DWC3 and UDC cleanup
The following changes since commit 57dbc151437b36cc1105857d222df28b095236d7:
rockchip: rk3399: Add MAINTAINERS entry (2018-12-06 10:24:12 -0500)
git://git.denx.de/u-boot-usb.git master
for you to fetch changes up to 532ededd5cbff3d55e8c8e5b6377cec9e90f2152:
board: ti: am57xx: remove USB platform code (2018-12-07 16:31:46 +0100)
---------------------------------------------------------------- Jean-Jacques Hiblot (19): usb: gadget: Do not call board_usb_xxx() directly in USB gadget drivers usb: introduce a separate config option for DM USB device usb: udc: implement DM versions of usb_gadget_initialize()/_release()/_handle_interrupt() dwc3_generic: do not probe the USB device driver when it's bound dwc3: move phy operation to core.c dm: usb: create a new UCLASS ID for USB gadget devices configs: evb-rk3328: Enable CONFIG_USB_DWC3 dwc3-generic: Handle the PHYs, the clocks and the reset lines dwc3-generic: Add select_dr_mode operation usb: dwc3: Fix a compilation error with the edison defconfig syscon: dm: Add a new method to get a regmap from DTS phy: Add a new driver for OMAP's USB2 PHYs dwc3-generic: Add support for the TI DWC3 glue board: ti: dra7xx-evm: turn on USB clocks in late init stage dts: dra7x: make ocp2scp@4a080000 compatible with simple-bus configs: enable DM_USB and DM_USB_DEV for all DRA7 platforms configs: am57xx_evm: Enable DM_USB and DM_USB_DEV board: ti: dra7-evm: remove USB platform code board: ti: am57xx: remove USB platform code
Vignesh R (2): phy: ti-pip3-phy: Add support for USB3 PHY board; ti: am57xx: turn on USB clocks
arch/arm/Kconfig | 2 ++ arch/arm/dts/omap5-u-boot.dtsi | 4 +++ arch/sandbox/dts/test.dts | 6 ++-- board/sunxi/board.c | 2 +- board/ti/am57xx/board.c | 106 ++++++++++--------------------------------------------- board/ti/dra7xx/evm.c | 123 ++++++++++----------------------------------------------------- cmd/fastboot.c | 4 +-- cmd/rockusb.c | 4 +-- cmd/thordown.c | 4 +-- cmd/usb_gadget_sdp.c | 4 +-- cmd/usb_mass_storage.c | 4 +-- common/dfu.c | 6 ++-- configs/am57xx_evm_defconfig | 12 +++++-- configs/am57xx_hs_evm_defconfig | 12 +++++-- configs/dra7xx_evm_defconfig | 10 +++--- configs/dra7xx_hs_evm_defconfig | 10 +++--- configs/evb-rk3328_defconfig | 1 + drivers/core/syscon-uclass.c | 23 ++++++++++++ drivers/phy/Kconfig | 9 +++++ drivers/phy/Makefile | 1 + drivers/phy/omap-usb2-phy.c | 196 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/phy/ti-pipe3-phy.c | 32 ++++++++++++----- drivers/usb/Kconfig | 14 ++++++++ drivers/usb/dwc3/Kconfig | 7 ++-- drivers/usb/dwc3/core.c | 89 ++++++++++++++++++++++++++++++++++++++++++++-- drivers/usb/dwc3/dwc3-generic.c | 293 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++------------------------ drivers/usb/dwc3/ep0.c | 2 +- drivers/usb/gadget/ether.c | 40 ++++----------------- drivers/usb/gadget/udc/Makefile | 4 +++ drivers/usb/gadget/udc/udc-core.c | 3 +- drivers/usb/gadget/udc/udc-uclass.c | 58 ++++++++++++++++++++++++++++++ drivers/usb/host/xhci-dwc3.c | 95 ++++--------------------------------------------- drivers/usb/musb-new/omap2430.c | 2 +- drivers/usb/musb-new/sunxi.c | 2 +- include/dm/uclass-id.h | 1 + include/dwc3-uboot.h | 19 ++++++++++ include/linux/usb/gadget.h | 18 ++++++++++ include/syscon.h | 13 +++++++ test/dm/syscon.c | 29 +++++++++++++++ 39 files changed, 857 insertions(+), 407 deletions(-) create mode 100644 drivers/phy/omap-usb2-phy.c create mode 100644 drivers/usb/gadget/udc/udc-uclass.c
