[U-Boot] [PATCH v2 1/2] net/designware: Do not select MIIPORT for RGMII interface
Signed-off-by: Vipin Kumar vipin.kumar@st.com Acked-by: Stefan Roese sr@denx.de --- drivers/net/designware.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/net/designware.c b/drivers/net/designware.c index bf21a08..46f6601 100644 --- a/drivers/net/designware.c +++ b/drivers/net/designware.c @@ -113,7 +113,9 @@ static int mac_reset(struct eth_device *dev) int timeout = CONFIG_MACRESET_TIMEOUT;
writel(DMAMAC_SRST, &dma_p->busmode); - writel(MII_PORTSELECT, &mac_p->conf); + + if (priv->interface != PHY_INTERFACE_MODE_RGMII) + writel(MII_PORTSELECT, &mac_p->conf);
start = get_timer(0); while (get_timer(start) < timeout) {
SPEAr310 and SPEAr320 Ethernet interfaces share same MDIO lines to control their respective phys. Currently there is a fixed configuration in which only a particular MAC can use the MDIO lines.
Call an arch specific function to take control of specific mdio lines at runtime.
Signed-off-by: Shiraz Hashim shiraz.hashim@st.com Signed-off-by: Vipin Kumar vipin.kumar@st.com Acked-by: Stefan Roese sr@denx.de --- Changes in v2 Used __weak instead of __attribute__((weak... Improve patch comment
drivers/net/macb.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index 8bacbda..6b49f0e 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -163,6 +163,11 @@ static u16 macb_mdio_read(struct macb_device *macb, u8 reg) return MACB_BFEXT(DATA, frame); }
+static void __weak arch_get_mdio_control(const char *name) +{ + return; +} + #if defined(CONFIG_CMD_MII)
int macb_miiphy_read(const char *devname, u8 phy_adr, u8 reg, u16 *value) @@ -173,6 +178,7 @@ int macb_miiphy_read(const char *devname, u8 phy_adr, u8 reg, u16 *value) if ( macb->phy_addr != phy_adr ) return -1;
+ arch_get_mdio_control(devname); *value = macb_mdio_read(macb, reg);
return 0; @@ -186,6 +192,7 @@ int macb_miiphy_write(const char *devname, u8 phy_adr, u8 reg, u16 value) if ( macb->phy_addr != phy_adr ) return -1;
+ arch_get_mdio_control(devname); macb_mdio_write(macb, reg, value);
return 0; @@ -377,6 +384,7 @@ static int macb_phy_init(struct macb_device *macb) int media, speed, duplex; int i;
+ arch_get_mdio_control(netdev->name); #ifdef CONFIG_MACB_SEARCH_PHY /* Auto-detect phy_addr */ if (!macb_phy_find(macb)) {
Applied, Thanks. -Joe
Joe Hershberger
Vipin Kumar
