Re: [U-Boot-Users] RapidIO on custom board (MPC8548 )
24 May
2008
24 May
'08
11:28 a.m.
Thanks John.
I should explain that I have only MPC8548 on the board. Other elements with access via RapidIO will be on another board which is not connected now. I guess that the common transport size does not matter in this case because we do not have any communication.
Should I assume that the most probable reason of hung up i the mapping of memory? The kernel hung up in function in_be32(regs_win + RIO_CCSR). This is access to configuration register.
Thanks, Adam
On Mon, 2008-05-19 at 09:22 +0100, John Traill wrote:
Adam,
Make sure you have matching common transport sizes in your system -
Section 4.4.3.16 RapidIO System Size in the 8548 manual.
6195
Adam Nowak
