[U-Boot] [PATCH] odroid: dts: cleanup of MAX77686 regulators
This commit cleanup MAX77686 regulator node by: - remove the sub-nodes of unconnected regulators - remove the "regulator-compatible" properties of all regulators
This prevents printing init errors for the regulators, with duplicated name strings.
Signed-off-by: Przemyslaw Marczak p.marczak@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- arch/arm/dts/exynos4412-odroid.dts | 80 +------------------------------------- 1 file changed, 2 insertions(+), 78 deletions(-)
diff --git a/arch/arm/dts/exynos4412-odroid.dts b/arch/arm/dts/exynos4412-odroid.dts index 415dfea..d572f1e 100644 --- a/arch/arm/dts/exynos4412-odroid.dts +++ b/arch/arm/dts/exynos4412-odroid.dts @@ -43,140 +43,102 @@
voltage-regulators { ldo1_reg: ldo1 { - regulator-compatible = "LDO1"; regulator-name = "VDD_ALIVE_1.0V"; regulator-min-microvolt = <1000000>; regulator-max-microvolt = <1000000>; };
ldo2_reg: ldo2 { - regulator-compatible = "LDO2"; regulator-name = "VDDQ_VM1M2_1.2V"; regulator-min-microvolt = <1200000>; regulator-max-microvolt = <1200000>; };
ldo3_reg: ldo3 { - regulator-compatible = "LDO3"; regulator-name = "VCC_1.8V_AP"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; };
ldo4_reg: ldo4 { - regulator-compatible = "LDO4"; regulator-name = "VDDQ_MMC2_2.8V"; regulator-min-microvolt = <2800000>; regulator-max-microvolt = <2800000>; };
ldo5_reg: ldo5 { - regulator-compatible = "LDO5"; regulator-name = "VDDQ_MMC0/1/3_1.8V"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; };
ldo6_reg: ldo6 { - regulator-compatible = "LDO6"; regulator-name = "VMPLL_1.0V"; regulator-min-microvolt = <1100000>; regulator-max-microvolt = <1100000>; };
ldo7_reg: ldo7 { - regulator-compatible = "LDO7"; regulator-name = "VPLL_1.1V"; regulator-min-microvolt = <1100000>; regulator-max-microvolt = <1100000>; };
ldo8_reg: ldo8 { - regulator-compatible = "LDO8"; regulator-name = "VDD_MIPI/HDMI_1.0V"; regulator-min-microvolt = <1000000>; regulator-max-microvolt = <1000000>; };
- ldo9_reg: ldo9 { - regulator-compatible = "LDO9"; - regulator-name = "nc"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - ldo10_reg: ldo10 { - regulator-compatible = "LDO10"; regulator-name = "VDD_MIPI/HDMI_1.8V"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; };
ldo11_reg: ldo11 { - regulator-compatible = "LDO11"; regulator-name = "VDD_ABB1_1.8V"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; };
ldo12_reg: ldo12 { - regulator-compatible = "LDO12"; regulator-name = "VDD_UOTG_3.0V"; regulator-min-microvolt = <3000000>; regulator-max-microvolt = <3000000>; };
ldo13_reg: ldo13 { - regulator-compatible = "LDO13"; regulator-name = "VDD_C2C_1.8V"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; };
ldo14_reg: ldo14 { - regulator-compatible = "LDO14"; regulator-name = "VDD_ABB02_1.8V"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; };
ldo15_reg: ldo15 { - regulator-compatible = "LDO15"; regulator-name = "VDD_HSIC/OTG_1.0V"; regulator-min-microvolt = <1000000>; regulator-max-microvolt = <1000000>; };
ldo16_reg: ldo16 { - regulator-compatible = "LDO16"; regulator-name = "VDD_HSIC_1.8V"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; };
ldo17_reg: ldo17 { - regulator-compatible = "LDO17"; regulator-name = "VDDQ_CAM_1.2V"; regulator-min-microvolt = <1200000>; regulator-max-microvolt = <1200000>; };
- ldo18_reg: ldo18 { - regulator-compatible = "LDO18"; - regulator-name = "nc"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - ldo19_reg: ldo19 { - regulator-compatible = "LDO19"; - regulator-name = "nc"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - ldo20_reg: ldo20 { - regulator-compatible = "LDO20"; regulator-name = "VDDQ_EMMC_1.8V"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; @@ -185,7 +147,6 @@ };
ldo21_reg: ldo21 { - regulator-compatible = "LDO21"; regulator-name = "TFLASH_2.8V"; regulator-min-microvolt = <2800000>; regulator-max-microvolt = <2800000>; @@ -194,7 +155,6 @@ };
ldo22_reg: ldo22 { - regulator-compatible = "LDO22"; regulator-name = "VDDQ_EMMC_2.8V"; regulator-min-microvolt = <2800000>; regulator-max-microvolt = <2800000>; @@ -202,20 +162,6 @@ regulator-boot-on; };
- ldo23_reg: ldo23 { - regulator-compatible = "LDO23"; - regulator-name = "nc"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - ldo24_reg: ldo24 { - regulator-compatible = "LDO24"; - regulator-name = "nc"; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - }; - ldo25_reg: ldo25 { regulator-compatible = "LDO25"; regulator-name = "VDDQ_LCD_3.0V"; @@ -223,75 +169,53 @@ regulator-max-microvolt = <3000000>; };
- ldo26_reg: ldo26 { - regulator-compatible = "LDO26"; - regulator-name = "nc"; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - }; - - buck1_reg: buck@1 { - regulator-compatible = "BUCK1"; + buck1_reg: buck1 { regulator-name = "VDD_MIF_1.0V"; regulator-min-microvolt = <8500000>; regulator-max-microvolt = <1100000>; };
- buck2_reg: buck@2 { - regulator-compatible = "BUCK2"; + buck2_reg: buck2 { regulator-name = "VDD_ARM_1.0V"; regulator-min-microvolt = <850000>; regulator-max-microvolt = <1500000>; };
buck3_reg: buck3 { - regulator-compatible = "BUCK3"; regulator-name = "VDD_INT_1.1V"; regulator-min-microvolt = <850000>; regulator-max-microvolt = <1150000>; };
buck4_reg: buck4 { - regulator-compatible = "BUCK4"; regulator-name = "VDD_G3D_1.0V"; regulator-min-microvolt = <850000>; regulator-max-microvolt = <1150000>; };
buck5_reg: buck5 { - regulator-compatible = "BUCK5"; regulator-name = "VDDQ_AP_1.2V"; regulator-min-microvolt = <1200000>; regulator-max-microvolt = <1200000>; };
buck6_reg: buck6 { - regulator-compatible = "BUCK6"; regulator-name = "VCC_INL1/7_1.35V"; regulator-min-microvolt = <1350000>; regulator-max-microvolt = <1350000>; };
buck7_reg: buck7 { - regulator-compatible = "BUCK7"; regulator-name = "VCC_INL2/3/5_2.0V"; regulator-min-microvolt = <2000000>; regulator-max-microvolt = <2000000>; };
buck8_reg: buck8 { - regulator-compatible = "BUCK8"; regulator-name = "VCC_P3V3_2.85V"; regulator-min-microvolt = <2850000>; regulator-max-microvolt = <3300000>; }; - - buck9_reg: buck9 { - regulator-compatible = "BUCK9"; - regulator-name = "nc"; - regulator-min-microvolt = <1200000>; - regulator-max-microvolt = <1200000>; - }; }; }; };
Hello Minkyu,
Could you apply this patch, please?
applied to u-boot-samsung.
Thanks, Minkyu Kang.
Minkyu Kang
Przemyslaw Marczak
