Please pull u-boot-marvell/master
Hi Tom,
please pull the following Marvell MVEBU related patches into master:
---------------------------------------------------------------- - mvebu: Thecus: Misc enhancement and cleanup (Tony) - mvebu: Add AC5X Allied Telesis x240 board support incl NAND controller enhancements for this SoC (Chris) ----------------------------------------------------------------
Here the Azure build, without any issues:
https://dev.azure.com/sr0718/u-boot/_build/results?buildId=305&view=resu...
Thanks, Stefan
The following changes since commit bf5152d0108683bbaabf9d7a7988f61649fc33f4:
Merge branch 'master' of https://source.denx.de/u-boot/custodians/u-boot-riscv (2023-07-12 13:10:04 -0400)
git@source.denx.de:u-boot/custodians/u-boot-marvell.git
for you to fetch changes up to 366a863e651edfe976d28995888721e9bd403366:
arm: mvebu: Remove unused alias from RC AC5X dts (2023-07-13 15:54:11 +0200)
---------------------------------------------------------------- Chris Packham (6): arm: mvebu: ac5: Add nand-controller node arm: mvebu: ac5: Define mvebu_get_nand_clock() mtd: nand: pxa3xx: Add support for the Marvell AC5 SoC mtd: nand: pxa3xx: Enable devbus/nand arbiter on Armada 8K arm: mvebu: Add Allied Telesis x240 board arm: mvebu: Remove unused alias from RC AC5X dts
Tony Dinh (2): arm: mvebu: Clean up Thecus N2350 board DTS arm: mvebu: Enable gpio-fan for Thecus N2350 board
arch/arm/dts/Makefile | 3 +- arch/arm/dts/ac5-98dx25xx.dtsi | 9 ++ arch/arm/dts/ac5-98dx35xx-atl-x240.dts | 212 +++++++++++++++++++++++++++++ arch/arm/dts/ac5-98dx35xx-rd.dts | 1 - arch/arm/dts/armada-385-thecus-n2350.dts | 223 ++++++++++++++++--------------- arch/arm/mach-mvebu/Kconfig | 7 + arch/arm/mach-mvebu/alleycat5/soc.c | 6 + board/alliedtelesis/x240/MAINTAINERS | 7 + board/alliedtelesis/x240/Makefile | 6 + board/alliedtelesis/x240/x240.c | 13 ++ board/thecus/n2350/n2350.c | 2 +- configs/x240_defconfig | 86 ++++++++++++ drivers/mtd/nand/raw/pxa3xx_nand.c | 20 ++- include/configs/x240.h | 37 +++++ 14 files changed, 514 insertions(+), 118 deletions(-) create mode 100644 arch/arm/dts/ac5-98dx35xx-atl-x240.dts create mode 100644 board/alliedtelesis/x240/MAINTAINERS create mode 100644 board/alliedtelesis/x240/Makefile create mode 100644 board/alliedtelesis/x240/x240.c create mode 100644 configs/x240_defconfig create mode 100644 include/configs/x240.h
Stefan Roese
