[PATCH v2 00/14] tools: patman: Convert Python tools to use absolute imports
At present the Python tools use relative paths to find modules they use from another tool. This means we need to adjust the sys.path variable at times. It also makes installing the tools (with python setup.py install) more difficult, since once installed the path of the executable (e.g. /usr/bin) is not the same as where the modules are installed (e.g. /usr/local/lib/python3.6/dist-packages).
It is better to use absolute paths. This series makes this adjustment, with 'tools/' as the base directory. Once the tools are installed, things work correctly.
Changes in v2: - Expand to convert all Python tools in U-Boot
Simon Glass (14): patman: Rename the main module rmboard: Move to Python 3 patman: Drop references to __future__ patman: Drop Python 2 StringIO code buildman: Rename the main module dtoc: Rename the main module binman: Rename the main module Add a 'make tcheck' option to test tools patman: Drop the python2 code in test coverage patman: Move test running/reporting to test_util buildman: Move to absolute imports binman: Move to absolute imports patman: Move to absolute imports patman: Tidy up sys.path changes
Makefile | 6 +- test/run | 26 ++-- tools/binman/binman | 2 +- tools/binman/cbfs_util.py | 8 +- tools/binman/cbfs_util_test.py | 12 +- tools/binman/control.py | 20 ++- tools/binman/elf.py | 8 +- tools/binman/elf_test.py | 10 +- tools/binman/entry.py | 22 +-- tools/binman/entry_test.py | 12 +- tools/binman/etype/__init__.py | 0 tools/binman/etype/_testing.py | 6 +- tools/binman/etype/blob.py | 8 +- tools/binman/etype/blob_dtb.py | 6 +- tools/binman/etype/blob_named_by_arg.py | 4 +- tools/binman/etype/cbfs.py | 10 +- tools/binman/etype/cros_ec_rw.py | 2 +- tools/binman/etype/fdtmap.py | 10 +- tools/binman/etype/files.py | 8 +- tools/binman/etype/fill.py | 6 +- tools/binman/etype/fmap.py | 10 +- tools/binman/etype/gbb.py | 8 +- tools/binman/etype/image_header.py | 4 +- tools/binman/etype/intel_cmc.py | 4 +- tools/binman/etype/intel_descriptor.py | 4 +- tools/binman/etype/intel_fit.py | 2 +- tools/binman/etype/intel_fit_ptr.py | 2 +- tools/binman/etype/intel_fsp.py | 4 +- tools/binman/etype/intel_fsp_m.py | 4 +- tools/binman/etype/intel_fsp_s.py | 4 +- tools/binman/etype/intel_fsp_t.py | 4 +- tools/binman/etype/intel_ifwi.py | 8 +- tools/binman/etype/intel_me.py | 4 +- tools/binman/etype/intel_mrc.py | 4 +- tools/binman/etype/intel_refcode.py | 4 +- tools/binman/etype/intel_vbt.py | 4 +- tools/binman/etype/intel_vga.py | 4 +- .../etype/powerpc_mpc85xx_bootpg_resetvec.py | 4 +- tools/binman/etype/section.py | 10 +- tools/binman/etype/text.py | 6 +- tools/binman/etype/u_boot.py | 4 +- tools/binman/etype/u_boot_dtb.py | 4 +- tools/binman/etype/u_boot_dtb_with_ucode.py | 10 +- tools/binman/etype/u_boot_elf.py | 8 +- tools/binman/etype/u_boot_img.py | 4 +- tools/binman/etype/u_boot_nodtb.py | 4 +- tools/binman/etype/u_boot_spl.py | 7 +- tools/binman/etype/u_boot_spl_bss_pad.py | 10 +- tools/binman/etype/u_boot_spl_dtb.py | 4 +- tools/binman/etype/u_boot_spl_elf.py | 4 +- tools/binman/etype/u_boot_spl_nodtb.py | 4 +- .../binman/etype/u_boot_spl_with_ucode_ptr.py | 6 +- tools/binman/etype/u_boot_tpl.py | 7 +- tools/binman/etype/u_boot_tpl_dtb.py | 4 +- .../binman/etype/u_boot_tpl_dtb_with_ucode.py | 5 +- tools/binman/etype/u_boot_tpl_elf.py | 4 +- .../binman/etype/u_boot_tpl_with_ucode_ptr.py | 10 +- tools/binman/etype/u_boot_ucode.py | 6 +- tools/binman/etype/u_boot_with_ucode_ptr.py | 12 +- tools/binman/etype/vblock.py | 6 +- tools/binman/etype/x86_reset16.py | 4 +- tools/binman/etype/x86_reset16_spl.py | 4 +- tools/binman/etype/x86_reset16_tpl.py | 4 +- tools/binman/etype/x86_start16.py | 4 +- tools/binman/etype/x86_start16_spl.py | 4 +- tools/binman/etype/x86_start16_tpl.py | 4 +- tools/binman/fdt_test.py | 8 +- tools/binman/fmap_util.py | 2 +- tools/binman/ftest.py | 49 ++++--- tools/binman/image.py | 18 ++- tools/binman/image_test.py | 2 +- tools/binman/{binman.py => main.py} | 110 ++++----------- tools/binman/state.py | 10 +- tools/buildman/builder.py | 12 +- tools/buildman/builderthread.py | 4 +- tools/buildman/buildman | 2 +- tools/buildman/control.py | 20 +-- tools/buildman/func_test.py | 18 +-- tools/buildman/{buildman.py => main.py} | 27 ++-- tools/buildman/test.py | 23 ++-- tools/buildman/toolchain.py | 8 +- tools/dtoc/dtb_platdata.py | 6 +- tools/dtoc/dtoc | 2 +- tools/dtoc/fdt.py | 4 +- tools/dtoc/fdt_util.py | 4 +- tools/dtoc/{dtoc.py => main.py} | 10 +- tools/dtoc/test_dtoc.py | 12 +- tools/dtoc/test_fdt.py | 17 +-- tools/genboardscfg.py | 3 +- tools/moveconfig.py | 8 +- tools/patman/checkpatch.py | 8 +- tools/patman/command.py | 5 +- tools/patman/func_test.py | 15 +-- tools/patman/get_maintainer.py | 5 +- tools/patman/gitutil.py | 12 +- tools/patman/{patman.py => main.py} | 27 ++-- tools/patman/patchstream.py | 8 +- tools/patman/patman | 2 +- tools/patman/project.py | 2 +- tools/patman/series.py | 12 +- tools/patman/settings.py | 13 +- tools/patman/terminal.py | 2 - tools/patman/test.py | 10 +- tools/patman/test_util.py | 125 ++++++++++++++++-- tools/patman/tools.py | 6 +- tools/patman/tout.py | 4 +- tools/rmboard.py | 7 +- 107 files changed, 529 insertions(+), 544 deletions(-) delete mode 100644 tools/binman/etype/__init__.py rename tools/binman/{binman.py => main.py} (54%) rename tools/buildman/{buildman.py => main.py} (76%) rename tools/dtoc/{dtoc.py => main.py} (94%) rename tools/patman/{patman.py => main.py} (93%)
Python does not like the module name being the same as the module directory. To allow patman modules to be used from other tools, rename it.
Changes in v2: None
tools/patman/{patman.py => main.py} | 27 ++++++++++++++------------- tools/patman/patman | 2 +- 2 files changed, 15 insertions(+), 14 deletions(-) rename tools/patman/{patman.py => main.py} (93%)
diff --git a/tools/patman/patman.py b/tools/patman/main.py similarity index 93% rename from tools/patman/patman.py rename to tools/patman/main.py index 7f4ac9aef4..f3d9c0c434 100755 --- a/tools/patman/patman.py +++ b/tools/patman/main.py @@ -12,19 +12,20 @@ import re import sys import unittest
+if __name__ == "__main__": + # Allow 'from patman import xxx to work' + our_path = os.path.dirname(os.path.realpath(__file__)) + sys.path.append(os.path.join(our_path, '..')) + # Our modules -try: - from patman import checkpatch, command, gitutil, patchstream, \ - project, settings, terminal, test -except ImportError: - import checkpatch - import command - import gitutil - import patchstream - import project - import settings - import terminal - import test +from patman import checkpatch +from patman import command +from patman import gitutil +from patman import patchstream +from patman import project +from patman import settings +from patman import terminal +from patman import test
parser = OptionParser() @@ -85,7 +86,7 @@ if __name__ != "__main__": # Run our meagre tests elif options.test: import doctest - import func_test + from patman import func_test
sys.argv = [sys.argv[0]] result = unittest.TestResult() diff --git a/tools/patman/patman b/tools/patman/patman index 6cc3d7a56a..11a5d8e18a 120000 --- a/tools/patman/patman +++ b/tools/patman/patman @@ -1 +1 @@ -patman.py \ No newline at end of file +main.py \ No newline at end of file
Changes in v2: None
Applied to u-boot-dm, thanks!
This script already works with Python 3. Make it use that by default so that it can import the patman libraries.
Changes in v2: None
tools/rmboard.py | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/rmboard.py b/tools/rmboard.py index df4f04b01c..1feface61d 100755 --- a/tools/rmboard.py +++ b/tools/rmboard.py @@ -1,4 +1,4 @@ -#! /usr/bin/python +#! /usr/bin/python3 # SPDX-License-Identifier: GPL-2.0+ # Copyright 2019 Google LLC #
Changes in v2: None
We don't need these now that the tools using Python 3. Drop them.
Changes in v2: None
tools/binman/binman.py | 2 -- tools/binman/cbfs_util.py | 2 -- tools/binman/cbfs_util_test.py | 2 -- tools/binman/control.py | 2 -- tools/binman/elf.py | 2 -- tools/binman/entry.py | 2 -- tools/binman/etype/section.py | 2 -- tools/binman/ftest.py | 2 -- tools/binman/image.py | 2 -- tools/buildman/buildman.py | 2 -- tools/dtoc/dtoc.py | 2 -- tools/dtoc/test_dtoc.py | 2 -- tools/dtoc/test_fdt.py | 2 -- tools/patman/series.py | 2 -- tools/patman/settings.py | 2 -- tools/patman/terminal.py | 2 -- tools/patman/test_util.py | 2 -- tools/patman/tools.py | 2 -- tools/patman/tout.py | 2 -- tools/rmboard.py | 2 -- 20 files changed, 40 deletions(-)
diff --git a/tools/binman/binman.py b/tools/binman/binman.py index 9e6fd72117..ec152e9b3b 100755 --- a/tools/binman/binman.py +++ b/tools/binman/binman.py @@ -9,8 +9,6 @@
"""See README for more information"""
-from __future__ import print_function - from distutils.sysconfig import get_python_lib import glob import multiprocessing diff --git a/tools/binman/cbfs_util.py b/tools/binman/cbfs_util.py index 99d77878c9..34c5116688 100644 --- a/tools/binman/cbfs_util.py +++ b/tools/binman/cbfs_util.py @@ -15,8 +15,6 @@ Currently supported: raw and stage types with compression, padding empty areas with empty files, fixed-offset files """
-from __future__ import print_function - from collections import OrderedDict import io import struct diff --git a/tools/binman/cbfs_util_test.py b/tools/binman/cbfs_util_test.py index ddc2e09e35..4aa2494fee 100755 --- a/tools/binman/cbfs_util_test.py +++ b/tools/binman/cbfs_util_test.py @@ -9,8 +9,6 @@ These create and read various CBFSs and compare the results with expected values and with cbfstool """
-from __future__ import print_function - import io import os import shutil diff --git a/tools/binman/control.py b/tools/binman/control.py index 68ad5fc2c0..82bc90d802 100644 --- a/tools/binman/control.py +++ b/tools/binman/control.py @@ -5,8 +5,6 @@ # Creates binary images from input files controlled by a description #
-from __future__ import print_function - from collections import OrderedDict import os import sys diff --git a/tools/binman/elf.py b/tools/binman/elf.py index de1ce73f2a..29fdac1b8f 100644 --- a/tools/binman/elf.py +++ b/tools/binman/elf.py @@ -5,8 +5,6 @@ # Handle various things related to ELF images #
-from __future__ import print_function - from collections import namedtuple, OrderedDict import command import io diff --git a/tools/binman/entry.py b/tools/binman/entry.py index b6f1b2c93f..1244d36c20 100644 --- a/tools/binman/entry.py +++ b/tools/binman/entry.py @@ -4,8 +4,6 @@ # Base class for all entries #
-from __future__ import print_function - from collections import namedtuple import importlib import os diff --git a/tools/binman/etype/section.py b/tools/binman/etype/section.py index 89b7bf67fa..87b3ddce86 100644 --- a/tools/binman/etype/section.py +++ b/tools/binman/etype/section.py @@ -8,8 +8,6 @@ Sections are entries which can contain other entries. This allows hierarchical images to be created. """
-from __future__ import print_function - from collections import OrderedDict import re import sys diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 872b855444..67f976e5d0 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -6,8 +6,6 @@ # # python -m unittest func_test.TestFunctional.testHelp
-from __future__ import print_function - import hashlib from optparse import OptionParser import os diff --git a/tools/binman/image.py b/tools/binman/image.py index 2beab7fd4d..3e961733f9 100644 --- a/tools/binman/image.py +++ b/tools/binman/image.py @@ -5,8 +5,6 @@ # Class for an image, the output of binman #
-from __future__ import print_function - from collections import OrderedDict import fnmatch from operator import attrgetter diff --git a/tools/buildman/buildman.py b/tools/buildman/buildman.py index 30a8690f93..0add628a63 100755 --- a/tools/buildman/buildman.py +++ b/tools/buildman/buildman.py @@ -6,8 +6,6 @@
-from __future__ import print_function - import multiprocessing import os import re diff --git a/tools/dtoc/dtoc.py b/tools/dtoc/dtoc.py index b3596a5918..f7ed62cd67 100755 --- a/tools/dtoc/dtoc.py +++ b/tools/dtoc/dtoc.py @@ -25,8 +25,6 @@ options. For more information about the use of this options and tool please see doc/driver-model/of-plat.txt """
-from __future__ import print_function - from optparse import OptionParser import os import sys diff --git a/tools/dtoc/test_dtoc.py b/tools/dtoc/test_dtoc.py index d733b70655..9db97489d4 100755 --- a/tools/dtoc/test_dtoc.py +++ b/tools/dtoc/test_dtoc.py @@ -9,8 +9,6 @@ This includes unit tests for some functions and functional tests for the dtoc tool. """
-from __future__ import print_function - import collections import os import struct diff --git a/tools/dtoc/test_fdt.py b/tools/dtoc/test_fdt.py index 3316757e61..4f39a5589f 100755 --- a/tools/dtoc/test_fdt.py +++ b/tools/dtoc/test_fdt.py @@ -4,8 +4,6 @@ # Written by Simon Glass sjg@chromium.org #
-from __future__ import print_function - from optparse import OptionParser import glob import os diff --git a/tools/patman/series.py b/tools/patman/series.py index 6d9d48b123..3869696abc 100644 --- a/tools/patman/series.py +++ b/tools/patman/series.py @@ -2,8 +2,6 @@ # Copyright (c) 2011 The Chromium OS Authors. #
-from __future__ import print_function - import itertools import os
diff --git a/tools/patman/settings.py b/tools/patman/settings.py index 5dc83a8500..9ac96c485d 100644 --- a/tools/patman/settings.py +++ b/tools/patman/settings.py @@ -2,8 +2,6 @@ # Copyright (c) 2011 The Chromium OS Authors. #
-from __future__ import print_function - try: import configparser as ConfigParser except: diff --git a/tools/patman/terminal.py b/tools/patman/terminal.py index 5c9e3eea20..c709438bdc 100644 --- a/tools/patman/terminal.py +++ b/tools/patman/terminal.py @@ -7,8 +7,6 @@ This module handles terminal interaction including ANSI color codes. """
-from __future__ import print_function - import os import re import shutil diff --git a/tools/patman/test_util.py b/tools/patman/test_util.py index 09f258c26b..4338dbcd28 100644 --- a/tools/patman/test_util.py +++ b/tools/patman/test_util.py @@ -3,8 +3,6 @@ # Copyright (c) 2016 Google, Inc #
-from __future__ import print_function - from contextlib import contextmanager import glob import os diff --git a/tools/patman/tools.py b/tools/patman/tools.py index 3feddb292f..7b21a128f3 100644 --- a/tools/patman/tools.py +++ b/tools/patman/tools.py @@ -3,8 +3,6 @@ # Copyright (c) 2016 Google, Inc #
-from __future__ import print_function - import command import glob import os diff --git a/tools/patman/tout.py b/tools/patman/tout.py index 2a384851b0..ee3c519c80 100644 --- a/tools/patman/tout.py +++ b/tools/patman/tout.py @@ -4,8 +4,6 @@ # Terminal output logging. #
-from __future__ import print_function - import sys
import terminal diff --git a/tools/rmboard.py b/tools/rmboard.py index 1feface61d..446e5d6ee2 100755 --- a/tools/rmboard.py +++ b/tools/rmboard.py @@ -23,8 +23,6 @@ This script works by: Search for ## to update the commit message manually. """
-from __future__ import print_function - import glob import os import re
Changes in v2: None
We can rely on Python 3 now, so drop the workaround for importing StringIO.
