Hi Tom,
The following changes since commit 14f2d087a3d6347ba0ff7a7e9aaff6955e53e7a8:
Merge tag 'sound-2023-01-rc4' of https://source.denx.de/u-boot/custodians/u-boot-efi (2022-12-06 10:07:01 -0500)
https://source.denx.de/u-boot/custodians/u-boot-riscv.git
for you to fetch changes up to 57b9900cd59ad492f74390515901788459f1e8aa:
riscv: use imply instead of select for SPL_SEPARATE_BSS (2022-12-08 15:50:22 +0800)
CI result shows no issue: https://source.denx.de/u-boot/custodians/u-boot-riscv/-/pipelines/14369
- Kautuk's semihosting patch: move semihosting library from arm directory to common place and add RISC-V support
- Zong's Kconfig patch: use "imply" instead of "select" to allow user to decide if SPL_SEPARATE_BSS should be selected
---------------------------------------------------------------- Kautuk Consul (3): lib: Add common semihosting library arch/riscv: add semihosting support for RISC-V common/spl/Kconfig: add dependency on SPL_SEMIHOSTING for SPL payload
Zong Li (1): riscv: use imply instead of select for SPL_SEPARATE_BSS
arch/Kconfig | 2 +- arch/arm/Kconfig | 46 ---------------------------------------------- arch/arm/lib/semihosting.c | 181 +------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------ arch/riscv/include/asm/spl.h | 1 + arch/riscv/lib/Makefile | 2 ++ arch/riscv/lib/interrupts.c | 25 +++++++++++++++++++++++++ arch/riscv/lib/semihosting.c | 24 ++++++++++++++++++++++++ common/spl/Kconfig | 2 +- include/semihosting.h | 11 +++++++++++ lib/Kconfig | 47 +++++++++++++++++++++++++++++++++++++++++++++++ lib/Makefile | 2 ++ lib/semihosting.c | 186 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 12 files changed, 301 insertions(+), 228 deletions(-) create mode 100644 arch/riscv/lib/semihosting.c create mode 100644 lib/semihosting.c
Best regards, Leo
On Thu, Dec 08, 2022 at 11:23:37AM +0000, Leo Liang wrote:
Hi Tom,
Leo Liang
