RE: [U-Boot-Users] u-boot for MPC8266-PCI board
First off. The MPC8260ADS config files will not run on a MPC8266ADS. Most likely culprit here (Remember seeing the same thing when dd ther initial port) is that it hangs when trying to initialise the (nonexisting) 4MB og SDRAM on the local bus that the MPC8260 has, and the MPC8266 doesn't.
The reason the config file for the MPC8266ADS don't give any output is most likely because it loads at adifferent initial configuration address. (See top of include/configs/MPC8266ADS.h for details)
To get it to work the way it is; Write the whole image to the start of the FLASH (on a board with JP3 in 2-3 position this is 0xFF800000). Then set JP3 in the 1-2 position. The flash start and boot at 0xFE000000.
-----Original Message----- From: Thomas Schäfer [mailto:tschaefer@giga-stream.de] Sent: Friday, July 25, 2003 04:37 To: u-boot-users@lists.sourceforge.net Subject: [U-Boot-Users] u-boot for MPC8266-PCI board
Hi all,
I'm trying to run u-boot on our MPC8266-PCI board. I'm using the latest CVS tree 0.4.5 from sourceforge. I found MPC8260ADS.h and MPC8266ADS.h in the configs directory. Trying the MPC8266ADS configuration and starting it ends with no console output at all. Trying the MPC8260ADS configuration with CONFIG_ADSTYPE=CFG_8266ADS ends with a bus fault after some console outputs (see below). What am I doing wrong?
U-Boot 0.4.5 (Jul 25 2003 - 11:18:40)
MPC8260 Reset Status: External Soft, External Hard
MPC8260 Clock Configuration
- Bus-to-Core Mult 3x, VCO Div 2, 60x Bus Freq 33-100, Core
Freq 100-300
- dfbrg 1, corecnf 0x08, busdf 3, cpmdf 1, plldf 0, pllmf 1
- vco_out 266666664, scc_clk 66666666, brg_clk 16666666
- cpu_clk 199999998, cpm_clk 133333332, bus_clk 66666666
CPU: MPC8260 (HiP4 Rev 14, Mask A.0(A) 2K25A) at 199.999 MHz Board: Motorola MPC8266ADS I2C: ready DRAM: 16 MB FLASH: Bus Fault @ 0x00feac3c, fixup 0x00000000 Machine check in kernel mode. Caused by (from msr): regs 00f71e10 Unknown values in msr NIP: 00FEAC3C XER: 20000000 LR: 00FD6E94 REGS: 00f71e10 TRAP: 0200 DAR: 00000000MSR: 00003000 Eª: 0 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 00500092 00F71F00 04280112 00000000 00FD6E88 Bus Fault @ 0x00fe73d0, fixup 0x00000000 Machine check in kernel mode. Caused by (from msr): regs 00f71af8 Unknown values in msr NIP: 00FE73D0 XER: 00000000 LR: 00FE7360 REGS: 00f71af8 TRAP: 0200 DAR: 00000000MSR: 00003000 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 00
Any hints would be appreciated.
Thomas Schäfer
GIGA STREAM GmbH
Konrad-Zuse-Str. 7 66115 Saarbrücken
Tel.: + 49 (0)681 / 95916 - 203 Fax: + 49 (0)681 / 95916 - 100 E-mail: tschaefer@giga-stream.de
This SF.Net email sponsored by: Free pre-built ASP.NET sites including Data Reports, E-commerce, Portals, and Forums are available now. Download today and enter to win an XBOX or Visual Studio .NET. http://aspnet.click-url.com/go/psa00100003ave/direct;at.aspnet
_072303_01/01 _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Rune Torgersen