Changes in v2: None
tools/patman/func_test.py | 5 +---- tools/patman/settings.py | 5 +---- tools/patman/test_util.py | 5 +---- 3 files changed, 3 insertions(+), 12 deletions(-)
diff --git a/tools/patman/func_test.py b/tools/patman/func_test.py index 76319fff37..748e225446 100644 --- a/tools/patman/func_test.py +++ b/tools/patman/func_test.py @@ -12,10 +12,7 @@ import sys import tempfile import unittest
-try: - from StringIO import StringIO -except ImportError: - from io import StringIO +from io import StringIO
import gitutil import patchstream diff --git a/tools/patman/settings.py b/tools/patman/settings.py index 9ac96c485d..21e8fc41a9 100644 --- a/tools/patman/settings.py +++ b/tools/patman/settings.py @@ -34,10 +34,7 @@ class _ProjectConfigParser(ConfigParser.SafeConfigParser): - Merge general default settings/aliases with project-specific ones.
# Sample config used for tests below... - >>> try: - ... from StringIO import StringIO - ... except ImportError: - ... from io import StringIO + >>> from io import StringIO >>> sample_config = ''' ... [alias] ... me: Peter P. likesspiders@example.com diff --git a/tools/patman/test_util.py b/tools/patman/test_util.py index 4338dbcd28..4d0085e2ed 100644 --- a/tools/patman/test_util.py +++ b/tools/patman/test_util.py @@ -10,10 +10,7 @@ import sys
import command
PYTHON = 'python%d' % sys.version_info[0]
Changes in v2: None
Python does not like the module name being the same as the module directory. To allow buildman modules to be used from other tools, rename it.
Changes in v2: None
tools/buildman/buildman | 2 +- tools/buildman/{buildman.py => main.py} | 0 2 files changed, 1 insertion(+), 1 deletion(-) rename tools/buildman/{buildman.py => main.py} (100%)
diff --git a/tools/buildman/buildman b/tools/buildman/buildman index e4fba2d4b0..11a5d8e18a 120000 --- a/tools/buildman/buildman +++ b/tools/buildman/buildman @@ -1 +1 @@ -buildman.py \ No newline at end of file +main.py \ No newline at end of file diff --git a/tools/buildman/buildman.py b/tools/buildman/main.py similarity index 100% rename from tools/buildman/buildman.py rename to tools/buildman/main.py
Changes in v2: None
Python does not like the module name being the same as the module directory. To allow dtoc modules to be used from other tools, rename it.
Changes in v2: None
tools/dtoc/dtoc | 2 +- tools/dtoc/{dtoc.py => main.py} | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-) rename tools/dtoc/{dtoc.py => main.py} (98%)
diff --git a/tools/dtoc/dtoc b/tools/dtoc/dtoc index 896ca44e62..11a5d8e18a 120000 --- a/tools/dtoc/dtoc +++ b/tools/dtoc/dtoc @@ -1 +1 @@ -dtoc.py \ No newline at end of file +main.py \ No newline at end of file diff --git a/tools/dtoc/dtoc.py b/tools/dtoc/main.py similarity index 98% rename from tools/dtoc/dtoc.py rename to tools/dtoc/main.py index f7ed62cd67..ac0e364bf2 100755 --- a/tools/dtoc/dtoc.py +++ b/tools/dtoc/main.py @@ -77,7 +77,7 @@ def run_tests(args): def RunTestCoverage(): """Run the tests and check that we get 100% coverage""" sys.argv = [sys.argv[0]] - test_util.RunTestCoverage('tools/dtoc/dtoc.py', '/dtoc.py', + test_util.RunTestCoverage('tools/dtoc/dtoc', '/main.py', ['tools/patman/*.py', '*/fdt*', '*test*'], options.build_dir)
Changes in v2: None
Changes in v2: None
tools/binman/binman | 2 +- tools/binman/ftest.py | 6 +++--- tools/binman/{binman.py => main.py} | 4 ++-- tools/patman/test_util.py | 2 +- 4 files changed, 7 insertions(+), 7 deletions(-) rename tools/binman/{binman.py => main.py} (98%)
diff --git a/tools/binman/binman b/tools/binman/binman index 979b7e4d4b..11a5d8e18a 120000 --- a/tools/binman/binman +++ b/tools/binman/binman @@ -1 +1 @@ -binman.py \ No newline at end of file +main.py \ No newline at end of file diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 67f976e5d0..0e2b50771e 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -15,7 +15,7 @@ import sys import tempfile import unittest
-import binman +import main import cbfs_util import cmdline import command @@ -1428,14 +1428,14 @@ class TestFunctional(unittest.TestCase): def testEntryDocs(self): """Test for creation of entry documentation""" with test_util.capture_sys_output() as (stdout, stderr): - control.WriteEntryDocs(binman.GetEntryModules()) + control.WriteEntryDocs(main.GetEntryModules()) self.assertTrue(len(stdout.getvalue()) > 0)
def testEntryDocsMissing(self): """Test handling of missing entry documentation""" with self.assertRaises(ValueError) as e: with test_util.capture_sys_output() as (stdout, stderr): - control.WriteEntryDocs(binman.GetEntryModules(), 'u_boot') + control.WriteEntryDocs(main.GetEntryModules(), 'u_boot') self.assertIn('Documentation is missing for modules: u_boot', str(e.exception))
diff --git a/tools/binman/binman.py b/tools/binman/main.py similarity index 98% rename from tools/binman/binman.py rename to tools/binman/main.py index ec152e9b3b..daff7ae4d3 100755 --- a/tools/binman/binman.py +++ b/tools/binman/main.py @@ -155,8 +155,8 @@ def RunTestCoverage(): glob_list = GetEntryModules(False) all_set = set([os.path.splitext(os.path.basename(item))[0] for item in glob_list if '_testing' not in item]) - test_util.RunTestCoverage('tools/binman/binman.py', None, - ['*test*', '*binman.py', 'tools/patman/*', 'tools/dtoc/*'], + test_util.RunTestCoverage('tools/binman/binman', None, + ['*test*', '*main.py', 'tools/patman/*', 'tools/dtoc/*'], args.build_dir, all_set)
def RunBinman(args): diff --git a/tools/patman/test_util.py b/tools/patman/test_util.py index 4d0085e2ed..76dbc21e3a 100644 --- a/tools/patman/test_util.py +++ b/tools/patman/test_util.py @@ -41,7 +41,7 @@ def RunTestCoverage(prog, filter_fname, exclude_list, build_dir, required=None): glob_list = [] glob_list += exclude_list glob_list += ['*libfdt.py', '*site-packages*', '*dist-packages*'] - test_cmd = 'test' if 'binman.py' in prog else '-t' + test_cmd = 'test' if 'binman' in prog else '-t' cmd = ('PYTHONPATH=$PYTHONPATH:%s/sandbox_spl/tools %s-coverage run ' '--omit "%s" %s %s -P1' % (build_dir, PYTHON, ','.join(glob_list), prog, test_cmd))
Changes in v2: None
Running all the unit tests takes a while and is not useful when you are just modifying the tools. Add an option to run only the tools tests.
Changes in v2: None
Makefile | 6 +++++- test/run | 26 ++++++++++++++++---------- 2 files changed, 21 insertions(+), 11 deletions(-)
diff --git a/Makefile b/Makefile index 26307fd4a6..4a9d2c383f 100644 --- a/Makefile +++ b/Makefile @@ -512,7 +512,7 @@ dt_h := include/generated/dt.h
no-dot-config-targets := clean clobber mrproper distclean \ help %docs check% coccicheck \ - ubootversion backup tests check qcheck + ubootversion backup tests check qcheck tcheck
config-targets := 0 mixed-targets := 0 @@ -2096,6 +2096,7 @@ help: @echo '' @echo ' check - Run all automated tests that use sandbox' @echo ' qcheck - Run quick automated tests that use sandbox' + @echo ' tcheck - Run quick automated tests on tools' @echo '' @echo 'Other generic targets:' @echo ' all - Build all necessary images depending on configuration' @@ -2141,6 +2142,9 @@ tests check: qcheck: $(srctree)/test/run quick
+tcheck: + $(srctree)/test/run tools + # Documentation targets # --------------------------------------------------------------------------- DOC_TARGETS := xmldocs latexdocs pdfdocs htmldocs epubdocs cleandocs \ diff --git a/test/run b/test/run index d635622c10..27331a8e40 100755 --- a/test/run +++ b/test/run @@ -15,22 +15,29 @@ run_test() {
# SKip slow tests if requested [ "$1" == "quick" ] && mark_expr="not slow" +[ "$1" == "quick" ] && skip=--skip-net-tests +[ "$1" == "tools" ] && tools_only=y
failures=0
-# Run all tests that the standard sandbox build can support -run_test "sandbox" ./test/py/test.py --bd sandbox --build -m "${mark_expr}" +if [ -z "$tools_only" ]; then + # Run all tests that the standard sandbox build can support + run_test "sandbox" ./test/py/test.py --bd sandbox --build \ + -m "${mark_expr}" +fi
# Run tests which require sandbox_spl run_test "sandbox_spl" ./test/py/test.py --bd sandbox_spl --build \ - -k 'test_ofplatdata or test_handoff' + -k 'test_ofplatdata or test_handoff'
-# Run tests for the flat-device-tree version of sandbox. This is a special -# build which does not enable CONFIG_OF_LIVE for the live device tree, so we can -# check that functionality is the same. The standard sandbox build (above) uses -# CONFIG_OF_LIVE. -run_test "sandbox_flattree" ./test/py/test.py --bd sandbox_flattree --build \ - -k test_ut +if [ -z "$tools_only" ]; then + # Run tests for the flat-device-tree version of sandbox. This is a special + # build which does not enable CONFIG_OF_LIVE for the live device tree, so we can + # check that functionality is the same. The standard sandbox build (above) uses + # CONFIG_OF_LIVE. + run_test "sandbox_flattree" ./test/py/test.py --bd sandbox_flattree \ + --build -k test_ut +fi
# Set up a path to dtc (device-tree compiler) and libfdt.py, a library it # provides and which is built by the sandbox_spl config. Also set up the path @@ -43,7 +50,6 @@ TOOLS_DIR=build-sandbox_spl/tools run_test "binman" ./tools/binman/binman --toolpath ${TOOLS_DIR} test run_test "patman" ./tools/patman/patman --test
-[ "$1" == "quick" ] && skip=--skip-net-tests run_test "buildman" ./tools/buildman/buildman -t ${skip} run_test "fdt" ./tools/dtoc/test_fdt -t run_test "dtoc" ./tools/dtoc/dtoc -t
Changes in v2: None
We don't need to run test coverage with Python 2 now. Drop the special-case code.
Changes in v2: None
tools/patman/test_util.py | 15 ++++++++------- 1 file changed, 8 insertions(+), 7 deletions(-)
diff --git a/tools/patman/test_util.py b/tools/patman/test_util.py index 76dbc21e3a..6575b11c1a 100644 --- a/tools/patman/test_util.py +++ b/tools/patman/test_util.py @@ -12,8 +12,6 @@ import command
-PYTHON = 'python%d' % sys.version_info[0] -
def RunTestCoverage(prog, filter_fname, exclude_list, build_dir, required=None): """Run tests and check that we get 100% coverage @@ -42,11 +40,14 @@ def RunTestCoverage(prog, filter_fname, exclude_list, build_dir, required=None): glob_list += exclude_list glob_list += ['*libfdt.py', '*site-packages*', '*dist-packages*'] test_cmd = 'test' if 'binman' in prog else '-t' - cmd = ('PYTHONPATH=$PYTHONPATH:%s/sandbox_spl/tools %s-coverage run ' - '--omit "%s" %s %s -P1' % (build_dir, PYTHON, ','.join(glob_list), + prefix = '' + if build_dir: + prefix = 'PYTHONPATH=$PYTHONPATH:%s/sandbox_spl/tools ' % build_dir + cmd = ('%spython3-coverage run ' + '--omit "%s" %s %s -P1' % (prefix, ','.join(glob_list), prog, test_cmd)) os.system(cmd) - stdout = command.Output('%s-coverage' % PYTHON, 'report') + stdout = command.Output('python3-coverage', 'report') lines = stdout.splitlines() if required: # Convert '/path/to/name.py' just the module name 'name' @@ -65,8 +66,8 @@ def RunTestCoverage(prog, filter_fname, exclude_list, build_dir, required=None): print(coverage) if coverage != '100%': print(stdout) - print("Type '%s-coverage html' to get a report in " - 'htmlcov/index.html' % PYTHON) + print("Type 'python3-coverage html' to get a report in " + 'htmlcov/index.html') print('Coverage error: %s, but should be 100%%' % coverage) ok = False if not ok:
Changes in v2: None
This code is useful in other tools. Move it into a common file so it can be shared.
