), 18 deletions(-) > > > > diff --git a/drivers/mmc/fsl_esdhc.c > > b/drivers/mmc/fsl_esdhc.c index 1b7de74a72..377b2673a3 > > 100644 > > --- a/drivers/mmc/fsl_esdhc.c > > +++ b/drivers/mmc/fsl_esdhc.c > > @@ -621,31 +621,18 @@ static void set_sysctl(struct > > fsl_esdhc_priv *priv, struct mmc *mmc, uint clock) #else > > int pre_div = 2; > > #endif > > + int ddr_pre_div = mmc->ddr_mode ? 2 : 1; > > int sdhc_clk = priv->sdhc_clk; > > uint clk; > > > > - /* > > - * For ddr mode, usdhc need to enable DDR mode first, > > after select > > - * this DDR mode, usdhc will automatically divide the > > usdhc clock > > - */ > > - if (mmc->ddr_mode) { > > - writel(readl(®s->mixctrl) | > > MIX_CTRL_DDREN, ®s->mixctrl); > > - sdhc_clk >>= 1; > > - } > > - > > if (clock < mmc->cfg->f_min) > > clock = mmc->cfg->f_min; > > > > - if (sdhc_clk / 16 > clock) { > > - for (; pre_div < 256; pre_div *= 2) > > - if ((sdhc_clk / pre_div) <= (clock * > > 16)) > > - break; > > - } else > > - pre_div = 1; > > + while (sdhc_clk / (16 * pre_div * ddr_pre_div) > > > clock && pre_div < 256) > > + pre_div *= 2; > > > > - for (div = 1; div <= 16; div++) > > - if ((sdhc_clk / (div * pre_div)) <= clock) > > - break; > > + while (sdhc_clk / (div * pre_div * ddr_pre_div) > > > clock && div < 16) > > + div++; > > > > pre_div >>= 1; > > div -= 1; > > -- > > 2.11.0 >
Lukasz Majewski
Wolfgang
Denk
Email:
lukma@denx.de
Lukasz Majewski
Wolfgang
lukma@denx.de
Lukasz Majewski
Denk
Hi Peng,
Hi Lukasz,
I think that you shall decide with Stefano who would take this patch.
For me there is no difference, I would just like to have it in main line ASAP (depends who prepare PR first).
Regards, Peng.
CHEN
> Hi Peng, > > > Hi Lukasz, > > > > > Subject: [PATCH] Revert "mmc: fsl_esdhc: fix sd/mmc > > > ddr mode clock setting issue" > > > > > > This reverts commit
> > > which causes the imx53 HSC to hang as the eMMC is not > > > working properly anymore. > > > > > > The exact error message: > > > MMC write: dev # 0, block # 2, count 927 ... mmc write > > > failed > > > 0 blocks written: ERROR > > > > > > imx53 is not using the DDR mode. > > > > > > Debugging of pre_div and div generation showed that > > > those values are generated in a way, which is not > > > matching the ones from working setup. > > > > > > As the original patch was performing code refactoring, > > > let's revert this change, so all imx53 boards would > > > work again. > > > > Could you share what is the clock value for your > > board? > > Sure, no problem: > > Working setup: > -------------- > > MMC: > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > pre_div: 8 div: 12 set_sysctl: clk: 2240 > FSL_SDHC: 0 > Loading Environment from MMC... > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > pre_div: 8 div: 12 set_sysctl: clk: 2240 > > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > pre_div: 8 div: 12 set_sysctl: clk: 2240 > > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > pre_div: 1 div: 1 set_sysctl: clk: 272 > > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > pre_div: 1 div: 0 set_sysctl: clk: 256 > > > > > Broken: > ------- > MMC: > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > pre_div: 8 div: 12 set_sysctl: clk: 2240 > FSL_SDHC: 0 > Loading Environment from MMC... > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > pre_div: 8 div: 12 set_sysctl: clk: 2240 > > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > pre_div: 8 div: 12 set_sysctl: clk: 2240 > > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > pre_div: 0 div: 3 set_sysctl: clk: 48 > > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > pre_div: 0 div: 1 set_sysctl: clk: 16 > > > (Please also find attached patch to reproduce debug > output).
} else
pre_div = 1;
Thanks, Peng.
Regards, Peng.
Thanks, Peng.
