[U-Boot] [PATCH] QSPI flash driver compatibility fixes for mx6ull
Avoid "SF: Timeout!" messages and generally speed up QSPI flash operations on mx6ull EVK by adding a QSPI sequence for reading "flag status register" as required for some (ST/Micron) NOR flash devices by the DM spi-flash driver.
Enable QSPI clock in EVK specific board_init function, as per other Freescale EVKs.
Tested on mcimx6ull EVK, U303 populated with a Micron MT25QL256ABA (ID reads as 'n25q256').
Cc: Peng Fan peng.fan@nxp.com Cc: Jagan Teki jagan@openedev.com Signed-off-by: Neil Stainton nstainton@asl-control.co.uk --- arch/arm/dts/imx6ull-14x14-evk.dts | 2 +- board/freescale/mx6ullevk/mx6ullevk.c | 15 +++++++++++++++ drivers/mtd/spi/spi_flash.c | 4 ++-- drivers/spi/fsl_qspi.c | 24 +++++++++++++++++++----- 4 files changed, 37 insertions(+), 8 deletions(-)
diff --git a/arch/arm/dts/imx6ull-14x14-evk.dts b/arch/arm/dts/imx6ull-14x14-evk.dts index 8a1b67d..7cb6d16 100644 --- a/arch/arm/dts/imx6ull-14x14-evk.dts +++ b/arch/arm/dts/imx6ull-14x14-evk.dts @@ -454,10 +454,10 @@ flash0: n25q256a@0 { #address-cells = <1>; #size-cells = <1>; - /* compatible = "micron,n25q256a"; */ compatible = "spi-flash"; spi-max-frequency = <29000000>; spi-nor,ddr-quad-read-dummy = <6>; + memory-map = <0x60000000 0x02000000>; reg = <0>; }; }; diff --git a/board/freescale/mx6ullevk/mx6ullevk.c b/board/freescale/mx6ullevk/mx6ullevk.c index ad83f36..46d61bc 100644 --- a/board/freescale/mx6ullevk/mx6ullevk.c +++ b/board/freescale/mx6ullevk/mx6ullevk.c @@ -58,11 +58,26 @@ int board_early_init_f(void) return 0; }
+#ifdef CONFIG_FSL_QSPI +static int board_qspi_init(void) +{ + /* Set the clock */ + enable_qspi_clk(0); + + return 0; +} +#endif /* !defined(CONFIG_FSL_QSPI) */ + int board_init(void) { /* Address of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
+#ifdef CONFIG_FSL_QSPI + /* Set the clock */ + board_qspi_init(); +#endif + return 0; }
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index c159124..c817772 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -360,7 +360,7 @@ int spi_flash_cmd_erase_ops(struct spi_flash *flash, u32 offset, size_t len) }
#ifdef CONFIG_SPI_FLASH_BAR - ret = clean_bar(flash); + clean_bar(flash); #endif
return ret; @@ -422,7 +422,7 @@ int spi_flash_cmd_write_ops(struct spi_flash *flash, u32 offset, }
return ret; diff --git a/drivers/spi/fsl_qspi.c b/drivers/spi/fsl_qspi.c index 1598c4f..07c3ade 100644 --- a/drivers/spi/fsl_qspi.c +++ b/drivers/spi/fsl_qspi.c @@ -47,10 +47,12 @@ DECLARE_GLOBAL_DATA_PTR; #endif #define SEQID_WRAR 13 #define SEQID_RDAR 14 +#define SEQID_RDFSR 15
/* QSPI CMD */ #define QSPI_CMD_PP 0x02 /* Page program (up to 256 bytes) */ #define QSPI_CMD_RDSR 0x05 /* Read status register */ +#define QSPI_CMD_RDFSR 0x70 /* Read flag status register */ #define QSPI_CMD_WREN 0x06 /* Write enable */ #define QSPI_CMD_FAST_READ 0x0b /* Read data bytes (high frequency) */ #define QSPI_CMD_BE_4K 0x20 /* 4K erase */ @@ -230,6 +232,15 @@ static void qspi_set_lut(struct fsl_qspi_priv *priv) qspi_write32(priv->flags, ®s->lut[lut_base + 2], 0); qspi_write32(priv->flags, ®s->lut[lut_base + 3], 0);