Changes in v2: None
tools/binman/main.py | 78 +++-------------------------- tools/patman/test_util.py | 100 ++++++++++++++++++++++++++++++++++++++ 2 files changed, 108 insertions(+), 70 deletions(-)
diff --git a/tools/binman/main.py b/tools/binman/main.py index daff7ae4d3..a17764cdb0 100755 --- a/tools/binman/main.py +++ b/tools/binman/main.py @@ -11,7 +11,6 @@
from distutils.sysconfig import get_python_lib import glob -import multiprocessing import os import site import sys @@ -37,11 +36,6 @@ sys.path.append(get_python_lib())
import cmdline import command -use_concurrent = True -try: - from concurrencytest import ConcurrentTestSuite, fork_for_tests -except: - use_concurrent = False import control import test_util
@@ -71,73 +65,17 @@ def RunTests(debug, verbosity, processes, test_preserve_dirs, args, toolpath): import doctest
result = unittest.TestResult() - for module in []: - suite = doctest.DocTestSuite(module) - suite.run(result) - - sys.argv = [sys.argv[0]] - if debug: - sys.argv.append('-D') - if verbosity: - sys.argv.append('-v%d' % verbosity) - if toolpath: - for path in toolpath: - sys.argv += ['--toolpath', path] + test_name = args and args[0] or None
# Run the entry tests first ,since these need to be the first to import the # 'entry' module. - test_name = args and args[0] or None - suite = unittest.TestSuite() - loader = unittest.TestLoader() - for module in (entry_test.TestEntry, ftest.TestFunctional, fdt_test.TestFdt, - elf_test.TestElf, image_test.TestImage, - cbfs_util_test.TestCbfs): - # Test the test module about our arguments, if it is interested - if hasattr(module, 'setup_test_args'): - setup_test_args = getattr(module, 'setup_test_args') - setup_test_args(preserve_indir=test_preserve_dirs, - preserve_outdirs=test_preserve_dirs and test_name is not None, - toolpath=toolpath, verbosity=verbosity) - if test_name: - try: - suite.addTests(loader.loadTestsFromName(test_name, module)) - except AttributeError: - continue - else: - suite.addTests(loader.loadTestsFromTestCase(module)) - if use_concurrent and processes != 1: - concurrent_suite = ConcurrentTestSuite(suite, - fork_for_tests(processes or multiprocessing.cpu_count())) - concurrent_suite.run(result) - else: - suite.run(result) - - # Remove errors which just indicate a missing test. Since Python v3.5 If an - # ImportError or AttributeError occurs while traversing name then a - # synthetic test that raises that error when run will be returned. These - # errors are included in the errors accumulated by result.errors. - if test_name: - errors = [] - for test, err in result.errors: - if ("has no attribute '%s'" % test_name) not in err: - errors.append((test, err)) - result.testsRun -= 1 - result.errors = errors - - print(result) - for test, err in result.errors: - print(test.id(), err) - for test, err in result.failures: - print(err, result.failures) - if result.skipped: - print('%d binman test%s SKIPPED:' % - (len(result.skipped), 's' if len(result.skipped) > 1 else '')) - for skip_info in result.skipped: - print('%s: %s' % (skip_info[0], skip_info[1])) - if result.errors or result.failures: - print('binman tests FAILED') - return 1 - return 0 + test_util.RunTestSuites( + result, debug, verbosity, test_preserve_dirs, processes, test_name, + toolpath, + [entry_test.TestEntry, ftest.TestFunctional, fdt_test.TestFdt, + elf_test.TestElf, image_test.TestImage, cbfs_util_test.TestCbfs]) + + return test_util.ReportResult('binman', test_name, result)
def GetEntryModules(include_testing=True): """Get a set of entry class implementations diff --git a/tools/patman/test_util.py b/tools/patman/test_util.py index 6575b11c1a..bb5a298e39 100644 --- a/tools/patman/test_util.py +++ b/tools/patman/test_util.py @@ -5,13 +5,21 @@
from contextlib import contextmanager import glob +import multiprocessing import os import sys +import unittest
import command
+use_concurrent = True +try: + from concurrencytest import ConcurrentTestSuite, fork_for_tests +except: + use_concurrent = False +
def RunTestCoverage(prog, filter_fname, exclude_list, build_dir, required=None): """Run tests and check that we get 100% coverage @@ -86,3 +94,95 @@ def capture_sys_output(): yield capture_out, capture_err finally: sys.stdout, sys.stderr = old_out, old_err + + +def ReportResult(toolname:str, test_name: str, result: unittest.TestResult): + """Report the results from a suite of tests + + Args: + toolname: Name of the tool that ran the tests + test_name: Name of test that was run, or None for all + result: A unittest.TestResult object containing the results + """ + # Remove errors which just indicate a missing test. Since Python v3.5 If an + # ImportError or AttributeError occurs while traversing name then a + # synthetic test that raises that error when run will be returned. These + # errors are included in the errors accumulated by result.errors. + if test_name: + errors = [] + + for test, err in result.errors: + if ("has no attribute '%s'" % test_name) not in err: + errors.append((test, err)) + result.testsRun -= 1 + result.errors = errors + + print(result) + for test, err in result.errors: + print(test.id(), err) + for test, err in result.failures: + print(err, result.failures) + if result.skipped: + print('%d binman test%s SKIPPED:' % + (len(result.skipped), 's' if len(result.skipped) > 1 else '')) + for skip_info in result.skipped: + print('%s: %s' % (skip_info[0], skip_info[1])) + if result.errors or result.failures: + print('binman tests FAILED') + return 1 + return 0 + + +def RunTestSuites(result, debug, verbosity, test_preserve_dirs, processes, + test_name, toolpath, test_class_list): + """Run a series of test suites and collect the results + + Args: + result: A unittest.TestResult object to add the results to + debug: True to enable debugging, which shows a full stack trace on error + verbosity: Verbosity level to use (0-4) + test_preserve_dirs: True to preserve the input directory used by tests + so that it can be examined afterwards (only useful for debugging + tests). If a single test is selected (in args[0]) it also preserves + the output directory for this test. Both directories are displayed + on the command line. + processes: Number of processes to use to run tests (None=same as #CPUs) + test_name: Name of test to run, or None for all + toolpath: List of paths to use for tools + test_class_list: List of test classes to run + """ + for module in []: + suite = doctest.DocTestSuite(module) + suite.run(result) + + sys.argv = [sys.argv[0]] + if debug: + sys.argv.append('-D') + if verbosity: + sys.argv.append('-v%d' % verbosity) + if toolpath: + for path in toolpath: + sys.argv += ['--toolpath', path] + + suite = unittest.TestSuite() + loader = unittest.TestLoader() + for module in test_class_list: + # Test the test module about our arguments, if it is interested + if hasattr(module, 'setup_test_args'): + setup_test_args = getattr(module, 'setup_test_args') + setup_test_args(preserve_indir=test_preserve_dirs, + preserve_outdirs=test_preserve_dirs and test_name is not None, + toolpath=toolpath, verbosity=verbosity) + if test_name: + try: + suite.addTests(loader.loadTestsFromName(test_name, module)) + except AttributeError: + continue + else: + suite.addTests(loader.loadTestsFromTestCase(module)) + if use_concurrent and processes != 1: + concurrent_suite = ConcurrentTestSuite(suite, + fork_for_tests(processes or multiprocessing.cpu_count())) + concurrent_suite.run(result) + else: + suite.run(result)
Changes in v2: None
At present buildman sets the python path on startup so that it can access the libraries it needs. If we convert to use absolute imports this is not necessary.
Move buildman to use absolute imports. Also adjust moveconfig.py too since it uses some buildman modules and cannot work without this.
Changes in v2: None
tools/buildman/builder.py | 4 ++-- tools/buildman/control.py | 12 ++++++------ tools/buildman/func_test.py | 9 +++++---- tools/buildman/main.py | 20 ++++++++++---------- tools/buildman/test.py | 12 ++++++------ tools/buildman/toolchain.py | 2 +- tools/moveconfig.py | 8 ++++---- 7 files changed, 34 insertions(+), 33 deletions(-)
diff --git a/tools/buildman/builder.py b/tools/buildman/builder.py index 1b61e3a837..b7f2c426e3 100644 --- a/tools/buildman/builder.py +++ b/tools/buildman/builder.py @@ -17,12 +17,12 @@ import sys import threading import time
-import builderthread +from buildman import builderthread +from buildman import toolchain import command import gitutil import terminal from terminal import Print -import toolchain
""" Theory of Operation diff --git a/tools/buildman/control.py b/tools/buildman/control.py index 7c8d7520fb..e05234c08f 100644 --- a/tools/buildman/control.py +++ b/tools/buildman/control.py @@ -5,18 +5,18 @@ import multiprocessing import os import shutil +import subprocess import sys
-import board -import bsettings -from builder import Builder +from buildman import board +from buildman import bsettings +from buildman import toolchain +from buildman.builder import Builder +import command import gitutil import patchstream import terminal from terminal import Print -import toolchain -import command -import subprocess
def GetPlural(count): """Returns a plural 's' if count is not 1""" diff --git a/tools/buildman/func_test.py b/tools/buildman/func_test.py index 29b28f5a9f..9bfdd53698 100644 --- a/tools/buildman/func_test.py +++ b/tools/buildman/func_test.py @@ -8,11 +8,12 @@ import sys import tempfile import unittest
-import board -import bsettings -import cmdline +from buildman import board +from buildman import bsettings +from buildman import cmdline +from buildman import control +from buildman import toolchain import command -import control import gitutil import terminal import toolchain diff --git a/tools/buildman/main.py b/tools/buildman/main.py index 0add628a63..94d495c40b 100755 --- a/tools/buildman/main.py +++ b/tools/buildman/main.py @@ -6,6 +6,7 @@
+import doctest import multiprocessing import os import re @@ -14,20 +15,19 @@ import unittest
# Bring in the patman libraries our_path = os.path.dirname(os.path.realpath(__file__)) -sys.path.insert(1, os.path.join(our_path, '../patman')) +sys.path.insert(1, os.path.join(our_path, '..')) +sys.path.insert(2, os.path.join(our_path, '../patman'))
# Our modules -import board -import bsettings -import builder -import checkpatch -import cmdline -import control -import doctest -import gitutil +from buildman import board +from buildman import bsettings +from buildman import builder +from buildman import cmdline +from buildman import control +from buildman import toolchain import patchstream +import gitutil import terminal -import toolchain
def RunTests(skip_net_tests): import func_test diff --git a/tools/buildman/test.py b/tools/buildman/test.py index 8b6d138f70..87175eeb63 100644 --- a/tools/buildman/test.py +++ b/tools/buildman/test.py @@ -13,15 +13,15 @@ import unittest our_path = os.path.dirname(os.path.realpath(__file__)) sys.path.append(os.path.join(our_path, '../patman'))
-import board -import bsettings -import builder -import control -import command +from buildman import board +from buildman import bsettings +from buildman import builder +from buildman import control +from buildman import toolchain import commit +import command import terminal import test_util -import toolchain import tools
use_network = True diff --git a/tools/buildman/toolchain.py b/tools/buildman/toolchain.py index 4456a805c7..a3540491ec 100644 --- a/tools/buildman/toolchain.py +++ b/tools/buildman/toolchain.py @@ -10,7 +10,7 @@ import sys import tempfile import urllib.request, urllib.error, urllib.parse
-import bsettings +from buildman import bsettings import command import terminal import tools diff --git a/tools/moveconfig.py b/tools/moveconfig.py index d8bf7fd071..0dd8670403 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -314,11 +314,11 @@ import tempfile import threading import time
-sys.path.append(os.path.join(os.path.dirname(__file__), 'buildman')) +sys.path.append(os.path.join(os.path.dirname(__file__), '..')) sys.path.append(os.path.join(os.path.dirname(__file__), 'patman')) -import bsettings -import kconfiglib -import toolchain +from buildman import bsettings +from buildman import kconfiglib +from buildman import toolchain
SHOW_GNU_MAKE = 'scripts/show-gnu-make' SLEEP_TIME=0.03
Changes in v2: None
At present binman sets the python path on startup so that it can access the libraries it needs. If we convert to use absolute imports this is not necessary.
Move binman to use absolute imports. This enables removable of the path adjusting in Entry also.
