[PATCH] rk3399: Add BOOTENV_SF command
Add missing BOOTENV_SF command in rk3399 config.
Fix it.
Fixes: f263b860acf8 ("rk3399: Enable SF distro bootcmd") Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reported-by: Suniel Mahesh sunil@amarulasolutions.com Tested-by: Suniel Mahesh sunil@amarulasolutions.com --- include/configs/rk3399_common.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/rk3399_common.h b/include/configs/rk3399_common.h index f0ae6e67a7..e63ebb14f7 100644 --- a/include/configs/rk3399_common.h +++ b/include/configs/rk3399_common.h @@ -67,6 +67,7 @@ "partitions=" PARTS_DEFAULT \ ROCKCHIP_DEVICE_SETTINGS \ BOOTENV \ + BOOTENV_SF \ "altbootcmd=" \ "setenv boot_syslinux_conf extlinux/extlinux-rollback.conf;" \ "run distro_bootcmd\0"
Fix it.
Can someone push this fix patch to master?
Jagan.
Fix it.
Kever, do you want me to pick this up? Do you have some objection? FWIW, include/configs/rk3399_common.h should get listed under some MAINTAINER entry directly. Thanks!
Hi Tom,
Fix it.
I will apply this patch and send to fix RP.
Thanks,
- Kever
Fix it.
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- BOOTENV_SF \ "altbootcmd=" \ "setenv boot_syslinux_conf extlinux/extlinux-rollback.conf;" \ "run distro_bootcmd\0"
Fix it.
Applied to u-boot-rockchip master branch.
Jagan Teki
Kever Yang
