[U-Boot] [PATCH u-boot] pinctrl: meson: add pinconf support
Adding pinconf support is necessary to enable boot from SPI without breaking the eMMC. When booting from SPI, the ROM code leave pull downs on the eMMC pad.
We need to set pinconf provided in DT to solve this
Signed-off-by: Jerome Brunet jbrunet@baylibre.com --- drivers/pinctrl/meson/Kconfig | 1 + drivers/pinctrl/meson/pinctrl-meson-axg-pmx.c | 10 ++ drivers/pinctrl/meson/pinctrl-meson-gx-pmx.c | 10 ++ drivers/pinctrl/meson/pinctrl-meson.c | 101 ++++++++++++++++-- drivers/pinctrl/meson/pinctrl-meson.h | 8 ++ 5 files changed, 123 insertions(+), 7 deletions(-)
diff --git a/drivers/pinctrl/meson/Kconfig b/drivers/pinctrl/meson/Kconfig index ee820a57a0e0..162642d7289b 100644 --- a/drivers/pinctrl/meson/Kconfig +++ b/drivers/pinctrl/meson/Kconfig @@ -2,6 +2,7 @@ if ARCH_MESON
config PINCTRL_MESON select PINCTRL_GENERIC + select PINCONF bool
config PINCTRL_MESON_GX_PMX diff --git a/drivers/pinctrl/meson/pinctrl-meson-axg-pmx.c b/drivers/pinctrl/meson/pinctrl-meson-axg-pmx.c index c82413d08f34..f9065723eea9 100644 --- a/drivers/pinctrl/meson/pinctrl-meson-axg-pmx.c +++ b/drivers/pinctrl/meson/pinctrl-meson-axg-pmx.c @@ -93,6 +93,12 @@ static int meson_axg_pinmux_group_set(struct udevice *dev, return 0; }
+const struct pinconf_param meson_axg_pinconf_params[] = { + { "bias-disable", PIN_CONFIG_BIAS_DISABLE, 0 }, + { "bias-pull-up", PIN_CONFIG_BIAS_PULL_UP, 1 }, + { "bias-pull-down", PIN_CONFIG_BIAS_PULL_DOWN, 1 }, +}; + const struct pinctrl_ops meson_axg_pinctrl_ops = { .get_groups_count = meson_pinctrl_get_groups_count, .get_group_name = meson_pinctrl_get_group_name, @@ -100,6 +106,10 @@ const struct pinctrl_ops meson_axg_pinctrl_ops = { .get_function_name = meson_pinmux_get_function_name, .pinmux_group_set = meson_axg_pinmux_group_set, .set_state = pinctrl_generic_set_state, + .pinconf_params = meson_axg_pinconf_params + .pinconf_num_params = ARRAY_SIZE(meson_axg_pinconf_params), + .pinconf_set = meson_pinconf_set, + .pinconf_group_set = meson_pinconf_group_set, };
static int meson_axg_gpio_request(struct udevice *dev, diff --git a/drivers/pinctrl/meson/pinctrl-meson-gx-pmx.c b/drivers/pinctrl/meson/pinctrl-meson-gx-pmx.c index fc1538ea719e..cf72576b6ce2 100644 --- a/drivers/pinctrl/meson/pinctrl-meson-gx-pmx.c +++ b/drivers/pinctrl/meson/pinctrl-meson-gx-pmx.c @@ -72,6 +72,12 @@ static int meson_gx_pinmux_group_set(struct udevice *dev, return 0; }
+const struct pinconf_param meson_gx_pinconf_params[] = { + { "bias-disable", PIN_CONFIG_BIAS_DISABLE, 0 }, + { "bias-pull-up", PIN_CONFIG_BIAS_PULL_UP, 1 }, + { "bias-pull-down", PIN_CONFIG_BIAS_PULL_DOWN, 1 }, +}; + const struct pinctrl_ops meson_gx_pinctrl_ops = { .get_groups_count = meson_pinctrl_get_groups_count, .get_group_name = meson_pinctrl_get_group_name, @@ -79,6 +85,10 @@ const struct pinctrl_ops meson_gx_pinctrl_ops = { .get_function_name = meson_pinmux_get_function_name, .pinmux_group_set = meson_gx_pinmux_group_set, .set_state = pinctrl_generic_set_state, + .pinconf_params = meson_gx_pinconf_params, + .pinconf_num_params = ARRAY_SIZE(meson_gx_pinconf_params), + .pinconf_set = meson_pinconf_set, + .pinconf_group_set = meson_pinconf_group_set, };