Changes in v2: None
tools/binman/cbfs_util.py | 2 +- tools/binman/cbfs_util_test.py | 6 +-- tools/binman/control.py | 12 +++--- tools/binman/elf.py | 2 +- tools/binman/elf_test.py | 2 +- tools/binman/entry.py | 16 +++----- tools/binman/entry_test.py | 10 ++--- tools/binman/etype/__init__.py | 0 tools/binman/etype/_testing.py | 4 +- tools/binman/etype/blob.py | 4 +- tools/binman/etype/blob_dtb.py | 6 +-- tools/binman/etype/blob_named_by_arg.py | 4 +- tools/binman/etype/cbfs.py | 10 ++--- tools/binman/etype/cros_ec_rw.py | 2 +- tools/binman/etype/fdtmap.py | 6 +-- tools/binman/etype/files.py | 6 +-- tools/binman/etype/fill.py | 4 +- tools/binman/etype/fmap.py | 6 +-- tools/binman/etype/gbb.py | 4 +- tools/binman/etype/image_header.py | 4 +- tools/binman/etype/intel_cmc.py | 4 +- tools/binman/etype/intel_descriptor.py | 4 +- tools/binman/etype/intel_fit.py | 2 +- tools/binman/etype/intel_fit_ptr.py | 2 +- tools/binman/etype/intel_fsp.py | 4 +- tools/binman/etype/intel_fsp_m.py | 4 +- tools/binman/etype/intel_fsp_s.py | 4 +- tools/binman/etype/intel_fsp_t.py | 4 +- tools/binman/etype/intel_ifwi.py | 6 +-- tools/binman/etype/intel_me.py | 4 +- tools/binman/etype/intel_mrc.py | 4 +- tools/binman/etype/intel_refcode.py | 4 +- tools/binman/etype/intel_vbt.py | 4 +- tools/binman/etype/intel_vga.py | 4 +- .../etype/powerpc_mpc85xx_bootpg_resetvec.py | 4 +- tools/binman/etype/section.py | 4 +- tools/binman/etype/text.py | 4 +- tools/binman/etype/u_boot.py | 4 +- tools/binman/etype/u_boot_dtb.py | 4 +- tools/binman/etype/u_boot_dtb_with_ucode.py | 8 ++-- tools/binman/etype/u_boot_elf.py | 6 +-- tools/binman/etype/u_boot_img.py | 4 +- tools/binman/etype/u_boot_nodtb.py | 4 +- tools/binman/etype/u_boot_spl.py | 7 ++-- tools/binman/etype/u_boot_spl_bss_pad.py | 6 +-- tools/binman/etype/u_boot_spl_dtb.py | 4 +- tools/binman/etype/u_boot_spl_elf.py | 4 +- tools/binman/etype/u_boot_spl_nodtb.py | 4 +- .../binman/etype/u_boot_spl_with_ucode_ptr.py | 6 +-- tools/binman/etype/u_boot_tpl.py | 7 ++-- tools/binman/etype/u_boot_tpl_dtb.py | 4 +- .../binman/etype/u_boot_tpl_dtb_with_ucode.py | 5 +-- tools/binman/etype/u_boot_tpl_elf.py | 4 +- .../binman/etype/u_boot_tpl_with_ucode_ptr.py | 6 +-- tools/binman/etype/u_boot_ucode.py | 4 +- tools/binman/etype/u_boot_with_ucode_ptr.py | 10 ++--- tools/binman/etype/vblock.py | 4 +- tools/binman/etype/x86_reset16.py | 4 +- tools/binman/etype/x86_reset16_spl.py | 4 +- tools/binman/etype/x86_reset16_tpl.py | 4 +- tools/binman/etype/x86_start16.py | 4 +- tools/binman/etype/x86_start16_spl.py | 4 +- tools/binman/etype/x86_start16_tpl.py | 4 +- tools/binman/fdt_test.py | 6 +-- tools/binman/ftest.py | 37 ++++++++++--------- tools/binman/image.py | 12 +++--- tools/binman/image_test.py | 2 +- tools/binman/main.py | 23 ++++++------ tools/binman/state.py | 6 +-- tools/patman/main.py | 20 +++++----- 70 files changed, 198 insertions(+), 213 deletions(-) delete mode 100644 tools/binman/etype/__init__.py
diff --git a/tools/binman/cbfs_util.py b/tools/binman/cbfs_util.py index 34c5116688..f7c3cd0d0e 100644 --- a/tools/binman/cbfs_util.py +++ b/tools/binman/cbfs_util.py @@ -20,8 +20,8 @@ import io import struct import sys
+from binman import elf import command -import elf import tools
# Set to True to enable printing output while working diff --git a/tools/binman/cbfs_util_test.py b/tools/binman/cbfs_util_test.py index 4aa2494fee..a929612b19 100755 --- a/tools/binman/cbfs_util_test.py +++ b/tools/binman/cbfs_util_test.py @@ -16,9 +16,9 @@ import struct import tempfile import unittest
-import cbfs_util -from cbfs_util import CbfsWriter -import elf +from binman import cbfs_util +from binman.cbfs_util import CbfsWriter +from binman import elf import test_util import tools
diff --git a/tools/binman/control.py b/tools/binman/control.py index 82bc90d802..d715b601b9 100644 --- a/tools/binman/control.py +++ b/tools/binman/control.py @@ -10,9 +10,9 @@ import os import sys import tools
-import cbfs_util +from binman import cbfs_util +from binman import elf import command -import elf import tout
# List of images we plan to create @@ -60,7 +60,7 @@ def WriteEntryDocs(modules, test_missing=None): to show as missing even if it is present. Should be set to None in normal use. """ - from entry import Entry + from binman.entry import Entry Entry.WriteDocs(modules, test_missing)
@@ -334,8 +334,8 @@ def PrepareImagesAndDtbs(dtb_fname, select_images, update_fdt): """ # Import these here in case libfdt.py is not available, in which case # the above help option still works. - import fdt - import fdt_util + from dtoc import fdt + from dtoc import fdt_util global images
# Get the device tree ready by compiling it and copying the compiled @@ -473,7 +473,7 @@ def Binman(args):
# Put these here so that we can import this module without libfdt from image import Image - import state + from binman import state
if args.cmd in ['ls', 'extract', 'replace']: try: diff --git a/tools/binman/elf.py b/tools/binman/elf.py index 29fdac1b8f..335d411303 100644 --- a/tools/binman/elf.py +++ b/tools/binman/elf.py @@ -6,7 +6,6 @@ #
from collections import namedtuple, OrderedDict -import command import io import os import re @@ -14,6 +13,7 @@ import shutil import struct import tempfile
+import command import tools import tout
diff --git a/tools/binman/elf_test.py b/tools/binman/elf_test.py index ac26fd51e4..e4497f30fc 100644 --- a/tools/binman/elf_test.py +++ b/tools/binman/elf_test.py @@ -10,8 +10,8 @@ import sys import tempfile import unittest
+from binman import elf import command -import elf import test_util import tools import tout diff --git a/tools/binman/entry.py b/tools/binman/entry.py index 1244d36c20..9f62322bed 100644 --- a/tools/binman/entry.py +++ b/tools/binman/entry.py @@ -9,9 +9,9 @@ import importlib import os import sys
-import fdt_util +from dtoc import fdt_util import tools -from tools import ToHex, ToHexSize +from patman.tools import ToHex, ToHexSize import tout
modules = {} @@ -63,7 +63,7 @@ class Entry(object): def __init__(self, section, etype, node, name_prefix=''): # Put this here to allow entry-docs and help to work without libfdt global state - import state + from binman import state
self.section = section self.etype = etype @@ -108,15 +108,11 @@ class Entry(object):
# Import the module if we have not already done so. if not module: - old_path = sys.path - sys.path.insert(0, os.path.join(our_path, 'etype')) try: - module = importlib.import_module(module_name) + module = importlib.import_module('binman.etype.' + module_name) except ImportError as e: raise ValueError("Unknown entry type '%s' in node '%s' (expected etype/%s.py, error '%s'" % (etype, node_path, module_name, e)) - finally: - sys.path = old_path modules[module_name] = module
# Look up the expected class name @@ -590,9 +586,7 @@ features to produce new behaviours. modules.remove('_testing') missing = [] for name in modules: - if name.startswith('__'): - continue - module = Entry.Lookup(name, name) + module = Entry.Lookup('WriteDocs', name) docs = getattr(module, '__doc__') if test_missing == name: docs = None diff --git a/tools/binman/entry_test.py b/tools/binman/entry_test.py index 277e10b585..ca5bb0fe1b 100644 --- a/tools/binman/entry_test.py +++ b/tools/binman/entry_test.py @@ -9,9 +9,9 @@ import os import sys import unittest
-import entry -import fdt -import fdt_util +from binman import entry +from dtoc import fdt +from dtoc import fdt_util import tools
class TestEntry(unittest.TestCase): @@ -37,11 +37,11 @@ class TestEntry(unittest.TestCase): else: reload(entry) else: - import entry + from binman import entry
def testEntryContents(self): """Test the Entry bass class""" - import entry + from binman import entry base_entry = entry.Entry(None, None, None) self.assertEqual(True, base_entry.ObtainContents())
diff --git a/tools/binman/etype/__init__.py b/tools/binman/etype/__init__.py deleted file mode 100644 index e69de29bb2..0000000000 diff --git a/tools/binman/etype/_testing.py b/tools/binman/etype/_testing.py index 25a6206bf3..4cde8df6f5 100644 --- a/tools/binman/etype/_testing.py +++ b/tools/binman/etype/_testing.py @@ -7,8 +7,8 @@
-from entry import Entry, EntryArg -import fdt_util +from binman.entry import Entry, EntryArg +from dtoc import fdt_util import tools
diff --git a/tools/binman/etype/blob.py b/tools/binman/etype/blob.py index d34c7b51bf..409beaadcc 100644 --- a/tools/binman/etype/blob.py +++ b/tools/binman/etype/blob.py @@ -5,8 +5,8 @@ # Entry-type module for blobs, which are binary objects read from files #
-from entry import Entry -import fdt_util +from binman.entry import Entry +from dtoc import fdt_util import tools import tout
diff --git a/tools/binman/etype/blob_dtb.py b/tools/binman/etype/blob_dtb.py index b2afa064c1..6c06943763 100644 --- a/tools/binman/etype/blob_dtb.py +++ b/tools/binman/etype/blob_dtb.py @@ -5,8 +5,8 @@ # Entry-type module for U-Boot device tree files #
-from entry import Entry -from blob import Entry_blob +from binman.entry import Entry +from binman.etype.blob import Entry_blob
class Entry_blob_dtb(Entry_blob): """A blob that holds a device tree @@ -18,7 +18,7 @@ class Entry_blob_dtb(Entry_blob): def __init__(self, section, etype, node): # Put this here to allow entry-docs and help to work without libfdt global state - import state + from binman import state
Entry_blob.__init__(self, section, etype, node)
diff --git a/tools/binman/etype/blob_named_by_arg.py b/tools/binman/etype/blob_named_by_arg.py index 344112bc42..3b4593f071 100644 --- a/tools/binman/etype/blob_named_by_arg.py +++ b/tools/binman/etype/blob_named_by_arg.py @@ -8,8 +8,8 @@
-from blob import Entry_blob -from entry import EntryArg +from binman.etype.blob import Entry_blob +from binman.entry import EntryArg
class Entry_blob_named_by_arg(Entry_blob): diff --git a/tools/binman/etype/cbfs.py b/tools/binman/etype/cbfs.py index 35b78370b2..e9aed8310c 100644 --- a/tools/binman/etype/cbfs.py +++ b/tools/binman/etype/cbfs.py @@ -7,10 +7,10 @@
-import cbfs_util -from cbfs_util import CbfsWriter -from entry import Entry -import fdt_util +from binman import cbfs_util +from binman.cbfs_util import CbfsWriter +from binman.entry import Entry +from dtoc import fdt_util
class Entry_cbfs(Entry): """Entry containing a Coreboot Filesystem (CBFS) @@ -165,7 +165,7 @@ class Entry_cbfs(Entry): def __init__(self, section, etype, node): # Put this here to allow entry-docs and help to work without libfdt global state - import state + from binman import state
Entry.__init__(self, section, etype, node) self._cbfs_arg = fdt_util.GetString(node, 'cbfs-arch', 'x86') diff --git a/tools/binman/etype/cros_ec_rw.py b/tools/binman/etype/cros_ec_rw.py index 261f8657a6..0dbe14b342 100644 --- a/tools/binman/etype/cros_ec_rw.py +++ b/tools/binman/etype/cros_ec_rw.py @@ -5,7 +5,7 @@ # Entry-type module for a Chromium OS EC image (read-write section) #
-from blob_named_by_arg import Entry_blob_named_by_arg +from binman.etype.blob_named_by_arg import Entry_blob_named_by_arg
class Entry_cros_ec_rw(Entry_blob_named_by_arg): diff --git a/tools/binman/etype/fdtmap.py b/tools/binman/etype/fdtmap.py index 5dc08b8289..820f34515a 100644 --- a/tools/binman/etype/fdtmap.py +++ b/tools/binman/etype/fdtmap.py @@ -8,7 +8,7 @@ This handles putting an FDT into the image with just the information about the image. """
-from entry import Entry +from binman.entry import Entry import tools import tout
@@ -82,8 +82,8 @@ class Entry_fdtmap(Entry): global Fdt
import libfdt - import state - from fdt import Fdt + from binman import state + from dtoc.fdt import Fdt
diff --git a/tools/binman/etype/files.py b/tools/binman/etype/files.py index 3473a2b1ef..7b4fc7db91 100644 --- a/tools/binman/etype/files.py +++ b/tools/binman/etype/files.py @@ -9,8 +9,8 @@ import glob import os
-from section import Entry_section -import fdt_util +from binman.etype.section import Entry_section +from dtoc import fdt_util import tools
@@ -30,7 +30,7 @@ class Entry_files(Entry_section): def __init__(self, section, etype, node): # Put this here to allow entry-docs and help to work without libfdt global state - import state + from binman import state
Entry_section.__init__(self, section, etype, node) self._pattern = fdt_util.GetString(self._node, 'pattern') diff --git a/tools/binman/etype/fill.py b/tools/binman/etype/fill.py index 623b7f4e95..1124ef26ea 100644 --- a/tools/binman/etype/fill.py +++ b/tools/binman/etype/fill.py @@ -3,8 +3,8 @@ # Written by Simon Glass sjg@chromium.org #
class Entry_fill(Entry): diff --git a/tools/binman/etype/fmap.py b/tools/binman/etype/fmap.py index 835ba5012e..a155beb617 100644 --- a/tools/binman/etype/fmap.py +++ b/tools/binman/etype/fmap.py @@ -5,10 +5,10 @@ # Entry-type module for a Flash map, as used by the flashrom SPI flash tool #
-from entry import Entry -import fmap_util +from binman.entry import Entry +from binman import fmap_util import tools -from tools import ToHexSize +from patman.tools import ToHexSize import tout
diff --git a/tools/binman/etype/gbb.py b/tools/binman/etype/gbb.py index a94c0fca9d..0fc7667908 100644 --- a/tools/binman/etype/gbb.py +++ b/tools/binman/etype/gbb.py @@ -9,9 +9,9 @@ from collections import OrderedDict
import command -from entry import Entry, EntryArg +from binman.entry import Entry, EntryArg
# Build GBB flags. diff --git a/tools/binman/etype/image_header.py b/tools/binman/etype/image_header.py index b9327dd799..176bdeb29b 100644 --- a/tools/binman/etype/image_header.py +++ b/tools/binman/etype/image_header.py @@ -11,8 +11,8 @@ image.
