[U-Boot] [PATCH 7/9] x86: Move lapic_setup() call into init_bsp()
Currently lapic_setup() is called before calling mp_init(), which then calls init_bsp() where it calls enable_lapic(), which was already enabled in lapic_setup(). Hence move lapic_setup() call into init_bsp() to avoid the duplication.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
arch/x86/cpu/cpu.c | 2 -- arch/x86/cpu/mp_init.c | 2 +- 2 files changed, 1 insertion(+), 3 deletions(-)
diff --git a/arch/x86/cpu/cpu.c b/arch/x86/cpu/cpu.c index ddc7dc3..dd1b18b 100644 --- a/arch/x86/cpu/cpu.c +++ b/arch/x86/cpu/cpu.c @@ -626,8 +626,6 @@ static int x86_mp_init(void) { struct mp_params mp_params;
- lapic_setup(); - mp_params.num_cpus = detect_num_cpus(); mp_params.parallel_microcode_load = 0, mp_params.flight_plan = &mp_steps[0]; diff --git a/arch/x86/cpu/mp_init.c b/arch/x86/cpu/mp_init.c index ac5753a..864eb63 100644 --- a/arch/x86/cpu/mp_init.c +++ b/arch/x86/cpu/mp_init.c @@ -415,7 +415,7 @@ static int init_bsp(struct udevice **devp) cpu_get_name(processor_name); debug("CPU: %s.\n", processor_name);
- enable_lapic(); + lapic_setup();
apic_id = lapicid(); ret = find_cpu_by_apid_id(apic_id, devp);
Bin Meng