> > > > Thanks, > > Peng. > > > > > > > > Signed-off-by: Lukasz Majewski lukma@denx.de > > > --- > > > drivers/mmc/fsl_esdhc.c | 23 +++++------------------ > > > 1 file changed, 5 insertions(+), 18 deletions(-) > > > > > > diff --git a/drivers/mmc/fsl_esdhc.c > > > b/drivers/mmc/fsl_esdhc.c index 1b7de74a72..377b2673a3 > > > 100644 > > > --- a/drivers/mmc/fsl_esdhc.c > > > +++ b/drivers/mmc/fsl_esdhc.c > > > @@ -621,31 +621,18 @@ static void set_sysctl(struct > > > fsl_esdhc_priv *priv, struct mmc *mmc, uint clock) > > > #else int pre_div = 2; > > > #endif > > > + int ddr_pre_div = mmc->ddr_mode ? 2 : 1; > > > int sdhc_clk = priv->sdhc_clk; > > > uint clk; > > > > > > - /* > > > - * For ddr mode, usdhc need to enable DDR > > > mode first, after select > > > - * this DDR mode, usdhc will automatically > > > divide the usdhc clock > > > - */ > > > - if (mmc->ddr_mode) { > > > - writel(readl(®s->mixctrl) | > > > MIX_CTRL_DDREN, ®s->mixctrl); > > > - sdhc_clk >>= 1; > > > - } > > > - > > > if (clock < mmc->cfg->f_min) > > > clock = mmc->cfg->f_min; > > > > > > - if (sdhc_clk / 16 > clock) { > > > - for (; pre_div < 256; pre_div *= 2) > > > - if ((sdhc_clk / pre_div) <= > > > (clock * 16)) > > > - break; > > > - } else > > > - pre_div = 1; > > > + while (sdhc_clk / (16 * pre_div * > > > ddr_pre_div) > clock && pre_div < 256) > > > + pre_div *= 2; > > > > > > - for (div = 1; div <= 16; div++) > > > - if ((sdhc_clk / (div * pre_div)) <= > > > clock) > > > - break; > > > + while (sdhc_clk / (div * pre_div * > > > ddr_pre_div) > clock && div < 16) > > > + div++; > > > > > > pre_div >>= 1; > > > div -= 1; > > > -- > > > 2.11.0 > > > > > > > Best regards, > > Lukasz Majewski > > -- > > DENX Software Engineering GmbH, Managing Director:
Wolfgang
Denk > HRB 165235 Munich, Office: Kirchenstr.5, D-82194 > Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: > (+49)-8142-66989-80
Email:
> lukma@denx.de
Lukasz Majewski
Wolfgang
lukma@denx.de
Lukasz Majewski
Denk
Lukasz Majewski
Hi Lukasz,
Hi Peng,
Hi Lukasz,
ok. I'll send a PR to Tom today after CI done. I was waiting IT to fix my ssh push issue, so delayed. I still have to use my github to PR (:
Regards, Peng.
Regards, Peng.
> -----Original Message----- > From: Lukasz Majewski [mailto:lukma@denx.de] > Sent: 2019年5月8日 14:38 > To: Peng Fan peng.fan@nxp.com > Cc: u-boot@lists.denx.de; Tom Rini trini@konsulko.com; > Marcel Ziswiler marcel.ziswiler@toradex.com; Fabio Estevam > fabio.estevam@nxp.com; dl-uboot-imx uboot-imx@nxp.com; > sbabic@denx.de; Stefan Agner stefan.agner@toradex.com; > BOUGH
CHEN
> haibo.chen@nxp.com; Ye Li ye.li@nxp.com > Subject: Re: [PATCH] Revert "mmc: fsl_esdhc: fix sd/mmc ddr > mode clock setting issue" > > On Wed, 8 May 2019 08:19:45 +0200 Lukasz Majewski > lukma@denx.de wrote: > > > Hi Peng, > > > > > Hi Lukasz, > > > > > > > Subject: [PATCH] Revert "mmc: fsl_esdhc: fix sd/mmc > > > > ddr mode clock setting issue" > > > > > > > > This reverts commit
> > > > which causes the imx53 HSC to hang as the eMMC is not > > > > working properly anymore. > > > > > > > > The exact error message: > > > > MMC write: dev # 0, block # 2, count 927 ... mmc write > > > > failed > > > > 0 blocks written: ERROR > > > > > > > > imx53 is not using the DDR mode. > > > > > > > > Debugging of pre_div and div generation showed that > > > > those values are generated in a way, which is not > > > > matching the ones from working setup. > > > > > > > > As the original patch was performing code refactoring, > > > > let's revert this change, so all imx53 boards would > > > > work again. > > > > > > Could you share what is the clock value for your board? > > > > Sure, no problem: > > > > Working setup: > > -------------- > > > > MMC: > > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > > pre_div: 8 div: 12 set_sysctl: clk: 2240 > > FSL_SDHC: 0 > > Loading