[PATCH v2] pinctrl: Add Apple pinctrl driver
This driver supports both pin muxing and GPIO support for the pin control logic found on Apple SoCs.
Signed-off-by: Mark Kettenis kettenis@openbsd.org ---
ChangeLog:
v2: - Enable driver on Apple hardware
MAINTAINERS | 1 + arch/arm/Kconfig | 2 + .../pinctrl/apple,pinctrl.yaml | 106 +++++++++ drivers/pinctrl/Kconfig | 11 + drivers/pinctrl/Makefile | 1 + drivers/pinctrl/pinctrl-apple.c | 207 ++++++++++++++++++ 6 files changed, 328 insertions(+) create mode 100644 doc/device-tree-bindings/pinctrl/apple,pinctrl.yaml create mode 100644 drivers/pinctrl/pinctrl-apple.c
diff --git a/MAINTAINERS b/MAINTAINERS index 9d8cba9028..98eb491f60 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -115,6 +115,7 @@ F: arch/arm/include/asm/arch-m1/ F: arch/arm/mach-apple/ F: configs/apple_m1_defconfig F: drivers/iommu/apple_dart.c +F: drivers/pinctrl/pinctrl-apple.c F: include/configs/apple.h
ARM diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index b4808d4c75..a694cc34a8 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -927,6 +927,7 @@ config ARCH_APPLE select CLK select CMD_USB select DM + select DM_GPIO select DM_KEYBOARD select DM_SERIAL select DM_USB @@ -935,6 +936,7 @@ config ARCH_APPLE select LINUX_KERNEL_IMAGE_HEADER select OF_CONTROL select OF_BOARD + select PINCTRL select POSITION_INDEPENDENT select USB imply CMD_DM diff --git a/doc/device-tree-bindings/pinctrl/apple,pinctrl.yaml b/doc/device-tree-bindings/pinctrl/apple,pinctrl.yaml new file mode 100644 index 0000000000..d50571affd --- /dev/null +++ b/doc/device-tree-bindings/pinctrl/apple,pinctrl.yaml @@ -0,0 +1,106 @@ +# SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) +%YAML 1.2 +--- +$id: http://devicetree.org/schemas/pinctrl/apple,pinctrl.yaml# +$schema: http://devicetree.org/meta-schemas/core.yaml# + +title: Apple GPIO controller + +maintainers: + - Mark Kettenis kettenis@openbsd.org + +description: | + The Apple GPIO controller is a simple combined pin and GPIO + controller present on Apple ARM SoC platforms, including various + iPhone and iPad devices and the "Apple Silicon" Macs. + +properties: + compatible: + items: + - const: apple,t8103-pinctrl + - const: apple,pinctrl + + reg: + maxItems: 1 + + clocks: + maxItems: 1 + + gpio-controller: true + + '#gpio-cells': + const: 2 + + gpio-ranges: + maxItems: 1 + + interrupts: + description: One interrupt for each of the (up to 7) interrupt + groups supported by the controller sorted by interrupt group + number in ascending order. + minItems: 1 + maxItems: 7 + + interrupt-controller: true + +patternProperties: + '-pins$': + type: object + $ref: pinmux-node.yaml# + + properties: + pinmux: + description: + Values are constructed from pin number and alternate function + configuration number using the APPLE_PINMUX() helper macro + defined in include/dt-bindings/pinctrl/apple.h. + + required: + - pinmux + + additionalProperties: false + +required: + - compatible + - reg + - gpio-controller + - '#gpio-cells' + - gpio-ranges + +additionalProperties: false + +examples: + - | + #include <dt-bindings/interrupt-controller/apple-aic.h> + #include <dt-bindings/pinctrl/apple.h> + + soc { + #address-cells = <2>; + #size-cells = <2>; + + pinctrl: pinctrl@23c100000 { + compatible = "apple,t8103-pinctrl", "apple,pinctrl"; + reg = <0x2 0x3c100000 0x0 0x100000>; + clocks = <&gpio_clk>; + + gpio-controller; + #gpio-cells = <2>; + gpio-ranges = <&pinctrl 0 0 212>; + + interrupt-controller; + interrupt-parent = <&aic>; + interrupts = <AIC_IRQ 16 