[U-Boot-Users] [PATCH] 85xx: Move LAW init code into C
Move the initialization of the LAWs into C code and provide an API to allow modification of LAWs after init.
Board code is responsible to provide a law_table and num_law_entries.
We should be able to use the same code on 86xx as well.
Signed-off-by: Kumar Gala galak@kernel.crashing.org ---
In my git tree mpc85xx branch.
cpu/mpc85xx/cpu_init.c | 8 ++++ cpu/mpc85xx/spd_sdram.c | 8 ++++ cpu/mpc85xx/start.S | 2 + drivers/misc/Makefile | 1 + drivers/misc/fsl_law.c | 64 ++++++++++++++++++++++++++++++++++++ include/asm-ppc/fsl_law.h | 80 +++++++++++++++++++++++++++++++++++++++++++++ 6 files changed, 163 insertions(+), 0 deletions(-) create mode 100644 drivers/misc/fsl_law.c create mode 100644 include/asm-ppc/fsl_law.h
diff --git a/cpu/mpc85xx/cpu_init.c b/cpu/mpc85xx/cpu_init.c index fdb9ecb..9a65142 100644 --- a/cpu/mpc85xx/cpu_init.c +++ b/cpu/mpc85xx/cpu_init.c @@ -31,6 +31,7 @@ #include <asm/processor.h> #include <ioports.h> #include <asm/io.h> +#include <asm/fsl_law.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -140,6 +141,9 @@ void cpu_init_f (void) /* Clear initial global data */ memset ((void *) gd, 0, sizeof (gd_t));
+#ifdef CONFIG_FSL_LAW + init_laws(); +#endif
#ifdef CONFIG_CPM2 config_8560_ioports((ccsr_cpm_t *)CFG_MPC85xx_CPM_ADDR); @@ -222,11 +226,15 @@ void cpu_init_f (void) int cpu_init_r(void) { #ifdef CONFIG_CLEAR_LAW0 +#ifdef CONFIG_FSL_LAW + disable_law(0); +#else volatile ccsr_local_ecm_t *ecm = (void *)(CFG_MPC85xx_ECM_ADDR);
/* clear alternate boot location LAW (used for sdram, or ddr bank) */ ecm->lawar0 = 0; #endif +#endif
#if defined(CONFIG_L2_CACHE) volatile ccsr_l2cache_t *l2cache = (void *)CFG_MPC85xx_L2_ADDR; diff --git a/cpu/mpc85xx/spd_sdram.c b/cpu/mpc85xx/spd_sdram.c index adc9c4d..bb5dc1f 100644 --- a/cpu/mpc85xx/spd_sdram.c +++ b/cpu/mpc85xx/spd_sdram.c @@ -27,6 +27,7 @@ #include <i2c.h> #include <spd.h> #include <asm/mmu.h> +#include <asm/fsl_law.h>
#if defined(CONFIG_DDR_ECC) && !defined(CONFIG_ECC_INIT_VIA_DDRCONTROLLER) @@ -1022,7 +1023,9 @@ spd_sdram(void) static unsigned int setup_laws_and_tlbs(unsigned int memsize) { +#ifndef CONFIG_FSL_LAW volatile ccsr_local_ecm_t *ecm = (void *)(CFG_MPC85xx_ECM_ADDR); +#endif unsigned int tlb_size; unsigned int law_size; unsigned int ram_tlb_index; @@ -1098,12 +1101,17 @@ setup_laws_and_tlbs(unsigned int memsize) /* * Set up LAWBAR for all of DDR. */ + +#ifdef CONFIG_FSL_LAW + set_law(1, CFG_DDR_SDRAM_BASE, law_size, LAW_TRGT_IF_DDR); +#else ecm->lawbar1 = ((CFG_DDR_SDRAM_BASE >> 12) & 0xfffff); ecm->lawar1 = (LAWAR_EN | LAWAR_TRGT_IF_DDR | (LAWAR_SIZE & law_size)); debug("DDR: LAWBAR1=0x%08x\n", ecm->lawbar1); debug("DDR: LARAR1=0x%08x\n", ecm->lawar1); +#endif
/* * Confirm that the requested amount of memory was mapped. diff --git a/cpu/mpc85xx/start.S b/cpu/mpc85xx/start.S index b489d2f..346369c 100644 --- a/cpu/mpc85xx/start.S +++ b/cpu/mpc85xx/start.S @@ -201,6 +201,7 @@ _start_e500: lis r7,CFG_CCSRBAR@h ori r7,r7,CFG_CCSRBAR@l
+#ifndef CONFIG_FSL_LAW bl law_entry mr r6,r0 lwzu r5,0(r6) /* how many windows we actually use */ @@ -216,6 +217,7 @@ _start_e500: addi r2,r2,0x0020 addi r1,r1,0x0020 bdnz 0b +#endif
