[U-Boot] [PATCH v2 00/11] Add BF60x processor support to Blackfin architecture.
ADSP-BF60x is the new generation Blackfin® dual-core processor announced by Analog Devices in late March, 2012. This patch set adds BF60x processor support to Das U-Boot Blackfin architecture.
For more information, see http://blackfin.uclinux.org .
The v2 patches 1) fix most checkpatch issues mentioned by Wolfgang 2) remove unrelated dma structure change patch 3) replace unreable macro in dma and uart structures with normal types. 4) replace unreable macro in uart peripheral portmux configuration with clear inline function. 5) clean up and merge redundant #ifdef's 6) spearate declarations and code by a blankline 7) remove the values for variables in blackfin config headers whose values are useless 8) replace run-time variable with new macro when adding 4M byte CPLB entries.
Bob Liu (5): Blackfin: bf60x: new processor header files Blackfin: bf60x: add dma support Blackfin: bf60x: support big cplb page Blackfin: bf60x: add gpio support Blackfin: bf60x: add hw watchdog support
Scott Jiang (1): Blackfin: spi: add bf6xx spi driver
Sonic Zhang (4): Blackfin: bf60x: Port blackfin core architecture code to boot on bf60x. Blackfin: bf60x: add serial support blackfin: bf609: add board and headers files to support bf609 Blackfin: bf60x: add rsi/sdh support
Steven Miao (1): Blackfin: bf60x: add resume from hibernate
MAINTAINERS | 3 +- arch/blackfin/cpu/cpu.c | 4 +- arch/blackfin/cpu/gpio.c | 36 +- arch/blackfin/cpu/initcode.c | 385 ++- arch/blackfin/cpu/initcode.h | 52 + arch/blackfin/cpu/reset.c | 6 + arch/blackfin/cpu/serial.c | 81 +- arch/blackfin/cpu/serial.h | 222 +-- arch/blackfin/cpu/serial1.h | 338 ++ arch/blackfin/cpu/serial4.h | 159 + arch/blackfin/cpu/start.S | 2 + arch/blackfin/include/asm/blackfin_cdef.h | 3 + arch/blackfin/include/asm/blackfin_def.h | 5 + arch/blackfin/include/asm/blackfin_local.h | 3 + arch/blackfin/include/asm/config-pre.h | 4 + arch/blackfin/include/asm/cplb.h | 31 +- arch/blackfin/include/asm/dma.h | 81 +- arch/blackfin/include/asm/gpio.h | 2 +- arch/blackfin/include/asm/mach-bf533/BF531_def.h | 1 + arch/blackfin/include/asm/mach-bf561/BF561_def.h | 1 + arch/blackfin/include/asm/mach-bf609/BF609_cdef.h | 551 +++ arch/blackfin/include/asm/mach-bf609/BF609_def.h | 3758 ++++++++++++++++++++ arch/blackfin/include/asm/mach-bf609/anomaly.h | 103 + arch/blackfin/include/asm/mach-bf609/def_local.h | 5 + arch/blackfin/include/asm/mach-bf609/gpio.h | 151 + arch/blackfin/include/asm/mach-bf609/portmux.h | 257 ++ arch/blackfin/include/asm/mach-bf609/ports.h | 103 + arch/blackfin/include/asm/mach-common/bits/cgu.h | 80 + arch/blackfin/include/asm/mach-common/bits/dde.h | 88 + arch/blackfin/include/asm/mach-common/bits/dma.h | 54 +- arch/blackfin/include/asm/mach-common/bits/mpu.h | 6 +- arch/blackfin/include/asm/mach-common/bits/pll.h | 5 + arch/blackfin/include/asm/mach-common/bits/sdh.h | 38 +- .../blackfin/include/asm/mach-common/bits/spi6xx.h | 240 ++ arch/blackfin/include/asm/mach-common/bits/uart4.h | 66 + arch/blackfin/lib/board.c | 25 +- arch/blackfin/lib/clocks.c | 112 +- arch/blackfin/lib/string.c | 97 +- board/bf609-ezkit/Makefile | 55 + board/bf609-ezkit/bf609-ezkit.c | 67 + boards.cfg | 1 + common/cmd_reginfo.c | 19 +- drivers/mmc/bfin_sdh.c | 68 +- drivers/spi/Makefile | 1 + drivers/spi/bfin_spi6xx.c | 308 ++ include/configs/bf609-ezkit.h | 162 + include/configs/bfin_adi_common.h | 12 +- 47 files changed, 7455 insertions(+), 396 deletions(-) create mode 100644 arch/blackfin/cpu/serial1.h create mode 100644 arch/blackfin/cpu/serial4.h create mode 100644 arch/blackfin/include/asm/mach-bf609/BF609_cdef.h create mode 100644 arch/blackfin/include/asm/mach-bf609/BF609_def.h create mode 100644 arch/blackfin/include/asm/mach-bf609/anomaly.h create mode 100644 arch/blackfin/include/asm/mach-bf609/def_local.h create mode 100644 arch/blackfin/include/asm/mach-bf609/gpio.h create mode 100644 arch/blackfin/include/asm/mach-bf609/portmux.h create mode 100644 arch/blackfin/include/asm/mach-bf609/ports.h create mode 100644 arch/blackfin/include/asm/mach-common/bits/cgu.h create mode 100644 arch/blackfin/include/asm/mach-common/bits/dde.h create mode 100644 arch/blackfin/include/asm/mach-common/bits/spi6xx.h create mode 100644 arch/blackfin/include/asm/mach-common/bits/uart4.h create mode 100644 board/bf609-ezkit/Makefile create mode 100644 board/bf609-ezkit/bf609-ezkit.c create mode 100644 drivers/spi/bfin_spi6xx.c create mode 100644 include/configs/bf609-ezkit.h
Sonic Zhang