Environment from MMC... > > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > > pre_div: 8 div: 12 set_sysctl: clk: 2240 > > > > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > > pre_div: 8 div: 12 set_sysctl: clk: 2240 > > > > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > > pre_div: 1 div: 1 set_sysctl: clk: 272 > > > > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > > pre_div: 1 div: 0 set_sysctl: clk: 256 > > > > > > > > > > Broken: > > ------- > > MMC: > > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > > pre_div: 8 div: 12 set_sysctl: clk: 2240 > > FSL_SDHC: 0 > > Loading Environment from MMC... > > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > > pre_div: 8 div: 12 set_sysctl: clk: 2240 > > > > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > > pre_div: 8 div: 12 set_sysctl: clk: 2240 > > > > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > > pre_div: 0 div: 3 set_sysctl: clk: 48 > > > > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > > pre_div: 0 div: 1 set_sysctl: clk: 16 > > > > > > (Please also find attached patch to reproduce debug > > output). > > And maybe the most important question - why it was necessary > to refactor this code? > > Parts responsible for calculating pre_div and div seems not > related to ddr problem (one spot issue is div <= 16 , but in > the original code it was div < 16)?
} else
pre_div = 1;
Thanks, Peng.
Regards, Peng.
Thanks, Peng.
> > > > > > > Thanks, > > > Peng. > > > > > > > > > > > Signed-off-by: Lukasz Majewski lukma@denx.de > > > > --- > > > > drivers/mmc/fsl_esdhc.c | 23 +++++------------------ > > > > 1 file changed, 5 insertions(+), 18 deletions(-) > > > > > > > > diff --git a/drivers/mmc/fsl_esdhc.c > > > > b/drivers/mmc/fsl_esdhc.c index 1b7de74a72..377b2673a3 > > > > 100644 > > > > --- a/drivers/mmc/fsl_esdhc.c > > > > +++ b/drivers/mmc/fsl_esdhc.c > > > > @@ -621,31 +621,18 @@ static void set_sysctl(struct > > > > fsl_esdhc_priv *priv, struct mmc *mmc, uint clock) > > > > #else int pre_div = 2; #endif > > > > + int ddr_pre_div = mmc->ddr_mode ? 2 : 1; > > > > int sdhc_clk = priv->sdhc_clk; > > > > uint clk; > > > > > > > > - /* > > > > - * For ddr mode, usdhc need to enable DDR > > > > mode first, after select > > > > - * this DDR mode, usdhc will automatically > > > > divide the usdhc clock > > > > - */ > > > > - if (mmc->ddr_mode) { > > > > - writel(readl(®s->mixctrl) | > > > > MIX_CTRL_DDREN, ®s->mixctrl); > > > > - sdhc_clk >>= 1; > > > > - } > > > > - > > > > if (clock < mmc->cfg->f_min) > > > > clock = mmc->cfg->f_min; > > > > > > > > - if (sdhc_clk / 16 > clock) { > > > > - for (; pre_div < 256; pre_div *= 2) > > > > - if ((sdhc_clk / pre_div) <= > > > > (clock * 16)) > > > > - break; > > > > - } else > > > > - pre_div = 1; > > > > + while (sdhc_clk / (16 * pre_div * > > > > ddr_pre_div) > clock && pre_div < 256) > > > > + pre_div *= 2; > > > > > > > > - for (div = 1; div <= 16; div++) > > > > - if ((sdhc_clk / (div * pre_div)) <= > > > > clock) > > > > - break; > > > > + while (sdhc_clk / (div * pre_div * > > > > ddr_pre_div) > clock && div < 16) > > > > + div++; > > > > > > > > pre_div >>= 1; > > > > div -= 1; > > > > -- > > > > 2.11.0 > > > > > > > > > > > > > Best regards, > > > > Lukasz Majewski > > > > -- > > > > DENX Software Engineering GmbH, Managing Director:
Wolfgang
> Denk > > HRB 165235 Munich, Office: Kirchenstr.5, D-82194 > > Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: > > (+49)-8142-66989-80
Email:
> > lukma@denx.de > > > > > Best regards, > > Lukasz Majewski > > -- > > DENX Software Engineering GmbH, Managing Director:
Wolfgang
> Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 > Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax:
> lukma@denx.de
Lukasz Majewski
Denk
Lukasz Majewski
Hi Peng,
Hi Lukasz,
Hi Peng,
Hi Lukasz,
Great. Thanks.