/* Clear and set up some registers. */ li r0,0 diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index 78cec21..6752172 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -28,6 +28,7 @@ LIB := $(obj)libmisc.a COBJS-y += ali512x.o COBJS-y += ns87308.o COBJS-y += status_led.o +COBJS-$(CONFIG_FSL_LAW) += fsl_law.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/misc/fsl_law.c b/drivers/misc/fsl_law.c new file mode 100644 index 0000000..371375e --- /dev/null +++ b/drivers/misc/fsl_law.c @@ -0,0 +1,64 @@ +/* + * Copyright 2008 Freescale Semiconductor, Inc. + * + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/fsl_law.h> +#include <asm/io.h> + +#define LAWAR_EN 0x80000000 + +void set_law(u8 idx, phys_addr_t addr, enum law_size sz, enum law_trgt_if id) +{ + volatile u32 *base = (volatile u32 *)(CFG_IMMR + 0xc08); + volatile u32 *lawbar = base + 8 * idx; + volatile u32 *lawar = base + 8 * idx + 2; + + out_be32(lawbar, addr >> 12); + out_be32(lawar, LAWAR_EN | ((u32)id << 20) | (u32)sz); + + return ; +} + +void disable_law(u8 idx) +{ + volatile u32 *base = (volatile u32 *)(CFG_IMMR + 0xc08); + volatile u32 *lawbar = base + 8 * idx; + volatile u32 *lawar = base + 8 * idx + 2; + + out_be32(lawar, 0); + out_be32(lawbar, 0); + + return; +} + +void init_laws(void) +{ + int i; + + for (i = 0; i < num_law_entries; i++) + set_law(law_table[i].index, law_table[i].addr, + law_table[i].size, law_table[i].trgt_id); + return ; +} diff --git a/include/asm-ppc/fsl_law.h b/include/asm-ppc/fsl_law.h new file mode 100644 index 0000000..2703476 --- /dev/null +++ b/include/asm-ppc/fsl_law.h @@ -0,0 +1,80 @@ +#ifndef _FSL_LAW_H_ +#define _FSL_LAW_H_ + +#include <asm/io.h> + +#define ARRAY_SIZE(x) (sizeof(x) / sizeof((x)[0])) +#define SET_LAW_ENTRY(idx, a, sz, trgt) \ + { .index = idx, .addr = a, .size = sz, .trgt_id = trgt } + +enum law_size { + LAW_SIZE_4K = 0xb, + LAW_SIZE_8K, + LAW_SIZE_16K, + LAW_SIZE_32K, + LAW_SIZE_64K, + LAW_SIZE_128K, + LAW_SIZE_256K, + LAW_SIZE_512K, + LAW_SIZE_1M, + LAW_SIZE_2M, + LAW_SIZE_4M, + LAW_SIZE_8M, + LAW_SIZE_16M, + LAW_SIZE_32M, + LAW_SIZE_64M, + LAW_SIZE_128M, + LAW_SIZE_256M, + LAW_SIZE_512M, + LAW_SIZE_1G, + LAW_SIZE_2G, + LAW_SIZE_4G, + LAW_SIZE_8G, + LAW_SIZE_16G, + LAW_SIZE_32G, +}; + +enum law_trgt_if { + LAW_TRGT_IF_PCI = 0x00, + LAW_TRGT_IF_PCI_2 = 0x01, +#ifndef CONFIG_MPC8641 + LAW_TRGT_IF_PCIE_1 = 0x02, +#endif +#ifndef CONFIG_MPC8572 + LAW_TRGT_IF_PCIE_3 = 0x03, +#endif + LAW_TRGT_IF_LBC = 0x04, + LAW_TRGT_IF_CCSR = 0x08, + LAW_TRGT_IF_DDR_INTRLV = 0x0b, + LAW_TRGT_IF_RIO = 0x0c, + LAW_TRGT_IF_DDR = 0x0f, + LAW_TRGT_IF_DDR_2 = 0x16, /* 2nd controller */ +}; +#define LAW_TRGT_IF_DDR_1 LAW_TRGT_IF_DDR +#define LAW_TRGT_IF_PCI_1 LAW_TRGT_IF_PCI +#define LAW_TRGT_IF_PCIX LAW_TRGT_IF_PCI +#define LAW_TRGT_IF_PCIE_2 LAW_TRGT_IF_PCI_2 + +#ifdef CONFIG_MPC8641 +#define LAW_TRGT_IF_PCIE_1 LAW_TRGT_IF_PCI +#endif + +#ifdef CONFIG_MPC8572 +#define LAW_TRGT_IF_PCIE_3 LAW_TRGT_IF_PCI +#endif + +struct law_entry { + u8 index; + phys_addr_t addr; + enum law_size size; + enum law_trgt_if trgt_id; +}; + +extern void set_law(u8 idx, phys_addr_t addr, enum law_size sz, enum law_trgt_if id); +extern void disable_law(u8 idx); +extern void init_laws(void); + +/* define in board code */ +extern struct law_entry law_table[]; +extern int num_law_entries; +#endif
Kumar Gala