static const struct dm_gpio_ops meson_gx_gpio_ops = { diff --git a/drivers/pinctrl/meson/pinctrl-meson.c b/drivers/pinctrl/meson/pinctrl-meson.c index b539749752c8..fa3d78858a9e 100644 --- a/drivers/pinctrl/meson/pinctrl-meson.c +++ b/drivers/pinctrl/meson/pinctrl-meson.c @@ -57,7 +57,7 @@ static int meson_gpio_calc_reg_and_bit(struct udevice *dev, unsigned int offset, enum meson_reg_type reg_type, unsigned int *reg, unsigned int *bit) { - struct meson_pinctrl *priv = dev_get_priv(dev->parent); + struct meson_pinctrl *priv = dev_get_priv(dev); struct meson_bank *bank = NULL; struct meson_reg_desc *desc; unsigned int pin; @@ -89,7 +89,8 @@ int meson_gpio_get(struct udevice *dev, unsigned int offset) unsigned int reg, bit; int ret;
- ret = meson_gpio_calc_reg_and_bit(dev, offset, REG_IN, ®, &bit); + ret = meson_gpio_calc_reg_and_bit(dev->parent, offset, REG_IN, ®, + &bit); if (ret) return ret;
@@ -102,7 +103,8 @@ int meson_gpio_set(struct udevice *dev, unsigned int offset, int value) unsigned int reg, bit; int ret;
- ret = meson_gpio_calc_reg_and_bit(dev, offset, REG_OUT, ®, &bit); + ret = meson_gpio_calc_reg_and_bit(dev->parent, offset, REG_OUT, ®, + &bit); if (ret) return ret;
@@ -117,7 +119,8 @@ int meson_gpio_get_direction(struct udevice *dev, unsigned int offset) unsigned int reg, bit, val; int ret;
- ret = meson_gpio_calc_reg_and_bit(dev, offset, REG_DIR, ®, &bit); + ret = meson_gpio_calc_reg_and_bit(dev->parent, offset, REG_DIR, ®, + &bit); if (ret) return ret;
@@ -132,7 +135,8 @@ int meson_gpio_direction_input(struct udevice *dev, unsigned int offset) unsigned int reg, bit; int ret;
@@ -148,13 +152,15 @@ int meson_gpio_direction_output(struct udevice *dev, unsigned int reg, bit; int ret;
clrbits_le32(priv->reg_gpio + reg, BIT(bit));
@@ -163,6 +169,72 @@ int meson_gpio_direction_output(struct udevice *dev, return 0; }
+static int meson_pinconf_bias_set(struct udevice *dev, unsigned int pin, + unsigned int param) +{ + struct meson_pinctrl *priv = dev_get_priv(dev); + unsigned int offset = pin - priv->data->pin_base; + unsigned int reg, bit; + int ret; + + ret = meson_gpio_calc_reg_and_bit(dev, offset, REG_PULLEN, ®, &bit); + if (ret) + return ret; + + if (param == PIN_CONFIG_BIAS_DISABLE) { + clrsetbits_le32(priv->reg_pullen + reg, BIT(bit), 0); + return 0; + } + + /* othewise, enable the bias and select level */ + clrsetbits_le32(priv->reg_pullen + reg, BIT(bit), 1); + ret = meson_gpio_calc_reg_and_bit(dev, offset, REG_PULL, ®, &bit); + if (ret) + return ret; + + clrsetbits_le32(priv->reg_pull + reg, BIT(bit), + param == PIN_CONFIG_BIAS_PULL_UP); + + return 0; +} + +int meson_pinconf_set(struct udevice *dev, unsigned int pin, + unsigned int param, unsigned int arg) +{ + int ret; + + switch (param) { + case PIN_CONFIG_BIAS_DISABLE: + case PIN_CONFIG_BIAS_PULL_UP: + case PIN_CONFIG_BIAS_PULL_DOWN: + ret = meson_pinconf_bias_set(dev, pin, param); + break; + + default: + dev_err(dev, "unsupported configuration parameter %u\n", param); + return -EINVAL; + } + + return ret; +} + +int meson_pinconf_group_set(struct udevice *dev, + unsigned int group_selector, + unsigned int param, unsigned int arg) +{ + struct meson_pinctrl *priv = dev_get_priv(dev); + struct meson_pmx_group *grp = &priv->data->groups[group_selector]; + int i, ret; + + for (i = 0; i < grp->num_pins; i++) { + ret = meson_pinconf_set(dev, grp->pins[i], param, arg); + if (ret) + return ret; + } + + return 0; +} + int meson_gpio_probe(struct