[PATCH 0/2] sunxi: Fix Ethernet on mostly A20 boards
testing on a BananaPi M1 board revealed that Ethernet has regressed since the last release due to not only one, but two bugs: - The pinmux and GMAC clock setup for the A20 GMAC is apparently called too early now. - The updated RGMII phy-mode properties are now taken for real, so many boards are using the wrong RX/TX line delay setup, with mostly fatal consequences.
Fix those two issues to bring Ethernet back on those affected boards.
I refrained from just syncing the DTs from the kernel (to fix the second issue): Recent changes in the mainline DTs require newer kernels to work, which breaks Linux distro installer ISO images running via UEFI. We need to find a solution for that, but not in -rc4, which would be rather late for a normal DT sync anyway.
Please have a look and test on your board!
Cheers, Andre
Andre Przywara (2): sunxi: Fix old GMAC pinmux setup sunxi: dts: Update RGMII phy-mode properties
arch/arm/dts/sun50i-a64-sopine-baseboard.dts | 2 +- arch/arm/dts/sun50i-h5-nanopi-neo2.dts | 2 +- arch/arm/dts/sun50i-h5-orangepi-zero-plus.dts | 2 +- arch/arm/dts/sun6i-a31-hummingbird.dts | 2 +- arch/arm/dts/sun7i-a20-bananapi-m1-plus.dts | 2 +- arch/arm/dts/sun7i-a20-bananapi.dts | 2 +- arch/arm/dts/sun7i-a20-bananapro.dts | 2 +- arch/arm/dts/sun7i-a20-cubietruck.dts | 2 +- arch/arm/dts/sun7i-a20-olinuxino-lime2.dts | 2 +- arch/arm/dts/sun7i-a20-pcduino3-nano.dts | 2 +- arch/arm/dts/sun8i-a83t-bananapi-m3.dts | 2 +- arch/arm/dts/sun8i-a83t-cubietruck-plus.dts | 2 +- arch/arm/dts/sun8i-h3-orangepi-plus.dts | 2 +- arch/arm/dts/sunxi-bananapi-m2-plus.dtsi | 2 +- arch/arm/mach-sunxi/board.c | 1 - board/sunxi/board.c | 3 +++ 16 files changed, 17 insertions(+), 15 deletions(-)
Commit 5bc4cd05d7d4 ("sunxi: move non-essential code out of s_init()") moved the call to eth_init_board() from s_init() into board_init_f(). This means it's now only called from the SPL, which makes sense for most of the other moved low-level functions. However the GMAC pinmux and clock setup in eth_init_board() was not happy about that, so it broke the sun7i GMAC.
Since Ethernet is of no use in the SPL anyway, just move the call into board_init(), which is only run in U-Boot proper.
This fixes Ethernet operation for the A20 SoCs, which broke in v2022.04-rc1, with the above mentioned commit.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/mach-sunxi/board.c | 1 - board/sunxi/board.c | 3 +++ 2 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index 0071de19ffd..9a7673d82dc 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -333,7 +333,6 @@ void board_init_f(ulong dummy) clock_init(); timer_init(); gpio_init(); - eth_init_board();
spl_init(); preloader_console_init(); diff --git a/board/sunxi/board.c b/board/sunxi/board.c index a0961590479..28f702bc296 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -30,6 +30,7 @@ #include <asm/arch/prcm.h> #include <asm/arch/pmic_bus.h> #include <asm/arch/spl.h> +#include <asm/arch/sys_proto.h> #include <asm/global_data.h> #include <linux/delay.h> #include <u-boot/crc.h> @@ -308,6 +309,8 @@ int board_init(void) #endif #endif /* CONFIG_DM_MMC */
+ eth_init_board(); + return 0; }
Dne sreda, 16. marec 2022 ob 01:54:42 CET je Andre Przywara napisal(a):
Reviewed-by: Jernej Skrabec jernej.skrabec@gmail.com
I guess this function will soon go away with introduction of clock and pinctrl driver.
Best regards, Jernej
eth_init_board();
- eth_init_board();
-- 2.35.1
On Wed, 16 Mar 2022 17:55:16 +0100 Jernej Škrabec jernej.skrabec@gmail.com wrote:
Thanks!
Yes, indeed, forgot to mention this. This is just a stop-gap measure to fix Ethernet before the 2022.04 release.
Cheers, Andre
eth_init_board();
- eth_init_board();
-- 2.35.1
Andre Przywara andre.przywara@arm.com [2022-03-16 00:54:42]:
Tested-by: Petr Štetiar ynezz@true.cz [a20-olinuxino-lime2]
eth_init_board();
- eth_init_board();
-- 2.35.1
Commit f11513d99787 ("net: phy: realtek: Add tx/rx delay config for 8211e") made the Realtek PHY driver honour the phy-mode DT property, to set up the proper delay scheme for the RX and TX lines. A similar change in the kernel revealed that those properties were mostly wrong. The kernel DTs got updated over the last few months, but we were missing out on the U-Boot version.
Just sync in the phy-mode properties from the mainline kernel, v5.17-rc7, to avoid the breaking DT sync that late in the cycle.