import struct
IMAGE_HEADER_MAGIC = b'BinM' IMAGE_HEADER_LEN = 8 diff --git a/tools/binman/etype/intel_cmc.py b/tools/binman/etype/intel_cmc.py index fa6f7793c6..5e6edbe4df 100644 --- a/tools/binman/etype/intel_cmc.py +++ b/tools/binman/etype/intel_cmc.py @@ -5,8 +5,8 @@ # Entry-type module for Intel Chip Microcode binary blob #
class Entry_intel_cmc(Entry_blob): """Entry containing an Intel Chipset Micro Code (CMC) file diff --git a/tools/binman/etype/intel_descriptor.py b/tools/binman/etype/intel_descriptor.py index b6477931d6..d4d7a26901 100644 --- a/tools/binman/etype/intel_descriptor.py +++ b/tools/binman/etype/intel_descriptor.py @@ -7,8 +7,8 @@
import struct
FD_SIGNATURE = struct.pack('<L', 0x0ff0a55a) MAX_REGIONS = 5 diff --git a/tools/binman/etype/intel_fit.py b/tools/binman/etype/intel_fit.py index 2a34a05f95..ea482a6125 100644 --- a/tools/binman/etype/intel_fit.py +++ b/tools/binman/etype/intel_fit.py @@ -7,7 +7,7 @@
import struct
-from blob import Entry_blob +from binman.etype.blob import Entry_blob
class Entry_intel_fit(Entry_blob): """Intel Firmware Image Table (FIT) diff --git a/tools/binman/etype/intel_fit_ptr.py b/tools/binman/etype/intel_fit_ptr.py index 148b206c3c..df118a68f2 100644 --- a/tools/binman/etype/intel_fit_ptr.py +++ b/tools/binman/etype/intel_fit_ptr.py @@ -7,7 +7,7 @@
import struct
class Entry_intel_fit_ptr(Entry_blob): """Intel Firmware Image Table (FIT) pointer diff --git a/tools/binman/etype/intel_fsp.py b/tools/binman/etype/intel_fsp.py index 00a78e7083..7db3d96b43 100644 --- a/tools/binman/etype/intel_fsp.py +++ b/tools/binman/etype/intel_fsp.py @@ -5,8 +5,8 @@ # Entry-type module for Intel Firmware Support Package binary blob #
class Entry_intel_fsp(Entry_blob): """Entry containing an Intel Firmware Support Package (FSP) file diff --git a/tools/binman/etype/intel_fsp_m.py b/tools/binman/etype/intel_fsp_m.py index bb1de73e41..51b4e7e1ac 100644 --- a/tools/binman/etype/intel_fsp_m.py +++ b/tools/binman/etype/intel_fsp_m.py @@ -5,8 +5,8 @@ # Entry-type module for Intel Firmware Support Package binary blob (M section) #
class Entry_intel_fsp_m(Entry_blob): """Entry containing Intel Firmware Support Package (FSP) memory init diff --git a/tools/binman/etype/intel_fsp_s.py b/tools/binman/etype/intel_fsp_s.py index 3d6900d1fb..b3683e476a 100644 --- a/tools/binman/etype/intel_fsp_s.py +++ b/tools/binman/etype/intel_fsp_s.py @@ -5,8 +5,8 @@ # Entry-type module for Intel Firmware Support Package binary blob (S section) #
class Entry_intel_fsp_s(Entry_blob): """Entry containing Intel Firmware Support Package (FSP) silicon init diff --git a/tools/binman/etype/intel_fsp_t.py b/tools/binman/etype/intel_fsp_t.py index 813a81f2e6..0f196f0f1c 100644 --- a/tools/binman/etype/intel_fsp_t.py +++ b/tools/binman/etype/intel_fsp_t.py @@ -5,8 +5,8 @@ # Entry-type module for Intel Firmware Support Package binary blob (T section) #
class Entry_intel_fsp_t(Entry_blob): """Entry containing Intel Firmware Support Package (FSP) temp ram init diff --git a/tools/binman/etype/intel_ifwi.py b/tools/binman/etype/intel_ifwi.py index 36aadc210c..1545476f8f 100644 --- a/tools/binman/etype/intel_ifwi.py +++ b/tools/binman/etype/intel_ifwi.py @@ -7,9 +7,9 @@
-from entry import Entry -from blob import Entry_blob -import fdt_util +from binman.entry import Entry +from binman.etype.blob import Entry_blob +from dtoc import fdt_util import tools
class Entry_intel_ifwi(Entry_blob): diff --git a/tools/binman/etype/intel_me.py b/tools/binman/etype/intel_me.py index c932ec5222..41c9c6b920 100644 --- a/tools/binman/etype/intel_me.py +++ b/tools/binman/etype/intel_me.py @@ -5,8 +5,8 @@ # Entry-type module for Intel Management Engine binary blob #
class Entry_intel_me(Entry_blob): """Entry containing an Intel Management Engine (ME) file diff --git a/tools/binman/etype/intel_mrc.py b/tools/binman/etype/intel_mrc.py index 4dbc99a04f..854a4dda61 100644 --- a/tools/binman/etype/intel_mrc.py +++ b/tools/binman/etype/intel_mrc.py @@ -5,8 +5,8 @@ # Entry-type module for Intel Memory Reference Code binary blob #
class Entry_intel_mrc(Entry_blob): """Entry containing an Intel Memory Reference Code (MRC) file diff --git a/tools/binman/etype/intel_refcode.py b/tools/binman/etype/intel_refcode.py index 045db589d1..a1059f787e 100644 --- a/tools/binman/etype/intel_refcode.py +++ b/tools/binman/etype/intel_refcode.py @@ -5,8 +5,8 @@ # Entry-type module for Intel Memory Reference Code binary blob #
class Entry_intel_refcode(Entry_blob): """Entry containing an Intel Reference Code file diff --git a/tools/binman/etype/intel_vbt.py b/tools/binman/etype/intel_vbt.py index d93dd19634..4d465ad017 100644 --- a/tools/binman/etype/intel_vbt.py +++ b/tools/binman/etype/intel_vbt.py @@ -4,8 +4,8 @@ # Entry-type module for Intel Video BIOS Table binary blob #
class Entry_intel_vbt(Entry_blob): """Entry containing an Intel Video BIOS Table (VBT) file diff --git a/tools/binman/etype/intel_vga.py b/tools/binman/etype/intel_vga.py index 40982c8665..04cd72f3dc 100644 --- a/tools/binman/etype/intel_vga.py +++ b/tools/binman/etype/intel_vga.py @@ -5,8 +5,8 @@ # Entry-type module for x86 VGA ROM binary blob #
class Entry_intel_vga(Entry_blob): """Entry containing an Intel Video Graphics Adaptor (VGA) file diff --git a/tools/binman/etype/powerpc_mpc85xx_bootpg_resetvec.py b/tools/binman/etype/powerpc_mpc85xx_bootpg_resetvec.py index 59fedd2b54..cefd425a5d 100644 --- a/tools/binman/etype/powerpc_mpc85xx_bootpg_resetvec.py +++ b/tools/binman/etype/powerpc_mpc85xx_bootpg_resetvec.py @@ -4,8 +4,8 @@ # Entry-type module for the PowerPC mpc85xx bootpg and resetvec code for U-Boot #
class Entry_powerpc_mpc85xx_bootpg_resetvec(Entry_blob): """PowerPC mpc85xx bootpg + resetvec code for U-Boot diff --git a/tools/binman/etype/section.py b/tools/binman/etype/section.py index 87b3ddce86..5893249e11 100644 --- a/tools/binman/etype/section.py +++ b/tools/binman/etype/section.py @@ -12,8 +12,8 @@ from collections import OrderedDict import re import sys
diff --git a/tools/binman/etype/text.py b/tools/binman/etype/text.py index da1813a638..cde816aec5 100644 --- a/tools/binman/etype/text.py +++ b/tools/binman/etype/text.py @@ -5,8 +5,8 @@
diff --git a/tools/binman/etype/u_boot.py b/tools/binman/etype/u_boot.py index 23dd12ce43..ab1019b00c 100644 --- a/tools/binman/etype/u_boot.py +++ b/tools/binman/etype/u_boot.py @@ -5,8 +5,8 @@ # Entry-type module for U-Boot binary #
class Entry_u_boot(Entry_blob): """U-Boot flat binary diff --git a/tools/binman/etype/u_boot_dtb.py b/tools/binman/etype/u_boot_dtb.py index 6c805a666d..e98350088f 100644 --- a/tools/binman/etype/u_boot_dtb.py +++ b/tools/binman/etype/u_boot_dtb.py @@ -5,8 +5,8 @@ # Entry-type module for U-Boot device tree #
-from entry import Entry -from blob_dtb import Entry_blob_dtb +from binman.entry import Entry +from binman.etype.blob_dtb import Entry_blob_dtb
class Entry_u_boot_dtb(Entry_blob_dtb): """U-Boot device tree diff --git a/tools/binman/etype/u_boot_dtb_with_ucode.py b/tools/binman/etype/u_boot_dtb_with_ucode.py index 6efd24a9b3..c802f477b4 100644 --- a/tools/binman/etype/u_boot_dtb_with_ucode.py +++ b/tools/binman/etype/u_boot_dtb_with_ucode.py @@ -5,8 +5,8 @@ # Entry-type module for U-Boot device tree with the microcode removed #
-from entry import Entry -from blob_dtb import Entry_blob_dtb +from binman.entry import Entry +from binman.etype.blob_dtb import Entry_blob_dtb import tools
class Entry_u_boot_dtb_with_ucode(Entry_blob_dtb): @@ -26,7 +26,7 @@ class Entry_u_boot_dtb_with_ucode(Entry_blob_dtb): def __init__(self, section, etype, node): # Put this here to allow entry-docs and help to work without libfdt global state - import state + from binman import state
Entry_blob_dtb.__init__(self, section, etype, node) self.ucode_data = b'' @@ -44,7 +44,7 @@ class Entry_u_boot_dtb_with_ucode(Entry_blob_dtb):
def ProcessFdt(self, fdt): # So the module can be loaded without it - import fdt + from dtoc import fdt
# If the section does not need microcode, there is nothing to do ucode_dest_entry = self.section.FindEntryType( diff --git a/tools/binman/etype/u_boot_elf.py b/tools/binman/etype/u_boot_elf.py index f83860dc0a..5123b9dc1e 100644 --- a/tools/binman/etype/u_boot_elf.py +++ b/tools/binman/etype/u_boot_elf.py @@ -5,10 +5,10 @@ # Entry-type module for U-Boot ELF image #
class Entry_u_boot_elf(Entry_blob): diff --git a/tools/binman/etype/u_boot_img.py b/tools/binman/etype/u_boot_img.py index 1ec0757c7f..50cc71d3ce 100644 --- a/tools/binman/etype/u_boot_img.py +++ b/tools/binman/etype/u_boot_img.py @@ -5,8 +5,8 @@ # Entry-type module for U-Boot binary #
class Entry_u_boot_img(Entry_blob): """U-Boot legacy image diff --git a/tools/binman/etype/u_boot_nodtb.py b/tools/binman/etype/u_boot_nodtb.py index a4b95a4390..e8c0e1a1d6 100644 --- a/tools/binman/etype/u_boot_nodtb.py +++ b/tools/binman/etype/u_boot_nodtb.py @@ -5,8 +5,8 @@ # Entry-type module for 'u-boot-nodtb.bin' #
class Entry_u_boot_nodtb(Entry_blob): """U-Boot flat binary without device tree appended diff --git a/tools/binman/etype/u_boot_spl.py b/tools/binman/etype/u_boot_spl.py index 7fedd00021..a6fddbe8f1 100644 --- a/tools/binman/etype/u_boot_spl.py +++ b/tools/binman/etype/u_boot_spl.py @@ -5,10 +5,9 @@ # Entry-type module for spl/u-boot-spl.bin #
-import elf - -from entry import Entry -from blob import Entry_blob +from binman import elf +from binman.entry import Entry +from binman.etype.blob import Entry_blob
class Entry_u_boot_spl(Entry_blob): """U-Boot SPL binary diff --git a/tools/binman/etype/u_boot_spl_bss_pad.py b/tools/binman/etype/u_boot_spl_bss_pad.py index 66a296a6f8..cfcca6b7c5 100644 --- a/tools/binman/etype/u_boot_spl_bss_pad.py +++ b/tools/binman/etype/u_boot_spl_bss_pad.py @@ -7,10 +7,10 @@ # to it will appear to SPL to be at the end of BSS rather than the start. #
+from binman import elf +from binman.entry import Entry import command -import elf -from entry import Entry -from blob import Entry_blob +from binman.etype.blob import Entry_blob import tools
class Entry_u_boot_spl_bss_pad(Entry_blob): diff --git a/tools/binman/etype/u_boot_spl_dtb.py b/tools/binman/etype/u_boot_spl_dtb.py index 1bcd449bf3..a0761eeacd 100644 --- a/tools/binman/etype/u_boot_spl_dtb.py +++ b/tools/binman/etype/u_boot_spl_dtb.py @@ -5,8 +5,8 @@ # Entry-type module for U-Boot device tree in SPL (Secondary Program Loader) #
class Entry_u_boot_spl_dtb(Entry_blob_dtb): """U-Boot SPL device tree diff --git a/tools/binman/etype/u_boot_spl_elf.py b/tools/binman/etype/u_boot_spl_elf.py index 24ee77237e..f99f74abab 100644 --- a/tools/binman/etype/u_boot_spl_elf.py +++ b/tools/binman/etype/u_boot_spl_elf.py @@ -5,8 +5,8 @@ # Entry-type module for U-Boot SPL ELF image #
class Entry_u_boot_spl_elf(Entry_blob): """U-Boot SPL ELF image diff --git a/tools/binman/etype/u_boot_spl_nodtb.py b/tools/binman/etype/u_boot_spl_nodtb.py index 41c17366b1..072b915ff3 100644 --- a/tools/binman/etype/u_boot_spl_nodtb.py +++ b/tools/binman/etype/u_boot_spl_nodtb.py @@ -5,8 +5,8 @@ # Entry-type module for 'u-boot-nodtb.bin' #
class Entry_u_boot_spl_nodtb(Entry_blob): """SPL binary without device tree appended diff --git a/tools/binman/etype/u_boot_spl_with_ucode_ptr.py b/tools/binman/etype/u_boot_spl_with_ucode_ptr.py index b650cf0146..b1543a5ef3 100644 --- a/tools/binman/etype/u_boot_spl_with_ucode_ptr.py +++ b/tools/binman/etype/u_boot_spl_with_ucode_ptr.py @@ -7,11 +7,7 @@
import struct
-import command -from entry import Entry -from blob import Entry_blob -from u_boot_with_ucode_ptr import Entry_u_boot_with_ucode_ptr -import tools +from binman.etype.u_boot_with_ucode_ptr import Entry_u_boot_with_ucode_ptr
class Entry_u_boot_spl_with_ucode_ptr(Entry_u_boot_with_ucode_ptr): """U-Boot SPL with embedded microcode pointer diff --git a/tools/binman/etype/u_boot_tpl.py b/tools/binman/etype/u_boot_tpl.py index 1b69c4f4a7..6562457c9a 100644 --- a/tools/binman/etype/u_boot_tpl.py +++ b/tools/binman/etype/u_boot_tpl.py @@ -5,10 +5,9 @@ # Entry-type module for tpl/u-boot-tpl.bin #
class Entry_u_boot_tpl(Entry_blob): """U-Boot TPL binary diff --git a/tools/binman/etype/u_boot_tpl_dtb.py b/tools/binman/etype/u_boot_tpl_dtb.py index 81a3970459..890155f271 100644 --- a/tools/binman/etype/u_boot_tpl_dtb.py +++ b/tools/binman/etype/u_boot_tpl_dtb.py @@ -5,8 +5,8 @@ # Entry-type module for U-Boot device tree in TPL (Tertiary Program Loader) #
class Entry_u_boot_tpl_dtb(Entry_blob_dtb): """U-Boot TPL device tree diff --git a/tools/binman/etype/u_boot_tpl_dtb_with_ucode.py b/tools/binman/etype/u_boot_tpl_dtb_with_ucode.py index ce19a49e2e..ca1bf85ace 100644 --- a/tools/binman/etype/u_boot_tpl_dtb_with_ucode.py +++ b/tools/binman/etype/u_boot_tpl_dtb_with_ucode.py @@ -5,10 +5,7 @@ # Entry-type module for U-Boot device tree with the microcode removed #
-import control -from entry import Entry -from u_boot_dtb_with_ucode import Entry_u_boot_dtb_with_ucode -import tools +from binman.etype.u_boot_dtb_with_ucode import Entry_u_boot_dtb_with_ucode
class Entry_u_boot_tpl_dtb_with_ucode(Entry_u_boot_dtb_with_ucode): """U-Boot TPL with embedded microcode pointer diff --git a/tools/binman/etype/u_boot_tpl_elf.py b/tools/binman/etype/u_boot_tpl_elf.py index 9cc1cc2c45..7fa8e96364 100644 --- a/tools/binman/etype/u_boot_tpl_elf.py +++ b/tools/binman/etype/u_boot_tpl_elf.py @@ -5,8 +5,8 @@ # Entry-type module for U-Boot TPL ELF image #
class Entry_u_boot_tpl_elf(Entry_blob): """U-Boot TPL ELF image diff --git a/tools/binman/etype/u_boot_tpl_with_ucode_ptr.py b/tools/binman/etype/u_boot_tpl_with_ucode_ptr.py index 8d94dded69..ca1f436c61 100644 --- a/tools/binman/etype/u_boot_tpl_with_ucode_ptr.py +++ b/tools/binman/etype/u_boot_tpl_with_ucode_ptr.py @@ -8,9 +8,9 @@ import struct
import command -from entry import Entry -from blob import Entry_blob -from u_boot_with_ucode_ptr import Entry_u_boot_with_ucode_ptr +from binman.entry import Entry +from binman.etype.blob import Entry_blob +from binman.etype.u_boot_with_ucode_ptr import Entry_u_boot_with_ucode_ptr import tools
class Entry_u_boot_tpl_with_ucode_ptr(Entry_u_boot_with_ucode_ptr): diff --git a/tools/binman/etype/u_boot_ucode.py b/tools/binman/etype/u_boot_ucode.py index dee8848db7..692ccceb71 100644 --- a/tools/binman/etype/u_boot_ucode.py +++ b/tools/binman/etype/u_boot_ucode.py @@ -5,8 +5,8 @@ # Entry-type module for a U-Boot binary with an embedded microcode pointer #
-from entry import Entry -from blob import Entry_blob +from binman.entry import Entry +from binman.etype.blob import Entry_blob import tools
class Entry_u_boot_ucode(Entry_blob): diff --git a/tools/binman/etype/u_boot_with_ucode_ptr.py b/tools/binman/etype/u_boot_with_ucode_ptr.py index 960a5efeb4..47ee33caba 100644 --- a/tools/binman/etype/u_boot_with_ucode_ptr.py +++ b/tools/binman/etype/u_boot_with_ucode_ptr.py @@ -7,12 +7,12 @@