udevice *dev) { struct meson_pinctrl *priv = dev_get_priv(dev->parent); @@ -240,6 +312,21 @@ int meson_pinctrl_probe(struct udevice *dev) return -EINVAL; } priv->reg_gpio = (void __iomem *)addr; + + addr = parse_address(gpio, "pull", na, ns); + if (addr == FDT_ADDR_T_NONE) { + debug("pull address not found\n"); + return -EINVAL; + } + priv->reg_pull = (void __iomem *)addr; + + addr = parse_address(gpio, "pull-enable", na, ns); + /* Use pull region if pull-enable one is not present */ + if (addr == FDT_ADDR_T_NONE) + priv->reg_pullen = priv->reg_pull; + else + priv->reg_pullen = (void __iomem *)addr; + priv->data = (struct meson_pinctrl_data *)dev_get_driver_data(dev);
/* Lookup GPIO driver */ diff --git a/drivers/pinctrl/meson/pinctrl-meson.h b/drivers/pinctrl/meson/pinctrl-meson.h index bdee721fc007..28085a7495d4 100644 --- a/drivers/pinctrl/meson/pinctrl-meson.h +++ b/drivers/pinctrl/meson/pinctrl-meson.h @@ -39,6 +39,8 @@ struct meson_pinctrl { struct meson_pinctrl_data *data; void __iomem *reg_mux; void __iomem *reg_gpio; + void __iomem *reg_pull; + void __iomem *reg_pullen; };
/** @@ -130,4 +132,10 @@ int meson_gpio_direction_output(struct udevice *dev, unsigned int offset, int value); int meson_gpio_probe(struct udevice *dev);
+int meson_pinconf_set(struct udevice *dev, unsigned int pin, + unsigned int param, unsigned int arg); +int meson_pinconf_group_set(struct udevice *dev, + unsigned int group_selector, + unsigned int param, unsigned int arg); + #endif /* __PINCTRL_MESON_H__ */
Hi Jerome,
- select PINCONF bool
- { "bias-disable", PIN_CONFIG_BIAS_DISABLE, 0 },
- { "bias-pull-up", PIN_CONFIG_BIAS_PULL_UP, 1 },
- { "bias-pull-down", PIN_CONFIG_BIAS_PULL_DOWN, 1 },
- .pinconf_params = meson_axg_pinconf_params
- .pinconf_num_params = ARRAY_SIZE(meson_axg_pinconf_params),
- .pinconf_set = meson_pinconf_set,
- .pinconf_group_set = meson_pinconf_group_set,
- .pinconf_params = meson_gx_pinconf_params,
- .pinconf_num_params = ARRAY_SIZE(meson_gx_pinconf_params),
- struct meson_pinctrl *priv = dev_get_priv(dev); struct meson_bank *bank = NULL; struct meson_reg_desc *desc; unsigned int pin;
- ret = meson_gpio_calc_reg_and_bit(dev->parent, offset, REG_IN, ®,
if (ret) return ret;&bit);
- ret = meson_gpio_calc_reg_and_bit(dev->parent, offset, REG_OUT, ®,
- ret = meson_gpio_calc_reg_and_bit(dev->parent, offset, REG_DIR, ®,
&bit);
unsigned int param)
- unsigned int offset = pin - priv->data->pin_base;
- unsigned int reg, bit;
- int ret;
- ret = meson_gpio_calc_reg_and_bit(dev, offset, REG_PULLEN, ®, &bit);
- if (ret)
return ret;
- if (param == PIN_CONFIG_BIAS_DISABLE) {
- /* othewise, enable the bias and select level */
- clrsetbits_le32(priv->reg_pullen + reg, BIT(bit), 1);
- ret = meson_gpio_calc_reg_and_bit(dev, offset, REG_PULL, ®, &bit);
- if (ret)
return ret;
- clrsetbits_le32(priv->reg_pull + reg, BIT(bit),
- int ret;
- switch (param) {
- case PIN_CONFIG_BIAS_DISABLE:
- case PIN_CONFIG_BIAS_PULL_UP:
- case PIN_CONFIG_BIAS_PULL_DOWN:
break;
- default:
return -EINVAL;
- return ret;
- struct meson_pmx_group *grp = &priv->data->groups[group_selector];
- int i, ret;
- for (i = 0; i < grp->num_pins; i++) {
if (ret)
return ret;
return -EINVAL;
else
- void __iomem *reg_pull;
- void __iomem *reg_pullen;
Looks good to me,
Applied to u-boot-amlogic
Neil
Jerome Brunet
Neil Armstrong