IRQ_TYPE_LEVEL_HIGH>, + <AIC_IRQ 17 IRQ_TYPE_LEVEL_HIGH>, + <AIC_IRQ 18 IRQ_TYPE_LEVEL_HIGH>, + <AIC_IRQ 19 IRQ_TYPE_LEVEL_HIGH>, + <AIC_IRQ 20 IRQ_TYPE_LEVEL_HIGH>, + <AIC_IRQ 21 IRQ_TYPE_LEVEL_HIGH>, + <AIC_IRQ 22 IRQ_TYPE_LEVEL_HIGH>; + + pcie_pins: pcie-pins { + pinmux = <APPLE_PINMUX(150, 1)>, + <APPLE_PINMUX(151, 1)>, + <APPLE_PINMUX(32, 1)>; + }; + }; + }; diff --git a/drivers/pinctrl/Kconfig b/drivers/pinctrl/Kconfig index 30eaa376c8..cac5f2488d 100644 --- a/drivers/pinctrl/Kconfig +++ b/drivers/pinctrl/Kconfig @@ -145,6 +145,17 @@ config SPL_PINCONF_RECURSIVE
if PINCTRL || SPL_PINCTRL
+config PINCTRL_APPLE + bool "Apple pinctrl driver" + depends on DM && PINCTRL_GENERIC && ARCH_APPLE + default y + help + Support pin multiplexing on Apple SoCs. + + The driver is controlled by a device tree node which contains + both the GPIO definitions and pin control functions for each + available multiplex function. + config PINCTRL_AR933X bool "QCA/Athores ar933x pin control driver" depends on DM && SOC_AR933X diff --git a/drivers/pinctrl/Makefile b/drivers/pinctrl/Makefile index 05b71f2f13..fd736a7f64 100644 --- a/drivers/pinctrl/Makefile +++ b/drivers/pinctrl/Makefile @@ -3,6 +3,7 @@ obj-y += pinctrl-uclass.o obj-$(CONFIG_$(SPL_)PINCTRL_GENERIC) += pinctrl-generic.o
+obj-$(CONFIG_PINCTRL_APPLE) += pinctrl-apple.o obj-$(CONFIG_PINCTRL_AT91) += pinctrl-at91.o obj-$(CONFIG_PINCTRL_AT91PIO4) += pinctrl-at91-pio4.o obj-y += nxp/ diff --git a/drivers/pinctrl/pinctrl-apple.c b/drivers/pinctrl/pinctrl-apple.c new file mode 100644 index 0000000000..62476358c3 --- /dev/null +++ b/drivers/pinctrl/pinctrl-apple.c @@ -0,0 +1,207 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2021 Mark Kettenis kettenis@openbsd.org + */ + +#include <common.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/pinctrl.h> +#include <dt-bindings/pinctrl/apple.h> +#include <asm/io.h> +#include <asm-generic/gpio.h> +#include <linux/bitfield.h> + +struct apple_pinctrl_priv { + void *base; + int pin_count; +}; + +#define REG_GPIO(x) (4 * (x)) +#define REG_GPIO_DATA BIT(0) +#define REG_GPIO_MODE GENMASK(3, 1) +#define REG_GPIO_OUT 1 +#define REG_GPIO_PERIPH GENMASK(6, 5) +#define REG_GPIO_INPUT_ENABLE BIT(9) + +static void apple_pinctrl_config_pin(struct apple_pinctrl_priv *priv, + unsigned pin, u32 clr, u32 set) +{ + unsigned reg = REG_GPIO(pin); + u32 old, new; + + old = readl(priv->base + REG_GPIO(pin)); + new = (old & ~clr) | set; + writel(new, priv->base + reg); +} + +static int apple_gpio_get_value(struct udevice *dev, unsigned offset) +{ + struct apple_pinctrl_priv *priv = dev_get_priv(dev->parent); + + return !!(readl(priv->base + REG_GPIO(offset)) & REG_GPIO_DATA); +} + +static int apple_gpio_set_value(struct udevice *dev, unsigned offset, + int value) +{ + struct apple_pinctrl_priv *priv = dev_get_priv(dev->parent); + + apple_pinctrl_config_pin(priv, offset, REG_GPIO_DATA, + value ? REG_GPIO_DATA : 0); + return 0; +} + +static int apple_gpio_get_direction(struct udevice *dev, unsigned offset) +{ + struct apple_pinctrl_priv *priv = dev_get_priv(dev->parent); + u32 reg = readl(priv->base + REG_GPIO(offset)); + + if (FIELD_GET(REG_GPIO_MODE, reg) == REG_GPIO_OUT) + return GPIOF_OUTPUT; + else + return GPIOF_INPUT; +} + +static int apple_gpio_direction_input(struct udevice *dev, unsigned offset) +{ + struct apple_pinctrl_priv *priv = dev_get_priv(dev->parent); + + apple_pinctrl_config_pin(priv, offset, + REG_GPIO_PERIPH | REG_GPIO_MODE, + REG_GPIO_INPUT_ENABLE); + return 0; +} + +static int apple_gpio_direction_output(struct