This fixes Ethernet operation on the affected boards.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/sun50i-a64-sopine-baseboard.dts | 2 +- arch/arm/dts/sun50i-h5-nanopi-neo2.dts | 2 +- arch/arm/dts/sun50i-h5-orangepi-zero-plus.dts | 2 +- arch/arm/dts/sun6i-a31-hummingbird.dts | 2 +- arch/arm/dts/sun7i-a20-bananapi-m1-plus.dts | 2 +- arch/arm/dts/sun7i-a20-bananapi.dts | 2 +- arch/arm/dts/sun7i-a20-bananapro.dts | 2 +- arch/arm/dts/sun7i-a20-cubietruck.dts | 2 +- arch/arm/dts/sun7i-a20-olinuxino-lime2.dts | 2 +- arch/arm/dts/sun7i-a20-pcduino3-nano.dts | 2 +- arch/arm/dts/sun8i-a83t-bananapi-m3.dts | 2 +- arch/arm/dts/sun8i-a83t-cubietruck-plus.dts | 2 +- arch/arm/dts/sun8i-h3-orangepi-plus.dts | 2 +- arch/arm/dts/sunxi-bananapi-m2-plus.dtsi | 2 +- 14 files changed, 14 insertions(+), 14 deletions(-)
diff --git a/arch/arm/dts/sun50i-a64-sopine-baseboard.dts b/arch/arm/dts/sun50i-a64-sopine-baseboard.dts index e22b94c8364..5e66ce1a334 100644 --- a/arch/arm/dts/sun50i-a64-sopine-baseboard.dts +++ b/arch/arm/dts/sun50i-a64-sopine-baseboard.dts @@ -79,7 +79,7 @@ &emac { pinctrl-names = "default"; pinctrl-0 = <&rgmii_pins>; - phy-mode = "rgmii-id"; + phy-mode = "rgmii-txid"; phy-handle = <&ext_rgmii_phy>; phy-supply = <®_dc1sw>; status = "okay"; diff --git a/arch/arm/dts/sun50i-h5-nanopi-neo2.dts b/arch/arm/dts/sun50i-h5-nanopi-neo2.dts index 02f8e72f0ca..05486cccee1 100644 --- a/arch/arm/dts/sun50i-h5-nanopi-neo2.dts +++ b/arch/arm/dts/sun50i-h5-nanopi-neo2.dts @@ -75,7 +75,7 @@ pinctrl-0 = <&emac_rgmii_pins>; phy-supply = <®_gmac_3v3>; phy-handle = <&ext_rgmii_phy>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id"; status = "okay"; };
diff --git a/arch/arm/dts/sun50i-h5-orangepi-zero-plus.dts b/arch/arm/dts/sun50i-h5-orangepi-zero-plus.dts index d13980ed7a7..7ec5ac850a0 100644 --- a/arch/arm/dts/sun50i-h5-orangepi-zero-plus.dts +++ b/arch/arm/dts/sun50i-h5-orangepi-zero-plus.dts @@ -69,7 +69,7 @@ pinctrl-0 = <&emac_rgmii_pins>; phy-supply = <®_gmac_3v3>; phy-handle = <&ext_rgmii_phy>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id"; status = "okay"; };
diff --git a/arch/arm/dts/sun6i-a31-hummingbird.dts b/arch/arm/dts/sun6i-a31-hummingbird.dts index ce4f9e9834b..2c143580350 100644 --- a/arch/arm/dts/sun6i-a31-hummingbird.dts +++ b/arch/arm/dts/sun6i-a31-hummingbird.dts @@ -162,7 +162,7 @@ pinctrl-names = "default"; pinctrl-0 = <&gmac_pins_rgmii_a>, <&gmac_phy_reset_pin_hummingbird>; phy = <&phy1>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id"; snps,reset-gpio = <&pio 0 21 GPIO_ACTIVE_HIGH>; snps,reset-active-low; snps,reset-delays-us = <0 10000 30000>; diff --git a/arch/arm/dts/sun7i-a20-bananapi-m1-plus.dts b/arch/arm/dts/sun7i-a20-bananapi-m1-plus.dts index e2bfe005883..4dbcad1343b 100644 --- a/arch/arm/dts/sun7i-a20-bananapi-m1-plus.dts +++ b/arch/arm/dts/sun7i-a20-bananapi-m1-plus.dts @@ -130,7 +130,7 @@ pinctrl-names = "default"; pinctrl-0 = <&gmac_rgmii_pins>; phy = <&phy1>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id"; phy-supply = <®_gmac_3v3>; status = "okay";
diff --git a/arch/arm/dts/sun7i-a20-bananapi.dts b/arch/arm/dts/sun7i-a20-bananapi.dts index 81bc85d398c..33040c43bce 100644 --- a/arch/arm/dts/sun7i-a20-bananapi.dts +++ b/arch/arm/dts/sun7i-a20-bananapi.dts @@ -132,7 +132,7 @@ pinctrl-names = "default"; pinctrl-0 = <&gmac_rgmii_pins>; phy = <&phy1>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id"; phy-supply = <®_gmac_3v3>; status = "okay";