I do know this topic well ... (Large companies have very strict rules regarding perceiving firewalls).
Regards, Peng.
Regards, Peng.
> > -----Original Message----- > > From: Lukasz Majewski [mailto:lukma@denx.de] > > Sent: 2019年5月8日 14:38 > > To: Peng Fan peng.fan@nxp.com > > Cc: u-boot@lists.denx.de; Tom Rini trini@konsulko.com; > > Marcel Ziswiler marcel.ziswiler@toradex.com; Fabio > > Estevam fabio.estevam@nxp.com; dl-uboot-imx > > uboot-imx@nxp.com; sbabic@denx.de; Stefan Agner > > stefan.agner@toradex.com; BOUGH CHEN > > haibo.chen@nxp.com; Ye Li ye.li@nxp.com > > Subject: Re: [PATCH] Revert "mmc: fsl_esdhc: fix sd/mmc > > ddr mode clock setting issue" > > > > On Wed, 8 May 2019 08:19:45 +0200 Lukasz Majewski > > lukma@denx.de wrote: > > > > > Hi Peng, > > > > > > > Hi Lukasz, > > > > > > > > > Subject: [PATCH] Revert "mmc: fsl_esdhc: fix > > > > > sd/mmc ddr mode clock setting issue" > > > > > > > > > > This reverts commit 72a89e0da5ac6a4ab929b15a2b656f04f50767f6, > > > > > which causes the imx53 HSC to hang as the eMMC is > > > > > not working properly anymore. > > > > > > > > > > The exact error message: > > > > > MMC write: dev # 0, block # 2, count 927 ... mmc > > > > > write failed > > > > > 0 blocks written: ERROR > > > > > > > > > > imx53 is not using the DDR mode. > > > > > > > > > > Debugging of pre_div and div generation showed > > > > > that those values are generated in a way, which > > > > > is not matching the ones from working setup. > > > > > > > > > > As the original patch was performing code > > > > > refactoring, let's revert this change, so all > > > > > imx53 boards would work again. > > > > > > > > Could you share what is the clock value for your > > > > board? > > > > > > Sure, no problem: > > > > > > Working setup: > > > -------------- > > > > > > MMC: > > > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > > > pre_div: 8 div: 12 set_sysctl: clk: 2240 > > > FSL_SDHC: 0 > > > Loading Environment from MMC... > > > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > > > pre_div: 8 div: 12 set_sysctl: clk: 2240 > > > > > > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > > > pre_div: 8 div: 12 set_sysctl: clk: 2240 > > > > > > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > > > pre_div: 1 div: 1 set_sysctl: clk: 272 > > > > > > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > > > pre_div: 1 div: 0 set_sysctl: clk: 256 > > > > > > > > > > > > > > > Broken: > > > ------- > > > MMC: > > > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > > > pre_div: 8 div: 12 set_sysctl: clk: 2240 > > > FSL_SDHC: 0 > > > Loading Environment from MMC... > > > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > > > pre_div: 8 div: 12 set_sysctl: clk: 2240 > > > > > > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > > > pre_div: 8 div: 12 set_sysctl: clk: 2240 > > > > > > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > > > pre_div: 0 div: 3 set_sysctl: clk: 48 > > > > > > set_sysctl: pre_div = 2 mmc->ddr: 0 sdhc_clk: 80000000 > > > pre_div: 0 div: 1 set_sysctl: clk: 16 > > > > > > > > > (Please also find attached patch to reproduce debug > > > output). > > > > And maybe the most important question - why it was > > necessary to refactor this code? > > > > Parts responsible for calculating pre_div and div seems > > not related to ddr problem (one spot issue is div <= > > 16 , but in the original code it was div < 16)? > > Could you help verify whether the patch fixes you issue? > > index 1b7de74a72..3347fbe738 100644 > --- a/drivers/mmc/fsl_esdhc.c > +++ b/drivers/mmc/fsl_esdhc.c > @@ -640,8 +640,7 @@ static void set_sysctl(struct > fsl_esdhc_priv *priv, struct mmc *mmc, uint clock) for (; > pre_div < 256; pre_div *= > 2) if ((sdhc_clk / pre_div) <= (clock * 16)) > break; > - } else > - pre_div = 1; > + }
> > for (div = 1; div <= 16; div++) > if ((sdhc_clk / (div * pre_div)) <= clock) >
Thanks, Peng.