udevice *dev, unsigned offset, + int value) +{ + struct apple_pinctrl_priv *priv = dev_get_priv(dev->parent); + u32 set = (value ? REG_GPIO_DATA : 0); + + apple_pinctrl_config_pin(priv, offset, REG_GPIO_DATA | + REG_GPIO_PERIPH | REG_GPIO_MODE, + set | FIELD_PREP(REG_GPIO_MODE, REG_GPIO_OUT)); + return 0; +} + +static int apple_gpio_probe(struct udevice *dev) +{ + struct apple_pinctrl_priv *priv = dev_get_priv(dev->parent); + struct gpio_dev_priv *uc_priv; + + uc_priv = dev_get_uclass_priv(dev); + uc_priv->bank_name = "gpio"; + uc_priv->gpio_count = priv->pin_count; + + return 0; +} + +static struct dm_gpio_ops apple_gpio_ops = { + .get_value = apple_gpio_get_value, + .set_value = apple_gpio_set_value, + .get_function = apple_gpio_get_direction, + .direction_input = apple_gpio_direction_input, + .direction_output = apple_gpio_direction_output, +}; + +static struct driver apple_gpio_driver = { + .name = "apple_gpio", + .id = UCLASS_GPIO, + .probe = apple_gpio_probe, + .ops = &apple_gpio_ops, +}; + +static int apple_pinctrl_get_pins_count(struct udevice *dev) +{ + struct apple_pinctrl_priv *priv = dev_get_priv(dev); + + return priv->pin_count; +} + +static const char *apple_pinctrl_get_pin_name(struct udevice *dev, + unsigned selector) +{ + static char pin_name[PINNAME_SIZE]; + + snprintf(pin_name, PINNAME_SIZE, "pin%d", selector); + return pin_name; +} + +static int apple_pinctrl_get_pin_muxing(struct udevice *dev, unsigned selector, + char *buf, int size) +{ + struct apple_pinctrl_priv *priv = dev_get_priv(dev); + + if (readl(priv->base + REG_GPIO(selector)) & REG_GPIO_PERIPH) + strncpy(buf, "periph", size); + else + strncpy(buf, "gpio", size); + return 0; +} + +static int apple_pinctrl_pinmux_set(struct udevice *dev, unsigned pin_selector, + unsigned func_selector) +{ + struct apple_pinctrl_priv *priv = dev_get_priv(dev); + + apple_pinctrl_config_pin(priv, pin_selector, + REG_GPIO_DATA | REG_GPIO_MODE, + FIELD_PREP(REG_GPIO_PERIPH, func_selector) | + REG_GPIO_INPUT_ENABLE); + return 0; +} + +static int apple_pinctrl_pinmux_property_set(struct udevice *dev, + u32 pinmux_group) +{ + unsigned pin_selector = APPLE_PIN(pinmux_group); + unsigned func_selector = APPLE_FUNC(pinmux_group); + int ret; + + ret = apple_pinctrl_pinmux_set(dev, pin_selector, func_selector); + return ret ? ret : pin_selector; +} + +static int apple_pinctrl_probe(struct udevice *dev) +{ + struct apple_pinctrl_priv *priv = dev_get_priv(dev); + struct ofnode_phandle_args args; + struct udevice *child; + + priv->base = dev_read_addr_ptr(dev); + if (!priv->base) + return -EINVAL; + + if (!dev_read_phandle_with_args(dev, "gpio-ranges", + NULL, 3, 0, &args)) + priv->pin_count = args.args[2]; + + device_bind(dev, &apple_gpio_driver, "apple_gpio", NULL, + dev_ofnode(dev), &child); + + return 0; +} + +static struct pinctrl_ops apple_pinctrl_ops = { + .set_state = pinctrl_generic_set_state, + .get_pins_count = apple_pinctrl_get_pins_count, + .get_pin_name = apple_pinctrl_get_pin_name, + .pinmux_set = apple_pinctrl_pinmux_set, + .pinmux_property_set = apple_pinctrl_pinmux_property_set, + .get_pin_muxing = apple_pinctrl_get_pin_muxing, +}; + +static const struct udevice_id apple_pinctrl_ids[] = { + { .compatible = "apple,pinctrl" }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(pinctrl_apple) = { + .name = "apple_pinctrl", + .id = UCLASS_PINCTRL, + .of_match = apple_pinctrl_ids, + .priv_auto = sizeof(struct apple_pinctrl_priv), + .ops = &apple_pinctrl_ops, + .probe = apple_pinctrl_probe, +};
Mark Kettenis