import struct
-import command -import elf -from entry import Entry -from blob import Entry_blob -import fdt_util +from binman import elf +from binman.entry import Entry +from binman.etype.blob import Entry_blob +from dtoc import fdt_util import tools +import command
class Entry_u_boot_with_ucode_ptr(Entry_blob): """U-Boot with embedded microcode pointer diff --git a/tools/binman/etype/vblock.py b/tools/binman/etype/vblock.py index 91fa2f7808..c13ceda796 100644 --- a/tools/binman/etype/vblock.py +++ b/tools/binman/etype/vblock.py @@ -9,9 +9,9 @@ from collections import OrderedDict import os
class Entry_vblock(Entry): diff --git a/tools/binman/etype/x86_reset16.py b/tools/binman/etype/x86_reset16.py index 54eb814ea3..ad864e5442 100644 --- a/tools/binman/etype/x86_reset16.py +++ b/tools/binman/etype/x86_reset16.py @@ -5,8 +5,8 @@ # Entry-type module for the 16-bit x86 reset code for U-Boot #
class Entry_x86_reset16(Entry_blob): """x86 16-bit reset code for U-Boot diff --git a/tools/binman/etype/x86_reset16_spl.py b/tools/binman/etype/x86_reset16_spl.py index 699a0c6bcb..9a663f0ae2 100644 --- a/tools/binman/etype/x86_reset16_spl.py +++ b/tools/binman/etype/x86_reset16_spl.py @@ -5,8 +5,8 @@ # Entry-type module for the 16-bit x86 reset code for U-Boot #
class Entry_x86_reset16_spl(Entry_blob): """x86 16-bit reset code for U-Boot diff --git a/tools/binman/etype/x86_reset16_tpl.py b/tools/binman/etype/x86_reset16_tpl.py index 4eedb8d601..864508f367 100644 --- a/tools/binman/etype/x86_reset16_tpl.py +++ b/tools/binman/etype/x86_reset16_tpl.py @@ -5,8 +5,8 @@ # Entry-type module for the 16-bit x86 reset code for U-Boot #
class Entry_x86_reset16_tpl(Entry_blob): """x86 16-bit reset code for U-Boot diff --git a/tools/binman/etype/x86_start16.py b/tools/binman/etype/x86_start16.py index 6736b692d5..d8345f6722 100644 --- a/tools/binman/etype/x86_start16.py +++ b/tools/binman/etype/x86_start16.py @@ -5,8 +5,8 @@ # Entry-type module for the 16-bit x86 start-up code for U-Boot #
class Entry_x86_start16(Entry_blob): """x86 16-bit start-up code for U-Boot diff --git a/tools/binman/etype/x86_start16_spl.py b/tools/binman/etype/x86_start16_spl.py index c8c70639de..ad520d3c6d 100644 --- a/tools/binman/etype/x86_start16_spl.py +++ b/tools/binman/etype/x86_start16_spl.py @@ -5,8 +5,8 @@ # Entry-type module for the 16-bit x86 start-up code for U-Boot SPL #
class Entry_x86_start16_spl(Entry_blob): """x86 16-bit start-up code for SPL diff --git a/tools/binman/etype/x86_start16_tpl.py b/tools/binman/etype/x86_start16_tpl.py index 5261a8adf0..ccc8727d1d 100644 --- a/tools/binman/etype/x86_start16_tpl.py +++ b/tools/binman/etype/x86_start16_tpl.py @@ -5,8 +5,8 @@ # Entry-type module for the 16-bit x86 start-up code for U-Boot TPL #
class Entry_x86_start16_tpl(Entry_blob): """x86 16-bit start-up code for TPL diff --git a/tools/binman/fdt_test.py b/tools/binman/fdt_test.py index ac6f910d3c..a9ab04e80d 100644 --- a/tools/binman/fdt_test.py +++ b/tools/binman/fdt_test.py @@ -9,9 +9,9 @@ import sys import tempfile import unittest
-import fdt -from fdt import FdtScan -import fdt_util +from dtoc import fdt +from dtoc import fdt_util +from dtoc.fdt import FdtScan import tools
class TestFdt(unittest.TestCase): diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 0e2b50771e..a11675d9aa 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -6,6 +6,7 @@ # # python -m unittest func_test.TestFunctional.testHelp
+import gzip import hashlib from optparse import OptionParser import os @@ -15,22 +16,21 @@ import sys import tempfile import unittest
-import main -import cbfs_util -import cmdline +from binman import cbfs_util +from binman import cmdline +from binman import control +from binman import elf +from binman import elf_test +from binman import fmap_util +from binman import main +from binman import state +from dtoc import fdt +from dtoc import fdt_util +from binman.etype import fdtmap +from binman.etype import image_header +from image import Image import command -import control -import elf -import elf_test -import fdt -from etype import fdtmap -from etype import image_header -import fdt_util -import fmap_util import test_util -import gzip -from image import Image -import state import tools import tout
@@ -101,7 +101,7 @@ class TestFunctional(unittest.TestCase): @classmethod def setUpClass(cls): global entry - import entry + from binman import entry
# Handle the case where argv[0] is 'python' cls._binman_dir = os.path.dirname(os.path.realpath(sys.argv[0])) @@ -1288,8 +1288,8 @@ class TestFunctional(unittest.TestCase): with self.assertRaises(ValueError) as e: self._DoReadFile('057_unknown_contents.dts', True) self.assertIn("Image '/binman': Internal error: Could not complete " - "processing of contents: remaining [<_testing.Entry__testing ", - str(e.exception)) + "processing of contents: remaining [" + "<binman.etype._testing.Entry__testing ", str(e.exception))
def testBadChangeSize(self): """Test that trying to change the size of an entry fails""" @@ -1336,7 +1336,8 @@ class TestFunctional(unittest.TestCase): with self.assertRaises(ValueError) as e: self._DoReadFileDtb('061_fdt_update_bad.dts', update_dtb=True) self.assertIn('Could not complete processing of Fdt: remaining ' - '[<_testing.Entry__testing', str(e.exception)) + '[<binman.etype._testing.Entry__testing', + str(e.exception))
def testEntryArgs(self): """Test passing arguments to entries from the command line""" diff --git a/tools/binman/image.py b/tools/binman/image.py index 3e961733f9..50bd57cdcb 100644 --- a/tools/binman/image.py +++ b/tools/binman/image.py @@ -12,12 +12,12 @@ import os import re import sys
-from entry import Entry -from etype import fdtmap -from etype import image_header -from etype import section -import fdt -import fdt_util +from binman.entry import Entry +from binman.etype import fdtmap +from binman.etype import image_header +from binman.etype import section +from dtoc import fdt +from dtoc import fdt_util import tools import tout
diff --git a/tools/binman/image_test.py b/tools/binman/image_test.py index 10f85d1081..f85c3c51c0 100644 --- a/tools/binman/image_test.py +++ b/tools/binman/image_test.py @@ -7,7 +7,7 @@ import unittest
from image import Image -from test_util import capture_sys_output +from patman.test_util import capture_sys_output
class TestImage(unittest.TestCase): def testInvalidFormat(self): diff --git a/tools/binman/main.py b/tools/binman/main.py index a17764cdb0..8736938d11 100755 --- a/tools/binman/main.py +++ b/tools/binman/main.py @@ -20,8 +20,8 @@ import unittest # Bring in the patman and dtoc libraries (but don't override the first path # in PYTHONPATH) our_path = os.path.dirname(os.path.realpath(__file__)) -for dirname in ['../patman', '../dtoc', '..', '../concurrencytest']: - sys.path.insert(2, os.path.join(our_path, dirname)) +for dirname in ['../patman', '../dtoc', '../concurrencytest', '..']: + sys.path.insert(2, os.path.realpath(os.path.join(our_path, dirname)))
# Bring in the libfdt module sys.path.insert(2, 'scripts/dtc/pylibfdt') @@ -34,9 +34,8 @@ sys.path.insert(2, os.path.join(our_path, # that is not available in a virtualenv. sys.path.append(get_python_lib())
-import cmdline -import command -import control +from binman import cmdline +from binman import control import test_util
def RunTests(debug, verbosity, processes, test_preserve_dirs, args, toolpath): @@ -55,13 +54,13 @@ def RunTests(debug, verbosity, processes, test_preserve_dirs, args, toolpath): name to execute (as in 'binman test testSections', for example) toolpath: List of paths to use for tools """ - import cbfs_util_test - import elf_test - import entry_test - import fdt_test - import ftest - import image_test - import test + from binman import cbfs_util_test + from binman import elf_test + from binman import entry_test + from binman import fdt_test + from binman import ftest + from binman import image_test + from binman import test import doctest
result = unittest.TestResult() diff --git a/tools/binman/state.py b/tools/binman/state.py index d704ed2c7c..7f85ab1f98 100644 --- a/tools/binman/state.py +++ b/tools/binman/state.py @@ -8,7 +8,7 @@ import hashlib import re
-import fdt +from dtoc import fdt import os import tools import tout @@ -167,8 +167,8 @@ def Prepare(images, dtb): global output_fdt_info, main_dtb, fdt_path_prefix # Import these here in case libfdt.py is not available, in which case # the above help option still works. - import fdt - import fdt_util + from dtoc import fdt + from dtoc import fdt_util
# If we are updating the DTBs we need to put these updated versions # where Entry_blob_dtb can find them. We can ignore 'u-boot.dtb' diff --git a/tools/patman/main.py b/tools/patman/main.py index f3d9c0c434..b642c2ed03 100755 --- a/tools/patman/main.py +++ b/tools/patman/main.py @@ -13,19 +13,19 @@ import sys import unittest
if __name__ == "__main__": - # Allow 'from patman import xxx to work' + # Allow 'import xxx to work' our_path = os.path.dirname(os.path.realpath(__file__)) sys.path.append(os.path.join(our_path, '..'))
# Our modules -from patman import checkpatch -from patman import command -from patman import gitutil -from patman import patchstream -from patman import project -from patman import settings -from patman import terminal -from patman import test +import checkpatch +import command +import gitutil +import patchstream +import project +import settings +import terminal +import test
parser = OptionParser() @@ -86,7 +86,7 @@ if __name__ != "__main__": # Run our meagre tests elif options.test: import doctest - from patman import func_test + import func_test
sys.argv = [sys.argv[0]] result = unittest.TestResult()
Changes in v2: None
Applied to u-boot-dm, thanks!
At present patman sets the python path on startup so that it can access the libraries it needs. If we convert to use absolute imports this is not necessary.
Move patman to use absolute imports. This requires changes in tools which use the patman libraries (which is most of them).
Changes in v2: - Expand to convert all Python tools in U-Boot
tools/binman/cbfs_util.py | 4 ++-- tools/binman/cbfs_util_test.py | 4 ++-- tools/binman/control.py | 6 +++--- tools/binman/elf.py | 6 +++--- tools/binman/elf_test.py | 8 ++++---- tools/binman/entry.py | 4 ++-- tools/binman/entry_test.py | 2 +- tools/binman/etype/_testing.py | 2 +- tools/binman/etype/blob.py | 4 ++-- tools/binman/etype/fdtmap.py | 4 ++-- tools/binman/etype/files.py | 2 +- tools/binman/etype/fill.py | 2 +- tools/binman/etype/fmap.py | 4 ++-- tools/binman/etype/gbb.py | 4 ++-- tools/binman/etype/intel_ifwi.py | 2 +- tools/binman/etype/section.py | 4 ++-- tools/binman/etype/text.py | 2 +- tools/binman/etype/u_boot_dtb_with_ucode.py | 2 +- tools/binman/etype/u_boot_elf.py | 2 +- tools/binman/etype/u_boot_spl_bss_pad.py | 4 ++-- .../binman/etype/u_boot_tpl_with_ucode_ptr.py | 4 ++-- tools/binman/etype/u_boot_ucode.py | 2 +- tools/binman/etype/u_boot_with_ucode_ptr.py | 4 ++-- tools/binman/etype/vblock.py | 2 +- tools/binman/fdt_test.py | 2 +- tools/binman/fmap_util.py | 2 +- tools/binman/ftest.py | 8 ++++---- tools/binman/image.py | 4 ++-- tools/binman/main.py | 2 +- tools/binman/state.py | 4 ++-- tools/buildman/builder.py | 8 ++++---- tools/buildman/builderthread.py | 4 ++-- tools/buildman/control.py | 10 +++++----- tools/buildman/func_test.py | 9 ++++----- tools/buildman/main.py | 6 +++--- tools/buildman/test.py | 10 +++++----- tools/buildman/toolchain.py | 6 +++--- tools/dtoc/dtb_platdata.py | 6 +++--- tools/dtoc/fdt.py | 4 ++-- tools/dtoc/fdt_util.py | 4 ++-- tools/dtoc/main.py | 5 +++-- tools/dtoc/test_dtoc.py | 10 +++++----- tools/dtoc/test_fdt.py | 12 ++++++------ tools/patman/checkpatch.py | 8 +++++--- tools/patman/command.py | 5 +++-- tools/patman/func_test.py | 8 ++++---- tools/patman/get_maintainer.py | 5 +++-- tools/patman/gitutil.py | 12 ++++++------ tools/patman/main.py | 18 +++++++++--------- tools/patman/patchstream.py | 8 ++++---- tools/patman/project.py | 2 +- tools/patman/series.py | 10 +++++----- tools/patman/settings.py | 6 +++--- tools/patman/test.py | 10 +++++----- tools/patman/test_util.py | 3 ++- tools/patman/tools.py | 4 ++-- tools/patman/tout.py | 2 +- tools/rmboard.py | 2 +- 58 files changed, 154 insertions(+), 149 deletions(-)
diff --git a/tools/binman/cbfs_util.py b/tools/binman/cbfs_util.py index f7c3cd0d0e..39973371b9 100644 --- a/tools/binman/cbfs_util.py +++ b/tools/binman/cbfs_util.py @@ -21,8 +21,8 @@ import struct import sys
from binman import elf -import command -import tools +from patman import command +from patman import tools
# Set to True to enable printing output while working DEBUG = False diff --git a/tools/binman/cbfs_util_test.py b/tools/binman/cbfs_util_test.py index a929612b19..2c62c8a0f8 100755 --- a/tools/binman/cbfs_util_test.py +++ b/tools/binman/cbfs_util_test.py @@ -19,8 +19,8 @@ import unittest from binman import cbfs_util from binman.cbfs_util import CbfsWriter from binman import elf -import test_util -import tools +from patman import test_util +from patman import tools
U_BOOT_DATA = b'1234' U_BOOT_DTB_DATA = b'udtb' diff --git a/tools/binman/control.py b/tools/binman/control.py index d715b601b9..dc1dd2a7dc 100644 --- a/tools/binman/control.py +++ b/tools/binman/control.py @@ -8,12 +8,12 @@ from collections import OrderedDict import os import sys -import tools +from patman import tools
from binman import cbfs_util from binman import elf -import command -import tout +from patman import command +from patman import tout
# List of images we plan to create # Make this global so that it can be referenced from tests diff --git a/tools/binman/elf.py b/tools/binman/elf.py index 335d411303..f88031c2bf 100644 --- a/tools/binman/elf.py +++ b/tools/binman/elf.py @@ -13,9 +13,9 @@ import shutil import struct import tempfile
-import command -import tools -import tout +from patman import command +from patman import tools +from patman import tout
ELF_TOOLS = True try: diff --git a/tools/binman/elf_test.py b/tools/binman/elf_test.py index e4497f30fc..37e1b423cf 100644 --- a/tools/binman/elf_test.py +++ b/tools/binman/elf_test.py @@ -11,10 +11,10 @@ import tempfile import unittest
from binman import elf -import command -import test_util -import tools -import tout +from patman import command +from patman import test_util +from patman import tools +from patman import tout
diff --git a/tools/binman/entry.py b/tools/binman/entry.py index 9f62322bed..90ffd27617 100644 --- a/tools/binman/entry.py +++ b/tools/binman/entry.py @@ -10,9 +10,9 @@ import os import sys
from dtoc import fdt_util -import tools +from patman import tools from patman.tools import ToHex, ToHexSize -import tout +from patman import tout
modules = {}