Regards, Peng.
> > Thanks, > Peng. > > > > > > > > > > > Thanks, > > > > Peng. > > > > > > > > > > > > > > Signed-off-by: Lukasz Majewski lukma@denx.de > > > > > --- > > > > > drivers/mmc/fsl_esdhc.c | 23 > > > > > +++++------------------ 1 file changed, 5 > > > > > insertions(+), 18 deletions(-) > > > > > > > > > > diff --git a/drivers/mmc/fsl_esdhc.c > > > > > b/drivers/mmc/fsl_esdhc.c index > > > > > 1b7de74a72..377b2673a3 100644 > > > > > --- a/drivers/mmc/fsl_esdhc.c > > > > > +++ b/drivers/mmc/fsl_esdhc.c > > > > > @@ -621,31 +621,18 @@ static void > > > > > set_sysctl(struct fsl_esdhc_priv *priv, struct > > > > > mmc *mmc, uint clock) #else int pre_div = 2; > > > > > #endif > > > > > + int ddr_pre_div = mmc->ddr_mode ? 2 : 1; > > > > > int sdhc_clk = priv->sdhc_clk; > > > > > uint clk; > > > > > > > > > > - /* > > > > > - * For ddr mode, usdhc need to enable DDR > > > > > mode first, after select > > > > > - * this DDR mode, usdhc will > > > > > automatically divide the usdhc clock > > > > > - */ > > > > > - if (mmc->ddr_mode) { > > > > > - writel(readl(®s->mixctrl) | > > > > > MIX_CTRL_DDREN, ®s->mixctrl); > > > > > - sdhc_clk >>= 1; > > > > > - } > > > > > - > > > > > if (clock < mmc->cfg->f_min) > > > > > clock = mmc->cfg->f_min; > > > > > > > > > > - if (sdhc_clk / 16 > clock) { > > > > > - for (; pre_div < 256; pre_div *= > > > > > 2) > > > > > - if ((sdhc_clk / pre_div) > > > > > <= (clock * 16)) > > > > > - break; > > > > > - } else > > > > > - pre_div = 1; > > > > > + while (sdhc_clk / (16 * pre_div * > > > > > ddr_pre_div) > clock && pre_div < 256) > > > > > + pre_div *= 2; > > > > > > > > > > - for (div = 1; div <= 16; div++) > > > > > - if ((sdhc_clk / (div * pre_div)) > > > > > <= clock) > > > > > - break; > > > > > + while (sdhc_clk / (div * pre_div * > > > > > ddr_pre_div) > clock && div < 16) > > > > > + div++; > > > > > > > > > > pre_div >>= 1; > > > > > div -= 1; > > > > > -- > > > > > 2.11.0 > > > > > > > > > > > > > > > > > > > Best regards, > > > > > > Lukasz Majewski > > > > > > -- > > > > > > DENX Software Engineering GmbH, Managing > > > Director:
Wolfgang
> > Denk > > > HRB 165235 Munich, Office: Kirchenstr.5, D-82194 > > > Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: > > > (+49)-8142-66989-80
Email:
> > > lukma@denx.de > > > > > > > > > > Best regards, > > > > Lukasz Majewski > > > > -- > > > > DENX Software Engineering GmbH, Managing > > Director:
Wolfgang
> > Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 > > Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax:
> > lukma@denx.de
Lukasz Majewski
Denk
Lukasz Majewski
Lukasz Majewski
BOUGH CHEN
Lukasz Majewski
Peng Fan