+ /* Read Flag Status */ + lut_base = SEQID_RDFSR * 4; + qspi_write32(priv->flags, ®s->lut[lut_base], OPRND0(QSPI_CMD_RDFSR) | + PAD0(LUT_PAD1) | INSTR0(LUT_CMD) | OPRND1(1) | + PAD1(LUT_PAD1) | INSTR1(LUT_READ)); + qspi_write32(priv->flags, ®s->lut[lut_base + 1], 0); + qspi_write32(priv->flags, ®s->lut[lut_base + 2], 0); + qspi_write32(priv->flags, ®s->lut[lut_base + 3], 0); + /* Erase a sector */ lut_base = SEQID_SE * 4; #ifdef CONFIG_SPI_FLASH_BAR @@ -698,7 +709,7 @@ static void qspi_op_write(struct fsl_qspi_priv *priv, u8 *txbuf, u32 len) qspi_write32(priv->flags, ®s->mcr, mcr_reg); }
-static void qspi_op_rdsr(struct fsl_qspi_priv *priv, void *rxbuf, u32 len) +static void qspi_op_rdsr(struct fsl_qspi_priv *priv, void *rxbuf, u32 len, u8 seqid) { struct fsl_qspi_regs *regs = priv->regs; u32 mcr_reg, reg, data; @@ -712,7 +723,7 @@ static void qspi_op_rdsr(struct fsl_qspi_priv *priv, void *rxbuf, u32 len) qspi_write32(priv->flags, ®s->sfar, priv->cur_amba_base);
qspi_write32(priv->flags, ®s->ipcr, - (SEQID_RDSR << QSPI_IPCR_SEQID_SHIFT) | 0); + (seqid << QSPI_IPCR_SEQID_SHIFT) | 0); while (qspi_read32(priv->flags, ®s->sr) & QSPI_SR_BUSY_MASK) ;
@@ -815,10 +826,13 @@ int qspi_xfer(struct fsl_qspi_priv *priv, unsigned int bitlen, #endif } else if (priv->cur_seqid == QSPI_CMD_RDAR) { qspi_op_read(priv, din, bytes); - } else if (priv->cur_seqid == QSPI_CMD_RDID) + } else if (priv->cur_seqid == QSPI_CMD_RDID) { qspi_op_rdid(priv, din, bytes); - else if (priv->cur_seqid == QSPI_CMD_RDSR) - qspi_op_rdsr(priv, din, bytes); + } else if (priv->cur_seqid == QSPI_CMD_RDSR) { + qspi_op_rdsr(priv, din, bytes, SEQID_RDSR); + } else if (priv->cur_seqid == QSPI_CMD_RDFSR) { + qspi_op_rdsr(priv, din, bytes, SEQID_RDFSR); + } #ifdef CONFIG_SPI_FLASH_BAR else if ((priv->cur_seqid == QSPI_CMD_BRRD) || (priv->cur_seqid == QSPI_CMD_RDEAR)) {
Hi Neil,
this patch landed in my queue and I am taking a look at it:
It is not bad to remember this is a micron, why do you want to drop it ?
What is the meaning here for a a SPI flash ? I do not understand it.
reg = <0>; }; };
You are touching several topics and they must be addressed in separate patches. You have a fix for the SPI flash driver and changes for imx6ull-14x14-evk board. They should belong to separate patches.
These two are related to mx6ull-evk, and they should belong to an own patch.
I supposed the return value is checked, not that it will simply ignored.
#endif
I am not so deep in SF to comment this - maybe Jagan can say something more. I have never seen this issue up now - Heiko, you have also a M6ULL board, have you seen this ?
Best regards, Stefano
Neil Stainton
Stefano Babic