diff --git a/tools/binman/entry_test.py b/tools/binman/entry_test.py index ca5bb0fe1b..80802f33de 100644 --- a/tools/binman/entry_test.py +++ b/tools/binman/entry_test.py @@ -12,7 +12,7 @@ import unittest from binman import entry from dtoc import fdt from dtoc import fdt_util -import tools +from patman import tools
class TestEntry(unittest.TestCase): def setUp(self): diff --git a/tools/binman/etype/_testing.py b/tools/binman/etype/_testing.py index 4cde8df6f5..ed718eed14 100644 --- a/tools/binman/etype/_testing.py +++ b/tools/binman/etype/_testing.py @@ -9,7 +9,7 @@ from collections import OrderedDict
from binman.entry import Entry, EntryArg from dtoc import fdt_util -import tools +from patman import tools
class Entry__testing(Entry): diff --git a/tools/binman/etype/blob.py b/tools/binman/etype/blob.py index 409beaadcc..ede7a7a68c 100644 --- a/tools/binman/etype/blob.py +++ b/tools/binman/etype/blob.py @@ -7,8 +7,8 @@
from binman.entry import Entry from dtoc import fdt_util -import tools -import tout +from patman import tools +from patman import tout
class Entry_blob(Entry): """Entry containing an arbitrary binary blob diff --git a/tools/binman/etype/fdtmap.py b/tools/binman/etype/fdtmap.py index 820f34515a..aa8807990b 100644 --- a/tools/binman/etype/fdtmap.py +++ b/tools/binman/etype/fdtmap.py @@ -9,8 +9,8 @@ image. """
from binman.entry import Entry -import tools -import tout +from patman import tools +from patman import tout
FDTMAP_MAGIC = b'_FDTMAP_' FDTMAP_HDR_LEN = 16 diff --git a/tools/binman/etype/files.py b/tools/binman/etype/files.py index 7b4fc7db91..10ab585f0e 100644 --- a/tools/binman/etype/files.py +++ b/tools/binman/etype/files.py @@ -11,7 +11,7 @@ import os
from binman.etype.section import Entry_section from dtoc import fdt_util -import tools +from patman import tools
class Entry_files(Entry_section): diff --git a/tools/binman/etype/fill.py b/tools/binman/etype/fill.py index 1124ef26ea..860410ed6e 100644 --- a/tools/binman/etype/fill.py +++ b/tools/binman/etype/fill.py @@ -5,7 +5,7 @@
from binman.entry import Entry from dtoc import fdt_util -import tools +from patman import tools
class Entry_fill(Entry): """An entry which is filled to a particular byte value diff --git a/tools/binman/etype/fmap.py b/tools/binman/etype/fmap.py index a155beb617..a43fac38de 100644 --- a/tools/binman/etype/fmap.py +++ b/tools/binman/etype/fmap.py @@ -7,9 +7,9 @@
from binman.entry import Entry from binman import fmap_util -import tools +from patman import tools from patman.tools import ToHexSize -import tout +from patman import tout
class Entry_fmap(Entry): diff --git a/tools/binman/etype/gbb.py b/tools/binman/etype/gbb.py index 0fc7667908..dd10599717 100644 --- a/tools/binman/etype/gbb.py +++ b/tools/binman/etype/gbb.py @@ -8,11 +8,11 @@
-import command +from patman import command from binman.entry import Entry, EntryArg
# Build GBB flags. # (src/platform/vboot_reference/firmware/include/gbb_header.h) diff --git a/tools/binman/etype/intel_ifwi.py b/tools/binman/etype/intel_ifwi.py index 1545476f8f..6a96f6be55 100644 --- a/tools/binman/etype/intel_ifwi.py +++ b/tools/binman/etype/intel_ifwi.py @@ -10,7 +10,7 @@ from collections import OrderedDict from binman.entry import Entry from binman.etype.blob import Entry_blob from dtoc import fdt_util -import tools +from patman import tools
class Entry_intel_ifwi(Entry_blob): """Entry containing an Intel Integrated Firmware Image (IFWI) file diff --git a/tools/binman/etype/section.py b/tools/binman/etype/section.py index 5893249e11..91b8e0c110 100644 --- a/tools/binman/etype/section.py +++ b/tools/binman/etype/section.py @@ -14,8 +14,8 @@ import sys
class Entry_section(Entry): diff --git a/tools/binman/etype/text.py b/tools/binman/etype/text.py index cde816aec5..3577135adb 100644 --- a/tools/binman/etype/text.py +++ b/tools/binman/etype/text.py @@ -7,7 +7,7 @@ from collections import OrderedDict
class Entry_text(Entry): diff --git a/tools/binman/etype/u_boot_dtb_with_ucode.py b/tools/binman/etype/u_boot_dtb_with_ucode.py index c802f477b4..aec145533e 100644 --- a/tools/binman/etype/u_boot_dtb_with_ucode.py +++ b/tools/binman/etype/u_boot_dtb_with_ucode.py @@ -7,7 +7,7 @@
from binman.entry import Entry from binman.etype.blob_dtb import Entry_blob_dtb -import tools +from patman import tools
class Entry_u_boot_dtb_with_ucode(Entry_blob_dtb): """A U-Boot device tree file, with the microcode removed diff --git a/tools/binman/etype/u_boot_elf.py b/tools/binman/etype/u_boot_elf.py index 5123b9dc1e..5f906e520c 100644 --- a/tools/binman/etype/u_boot_elf.py +++ b/tools/binman/etype/u_boot_elf.py @@ -9,7 +9,7 @@ from binman.entry import Entry from binman.etype.blob import Entry_blob
class Entry_u_boot_elf(Entry_blob): """U-Boot ELF image diff --git a/tools/binman/etype/u_boot_spl_bss_pad.py b/tools/binman/etype/u_boot_spl_bss_pad.py index cfcca6b7c5..a6a177a128 100644 --- a/tools/binman/etype/u_boot_spl_bss_pad.py +++ b/tools/binman/etype/u_boot_spl_bss_pad.py @@ -9,9 +9,9 @@
from binman import elf from binman.entry import Entry -import command +from patman import command from binman.etype.blob import Entry_blob -import tools +from patman import tools
class Entry_u_boot_spl_bss_pad(Entry_blob): """U-Boot SPL binary padded with a BSS region diff --git a/tools/binman/etype/u_boot_tpl_with_ucode_ptr.py b/tools/binman/etype/u_boot_tpl_with_ucode_ptr.py index ca1f436c61..7f7fab7105 100644 --- a/tools/binman/etype/u_boot_tpl_with_ucode_ptr.py +++ b/tools/binman/etype/u_boot_tpl_with_ucode_ptr.py @@ -7,11 +7,11 @@
import struct
-import command +from patman import command from binman.entry import Entry from binman.etype.blob import Entry_blob from binman.etype.u_boot_with_ucode_ptr import Entry_u_boot_with_ucode_ptr -import tools +from patman import tools
class Entry_u_boot_tpl_with_ucode_ptr(Entry_u_boot_with_ucode_ptr): """U-Boot TPL with embedded microcode pointer diff --git a/tools/binman/etype/u_boot_ucode.py b/tools/binman/etype/u_boot_ucode.py index 692ccceb71..d9e1a605ef 100644 --- a/tools/binman/etype/u_boot_ucode.py +++ b/tools/binman/etype/u_boot_ucode.py @@ -7,7 +7,7 @@
from binman.entry import Entry from binman.etype.blob import Entry_blob -import tools +from patman import tools
class Entry_u_boot_ucode(Entry_blob): """U-Boot microcode block diff --git a/tools/binman/etype/u_boot_with_ucode_ptr.py b/tools/binman/etype/u_boot_with_ucode_ptr.py index 47ee33caba..06047b654d 100644 --- a/tools/binman/etype/u_boot_with_ucode_ptr.py +++ b/tools/binman/etype/u_boot_with_ucode_ptr.py @@ -11,8 +11,8 @@ from binman import elf from binman.entry import Entry from binman.etype.blob import Entry_blob from dtoc import fdt_util -import tools -import command +from patman import tools +from patman import command
class Entry_u_boot_with_ucode_ptr(Entry_blob): """U-Boot with embedded microcode pointer diff --git a/tools/binman/etype/vblock.py b/tools/binman/etype/vblock.py index c13ceda796..5753de7ec7 100644 --- a/tools/binman/etype/vblock.py +++ b/tools/binman/etype/vblock.py @@ -12,7 +12,7 @@ import os from binman.entry import Entry, EntryArg
class Entry_vblock(Entry): """An entry which contains a Chromium OS verified boot block diff --git a/tools/binman/fdt_test.py b/tools/binman/fdt_test.py index a9ab04e80d..c491d40e9e 100644 --- a/tools/binman/fdt_test.py +++ b/tools/binman/fdt_test.py @@ -12,7 +12,7 @@ import unittest from dtoc import fdt from dtoc import fdt_util from dtoc.fdt import FdtScan -import tools +from patman import tools
class TestFdt(unittest.TestCase): @classmethod diff --git a/tools/binman/fmap_util.py b/tools/binman/fmap_util.py index d0f956b622..25fe60a9cc 100644 --- a/tools/binman/fmap_util.py +++ b/tools/binman/fmap_util.py @@ -10,7 +10,7 @@ import collections import struct import sys
# constants imported from lib/fmap.h FMAP_SIGNATURE = b'__FMAP__' diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index a11675d9aa..5e24920088 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -29,10 +29,10 @@ from dtoc import fdt_util from binman.etype import fdtmap from binman.etype import image_header from image import Image -import command -import test_util -import tools -import tout +from patman import command +from patman import test_util +from patman import tools +from patman import tout
# Contents of test files, corresponding to different entry types U_BOOT_DATA = b'1234' diff --git a/tools/binman/image.py b/tools/binman/image.py index 50bd57cdcb..523b274c31 100644 --- a/tools/binman/image.py +++ b/tools/binman/image.py @@ -18,8 +18,8 @@ from binman.etype import image_header from binman.etype import section from dtoc import fdt from dtoc import fdt_util -import tools -import tout +from patman import tools +from patman import tout
class Image(section.Entry_section): """A Image, representing an output from binman diff --git a/tools/binman/main.py b/tools/binman/main.py index 8736938d11..97a8a02034 100755 --- a/tools/binman/main.py +++ b/tools/binman/main.py @@ -36,7 +36,7 @@ sys.path.append(get_python_lib())
from binman import cmdline from binman import control -import test_util +from patman import test_util
def RunTests(debug, verbosity, processes, test_preserve_dirs, args, toolpath): """Run the functional tests and any embedded doctests diff --git a/tools/binman/state.py b/tools/binman/state.py index 7f85ab1f98..36bc513535 100644 --- a/tools/binman/state.py +++ b/tools/binman/state.py @@ -10,8 +10,8 @@ import re
from dtoc import fdt import os -import tools -import tout +from patman import tools +from patman import tout
# Records the device-tree files known to binman, keyed by entry type (e.g. # 'u-boot-spl-dtb'). These are the output FDT files, which can be updated by diff --git a/tools/buildman/builder.py b/tools/buildman/builder.py index b7f2c426e3..f8e71de427 100644 --- a/tools/buildman/builder.py +++ b/tools/buildman/builder.py @@ -19,10 +19,10 @@ import time
from buildman import builderthread from buildman import toolchain -import command -import gitutil -import terminal -from terminal import Print +from patman import command +from patman import gitutil +from patman import terminal +from patman.terminal import Print
""" Theory of Operation diff --git a/tools/buildman/builderthread.py b/tools/buildman/builderthread.py index f673f386e4..48fcd6cf7e 100644 --- a/tools/buildman/builderthread.py +++ b/tools/buildman/builderthread.py @@ -9,8 +9,8 @@ import shutil import sys import threading
-import command -import gitutil +from patman import command +from patman import gitutil
RETURN_CODE_RETRY = -1
diff --git a/tools/buildman/control.py b/tools/buildman/control.py index e05234c08f..071c2613ec 100644 --- a/tools/buildman/control.py +++ b/tools/buildman/control.py @@ -12,11 +12,11 @@ from buildman import board from buildman import bsettings from buildman import toolchain from buildman.builder import Builder -import command -import gitutil -import patchstream -import terminal -from terminal import Print +from patman import command +from patman import gitutil +from patman import patchstream +from patman import terminal +from patman.terminal import Print
def GetPlural(count): """Returns a plural 's' if count is not 1""" diff --git a/tools/buildman/func_test.py b/tools/buildman/func_test.py index 9bfdd53698..418677f9cc 100644 --- a/tools/buildman/func_test.py +++ b/tools/buildman/func_test.py @@ -13,11 +13,10 @@ from buildman import bsettings from buildman import cmdline from buildman import control from buildman import toolchain -import command -import gitutil -import terminal -import toolchain -import tools +from patman import command +from patman import gitutil +from patman import terminal +from patman import tools
settings_data = ''' # Buildman settings file diff --git a/tools/buildman/main.py b/tools/buildman/main.py index 94d495c40b..52a83fce7d 100755 --- a/tools/buildman/main.py +++ b/tools/buildman/main.py @@ -25,9 +25,9 @@ from buildman import builder from buildman import cmdline from buildman import control from buildman import toolchain -import patchstream -import gitutil -import terminal +from patman import patchstream +from patman import gitutil +from patman import terminal
def RunTests(skip_net_tests): import func_test diff --git a/tools/buildman/test.py b/tools/buildman/test.py index 87175eeb63..b37c37b2fa 100644 --- a/tools/buildman/test.py +++ b/tools/buildman/test.py @@ -18,11 +18,11 @@ from buildman import bsettings from buildman import builder from buildman import control from buildman import toolchain -import commit -import command -import terminal -import test_util -import tools +from patman import commit +from patman import command +from patman import terminal +from patman import test_util +from patman import tools
use_network = True
diff --git a/tools/buildman/toolchain.py b/tools/buildman/toolchain.py index a3540491ec..acb5a29c8f 100644 --- a/tools/buildman/toolchain.py +++ b/tools/buildman/toolchain.py @@ -11,9 +11,9 @@ import tempfile import urllib.request, urllib.error, urllib.parse
from buildman import bsettings -import command -import terminal -import tools +from patman import command +from patman import terminal +from patman import tools
(PRIORITY_FULL_PREFIX, PRIORITY_PREFIX_GCC, PRIORITY_PREFIX_GCC_PATH, PRIORITY_CALC) = list(range(4)) diff --git a/tools/dtoc/dtb_platdata.py b/tools/dtoc/dtb_platdata.py index 037e82c8bb..b86922b675 100644 --- a/tools/dtoc/dtb_platdata.py +++ b/tools/dtoc/dtb_platdata.py @@ -15,9 +15,9 @@ import collections import copy import sys
-import fdt -import fdt_util -import tools +from dtoc import fdt +from dtoc import fdt_util +from patman import tools
# When we see these properties we ignore them - i.e. do not create a structure member PROP_IGNORE_LIST = [ diff --git a/tools/dtoc/fdt.py b/tools/dtoc/fdt.py index 1b7b730359..188490b728 100644 --- a/tools/dtoc/fdt.py +++ b/tools/dtoc/fdt.py @@ -8,10 +8,10 @@ import struct import sys
-import fdt_util +from dtoc import fdt_util import libfdt from libfdt import QUIET_NOTFOUND -import tools +from patman import tools
# This deals with a device tree, presenting it as an assortment of Node and # Prop objects, representing nodes and properties, respectively. This file diff --git a/tools/dtoc/fdt_util.py b/tools/dtoc/fdt_util.py index b105faec74..b040793772 100644 --- a/tools/dtoc/fdt_util.py +++ b/tools/dtoc/fdt_util.py @@ -13,8 +13,8 @@ import struct import sys import tempfile
def fdt32_to_cpu(val): """Convert a device tree cell to an integer diff --git a/tools/dtoc/main.py b/tools/dtoc/main.py index ac0e364bf2..8f3ec1deef 100755 --- a/tools/dtoc/main.py +++ b/tools/dtoc/main.py @@ -33,14 +33,15 @@ import unittest # Bring in the patman libraries our_path = os.path.dirname(os.path.realpath(__file__)) sys.path.append(os.path.join(our_path, '../patman')) +sys.path.append(os.path.join(our_path, '..'))