diff --git a/arch/arm/dts/sun7i-a20-bananapro.dts b/arch/arm/dts/sun7i-a20-bananapro.dts index 0176e9de018..8a75545e228 100644 --- a/arch/arm/dts/sun7i-a20-bananapro.dts +++ b/arch/arm/dts/sun7i-a20-bananapro.dts @@ -110,7 +110,7 @@ pinctrl-names = "default"; pinctrl-0 = <&gmac_rgmii_pins>; phy = <&phy1>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id"; phy-supply = <®_gmac_3v3>; status = "okay";
diff --git a/arch/arm/dts/sun7i-a20-cubietruck.dts b/arch/arm/dts/sun7i-a20-cubietruck.dts index 99f531b8d2a..46a9f4669e1 100644 --- a/arch/arm/dts/sun7i-a20-cubietruck.dts +++ b/arch/arm/dts/sun7i-a20-cubietruck.dts @@ -151,7 +151,7 @@ pinctrl-names = "default"; pinctrl-0 = <&gmac_rgmii_pins>; phy = <&phy1>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id"; status = "okay";
phy1: ethernet-phy@1 { diff --git a/arch/arm/dts/sun7i-a20-olinuxino-lime2.dts b/arch/arm/dts/sun7i-a20-olinuxino-lime2.dts index 4e1c590eb09..996201665b7 100644 --- a/arch/arm/dts/sun7i-a20-olinuxino-lime2.dts +++ b/arch/arm/dts/sun7i-a20-olinuxino-lime2.dts @@ -112,7 +112,7 @@ pinctrl-names = "default"; pinctrl-0 = <&gmac_rgmii_pins>; phy = <&phy1>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id"; status = "okay";
phy1: ethernet-phy@1 { diff --git a/arch/arm/dts/sun7i-a20-pcduino3-nano.dts b/arch/arm/dts/sun7i-a20-pcduino3-nano.dts index 538ea15fa32..205eaae44a0 100644 --- a/arch/arm/dts/sun7i-a20-pcduino3-nano.dts +++ b/arch/arm/dts/sun7i-a20-pcduino3-nano.dts @@ -115,7 +115,7 @@ pinctrl-names = "default"; pinctrl-0 = <&gmac_rgmii_pins>; phy = <&phy1>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id"; status = "okay";
phy1: ethernet-phy@1 { diff --git a/arch/arm/dts/sun8i-a83t-bananapi-m3.dts b/arch/arm/dts/sun8i-a83t-bananapi-m3.dts index eaff6fa4018..2beafe3a31d 100644 --- a/arch/arm/dts/sun8i-a83t-bananapi-m3.dts +++ b/arch/arm/dts/sun8i-a83t-bananapi-m3.dts @@ -123,7 +123,7 @@ pinctrl-0 = <&emac_rgmii_pins>; phy-supply = <®_sw>; phy-handle = <&rgmii_phy>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id"; allwinner,rx-delay-ps = <700>; allwinner,tx-delay-ps = <700>; status = "okay"; diff --git a/arch/arm/dts/sun8i-a83t-cubietruck-plus.dts b/arch/arm/dts/sun8i-a83t-cubietruck-plus.dts index 5dba4fc310f..ecd9ff38a8b 100644 --- a/arch/arm/dts/sun8i-a83t-cubietruck-plus.dts +++ b/arch/arm/dts/sun8i-a83t-cubietruck-plus.dts @@ -160,7 +160,7 @@ pinctrl-0 = <&emac_rgmii_pins>; phy-supply = <®_dldo4>; phy-handle = <&rgmii_phy>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id"; status = "okay"; };
diff --git a/arch/arm/dts/sun8i-h3-orangepi-plus.dts b/arch/arm/dts/sun8i-h3-orangepi-plus.dts index 97f497854e0..d05fa679dcd 100644 --- a/arch/arm/dts/sun8i-h3-orangepi-plus.dts +++ b/arch/arm/dts/sun8i-h3-orangepi-plus.dts @@ -85,7 +85,7 @@ pinctrl-0 = <&emac_rgmii_pins>; phy-supply = <®_gmac_3v3>; phy-handle = <&ext_rgmii_phy>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id";
status = "okay"; }; diff --git a/arch/arm/dts/sunxi-bananapi-m2-plus.dtsi b/arch/arm/dts/sunxi-bananapi-m2-plus.dtsi index 39263e74fbb..8e5cb3b3fd6 100644 --- a/arch/arm/dts/sunxi-bananapi-m2-plus.dtsi +++ b/arch/arm/dts/sunxi-bananapi-m2-plus.dtsi @@ -126,7 +126,7 @@ pinctrl-0 = <&emac_rgmii_pins>; phy-supply = <®_gmac_3v3>; phy-handle = <&ext_rgmii_phy>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id";
status = "okay"; };
Reviewed-by: Samuel Holland samuel@sholland.org
Verified against the updated files from Linux. I suppose I broke this by not sending a DT sync series during the same release cycle. Hopefully we can get DT syncing unblocked soon and merged for the next release.
Regards, Samuel
Andre Przywara
Jernej Škrabec
Petr Štetiar
Samuel Holland