# Bring in the libfdt module sys.path.insert(0, 'scripts/dtc/pylibfdt') sys.path.insert(0, os.path.join(our_path, '../../build-sandbox_spl/scripts/dtc/pylibfdt'))
-import dtb_platdata -import test_util +from dtoc import dtb_platdata +from patman import test_util
def run_tests(args): """Run all the test we have for dtoc diff --git a/tools/dtoc/test_dtoc.py b/tools/dtoc/test_dtoc.py index 9db97489d4..8498e8303c 100755 --- a/tools/dtoc/test_dtoc.py +++ b/tools/dtoc/test_dtoc.py @@ -14,15 +14,15 @@ import os import struct import unittest
-import dtb_platdata +from dtoc import dtb_platdata from dtb_platdata import conv_name_to_c from dtb_platdata import get_compat_name from dtb_platdata import get_value from dtb_platdata import tab_to -import fdt -import fdt_util -import test_util -import tools +from dtoc import fdt +from dtoc import fdt_util +from patman import test_util +from patman import tools
diff --git a/tools/dtoc/test_fdt.py b/tools/dtoc/test_fdt.py index 4f39a5589f..d68230713e 100755 --- a/tools/dtoc/test_fdt.py +++ b/tools/dtoc/test_fdt.py @@ -17,14 +17,14 @@ our_path = os.path.dirname(os.path.realpath(__file__)) for dirname in ['../patman', '..']: sys.path.insert(0, os.path.join(our_path, dirname))
-import command -import fdt +from dtoc import fdt +from dtoc import fdt_util +from dtoc.fdt_util import fdt32_to_cpu from fdt import TYPE_BYTE, TYPE_INT, TYPE_STRING, TYPE_BOOL, BytesToValue -import fdt_util -from fdt_util import fdt32_to_cpu import libfdt -import test_util -import tools +from patman import command +from patman import test_util +from patman import tools
def _GetPropertyValue(dtb, node, prop_name): """Low-level function to get the property value based on its offset diff --git a/tools/patman/checkpatch.py b/tools/patman/checkpatch.py index d47ea438b7..795b519314 100644 --- a/tools/patman/checkpatch.py +++ b/tools/patman/checkpatch.py @@ -3,12 +3,14 @@ #
import collections -import command -import gitutil import os import re import sys -import terminal + +from patman import command +from patman import gitutil +from patman import terminal +from patman import tools
def FindCheckPatch(): top_level = gitutil.GetTopLevel() diff --git a/tools/patman/command.py b/tools/patman/command.py index 5fbd2c4a3e..e67ac159e5 100644 --- a/tools/patman/command.py +++ b/tools/patman/command.py @@ -3,8 +3,9 @@ #
import os -import cros_subprocess -import tools + +from patman import cros_subprocess +from patman import tools
"""Shell command ease-ups for Python."""
diff --git a/tools/patman/func_test.py b/tools/patman/func_test.py index 748e225446..b7e2825de8 100644 --- a/tools/patman/func_test.py +++ b/tools/patman/func_test.py @@ -14,10 +14,10 @@ import unittest
from io import StringIO
-import gitutil -import patchstream -import settings -import tools +from patman import gitutil +from patman import patchstream +from patman import settings +from patman import tools
@contextlib.contextmanager diff --git a/tools/patman/get_maintainer.py b/tools/patman/get_maintainer.py index 0ffb55a821..473f0feebf 100644 --- a/tools/patman/get_maintainer.py +++ b/tools/patman/get_maintainer.py @@ -2,10 +2,11 @@ # Copyright (c) 2012 The Chromium OS Authors. #
+from patman import command +from patman import gitutil + def FindGetMaintainer(): """Look for the get_maintainer.pl script.
diff --git a/tools/patman/gitutil.py b/tools/patman/gitutil.py index a2a225c6b9..770a051014 100644 --- a/tools/patman/gitutil.py +++ b/tools/patman/gitutil.py @@ -2,17 +2,17 @@ # Copyright (c) 2011 The Chromium OS Authors. #
-import command import re import os -import series import subprocess import sys -import terminal
-import checkpatch -import settings -import tools +from patman import checkpatch +from patman import command +from patman import series +from patman import settings +from patman import terminal +from patman import tools
# True to use --no-decorate - we check this in Setup() use_no_decorate = True diff --git a/tools/patman/main.py b/tools/patman/main.py index b642c2ed03..f59367fafb 100755 --- a/tools/patman/main.py +++ b/tools/patman/main.py @@ -18,14 +18,14 @@ if __name__ == "__main__": sys.path.append(os.path.join(our_path, '..'))
# Our modules -import checkpatch -import command -import gitutil -import patchstream -import project -import settings -import terminal -import test +from patman import checkpatch +from patman import command +from patman import gitutil +from patman import patchstream +from patman import project +from patman import settings +from patman import terminal +from patman import test
parser = OptionParser() @@ -86,7 +86,7 @@ if __name__ != "__main__": # Run our meagre tests elif options.test: import doctest - import func_test + from patman import func_test
sys.argv = [sys.argv[0]] result = unittest.TestResult() diff --git a/tools/patman/patchstream.py b/tools/patman/patchstream.py index df3eb7483b..405297505c 100644 --- a/tools/patman/patchstream.py +++ b/tools/patman/patchstream.py @@ -9,10 +9,10 @@ import re import shutil import tempfile
-import command -import commit -import gitutil -from series import Series +from patman import command +from patman import commit +from patman import gitutil +from patman.series import Series
# Tags that we detect and remove re_remove = re.compile('^BUG=|^TEST=|^BRANCH=|^Review URL:' diff --git a/tools/patman/project.py b/tools/patman/project.py index 1d9cfc0625..2dfc303729 100644 --- a/tools/patman/project.py +++ b/tools/patman/project.py @@ -4,7 +4,7 @@
import os.path
-import gitutil +from patman import gitutil
def DetectProject(): """Autodetect the name of the current project. diff --git a/tools/patman/series.py b/tools/patman/series.py index 3869696abc..e5e28cebdf 100644 --- a/tools/patman/series.py +++ b/tools/patman/series.py @@ -5,11 +5,11 @@ import itertools import os
-import get_maintainer -import gitutil -import settings -import terminal -import tools +from patman import get_maintainer +from patman import gitutil +from patman import settings +from patman import terminal +from patman import tools
# Series-xxx tags that we understand valid_series = ['to', 'cc', 'version', 'changes', 'prefix', 'notes', 'name', diff --git a/tools/patman/settings.py b/tools/patman/settings.py index 21e8fc41a9..ca74fc611f 100644 --- a/tools/patman/settings.py +++ b/tools/patman/settings.py @@ -10,9 +10,9 @@ except: import os import re
-import command -import gitutil -import tools +from patman import command +from patman import gitutil +from patman import tools
"""Default settings per-project.
diff --git a/tools/patman/test.py b/tools/patman/test.py index 889e186606..e7f709e34c 100644 --- a/tools/patman/test.py +++ b/tools/patman/test.py @@ -8,11 +8,11 @@ import os import tempfile import unittest
-import checkpatch -import gitutil -import patchstream -import series -import commit +from patman import checkpatch +from patman import gitutil +from patman import patchstream +from patman import series +from patman import commit
class TestPatch(unittest.TestCase): diff --git a/tools/patman/test_util.py b/tools/patman/test_util.py index bb5a298e39..4d28d9fc92 100644 --- a/tools/patman/test_util.py +++ b/tools/patman/test_util.py @@ -10,7 +10,8 @@ import os import sys import unittest
-import command +from patman import command +from patman import test_util
diff --git a/tools/patman/tools.py b/tools/patman/tools.py index 7b21a128f3..b50370dfe8 100644 --- a/tools/patman/tools.py +++ b/tools/patman/tools.py @@ -3,7 +3,6 @@ # Copyright (c) 2016 Google, Inc #
-import command import glob import os import shutil @@ -11,7 +10,8 @@ import struct import sys import tempfile
# Output directly (generally this is temporary) outdir = None diff --git a/tools/patman/tout.py b/tools/patman/tout.py index ee3c519c80..c7e3272096 100644 --- a/tools/patman/tout.py +++ b/tools/patman/tout.py @@ -6,7 +6,7 @@
import sys
-import terminal +from patman import terminal
# Output verbosity levels that we support ERROR, WARNING, NOTICE, INFO, DETAIL, DEBUG = range(6) diff --git a/tools/rmboard.py b/tools/rmboard.py index 446e5d6ee2..1ed2527d0e 100755 --- a/tools/rmboard.py +++ b/tools/rmboard.py @@ -32,7 +32,7 @@ import sys our_path = os.path.dirname(os.path.realpath(__file__)) sys.path.append(os.path.join(our_path, '../tools/patman'))
def rm_kconfig_include(path): """Remove a path from Kconfig files
Now that we are using absolute paths we can remove some of the sys.path mangling that appears in the tools.
We only need to add the path to 'tools/' so that everything can find modules relative to that directory.
The special paths for finding pylibfdt remain.
Changes in v2: None
tools/binman/main.py | 5 +++-- tools/buildman/main.py | 3 +-- tools/buildman/test.py | 1 - tools/dtoc/main.py | 1 - tools/dtoc/test_fdt.py | 3 +-- tools/genboardscfg.py | 3 +-- tools/moveconfig.py | 2 -- tools/patman/main.py | 2 +- tools/rmboard.py | 1 - 9 files changed, 7 insertions(+), 14 deletions(-)
diff --git a/tools/binman/main.py b/tools/binman/main.py index 97a8a02034..efa7fa8386 100755 --- a/tools/binman/main.py +++ b/tools/binman/main.py @@ -20,8 +20,9 @@ import unittest # Bring in the patman and dtoc libraries (but don't override the first path # in PYTHONPATH) our_path = os.path.dirname(os.path.realpath(__file__)) -for dirname in ['../patman', '../dtoc', '../concurrencytest', '..']: - sys.path.insert(2, os.path.realpath(os.path.join(our_path, dirname))) +sys.path.insert(2, os.path.join(our_path, '..')) + +from patman import test_util
# Bring in the libfdt module sys.path.insert(2, 'scripts/dtc/pylibfdt') diff --git a/tools/buildman/main.py b/tools/buildman/main.py index 52a83fce7d..2b714739a2 100755 --- a/tools/buildman/main.py +++ b/tools/buildman/main.py @@ -16,7 +16,6 @@ import unittest # Bring in the patman libraries our_path = os.path.dirname(os.path.realpath(__file__)) sys.path.insert(1, os.path.join(our_path, '..')) -sys.path.insert(2, os.path.join(our_path, '../patman'))
# Our modules from buildman import board @@ -35,7 +34,7 @@ def RunTests(skip_net_tests): import doctest
result = unittest.TestResult() - for module in ['toolchain', 'gitutil']: + for module in ['buildman.toolchain', 'patman.gitutil']: suite = doctest.DocTestSuite(module) suite.run(result)
diff --git a/tools/buildman/test.py b/tools/buildman/test.py index b37c37b2fa..40811ba9f9 100644 --- a/tools/buildman/test.py +++ b/tools/buildman/test.py @@ -11,7 +11,6 @@ import unittest
# Bring in the patman libraries our_path = os.path.dirname(os.path.realpath(__file__)) -sys.path.append(os.path.join(our_path, '../patman'))
from buildman import board from buildman import bsettings diff --git a/tools/dtoc/main.py b/tools/dtoc/main.py index 8f3ec1deef..5a33c57ffd 100755 --- a/tools/dtoc/main.py +++ b/tools/dtoc/main.py @@ -32,7 +32,6 @@ import unittest
# Bring in the patman libraries our_path = os.path.dirname(os.path.realpath(__file__)) -sys.path.append(os.path.join(our_path, '../patman')) sys.path.append(os.path.join(our_path, '..'))
# Bring in the libfdt module diff --git a/tools/dtoc/test_fdt.py b/tools/dtoc/test_fdt.py index d68230713e..375e906424 100755 --- a/tools/dtoc/test_fdt.py +++ b/tools/dtoc/test_fdt.py @@ -14,8 +14,7 @@ import unittest
# Bring in the patman libraries our_path = os.path.dirname(os.path.realpath(__file__)) -for dirname in ['../patman', '..']: - sys.path.insert(0, os.path.join(our_path, dirname)) +sys.path.insert(1, os.path.join(our_path, '..'))
from dtoc import fdt from dtoc import fdt_util diff --git a/tools/genboardscfg.py b/tools/genboardscfg.py index 4f6382bc7c..4ee7aa1f89 100755 --- a/tools/genboardscfg.py +++ b/tools/genboardscfg.py @@ -22,8 +22,7 @@ import sys import tempfile import time
-sys.path.insert(1, os.path.join(os.path.dirname(__file__), 'buildman')) -import kconfiglib +from buildman import kconfiglib
### constant variables ### OUTPUT_FILE = 'boards.cfg' diff --git a/tools/moveconfig.py b/tools/moveconfig.py index 0dd8670403..36361f9ed1 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -314,8 +314,6 @@ import tempfile import threading import time
-sys.path.append(os.path.join(os.path.dirname(__file__), '..')) -sys.path.append(os.path.join(os.path.dirname(__file__), 'patman')) from buildman import bsettings from buildman import kconfiglib from buildman import toolchain diff --git a/tools/patman/main.py b/tools/patman/main.py index f59367fafb..f3d9c0c434 100755 --- a/tools/patman/main.py +++ b/tools/patman/main.py @@ -13,7 +13,7 @@ import sys import unittest
if __name__ == "__main__": - # Allow 'import xxx to work' + # Allow 'from patman import xxx to work' our_path = os.path.dirname(os.path.realpath(__file__)) sys.path.append(os.path.join(our_path, '..'))
diff --git a/tools/rmboard.py b/tools/rmboard.py index 1ed2527d0e..06c3562ad8 100755 --- a/tools/rmboard.py +++ b/tools/rmboard.py @@ -30,7 +30,6 @@ import sys
# Bring in the patman libraries our_path = os.path.dirname(os.path.realpath(__file__)) -sys.path.append(os.path.join(our_path, '../tools/patman'))
Changes in v2: None
sjg@google.com
